[ Upstream commit 8d911904f3ce412b20874a9c95f82009dcbb007c ]
PMC5 on POWER9 DD1 may not provide right counts in all
sampling scenarios, hence use PM_INST_DISP event instead
in PMC2 or PMC3 in preference.
Signed-off-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com>
[ Upstream commit ddffe98d166f4a93d996d5aa628fd745311fc1e7 ]
To identify that pages of page table are allocated from bootmem
allocator, magic number sets to page->lru.next.
But page->lru list is initialized in reserve_bootmem_region(). So when
calling free_pagetable(), the function cannot find the magic number of
pages. And free_pagetable() frees the pages by free_reserved_page() not
put_page_bootmem().
But if the pages are allocated from bootmem allocator and used as page
table, the pages have private flag. So before freeing the pages, we
should clear the private flag by put_page_bootmem().
Before applying the commit 7bfec6f47bb0 ("mm, page_alloc: check multiple
page fields with a single branch"), we could find the following visible
issue:
BUG: Bad page state in process kworker/u1024:1
page:ffffea103cfd8040 count:0 mapcount:0 mappi
flags: 0x6fffff80000800(private)
page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set
bad because of flags: 0x800(private)
<snip>
Call Trace:
[...] dump_stack+0x63/0x87
[...] bad_page+0x114/0x130
[...] free_pages_prepare+0x299/0x2d0
[...] free_hot_cold_page+0x31/0x150
[...] __free_pages+0x25/0x30
[...] free_pagetable+0x6f/0xb4
[...] remove_pagetable+0x379/0x7ff
[...] vmemmap_free+0x10/0x20
[...] sparse_remove_one_section+0x149/0x180
[...] __remove_pages+0x2e9/0x4f0
[...] arch_remove_memory+0x63/0xc0
[...] remove_memory+0x8c/0xc0
[...] acpi_memory_device_remove+0x79/0xa5
[...] acpi_bus_trim+0x5a/0x8d
[...] acpi_bus_trim+0x38/0x8d
[...] acpi_device_hotplug+0x1b7/0x418
[...] acpi_hotplug_work_fn+0x1e/0x29
[...] process_one_work+0x152/0x400
[...] worker_thread+0x125/0x4b0
[...] kthread+0xd8/0xf0
[...] ret_from_fork+0x22/0x40
And the issue still silently occurs.
Until freeing the pages of page table allocated from bootmem allocator,
the page->freelist is never used. So the patch sets magic number to
page->freelist instead of page->lru.next.
[isimatu.yasuaki@jp.fujitsu.com: fix merge issue]
Link: http://lkml.kernel.org/r/722b1cc4-93ac-dd8b-2be2-7a7e313b3b0b@gmail.com
Link: http://lkml.kernel.org/r/2c29bd9f-5b67-02d0-18a3-8828e78bbb6f@gmail.com
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Xishi Qiu <qiuxishi@huawei.com>
[ Upstream commit 7dd4fcf5b70694dc961eb6b954673e4fc9730dbd ]
On panic, all other CPUs are stopped except the one which had
hit panic. To keep console alive, we need to migrate hvcons irq
to panicked CPU.
Signed-off-by: Vijay Kumar <vijay.ac.kumar@oracle.com>
commit 5fdc66e046206306bf61ff2d626bfa52ca087f7b upstream.
Commit db8466c581cc ("MIPS: IRQ Stack: Unwind IRQ stack onto task
stack") erroneously set the initial stack pointer of the IRQ stack to a
value with a 4 byte alignment. The MIPS32 ABI requires that the minimum
stack alignment is 8 byte, and the MIPS64 ABIs(n32/n64) require 16 byte
minimum alignment. Fix IRQ_STACK_START such that it leaves space for the
dummy stack frame (containing interrupted task kernel stack pointer)
while also meeting minimum alignment requirements.
Fixes: db8466c581cc ("MIPS: IRQ Stack: Unwind IRQ stack onto task stack")
Reported-by: Darius Ivanauskas <dasilt@yahoo.com>
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Jason A. Donenfeld <jason@zx2c4.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/16760/
commit fd19d3b45164466a4adce7cbff448ba9189e1427 upstream.
The function updates context->root_level but didn't call
update_last_nonleaf_level so the previous and potentially wrong value
was used for page walks. For example, a zero value of last_nonleaf_level
would allow a potential out-of-bounds access in arch/x86/mmu/paging_tmpl.h's
walk_addr_generic function (CVE-2017-12188).
Fixes: 155a97a3d7c78b46cef6f1a973c831bc5a4f82bb
Signed-off-by: Ladi Prosek <lprosek@redhat.com>
commit 6b32c126d33d5cb379bca280ab8acedc1ca978ff upstream.
The alt_max_short() macro in asm/alternative.h does not work as
intended, leading to nasty bugs. E.g. alt_max_short("1", "3")
evaluates to 3, but alt_max_short("3", "1") evaluates to 1 -- not
exactly the maximum of 1 and 3.
In fact, I had to learn it the hard way by crashing my kernel in not
so funny ways by attempting to make use of the ALTENATIVE_2 macro
with alternatives where the first one was larger than the second
one.
According to [1] and commit dbe4058a6a44 ("x86/alternatives: Fix
ALTERNATIVE_2 padding generation properly") the right handed side
should read "-(-(a < b))" not "-(-(a - b))". Fix that, to make the
macro work as intended.
While at it, fix up the comments regarding the additional "-", too.
It's not about gas' usage of s32 but brain dead logic of having a
"true" value of -1 for the < operator ... *sigh*
Btw., the one in asm/alternative-asm.h is correct. And, apparently,
all current users of ALTERNATIVE_2() pass same sized alternatives,
avoiding to hit the bug.
[1] http://graphics.stanford.edu/~seander/bithacks.html#IntegerMinOrMax
Reviewed-and-tested-by: Borislav Petkov <bp@suse.de>
Fixes: dbe4058a6a44 ("x86/alternatives: Fix ALTERNATIVE_2 padding generation properly")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Borislav Petkov <bp@suse.de>
Link: https://lkml.kernel.org/r/1507228213-13095-1-git-send-email-minipli@googlemail.com
commit 8eb3f87d903168bdbd1222776a6b1e281f50513e upstream.
