path: root/arch
2013-03-06s390/timer: avoid overflow when programming clock comparatorHeiko Carstens
commit d911e03d097bdc01363df5d81c43f69432eb785c upstream. Since ed4f209 "s390/time: fix sched_clock() overflow" a new helper function is used to avoid overflows when converting TOD format values to nanosecond values. The kvm interrupt code formerly however only worked by accident because of an overflow. It tried to program a timer that would expire in more than ~29 years. Because of the old TOD-to-nanoseconds overflow bug the real expiry value however was much smaller, but now it isn't anymore. This however triggers yet another bug in the function that programs the clock comparator s390_next_ktime(): if the absolute "expires" value is after 2042 this will result in an overflow and the programmed value is lower than the current TOD value which immediatly triggers a clock comparator (= timer) interrupt. Since the timer isn't expired it will be programmed immediately again and so on... the result is a dead system. To fix this simply program the maximum possible value if an overflow is detected. Reported-by: Christian Borntraeger <borntraeger@de.ibm.com> Tested-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06x86: Make sure we can boot in the case the BDA contains pure garbageH. Peter Anvin
commit 7c10093692ed2e6f318387d96b829320aa0ca64c upstream. On non-BIOS platforms it is possible that the BIOS data area contains garbage instead of being zeroed or something equivalent (firmware people: we are talking of 1.5K here, so please do the sane thing.) We need on the order of 20-30K of low memory in order to boot, which may grow up to < 64K in the future. We probably want to avoid the lowest of the low memory. At the same time, it seems extremely unlikely that a legitimate EBDA would ever reach down to the 128K (which would require it to be over half a megabyte in size.) Thus, pick 128K as the cutoff for "this is insane, ignore." We may still end up reserving a bunch of extra memory on the low megabyte, but that is not really a major issue these days. In the worst case we lose 512K of RAM. This code really should be merged with trim_bios_range() in arch/x86/kernel/setup.c, but that is a bigger patch for a later merge window. Reported-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Matt Fleming <matt.fleming@intel.com> Link: http://lkml.kernel.org/n/tip-oebml055yyfm8yxmria09rja@git.kernel.org Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06powerpc/kexec: Disable hard IRQ before kexecPhileas Fogg
commit 8520e443aa56cc157b015205ea53e7b9fc831291 upstream. Disable hard IRQ before kexec a new kernel image. Not doing it can result in corrupted data in the memory segments reserved for the new kernel. Signed-off-by: Phileas Fogg <phileas-fogg@mail.ru> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06x86, efi: Make "noefi" really disable EFI runtime serivcesMatt Fleming
commit fb834c7acc5e140cf4f9e86da93a66de8c0514da upstream. commit 1de63d60cd5b ("efi: Clear EFI_RUNTIME_SERVICES rather than EFI_BOOT by "noefi" boot parameter") attempted to make "noefi" true to its documentation and disable EFI runtime services to prevent the bricking bug described in commit e0094244e41c ("samsung-laptop: Disable on EFI hardware"). However, it's not possible to clear EFI_RUNTIME_SERVICES from an early param function because EFI_RUNTIME_SERVICES is set in efi_init() *after* parse_early_param(). This resulted in "noefi" effectively becoming a no-op and no longer providing users with a way to disable EFI, which is bad for those users that have buggy machines. Reported-by: Walt Nelson Jr <walt0924@gmail.com> Cc: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Link: http://lkml.kernel.org/r/1361392572-25657-1-git-send-email-matt@console-pimps.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> [bwh: Backported to 3.2: efi_runtime_init() is not a separate function, so put a whole set of statements in an if (!disable_runtime) block] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06xen: Send spinlock IPI to all waitersStefan Bader
commit 76eaca031f0af2bb303e405986f637811956a422 upstream. There is a loophole between Xen's current implementation of pv-spinlocks and the scheduler. This was triggerable through a testcase until v3.6 changed the TLB flushing code. The problem potentially is still there just not observable in the same way. What could happen was (is): 1. CPU n tries to schedule task x away and goes into a slow wait for the runq lock of CPU n-# (must be one with a lower number). 2. CPU n-#, while processing softirqs, tries to balance domains and goes into a slow wait for its own runq lock (for updating some records). Since this is a spin_lock_irqsave in softirq context, interrupts will be re-enabled for the duration of the poll_irq hypercall used by Xen. 3. Before the runq lock of CPU n-# is unlocked, CPU n-1 receives an interrupt (e.g. endio) and when processing the interrupt, tries to wake up task x. But that is in schedule and still on_cpu, so try_to_wake_up goes into a tight loop. 4. The runq lock of CPU n-# gets unlocked, but the message only gets sent to the first waiter, which is CPU n-# and that is busily stuck. 