path: root/arch/xtensa
2013-07-14xtensa: delete __cpuinit usage from all xtensa filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. Note that some harmless section mismatch warnings may result, since notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c) are flagged as __cpuinit -- so if we remove the __cpuinit from arch specific callers, we will also get section mismatch warnings. As an intermediate step, we intend to turn the linux/init.h cpuinit content into no-ops as early as possible, since that will get rid of these warnings. In any case, they are temporary and harmless. This removes all the arch/xtensa uses of the __cpuinit macros from all C files. Currently xtensa does not have any __CPUINIT used in assembly files. [1] https://lkml.org/lkml/2013/5/20/589 Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: linux-xtensa@linux-xtensa.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Just a bunch of small fixes and tidy ups: 1) Finish the "busy_poll" renames, from Eliezer Tamir. 2) Fix RCU stalls in IFB driver, from Ding Tianhong. 3) Linearize buffers properly in tun/macvtap zerocopy code. 4) Don't crash on rmmod in vxlan, from Pravin B Shelar. 5) Spinlock used before init in alx driver, from Maarten Lankhorst. 6) A sparse warning fix in bnx2x broke TSO checksums, fix from Dmitry Kravkov. 7) Dummy and ifb driver load failure paths can oops, fixes from Tan Xiaojun and Ding Tianhong. 8) Correct MTU calculations in IP tunnels, from Alexander Duyck. 9) Account all TCP retransmits in SNMP stats properly, from Yuchung Cheng. 10) atl1e and via-rhine do not handle DMA mapping failures properly, from Neil Horman. 11) Various equal-cost multipath route fixes in ipv6 from Hannes Frederic Sowa" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (36 commits) ipv6: only static routes qualify for equal cost multipathing via-rhine: fix dma mapping errors atl1e: fix dma mapping warnings tcp: account all retransmit failures usb/net/r815x: fix cast to restricted __le32 usb/net/r8152: fix integer overflow in expression net: access page->private by using page_private net: strict_strtoul is obsolete, use kstrtoul instead drivers/net/ieee802154: don't use devm_pinctrl_get_select_default() in probe drivers/net/ethernet/cadence: don't use devm_pinctrl_get_select_default() in probe drivers/net/can/c_can: don't use devm_pinctrl_get_select_default() in probe net/usb: add relative mii functions for r815x net/tipc: use %*phC to dump small buffers in hex form qlcnic: Adding Maintainers. gre: Fix MTU sizing check for gretap tunnels pkt_sched: sch_qfq: remove forward declaration of qfq_update_agg_ts pkt_sched: sch_qfq: improve efficiency of make_eligible gso: Update tunnel segmentation to support Tx checksum offload inet: fix spacing in assignment ifb: fix oops when loading the ifb failed ...
2013-07-11Merge tag 'xtensa-next-20130710' of git://github.com/czankel/xtensa-linuxLinus Torvalds
Pull Xtensa updates from Chris Zankel. * tag 'xtensa-next-20130710' of git://github.com/czankel/xtensa-linux: (22 commits) xtensa: remove the second argument of __bio_kmap_atomic() xtensa: add static function tracer support xtensa: Flat DeviceTree copy not future-safe xtensa: check TLB sanity on return to userspace xtensa: adjust boot parameters address when INITIALIZE_XTENSA_MMU_INSIDE_VMLINUX is selected xtensa: bootparams: fix typo xtensa: tell git to ignore generated .dtb files xtensa: ccount based sched_clock xtensa: ccount based clockevent implementation xtensa: consolidate ccount access routines xtensa: cleanup ccount frequency tracking xtensa: timex.h: remove unused symbols xtensa: tell git to ignore copied zlib source files xtensa: fix section mismatch in pcibios_fixup_bus xtensa: ISS: fix section mismatch in iss_net_setup arch: xtensa: include: asm: compiling issue, need cmpxchg64() defined. xtensa: xtfpga: fix section mismatch xtensa: remove unused platform_init_irq() xtensa: tell git to ignore generated files xtensa: flush TLB entries for pages of non-current mm correctly ...