When KVM emulates an exit from L2 to L1, it loads L1 CR4 into the
guest CR4. Before this CR4 loading, the guest CR4 refers to L2
CR4. Because these two CR4's are in different levels of guest, we
should vmx_set_cr4() rather than kvm_set_cr4() here. The latter, which
is used to handle guest writes to its CR4, checks the guest change to
CR4 and may fail if the change is invalid.
The failure may cause trouble. Consider we start
a L1 guest with non-zero L1 PCID in use,
(i.e. L1 CR4.PCIDE == 1 && L1 CR3.PCID != 0)
and
a L2 guest with L2 PCID disabled,
(i.e. L2 CR4.PCIDE == 0)
and following events may happen:
1. If kvm_set_cr4() is used in load_vmcs12_host_state() to load L1 CR4
into guest CR4 (in VMCS01) for L2 to L1 exit, it will fail because
of PCID check. As a result, the guest CR4 recorded in L0 KVM (i.e.
vcpu->arch.cr4) is left to the value of L2 CR4.
2. Later, if L1 attempts to change its CR4, e.g., clearing VMXE bit,
kvm_set_cr4() in L0 KVM will think L1 also wants to enable PCID,
because the wrong L2 CR4 is used by L0 KVM as L1 CR4. As L1
CR3.PCID != 0, L0 KVM will inject GP to L1 guest.
Fixes: 4704d0befb072 ("KVM: nVMX: Exiting from L2 to L1")
Cc: qemu-stable@nongnu.org
Signed-off-by: Haozhong Zhang <haozhong.zhang@intel.com>
commit 829ee279aed43faa5cb1e4d65c0cad52f2426c53 upstream.
is_last_gpte() is not equivalent to the pseudo-code given in commit
6bb69c9b69c31 ("KVM: MMU: simplify last_pte_bitmap") because an incorrect
value of last_nonleaf_level may override the result even if level == 1.
It is critical for is_last_gpte() to return true on level == 1 to
terminate page walks. Otherwise memory corruption may occur as level
is used as an index to various data structures throughout the page
walking code. Even though the actual bug would be wherever the MMU is
initialized (as in the previous patch), be defensive and ensure here
that is_last_gpte() returns the correct value.
This patch is also enough to fix CVE-2017-12188.
Fixes: 6bb69c9b69c315200ddc2bc79aee14c0184cf5b2
Cc: Andy Honig <ahonig@google.com>
[Panic if walk_addr_generic gets an incorrect level; this is a serious
bug and it's not worth a WARN_ON where the recovery path might hide
further exploitable issues; suggested by Andrew Honig. - Paolo]
commit ca8eb05b5f332a9e1ab3e2ece498d49f4d683470 upstream.
The FPU emulator includes 2 calls to pr_err() which are triggered by
invalid instruction encodings for MIPSr6 cmp.cond.fmt instructions.
These cases are not kernel errors, merely invalid instructions which are
already handled by delivering a SIGILL which will provide notification
that something failed in cases where that makes sense.
In cases where that SIGILL is somewhat expected & being handled, for
example when crashme happens to generate one of the affected bad
encodings, the message is printed with no useful context about what
triggered it & spams the kernel log for no good reason.
Remove the pr_err() calls to make crashme run silently & treat the bad
encodings the same way we do others, with a SIGILL & no further kernel
log output.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Fixes: f8c3c6717a71 ("MIPS: math-emu: Add support for the CMP.condn.fmt R6 instruction")
Patchwork: https://patchwork.linux-mips.org/patch/17253/
commit c8401dda2f0a00cd25c0af6a95ed50e478d25de4 upstream.
TF is handled a bit differently for syscall and sysret, compared
to the other instructions: TF is checked after the instruction completes,
so that the OS can disable #DB at a syscall by adding TF to FMASK.
When the sysret is executed the #DB is taken "as if" the syscall insn
just completed.
KVM emulates syscall so that it can trap 32-bit syscall on Intel processors.
Fix the behavior, otherwise you could get #DB on a user stack which is not
nice. This does not affect Linux guests, as they use an IST or task gate
for #DB.
This fixes CVE-2017-7518.
Cc: stable@vger.kernel.org
Reported-by: Andy Lutomirski <luto@kernel.org>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
[bwh: Backported to 4.9:
- kvm_vcpu_check_singlestep() sets some flags differently
- Drop changes to kvm_skip_emulated_instruction()]
Cc: Ben Hutchings <benh@debian.org>
Cc: Salvatore Bonaccorso <carnil@debian.org>
commit 044215d145a7a8a60ffa8fdc859d110a795fa6ea upstream.
Currently it's possible that on returning from the signal handler
through the restore_tm_sigcontexts() code path (e.g. from a signal
caught due to a `trap` instruction executed in the middle of an HTM
block, or a deliberately constructed sigframe) an illegal TM state
(like TS=10 TM=0, i.e. "T0") is set in SRR1 and when `rfid` sets
implicitly the MSR register from SRR1 register on return to userspace
it causes a TM Bad Thing exception.
That illegal state can be set (a) by a malicious user that disables
the TM bit by tweaking the bits in uc_mcontext before returning from
the signal handler or (b) by a sufficient number of context switches
occurring such that the load_tm counter overflows and TM is disabled
whilst in the signal handler.
This commit fixes the illegal TM state by ensuring that TM bit is
always enabled before we return from restore_tm_sigcontexts(). A small
comment correction is made as well.
Fixes: 5d176f751ee3 ("powerpc: tm: Enable transactional memory (TM) lazily for userspace")
Signed-off-by: Gustavo Romero <gromero@linux.vnet.ibm.com>
Signed-off-by: Breno Leitao <leitao@debian.org>
Signed-off-by: Cyril Bur <cyrilbur@gmail.com>
commit 265e60a170d0a0ecfc2d20490134ed2c48dd45ab upstream.
When using transactional memory (TM), the CPU can be in one of six
states as far as TM is concerned, encoded in the Machine State
Register (MSR). Certain state transitions are illegal and if attempted
trigger a "TM Bad Thing" type program check exception.
If we ever hit one of these exceptions it's treated as a bug, ie. we
oops, and kill the process and/or panic, depending on configuration.
One case where we can trigger a TM Bad Thing, is when returning to
userspace after a system call or interrupt, using RFID. When this
happens the CPU first restores the user register state, in particular
r1 (the stack pointer) and then attempts to update the MSR. However
the MSR update is not allowed and so we take the program check with
the user register state, but the kernel MSR.