5. CPU n-# never returns from the nested interruption to take and release the lock because the scheduler uses a busy wait. And CPU n never finishes the task migration because the unlock notification only went to CPU n-#. To avoid this and since the unlocking code has no real sense of which waiter is best suited to grab the lock, just send the IPI to all of them. This causes the waiters to return from the hyper- call (those not interrupted at least) and do active spinlocking. BugLink: http://bugs.launchpad.net/bugs/1011792 Acked-by: Jan Beulich <JBeulich@suse.com> Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06ARM: w90x900: fix legacy assembly syntaxArnd Bergmann
commit fa5ce5f94c0f2bfa41ba68d2d2524298e1fc405e upstream. New ARM binutils don't allow extraneous whitespace inside of brackets, which causes this error on all mach-w90x900 defconfigs: arch/arm/kernel/entry-armv.S: Assembler messages: arch/arm/kernel/entry-armv.S:214: Error: ARM register expected -- `ldr r0,[ r6,#(0x10C)]' arch/arm/kernel/entry-armv.S:214: Error: ARM register expected -- `ldr r0,[ r6,#(0x110)]' arch/arm/kernel/entry-armv.S:430: Error: ARM register expected -- `ldr r0,[ r6,#(0x10C)]' arch/arm/kernel/entry-armv.S:430: Error: ARM register expected -- `ldr r0,[ r6,#(0x110)]' This removes the whitespace in order to build the kernel again. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06ARM: samsung: fix assembly syntax for new gasArnd Bergmann
commit 2815774bb38445006074e16251b9ef5123bdc616 upstream. Recent assembler versions complain about extraneous whitespace inside [] brackets. This fixes all of these instances for the samsung platforms. We should backport this to all kernels that might need to be built with new binutils. arch/arm/kernel/entry-armv.S: Assembler messages: arch/arm/kernel/entry-armv.S:214: Error: ARM register expected -- `ldr r2,[ r6,#(0x10)]' arch/arm/kernel/entry-armv.S:214: Error: ARM register expected -- `ldr r0,[ r6,#(0x14)]' arch/arm/kernel/entry-armv.S:430: Error: ARM register expected -- `ldr r2,[ r6,#(0x10)]' arch/arm/kernel/entry-armv.S:430: Error: ARM register expected -- `ldr r0,[ r6,#(0x14)]' arch/arm/mach-s3c24xx/sleep-s3c2410.S: Assembler messages: arch/arm/mach-s3c24xx/sleep-s3c2410.S:48: Error: ARM register expected -- `ldr r7,[ r4 ]' arch/arm/mach-s3c24xx/sleep-s3c2410.S:49: Error: ARM register expected -- `ldr r8,[ r5 ]' arch/arm/mach-s3c24xx/sleep-s3c2410.S:50: Error: ARM register expected -- `ldr r9,[ r6 ]' arch/arm/mach-s3c24xx/sleep-s3c2410.S:64: Error: ARM register expected -- `streq r7,[ r4 ]' arch/arm/mach-s3c24xx/sleep-s3c2410.S:65: Error: ARM register expected -- `streq r8,[ r5 ]' arch/arm/mach-s3c24xx/sleep-s3c2410.S:66: Error: ARM register expected -- `streq r9,[ r6 ]' arch/arm/kernel/debug.S: Assembler messages: arch/arm/kernel/debug.S:83: Error: ARM register expected -- `ldr r2,[ r2,#((0x0B0)+(((0x56000000)-(0x50000000))+(0xF6000000+(0x01000000))))-((0)+(((0x56000000)-(0x50000000))+(0xF6000000+(0x01000000))))]' arch/arm/kernel/debug.S:83: Error: ARM register expected -- `ldr r2,[ r3,#(0x18)]' arch/arm/kernel/debug.S:85: Error: ARM register expected -- `ldr r2,[ r2,#((0x0B0)+(((0x56000000)-(0x50000000))+(0xF6000000+(0x01000000))))-((0)+(((0x56000000)-(0x50000000))+(0xF6000000+(0x01000000))))]' arch/arm/kernel/debug.S:85: Error: ARM register expected -- `ldr r2,[ r3,#(0x18)]' arch/arm/mach-s3c24xx/pm-h1940.S: Assembler messages: arch/arm/mach-s3c24xx/pm-h1940.S:33: Error: ARM register expected -- `ldr pc,[ r0,#((0x0B8)+(((0x56000000)-(0x50000000))+(0xF6000000+(0x01000000))))-(((0x56000000)-(0x50000000))+(0xF6000000+(0x01000000)))]' arch/arm/mach-s3c24xx/sleep-s3c2412.S: Assembler messages: arch/arm/mach-s3c24xx/sleep-s3c2412.S:60: Error: ARM register expected -- `ldrne r9,[ r1 ]' arch/arm/mach-s3c24xx/sleep-s3c2412.S:61: Error: ARM register expected -- `strne r9,[ r1 ]' arch/arm/mach-s3c24xx/sleep-s3c2412.S:62: Error: ARM register expected -- `ldrne r9,[ r2 ]' arch/arm/mach-s3c24xx/sleep-s3c2412.S:63: Error: ARM register expected -- `strne r9,[ r2 ]' arch/arm/mach-s3c24xx/sleep-s3c2412.S:64: Error: ARM register expected -- `ldrne r9,[ r3 ]' arch/arm/mach-s3c24xx/sleep-s3c2412.S:65: Error: ARM register expected -- `strne r9,[ r3 ]' arch/arm/kernel/debug.S:83: Error: ARM register expected -- `ldr r2,[ r3,#(0x08)]' arch/arm/kernel/debug.S:83: Error: ARM register expected -- `ldr r2,[ r3,#(0x18)]' arch/arm/kernel/debug.S:83: Error: ARM register expected -- `ldr r2,[ r3,#(0x10)]' arch/arm/kernel/debug.S:85: Error: ARM register expected -- `ldr r2,[ r3,#(0x08)]' arch/arm/kernel/debug.S:85: Error: ARM register expected -- `ldr r2,[ r3,#(0x18)]' arch/arm/kernel/debug.S:85: Error: ARM register expected -- `ldr r2,[ r3,#(0x10)]' Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> [bwh: Backported to 3.2: adjust filenames] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06efi: Clear EFI_RUNTIME_SERVICES rather than EFI_BOOT by "noefi" boot parameterSatoru Takeuchi
