commit f0adb134d8dc9993a9998dc50845ec4f6ff4fadc upstream.
Fixes bugzilla #13780
Signed-off-by: Dave Jones <davej@redhat.com>
(cherry picked from commit dc7e795e3dd2a763e5ceaa1615f307e808cf3932)
This reverts commit 6c20e1442bb1c62914bb85b7f4a38973d2a423ba.
To my understanding, it became obsolete with the advent of the more
robust check in mmu_alloc_roots (89da4ff17f). Moreover, it prevents
the conceptually safe pattern
1. set sregs
2. register mem-slots
3. run vcpu
by setting a sticky triple fault during step 1.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
(cherry picked from commit 88c808fd42b53a7e01a2ac3253ef31fef74cb5af)
update_cr8_intercept() can be triggered from userspace while there
is no apic present.
Cc: Marcelo Tosatti <mtosatti@redhat.com>
(cherry picked from commit b90c062c65cc8839edfac39778a37a55ca9bda36)
Remove the bogus n_free_mmu_pages assignment from alloc_mmu_pages.
It breaks accounting of mmu pages, since n_free_mmu_pages is modified
but the real number of pages remains the same.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
(cherry picked from commit 6a1ac77110ee3e8d8dfdef8442f3b30b3d83e6a2)
n_requested_mmu_pages/n_free_mmu_pages are used by
kvm_mmu_change_mmu_pages to calculate the number of pages to zap.
alloc_mmu_pages, called from the vcpu initialization path, modifies this
variables without proper locking, which can result in a negative value
in kvm_mmu_change_mmu_pages (say, with cpu hotplug).
(cherry picked from commit cb007648de83cf226d69ec76e1c01848b4e8e49f)
If we run out of cpuid entries for extended request types
we should return -E2BIG, just like we do for the standard
request types.
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
commit e517a5e97080bbe52857bd0d7df9b66602d53c4d upstream.
Ever since we enabled GEM, the pre-9xx chipsets (particularly 865) have had
serious stability issues. Back in May a wbinvd was added to the DRM to
work around much of the problem. Some failure remained -- easily visible
by dragging a window around on an X -retro desktop, or by looking at bugzilla.
The chipset flush was on the right track -- hitting the right amount of
memory, and it appears to be the only way to flush on these chipsets, but the
flush page was mapped uncached. As a result, the writes trying to clear the
writeback cache ended up bypassing the cache, and not flushing anything! The
wbinvd would flush out other writeback data and often cause the data we wanted
to get flushed, but not always. By removing the setting of the page to UC
and instead just clflushing the data we write to try to flush it, we get the
desired behavior with no wbinvd.
This exports clflush_cache_range(), which was laying around and happened to
basically match the code I was otherwise going to copy from the DRM.
Signed-off-by: Eric Anholt <eric@anholt.net>
Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org>
commit d2374aecda3f6c9b0d13287027132a37311da300 upstream.
The UV BIOS has changed the way interrupt remapping is being done.
This affects the id used for sending IPIs. The upper id bits no
longer need to be masked off.
Signed-off-by: Jack Steiner <steiner@sgi.com>
LKML-Reference: <20090909154104.GA25083@sgi.com>
commit b75fe4e5b869f8dbebd36df64a7fcda0c5b318ed upstream.
x86-64 assumes NX is available by default, so we need to
explicitly check for it before using NX. Some first-generation
Intel x86-64 processors didn't support NX, and even recent systems
allow it to be disabled in BIOS.
[ Impact: prevent Xen crash on NX-less 64-bit machines ]
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
commit 2496afbf1e50c70f80992656bcb730c8583ddac3 upstream.
We need to have a stronger barrier between releasing the lock and
checking for any waiting spinners. A compiler barrier is not sufficient
because the CPU's ordering rules do not prevent the read xl->spinners
from happening before the unlock assignment, as they are different
memory locations.