This tricks the exception entry code into thinking we have a bad
kernel stack pointer, because the MSR says we're coming from the
kernel, but r1 is pointing to userspace.
To avoid this we instead always switch to the emergency stack if we
take a TM Bad Thing from the kernel. That way none of the user
register values are used, other than for printing in the oops message.
This is the fix for CVE-2017-1000255.
[mpe: Rewrite change log & comments, tweak asm slightly]
commit 91c575b335766effa6103eba42a82aea560c365f upstream.
Commit 227be799c39a ("s390/mm: uninline pmdp_xxx functions from pgtable.h")
inadvertently changed the behavior of pmdp_invalidate(), so that it now
clears the pmd instead of just marking it as invalid. Fix this by restoring
the original behavior.
A possible impact of the misbehaving pmdp_invalidate() would be the
MADV_DONTNEED races (see commits ced10803 and 58ceeb6b), although we
should not have any negative impact on the related dirty/young flags,
since those flags are not set by the hardware on s390.
Fixes: 227be799c39a ("s390/mm: uninline pmdp_xxx functions from pgtable.h")
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
commit 0527873b29b077fc8e656acd63e1866b429fef55 upstream.
gcc-7 warns about some declarations that are more 'const' than necessary:
arch/arm/mach-at91/pm.c:338:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct of_device_id const ramc_ids[] __initconst = {
arch/arm/mach-bcm/bcm_kona_smc.c:36:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct of_device_id const bcm_kona_smc_ids[] __initconst = {
arch/arm/mach-spear/time.c:207:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct of_device_id const timer_of_match[] __initconst = {
arch/arm/mach-omap2/prm_common.c:714:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct of_device_id const omap_prcm_dt_match_table[] __initconst = {
arch/arm/mach-omap2/vc.c:562:35: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct i2c_init_data const omap4_i2c_timing_data[] __initconst = {
The ones in arch/arm were apparently all introduced accidentally by one
commit that correctly marked a lot of variables as __initconst.
Fixes: 19c233b79d1a ("ARM: appropriate __init annotation for const data")
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Krzysztof Hałasa <khalasa@piap.pl>
[ Upstream commit 88d1fa70c21d7b431386cfe70cdc514d98b0c9c4 ]
Memory starts at 0x80000000, not 0. 0 "works" due to mirrior of the
first 128M of RAM to that address. Anything greater than 128M will
quickly find nothing there. Correcting the starting address has
everything working again.
Signed-off-by: Jon Mason <jon.mason@broadcom.com>
Fixes: 7eb05f6d ("ARM: dts: bcm5301x: Add BCM SVK DT files")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 2b85b3d22920db7473e5fed5719e7955c0ec323e ]
The following commits:
f7c28833c2 ("x86/acpi: Enable acpi to register all possible cpus at
boot time") and 8f54969dc8 ("x86/acpi: Introduce persistent storage
for cpuid <-> apicid mapping")
... registered all the possible CPUs at boot time via ACPI tables to
make the mapping of cpuid <-> apicid fixed. Both enabled and disabled
CPUs could have a logical CPU ID after boot time.
But, ACPI tables are unreliable. the number amd order of Local APIC
entries which depends on the firmware is often inconsistent with the
physical devices. Even if they are consistent, The disabled CPUs which
take up some logical CPU IDs will also make the order discontinuous.
Revert the part of disabled CPUs registration, keep the allocation
logic of logical CPU IDs and also keep some code location changes.
Signed-off-by: Dou Liyang <douly.fnst@cn.fujitsu.com>
Tested-by: Xiaolong Ye <xiaolong.ye@intel.com>
Cc: rjw@rjwysocki.net
Cc: linux-acpi@vger.kernel.org
Cc: guzheng1@huawei.com
Cc: izumi.taku@jp.fujitsu.com
Cc: lenb@kernel.org
Link: http://lkml.kernel.org/r/1488528147-2279-4-git-send-email-douly.fnst@cn.fujitsu.com
[ Upstream commit 74e3f6e63da6c8e8246fba1689e040bc926b4a1a ]
Fix potential NULL pointer dereference and clean up
coding style errors (code indent, trailing whitespaces).
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Signed-off-by: Helge Deller <deller@gmx.de>
[ Upstream commit fb2155e3c30dc2043b52020e26965067a3e7779c ]
The vpe_mask member of struct core_boot_config is of type atomic_t,
which is a 32bit type. In cps-vec.S this member was being retrieved by a
PTR_L macro, which on 64bit systems is a 64bit load. On little endian
systems this is OK, since the double word that is retrieved will have
the required less significant word in the correct position. However, on
big endian systems the less significant word of the load is retrieved
from address+4, and the more significant from address+0. The destination
register therefore ends up with the required word in the more
significant word
e.g. when starting the second VP of a big endian 64bit system, the load
PTR_L ta2, COREBOOTCFG_VPEMASK(a0)
ends up setting register ta2 to 0x0000000300000000
When this value is written to the CPC it is ignored, since it is
invalid to write anything larger than 4 bits. This results in any VP
other than VP0 in a core failing to start in 64bit big endian systems.
Change the load to a 32bit load word instruction to fix the bug.
Fixes: f12401d7219f ("MIPS: smp-cps: Pull boot config retrieval out of mips_cps_boot_vpes")
Cc: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/15787/
[ Upstream commit db8466c581cca1a08b505f1319c3ecd246f16fa8 ]
When the separate IRQ stack was introduced, stack unwinding only
proceeded as far as the top of the IRQ stack, leading to kernel
backtraces being less useful, lacking the trace of what was interrupted.
Fix this by providing a means for the kernel to unwind the IRQ stack
onto the interrupted task stack. The processor state is saved to the
kernel task stack on interrupt. The IRQ_STACK_START macro reserves an
unsigned long at the top of the IRQ stack where the interrupted task
stack pointer can be saved. After the active stack is switched to the
IRQ stack, save the interrupted tasks stack pointer to the reserved
location.
Fix the stack unwinding code to look for the frame being the top of the
IRQ stack and if so get the next frame from the saved location. The
existing test does not work with the separate stack since the ra is no
longer pointed at ret_from_{irq,exception}.
