commit 8b39da985194aac2998dd9e3a22d00b596cebf1e upstream.
Custom outs*/ins* implementations are long gone from the xtensa port,
remove matching EXPORT_SYMBOLs.
This fixes the following build warnings issued by modpost since commit
15bfc2348d54 ("modpost: check for static EXPORT_SYMBOL* functions"):
WARNING: "insb" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "insw" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "insl" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "outsb" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "outsw" [vmlinux] is a static EXPORT_SYMBOL
WARNING: "outsl" [vmlinux] is a static EXPORT_SYMBOL
Cc: stable@vger.kernel.org
Fixes: d38efc1f150f ("xtensa: adopt generic io routines")
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
ITLB entry modifications must be followed by the isync instruction
before the new entries are possibly used. cpu_reset lacks one isync
between ITLB way 6 initialization and jump to the identity mapping.
Add missing isync to xtensa cpu_reset.
Assembly entry/return abstraction change didn't add asmmacro.h include
statement to coprocessor.S, resulting in references to undefined macros
abi_entry and abi_ret on cores that define XTENSA_HAVE_COPROCESSORS.
Fix that by including asm/asmmacro.h from the coprocessor.S.
Pull Xtensa updates from Max Filippov:
- clean up PCI support code
- add defconfig and DTS for the 'virt' board
- abstract 'entry' and 'retw' uses in xtensa assembly in preparation
for XEA3/NX pipeline support
- random small cleanups
* tag 'xtensa-20190715' of git://github.com/jcmvbkbc/linux-xtensa:
xtensa: virt: add defconfig and DTS
xtensa: abstract 'entry' and 'retw' in assembly code
xtensa: One function call less in bootmem_init()
xtensa: remove arch/xtensa/include/asm/types.h
xtensa: use generic pcibios_set_master and pcibios_enable_device
xtensa: drop dead PCI support code
xtensa/PCI: Remove unused variable
Pull dma-mapping updates from Christoph Hellwig:
- move the USB special case that bounced DMA through a device bar into
the USB code instead of handling it in the common DMA code (Laurentiu
Tudor and Fredrik Noring)
- don't dip into the global CMA pool for single page allocations
(Nicolin Chen)
- fix a crash when allocating memory for the atomic pool failed during
boot (Florian Fainelli)
- move support for MIPS-style uncached segments to the common code and
use that for MIPS and nios2 (me)
- make support for DMA_ATTR_NON_CONSISTENT and
DMA_ATTR_NO_KERNEL_MAPPING generic (me)
- convert nds32 to the generic remapping allocator (me)
* tag 'dma-mapping-5.3' of git://git.infradead.org/users/hch/dma-mapping: (29 commits)
dma-mapping: mark dma_alloc_need_uncached as __always_inline
MIPS: only select ARCH_HAS_UNCACHED_SEGMENT for non-coherent platforms
usb: host: Fix excessive alignment restriction for local memory allocations
lib/genalloc.c: Add algorithm, align and zeroed family of DMA allocators
nios2: use the generic uncached segment support in dma-direct
nds32: use the generic remapping allocator for coherent DMA allocations
arc: use the generic remapping allocator for coherent DMA allocations
dma-direct: handle DMA_ATTR_NO_KERNEL_MAPPING in common code
dma-direct: handle DMA_ATTR_NON_CONSISTENT in common code
dma-mapping: add a dma_alloc_need_uncached helper
openrisc: remove the partial DMA_ATTR_NON_CONSISTENT support
arc: remove the partial DMA_ATTR_NON_CONSISTENT support
arm-nommu: remove the partial DMA_ATTR_NON_CONSISTENT support
ARM: dma-mapping: allow larger DMA mask than supported
dma-mapping: truncate dma masks to what dma_addr_t can hold
iommu/dma: Apply dma_{alloc,free}_contiguous functions
dma-remap: Avoid de-referencing NULL atomic_pool
MIPS: use the generic uncached segment support in dma-direct
dma-direct: provide generic support for uncached kernel segments
au1100fb: fix DMA API abuse
git://git.kernel.org/pub/scm/linux/kernel/git/brauner/linux
Pull clone3 system call from Christian Brauner:
"This adds the clone3 syscall which is an extensible successor to clone
after we snagged the last flag with CLONE_PIDFD during the 5.2 merge
window for clone(). It cleanly supports all of the flags from clone()
and thus all legacy workloads.
