path: root/arch/xtensa/configs
2011-04-11xtensa: remove obsolete BKL kernel option from defconfigAlessio Igor Bogani
The BKL doesn't exist anymore so remove CONFIG_LOCK_KERNEL. This work was supported by a hardware donation from the CE Linux Forum. Signed-off-by: Alessio Igor Bogani <abogani@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-15Merge branch 'master' into for-nextJiri Kosina
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-19replace obsolete CONFIG_DYNAMIC_PRINTK_DEBUG with CONFIG_DYNAMIC_DEBUGJim Cromie
former is obsoleted by latter, done by       commit e9d376f0fa66bd630fe27403669c6ae6c22a868f       Author: Jason Baron <jbaron@redhat.com>       Date:   Thu Feb 5 11:51:38 2009 -0500 most defconfig mentions have been removed in the big defconfig cleanup, but the one in s6105_defconfig remains. Signed-off-by:  Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-03xtensa: Disable PCI and nfsroot on simulation targetChris Zankel
The ISS platform is a pure simulation target and doesn't support PCI, so disable it in the default configuration. Signed-off-by: Chris Zankel <chris@zankel.net>
2009-06-22xtensa: enable m41t80 driver in s6105_defconfigDaniel Glockner
Signed-off-by: Daniel Glockner <dg@emlix.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2009-06-22xtensa: enable s6gmac in s6105_defconfigDaniel Glockner
Signed-off-by: Daniel Glockner <dg@emlix.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Johannes Weiner <jw@emlix.com> Cc: Oskar Schirmer <os@emlix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2009-05-11xtensa: update s6105_defconfig for ccount calibrationOskar Schirmer
The previous patch enabled ccount calibration for the s6000 variant. This patch updates the defconfig for the s6105 platform to reflect this change. Signed-off-by: Oskar Schirmer <os@emlix.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2009-04-02xtensa: platform: s6105Johannes Weiner
Support for the S6105 IP Camera Reference Design Kit. Signed-off-by: Johannes Weiner <jw@emlix.com> Signed-off-by: Oskar Schirmer <os@emlix.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2006-12-10[PATCH] xtensa: remove extra header filesChris Zankel
The Xtensa port contained many header files that were never needed. This rather lengthy patch removes all those files. Unfortunately, there were many dependencies that needed to be updated, so this patch touches quite a few source files. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xtensa: Architecture support for Tensilica Xtensa Part 8Chris Zankel
The attached patches provides part 8 of an architecture implementation for the Tensilica Xtensa CPU series. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xtensa: Architecture support for Tensilica Xtensa Part 1Chris Zankel
The attached patches provides part 1 of an architecture implementation for the Tensilica Xtensa CPU series. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