We need to have an explicit barrier to enforce the write-read ordering
to different memory locations.
Because of it, I can't bring up > 4 HVM guests on one SMP machine.
[ Code and commit comments expanded -J ]
[ Impact: avoid deadlock when using Xen PV spinlocks ]
Signed-off-by: Yang Xiaowei <xiaowei.yang@intel.com>
commit 4d576b57b50a92801e6493e76e5243d6cff193d2 upstream.
Where possible we enable interrupts while waiting for a spinlock to
become free, in order to reduce big latency spikes in interrupt handling.
However, at present if we manage to pick up the spinlock just before
blocking, we'll end up holding the lock with interrupts enabled for a
while. This will cause a deadlock if we recieve an interrupt in that
window, and the interrupt handler tries to take the lock too.
Solve this by shrinking the interrupt-enabled region to just around the
blocking call.
[ Impact: avoid race/deadlock when using Xen PV spinlocks ]
Reported-by: "Yang, Xiaowei" <xiaowei.yang@intel.com>
commit 577eebeae34d340685d8985dfdb7dfe337c511e8 upstream.
-fstack-protector uses a special per-cpu "stack canary" value.
gcc generates special code in each function to test the canary to make
sure that the function's stack hasn't been overrun.
On x86-64, this is simply an offset of %gs, which is the usual per-cpu
base segment register, so setting it up simply requires loading %gs's
base as normal.
On i386, the stack protector segment is %gs (rather than the usual kernel
percpu %fs segment register). This requires setting up the full kernel
GDT and then loading %gs accordingly. We also need to make sure %gs is
initialized when bringing up secondary cpus too.
To keep things consistent, we do the full GDT/segment register setup on
both architectures.
Because we need to avoid -fstack-protected code before setting up the GDT
and because there's no way to disable it on a per-function basis, several
files need to have stack-protector inhibited.
[ Impact: allow Xen booting with stack-protector enabled ]
commit 80938332d8cf652f6b16e0788cf0ca136befe0b5 upstream.
Currently we are not including randomized stack size when calculating
mmap_base address in arch_pick_mmap_layout for topdown case. This might
cause that mmap_base starts in the stack reserved area because stack is
randomized by 1GB for 64b (8MB for 32b) and the minimum gap is 128MB.
If the stack really grows down to mmap_base then we can get silent mmap
region overwrite by the stack values.
Let's include maximum stack randomization size into MIN_GAP which is
used as the low bound for the gap in mmap.
LKML-Reference: <1252400515-6866-1-git-send-email-mhocko@suse.cz>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit 95eb84a7588d7d7afd3096807efc052adc7479e1 upstream
QNX update WP bit when paging enabled, which is not covered yet. This one
fix QNX boot with EPT.
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
commit 1444885a045fe3b1905a14ea1b52540bf556578b upstream.
Otherwise its possible to starve the host by programming lapic timer
with a very high frequency.
commit ee3d29e8bee8d7c321279a9bd9bd25d4cfbf79b7 upstream.
The jump target should not be sign extened; use an unsigned decode flag.
commit 3b80fffe2b31fb716d3ebe729c54464ee7856723 upstream.
First check if the list is empty before attempting to look at list
entries.
Signed-off-by: Izik Eidus <ieidus@redhat.com>
commit c9eaf20f268c7051bfde2ba212c5ea76a6cbc7a1 upstream.
Absolute jumps use zero extended immediate operands.
commit 5fff7d270bd6a4759b6d663741b729cdee370257 upstream.
Don't call adjust_vmx_controls() two times for the same control.
It restores options that were dropped earlier. This loses us the cr8
exit control, which causes a massive performance regression Windows x64.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
commit 07708c4af1346ab1521b26a202f438366b7bcffd upstream.
So far unprivileged guest callers running in ring 3 can issue, e.g., MMU
hypercalls. Normally, such callers cannot provide any hand-crafted MMU
command structure as it has to be passed by its physical address, but
they can still crash the guest kernel by passing random addresses.
