[ Upstream commit: c07c6053c41f736711ed856aa377007078c7c396 ]
That bit isn't used on this platform.
[ This is a 2.6.25 backport of upstream changeset
28e6103665301ce60634e8a77f0b657c6cc099de with sparc32 build
fixes from Robert Reif ]
So, forever, we've had this ptrace_signal_deliver implementation
which tries to handle all of the nasties that can occur when the
debugger looks at a process about to take a signal. It's meant
to address all of these issues inside of the kernel so that the
debugger need not be mindful of such things.
Problem is, this doesn't work.
The idea was that we should do the syscall restart business first, so
that the debugger captures that state. Otherwise, if the debugger for
example saves the child's state, makes the child execute something
else, then restores the saved state, we won't handle the syscall
restart properly because we lose the "we're in a syscall" state.
The code here worked for most cases, but if the debugger actually
passes the signal through to the child unaltered, it's possible that
we would do a syscall restart when we shouldn't have.
In particular this breaks the case of debugging a process under a gdb
which is being debugged by yet another gdb. gdb uses sigsuspend
to wait for SIGCHLD of the inferior, but if gdb itself is being
debugged by a top-level gdb we get a ptrace_stop(). The top-level gdb
does a PTRACE_CONT with SIGCHLD to let the inferior gdb see the
signal. But ptrace_signal_deliver() assumed the debugger would cancel
out the signal and therefore did a syscall restart, because the return
error was ERESTARTNOHAND.
Fix this by simply making ptrace_signal_deliver() a nop, and providing
a way for the debugger to control system call restarting properly:
1) Report a "in syscall" software bit in regs->{tstate,psr}.
It is set early on in trap entry to a system call and is fully
visible to the debugger via ptrace() and regsets.
2) Test this bit right before doing a syscall restart. We have
to do a final recheck right after get_signal_to_deliver() in
case the debugger cleared the bit during ptrace_stop().
3) Clear the bit in trap return so we don't accidently try to set
that bit in the real register.
As a result we also get a ptrace_{is,clear}_syscall() for sparc32 just
like sparc64 has.
M68K has this same exact bug, and is now the only other user of the
ptrace_signal_deliver hook. It needs to be fixed in the same exact
way as sparc.
Just like mmap, we need to validate address ranges regardless
of MAP_FIXED.
sparc{,64}_mmap_check()'s flag argument is unused, remove.
Based upon a report and preliminary patch by
Jan Lieskovsky <jlieskov@redhat.com>
[ Upstream commit: 986bef854fab44012df678a5b51817d5274d3ca1 ]
Forever we had a PTRACE_SUNOS_DETACH which was unconditionally
recognized, regardless of the personality of the process.
Unfortunately, this value is what ended up in the GLIBC sys/ptrace.h
header file on sparc as PTRACE_DETACH and PT_DETACH.
So continue to recognize this old value. Luckily, it doesn't conflict
with anything we actually care about.
commit b9b39bfba5b0de3418305f01cfa7bc55a16004e1 upstream
x86: use defconfigs from x86/configs/*
Daniel Drake <dsd@gentoo.org> reported:
In 2.6.23, if you unpacked a kernel source tarball and then
ran "make menuconfig" you'd be presented with this message:
# using defaults found in arch/i386/defconfig
and the default options would be set.
The same thing in 2.6.24 does not give you any "using defaults" message, and
the default config options within menuconfig are rather blank (e.g. no PCI
support). You can work around this by explicitly running "make defconfig"
before menuconfig, but it would be nice to have the behaviour the way it was
for 2.6.23 (and the way it still is for other archs).
Fixed by adding a x86 specific defconfig list to Kconfig.
Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=10470
Tested-by: Daniel Drake <dsd@gentoo.org>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
[ Upstream commit: 020cfb05f2c594c778537159bd45ea5efb0c5e0d ]
Second and third arguments were swapped for whatever reason.
Reported by Tom Callaway.
[ Upstream commit: 92aa3573c9cd58fe0bcd1c52c9fd8f5708785917 ]
Kernel bugzilla 10273
As reported by Jos van der Ende, ever since commit
5a606b72a4309a656cd1a19ad137dc5557c4b8ea ("[SPARC64]: Do not ACK an
INO if it is disabled or inprogress.") sun4u interrupts
can get stuck.
What this changset did was add the following conditional to
the various IRQ chip ->enable() handlers on sparc64:
if (unlikely(desc->status & (IRQ_DISABLED|IRQ_INPROGRESS)))
return;
which is correct, however it means that special care is needed
in the ->enable() method.