2013-07-10net: rename busy poll socket op and globalsEliezer Tamir
Rename LL_SO to BUSY_POLL_SO Rename sysctl_net_ll_{read,poll} to sysctl_busy_{read,poll} Fix up users of these variables. Fix documentation for sysctl. a patch for the socket.7 man page will follow separately, because of limitations of my mail setup. Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "This is a re-do of the net-next pull request for the current merge window. The only difference from the one I made the other day is that this has Eliezer's interface renames and the timeout handling changes made based upon your feedback, as well as a few bug fixes that have trickeled in. Highlights: 1) Low latency device polling, eliminating the cost of interrupt handling and context switches. Allows direct polling of a network device from socket operations, such as recvmsg() and poll(). Currently ixgbe, mlx4, and bnx2x support this feature. Full high level description, performance numbers, and design in commit 0a4db187a999 ("Merge branch 'll_poll'") From Eliezer Tamir. 2) With the routing cache removed, ip_check_mc_rcu() gets exercised more than ever before in the case where we have lots of multicast addresses. Use a hash table instead of a simple linked list, from Eric Dumazet. 3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski, Marek Puzyniak, Michal Kazior, and Sujith Manoharan. 4) Support reporting the TUN device persist flag to userspace, from Pavel Emelyanov. 5) Allow controlling network device VF link state using netlink, from Rony Efraim. 6) Support GRE tunneling in openvswitch, from Pravin B Shelar. 7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from Daniel Borkmann and Eric Dumazet. 8) Allow controlling of TCP quickack behavior on a per-route basis, from Cong Wang. 9) Several bug fixes and improvements to vxlan from Stephen Hemminger, Pravin B Shelar, and Mike Rapoport. In particular, support receiving on multiple UDP ports. 10) Major cleanups, particular in the area of debugging and cookie lifetime handline, to the SCTP protocol code. From Daniel Borkmann. 11) Allow packets to cross network namespaces when traversing tunnel devices. From Nicolas Dichtel. 12) Allow monitoring netlink traffic via AF_PACKET sockets, in a manner akin to how we monitor real network traffic via ptype_all. From Daniel Borkmann. 13) Several bug fixes and improvements for the new alx device driver, from Johannes Berg. 14) Fix scalability issues in the netem packet scheduler's time queue, by using an rbtree. From Eric Dumazet. 15) Several bug fixes in TCP loss recovery handling, from Yuchung Cheng. 16) Add support for GSO segmentation of MPLS packets, from Simon Horman. 17) Make network notifiers have a real data type for the opaque pointer that's passed into them. Use this to properly handle network device flag changes in arp_netdev_event(). From Jiri Pirko and Timo Teräs. 18) Convert several drivers over to module_pci_driver(), from Peter Huewe. 19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a O(1) calculation instead. From Eric Dumazet. 20) Support setting of explicit tunnel peer addresses in ipv6, just like ipv4. From Nicolas Dichtel. 21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet. 22) Prevent a single high rate flow from overruning an individual cpu during RX packet processing via selective flow shedding. From Willem de Bruijn. 23) Don't use spinlocks in TCP md5 signing fast paths, from Eric Dumazet. 24) Don't just drop GSO packets which are above the TBF scheduler's burst limit, chop them up so they are in-bounds instead. Also from Eric Dumazet. 25) VLAN offloads are missed when configured on top of a bridge, fix from Vlad Yasevich. 26) Support IPV6 in ping sockets. From Lorenzo Colitti. 27) Receive flow steering targets should be updated at poll() time too, from David Majnemer. 28) Fix several corner case regressions in PMTU/redirect handling due to the routing cache removal, from Timo Teräs. 29) We have to be mindful of ipv4 mapped ipv6 sockets in upd_v6_push_pending_frames(). From Hannes Frederic Sowa. 30) Fix L2TP sequence number handling bugs, from James Chapman." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits) drivers/net: caif: fix wrong rtnl_is_locked() usage drivers/net: enic: release rtnl_lock on error-path vhost-net: fix use-after-free in vhost_net_flush net: mv643xx_eth: do not use port number as platform device id net: sctp: confirm route during forward progress virtio_net: fix race in RX VQ processing virtio: support unlocked queue poll net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit Documentation: Fix references to defunct linux-net@vger.kernel.org net/fs: change busy poll time accounting net: rename low latency sockets functions to busy poll bridge: fix some kernel warning in multicast timer sfc: Fix memory leak when discarding scattered packets sit: fix tunnel update via netlink dt:net:stmmac: Add dt specific phy reset callback support. dt:net:stmmac: Add support to dwmac version 3.610 and 3.710 dt:net:stmmac: Allocate platform data only if its NULL. net:stmmac: fix memleak in the open method ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available net: ipv6: fix wrong ping_v6_sendmsg return value ...