The test to stop unwinding the stack 32 bytes from the top of a stack
must be modified to allow unwinding to continue up to the location of
the saved task stack pointer when on the IRQ stack. The low / high marks
of the stack are set depending on whether the sp is on an irq stack or
not.
Cc: Marcin Nowakowski <marcin.nowakowski@imgtec.com>
Cc: Masanari Iida <standby24x7@gmail.com>
Cc: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/15788/
[ Upstream commit 13a6798e4a03096b11bf402a063786a7be55d426 ]
Fixes this:
kexec: Undefined symbol: __asan_load8_noabort
kexec-bzImage64: Loading purgatory failed
Link: http://lkml.kernel.org/r/1489672155.4458.7.camel@gmx.de
Signed-off-by: Mike Galbraith <efault@gmx.de>
Cc: Alexander Potapenko <glider@google.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
[ Upstream commit b3d91db3f71d5f70ea60d900425a3f96aeb3d065 ]
Free memory mapping, if ath79_clocks_init_dt_ng is not successful.
Fixes: 3bdf1071ba7d ("MIPS: ath79: update devicetree clock support for AR9132")
Cc: antonynpavlov@gmail.com
Cc: albeu@free.fr
Cc: hackpascal@gmail.com
Cc: sboyd@codeaurora.org
Patchwork: https://patchwork.linux-mips.org/patch/14915/
[ Upstream commit 98ea51cb0c8ce009d9da1fd7b48f0ff1d7a9bbb0 ]
Hauke already fixed a couple of them, but one instance remains
that checks for a negative integer when it should check
for a NULL pointer:
arch/mips/lantiq/xway/sysctrl.c: In function 'ltq_soc_init':
arch/mips/lantiq/xway/sysctrl.c:473:19: error: ordered comparison of pointer with integer zero [-Werror=extra]
Fixes: 6e807852676a ("MIPS: Lantiq: Fix check for return value of request_mem_region()")
Cc: John Crispin <john@phrozen.org>
Patchwork: https://patchwork.linux-mips.org/patch/15043/
[ Upstream commit f235c7e7a75325f28a33559a71f25a0eca6112db ]
Add MT2701 subsystem clock controllers, inlcude mmsys, imgsys,
vdecsys, hifsys, ethsys and bdpsys.
Signed-off-by: James Liao <jamesjj.liao@mediatek.com>
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
[ Upstream commit 8a792e9afbce84a0fdaf213fe42bb97382487094 ]
REMAP_VECTORS_TO_RAM depends on DRAM_BASE, but since DRAM_BASE is a
hex, REMAP_VECTORS_TO_RAM could never get enabled. Also depending on
DRAM_BASE is redundant as whenever REMAP_VECTORS_TO_RAM makes itself
available to Kconfig, DRAM_BASE also is available as the Kconfig
gets sourced on !MMU.
Signed-off-by: Afzal Mohammed <afzal.mohd.ma@gmail.com>
Reviewed-by: Vladimir Murzin <vladimir.murzin@arm.com>
[ Upstream commit ca244a83ecc7f0a9242ee2116e622cb6d7ec2a90 ]
On chiliSOM TPS65217 nWAKEUP pin is connected to AM335x internal RTC
EXT_WAKEUP input. In RTC-only state TPS65217 is notifying about power on
events (such as power buton presses) by setting nWAKEUP output
low. After that it waits 5s for proper device boot. Currently it doesn't
happen, as the processor doesn't listen for such events. Consequently
TPS65217 changes state from SLEEP (RTC-only state) to OFF.
Enable EXT_WAKEUP input of AM335x's RTC, so the processor can properly
detect power on events and recover immediately from RTC-only states,
without powering off RTC and losing time.
Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
[ Upstream commit 08d90c81b714482dceb5323d14f6617bcf55ee61 ]
ralink_soc sould be assigned to RT3883_SOC, replace incorrect
comparision with assignment.
Fixes: 418d29c87061 ("MIPS: ralink: Unify SoC id handling")
Patchwork: https://patchwork.linux-mips.org/patch/14903/
[ Upstream commit 58181a117d353427127a2e7afc7cf1ab44759828 ]
There is a typo inside the pinmux setup code. The function is really
called utif and not util. This was recently discovered when people were
trying to make the UTIF interface work.
Signed-off-by: John Crispin <john@phrozen.org>
Patchwork: https://patchwork.linux-mips.org/patch/14899/
[ Upstream commit 3f00f4d8f083bc61005d0a1ef592b149f5c88bbd ]
When clearing the .bss section in kernel_entry we do so using LONG_S
instructions, and branch whilst the current write address doesn't equal
the end of the .bss section minus the size of a long integer. The .bss
section always begins at a long-aligned address and we always increment
the write pointer by the size of a long integer - we therefore rely upon
the .bss section ending at a long-aligned address. If this is not the
case then the long-aligned write address can never be equal to the
non-long-aligned end address & we will continue to increment past the
end of the .bss section, attempting to zero the rest of memory.
Despite this requirement that .bss end at a long-aligned address we pass
0 as the end alignment requirement to the BSS_SECTION macro and thus
don't guarantee any particular alignment, allowing us to hit the error
condition described above.
Fix this by instead passing 8 bytes as the end alignment argument to
the BSS_SECTION macro, ensuring that the end of the .bss section is
always at least long-aligned.
Patchwork: https://patchwork.linux-mips.org/patch/14526/
[ Upstream commit 654450baf2afba86cf328e1849ccac61ec4630af ]
Use recently added R-Car Gen 2 fallback binding for msiof nodes in
DT for r8a7790 SoC.
This has no run-time effect for the current driver as the initialisation
sequence is the same for the SoC-specific binding for r8a7790 and the
fallback binding for R-Car Gen 2.
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
[ Upstream commit 80b7a2e2498bcffb1a79980dfbeb7a1275577b28 ]
Add CPU operating points for Exynos4412 Prime (it supports
additional 1704MHz & 1600MHz OPPs and 1500MHz OPP is just
a regular non-turbo OPP on this SoC). Also update relevant
cooling maps to account for new OPPs.
ODROID-X2/U2/U3 boards use Exynos4412 Prime SoC version so
update their board files accordingly.
Based on Hardkernel's kernel for ODROID-X2/U2/U3 boards.