There are few user visible differences between clone3 and clone.
First, CLONE_DETACHED will cause EINVAL with clone3 so we can reuse
this flag. Second, the CSIGNAL flag is deprecated and will cause
EINVAL to be reported. It is superseeded by a dedicated "exit_signal"
argument in struct clone_args thus freeing up even more flags. And
third, clone3 gives CLONE_PIDFD a dedicated return argument in struct
clone_args instead of abusing CLONE_PARENT_SETTID's parent_tidptr
argument.
The clone3 uapi is designed to be easy to handle on 32- and 64 bit:
/* uapi */
struct clone_args {
__aligned_u64 flags;
__aligned_u64 pidfd;
__aligned_u64 child_tid;
__aligned_u64 parent_tid;
__aligned_u64 exit_signal;
__aligned_u64 stack;
__aligned_u64 stack_size;
__aligned_u64 tls;
and a separate kernel struct is used that uses proper kernel typing:
/* kernel internal */
struct kernel_clone_args {
u64 flags;
int __user *pidfd;
int __user *child_tid;
int __user *parent_tid;
int exit_signal;
unsigned long stack;
unsigned long stack_size;
unsigned long tls;
The system call comes with a size argument which enables the kernel to
detect what version of clone_args userspace is passing in. clone3
validates that any additional bytes a given kernel does not know about
are set to zero and that the size never exceeds a page.
A nice feature is that this patchset allowed us to cleanup and
simplify various core kernel codepaths in kernel/fork.c by making the
internal _do_fork() function take struct kernel_clone_args even for
legacy clone().
This patch also unblocks the time namespace patchset which wants to
introduce a new CLONE_TIMENS flag.
Note, that clone3 has only been wired up for x86{_32,64}, arm{64}, and
xtensa. These were the architectures that did not require special
massaging.
Other architectures treat fork-like system calls individually and
after some back and forth neither Arnd nor I felt confident that we
dared to add clone3 unconditionally to all architectures. We agreed to
leave this up to individual architecture maintainers. This is why
there's an additional patch that introduces __ARCH_WANT_SYS_CLONE3
which any architecture can set once it has implemented support for
clone3. The patch also adds a cond_syscall(clone3) for architectures
such as nios2 or h8300 that generate their syscall table by simply
including asm-generic/unistd.h. The hope is to get rid of
__ARCH_WANT_SYS_CLONE3 and cond_syscall() rather soon"
* tag 'clone3-v5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/brauner/linux:
arch: handle arches who do not yet define clone3
arch: wire-up clone3() syscall
fork: add clone3
Pull pidfd updates from Christian Brauner:
"This adds two main features.
- First, it adds polling support for pidfds. This allows process
managers to know when a (non-parent) process dies in a race-free
way.
The notification mechanism used follows the same logic that is
currently used when the parent of a task is notified of a child's
death. With this patchset it is possible to put pidfds in an
{e}poll loop and get reliable notifications for process (i.e.
thread-group) exit.
- The second feature compliments the first one by making it possible
to retrieve pollable pidfds for processes that were not created
using CLONE_PIDFD.
A lot of processes get created with traditional PID-based calls
such as fork() or clone() (without CLONE_PIDFD). For these
processes a caller can currently not create a pollable pidfd. This
is a problem for Android's low memory killer (LMK) and service
managers such as systemd.
Both patchsets are accompanied by selftests.
It's perhaps worth noting that the work done so far and the work done
in this branch for pidfd_open() and polling support do already see
some adoption:
- Android is in the process of backporting this work to all their LTS
kernels [1]
- Service managers make use of pidfd_send_signal but will need to
wait until we enable waiting on pidfds for full adoption.