2013-07-08xtensa: remove the second argument of __bio_kmap_atomic()Zhao Hongjiang
kmap_atomic allows only one argument now, just remove the unused 'kmtype'. Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-07-08xtensa: add static function tracer supportMax Filippov
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-07-08xtensa: Flat DeviceTree copy not future-safeVineet Gupta
flat DT copy code calls bootmem allocator with @align = 0. This is probably OK with legacy allocator which xtensa uses right now, but this will panic right away with memblock allocator Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Marc Gauthier <marc@tensilica.com> Cc: linux-xtensa@linux-xtensa.org Cc: linux-kernel@vger.kernel.org Acked-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-07-08xtensa: check TLB sanity on return to userspaceMax Filippov
- check that user TLB mappings correspond to the current page table; - check that TLB mapping VPN is in the kernel/user address range in accordance with its ASID. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-07-08xtensa: adjust boot parameters address when ↵Max Filippov
INITIALIZE_XTENSA_MMU_INSIDE_VMLINUX is selected The virtual address of boot parameters chain is passed to the kernel via a2 register. Adjust it in case it is remapped during MMUv3 -> MMUv2 mapping change, i.e. when it is in the first 128M. Also fix interpretation of initrd and FDT addresses passed in the boot parameters: these are physical addresses. Cc: stable@vger.kernel.org Reported-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-07-08xtensa: bootparams: fix typoBaruch Siach
Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-07-08xtensa: tell git to ignore generated .dtb filesBaruch Siach
2013-07-08xtensa: ccount based sched_clockBaruch Siach
Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-07-08xtensa: ccount based clockevent implementationBaruch Siach
Reused some code from a preliminary implementation by Max Fillippov. Cc: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-07-08xtensa: consolidate ccount access routinesBaruch Siach
Use get_ccount everywhere; remove xtensa_get_ccount. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-07-08xtensa: cleanup ccount frequency trackingBaruch Siach
Remove unused nsec_per_ccount, and rename ccount_per_jiffy to ccount_preq. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-07-08xtensa: timex.h: remove unused symbolsBaruch Siach
2013-07-08xtensa: tell git to ignore copied zlib source filesBaruch Siach
2013-07-03mm/xtensa: prepare for removing num_physpages and simplify mem_init()Jiang Liu
Prepare for removing num_physpages and simplify mem_init(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: concentrate modification of totalram_pages into the mm coreJiang Liu
Concentrate code to modify totalram_pages into the mm core, so the arch memory initialized code doesn't need to take care of it. With these changes applied, only following functions from mm core modify global variable totalram_pages: free_bootmem_late(), free_all_bootmem(), free_all_bootmem_node(), adjust_managed_page_count(). With this patch applied, it will be much more easier for us to keep totalram_pages and zone->managed_pages in consistence. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: David Howells <dhowells@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: enhance free_reserved_area() to support poisoning memory with zeroJiang Liu