Cc: Doug Anderson <dianders@chromium.org>
Cc: Andreas Faerber <afaerber@suse.de>
Cc: Thomas Abraham <thomas.ab@samsung.com>
Cc: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
Cc: Ben Gamari <ben@smart-cactus.org>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
commit 7e91c7df29b5e196de3dc6f086c8937973bd0b88 upstream.
This function creates userspace mapping for the DMA-coherent memory.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by: Oleksandr Dmytryshyn <oleksandr.dmytryshyn@globallogic.com>
Signed-off-by: Andrii Anisov <andrii_anisov@epam.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
commit c0a1666bcb2a33e84187a15eabdcd54056be9a97 upstream.
This fixes a compilation failure on 32-bit systems.
commit 5753743fa5108b8f98bd61e40dc63f641b26c768 upstream.
WARN_ON_ONCE(pi_test_sn(&vmx->pi_desc)) in kvm_vcpu_trigger_posted_interrupt()
intends to detect the violation of invariant that VT-d PI notification
event is not suppressed when vcpu is in the guest mode. Because the
two checks for the target vcpu mode and the target suppress field
cannot be performed atomically, the target vcpu mode may change in
between. If that does happen, WARN_ON_ONCE() here may raise false
alarms.
As the previous patch fixed the real invariant breaker, remove this
WARN_ON_ONCE() to avoid false alarms, and document the allowed cases
instead.
Reported-by: "Ramamurthy, Venkatesh" <venkatesh.ramamurthy@intel.com>
Reported-by: Dan Williams <dan.j.williams@intel.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Fixes: 28b835d60fcc ("KVM: Update Posted-Interrupts Descriptor when vCPU is preempted")
commit dc91f2eb1a4021eb6705c15e474942f84ab9b211 upstream.
In kvm_vcpu_trigger_posted_interrupt() and pi_pre_block(), KVM
assumes that PI notification events should not be suppressed when the
target vCPU is not blocked.
vmx_update_pi_irte() sets the SN field before changing an interrupt
from posting to remapping, but it does not check the vCPU mode.
Therefore, the change of SN field may break above the assumption.
Besides, I don't see reasons to suppress notification events here, so
remove the changes of SN field to avoid race condition.
commit 814fb7bb7db5433757d76f4c4502c96fc53b0b5e upstream.
On x86, userspace can use the ptrace() or rt_sigreturn() system calls to
set a task's extended state (xstate) or "FPU" registers. ptrace() can
set them for another task using the PTRACE_SETREGSET request with
NT_X86_XSTATE, while rt_sigreturn() can set them for the current task.
In either case, registers can be set to any value, but the kernel
assumes that the XSAVE area itself remains valid in the sense that the
CPU can restore it.
However, in the case where the kernel is using the uncompacted xstate
format (which it does whenever the XSAVES instruction is unavailable),
it was possible for userspace to set the xcomp_bv field in the
xstate_header to an arbitrary value. However, all bits in that field
are reserved in the uncompacted case, so when switching to a task with
nonzero xcomp_bv, the XRSTOR instruction failed with a #GP fault. This
caused the WARN_ON_FPU(err) in copy_kernel_to_xregs() to be hit. In
addition, since the error is otherwise ignored, the FPU registers from
the task previously executing on the CPU were leaked.
Fix the bug by checking that the user-supplied value of xcomp_bv is 0 in
the uncompacted case, and returning an error otherwise.
The reason for validating xcomp_bv rather than simply overwriting it
with 0 is that we want userspace to see an error if it (incorrectly)
provides an XSAVE area in compacted format rather than in uncompacted
format.
Note that as before, in case of error we clear the task's FPU state.
This is perhaps non-ideal, especially for PTRACE_SETREGSET; it might be
better to return an error before changing anything. But it seems the
"clear on error" behavior is fine for now, and it's a little tricky to
do otherwise because it would mean we couldn't simply copy the full
userspace state into kernel memory in one __copy_from_user().
This bug was found by syzkaller, which hit the above-mentioned
WARN_ON_FPU():
WARNING: CPU: 1 PID: 0 at ./arch/x86/include/asm/fpu/internal.h:373 __switch_to+0x5b5/0x5d0
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.13.0 #453
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff9ba2bc8e42c0 task.stack: ffffa78cc036c000
RIP: 0010:__switch_to+0x5b5/0x5d0
RSP: 0000:ffffa78cc08bbb88 EFLAGS: 00010082
RAX: 00000000fffffffe RBX: ffff9ba2b8bf2180 RCX: 00000000c0000100
RDX: 00000000ffffffff RSI: 000000005cb10700 RDI: ffff9ba2b8bf36c0
RBP: ffffa78cc08bbbd0 R08: 00000000929fdf46 R09: 0000000000000001
R10: 0000000000000000 R11: 0000000000000000 R12: ffff9ba2bc8e42c0
R13: 0000000000000000 R14: ffff9ba2b8bf3680 R15: ffff9ba2bf5d7b40
FS: 00007f7e5cb10700(0000) GS:ffff9ba2bf400000(0000) knlGS:0000000000000000
CR2: 00000000004005cc CR3: 0000000079fd5000 CR4: 00000000001406e0
Call Trace:
Code: 84 00 00 00 00 00 e9 11 fd ff ff 0f ff 66 0f 1f 84 00 00 00 00 00 e9 e7 fa ff ff 0f ff 66 0f 1f 84 00 00 00 00 00 e9 c2 fa ff ff <0f> ff 66 0f 1f 84 00 00 00 00 00 e9 d4 fc ff ff 66 66 2e 0f 1f
Here is a C reproducer. The expected behavior is that the program spin
forever with no output. However, on a buggy kernel running on a
processor with the "xsave" feature but without the "xsaves" feature
(e.g. Sandy Bridge through Broadwell for Intel), within a second or two
the program reports that the xmm registers were corrupted, i.e. were not
restored correctly. With CONFIG_X86_DEBUG_FPU=y it also hits the above
kernel warning.
