Prepare for snapd integration.
Change SPI2 clock parent to clk_m being 12 MHz which is anyway the
maximum frequency the K20 micro controller's SPI peripheral can be run.
This further allows for the EzPort to be run at exactly 2 MHz which is
the maximum allowed as well.
(cherry picked from commit 15e73283a975a1b899d7f6807aa882ef885573dd)
This patch includes CAN driver and improvements in SPI communications
for Apalis TK1 k20 based MFD.
Requires firmware version 0.9.
Due to problems with LP0 sleep, make LP1 the default option.
Use modedb to set mode on Apalis TK1 frame buffer/display
controller.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Allow to specify framebuffer videomode using kernel command line
parameters. NVIDIAs binary X driver later on picks up those settings
and start X with current mode settings, if no EDID data are available.
Reused some of the implementation from Stefan's work for modedb
support[1] on Tegra20/30
[1] http://git.toradex.com/cgit/linux-toradex.git/commit/?h=tegra-next&id=1d3625dd9903bcc59e2df56836565ebb682948c1
Instead of providing revision, SKU and PID information
via soc_id pass SoC's unique ID.
Signed-off-by: Wojciech Bieganski <wbieganski@antmicro.com>
Configure GPIO connected to i210 wake-up pin
as a wake-up source in the device tree.
Fix suspend and resume for LP1 sleep.
On Apalis TK1 boards K20 MCU is used
for CAN, GPIO, ADC and touch screen.
This patch includes support for core MFD device, GPIO, ADC
and touch screen.
Integrate support for the carrier board level I2C RTC.
Now with the working card detect pin in place on the latest V1.1 HW
polling is no longer required. Therefore make it an optional define for
V1.0 samples.
Add sd card detect SD1_CD# applicable for V1.1 modules using GPIO_PV2.
Configure Apalis MMC1 D6 GPIO on SDMMC3_CLK_LB_IN as reserved function
without any pull-up/down.
Configure GPIO_PV2 as SD1_CD# according to latest V1.1 HW.
Leave SDMMC3_CLK_LB_OUT muxed as SDMMC3 with output driver enabled aka
not tristated and input driver enabled as well as it features some
magic properties even though the external loopback is disabled and the
internal loopback used as per SDMMC_VENDOR_MISC_CNTRL_0 register's
SDMMC_SPARE1 bits being set to 0xfffd according to the TRM! This pin is
now a not-connect on V1.1 HW in order to avoid any interference.
Pull-up GPIO_PI6 connected to TMP451's ALERT#/THERM2#.
While at it improve some comments.
Fix PCIe clock and reset not conforming to specification by moving PCIe
reset handling including the PLX PEX 8605 errata 5 workaround from the
board platform data into the right places timing wise in the PCIe driver
itself.
Also add a kernel command line argument to allow using the Apalis GPIO7
as a regular GPIO rather than for above mentioned PLX PEX 8605
workaround:
pex_perst=0
(cherry picked from tegra-next commit
a2f63805703b43d55d91ae17f10d0049bf0f625e)
SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
Integrate SoC camera support for the following CSI-2 codecs/sensors:
- Analog Devices ADV7280-M, analog camera decoder with deinterlacer,
PAL/NTSC@60fps
- ON Semiconductor (formerly Aptina) AP1302 ISP + AR1820 image sensor,
13Mpx, 1080p@30fps
- OmniVision OV5640, 5Mpx sensor, 1080p@30fps
- Toshiba TC358743 HDMI to CSI-2 bridge, 1080p@60fps
Connected to CSI CIL-E. Cameras doesn't work simultaneously.
A major part of the driver has been rewritten in order to avoid
writing binary blobs to the chip.
This version also adds support for more video modes.
Input video modes supported:
- 1920x1080 @ 60
- 1280x1024 @ 75
- 1280x720 @ 60
- 1024x768 @ 75
- 800x600 @ 75
- 640x480 @ 75
known issues:
- decoder outputs PAL (720x576), but the image
looks fine only when streamed in 640x576 mode,
- vertical synchronisation glitches,
- setting queue-size in gstreamer greater than 1
results in blinking image,
- every start of streaming requires reloading of
the modules
known issues:
- HDMI input works only in 640x480 mode, 720p only in
test pattern mode, any 4-lane mode doesn't work
- set HDMI transmitter to VGA mode before
starting the stream
known issues:
- works only in 1080p mode,
the modules
Re-add SoC camera platform data from Ardbeg/Jetson TK1 board files.
Integrate optional eDP support (e.g. uncomment define of APALIS_TK1_EDP
as found in the platform data header file.
Tested using a prototype Apalis TK1 mezzanine connecting to a Samsung
LTN156FL02-L01 panel featuring a 4K aka UHD resolution of 3840 by 2160.
Select dp pinmux function for Apalis GPIO2 aka DP_HPD to allow it to be used as
eDP hot-plug detect. From user space customer may still configure and use it as
a regular GPIO if desired.
Remove default GPIO functionality from Apalis GPIO1 aka GPIO_PFF2 and Apalis
GPIO2 aka DP_HPD as if later trying to use resp. pins as special function (e.g.
the former for eDP hot-plug detect and the later for SATA data activity) there
is currently no sane way of removing the GPIO functionality again.