- And projects I maintain make use of both pidfd_send_signal and
CLONE_PIDFD [2] and will use polling support and pidfd_open() too"
[1] https://android-review.googlesource.com/q/topic:%22pidfd+polling+support+4.9+backport%22
https://android-review.googlesource.com/q/topic:%22pidfd+polling+support+4.14+backport%22
https://android-review.googlesource.com/q/topic:%22pidfd+polling+support+4.19+backport%22
[2] https://github.com/lxc/lxc/blob/aab6e3eb73c343231cdde775db938994fc6f2803/src/lxc/start.c#L1753
* tag 'pidfd-updates-v5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/brauner/linux:
tests: add pidfd_open() tests
arch: wire-up pidfd_open()
pid: add pidfd_open()
pidfd: add polling selftests
pidfd: add polling support
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull force_sig() argument change from Eric Biederman:
"A source of error over the years has been that force_sig has taken a
task parameter when it is only safe to use force_sig with the current
task.
The force_sig function is built for delivering synchronous signals
such as SIGSEGV where the userspace application caused a synchronous
fault (such as a page fault) and the kernel responded with a signal.
Because the name force_sig does not make this clear, and because the
force_sig takes a task parameter the function force_sig has been
abused for sending other kinds of signals over the years. Slowly those
have been fixed when the oopses have been tracked down.
This set of changes fixes the remaining abusers of force_sig and
carefully rips out the task parameter from force_sig and friends
making this kind of error almost impossible in the future"
* 'siginfo-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (27 commits)
signal/x86: Move tsk inside of CONFIG_MEMORY_FAILURE in do_sigbus
signal: Remove the signal number and task parameters from force_sig_info
signal: Factor force_sig_info_to_task out of force_sig_info
signal: Generate the siginfo in force_sig
signal: Move the computation of force into send_signal and correct it.
signal: Properly set TRACE_SIGNAL_LOSE_INFO in __send_signal
signal: Remove the task parameter from force_sig_fault
signal: Use force_sig_fault_to_task for the two calls that don't deliver to current
signal: Explicitly call force_sig_fault on current
signal/unicore32: Remove tsk parameter from __do_user_fault
signal/arm: Remove tsk parameter from __do_user_fault
signal/arm: Remove tsk parameter from ptrace_break
signal/nds32: Remove tsk parameter from send_sigtrap
signal/riscv: Remove tsk parameter from do_trap
signal/sh: Remove tsk parameter from force_sig_info_fault
signal/um: Remove task parameter from send_sigtrap
signal/x86: Remove task parameter from send_sigtrap
signal: Remove task parameter from force_sig_mceerr
signal: Remove task parameter from force_sigsegv
Provide abi_entry, abi_entry_default, abi_ret and abi_ret_default macros
that allocate aligned stack frame in windowed and call0 ABIs.
Provide XTENSA_SPILL_STACK_RESERVE macro that specifies required stack
frame size when register spilling is involved.
Replace all uses of 'entry' and 'retw' with the above macros.
This makes most of the xtensa assembly code ready for XEA3 and call0 ABI.
This wires up the pidfd_open() syscall into all arches at once.
Signed-off-by: Christian Brauner <christian@brauner.io>
Reviewed-by: David Howells <dhowells@redhat.com>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Joel Fernandes (Google) <joel@joelfernandes.org>
Cc: Jann Horn <jannh@google.com>
Cc: Andy Lutomirsky <luto@kernel.org>
Cc: Aleksa Sarai <cyphar@cyphar.com>
Cc: linux-api@vger.kernel.org
Cc: linux-alpha@vger.kernel.org
Cc: linux-ia64@vger.kernel.org
Cc: linux-m68k@lists.linux-m68k.org
Cc: linux-mips@vger.kernel.org
Cc: linux-parisc@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: linux-s390@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: sparclinux@vger.kernel.org
Cc: linux-xtensa@linux-xtensa.org
Cc: x86@kernel.org
DMA_ATTR_NO_KERNEL_MAPPING is generally implemented by allocating
normal cacheable pages or CMA memory, and then returning the page
pointer as the opaque handle. Lift that code from the xtensa and
generic dma remapping implementations into the generic dma-direct
code so that we don't even call arch_dma_alloc for these allocations.
Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
Both functions don't do anything xtensa-specific and there are generic
implementations for both. Drop both and use generic versions.
xtensa-specific PCI initialization code has significantly bitrotted over
time because there's no platform that use it. Get rid of remaining
non-functioning initialization and remove platform_pcibios_* interface.
