Scripted with coccinelle.
Also use proper wrappers for irq_desc access.
Cc: Chris Zankel <chris@zankel.net>
LKML-Reference: <20110206211137.750284615@linutronix.de>
Implement an irq chip to handle interrupts via gpio. The GPIO chip
initialization function now takes a bitmask denoting pins that should
be configured for their alternate function.
changes compared to v1:
- fixed bug on edge interrupt configuration
- accommodated to function name change
- moved definition of VARIANT_NR_IRQS to this patch
- renamed __XTENSA_S6000_IRQ_H to _XTENSA_S6000_IRQ_H as requested
Signed-off-by: Daniel Glöckner <dg@emlix.com>
Signed-off-by: Johannes Weiner <jw@emlix.com>
Signed-off-by: Chris Zankel <chris@zankel.net>
Platform initialization sets up the LED heartbeat that is controlled
via GPIO. Requesting the GPIO pins fails, however, as the chip is
only initialized later by a device_initcall().
Fix this up by exporting the initialization function. Let the
platform set up the chip before it starts using it.
Support for the Stretch S6000 Xtensa core variant.
Signed-off-by: Oskar Schirmer <os@emlix.com>