#define _GNU_SOURCE
#include <stdbool.h>
#include <inttypes.h>
#include <linux/elf.h>
#include <stdio.h>
#include <sys/ptrace.h>
#include <sys/uio.h>
#include <sys/wait.h>
#include <unistd.h>
int main(void)
int pid = fork();
uint64_t xstate[512];
struct iovec iov = { .iov_base = xstate, .iov_len = sizeof(xstate) };
if (pid == 0) {
bool tracee = true;
for (int i = 0; i < sysconf(_SC_NPROCESSORS_ONLN) && tracee; i++)
tracee = (fork() != 0);
uint32_t xmm0[4] = { [0 ... 3] = tracee ? 0x00000000 : 0xDEADBEEF };
asm volatile(" movdqu %0, %%xmm0\n"
" mov %0, %%rbx\n"
"1: movdqu %%xmm0, %0\n"
" mov %0, %%rax\n"
" cmp %%rax, %%rbx\n"
" je 1b\n"
: "+m" (xmm0) : : "rax", "rbx", "xmm0");
printf("BUG: xmm registers corrupted! tracee=%d, xmm0=%08X%08X%08X%08X\n",
tracee, xmm0[0], xmm0[1], xmm0[2], xmm0[3]);
} else {
usleep(100000);
ptrace(PTRACE_ATTACH, pid, 0, 0);
wait(NULL);
ptrace(PTRACE_GETREGSET, pid, NT_X86_XSTATE, &iov);
xstate[65] = -1;
ptrace(PTRACE_SETREGSET, pid, NT_X86_XSTATE, &iov);
ptrace(PTRACE_CONT, pid, 0, 0);
wait(NULL);
return 1;
Note: the program only tests for the bug using the ptrace() system call.
The bug can also be reproduced using the rt_sigreturn() system call, but
only when called from a 32-bit program, since for 64-bit programs the
kernel restores the FPU state from the signal frame by doing XRSTOR
directly from userspace memory (with proper error checking).
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Eric Biggers <ebiggers3@gmail.com>
Cc: Kevin Hao <haokexin@gmail.com>
Cc: Michael Halcrow <mhalcrow@google.com>
Cc: Wanpeng Li <wanpeng.li@hotmail.com>
Cc: Yu-cheng Yu <yu-cheng.yu@intel.com>
Cc: kernel-hardening@lists.openwall.com
Fixes: 0b29643a5843 ("x86/xsaves: Change compacted format xsave area header")
Link: http://lkml.kernel.org/r/20170922174156.16780-2-ebiggers3@gmail.com
Link: http://lkml.kernel.org/r/20170923130016.21448-25-mingo@kernel.org
commit a3c4fb7c9c2ebfd50b8c60f6c069932bb319bc37 upstream.
commit 7b2d0dbac489 ("x86/mm/pkeys: Pass VMA down in to fault signal
generation code") passes down a vma pointer to the error path, but that is
done once the mmap_sem is released when calling mm_fault_error() from
__do_page_fault().
This is dangerous as the vma structure is no more safe to be used once the
mmap_sem has been released. As only the protection key value is required in
the error processing, we could just pass down this value.
Fix it by passing a pointer to a protection key value down to the fault
signal generation code. The use of a pointer allows to keep the check
generating a warning message in fill_sig_info_pkey() when the vma was not
known. If the pointer is valid, the protection value can be accessed by
deferencing the pointer.
[ tglx: Made *pkey u32 as that's the type which is passed in siginfo ]
Fixes: 7b2d0dbac489 ("x86/mm/pkeys: Pass VMA down in to fault signal generation code")
Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/1504513935-12742-1-git-send-email-ldufour@linux.vnet.ibm.com
commit 51aa68e7d57e3217192d88ce90fd5b8ef29ec94f upstream.
If L1 does not specify the "use TPR shadow" VM-execution control in
vmcs12, then L0 must specify the "CR8-load exiting" and "CR8-store
exiting" VM-execution controls in vmcs02. Failure to do so will give
the L2 VM unrestricted read/write access to the hardware CR8.
This fixes CVE-2017-12154.
Signed-off-by: Jim Mattson <jmattson@google.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
commit 3a8b0677fc6180a467e26cc32ce6b0c09a32f9bb upstream.
The value of the guest_irq argument to vmx_update_pi_irte() is
ultimately coming from a KVM_IRQFD API call. Do not BUG() in
vmx_update_pi_irte() if the value is out-of bounds. (Especially,
since KVM as a whole seems to hang after that.)
Instead, print a message only once if we find that we don't have a
route for a certain IRQ (which can be out-of-bounds or within the
array).
This fixes CVE-2017-1000252.
Fixes: efc644048ecde54 ("KVM: x86: Update IRTE for posted-interrupts")
Signed-off-by: Jan H. Schönherr <jschoenh@amazon.de>
commit b862789aa5186d5ea3a024b7cfe0f80c3a38b980 upstream.
Sasha Levin reported a WARNING:
| WARNING: CPU: 0 PID: 6974 at kernel/rcu/tree_plugin.h:329
| rcu_preempt_note_context_switch kernel/rcu/tree_plugin.h:329 [inline]
| rcu_note_context_switch+0x16c/0x2210 kernel/rcu/tree.c:458
| CPU: 0 PID: 6974 Comm: syz-fuzzer Not tainted 4.13.0-next-20170908+ #246
| 1.10.1-1ubuntu1 04/01/2014
| Call Trace:
| RIP: 0010:rcu_preempt_note_context_switch kernel/rcu/tree_plugin.h:329 [inline]
| RIP: 0010:rcu_note_context_switch+0x16c/0x2210 kernel/rcu/tree.c:458
| RSP: 0018:ffff88003b2debc8 EFLAGS: 00010002
| RAX: 0000000000000001 RBX: 1ffff1000765bd85 RCX: 0000000000000000
| RDX: 1ffff100075d7882 RSI: ffffffffb5c7da20 RDI: ffff88003aebc410
| RBP: ffff88003b2def30 R08: dffffc0000000000 R09: 0000000000000001
| R10: 0000000000000000 R11: 0000000000000000 R12: ffff88003b2def08
| R13: 0000000000000000 R14: ffff88003aebc040 R15: ffff88003aebc040
| __schedule+0x201/0x2240 kernel/sched/core.c:3292
| schedule+0x113/0x460 kernel/sched/core.c:3421
| kvm_async_pf_task_wait+0x43f/0x940 arch/x86/kernel/kvm.c:158
| do_async_page_fault+0x72/0x90 arch/x86/kernel/kvm.c:271
| async_page_fault+0x22/0x30 arch/x86/entry/entry_64.S:1069
| RIP: 0010:format_decode+0x240/0x830 lib/vsprintf.c:1996
| RSP: 0018:ffff88003b2df520 EFLAGS: 00010283
| RAX: 000000000000003f RBX: ffffffffb5d1e141 RCX: ffff88003b2df670
| RDX: 0000000000000001 RSI: dffffc0000000000 RDI: ffffffffb5d1e140
| RBP: ffff88003b2df560 R08: dffffc0000000000 R09: 0000000000000000
| R10: ffff88003b2df718 R11: 0000000000000000 R12: ffff88003b2df5d8
| R13: 0000000000000064 R14: ffffffffb5d1e140 R15: 0000000000000000
| vsnprintf+0x173/0x1700 lib/vsprintf.c:2136
| sprintf+0xbe/0xf0 lib/vsprintf.c:2386
| proc_self_get_link+0xfb/0x1c0 fs/proc/self.c:23
| get_link fs/namei.c:1047 [inline]
| link_path_walk+0x1041/0x1490 fs/namei.c:2127
This happened when the host hit a page fault, and delivered it as in an
async page fault, while the guest was in an RCU read-side critical
section. The guest then tries to reschedule in kvm_async_pf_task_wait(),
but rcu_preempt_note_context_switch() would treat the reschedule as a
sleep in RCU read-side critical section, which is not allowed (even in
preemptible RCU). Thus the WARN.