A new platform that would use PCI on xtensa will configure PCI
controller using device tree.
Drop variables pci_ctrl_head, pci_bus_count and functions pcibios_init,
pci_controller_apertures, platform_pcibios_init and
platform_pcibios_fixup.
gcc reports:
arch/xtensa/kernel/pci.c:40:32: warning:
'pci_ctrl_tail' defined but not used
which is indeed the case.
Message-Id: <1560694321-31380-1-git-send-email-linux@roeck-us.net>
Wire up the clone3() call on all arches that don't require hand-rolled
assembly.
Some of the arches look like they need special assembly massaging and it is
probably smarter if the appropriate arch maintainers would do the actual
wiring. Arches that are wired-up are:
- x86{_32,64}
- arm{64}
- xtensa
Cc: Adrian Reber <adrian@lisas.de>
Cc: Florian Weimer <fweimer@redhat.com>
Cc: x86@kernel.org
Pull xtensa fix from Max Filippov:
"Fix a section mismatch between memblock_reserve and mem_reserve.
This fixes tinyconfig xtensa builds"
* tag 'xtensa-20190607' of git://github.com/jcmvbkbc/linux-xtensa:
xtensa: Fix section mismatch between memblock_reserve and mem_reserve
Based on 1 normalized pattern(s):
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 3029 file(s).
Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de
Since commit 9012d011660ea5cf2 ("compiler: allow all arches to enable
CONFIG_OPTIMIZE_INLINING"), xtensa:tinyconfig fails to build with section
mismatch errors.
WARNING: vmlinux.o(.text.unlikely+0x68): Section mismatch in reference
from the function ___pa()
to the function .meminit.text:memblock_reserve()
WARNING: vmlinux.o(.text.unlikely+0x74): Section mismatch in reference
from the function mem_reserve()
FATAL: modpost: Section mismatches detected.
This was not seen prior to the above mentioned commit because mem_reserve()
was always inlined.
Mark mem_reserve(() as __init_memblock to have it reside in the same
section as memblock_reserve().
Message-Id: <1559220098-9955-1-git-send-email-linux@roeck-us.net>
As synchronous exceptions really only make sense against the current
task (otherwise how are you synchronous) remove the task parameter
from from force_sig_fault to make it explicit that is what is going
on.
The two known exceptions that deliver a synchronous exception to a
stopped ptraced task have already been changed to
force_sig_fault_to_task.
The callers have been changed with the following emacs regular expression
(with obvious variations on the architectures that take more arguments)
to avoid typos:
force_sig_fault[(]\([^,]+\)[,]\([^,]+\)[,]\([^,]+\)[,]\W+current[)]
force_sig_fault(\1,\2,\3)
All of the remaining callers pass current into force_sig so
remove the task parameter to make this obvious and to make
misuse more difficult in the future.
This also makes it clear force_sig passes current into force_sig_info.
Pull more vfs mount updates from Al Viro:
"Propagation of new syscalls to other architectures + cosmetic change
from Christian (fscontext didn't follow the convention for anon inode
names)"
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
uapi: Wire up the mount API syscalls on non-x86 arches [ver #2]
uapi, x86: Fix the syscall numbering of the mount API syscalls [ver #2]
uapi, fsopen: use square brackets around "fscontext" [ver #2]
Wire up the mount API syscalls on non-x86 arches.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
CONFIG_DEBUG_KERNEL should not impact code generation. Use the newly
defined CONFIG_DEBUG_MISC instead to keep the current code.
Link: http://lkml.kernel.org/r/20190413224438.10802-5-okaya@kernel.org
Signed-off-by: Sinan Kaya <okaya@kernel.org>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: Max Filippov <jcmvbkbc@gmail.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: Anders Roxell <anders.roxell@linaro.org>
Cc: Christophe Leroy <christophe.leroy@c-s.fr>
Cc: Florian Westphal <fw@strlen.de>
Cc: James Hogan <jhogan@kernel.org>
Cc: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Mike Rapoport <rppt@linux.ibm.com>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Thomas Bogendoerfer <tbogendoerfer@suse.de>
Implement atomic primitives using exclusive access opcodes available in
the recent xtensa cores.