Address more review comments from last round of code review. 1) Enhance free_reserved_area() to support poisoning freed memory with pattern '0'. This could be used to get rid of poison_init_mem() on ARM64. 2) A previous patch has disabled memory poison for initmem on s390 by mistake, so restore to the original behavior. 3) Remove redundant PAGE_ALIGN() when calling free_reserved_area(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: change signature of free_reserved_area() to fix building warningsJiang Liu
Change signature of free_reserved_area() according to Russell King's suggestion to fix following build warnings: arch/arm/mm/init.c: In function 'mem_init': arch/arm/mm/init.c:603:2: warning: passing argument 1 of 'free_reserved_area' makes integer from pointer without a cast [enabled by default] free_reserved_area(__va(PHYS_PFN_OFFSET), swapper_pg_dir, 0, NULL); ^ In file included from include/linux/mman.h:4:0, from arch/arm/mm/init.c:15: include/linux/mm.h:1301:22: note: expected 'long unsigned int' but argument is of type 'void *' extern unsigned long free_reserved_area(unsigned long start, unsigned long end, mm/page_alloc.c: In function 'free_reserved_area': >> mm/page_alloc.c:5134:3: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast [enabled by default] In file included from arch/mips/include/asm/page.h:49:0, from include/linux/mmzone.h:20, from include/linux/gfp.h:4, from include/linux/mm.h:8, from mm/page_alloc.c:18: arch/mips/include/asm/io.h:119:29: note: expected 'const volatile void *' but argument is of type 'long unsigned int' mm/page_alloc.c: In function 'free_area_init_nodes': mm/page_alloc.c:5030:34: warning: array subscript is below array bounds [-Warray-bounds] Also address some minor code review comments. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reported-by: Arnd Bergmann <arnd@arndb.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-29consolidate io_remap_pfn_range definitionsAl Viro
2013-06-17net: add socket option for low latency pollingEliezer Tamir
adds a socket option for low latency polling. This allows overriding the global sysctl value with a per-socket one. Unexport sysctl_net_ll_poll since for now it's not needed in modules. Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-05xtensa: fix section mismatch in pcibios_fixup_busMax Filippov
Remove __init annotation from pcibios_fixup_bus as is called from pci_scan_child_bus which is not __init. Also fix a couple of minor build warnings. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-06-05xtensa: ISS: fix section mismatch in iss_net_setupMax Filippov
iss_net_setup is only called from __setup, so it should be marked __init. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-06-05arch: xtensa: include: asm: compiling issue, need cmpxchg64() defined.Chen Gang
When compiling with 'allmodconfig', some of drivers need cmpxchg64(), xtensa does not supply 64-bit implementation for 'xchg', so use the 'generic' implementation. e.g. (for next-20130527 tree): drivers/block/blockconsole.c:164:2: error: implicit declaration of function ‘cmpxchg64’ [-Werror=implicit-function-declaration] Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-06-05xtensa: xtfpga: fix section mismatchBaruch Siach
platform_calibrate_ccount() calls update_clock_frequency() which is in .init section. However, platform_calibrate_ccount() itself is only called from .init (i.e., time_init()). Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-06-05xtensa: remove unused platform_init_irq()Baruch Siach
2013-06-05xtensa: tell git to ignore generated filesBaruch Siach
2013-06-05xtensa: flush TLB entries for pages of non-current mm correctlyMax Filippov