commit 1de63d60cd5b0d33a812efa455d5933bf1564a51 upstream. There was a serious problem in samsung-laptop that its platform driver is designed to run under BIOS and running under EFI can cause the machine to become bricked or can cause Machine Check Exceptions. Discussion about this problem: https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557 https://bugzilla.kernel.org/show_bug.cgi?id=47121 The patches to fix this problem: efi: Make 'efi_enabled' a function to query EFI facilities 83e68189745ad931c2afd45d8ee3303929233e7f samsung-laptop: Disable on EFI hardware e0094244e41c4d0c7ad69920681972fc45d8ce34 Unfortunately this problem comes back again if users specify "noefi" option. This parameter clears EFI_BOOT and that driver continues to run even if running under EFI. Refer to the document, this parameter should clear EFI_RUNTIME_SERVICES instead. Documentation/kernel-parameters.txt: =============================================================================== ... noefi [X86] Disable EFI runtime services support. ... =============================================================================== Documentation/x86/x86_64/uefi.txt: =============================================================================== ... - If some or all EFI runtime services don't work, you can try following kernel command line parameters to turn off some or all EFI runtime services. noefi turn off all EFI runtime services ... =============================================================================== Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Link: http://lkml.kernel.org/r/511C2C04.2070108@jp.fujitsu.com Cc: Matt Fleming <matt.fleming@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06x86/mm: Check if PUD is large when validating a kernel addressMel Gorman
commit 0ee364eb316348ddf3e0dfcd986f5f13f528f821 upstream. A user reported the following oops when a backup process reads /proc/kcore: BUG: unable to handle kernel paging request at ffffbb00ff33b000 IP: [<ffffffff8103157e>] kern_addr_valid+0xbe/0x110 [...] Call Trace: [<ffffffff811b8aaa>] read_kcore+0x17a/0x370 [<ffffffff811ad847>] proc_reg_read+0x77/0xc0 [<ffffffff81151687>] vfs_read+0xc7/0x130 [<ffffffff811517f3>] sys_read+0x53/0xa0 [<ffffffff81449692>] system_call_fastpath+0x16/0x1b Investigation determined that the bug triggered when reading system RAM at the 4G mark. On this system, that was the first address using 1G pages for the virt->phys direct mapping so the PUD is pointing to a physical address, not a PMD page. The problem is that the page table walker in kern_addr_valid() is not checking pud_large() and treats the physical address as if it was a PMD. If it happens to look like pmd_none then it'll silently fail, probably returning zeros instead of real data. If the data happens to look like a present PMD though, it will be walked resulting in the oops above. This patch adds the necessary pud_large() check. Unfortunately the problem was not readily reproducible and now they are running the backup program without accessing /proc/kcore so the patch has not been validated but I think it makes sense. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.coM> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20130211145236.GX21389@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06x86: Hyper-V: register clocksource only if its advertisedOlaf Hering
commit 32068f6527b8f1822a30671dedaf59c567325026 upstream. Enable hyperv_clocksource only if its advertised as a feature. XenServer 6 returns the signature which is checked in ms_hyperv_platform(), but it does not offer all features. Currently the clocksource is enabled unconditionally in ms_hyperv_init_platform(), and the result is a hanging guest. Hyper-V spec Bit 1 indicates the availability of Partition Reference Counter. Register the clocksource only if this bit is set. The guest in question prints this in dmesg: [ 0.000000] Hypervisor detected: Microsoft HyperV [ 0.000000] HyperV: features 0x70, hints 0x0 This bug can be reproduced easily be setting 'viridian=1' in a HVM domU .cfg file. A workaround without this patch is to boot the HVM guest with 'clocksource=jiffies'. Signed-off-by: Olaf Hering <olaf@aepfle.de> Link: http://lkml.kernel.org/r/1359940959-32168-1-git-send-email-kys@microsoft.com Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: Greg KH <gregkh@linuxfoundation.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06x86/apic: Work around boot failure on HP ProLiant DL980 G7 Server systemsStoney Wang