Since l32ex/s32ex don't have any memory ordering guarantees don't define
__smp_mb__before_atomic/__smp_mb__after_atomic to make them use memw.
Introduce the header arch/xtensa/include/asm/core.h that provides
definitions for XCHAL macros missing in older xtensa releases. Use this
header instead of variant/core.h
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull syscall numbering updates from Arnd Bergmann:
"arch: add pidfd and io_uring syscalls everywhere
This comes a bit late, but should be in 5.1 anyway: we want the newly
added system calls to be synchronized across all architectures in the
release.
I hope that in the future, any newly added system calls can be added
to all architectures at the same time, and tested there while they are
in linux-next, avoiding dependencies between the architecture
maintainer trees and the tree that contains the new system call"
* tag 'syscalls-5.1' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic:
Add the io_uring and pidfd_send_signal system calls to all architectures.
These system calls are designed to handle both native and compat tasks,
so all entries are the same across architectures, only arm-compat and
the generic tale still use an old format.
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> (s390)
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
return_address returns the address that is one level higher in the call
stack than requested in its argument, because level 0 corresponds to its
caller's return address. Use requested level as the number of stack
frames to skip.
This fixes the address reported by might_sleep and friends.
Syscall may alter pt_regs structure passed to it, resulting in a
mismatch between syscall entry end syscall exit entries in the ftrace.
Temporary restore syscall field of the pt_regs for the duration of
do_syscall_trace_leave.
Pull xtensa updates from Max Filippov:
- use generic spinlock/rwlock implementations
- clean up IPI processing
- document boot parameters passing to the kernel
- fix get_wchan
- various cleanups in time.c, process.c, traps.c and thread_info.h
* tag 'xtensa-20190307' of git://github.com/jcmvbkbc/linux-xtensa:
xtensa: simplify trap_init
xtensa: drop unused definitions
xtensa: fix get_wchan
xtensa: use generic spinlock/rwlock implementation
xtensa: provide xchg for sizes 1 and 2
xtensa: clean up arch/xtensa/kernel/time.c
xtensa: SMP: rework IPI processing
xtensa: document boot parameter passing
git://git.kernel.org:/pub/scm/linux/kernel/git/arnd/playground into timers/2038
Pull y2038 - time64 system calls from Arnd Bergmann:
This series finally gets us to the point of having system calls with 64-bit
time_t on all architectures, after a long time of incremental preparation
patches.
There was actually one conversion that I missed during the summer,
i.e. Deepa's timex series, which I now updated based the 5.0-rc1 changes
and review comments.
The following system calls are now added on all 32-bit architectures using
the same system call numbers:
403 clock_gettime64
404 clock_settime64
405 clock_adjtime64
406 clock_getres_time64
407 clock_nanosleep_time64
408 timer_gettime64
409 timer_settime64
410 timerfd_gettime64
411 timerfd_settime64
412 utimensat_time64
413 pselect6_time64
414 ppoll_time64
416 io_pgetevents_time64
417 recvmmsg_time64
418 mq_timedsend_time64
419 mq_timedreceiv_time64
420 semtimedop_time64
421 rt_sigtimedwait_time64
422 futex_time64
423 sched_rr_get_interval_time64
Each one of these corresponds directly to an existing system call that
includes a 'struct timespec' argument, or a structure containing a timespec
or (in case of clock_adjtime) timeval. Not included here are new versions
of getitimer/setitimer and getrusage/waitid, which are planned for the
future but only needed to make a consistent API rather than for correct
operation beyond y2038. These four system calls are based on 'timeval', and
it has not been finally decided what the replacement kernel interface will
use instead.
So far, I have done a lot of build testing across most architectures, which
has found a number of bugs. Runtime testing so far included testing LTP on
32-bit ARM with the existing system calls, to ensure we do not regress for
existing binaries, and a test with a 32-bit x86 build of LTP against a
modified version of the musl C library that has been adapted to the new
system call interface [3]. This library can be used for testing on all
architectures supported by musl-1.1.21, but it is not how the support is
getting integrated into the official musl release. Official musl support is
planned but will require more invasive changes to the library.
