commit 8b39da985194aac2998dd9e3a22d00b596cebf1e upstream.
Custom outs*/ins* implementations are long gone from the xtensa port,
remove matching EXPORT_SYMBOLs.
This fixes the following build warnings issued by modpost since commit
15bfc2348d54 ("modpost: check for static EXPORT_SYMBOL* functions"):
WARNING: "insb" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "insw" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "insl" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "outsb" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "outsw" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "outsl" [vmlinux] is a static EXPORT_SYMBOL
Cc: stable@vger.kernel.org
Fixes: d38efc1f150f ("xtensa: adopt generic io routines")
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
This enables KASAN check of the destination buffer.
Cover kernel addresses above 0x90000000 by the shadow map. Enable
HAVE_ARCH_KASAN when MMU is enabled. Provide kasan_early_init that fills
shadow map with writable copies of kasan_zero_page. Call
kasan_early_init right after mmu initialization in the setup_arch.
Provide kasan_init that allocates proper shadow map pages from the
memblock and puts these pages into the shadow map for addresses from
VMALLOC area to the end of KSEG. Call kasan_init right after memblock
initialization. Don't use KASAN for the boot code, MMU and KASAN
initialization and page fault handler. Make kernel stack size 4 times
larger when KASAN is enabled to avoid stack overflows.
GCC 7.3, 8 or newer is required to build the xtensa kernel with KASAN.
csum_partial and csum_partial_copy_generic are defined unconditionally
and are available even when CONFIG_NET is disabled. They are used not
only by the network drivers, but also by scsi and media.
Don't limit these functions export by CONFIG_NET.
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
When modular code calls flush_icache_range():
ERROR: "__invalidate_icache_range" [drivers/misc/lkdtm.ko] undefined!
make[1]: *** [__modpost] Error 1
The original implementation could clobber registers under certain conditions.
The Xtensa processor architecture uses windowed registers and the original
implementation was using a4 as a temporary register, which under certain
conditions could be register a0 of the oldest window frame, and didn't always
restore the content correctly.
By moving the _spill_registers routine inside the fast system call, it frees
up one more register (the return address is not required anymore) for the
spill routine.
Signed-off-by: Chris Zankel <chris@zankel.net>
xtansa allmodbuild fails with:
arch/xtensa/kernel/xtensa_ksyms.c:129:1: error: '_mcount' undeclared here (not in a function)
make[2]: *** [arch/xtensa/kernel/xtensa_ksyms.o] Error 1
make[1]: *** [arch/xtensa/kernel] Error 2
The breakage is due to commit 478ba61af (xtensa: add static function tracer
support) which exports _mcount without declaring it.
Cc: Max Filippov <jcmvbkbc@gmail.com>
__xtensa_libgcc_window_spill is needed for __builtin_return_address(1),
but its libgcc implementation cannot be used as it makes a syscall.
Atomic intrinsics are used by single staging driver.
This patch remove unneeded #include <linux/ide.h>'s.
It also adds a required #include <linux/interrupt.h> that was previously
implicitely pulled by ide.h
Signed-off-by: Adrian Bunk <bunk@kernel.org>
[bart: revert change to tests/lkdtm.c (spotted by Stephen Rothwell)]
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Semaphores are no longer performance-critical, so a generic C
implementation is better for maintainability, debuggability and
extensibility. Thanks to Peter Zijlstra for fixing the lockdep
warning. Thanks to Harvey Harrison for pointing out that the
unlikely() was unnecessary.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
This patch removes the following symbols from
arch/xtensa/kernel/xtensa_ksyms.c that were already exported:
memcmp, memchr, strcat, strchr, strlen, stncat, strnlen, strrchr,
strstr, enable_irq, and disable_irq
I noticed that many source files include <linux/pci.h> while they do
not appear to need it. Here is an attempt to clean it all up.
In order to find all possibly affected files, I searched for all
files including <linux/pci.h> but without any other occurence of "pci"
or "PCI". I removed the include statement from all of these, then I
compiled an allmodconfig kernel on both i386 and x86_64 and fixed the
false positives manually.
My tests covered 66% of the affected files, so there could be false
positives remaining. Untested files are:
arch/alpha/kernel/err_common.c
arch/alpha/kernel/err_ev6.c
arch/alpha/kernel/err_ev7.c
arch/ia64/sn/kernel/huberror.c
arch/ia64/sn/kernel/xpnet.c
arch/m68knommu/kernel/dma.c
arch/mips/lib/iomap.c
arch/powerpc/platforms/pseries/ras.c
arch/ppc/8260_io/enet.c
arch/ppc/8260_io/fcc_enet.c
arch/ppc/8xx_io/enet.c
arch/ppc/syslib/ppc4xx_sgdma.c
arch/sh64/mach-cayman/iomap.c
arch/xtensa/platform-iss/setup.c
drivers/i2c/busses/i2c-at91.c
drivers/i2c/busses/i2c-mpc.c
drivers/media/video/saa711x.c
drivers/misc/hdpuftrs/hdpu_cpustate.c
drivers/misc/hdpuftrs/hdpu_nexus.c
drivers/net/au1000_eth.c
drivers/net/fec_8xx/fec_main.c
drivers/net/fec_8xx/fec_mii.c
drivers/net/fs_enet/fs_enet-main.c
drivers/net/fs_enet/mac-fcc.c
drivers/net/fs_enet/mac-fec.c
drivers/net/fs_enet/mac-scc.c
drivers/net/fs_enet/mii-bitbang.c
drivers/net/fs_enet/mii-fec.c
drivers/net/ibm_emac/ibm_emac_core.c
drivers/net/lasi_82596.c
drivers/parisc/hppb.c
drivers/sbus/sbus.c
drivers/video/g364fb.c
drivers/video/platinumfb.c
drivers/video/stifb.c
drivers/video/valkyriefb.c
include/asm-arm/arch-ixp4xx/dma.h
sound/oss/au1550_ac97.c
I would welcome test reports for these files. I am fine with removing
the untested files from the patch if the general opinion is that these
changes aren't safe. The tested part would still be nice to have.
Note that this patch depends on another header fixup patch I submitted
to LKML yesterday:
[PATCH] scatterlist.h needs types.h
http://lkml.org/lkml/2007/3/01/141
Cc: Badari Pulavarty <pbadari@us.ibm.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
While cleaning up parisc_ksyms.c earlier, I noticed that strpbrk wasn't
being exported from lib/string.c. Investigating further, I noticed a
changeset that removed its export and added it to _ksyms.c on a few more
architectures. The justification was that "other arches do it."
I think this is wrong, since no architecture currently defines
__HAVE_ARCH_STRPBRK, there's no reason for any of them to be exporting it
themselves. Therefore, consolidate the export to lib/string.c.
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
The only user of get_wchan is the proc fs - and proc can't be built modular.
The attached patches provides part 3 of an architecture implementation for the
Tensilica Xtensa CPU series.