commit cb214ede7657db458fd0b2a25ea0b28dbf900ebc upstream. When a HP ProLiant DL980 G7 Server boots a regular kernel, there will be intermittent lost interrupts which could result in a hang or (in extreme cases) data loss. The reason is that this system only supports x2apic physical mode, while the kernel boots with a logical-cluster default setting. This bug can be worked around by specifying the "x2apic_phys" or "nox2apic" boot option, but we want to handle this system without requiring manual workarounds. The BIOS sets ACPI_FADT_APIC_PHYSICAL in FADT table. As all apicids are smaller than 255, BIOS need to pass the control to the OS with xapic mode, according to x2apic-spec, chapter 2.9. Current code handle x2apic when BIOS pass with xapic mode enabled: When user specifies x2apic_phys, or FADT indicates PHYSICAL: 1. During madt oem check, apic driver is set with xapic logical or xapic phys driver at first. 2. enable_IR_x2apic() will enable x2apic_mode. 3. if user specifies x2apic_phys on the boot line, x2apic_phys_probe() will install the correct x2apic phys driver and use x2apic phys mode. Otherwise it will skip the driver will let x2apic_cluster_probe to take over to install x2apic cluster driver (wrong one) even though FADT indicates PHYSICAL, because x2apic_phys_probe does not check FADT PHYSICAL. Add checking x2apic_fadt_phys in x2apic_phys_probe() to fix the problem. Signed-off-by: Stoney Wang <song-bo.wang@hp.com> [ updated the changelog and simplified the code ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1360263182-16226-1-git-send-email-yinghai@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06x86/apic: Use x2apic physical mode based on FADT settingGreg Pearson
commit ea0dcf903e7d76aa5d483d876215fedcfdfe140f upstream. Provide systems that do not support x2apic cluster mode a mechanism to select x2apic physical mode using the FADT FORCE_APIC_PHYSICAL_DESTINATION_MODE bit. Changes from v1: (based on Suresh's comments) - removed #ifdef CONFIG_ACPI - removed #include <linux/acpi.h> Signed-off-by: Greg Pearson <greg.pearson@hp.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Link: http://lkml.kernel.org/r/1335313436-32020-1-git-send-email-greg.pearson@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06x86: Do not leak kernel page mapping locationsKees Cook
commit e575a86fdc50d013bf3ad3aa81d9100e8e6cc60d upstream. Without this patch, it is trivial to determine kernel page mappings by examining the error code reported to dmesg[1]. Instead, declare the entire kernel memory space as a violation of a present page. Additionally, since show_unhandled_signals is enabled by default, switch branch hinting to the more realistic expectation, and unobfuscate the setting of the PF_PROT bit to improve readability. [1] http://vulnfactory.org/blog/2013/02/06/a-linux-memory-trick/ Reported-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Suggested-by: Brad Spengler <spender@grsecurity.net> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20130207174413.GA12485@www.outflux.net Signed-off-by: Ingo Molnar <mingo@kernel.org> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06x86-32, mm: Rip out x86_32 NUMA remapping codeDave Hansen
commit f03574f2d5b2d6229dcdf2d322848065f72953c7 upstream. This code was an optimization for 32-bit NUMA systems. It has probably been the cause of a number of subtle bugs over the years, although the conditions to excite them would have been hard to trigger. Essentially, we remap part of the kernel linear mapping area, and then sometimes part of that area gets freed back in to the bootmem allocator. If those pages get used by kernel data structures (say mem_map[] or a dentry), there's no big deal. But, if anyone ever tried to use the linear mapping for these pages _and_ cared about their physical address, bad things happen. For instance, say you passed __GFP_ZERO to the page allocator and then happened to get handed one of these pages, it zero the remapped page, but it would make a pte to the _old_ page. There are probably a hundred other ways that it could screw with things. We don't need to hang on to performance optimizations for these old boxes any more. All my 32-bit NUMA systems are long dead and buried, and I probably had access to more than most people. This code is causing real things to break today: https://lkml.org/lkml/2013/1/9/376 I looked in to actually fixing this, but it requires surgery to way too much brittle code, as well as stuff like per_cpu_ptr_to_phys(). [ hpa: Cc: this for -stable, since it is a memory corruption issue. However, an alternative is to simply mark NUMA as depends BROKEN rather than EXPERIMENTAL in the X86_32 subclause... ] Link: http://lkml.kernel.org/r/20130131005616.1C79F411@kernel.stglabs.ibm.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> [bwh: For 3.2, using the suggested alternative] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06s390/kvm: Fix store status for ACRS/FPRSChristian Borntraeger
commit 15bc8d8457875f495c59d933b05770ba88d1eacb upstream. On store status we need to copy the current state of registers into a save area. Currently we might save stale versions: The sie state descriptor doesnt have fields for guest ACRS,FPRS, those registers are simply stored in the host registers. The host program must copy these away if needed. We do that in vcpu_put/load. If we now do a store status in KVM code between vcpu_put/load, the saved values are not up-to-date. Lets collect the ACRS/FPRS before saving them. This also fixes some strange problems with hotplug and virtio-ccw, since the low level machine check handler (on hotplug a machine check will happen) will revalidate all registers with the content of the save area. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> [bwh: Backported to 3.2 as done in 3.0 by Jiri Slaby] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Jiri Slaby <jslaby@suse.cz>