Specifically we must put the interrupt into IDLE state during
an enable, or else it might never be sent out again.
Setting the INO interrupt state to IDLE resets the state machine,
the interrupt input to the INO is retested by the hardware, and
if an interrupt is being signalled by the device, the INO
moves back into TRANSMIT state, and an interrupt vector is sent
to the cpu.
The two sun4v IRQ chip handlers were already doing this properly,
only sun4u got it wrong.
[ Upstream commit: 86d8337618e69573b5ccd3553f800944e843cae7 ]
It just creates confusion, errors, and bugs.
For one thing, this can cause dup sysfs or procfs nodes to get
created:
[ 1.198015] proc_dir_entry '00.0' already registered
[ 1.198036] Call Trace:
[ 1.198052] [00000000004f2534] create_proc_entry+0x7c/0x98
[ 1.198092] [00000000005719e4] pci_proc_attach_device+0xa4/0xd4
[ 1.198126] [00000000007d991c] pci_proc_init+0x64/0x88
[ 1.198158] [00000000007c62a4] kernel_init+0x190/0x330
[ 1.198183] [0000000000426cf8] kernel_thread+0x38/0x48
[ 1.198210] [00000000006a0d90] rest_init+0x18/0x5c
[ Upstream commit: 1e38c126c9252b612697e34f43b1b3371c8ee31d ]
We clobber %i1 as well as %i0 for these system calls,
because they give two return values.
Therefore, on error, we have to restore %i1 properly
or else the restart explodes since it uses the wrong
arguments.
This fixes glibc's nptl/tst-eintr1.c testcase.
[ Upstream commit: dc5dc7e6d71ca9fd1ea01a1418150af3b2937489 ]
We need to be more liberal about the alignment of the buffer given to
us by sigaltstack(). The user should not need to be mindful of all of
the alignment constraints we have for the stack frame.
This mirrors how we handle this situation in clone() as well.
Also, we align the stack even in non-SA_ONSTACK cases so that signals
due to bad stack alignment can be delivered properly. This makes such
errors easier to debug and recover from.
Finally, add the sanity check x86 has to make sure we won't overflow
the signal stack.
This fixes glibc testcases nptl/tst-cancel20.c and
nptl/tst-cancelx20.c
[ Upstream commit: 5816339310b2d9623cf413d33e538b45e815da5d ]
We should not conditionalize VA range checks on MAP_FIXED.
This is a backport of the noted commit which is in 2.6.26-rc1
now. This is necessary to enable pci=bfsort automatically on a number
of Dell and HP servers, as well as pci=assign-busses for a few other
systems, which was broken between 2.6.22 and 2.6.23.
commit 0df18ff366853cdf31e5238764ec5c63e6b5a398 upstream
x86 PCI: call dmi_check_pciprobe()
this change:
| commit 08f1c192c3c32797068bfe97738babb3295bbf42
| Author: Muli Ben-Yehuda <muli@il.ibm.com>
| Date: Sun Jul 22 00:23:39 2007 +0300
| x86-64: introduce struct pci_sysdata to facilitate sharing of ->sysdata
| This patch introduces struct pci_sysdata to x86 and x86-64, and
| converts the existing two users (NUMA, Calgary) to use it.
| This lays the groundwork for having other users of sysdata, such as
| the PCI domains work.
| The Calgary bits are tested, the NUMA bits just look ok.
replaces pcibios_scan_root with pci_scan_bus_parented...
but in pcibios_scan_root we have a DMI check:
dmi_check_system(pciprobe_dmi_table);
when when have several peer root buses this could be called multiple
times (which is bad), so move that call to pci_access_init().
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Matt Domsch <Matt_Domsch@dell.com>
The ARM kprobes arithmetic immediate instruction decoder
(space_cccc_001x()) was accidentally zero'ing out not only the Rn and
Rd arguments, but the lower nibble of the immediate argument as well
-- this patch fixes this.
Mainline commit: a3fd133c24e16d430ba21f3d9f5c0b8faeeb37fe
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
Acked-by: Nicolas Pitre <nico@marvell.com>
It is more useful to flush the cache with the actual buffer address
rather than the address containing a pointer to the buffer.
Mainline commit: 8f79ff0cb5330a92032c30ff586745d3016b34ca
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Acked-by: Lennert Buytenhek <buytenh@marvell.com>
commit 9d9ad4b51d2b29b5bbeb4011f5e76f7538119cf9 upstream
This bug was introduced in the 2.6.24 lguest merge, where
MSI-X vector allocation will eventually fail. The cause is the new
bit array tracking used vectors is not getting cleared properly on
IRQ destruction on the 32-bit APIC code.
