Move them to drivers/clocksource/i8253.c and remove the
implementations in arch/
[ tglx: Avoid the extra file in lib - folded arch patches in. The
export will become conditional in a later step ]
Link: http://lkml.kernel.org/r/20110601180610.221426078@duck.linux-mips.net
Cc: linux-mips@linux-mips.org
Link: http://lkml.kernel.org/r/20110601180610.134151920@duck.linux-mips.net
Link: http://lkml.kernel.org/r/20110601180610.054254048@duck.linux-mips.net
arch/arm/mach-footbridge/isa-timer.c | 2 +-
arch/mips/cobalt/time.c | 2 +-
arch/mips/jazz/irq.c | 2 +-
arch/mips/kernel/i8253.c | 2 +-
arch/mips/mti-malta/malta-time.c | 2 +-
arch/mips/sgi-ip22/ip22-time.c | 2 +-
arch/mips/sni/time.c | 2 +-
arch/x86/kernel/apic/apic.c | 2 +-
arch/x86/kernel/apm_32.c | 2 +-
arch/x86/kernel/hpet.c | 2 +-
arch/x86/kernel/i8253.c | 2 +-
arch/x86/kernel/time.c | 2 +-
drivers/block/hd.c | 2 +-
drivers/clocksource/i8253.c | 2 +-
drivers/input/gameport/gameport.c | 2 +-
drivers/input/joystick/analog.c | 2 +-
drivers/input/misc/pcspkr.c | 2 +-
include/linux/i8253.h | 11 +++++++++++
sound/drivers/pcsp/pcsp.h | 2 +-
19 files changed, 29 insertions(+), 18 deletions(-)
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/bug.fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: off by one errors in multicalls.c
xen: use the trigger info we already have to choose the irq handler
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86/amd-iommu: Fix boot crash with hidden PCI devices
x86/amd-iommu: Use only per-device dma_ops
x86/amd-iommu: Fix 3 possible endless loops
* 'kvm-updates/3.0' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: Initialize kvm before registering the mmu notifier
KVM: x86: use proper port value when checking io instruction permission
KVM: add missing void __user * cast to access_ok() call
Some PCIe cards ship with a PCI-PCIe bridge which is not
visible as a PCI device in Linux. But the device-id of the
bridge is present in the IOMMU tables which causes a boot
crash in the IOMMU driver.
This patch fixes by removing these cards from the IOMMU
handling. This is a pure -stable fix, a real fix to handle
this situation appriatly will follow for the next merge
window.
Cc: stable@kernel.org # > 2.6.32
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Unfortunatly there are systems where the AMD IOMMU does not
cover all devices. This breaks with the current driver as it
initializes the global dma_ops variable. This patch limits
the AMD IOMMU to the devices listed in the IVRS table fixing
DMA for devices not covered by the IOMMU.
The driver contains several loops counting on an u16 value
where the exit-condition is checked against variables that
can have values up to 0xffff. In this case the loops will
never exit. This patch fixed 3 such loops.
Commit f6511935f42 moved the permission check for io instructions
to the ->check_perm callback. It failed to copy the port value from RDX
register for string and "in,out ax,dx" instructions.
Fix it by reading RDX register at decode stage when appropriate.
Fixes FC8.32 installation.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
b->args[] has MC_ARGS elements, so the comparison here should be
">=" instead of ">". Otherwise we read past the end of the array
one space.
CC: stable@kernel.org
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
virtio_net: delay TX callbacks
virtio: add api for delayed callbacks
virtio_test: support event index
vhost: support event index
virtio_ring: support event idx feature
virtio ring: inline function to check for events
virtio: event index interface
virtio: add full three-clause BSD text to headers.
virtio balloon: kill tell-host-first logic
virtio console: don't manually set or finalize VIRTIO_CONSOLE_F_MULTIPORT.
drivers, block: virtio_blk: Replace cryptic number with the macro
virtio_blk: allow re-reading config space at runtime
lguest: remove support for VIRTIO_F_NOTIFY_ON_EMPTY.
lguest: fix up compilation after move
lguest: fix timer interrupt setup
x86: Fix mwait_play_dead() faulting on mwait-incapable cpus
x86 idle: Fix mwait deprecation warning message
Evil merge to remove extra quote noticed by Joe Perches
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Put back -pg to tsc.o and add no GCOV to vread_tsc_64.o
A logic error in mwait_play_dead() causes the kernel to use
mwait even on cpus which don't support it, such as KVM virtual
cpus.