To close the hole, this patch considers hypercalls valid only if issued
from guest ring 0. This may still be relaxed on a per-hypercall base in
the future once required.
commit a20316d2aa41a8f4fd171648bad8f044f6060826 upstream.
The use of __pa() to calculate the address of a C-visible symbol
is wrong, and can lead to unpredictable results. See arch/x86/include/asm/page.h
for details.
It should be replaced with __pa_symbol(), that does the correct math here,
by taking relocations into account. This ensures the correct wallclock data
structure physical address is passed to the hypervisor.
Signed-off-by: Glauber Costa <glommer@redhat.com>
commit 0a79b009525b160081d75cef5dbf45817956acf2 upstream.
Debug registers may only be accessed from cpl 0. Unfortunately, vmx will
code to emulate the instruction even though it was issued from guest
userspace, possibly leading to an unexpected trap later.
commit 6ba661787594868512a71c129062ebd57d0c01e7 upstream.
Commit b8bcfe997e4 made paravirt pte updates synchronous in interrupt
context.
Unfortunately the KVM pv mmu code caches the lazy/nonlazy mode
internally, so a pte update from interrupt context during a lazy mmu
operation can be batched while it should be performed synchronously.
https://bugzilla.redhat.com/show_bug.cgi?id=518022
Drop the internal mode variable and use paravirt_get_lazy_mode(), which
returns the correct state.
commit fa526d0d641b5365676a1fb821ce359e217c9b85 upstream.
Fix address passed to cpa_flush_range() when changing page
attributes from WB to UC. The address (*addr) is
modified by __change_page_attr_set_clr(). The result is that
the pages being flushed start at the _end_ of the changed range
instead of the beginning.
This should be considered for 2.6.30-stable and 2.6.31-stable.
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
commit 1ea0d14e480c245683927eecc03a70faf06e80c8 upstream.
The Intel Optimization Reference Guide says:
In Intel Atom microarchitecture, the address generation unit
assumes that the segment base will be 0 by default. Non-zero
segment base will cause load and store operations to experience
a delay.
- If the segment base isn't aligned to a cache line
boundary, the max throughput of memory operations is
reduced to one [e]very 9 cycles.
Assembly/Compiler Coding Rule 15. (H impact, ML generality)
For Intel Atom processors, use segments with base set to 0
whenever possible; avoid non-zero segment base address that is
not aligned to cache line boundary at all cost.
We can't avoid having a non-zero base for the stack-protector
segment, but we can make it cache-aligned.
LKML-Reference: <4AA01893.6000507@goop.org>
commit 005155b1f626d2b2d7932e4afdf4fead168c6888 upstream.
For the x86_model to be greater than 6 or less than 12 is
logically always true.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
commit e0faf54ee82bf9c07f0307b4391caad4020bd659 upstream.
The amd_iommu_pd_table is indexed by protection domain
number and not by device id. So this check is broken and
must be removed.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2.6.31-rc7 does not boot on vSMP systems:
[ 8.501108] CPU31: Thermal monitoring enabled (TM1)
[ 8.501127] CPU 31 MCA banks SHD:2 SHD:3 SHD:5 SHD:6 SHD:8
[ 8.650254] CPU31: Intel(R) Xeon(R) CPU E5540 @ 2.53GHz stepping 04
[ 8.710324] Brought up 32 CPUs
[ 8.713916] Total of 32 processors activated (162314.96 BogoMIPS).
[ 8.721489] ERROR: parent span is not a superset of domain->span
[ 8.727686] ERROR: domain->groups does not contain CPU0
[ 8.733091] ERROR: groups don't span domain->span
[ 8.737975] ERROR: domain->cpu_power not set
[ 8.742416]
Ravikiran Thirumalai bisected it to:
| commit 2759c3287de27266e06f1f4e82cbd2d65f6a044c
| x86: don't call read_apic_id if !cpu_has_apic
The problem is that on vSMP systems the CPUID derived
initial-APICIDs are overlapping - so we need to fall
back on hard_smp_processor_id() which reads the local
APIC.