2013-03-06ARM: PXA3xx: program the CSMSADRCFG registerIgor Grinberg
commit d107a204154ddd79339203c2deeb7433f0cf6777 upstream. The Chip Select Configuration Register must be programmed to 0x2 in order to achieve the correct behavior of the Static Memory Controller. Without this patch devices wired to DFI and accessed through SMC cannot be accessed after resume from S2. Do not rely on the boot loader to program the CSMSADRCFG register by programming it in the kernel smemc module. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06Purge existing TLB entries in set_pte_at and ptep_set_wrprotectJohn David Anglin
commit 7139bc1579901b53db7e898789e916ee2fb52d78 upstream. This patch goes a long way toward fixing the minifail bug, and it  significantly improves the stability of SMP machines such as the rp3440.  When write  protecting a page for COW, we need to purge the existing translation.  Otherwise, the COW break doesn't occur as expected because the TLB may still have a stale entry which allows writes. [jejb: fix up checkpatch errors] Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06powerpc/eeh: Fix crash when adding a device in a slot with DDWThadeu Lima de Souza Cascardo
commit 6a040ce72598159a74969a2d01ab0ba5ee6536b3 upstream. The DDW code uses a eeh_dev struct from the pci_dev. However, this is not set until eeh_add_device_late is called. Since pci_bus_add_devices is called before eeh_add_device_late, the PCI devices are added to the bus, making drivers' probe hooks to be called. These will call set_dma_mask, which will call the DDW code, which will require the eeh_dev struct from pci_dev. This would result in a crash, due to a NULL dereference. Calling eeh_add_device_late after pci_bus_add_devices would make the system BUG, because device files shouldn't be added to devices there were not added to the system. So, a new function is needed to add such files only after pci_bus_add_devices have been called. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com> Acked-by: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-20x86/xen: don't assume %ds is usable in xen_iret for 32-bit PVOPS.Jan Beulich
commit 13d2b4d11d69a92574a55bfd985cfb0ca77aebdc upstream. This fixes CVE-2013-0228 / XSA-42 Drew Jones while working on CVE-2013-0190 found that that unprivileged guest user in 32bit PV guest can use to crash the > guest with the panic like this: ------------- general protection fault: 0000 [#1] SMP last sysfs file: /sys/devices/vbd-51712/block/xvda/dev Modules linked in: sunrpc ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4 iptable_filter ip_tables ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables ipv6 xen_netfront ext4 mbcache jbd2 xen_blkfront dm_mirror dm_region_hash dm_log dm_mod [last unloaded: scsi_wait_scan] Pid: 1250, comm: r Not tainted 2.6.32-356.el6.i686 #1 EIP: 0061:[<c0407462>] EFLAGS: 00010086 CPU: 0 EIP is at xen_iret+0x12/0x2b EAX: eb8d0000 EBX: 00000001 ECX: 08049860 EDX: 00000010 ESI: 00000000 EDI: 003d0f00 EBP: b77f8388 ESP: eb8d1fe0 DS: 0000 ES: 007b FS: 0000 GS: 00e0 SS: 0069 Process r (pid: 1250, ti=eb8d0000 task=c2953550 task.ti=eb8d0000) Stack: 00000000 0027f416 00000073 00000206 b77f8364 0000007b 00000000 00000000 Call Trace: Code: c3 8b 44 24 18 81 4c 24 38 00 02 00 00 8d 64 24 30 e9 03 00 00 00 8d 76 00 f7 44 24 08 00 00 02 80 75 33 50 b8 00 e0 ff ff 21 e0 <8b> 40 10 8b 04 85 a0 f6 ab c0 8b 80 0c b0 b3 c0 f6 44 24 0d 02 EIP: [<c0407462>] xen_iret+0x12/0x2b SS:ESP 0069:eb8d1fe0 general protection fault: 0000 [#2] ---[ end trace ab0d29a492dcd330 ]--- Kernel panic - not syncing: Fatal exception Pid: 1250, comm: r Tainted: G D --------------- 2.6.32-356.el6.i686 #1 Call Trace: [<c08476df>] ? panic+0x6e/0x122 [<c084b63c>] ? oops_end+0xbc/0xd0 [<c084b260>] ? do_general_protection+0x0/0x210 [<c084a9b7>] ? error_code+0x73/ ------------- Petr says: " I've analysed the bug and I think that xen_iret() cannot cope with mangled DS, in this case zeroed out (null selector/descriptor) by either xen_failsafe_callback() or RESTORE_REGS because the corresponding LDT entry was invalidated by the reproducer. " Jan took a look at the preliminary patch and came up a fix that solves this problem: "This code gets called after all registers other than those handled by IRET got already restored, hence a null selector in %ds or a non-null one that got loaded from a code or read-only data descriptor would cause a kernel mode fault (with the potential of crashing the kernel as a whole, if panic_on_oops is set)." The way to fix this is to realize that the we can only relay on the registers that IRET restores. The two that are guaranteed are the %cs and %ss as they are always fixed GDT selectors. Also they are