This can be seen easily using the ixgbe 10 GbE driver on multi-core
systems by simply loading and unloading the driver a few times.
Depending on the number of available vectors on the host system, the
MSI-X allocation will eventually fail, and the driver will only be
able to use legacy interrupts.
Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
commit 2444e56b0c08e6f3e3877583841a1213e3263d98 upstream
OSF/1 brk(2) was broken by following one-liner in sys_brk()
(commit 4cc6028d4040f95cdb590a87db478b42b8be0508):
- if (brk < mm->end_code)
+ if (brk < mm->start_brk)
goto out;
The problem is that osf_set_program_attributes()
does update mm->end_code, but not mm->start_brk,
which still contains inappropriate value left from
binary loader, so brk() always fails.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
commit 223ac2f42d49dd0324ca02ea15897ead1a2f5133 upstream.
fix bogus pirq warnings reported in:
http://bugzilla.kernel.org/show_bug.cgi?id=10366
safe to be backported to v2.6.25 and earlier.
Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de>
The header files for the Pb1200/DBAu1200 boards have wrong definition for the
IDE interface's decoded range length -- it should be 512 bytes according to
what the IDE driver does. In addition, the IDE platform device claims 1 byte
too many for its memory resource -- fix the platform code and the IDE driver
in accordance.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
There's a libata based PATA driver for avr32, but no support for
drivers/ide/ on avr32.
This patch fixes the following compile error:
<-- snip -->
CC [M] drivers/ide/ide-cd.o
In file included from /home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/ide/ide-cd.c:37:
/home/bunk/linux/kernel-2.6/git/linux-2.6/include/linux/ide.h:209:21: error: asm/ide.h: No such file or directory
make[3]: *** [drivers/ide/ide-cd.o] Error 1
<-- snip -->
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
http://bugzilla.kernel.org/show_bug.cgi?id=10124
this change:
replaces pcibios_scan_root by pci_scan_bus_parented...
but in pcibios_scan_root we have a check about scanned busses.
Cc: <yakui.zhao@intel.com>
Cc: Stian Jordet <stian@jordet.net>
Cc: Len Brown <lenb@kernel.org>
Cc: Greg KH <greg@kroah.com>
Cc: "Yinghai Lu" <yhlu.kernel@gmail.com>
The signal trampolines were accidently flushing the kernel I$ instead of
the users. Fix that up, and also add a missing user D$ flush while
we're at it.
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
ERROR: "empty_zero_page" [fs/ext4/ext4dev.ko] undefined!
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
arch/sh/kernel/traps_32.c: In function `do_reserved_inst':
arch/sh/kernel/traps_32.c:667: error: implicit declaration of function `do_fpu_inst'
commit 54a015104136974262afa4b8ddd943ea70dec8a2 broke zImage build on sh arch:
LD vmlinux
SYSMAP System.map
SYSMAP .tmp_System.map
AS arch/sh/boot/compressed/head_32.o
In file included from /k/arch/sh/boot/compressed/head_32.S:11:
/k/include/linux/linkage.h:34: error: syntax error in macro parameter list
Fix it for both sh and sh64.
Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net>
This patch fixes some compile errors due to missing save_fpu()
prototypes on sh64 caused by
commit 9bbafce2eec190ef7e44b0eb1095ba17ce6ad3af
(sh: Fix occasional FPU register corruption under preempt).
Signed-off-by: Adrian Bunk <adrian.bunk@movial.fi>
Correctly determine the address of an illegal instruction. The EPCR0 register
holds this value (masked by EPCR0_PC) if the validity bit is set (masked by
EPCR0_V). So the test as to whether the contents of the register are usable
should be involve checking the _V bit, not the _PC bits.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
[SPARC]: Fix several regset and ptrace bugs.
The prevent_tail_call() macro works around the problem of the compiler
clobbering argument words on the stack, which for asmlinkage functions
is the caller's (user's) struct pt_regs. The tail/sibling-call
optimization is not the only way that the compiler can decide to use
stack argument words as scratch space, which we have to prevent.
Other optimizations can do it too.
Until we have new compiler support to make "asmlinkage" binding on the
compiler's own use of the stack argument frame, we have work around all
the manifestations of this issue that crop up.
More cases seem to be prevented by also keeping the incoming argument
variables live at the end of the function. This makes their original
stack slots attractive places to leave those variables, so the compiler
tends not clobber them for something else. It's still no guarantee, but
it handles some observed cases that prevent_tail_call() did not.