Both come from the hardware (influenced by firmware
though) so it's a tough call which one to trust.
Doing the quirk expresses the vSMP property properly
and also does not affect other systems, so we go for
this solution instead of a revert.
Reported-and-Tested-by: Ravikiran Thirumalai <kiran@scalex86.org>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Cc: Shai Fultheim <shai@scalex86.org>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <4A944D3C.5030100@kernel.org>
Initialize cx before calling xen_cpuid(), in order to suppress the
"may be used uninitialized in this function" warning.
Xen always runs on CPUs which properly support WP enforcement in
privileged mode, so there's no need to test for it.
This also works around a crash reported by Arnd Hannemann, though I
think its just a band-aid for that case.
Reported-by: Arnd Hannemann <hannemann@nets.rwth-aachen.de>
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
clockevent: Prevent dead lock on clockevents_lock
timers: Drop write permission on /proc/timer_list
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Fix build with older binutils and consolidate linker script
x86: Fix an incorrect argument of reserve_bootmem()
x86: add vmlinux.lds to targets in arch/x86/boot/compressed/Makefile
xen: rearrange things to fix stackprotector
x86: make sure load_percpu_segment has no stackprotector
i386: Fix section mismatches for init code with !HOTPLUG_CPU
x86, pat: Allow ISA memory range uncacheable mapping requests
binutils prior to 2.17 can't deal with the currently possible
situation of a new segment following the per-CPU segment, but
that new segment being empty - objcopy misplaces the .bss (and
perhaps also the .brk) sections outside of any segment.
However, the current ordering of sections really just appears
to be the effect of cumulative unrelated changes; re-ordering
things allows to easily guarantee that the segment following
the per-CPU one is non-empty, and at once eliminates the need
for the bogus data.init2 segment.
Once touching this code, also use the various data section
helper macros from include/asm-generic/vmlinux.lds.h.
-v2: fix !SMP builds.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: <sam@ravnborg.org>
LKML-Reference: <4A94085D02000078000119A5@vpn.id2.novell.com>
This line looks suspicious, because if this is true, then the
'flags' parameter of function reserve_bootmem_generic() will be
unused when !CONFIG_NUMA. I don't think this is what we want.
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: akpm@linux-foundation.org
LKML-Reference: <20090821083709.5098.52505.sendpatchset@localhost.localdomain>
As noted in 83d349f35e1ae72268c5104dbf9ab2ae635425d4 ("x86: don't send
an IPI to the empty set of CPU's"), some APIC's will be very unhappy
with an empty destination mask. That commit added a WARN_ON() for that
case, and avoided the resulting problem, but didn't fix the underlying
reason for why those empty mask cases happened.
This fixes that, by checking the result of 'cpumask_andnot()' of the
current CPU actually has any other CPU's left in the set of CPU's to be
sent a TLB flush, and not calling down to the IPI code if the mask is
empty.
The reason this started happening at all is that we started passing just
the CPU mask pointers around in commit 4595f9620 ("x86: change
flush_tlb_others to take a const struct cpumask"), and when we did that,
the cpumask was no longer thread-local.
Before that commit, flush_tlb_mm() used to create it's own copy of
'mm->cpu_vm_mask' and pass that copy down to the low-level flush
routines after having tested that it was not empty. But after changing
it to just pass down the CPU mask pointer, the lower level TLB flush
routines would now get a pointer to that 'mm->cpu_vm_mask', and that
could still change - and become empty - after the test due to other
CPU's having flushed their own TLB's.
See
http://bugzilla.kernel.org/show_bug.cgi?id=13933
for details.