inaccessible from user mode - so they cannot be altered. This is the approach taken in this patch. Another alternative option suggested by Jan would be to relay on the subtle realization that using the %ebp or %esp relative references uses the %ss segment. In which case we could switch from using %eax to %ebp and would not need the %ss over-rides. That would also require one extra instruction to compensate for the one place where the register is used as scaled index. However Andrew pointed out that is too subtle and if further work was to be done in this code-path it could escape folks attention and lead to accidents. Reviewed-by: Petr Matousek <pmatouse@redhat.com> Reported-by: Petr Matousek <pmatouse@redhat.com> Reviewed-by: Andrew Cooper <andrew.cooper3@citrix.com> Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-20ptrace: ensure arch_ptrace/ptrace_request can never race with SIGKILLOleg Nesterov
commit 9899d11f654474d2d54ea52ceaa2a1f4db3abd68 upstream. putreg() assumes that the tracee is not running and pt_regs_access() can safely play with its stack. However a killed tracee can return from ptrace_stop() to the low-level asm code and do RESTORE_REST, this means that debugger can actually read/modify the kernel stack until the tracee does SAVE_REST again. set_task_blockstep() can race with SIGKILL too and in some sense this race is even worse, the very fact the tracee can be woken up breaks the logic. As Linus suggested we can clear TASK_WAKEKILL around the arch_ptrace() call, this ensures that nobody can ever wakeup the tracee while the debugger looks at it. Not only this fixes the mentioned problems, we can do some cleanups/simplifications in arch_ptrace() paths. Probably ptrace_unfreeze_traced() needs more callers, for example it makes sense to make the tracee killable for oom-killer before access_process_vm(). While at it, add the comment into may_ptrace_stop() to explain why ptrace_stop() still can't rely on SIGKILL and signal_pending_state(). Reported-by: Salman Qazi <sqazi@google.com> Reported-by: Suleiman Souhlal <suleiman@google.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-20ptrace/x86: Partly fix set_task_blockstep()->update_debugctlmsr() logicOleg Nesterov
commit 95cf00fa5d5e2a200a2c044c84bde8389a237e02 upstream. Afaics the usage of update_debugctlmsr() and TIF_BLOCKSTEP in step.c was always very wrong. 1. update_debugctlmsr() was simply unneeded. The child sleeps TASK_TRACED, __switch_to_xtra(next_p => child) should notice TIF_BLOCKSTEP and set/clear DEBUGCTLMSR_BTF after resume if needed. 2. It is wrong. The state of DEBUGCTLMSR_BTF bit in CPU register should always match the state of current's TIF_BLOCKSTEP bit. 3. Even get_debugctlmsr() + update_debugctlmsr() itself does not look right. Irq can change other bits in MSR_IA32_DEBUGCTLMSR register or the caller can be preempted in between. 4. It is not safe to play with TIF_BLOCKSTEP if task != current. DEBUGCTLMSR_BTF and TIF_BLOCKSTEP should always match each other if the task is running. The tracee is stopped but it can be SIGKILL'ed right before set/clear_tsk_thread_flag(). However, now that uprobes uses user_enable_single_step(current) we can't simply remove update_debugctlmsr(). So this patch adds the additional "task == current" check and disables irqs to avoid the race with interrupts/preemption. Unfortunately this patch doesn't solve the last problem, we need another fix. Probably we should teach ptrace_stop() to set/clear single/block stepping after resume. And afaics there is yet another problem: perf can play with MSR_IA32_DEBUGCTLMSR from nmi, this obviously means that even __switch_to_xtra() has problems. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-20ptrace/x86: Introduce set_task_blockstep() helperOleg Nesterov
commit 848e8f5f0ad3169560c516fff6471be65f76e69f upstream. No functional changes, preparation for the next fix and for uprobes single-step fixes. Move the code playing with TIF_BLOCKSTEP/DEBUGCTLMSR_BTF into the new helper, set_task_blockstep(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-20x86-64: Replace left over sti/cli in ia32 audit exit codeJan Beulich
commit 40a1ef95da85843696fc3ebe5fce39b0db32669f upstream. For some reason they didn't get replaced so far by their paravirt equivalents, resulting in code to be run with interrupts disabled that doesn't expect so (causing, in the observed case, a BUG_ON() to trigger) when syscall auditing is enabled. David (Cc-ed) came up with an identical fix, so likely this can be taken to count as an ack from him. Reported-by: Peter Moody <pmoody@google.com> Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Link: http://lkml.kernel.org/r/5108E01902000078000BA9C5@nat28.tlf.novell.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: David Vrabel <david.vrabel@citrix.com> Tested-by: Peter Moody <pmoody@google.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06x86, efi: Set runtime_version to the EFI spec revisionMatt Fleming