To cure this, make kvm_async_pf_task_wait() go to the halt path if the
PF happens in a RCU read-side critical section.
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Signed-off-by: Boqun Feng <boqun.feng@gmail.com>
commit 31afb2ea2b10a7d17ce3db4cdb0a12b63b2fe08a upstream.
The simplify part: do not touch pi_desc.nv, we can set it when the
VCPU is first created. Likewise, pi_desc.sn is only handled by
vmx_vcpu_pi_load, do not touch it in __pi_post_block.
The fix part: do not check kvm_arch_has_assigned_device, instead
check the SN bit to figure out whether vmx_vcpu_pi_put ran before.
This matches what the previous patch did in pi_post_block.
Cc: Huangweidong <weidong.huang@huawei.com>
Cc: Gonglei <arei.gonglei@huawei.com>
Cc: wangxin <wangxinxin.wang@huawei.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Tested-by: Longpeng (Mike) <longpeng2@huawei.com>
commit 8b306e2f3c41939ea528e6174c88cfbfff893ce1 upstream.
In some cases, for example involving hot-unplug of assigned
devices, pi_post_block can forget to remove the vCPU from the
blocked_vcpu_list. When this happens, the next call to
pi_pre_block corrupts the list.
Fix this in two ways. First, check vcpu->pre_pcpu in pi_pre_block
and WARN instead of adding the element twice in the list. Second,
always do the list removal in pi_post_block if vcpu->pre_pcpu is
set (not -1).
The new code keeps interrupts disabled for the whole duration of
pi_pre_block/pi_post_block. This is not strictly necessary, but
easier to follow. For the same reason, PI.ON is checked only
after the cmpxchg, and to handle it we just call the post-block
code. This removes duplication of the list removal code.
commit cd39e1176d320157831ce030b4c869bd2d5eb142 upstream.
Simple code movement patch, preparing for the next one.
commit 760bfb47c36a07741a089bf6a28e854ffbee7dc9 upstream.
We currently route pte translation faults via do_page_fault, which elides
the address check against TASK_SIZE before invoking the mm fault handling
code. However, this can cause issues with the path walking code in
conjunction with our word-at-a-time implementation because
load_unaligned_zeropad can end up faulting in kernel space if it reads
across a page boundary and runs into a page fault (e.g. by attempting to
read from a guard region).
In the case of such a fault, load_unaligned_zeropad has registered a
fixup to shift the valid data and pad with zeroes, however the abort is
reported as a level 3 translation fault and we dispatch it straight to
do_page_fault, despite it being a kernel address. This results in calling
a sleeping function from atomic context:
BUG: sleeping function called from invalid context at arch/arm64/mm/fault.c:313
in_atomic(): 0, irqs_disabled(): 0, pid: 10290
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[<ffffff8e016cd0cc>] ___might_sleep+0x134/0x144
[<ffffff8e016cd158>] __might_sleep+0x7c/0x8c
[<ffffff8e016977f0>] do_page_fault+0x140/0x330
[<ffffff8e01681328>] do_mem_abort+0x54/0xb0
Exception stack(0xfffffffb20247a70 to 0xfffffffb20247ba0)
[<ffffff8e016844fc>] el1_da+0x18/0x78
[<ffffff8e017f399c>] path_parentat+0x44/0x88
[<ffffff8e017f4c9c>] filename_parentat+0x5c/0xd8
[<ffffff8e017f5044>] filename_create+0x4c/0x128
[<ffffff8e017f59e4>] SyS_mkdirat+0x50/0xc8
[<ffffff8e01684e30>] el0_svc_naked+0x24/0x28
Code: 36380080 d5384100 f9400800 9402566d (d4210000)
---[ end trace 2d01889f2bca9b9f ]---
Fix this by dispatching all translation faults to do_translation_faults,
which avoids invoking the page fault logic for faults on kernel addresses.
Reported-by: Ankit Jain <ankijain@codeaurora.org>
commit 5371513fb338fb9989c569dc071326d369d6ade8 upstream.
When the kernel is entered at EL2 on an ARMv8.0 system, we construct
the EL1 pstate and make sure this uses the the EL1 stack pointer
(we perform an exception return to EL1h).
But if the kernel is either entered at EL1 or stays at EL2 (because
we're on a VHE-capable system), we fail to set SPsel, and use whatever
stack selection the higher exception level has choosen for us.
Let's not take any chance, and make sure that SPsel is set to one
before we decide the mode we're going to run in.
Acked-by: Mark Rutland <mark.rutland@arm.com>
commit ba385c0594e723d41790ecfb12c610e6f90c7785 upstream.
The check for the _SEGMENT_ENTRY_PROTECT bit in gup_huge_pmd() is the
wrong way around. It must not be set for write==1, and not be checked for
write==0. Fix this similar to how it was fixed for ptes long time ago in
commit 25591b070336 ("[S390] fix get_user_pages_fast").