Tested-by: Thomas Björnell <thomas.bjornell@gmail.com>
Cc: stable@kernel.org
The default_send_IPI_mask_logical() function uses the "flat" APIC mode
to send an IPI to a set of CPU's at once, but if that set happens to be
empty, some older local APIC's will apparently be rather unhappy. So
just warn if a caller gives us an empty mask, and ignore it.
This fixes a regression in 2.6.30.x, due to commit 4595f9620 ("x86:
change flush_tlb_others to take a const struct cpumask"), documented
here:
which causes a silent lock-up. It only seems to happen on PPro, P2, P3
and Athlon XP cores. Most developers sadly (or not so sadly, if you're
a developer..) have more modern CPU's. Also, on x86-64 we don't use the
flat APIC mode, so it would never trigger there even if the APIC didn't
like sending an empty IPI mask.
Reported-by: Pavel Vilim <wylda@volny.cz>
Reported-and-tested-by: Thomas Björnell <thomas.bjornell@gmail.com>
Reported-and-tested-by: Martin Rogge <marogge@onlinehome.de>
Cc: Mike Travis <travis@sgi.com>
The absence of vmlinux.lds here keeps .vmlinux.lds.cmd from being
included, which in turn leads to it and all its dependents always
getting rebuilt independent of whether they are already up-to-date.
LKML-Reference: <4A8D84670200007800010D31@vpn.id2.novell.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen into x86/urgent
Make sure the stack-protector segment registers are properly set up
before calling any functions which may have stack-protection compiled
into them.
[ Impact: prevent Xen early-boot crash when stack-protector is enabled ]
load_percpu_segment() is used to set up the per-cpu segment registers,
which are also used for -fstack-protector. Make sure that the
load_percpu_segment() function doesn't have stackprotector enabled.
[ Impact: allow percpu setup before calling stack-protected functions ]
Currently clockevents_notify() is called with interrupts enabled at
some places and interrupts disabled at some other places.
This results in a deadlock in this scenario.
cpu A holds clockevents_lock in clockevents_notify() with irqs enabled
cpu B waits for clockevents_lock in clockevents_notify() with irqs disabled
cpu C doing set_mtrr() which will try to rendezvous of all the cpus.
This will result in C and A come to the rendezvous point and waiting
for B. B is stuck forever waiting for the spinlock and thus not
reaching the rendezvous point.
Fix the clockevents code so that clockevents_lock is taken with
interrupts disabled and thus avoid the above deadlock.
Also call lapic_timer_propagate_broadcast() on the destination cpu so
that we avoid calling smp_call_function() in the clockevents notifier
chain.
This issue left us wondering if we need to change the MTRR rendezvous
logic to use stop machine logic (instead of smp_call_function) or add
a check in spinlock debug code to see if there are other spinlocks
which gets taken under both interrupts enabled/disabled conditions.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: "Pallipadi Venkatesh" <venkatesh.pallipadi@intel.com>
Cc: "Brown Len" <len.brown@intel.com>
LKML-Reference: <1250544899.2709.210.camel@sbs-t61.sc.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: use the right flag for get_vm_area()
percpu, sparc64: fix sparse possible cpu map handling
init: set nr_cpu_ids before setup_per_cpu_areas()
Commit 0e83815be719d3391bf5ea24b7fe696c07dbd417 changed the
section the initial_code variable gets allocated in, in an
attempt to address a section conflict warning. This, however
created a new section conflict when building without
HOTPLUG_CPU. The apparently only (reasonable) way to address
this is to always use __REFDATA.
Once at it, also fix a second section mismatch when not using
HOTPLUG_CPU.
Cc: Robert Richter <robert.richter@amd.com>
LKML-Reference: <4A8AE7CD020000780001054B@vpn.id2.novell.com>
Max Vozeler reported:
> Bug 13877 - bogl-term broken with CONFIG_X86_PAT=y, works with =n
> strace of bogl-term:
> 814 mmap2(NULL, 65536, PROT_READ|PROT_WRITE, MAP_SHARED, 4, 0)
> = -1 EAGAIN (Resource temporarily unavailable)
> 814 write(2, "bogl: mmaping /dev/fb0: Resource temporarily unavailable\n",
> 57) = 57
PAT code maps the ISA memory range as WB in the PAT attribute, so that
fixed range MTRR registers define the actual memory type (UC/WC/WT etc).