Introduced by:
349c004e3d31: x86: A fast way to check capabilities of the current cpu
Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=36222
Reported-by: Török Edwin <edwintorok@gmail.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Tejun Heo <tj@kernel.org>
Link: http://lkml.kernel.org/r/1306758237-9327-1-git-send-email-avi@redhat.com
Fix:
arch/x86/kernel/process.c:645:1: warning: unknown escape sequence '\i'
due to missing escape backslash, introduced by this commit:
5d4c47e0195b: x86 idle: deprecate mwait_idle() and "idle=mwait" cmdline param
Signed-off-by: Borislav Petkov <bp@alien8.de>
Cc: Len Brown <len.brown@intel.com>
Link: http://lkml.kernel.org/r/1306748286-24701-1-git-send-email-bp@alien8.de
Without an IRQ chip set, we now get a WARN_ON and no timer interrupt. This
prevents booting.
Fortunately, the fix is a one-liner: set up the timer IRQ like everything
else.
Cc: stable@kernel.org # .39.x
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6
* 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6:
x86 idle: deprecate "no-hlt" cmdline param
x86 idle APM: deprecate CONFIG_APM_CPU_IDLE
x86 idle floppy: deprecate disable_hlt()
x86 idle: EXPORT_SYMBOL(default_idle, pm_idle) only when APM demands it
x86 idle: clarify AMD erratum 400 workaround
idle governor: Avoid lock acquisition to read pm_qos before entering idle
cpuidle: menu: fixed wrapping timers at 4.294 seconds
mwait_idle() is a C1-only idle loop intended to be more efficient
than HLT on SMP hardware that supports it.
But mwait_idle() has been replaced by the more general
mwait_idle_with_hints(), which handles both C1 and deeper C-states.
ACPI uses only mwait_idle_with_hints(), and never uses mwait_idle().
Deprecate mwait_idle() and the "idle=mwait" cmdline param
to simplify the x86 idle code.
After this change, kernels configured with
(!CONFIG_ACPI=n && !CONFIG_INTEL_IDLE=n) when run on hardware
that support MWAIT will simply use HLT. If MWAIT is desired
on those systems, cpuidle and the cpuidle drivers above
can be used.
cc: x86@kernel.org
cc: stable@kernel.org # .39.x
Signed-off-by: Len Brown <len.brown@intel.com>
We'd rather that modern machines not check if HLT works on
every entry into idle, for the benefit of machines that had
marginal electricals 15-years ago. If those machines are still running
the upstream kernel, they can use "idle=poll". The only difference
will be that they'll now invoke HLT in machine_hlt().
cc: x86@kernel.org # .39.x
We don't want to export the pm_idle function pointer to modules.
Currently CONFIG_APM_CPU_IDLE w/ CONFIG_APM_MODULE forces us to.
CONFIG_APM_CPU_IDLE is of dubious value, it runs only on 32-bit
uniprocessor laptops that are over 10 years old. It calls into
the BIOS during idle, and is known to cause a number of machines
to fail.
Removing CONFIG_APM_CPU_IDLE and will allow us to stop exporting
pm_idle. Any systems that were calling into the APM BIOS
at run-time will simply use HLT instead.
cc: x86@kernel.org
cc: Jiri Kosina <jkosina@suse.cz>
In the long run, we don't want default_idle() or (pm_idle)() to
be exported outside of process.c. Start by not exporting them
to modules, unless the APM build demands it.
cc: x86@kernel.org
The workaround for AMD erratum 400 uses the term "c1e" falsely suggesting:
1. Intel C1E is somehow involved
2. All AMD processors with C1E are involved
Use the string "amd_c1e" instead of simply "c1e" to clarify that
this workaround is specific to AMD's version of C1E.
Use the string "e400" to clarify that the workaround is specific
to AMD processors with Erratum 400.
This patch is text-substitution only, with no functional change.