Uncomment UART4 device tree node and enable support in machfile
arch/arm/mach-tegra/board-ardbeg.c: In function 'ardbeg_touch_init':
arch/arm/mach-tegra/board-ardbeg.c:1159:6: error: this 'else' clause
does not guard... [-Werror=misleading-indentation]
} else
arch/arm/mach-tegra/board-ardbeg.c:1161:5: note: ...this statement, but
the latter is misleadingly indented as if it is guarded by the 'else'
rm31080a_ardbeg_spi_board[0].irq =
arch/arm/mach-tegra/board-ardbeg.c: In function 'tegra_ardbeg_late_init':
arch/arm/mach-tegra/board-ardbeg.c:1470:2: error: this 'else' clause
else
arch/arm/mach-tegra/board-ardbeg.c:1474:3: note: ...this statement, but
tegra_io_dpd_enable(&pexbias_io);
At top level:
arch/arm/mach-tegra/board-ardbeg.c:1608:27: error:
'loki_dt_board_compat' defined but not used
[-Werror=unused-const-variable=]
static const char * const loki_dt_board_compat[] = {
Optimized DVFS table for Apalis TK1 boards.
This patch adds support for the Toradex Apalis TK1 acomputer on module
which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L
RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor
chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec.
Furthermore, there is a Kinetis MK20DN512 companion micro controller for
analogue, CAN and resistive touch functionality which is not yet
supported.
This is known to boot into either a basic Angstrom/OpenEmbedded/Yocto
or L4T/JetPack Ubuntu based image.
The following things are known to work to a certain extend:
- analogue/digital audio
- debug UART1
- DVFS power management incl. low power core migration
- eMMC
- gigabit Ethernet
- GPIOs
- HDMI (incl. HDA audio)
- I2C
- LVDS
- PCIe
- SATA
- SD/MMC cards
- temperature sensor
- USB host ports
The rest is untested.
Fix the backlight PWM instance used and add 800x600 and 1024x600 LVDS
panel timings.
This fixes the following GCC 5.2 built time error:
arch/arm/mach-tegra/tegra_cl_dvfs.c: In function 'monitor_get':
arch/arm/mach-tegra/tegra_cl_dvfs.c:372:8: error: 'v' may be used uninitialized in this function [-Werror=maybe-uninitialized]
*data &= CL_DVFS_MONITOR_DATA_MASK;
arch/arm/mach-tegra/tegra_cl_dvfs.c:2949:6: note: 'v' was declared here
u32 v, s;
arch/arm/mach-tegra/tegra_cl_dvfs.c: In function 'cl_dvfs_calibrate':
arch/arm/mach-tegra/tegra_cl_dvfs.c:372:8: error: 'data' may be used uninitialized in this function [-Werror=maybe-uninitialized]
arch/arm/mach-tegra/tegra_cl_dvfs.c:902:11: note: 'data' was declared here
u32 val, data;
newer compilers throw the following error:
arch/arm/mach-tegra/tegra12_clocks.c: In function 'tegra12_cpu_clk_init':
arch/arm/mach-tegra/tegra12_clocks.c:1334:31: error: logical not is only applied to the left hand side of comparison [-Werror=logical-not-parentheses]
c->state = (!is_lp_cluster() == (c->u.cpu.mode == MODE_G))? ON : OFF;
While working on the 32-bit ARM port of UEFI, I noticed a strange
corruption in the kernel log. The following snprintf() statement
(in drivers/firmware/efi/efi.c:efi_md_typeattr_format())
snprintf(pos, size, "|%3s|%2s|%2s|%2s|%3s|%2s|%2s|%2s|%2s]",
was producing the following output in the log:
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
|RUN| | | | |WB|WT|WC|UC]*
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
|RUN| | | | | | | |UC]
As it turns out, this is caused by incorrect code being emitted for
the string() function in lib/vsprintf.c. The following code
if (!(spec.flags & LEFT)) {
while (len < spec.field_width--) {
if (buf < end)
*buf = ' ';
++buf;
for (i = 0; i < len; ++i) {
if (buf < end)
*buf = *s;
++buf; ++s;
if (buf < end)
*buf = ' ';
++buf;
when called with len == 0, triggers an issue in the GCC SRA optimization
pass (Scalar Replacement of Aggregates), which handles promotion of signed
struct members incorrectly. This is a known but as yet unresolved issue.
(https://gcc.gnu.org/bugzilla/show_bug.cgi?id=65932). In this particular
case, it is causing the second while loop to be executed erroneously a
single time, causing the additional space characters to be printed.
So disable the optimization by passing -fno-ipa-sra.
Cc: <stable@vger.kernel.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
(cherry picked from commit a077224fd35b2f7fbc93f14cf67074fc792fbac2)
With compilers which follow the C99 standard (like modern versions of gcc and
clang), "extern inline" does the wrong thing (emits code for an externally
linkable version of the inline function). In this case using static inline
and removing the NULL version of return_address in return_address.c does
the right thing.
Signed-off-by: Behan Webster <behanw@converseincode.com>
Reviewed-by: Mark Charlebois <charlebm@gmail.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
(cherry picked from commit aeea3592a13bf12861943e44fc48f1f270941f8d)
Following support added
DVFS for Gauranteed freq considering aging
CPU freq limit at higher temperature
EDP max current limits for each SKU
Bug 200195229
Change-Id: If00f3fd6b891cf366047dda331bd7ab1c15b40f7
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/1146577
GVS: Gerrit_Virtual_Submit
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
select emc evfs table based on DDR present
using RAMCODE
Bug 200195279
Change-Id: I7fbc693383c9e231b2c2119020eebc7bba544c6e
Reviewed-on: http://git-master/r/1144528
Reviewed-by: Jimmy Zhang <jimmzhang@nvidia.com>