But the upper level is_new_memtype_allowed() API checks are failing,
as the request here is for UC and the return tracked type is WB (Tracked type is
WB as MTRR type for this legacy range potentially will be different for each
4k page).
Fix is_new_memtype_allowed() by always succeeding the ISA address range
checks, as the null PAT (WB) and def MTRR fixed range register settings
satisfy the memory type needs of the applications that map the ISA address
range.
Reported-and-Tested-by: Max Vozeler <xam@debian.org>
An older test-box started hanging at the following point during
bootup:
[ 0.022996] Mount-cache hash table entries: 512
[ 0.024996] Initializing cgroup subsys debug
[ 0.025996] Initializing cgroup subsys cpuacct
[ 0.026995] Initializing cgroup subsys devices
[ 0.027995] Initializing cgroup subsys freezer
[ 0.028995] mce: CPU supports 5 MCE banks
I've bisected it down to commit 4efc0670 ("x86, mce: use 64bit
machine check code on 32bit"), which utilizes the MCE code on
32-bit systems too.
The problem is caused by this detail in my config:
# CONFIG_CPU_SUP_INTEL is not set
This disables the quirks in mce_cpu_quirks() but still enables
MCE support - which then hangs due to the missing quirk
workaround needed on this CPU:
if (c->x86 == 6 && c->x86_model < 0x1A && banks > 0)
mce_banks[0].init = 0;
The safe solution is to not initialize MCEs if we dont know on
what CPU we are running (or if that CPU's support code got
disabled in the config).
Also be a bit more defensive on 32-bit systems: dont do a
boot-time dump of pending MCEs not just on the specific system
that we found a problem with (Pentium-M), but earlier ones as
well.
Now this problem is probably not common and disabling CPU
support is rare - but still being more defensive in something
we turned on for a wide range of CPUs is prudent.
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
LKML-Reference: Message-ID: <4A88E3E4.40506@jp.fujitsu.com>
On my legacy Pentium M laptop (Acer Extensa 2900) I get bogus MCE on a cold
boot with CONFIG_X86_NEW_MCE enabled, i.e. (after decoding it with mcelog):
MCE 0
HARDWARE ERROR. This is *NOT* a software problem!
Please contact your hardware vendor
CPU 0 BANK 1 MCG status:
MCi status:
Error overflow
Uncorrected error
Error enabled
Processor context corrupt
MCA: Data CACHE Level-1 UNKNOWN Error
STATUS f200000000000195 MCGSTATUS 0
[ The other STATUS values observed: f2000000000001b5 (... UNKNOWN error)
and f200000000000115 (... READ Error).
To verify that this is not a CONFIG_X86_NEW_MCE bug I also modified
the CONFIG_X86_OLD_MCE code (which doesn't log any MCEs) to dump
content of STATUS MSR before it is cleared during initialization. ]
Since the bogus MCE results in a kernel taint (which in turn disables
lockdep support) don't log boot MCEs on Pentium M (model == 13) CPUs
by default ("mce=bootlog" boot parameter can be be used to get the old
behavior).
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Reviewed-by: Andi Kleen <andi@firstfloor.org>
The function uv_acpi_madt_oem_check() has been marked __init,
the struct apic_x2apic_uv_x has been marked __refdata.