cc: x86@kernel.org
Acked-by: Borislav Petkov <borislav.petkov@amd.com>
x86, asm: Clean up desc.h a bit
x86, amd: Do not enable ARAT feature on AMD processors below family 0x12
x86: Move do_page_fault()'s error path under unlikely()
x86, efi: Retain boot service code until after switching to virtual mode
x86: Remove unnecessary check in detect_ht()
x86: Reorder mm_context_t to remove x86_64 alignment padding and thus shrink mm_struct
x86, UV: Clean up uv_tlb.c
x86, UV: Add support for SGI UV2 hub chip
x86, cpufeature: Update CPU feature RDRND to RDRAND
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits)
perf: Fix SIGIO handling
perf top: Don't stop if no kernel symtab is found
perf top: Handle kptr_restrict
perf top: Remove unused macro
perf events: initialize fd array to -1 instead of 0
perf tools: Make sure kptr_restrict warnings fit 80 col terms
perf tools: Fix build on older systems
perf symbols: Handle /proc/sys/kernel/kptr_restrict
perf: Remove duplicate headers
ftrace: Add internal recursive checks
tracing: Update btrfs's tracepoints to use u64 interface
tracing: Add __print_symbolic_u64 to avoid warnings on 32bit machine
ftrace: Set ops->flag to enabled even on static function tracing
tracing: Have event with function tracer check error return
ftrace: Have ftrace_startup() return failure code
jump_label: Check entries limit in __jump_label_update
ftrace/recordmcount: Avoid STT_FUNC symbols as base on ARM
scripts/tags.sh: Add magic for trace-events for etags too
scripts/tags.sh: Fix ctags for DEFINE_EVENT()
x86/ftrace: Fix compiler warning in ftrace.c
* setns:
ns: Wire up the setns system call
Done as a merge to make it easier to fix up conflicts in arm due to
addition of sendmmsg system call
32bit and 64bit on x86 are tested and working. The rest I have looked
at closely and I can't find any problems.
setns is an easy system call to wire up. It just takes two ints so I
don't expect any weird architecture porting problems.
While doing this I have noticed that we have some architectures that are
very slow to get new system calls. cris seems to be the slowest where
the last system calls wired up were preadv and pwritev. avr32 is weird
in that recvmmsg was wired up but never declared in unistd.h. frv is
behind with perf_event_open being the last syscall wired up. On h8300
the last system call wired up was epoll_wait. On m32r the last system
call wired up was fallocate. mn10300 has recvmmsg as the last system
call wired up. The rest seem to at least have syncfs wired up which was
new in the 2.6.39.
v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com>
v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com>
v4: Moved wiring up of the system call to another patch
v5: ported to v2.6.39-rc6
v6: rebased onto parisc-next and net-next to avoid syscall conflicts.
v7: ported to Linus's latest post 2.6.39 tree.
> arch/blackfin/include/asm/unistd.h | 3 ++-
> arch/blackfin/mach-common/entry.S | 1 +
Oh - ia64 wiring looks good.
Acked-by: Tony Luck <tony.luck@intel.com>
The commit 44259b1abfaa8bb819d25d41d71e8e33e25dd36a
Author: Andy Lutomirski <luto@MIT.EDU>
x86-64: Move vread_tsc into a new file with sensible options
Removed the -pg from tsc.o which caused the function graph tracer
to go into an infinite function call recursion as it uses the tsc
internally outside its recursion protection, thus tracing the tsc
breaks the function graph tracer.
This commit also added the file vread_tsc_64.c that gets used
by vdso but failed to prevent GCOV from monkeying with it,
causing userspace to try to access kernel data when GCOV was
enabled.
Thanks to Thomas Gleixner for pointing out GCOV as the likely
culprit that added strange kernel accesses into the vread_tsc()
call.
Cc: Author: Andy Lutomirski <luto@MIT.EDU>
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM: Fix PM QOS's user mode interface to work with ASCII input
PM / Hibernate: Update kerneldoc comments in hibernate.c
PM / Hibernate: Remove arch_prepare_suspend()
PM / Hibernate: Update some comments in core hibernate code
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/urgent
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/urgent
I have looked at this file and found it rather ugly - improve
readability a bit. No change in functionality.
Link: http://lkml.kernel.org/n/tip-incpt6y26yd8586idx65t9ll@git.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
* 'upstream/tidy-xen-mmu-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
xen: fix compile without CONFIG_XEN_DEBUG_FS
Use arbitrary_virt_to_machine() to deal with ioremapped pud updates.
Use arbitrary_virt_to_machine() to deal with ioremapped pmd updates.
xen/mmu: remove all ad-hoc stats stuff
xen: use normal virt_to_machine for ptes
xen: make a pile of mmu pvop functions static
vmalloc: remove vmalloc_sync_all() from alloc_vm_area()
xen: condense everything onto xen_set_pte
xen: use mmu_update for xen_set_pte_at()
xen: drop all the special iomap pte paths.
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT,
CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used
to test for existence of find bitops anymore.
Acked-by: Greg Ungerer <gerg@uclinux.org>
The Blackfin arch, like the x86 arch, needs to adjust the PC manually
after a breakpoint is hit as normally this is handled by the remote gdb.
However, rather than starting another arch ifdef mess, create a common
GDB_ADJUSTS_BREAK_OFFSET define for any arch to opt-in via their kgdb.h.