commit 712ba9e9afc4b3d3d6fa81565ca36fe518915c01 upstream. efi.runtime_version is erroneously being set to the value of the vendor's firmware revision instead of that of the implemented EFI specification. We can't deduce which EFI functions are available based on the revision of the vendor's firmware since the version scheme is likely to be unique to each vendor. What we really need to know is the revision of the implemented EFI specification, which is available in the EFI System Table header. Cc: Seiji Aguchi <seiji.aguchi@hds.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06x86: Use enum instead of literals for trap valuesKees Cook
commit c94082656dac74257f63e91f78d5d458ac781fa5 upstream. The traps are referred to by their numbers and it can be difficult to understand them while reading the code without context. This patch adds enumeration of the trap numbers and replaces the numbers with the correct enum for x86. Signed-off-by: Kees Cook <keescook@chromium.org> Link: http://lkml.kernel.org/r/20120310000710.GA32667@www.outflux.net Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cherry-picked-for: v2.3.37 Signed-off-by: John Kacur <jkacur@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06x86/Sandy Bridge: Sandy Bridge workaround depends on CONFIG_PCIH. Peter Anvin
commit e43b3cec711a61edf047adf6204d542f3a659ef8 upstream. early_pci_allowed() and read_pci_config_16() are only available if CONFIG_PCI is defined. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06x86/Sandy Bridge: mark arrays in __init functions as __initconstH. Peter Anvin
commit ab3cd8670e0b3fcde7f029e1503ed3c5138e9571 upstream. Mark static arrays as __initconst so they get removed when the init sections are flushed. Reported-by: Mathias Krause <minipli@googlemail.com> Link: http://lkml.kernel.org/r/75F4BEE6-CB0E-4426-B40B-697451677738@googlemail.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06x86/Sandy Bridge: reserve pages when integrated graphics is presentJesse Barnes
commit a9acc5365dbda29f7be2884efb63771dc24bd815 upstream. SNB graphics devices have a bug that prevent them from accessing certain memory ranges, namely anything below 1M and in the pages listed in the table. So reserve those at boot if set detect a SNB gfx device on the CPU to avoid GPU hangs. Stephane Marchesin had a similar patch to the page allocator awhile back, but rather than reserving pages up front, it leaked them at allocation time. [ hpa: made a number of stylistic changes, marked arrays as static const, and made less verbose; use "memblock=debug" for full verbosity. ] Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06efi: Make 'efi_enabled' a function to query EFI facilitiesMatt Fleming
commit 83e68189745ad931c2afd45d8ee3303929233e7f upstream. Originally 'efi_enabled' indicated whether a kernel was booted from EFI firmware. Over time its semantics have changed, and it now indicates whether or not we are booted on an EFI machine with bit-native firmware, e.g. 64-bit kernel with 64-bit firmware. The immediate motivation for this patch is the bug report at, https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557 which details how running a platform driver on an EFI machine that is designed to run under BIOS can cause the machine to become bricked. Also, the following report, https://bugzilla.kernel.org/show_bug.cgi?id=47121 details how running said driver can also cause Machine Check Exceptions. Drivers need a new means of detecting whether they're running on an EFI machine, as sadly the expression, if (!efi_enabled) hasn't been a sufficient condition for quite some time. Users actually want to query 'efi_enabled' for different reasons - what they really want access to is the list of available EFI facilities. For instance, the x86 reboot code needs to know whether it can invoke the ResetSystem() function provided by the EFI runtime services, while the ACPI OSL code wants to know whether the EFI config tables were mapped successfully. There are also checks in some of the platform driver code to simply see if they're running on an EFI machine (which would make it a bad idea to do BIOS-y things). This patch is a prereq for the samsung-laptop fix patch. Cc: David Airlie <airlied@linux.ie> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Olof Johansson <olof@lixom.net> Cc: Peter Jones <pjones@redhat.com> Cc: Colin Ian King <colin.king@canonical.com> Cc: Steve Langasek <steve.langasek@canonical.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Konrad Rzeszutek Wilk <konrad@kernel.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> [bwh: Backported to 3.2: - Adjust context (a lot) - Add efi_is_native() function from commit 5189c2a7c776 ('x86: efi: Turn off efi_enabled after setup on mixed fw/kernel') - Make efi_init() bail out when booted non-native, as it would previously not be called in this case - Drop inapplicable changes to start_kernel()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06x86/msr: Add capabilities checkAlan Cox