Signed-off-by: Roland McGrath <roland@redhat.com>
This patch also resolves hangs on boot:
http://lkml.org/lkml/2008/2/23/263
http://bugzilla.kernel.org/show_bug.cgi?id=10093
The bug was causing once-in-few-reboots 10-15 sec wait during boot on
certain laptops.
Earlier commit 40d6a146629b98d8e322b6f9332b182c7cbff3df added
smp_call_function in cpu_idle_wait() to kick cpus that are in tickless
idle. Looking at cpu_idle_wait code at that time, code seemed to be
over-engineered for a case which is rarely used (while changing idle
handler).
Below is a simplified version of cpu_idle_wait, which just makes a dummy
smp_call_function to all cpus, to make them come out of old idle handler
and start using the new idle handler. It eliminates code in the idle
loop to handle cpu_idle_wait.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Make NOMMU-mode work with base addresses other than 0xC0000000 by:
(1) Giving the code that sets up the protection registers the right address
in __sdram_base. Rather than being hard coded to 0xC0000000, the value
of __page_offset is obtained from the linker script.
(2) Eliminate the check in __switch_to() that verifies the current thread
info is in the 0xCxxxxxxx region.
Use traps 120-126 to emulate atomic cmpxchg32, xchg32, and XOR-, OR-, AND-, SUB-
and ADD-to-memory operations for userspace.
1) ptrace should pass 'current' to task_user_regset_view()
2) When fetching general registers using a 64-bit view, and
the target is 32-bit, we have to convert.
3) Skip the whole register window get/set code block if
the user isn't asking to access anything in there.
Otherwise we have problems if the user doesn't have
an address space setup. Fetching ptrace register is
still valid at such a time, and ptrace does not try
to access the register window area of the regset.
gcc expects all toplevel assembly to return to the original section type.
The code in alteranative.c does not do this. This caused some strange bugs
in sched-devel where code would end up in the .rodata section and when
the kernel sets the NX bit on all .rodata, the kernel would crash when
executing this code.
This patch adds a .previous marker to return the code back to the
original section.
Credit goes to Andrew Pinski for telling me it wasn't a gcc bug but a
bug in the toplevel asm code in the kernel. ;-)
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
flush_cache_vmap / flush_cache_vunmap were calling flush_cache_all which -
having been deprecated - turned into a nop ...
In time_cpufreq_notifier() the cpu id to act upon is held in freq->cpu. Use it
instead of smp_processor_id() in the call to set_cyc2ns_scale().
This makes the preempt_*able() unnecessary and lets set_cyc2ns_scale() update
the intended cpu's cyc2ns.
Related mail/thread: http://lkml.org/lkml/2007/12/7/130
Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de>
revert:
| commit 47001d603375f857a7fab0e9c095d964a1ea0039
| Author: Thomas Gleixner <tglx@linutronix.de>
| Date: Tue Apr 1 19:45:18 2008 +0200
| x86: tsc prevent time going backwards
it has been identified to cause suspend regression - and the
commit fixes a longstanding bug that existed before 2.6.25 was
opened - so it can wait some more until the effects are better
understood.
[SPARC64]: Fix user accesses in regset code.
[SPARC64]: Fix FPU saving in 64-bit signal handling.
We handle a broken tsc these days, so no need to panic. We clear the
TSC bit when tsc_init decides it's unreliable (eg. under lguest w/ bad
host TSC), leading to bogus panic.
git://git.kernel.org/pub/scm/linux/kernel/git/ralf/upstream-linus
* 'upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/ralf/upstream-linus:
[MIPS] Make KGDB compile on UP
[MIPS] Pb1200: Fix header breakage
Building UP kernel with KGDB enabled produces the following errors and warning
(fatal due to -Werror in arch/mips/kernel/Makefile):
In file included from arch/mips/kernel/gdb-stub.c:142:
include/asm/smp.h:25:1: "raw_smp_processor_id" redefined
In file included from include/linux/sched.h:69,
from arch/mips/kernel/gdb-stub.c:126:
include/linux/smp.h:88:1: this is the location of the previous definition
include/asm/smp.h:62: error: redefinition of 'smp_send_reschedule'
include/linux/smp.h:102: error: previous definition of 'smp_send_reschedule' was here
include/asm/smp.h: In function `smp_send_reschedule':
include/asm/smp.h:65: error: dereferencing pointer to incomplete type
arch/mips/kernel/gdb-stub.c: At top level:
arch/mips/kernel/gdb-stub.c:660: warning: 'kgdb_wait' defined but not used
Fix the errors by not directly including <asm/smp.h> (which is already included
by <linux/smp.h>) and the warning by enclosing kgdb_wait() in #ifdef CONFIG_SMP.