Cc: Jason Wessel <jason.wessel@windriver.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Dongdong Deng <dongdong.deng@windriver.com>
Cc: Sergei Shtylyov <sshtylyov@mvista.com>
Cc: Dongdong Deng <dongdong.deng@windriver.com>
The ns_cgroup is an annoying cgroup at the namespace / cgroup frontier and
leads to some problems:
* cgroup creation is out-of-control
* cgroup name can conflict when pids are looping
* it is not possible to have a single process handling a lot of
namespaces without falling in a exponential creation time
* we may want to create a namespace without creating a cgroup
The ns_cgroup was replaced by a compatibility flag 'clone_children',
where a newly created cgroup will copy the parent cgroup values.
The userspace has to manually create a cgroup and add a task to
the 'tasks' file.
This patch removes the ns_cgroup as suggested in the following thread:
https://lists.linux-foundation.org/pipermail/containers/2009-June/018616.html
The 'cgroup_clone' function is removed because it is no longer used.
This is a userspace-visible change. Commit 45531757b45c ("cgroup: notify
ns_cgroup deprecated") (merged into 2.6.27) caused the kernel to emit a
printk warning users that the feature is planned for removal. Since that
time we have heard from XXX users who were affected by this.
Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr>
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Jamal Hadi Salim <hadi@cyberus.ca>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Paul Menage <menage@google.com>
Acked-by: Matt Helsley <matthltc@us.ibm.com>
* 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: vdso: Remove unused variable
x86-64: Optimize vDSO time()
x86-64: Add time to vDSO
x86-64: Turn off -pg and turn on -foptimize-sibling-calls for vDSO
x86-64: Vclock_gettime(CLOCK_MONOTONIC) can't ever see nsec < 0
x86-64: Don't generate cmov in vread_tsc
x86-64: Remove unnecessary barrier in vread_tsc
x86-64: Clean up vdso/kernel shared variables
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
seqlock: Get rid of SEQLOCK_UNLOCKED
* 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
irq: Remove smp_affinity_list when unregister irq proc
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem:
xen: cleancache shim to Xen Transcendent Memory
ocfs2: add cleancache support
ext4: add cleancache support
btrfs: add cleancache support
ext3: add cleancache support
mm/fs: add hooks to support cleancache
mm: cleancache core ops functions and config
fs: add field to superblock to support cleancache
mm/fs: cleancache documentation
Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
Commit b87cf80af3ba4b4c008b4face3c68d604e1715c6 added support for
ARAT (Always Running APIC timer) on AMD processors that are not
affected by erratum 400. This erratum is present on certain processor
families and prevents APIC timer from waking up the CPU when it
is in a deep C state, including C1E state.
Determining whether a processor is affected by this erratum may
have some corner cases and handling these cases is somewhat
complicated. In the interest of simplicity we won't claim ARAT
support on processor families below 0x12 and will go back to
broadcasting timer when going idle.
Signed-off-by: Boris Ostrovsky <ostr@amd64.org>
Link: http://lkml.kernel.org/r/1306423192-19774-1-git-send-email-ostr@amd64.org
Tested-by: Boris Petkov <borislav.petkov@amd.com>
Cc: Hans Rosenfeld <Hans.Rosenfeld@amd.com>
Cc: Andreas Herrmann <Andreas.Herrmann3@amd.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
Cc: stable@kernel.org # 32.x, 38.x, 39.x
This patch provides a shim between the kernel-internal cleancache
API (see Documentation/mm/cleancache.txt) and the Xen Transcendent
Memory ABI (see http://oss.oracle.com/projects/tmem).
Xen tmem provides "hypervisor RAM" as an ephemeral page-oriented
pseudo-RAM store for cleancache pages, shared cleancache pages,
and frontswap pages. Tmem provides enterprise-quality concurrency,
full save/restore and live migration support, compression
and deduplication.
A presentation showing up to 8% faster performance and up to 52%
reduction in sectors read on a kernel compile workload, despite
aggressive in-kernel page reclamation ("self-ballooning") can be
found at:
http://oss.oracle.com/projects/tmem/dist/documentation/presentations/TranscendentMemoryXenSummit2010.pdf
Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com>
Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Rik Van Riel <riel@redhat.com>
Cc: Jan Beulich <JBeulich@novell.com>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Andreas Dilger <adilger@sun.com>
Cc: Ted Ts'o <tytso@mit.edu>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Joel Becker <joel.becker@oracle.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Ingo suggested SIGKILL check should be moved into slowpath
function. This will reduce the page fault fastpath impact
of this recent commit:
37b23e0525d3: x86,mm: make pagefault killable
Suggested-by: Ingo Molnar <mingo@elte.hu>
Cc: kamezawa.hiroyu@jp.fujitsu.com
Cc: minchan.kim@gmail.com
Cc: willy@linux.intel.com
Link: http://lkml.kernel.org/r/4DDE0B5C.9050907@jp.fujitsu.com
Merge reason: we want to queue up a dependent patch.