Sometimes under high memory pressure one process gets a page of another process, which manifests itself with an invalid instruction exception. This happens because flush_tlb_page fails to clear TLB entries when called with vma that does not belong to current mm, because it does not set RASID appropriately. When page reclaiming mechanism swaps physical pages out replacing their PTEs with none or swap PTEs, it calls flush_tlb_page. Later physical page may be reused elsewhere, but the stale TLB mapping still refers to it, allowing process that owned the mapping to see the new state of that physical page. Put ASID of the mm that owns vma to the RASID to fix that issue. Also replace otherwise meaningless local_save_flags with local_irq_save. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-05-20xtensa: fix fast_store_prohibited _PAGE_WRITABLE_BIT testMax Filippov
Before _PAGE_WRITABLE_BIT test fast_store_prohibited must make sure that PTE is present. Otherwise 'writable' bit is undefined and may be reused in the 'file offset' or 'swap type' PTE fields. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-05-20xtensa: fix TLB multihit exceptionsChris Zankel
- set _PAGE_USER in the pte_clear to avoid having TLB multihit exceptions (see following threads for more details); http://lists.linux-xtensa.org/pipermail/linux-xtensa/Week-of-Mon-20130401/ http://lists.linux-xtensa.org/pipermail/linux-xtensa/Week-of-Mon-20130408/ - improved documentation of the PTE layout - fix PTE mapping for present and 'prot_none' pages for T1050 hw and earlier - fix pte_file offset and size - add check for the correct number of bits for swap type CC: piet.delaney@gmail.com CC: jcmvbkbc@gmail.com Signed-off-by: Chris Zankel <chris@zankel.net>
2013-05-09Merge tag 'xtensa-next-20130508' of git://github.com/czankel/xtensa-linuxLinus Torvalds
Pull xtensa updates from Chris Zankel: "Support for the latest MMU architecture that allows for a larger accessible memory region, and various bug-fixes" * tag 'xtensa-next-20130508' of git://github.com/czankel/xtensa-linux: xtensa: Switch to asm-generic/linkage.h xtensa: fix redboot load address xtensa: ISS: fix timer_lock usage in rs_open xtensa: disable IRQs while IRQ handler is running xtensa: enable lockdep support xtensa: fix arch_irqs_disabled_flags implementation xtensa: add irq flags trace support xtensa: provide custom CALLER_ADDR* implementations xtensa: add stacktrace support xtensa: clean up stpill_registers xtensa: don't use a7 in simcalls xtensa: don't attempt to use unconfigured timers xtensa: provide default platform_pcibios_init implementation xtensa: remove KCORE_ELF again xtensa: document MMUv3 setup sequence xtensa: add MMU v3 support xtensa: fix ibreakenable register update xtensa: fix oprofile building as module
2013-05-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs fixes from Al Viro: "Regression fix from Geert + yet another open-coded kernel_read()" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: ecryptfs: don't open-code kernel_read() xtensa simdisk: Fix proc_create_data() conversion fallout
2013-05-09xtensa simdisk: Fix proc_create_data() conversion falloutGeert Uytterhoeven
arch/xtensa/platforms/iss/simdisk.c: In function 'proc_read_simdisk': arch/xtensa/platforms/iss/simdisk.c:220:12: warning: initialization discards 'const' qualifier from pointer target type [enabled by default] arch/xtensa/platforms/iss/simdisk.c: In function 'proc_write_simdisk': arch/xtensa/platforms/iss/simdisk.c:241:38: error: 'buffer' undeclared (first use in this function) arch/xtensa/platforms/iss/simdisk.c:241:38: note: each undeclared identifier is reported only once for each function it appears in Introduced by commit a69755b187749e7cc020e17127a54f395aea4eaa ("xtensa simdisk: switch