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86:
x86: revert assign IRQs to hpet timer
xen: Clear PG_pinned in release_{pt,pd}()
xen: Do not pin/unpin PMD pages
xen: refactor xen_{alloc,release}_{pt,pd}()
x86, agpgart: scary messages are fortunately obsolete
xen: fix grant table bug
x86: fix breakage of vSMP irq operations
x86: print message if nmi_watchdog=2 cannot be enabled
x86: fix nmi_watchdog=2 on Pentium-D CPUs
Long overdue update of the m68k defconfigs
The default defconfig should be one from arch/m68k/configs/
arch/m68k/defconfig was not exactly identical to amiga_defconfig but
also considering how long they have been without any update that doesn't
seem to have been on purpose.
The commits:
commit 37a47db8d7f0f38dac5acf5a13abbc8f401707fa
Author: Balaji Rao <balajirrao@gmail.com>
Date: Wed Jan 30 13:30:03 2008 +0100
x86: assign IRQs to HPET timers, fix
and
commit e3f37a54f690d3e64995ea7ecea08c5ab3070faf
have been identified to cause a regression on some platforms due to
the assignement of legacy IRQs which makes the legacy devices
connected to those IRQs disfunctional.
Revert them.
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=10382
We already catch most of the TSC problems by sanity checks, but there
is a subtle bug which has been in the code for ever. This can cause
time jumps in the range of hours.
This was reported in:
http://lkml.org/lkml/2007/8/23/96
and
http://lkml.org/lkml/2008/3/31/23
I was able to reproduce the problem with a gettimeofday loop test on a
dual core and a quad core machine which both have sychronized
TSCs. The TSCs seems not to be perfectly in sync though, but the
kernel is not able to detect the slight delta in the sync check. Still
there exists an extremly small window where this delta can be observed
with a real big time jump. So far I was only able to reproduce this
with the vsyscall gettimeofday implementation, but in theory this
might be observable with the syscall based version as well.
CPU 0 updates the clock source variables under xtime/vyscall lock and
CPU1, where the TSC is slighty behind CPU0, is reading the time right
after the seqlock was unlocked.
The clocksource reference data was updated with the TSC from CPU0 and
the value which is read from TSC on CPU1 is less than the reference
data. This results in a huge delta value due to the unsigned
subtraction of the TSC value and the reference value. This algorithm
can not be changed due to the support of wrapping clock sources like
pm timer.
The huge delta is converted to nanoseconds and added to xtime, which
is then observable by the caller. The next gettimeofday call on CPU1
will show the correct time again as now the TSC has advanced above the
reference value.
To prevent this TSC specific wreckage we need to compare the TSC value
against the reference value and return the latter when it is larger
than the actual TSC value.
I pondered to mark the TSC unstable when the readout is smaller than
the reference value, but this would render an otherwise good and fast
clocksource unusable without a real good reason.
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
Cc: xen-devel@lists.xensource.com
Cc: Mark McLoughlin <markmc@redhat.com>
i.e. with this simple test case:
int fd = open("/dev/zero", O_RDONLY);
munmap(mmap((void *)0x40000000, 0x1000_LEN, PROT_READ, MAP_PRIVATE, fd, 0), 0x1000);
close(fd);
we currently get:
kernel BUG at arch/x86/xen/enlighten.c:678!
EIP is at xen_release_pt+0x79/0xa9
Call Trace:
[<c041da25>] ? __pmd_free_tlb+0x1a/0x75
[<c047a192>] ? free_pgd_range+0x1d2/0x2b5
[<c047a2f3>] ? free_pgtables+0x7e/0x93
[<c047b272>] ? unmap_region+0xb9/0xf5
[<c047c1bd>] ? do_munmap+0x193/0x1f5
[<c047c24f>] ? sys_munmap+0x30/0x3f
[<c0408cce>] ? syscall_call+0x7/0xb
and xen complains:
(XEN) mm.c:2241:d4 Mfn 1cc37 not pinned
Further details at:
https://bugzilla.redhat.com/436453
Fix obsolete printks in aperture-64. We used not to handle missing
agpgart, but we handle it okay now.
Signed-off-by: Pavel Machek <pavel@suse.cz>
right now if there's no CPU support for nmi_watchdog=2 we'll just
refuse it silently.
print a useful warning.