Reported-by: Peter Zijlstra <peterz@infradead.org>
Cc: Andy Lutomirski <luto@mit.edu>
UEFI stands for "Unified Extensible Firmware Interface", where "Firmware"
is an ancient African word meaning "Why do something right when you can
do it so wrong that children will weep and brave adults will cower before
you", and "UEI" is Celtic for "We missed DOS so we burned it into your
ROMs". The UEFI specification provides for runtime services (ie, another
way for the operating system to be forced to depend on the firmware) and
we rely on these for certain trivial tasks such as setting up the
bootloader. But some hardware fails to work if we attempt to use these
runtime services from physical mode, and so we have to switch into virtual
mode. So far so dreadful.
The specification makes it clear that the operating system is free to do
whatever it wants with boot services code after ExitBootServices() has been
called. SetVirtualAddressMap() can't be called until ExitBootServices() has
been. So, obviously, a whole bunch of EFI implementations call into boot
services code when we do that. Since we've been charmingly naive and
trusted that the specification may be somehow relevant to the real world,
we've already stuffed a picture of a penguin or something in that address
space. And just to make things more entertaining, we've also marked it
non-executable.
This patch allocates the boot services regions during EFI init and makes
sure that they're executable. Then, after SetVirtualAddressMap(), it
discards them and everyone lives happily ever after. Except for the ones
who have to work on EFI, who live sad lives haunted by the knowledge that
someone's eventually going to write yet another firmware specification.
[ hpa: adding this to urgent with a stable tag since it fixes currently-broken
hardware. However, I do not know what the dependencies are and so I do
not know which -stable versions this may be a candidate for. ]
Link: http://lkml.kernel.org/r/1306331593-28715-1-git-send-email-mjg@redhat.com
Cc: <stable@kernel.org>
Due to commit dc326fca2b64 (x86, cpu: Clean up and unify the NOP selection infrastructure), we get the following warning:
arch/x86/kernel/ftrace.c: In function ‘ftrace_make_nop’:
arch/x86/kernel/ftrace.c:308:6: warning: assignment discards qualifiers from pointer target type
arch/x86/kernel/ftrace.c: In function ‘ftrace_make_call’:
arch/x86/kernel/ftrace.c:318:6: warning: assignment discards qualifiers from pointer target type
ftrace_nop_replace() now returns const unsigned char *, so change its associated function/variable to its compatible type to keep compiler clam.
Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com>
Link: http://lkml.kernel.org/r/1305221620.7986.4.camel@localhost.localdomain
[ updated for change of const void *src in probe_kernel_write() ]
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon: New driver for the SMSC EMC6W201
hwmon: (abituguru) Depend on DMI
hwmon: (it87) Use request_muxed_region
hwmon: (sch5627) Trigger Vbat measurements
hwmon: (sch5627) Add sch5627_send_cmd function
i8k: Integrate with the hwmon subsystem
hwmon: (max6650) Properly support the MAX6650
hwmon: (max6650) Drop device detection
Move ACPI power meter driver to hwmon
hwmon: (f71882fg) Add support for F71808A
hwmon: (f71882fg) Split has_beep in fan_has_beep and temp_has_beep
hwmon: (asc7621) Drop duplicate dependency
hwmon: (jc42) Change detection class
hwmon: Add driver for AMD family 15h processor power information
hwmon: (k10temp) Add support for Fam15h (Bulldozer)
hwmon: Use helper functions to set and get driver data
i8k: Avoid lahf in 64-bit code
This patch removes a check that causes incorrect scheduler
domain setup (SMP instead of SMT) and bootlog warning messages
when cpuid extensions for topology enumeration are not supported
and the number of processors reported to the OS is smaller than
smp_num_siblings.
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Signed-off-by: Nikhil P Rao <nikhil.rao@intel.com>
Link: http://lkml.kernel.org/r/1306343921.19325.1.camel@fedora13
Let i8k create an hwmon class device so that libsensors will expose
the CPU temperature and fan speeds to monitoring applications.
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: Massimo Dal Zotto <dz@debian.org>