to proc_create_data()") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-09Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull removal of GENERIC_GPIO from Grant Likely: "GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it is possible to do so which has been causing confusion and breakage. This branch does the work to completely eliminate GENERIC_GPIO." * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux: gpio: update gpio Chinese documentation Remove GENERIC_GPIO config option Convert selectors of GENERIC_GPIO to GPIOLIB blackfin: force use of gpiolib m68k: coldfire: use gpiolib mips: pnx833x: remove requirement for GENERIC_GPIO openrisc: default GENERIC_GPIO to false avr32: default GENERIC_GPIO to false xtensa: remove explicit selection of GENERIC_GPIO sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB powerpc: remove redundant GENERIC_GPIO selection unicore32: default GENERIC_GPIO to false unicore32: remove unneeded select GENERIC_GPIO arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB arm: remove redundant GENERIC_GPIO selection mips: alchemy: require gpiolib mips: txx9: change GENERIC_GPIO to GPIOLIB mips: loongson: use GPIO driver on CONFIG_GPIOLIB mips: remove redundant GENERIC_GPIO select
2013-05-09xtensa: Switch to asm-generic/linkage.hGeert Uytterhoeven
2013-05-09xtensa: fix redboot load addressChris Zankel
With the patch to support MMUv3, the base address for the loaded binary image has changed, and a fix was applied to the U-Boot image. This fixes the RedBoot image. Signed-off-by: Chris Zankel <chris@zankel.net>
2013-05-09xtensa: ISS: fix timer_lock usage in rs_openMax Filippov
This fixes the following lockdep splat: [ 66.460000] ================================= [ 66.460000] [ INFO: inconsistent lock state ] [ 66.460000] 3.9.0-rc5-00161-ga48dd49 #4 Not tainted [ 66.460000] --------------------------------- [ 66.460000] inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage. [ 66.460000] swapper/1 [HC0[0]:SC1[1]:HE1:SE0] takes: [ 66.460000] (timer_lock){+.?...}, at: [<d0006cde>] rs_poll+0x12/0xdc [ 66.460000] {SOFTIRQ-ON-W} state was registered at: [ 66.460000] [<d00421f0>] lock_acquire+0xec/0x13c [ 66.460000] [<d01ea036>] _raw_spin_lock+0x3a/0x84 [ 66.460000] [<d0006c8c>] rs_open+0x18/0x58 [ 66.460000] [<d0139ea2>] tty_open+0x262/0x3cc [ 66.460000] [<d00942e0>] chrdev_open+0x8c/0xe0 [ 66.460000] [<d00907b2>] do_dentry_open$isra$16+0x10e/0x190 [ 66.460000] [<d0091141>] finish_open+0x39/0x48 [ 66.460000] [<d009a0b4>] do_last$isra$34+0x6c4/0x824 [ 66.460000] [<d009a27a>] path_openat+0x66/0x310 [ 66.460000] [<d009a53a>] do_filp_open+0x16/0x44 [ 66.460000] [<d0091445>] do_sys_open+0xd5/0x13c [ 66.460000] [<d00914be>] sys_open+0x12/0x18 [ 66.460000] [<d0413ffc>] kernel_init_freeable+0xe4/0x12c [ 66.460000] [<d01e2a9c>] kernel_init+0xc/0x9c [ 66.460000] [<d00044fc>] ret_from_kernel_thread+0x8/0xc [ 66.460000] irq event stamp: 132542 [ 66.460000] hardirqs last enabled at (132542): [<d01ea2ec>] _raw_spin_unlock_irq+0x30/0x44 [ 66.460000] hardirqs last disabled at (132541): [<d01ea11e>] _raw_spin_lock_irq+0xe/0x8c [ 66.460000] softirqs last enabled at (132234): [<d0017d32>] __do_softirq+0x216/0x2a4 [ 66.460000] softirqs last disabled at (132539): [<d0018024>] irq_exit+0x38/0x40 [ 66.460000] [ 66.460000] other info that might help us debug this: [ 66.460000] Possible unsafe locking scenario: [ 66.460000] [ 66.460000] CPU0 [ 66.460000] ---- [ 66.460000] lock(timer_lock); [ 66.460000] <Interrupt> [ 66.460000] lock(timer_lock); [ 66.460000] [ 66.460000] *** DEADLOCK *** [ 66.460000] [ 66.460000] 1 lock held by swapper/1: [ 66.460000] #0: (((&serial_timer))){+.