Link: https://lore.kernel.org/lkml/20190110162435.309262-1-arnd@arndb.de/T/
Link: https://lore.kernel.org/lkml/20190118161835.2259170-1-arnd@arndb.de/
Link: https://git.linaro.org/people/arnd/musl-y2038.git/ [2]
Pull preparatory work for y2038 changes from Arnd Bergmann:
System call unification and cleanup
The system call tables have diverged a bit over the years, and a number of
the recent additions never made it into all architectures, for one reason
or another.
This is an attempt to clean it up as far as we can without breaking
compatibility, doing a number of steps:
- Add system calls that have not yet been integrated into all architectures
but that we definitely want there. This includes {,f}statfs64() and
get{eg,eu,g,p,u,pp}id() on alpha, which have been missing traditionally.
- The s390 compat syscall handling is cleaned up to be more like what we
do on other architectures, while keeping the 31-bit pointer
extension. This was merged as a shared branch by the s390 maintainers
and is included here in order to base the other patches on top.
- Add the separate ipc syscalls on all architectures that traditionally
only had sys_ipc(). This version is done without support for IPC_OLD
that is we have in sys_ipc. The new semtimedop_time64 syscall will only
be added here, not in sys_ipc
- Add syscall numbers for a couple of syscalls that we probably don't need
everywhere, in particular pkey_* and rseq, for the purpose of symmetry:
if it's in asm-generic/unistd.h, it makes sense to have it everywhere. I
expect that any future system calls will get assigned on all platforms
together, even when they appear to be specific to a single architecture.
- Prepare for having the same system call numbers for any future calls. In
combination with the generated tables, this hopefully makes it easier to
add new calls across all architectures together.
All of the above are technically separate from the y2038 work, but are done
as preparation before we add the new 64-bit time_t system calls everywhere,
providing a common baseline set of system calls.
I expect that glibc and other libraries that want to use 64-bit time_t will
require linux-5.1 kernel headers for building in the future, and at a much
later point may also require linux-5.1 or a later version as the minimum
kernel at runtime. Having a common baseline then allows the removal of many
architecture or kernel version specific workarounds.
Drop redundant 'fast &&' condition from the exception handler assignment
loop.
drop the following unused definitions:
- TS_USEDFPU from arch/xtensa/include/asm/thread_info.h
- current_set from arch/xtensa/kernel/process.c
Stack unwinding is implemented incorrectly in xtensa get_wchan: instead
of extracting a0 and a1 registers from the spill location under the
stack pointer it extracts a word pointed to by the stack pointer and
subtracts 4 or 3 from it.
- move all constant assignments from local_timer_setup to the definition
of ccount_timer to make it mostly statically initialized;
- drop local function declarations, reorder functions and variables that
reference them.
Don't skip current CPU in send_ipi_message: callers of this function
take care of it and it's harmless anyway.
Don't clear IPI bits one by one, clear all that were read at once.
Check IPI register in a loop in case new IPI was posted while previous
was being handled.
This adds 21 new system calls on each ABI that has 32-bit time_t
today. All of these have the exact same semantics as their existing
counterparts, and the new ones all have macro names that end in 'time64'
for clarification.
This gets us to the point of being able to safely use a C library
that has 64-bit time_t in user space. There are still a couple of
loose ends to tie up in various areas of the code, but this is the
big one, and should be entirely uncontroversial at this point.
In particular, there are four system calls (getitimer, setitimer,
waitid, and getrusage) that don't have a 64-bit counterpart yet,
but these can all be safely implemented in the C library by wrapping
around the existing system calls because the 32-bit time_t they
pass only counts elapsed time, not time since the epoch. They
will be dealt with later.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
The time, stime, utime, utimes, and futimesat system calls are only
used on older architectures, and we do not provide y2038 safe variants
of them, as they are replaced by clock_gettime64, clock_settime64,
and utimensat_time64.
However, for consistency it seems better to have the 32-bit architectures
that still use them call the "time32" entry points (leaving the
traditional handlers for the 64-bit architectures), like we do for system
calls that now require two versions.