One impact of this bug would be unnecessarily using the gup slow path for
write==0 on r/w mappings. A potentially more severe impact would be that
gup_huge_pmd() will succeed for write==1 on r/o mappings.
commit a4979a7e71eb8da976cbe4a0a1fa50636e76b04f upstream.
For DYNAMIC_FTRACE_WITH_REGS, we should be passing-in the original set
of registers in pt_regs, to capture the state _before_ ftrace_caller.
However, we are instead passing the stack pointer *after* allocating a
stack frame in ftrace_caller. Fix this by saving the proper value of r1
in pt_regs. Also, use SAVE_10GPRS() to simplify the code.
Fixes: 153086644fd1 ("powerpc/ftrace: Add support for -mprofile-kernel ftrace ABI")
Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
commit c1fa0768a8713b135848f78fd43ffc208d8ded70 upstream.
Commit cd63f3c ("powerpc/tm: Fix saving of TM SPRs in core dump")
added code to access TM SPRs in flush_tmregs_to_thread(). However
flush_tmregs_to_thread() does not check if TM feature is available on
CPU before trying to access TM SPRs in order to copy live state to
thread structures. flush_tmregs_to_thread() is indeed guarded by
CONFIG_PPC_TRANSACTIONAL_MEM but it might be the case that kernel
was compiled with CONFIG_PPC_TRANSACTIONAL_MEM enabled and ran on
a CPU without TM feature available, thus rendering the execution
of TM instructions that are treated by the CPU as illegal instructions.
The fix is just to add proper checking in flush_tmregs_to_thread()
if CPU has the TM feature before accessing any TM-specific resource,
returning immediately if TM is no available on the CPU. Adding
that checking in flush_tmregs_to_thread() instead of in places
where it is called, like in vsr_get() and vsr_set(), is better because
avoids the same problem cropping up elsewhere.
Fixes: cd63f3c ("powerpc/tm: Fix saving of TM SPRs in core dump")
Reviewed-by: Cyril Bur <cyrilbur@gmail.com>
commit b537ca6fede69a281dc524983e5e633d79a10a08 upstream.
A reference to the parent device node is held by add_dt_node() for the
node to be added. If the call to dlpar_configure_connector() fails
add_dt_node() returns ENOENT and that reference is not freed.
Add a call to of_node_put(parent_dn) prior to bailing out after a
failed dlpar_configure_connector() call.
Fixes: 8d5ff320766f ("powerpc/pseries: Make dlpar_configure_connector parent node aware")
Signed-off-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
commit edd03602d97236e8fea13cd76886c576186aa307 upstream.
Al Viro pointed out that while one thread of a process is executing
in kvm_vm_ioctl_create_spapr_tce(), another thread could guess the
file descriptor returned by anon_inode_getfd() and close() it before
the first thread has added it to the kvm->arch.spapr_tce_tables list.
That highlights a more general problem: there is no mutual exclusion
between writers to the spapr_tce_tables list, leading to the
possibility of the list becoming corrupted, which could cause a
host kernel crash.
To fix the mutual exclusion problem, we add a mutex_lock/unlock
pair around the list_del_rce in kvm_spapr_tce_release().
If another thread does guess the file descriptor returned by the
anon_inode_getfd() call in kvm_vm_ioctl_create_spapr_tce() and closes
it, its call to kvm_spapr_tce_release() will not do any harm because
it will have to wait until the first thread has released kvm->lock.
The other things that the second thread could do with the guessed
file descriptor are to mmap it or to pass it as a parameter to a
KVM_DEV_VFIO_GROUP_SET_SPAPR_TCE ioctl on a KVM device fd. An mmap
call won't cause any harm because kvm_spapr_tce_mmap() and
kvm_spapr_tce_fault() don't access the spapr_tce_tables list or
the kvmppc_spapr_tce_table.list field, and the fields that they do use
have been properly initialized by the time of the anon_inode_getfd()
call.
The KVM_DEV_VFIO_GROUP_SET_SPAPR_TCE ioctl calls
kvm_spapr_tce_attach_iommu_group(), which scans the spapr_tce_tables
list looking for the kvmppc_spapr_tce_table struct corresponding to
the fd given as the parameter. Either it will find the new entry
or it won't; if it doesn't, it just returns an error, and if it
does, it will function normally. So, in each case there is no
harmful effect.
[paulus@ozlabs.org - moved parts of the upstream patch into the backport
of 47c5310a8dbe, adjusted this commit message accordingly.]
Fixes: 366baf28ee3f ("KVM: PPC: Use RCU for arch.spapr_tce_tables")
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Signed-off-by: Paul Mackerras <paulus@ozlabs.org>
commit 47c5310a8dbe7c2cb9f0083daa43ceed76c257fa upstream, with part
of commit edd03602d97236e8fea13cd76886c576186aa307 folded in.
Nixiaoming pointed out that there is a memory leak in
kvm_vm_ioctl_create_spapr_tce() if the call to anon_inode_getfd()
fails; the memory allocated for the kvmppc_spapr_tce_table struct
is not freed, and nor are the pages allocated for the iommu
tables. In addition, we have already incremented the process's
count of locked memory pages, and this doesn't get restored on
error.
David Hildenbrand pointed out that there is a race in that the
function checks early on that there is not already an entry in the
stt->iommu_tables list with the same LIOBN, but an entry with the
same LIOBN could get added between then and when the new entry is
added to the list.
This fixes all three problems. To simplify things, we now call
anon_inode_getfd() before placing the new entry in the list. The
check for an existing entry is done while holding the kvm->lock
mutex, immediately before adding the new entry to the list.
Finally, on failure we now call kvmppc_account_memlimit to
decrement the process's count of locked memory pages.
[paulus@ozlabs.org - folded in that part of edd03602d972 ("KVM:
PPC: Book3S HV: Protect updates to spapr_tce_tables list", 2017-08-28)
which restructured the code that 47c5310a8dbe modified, to avoid
a build failure caused by the absence of put_unused_fd().]
Fixes: 54738c097163 ("KVM: PPC: Accelerate H_PUT_TCE by implementing it in real mode")
Fixes: f8626985c7c2 ("KVM: PPC: Account TCE-containing pages in locked_vm")
Reported-by: Nixiaoming <nixiaoming@huawei.com>
Reported-by: David Hildenbrand <david@redhat.com>