-...}, at: [<d001c65c>] call_timer_fn+0x0/0x1f0 [ 66.460000] Stack: d7c2fac0 00000018 00000004 00000001 d7c2faa0 00000004 00000006 d7c2fa90 9003e87c d7c2fae0 d7c30000 d025a87c 00000001 0000000f 00000000 d7c2fac0 9004005d d7c2fb10 d7c30000 d7c30338 00000001 00000001 00000000 d7c30338 [ 66.460000] Call Trace: [ 66.460000] [<d01e4f93>] print_usage_bug$part$26+0x1c3/0x1c8 [ 66.460000] [<d003e87c>] mark_lock+0x2b4/0x440 [ 66.460000] [<d004005d>] __lock_acquire+0x54d/0x16c4 [ 66.460000] [<d00421f0>] lock_acquire+0xec/0x13c [ 66.460000] [<d01ea036>] _raw_spin_lock+0x3a/0x84 [ 66.460000] [<d0006cde>] rs_poll+0x12/0xdc [ 66.460000] [<d001c71a>] call_timer_fn+0xbe/0x1f0 [ 66.460000] [<d001cd90>] run_timer_softirq+0x198/0x1f4 [ 66.460000] [<d0017c30>] __do_softirq+0x114/0x2a4 [ 66.460000] [<d0018024>] irq_exit+0x38/0x40 [ 66.460000] [<d00046c0>] do_IRQ+0x44/0x48 [ 66.460000] [<d0005c58>] do_interrupt+0x4c/0x54 [ 66.460000] [<d0003c80>] common_exception_return+0x0/0x5c [ 66.460000] [<d006682c>] free_pcppages_bulk+0x254/0x308 [ 66.460000] Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-05-09xtensa: disable IRQs while IRQ handler is runningMax Filippov
IRQ handlers are expected to run with IRQs disabled. See e.g. http://lwn.net/Articles/380931/ for a longer story. This was overlooked in the commit 2d1c645 xtensa: dispatch medium-priority interrupts Revert to old behavior and simplify interrupt entry and exit code. Interrupt handler still honours IRQ priority. do_notify_resume/schedule must be called with interrupts enabled, enable interrupts if we return from user exception. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-05-09xtensa: enable lockdep supportMax Filippov
2013-05-09xtensa: fix arch_irqs_disabled_flags implementationMax Filippov
IRQs are disabled when PS.EXCM is set or PS.INTLEVEL is equal to or higher than LOCKLEVEL. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-05-09xtensa: add irq flags trace supportMax Filippov
2013-05-09xtensa: provide custom CALLER_ADDR* implementationsMax Filippov
Definition of CALLER_ADDR* through __builtin_return_address makes compiler insert calls to __xtensa_libgcc_window_spill, which in turn makes fast_syscall_spill_registers syscall that clobbers registers when called from the kernel mode, leading to invalid opcode exceptions on return to userspace. Provide definition for CALLER_ADDR0 as MAKE_PC_FROM_RA(a0, a1) and in case CONFIG_FRAME_POINTER is enabled extract CALLER_ADDR{1-3} from stack. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-05-09xtensa: add stacktrace supportMax Filippov
2013-05-09xtensa: clean up stpill_registersMax Filippov
- remove unused asm parameters; - fix EXCM bit setting in the PS SR during _spill_registers call. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-05-09xtensa: don't use a7 in simcallsMax Filippov
To support FRAME_POINTER avoid using a7 in __simc (none of the existing simcalls needs it). Replace calls to __simc with more specific simc_read, simc_write and simc_lseek calls. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2013-05-09xtensa: don't attempt to use unconfigured timersMax Filippov
2013-05-09xtensa: provide default platform_pcibios_init implementationMax Filippov
This fixes the following build error: arch/xtensa/kernel/built-in.o:(.init.literal+0xe8): undefined reference to `platform_pcibios_init' arch/xtensa/kernel/built-in.o: In function `setup_arch': (.init.text+0x20e): undefined reference to `platform_pcibios_init' and allows platform to omit definition of platform_pcibios_init if it's empty. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