Note: We used to always define __ARCH_WANT_SYS_TIME and
__ARCH_WANT_SYS_UTIME and only set __ARCH_WANT_COMPAT_SYS_TIME and
__ARCH_WANT_SYS_UTIME32 for compat mode on 64-bit kernels. Now this is
reversed: only 64-bit architectures set __ARCH_WANT_SYS_TIME/UTIME, while
we need __ARCH_WANT_SYS_TIME32/UTIME32 for 32-bit architectures and compat
mode. The resulting asm/unistd.h changes look a bit counterintuitive.
This is only a cleanup patch and it should not change any behavior.
This is the big flip, where all 32-bit architectures set COMPAT_32BIT_TIME
and use the _time32 system calls from the former compat layer instead
of the system calls that take __kernel_timespec and similar arguments.
The temporary redirects for __kernel_timespec, __kernel_itimerspec
and __kernel_timex can get removed with this.
It would be easy to split this commit by architecture, but with the new
generated system call tables, it's easy enough to do it all at once,
which makes it a little easier to check that the changes are the same
in each table.
This fixes the following warning at boot when the kernel is booted on a
board with more CPU cores than was configured in NR_CPUS:
smp_init_cpus: Core Count = 8
smp_init_cpus: Core Id = 0
WARNING: CPU: 0 PID: 0 at include/linux/cpumask.h:121 smp_init_cpus+0x54/0x74
Modules linked in:
CPU: 0 PID: 0 Comm: swapper Not tainted 5.0.0-rc3-00015-g1459333f88a0 #124
Call Trace:
__warn$part$3+0x6a/0x7c
warn_slowpath_null+0x35/0x3c
setup_arch+0x1c0/0x1d0
start_kernel+0x44/0x310
_startup+0x107/0x107
Otherwise it is impossible to enable CPUs after booting with 'maxcpus'
parameter.
- add missing memory barriers to the secondary CPU synchronization spin
loops; add comment to the matching memory barrier in the boot_secondary
and __cpu_die functions;
- use READ_ONCE/WRITE_ONCE to access cpu_start_id/cpu_start_ccount
instead of reading/writing them directly;
- re-initialize cpu_running every time before starting secondary CPU to
flush possible previous CPU startup results.
Most architectures define system call numbers for the rseq and pkey system
calls, even when they don't support the features, and perhaps never will.
Only a few architectures are missing these, so just define them anyway
for consistency. If we decide to add them later to one of these, the
system call numbers won't get out of sync then.
The behavior of these system calls is slightly different between
architectures, as determined by the CONFIG_ARCH_WANT_IPC_PARSE_VERSION
symbol. Most architectures that implement the split IPC syscalls don't set
that symbol and only get the modern version, but alpha, arm, microblaze,
mips-n32, mips-n64 and xtensa expect the caller to pass the IPC_64 flag.
For the architectures that so far only implement sys_ipc(), i.e. m68k,
mips-o32, powerpc, s390, sh, sparc, and x86-32, we want the new behavior
when adding the split syscalls, so we need to distinguish between the
two groups of architectures.
The method I picked for this distinction is to have a separate system call
entry point: sys_old_*ctl() now uses ipc_parse_version, while sys_*ctl()
does not. The system call tables of the five architectures are changed
accordingly.
As an additional benefit, we no longer need the configuration specific
definition for ipc_parse_version(), it always does the same thing now,
but simply won't get called on architectures with the modern interface.
A small downside is that on architectures that do set
ARCH_WANT_IPC_PARSE_VERSION, we now have an extra set of entry points
that are never called. They only add a few bytes of bloat, so it seems
better to keep them compared to adding yet another Kconfig symbol.
I considered adding new syscall numbers for the IPC_64 variants for
consistency, but decided against that for now.
ccount_timer_shutdown is called from the atomic context in the
secondary_start_kernel, resulting in the following BUG:
BUG: sleeping function called from invalid context
in_atomic(): 1, irqs_disabled(): 1, pid: 0, name: swapper/1
Preemption disabled at:
secondary_start_kernel+0xa1/0x130
Call Trace:
___might_sleep+0xe7/0xfc
__might_sleep+0x41/0x44
synchronize_irq+0x24/0x64
disable_irq+0x11/0x14
ccount_timer_shutdown+0x12/0x20
clockevents_switch_state+0x82/0xb4
clockevents_exchange_device+0x54/0x60
tick_check_new_device+0x46/0x70
clockevents_register_device+0x8c/0xc8
clockevents_config_and_register+0x1d/0x2c
local_timer_setup+0x75/0x7c
secondary_start_kernel+0xb4/0x130
should_never_return+0x32/0x35
Use disable_irq_nosync instead of disable_irq to avoid it.