The aim is to address the following section mismatch messages:
WARNING: arch/x86/kernel/apic/built-in.o(.data+0x1368): Section mismatch in reference from the variable apic_x2apic_uv_x to the function .cpuinit.text:uv_wakeup_secondary()
The variable apic_x2apic_uv_x references
the function __cpuinit uv_wakeup_secondary()
If the reference is valid then annotate the
variable with __init* or __refdata (see linux/init.h) or name the variable:
*driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console,
WARNING: arch/x86/kernel/built-in.o(.data+0x68e8): Section mismatch in reference from the variable apic_x2apic_uv_x to the function .cpuinit.text:uv_wakeup_secondary()
WARNING: arch/x86/built-in.o(.text+0x7b36f): Section mismatch in reference from the function uv_acpi_madt_oem_check() to the function .init.text:early_ioremap()
The function uv_acpi_madt_oem_check() references
the function __init early_ioremap().
This is often because uv_acpi_madt_oem_check lacks a __init
annotation or the annotation of early_ioremap is wrong.
WARNING: arch/x86/built-in.o(.text+0x7b38d): Section mismatch in reference from the function uv_acpi_madt_oem_check() to the function .init.text:early_iounmap()
the function __init early_iounmap().
annotation or the annotation of early_iounmap is wrong.
WARNING: arch/x86/built-in.o(.data+0x8668): Section mismatch in reference from the variable apic_x2apic_uv_x to the function .cpuinit.text:uv_wakeup_secondary()
Signed-off-by: Leonardo Potenza <lpotenza@inwind.it>
LKML-Reference: <200908161855.48302.lpotenza@inwind.it>
0d01f31439c1e4d602bf9fdc924ab66f407f5e38 "x86, mce: therm_throt
- change when we print messages" removed redundant
announcements of "Temperature/speed normal".
They're not worth logging and remove their accompanying
"Machine check events logged" messages as well from the
console.
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Dmitry Torokhov <dtor@mail.ru>
LKML-Reference: <Pine.LNX.4.64.0908161544100.7929@sister.anvils>
The SGI UV Broadcast Assist Unit is used to send TLB shootdown
messages to remote nodes of the system. The header of the
message must contain the subnode id of the block in the
receiving hub that handles such messages. It should always be
0x10, the id of the "LB" block.
It had previously been documented as a "must be zero" field.
Signed-off-by: Cliff Wickman <cpw@sgi.com>
Acked-by: Jack Steiner <steiner@sgi.com>
LKML-Reference: <E1Mc1x7-0005Ce-6t@eag09.americas.sgi.com>
percpu code has been assuming num_possible_cpus() == nr_cpu_ids which
is incorrect if cpu_possible_map contains holes. This causes percpu
code to access beyond allocated memories and vmalloc areas. On a
sparc64 machine with cpus 0 and 2 (u60), this triggers the following
warning or fails boot.
WARNING: at /devel/tj/os/work/mm/vmalloc.c:106 vmap_page_range_noflush+0x1f0/0x240()
Modules linked in:
Call Trace:
[00000000004b17d0] vmap_page_range_noflush+0x1f0/0x240
[00000000004b1840] map_vm_area+0x20/0x60
[00000000004b1950] __vmalloc_area_node+0xd0/0x160
[0000000000593434] deflate_init+0x14/0xe0
[0000000000583b94] __crypto_alloc_tfm+0xd4/0x1e0
[00000000005844f0] crypto_alloc_base+0x50/0xa0
[000000000058b898] alg_test_comp+0x18/0x80
[000000000058dad4] alg_test+0x54/0x180
[000000000058af00] cryptomgr_test+0x40/0x60
[0000000000473098] kthread+0x58/0x80
[000000000042b590] kernel_thread+0x30/0x60
[0000000000472fd0] kthreadd+0xf0/0x160
---[ end trace 429b268a213317ba ]---
This patch fixes generic percpu functions and sparc64
setup_per_cpu_areas() so that they handle sparse cpu_possible_map
properly.
Please note that on x86, cpu_possible_map() doesn't contain holes and
thus num_possible_cpus() == nr_cpu_ids and this patch doesn't cause
any behavior difference.