This is safe because the ccount timer IRQ is per-CPU, and once IRQ is
masked the ISR will not be called.
Currently, CONFIG_JUMP_LABEL just means "I _want_ to use jump label".
The jump label is controlled by HAVE_JUMP_LABEL, which is defined
like this:
#if defined(CC_HAVE_ASM_GOTO) && defined(CONFIG_JUMP_LABEL)
# define HAVE_JUMP_LABEL
#endif
We can improve this by testing 'asm goto' support in Kconfig, then
make JUMP_LABEL depend on CC_HAS_ASM_GOTO.
Ugly #ifdef HAVE_JUMP_LABEL will go away, and CONFIG_JUMP_LABEL will
match to the real kernel capability.
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
Nobody has actually used the type (VERIFY_READ vs VERIFY_WRITE) argument
of the user address range verification function since we got rid of the
old racy i386-only code to walk page tables by hand.
It existed because the original 80386 would not honor the write protect
bit when in kernel mode, so you had to do COW by hand before doing any
user access. But we haven't supported that in a long time, and these
days the 'type' argument is a purely historical artifact.
A discussion about extending 'user_access_begin()' to do the range
checking resulted this patch, because there is no way we're going to
move the old VERIFY_xyz interface to that model. And it's best done at
the end of the merge window when I've done most of my merges, so let's
just get this done once and for all.
This patch was mostly done with a sed-script, with manual fix-ups for
the cases that weren't of the trivial 'access_ok(VERIFY_xyz' form.
There were a couple of notable cases:
- csky still had the old "verify_area()" name as an alias.
- the iter_iov code had magical hardcoded knowledge of the actual
values of VERIFY_{READ,WRITE} (not that they mattered, since nothing
really used it)
- microblaze used the type argument for a debug printout
but other than those oddities this should be a total no-op patch.
I tried to fix up all architectures, did fairly extensive grepping for
access_ok() uses, and the changes are trivial, but I may have missed
something. Any missed conversion should be trivially fixable, though.
- switch to generated syscall table
- switch ptrace to regsets, use regsets for core dumps
- complete tracehook implementation
- add syscall tracepoints support
- add jumplabels support
- add memtest support
- drop unused/duplicated code from entry.S, ptrace.c, coprocessor.S,
elf.h and syscall.h
- clean up warnings caused by WSR/RSR macros
- clean up DTC warnings about SPI controller node names in xtfpga.dtsi
- simplify coprocessor.S
- get rid of explicit 'l32r' instruction usage in assembly
* tag 'xtensa-20181228' of git://github.com/jcmvbkbc/linux-xtensa: (25 commits)
xtensa: implement jump_label support
xtensa: implement syscall tracepoints
xtensa: implement tracehook functions and enable HAVE_ARCH_TRACEHOOK
xtensa: enable CORE_DUMP_USE_REGSET
xtensa: implement TIE regset
xtensa: implement task_user_regset_view
xtensa: call do_syscall_trace_{enter,leave} selectively
xtensa: use NO_SYSCALL instead of -1
xtensa: define syscall_get_arch()
Move EM_XTENSA to uapi/linux/elf-em.h
xtensa: support memtest
xtensa: don't use l32r opcode directly
xtensa: xtfpga.dtsi: fix dtc warnings about SPI
xtensa: don't clear cpenable unconditionally on release
xtensa: simplify coprocessor.S
xtensa: clean up WSR*/RSR*/get_sr/set_sr
xtensa: drop unused declarations from elf.h
xtensa: clean up syscall.h
xtensa: drop unused coprocessor helper functions
xtensa: drop custom PTRACE_{PEEK,POKE}{TEXT,DATA}