commit c903f0456bc69176912dee6dd25c6a66ee1aed00 upstream. At the moment the MSR driver only relies upon file system checks. This means that anything as root with any capability set can write to MSRs. Historically that wasn't very interesting but on modern processors the MSRs are such that writing to them provides several ways to execute arbitary code in kernel space. Sample code and documentation on doing this is circulating and MSR attacks are used on Windows 64bit rootkits already. In the Linux case you still need to be able to open the device file so the impact is fairly limited and reduces the security of some capability and security model based systems down towards that of a generic "root owns the box" setup. Therefore they should require CAP_SYS_RAWIO to prevent an elevation of capabilities. The impact of this is fairly minimal on most setups because they don't have heavy use of capabilities. Those using SELinux, SMACK or AppArmor rules might want to consider if their rulesets on the MSR driver could be tighter. Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06efi, x86: Pass a proper identity mapping in efi_call_phys_prelogNathan Zimmer
commit b8f2c21db390273c3eaf0e5308faeaeb1e233840 upstream. Update efi_call_phys_prelog to install an identity mapping of all available memory. This corrects a bug on very large systems with more then 512 GB in which bios would not be able to access addresses above not in the mapping. The result is a crash that looks much like this. BUG: unable to handle kernel paging request at 000000effd870020 IP: [<0000000078bce331>] 0x78bce330 PGD 0 Oops: 0000 [#1] SMP Modules linked in: CPU 0 Pid: 0, comm: swapper/0 Tainted: G W 3.8.0-rc1-next-20121224-medusa_ntz+ #2 Intel Corp. Stoutland Platform RIP: 0010:[<0000000078bce331>] [<0000000078bce331>] 0x78bce330 RSP: 0000:ffffffff81601d28 EFLAGS: 00010006 RAX: 0000000078b80e18 RBX: 0000000000000004 RCX: 0000000000000004 RDX: 0000000078bcf958 RSI: 0000000000002400 RDI: 8000000000000000 RBP: 0000000078bcf760 R08: 000000effd870000 R09: 0000000000000000 R10: 0000000000000000 R11: 00000000000000c3 R12: 0000000000000030 R13: 000000effd870000 R14: 0000000000000000 R15: ffff88effd870000 FS: 0000000000000000(0000) GS:ffff88effe400000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 000000effd870020 CR3: 000000000160c000 CR4: 00000000000006b0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process swapper/0 (pid: 0, threadinfo ffffffff81600000, task ffffffff81614400) Stack: 0000000078b80d18 0000000000000004 0000000078bced7b ffff880078b81fff 0000000000000000 0000000000000082 0000000078bce3a8 0000000000002400 0000000060000202 0000000078b80da0 0000000078bce45d ffffffff8107cb5a Call Trace: [<ffffffff8107cb5a>] ? on_each_cpu+0x77/0x83 [<ffffffff8102f4eb>] ? change_page_attr_set_clr+0x32f/0x3ed [<ffffffff81035946>] ? efi_call4+0x46/0x80 [<ffffffff816c5abb>] ? efi_enter_virtual_mode+0x1f5/0x305 [<ffffffff816aeb24>] ? start_kernel+0x34a/0x3d2 [<ffffffff816ae5ed>] ? repair_env_string+0x60/0x60 [<ffffffff816ae2be>] ? x86_64_start_reservations+0xba/0xc1 [<ffffffff816ae120>] ? early_idt_handlers+0x120/0x120 [<ffffffff816ae419>] ? x86_64_start_kernel+0x154/0x163 Code: Bad RIP value. RIP [<0000000078bce331>] 0x78bce330 RSP <ffffffff81601d28> CR2: 000000effd870020 ---[ end trace ead828934fef5eab ]--- Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Nathan Zimmer <nzimmer@sgi.com> Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06ARM: DMA: Fix struct page iterator in dma_cache_maint() to work with sparsememRussell King
commit 15653371c67c3fbe359ae37b720639dd4c7b42c5 upstream. Subhash Jadavani reported this partial backtrace: Now consider this call stack from MMC block driver (this is on the ARMv7 based board): [<c001b50c>] (v7_dma_inv_range+0x30/0x48) from [<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c) [<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c) from [<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c) [<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c) from [<c0017ff8>] (dma_map_sg+0x3c/0x114) This is caused by incrementing the struct page pointer, and running off the end of the sparsemem page array. Fix this by incrementing by pfn instead, and convert the pfn to a struct page. Suggested-by: James Bottomley <JBottomley@Parallels.com> Tested-by: Subhash Jadavani <subhashj@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06KVM: PPC: Emulate dcbfAlexander Graf
commit d3286144c92ec876da9e30320afa875699b7e0f1 upstream. Guests can trigger MMIO exits using dcbf. Since we don't emulate cache incoherent MMIO, just do nothing and move on. Reported-by: Ben Collins <ben.c@servergy.com> Signed-off-by: Alexander Graf <agraf@suse.de> Tested-by: Ben Collins <ben.c@servergy.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06xen: Fix stack corruption in xen_failsafe_callback for 32bit PVOPS guests.Andrew Cooper
commit 9174adbee4a9a49d0139f5d71969852b36720809 upstream. This fixes CVE-2013-0190 / XSA-40 There has been an error on the xen_failsafe_callback path for failed iret, which causes the stack pointer to be wrong when entering the iret_exc error path. This can result in the kernel crashing. In the classic kernel case, the relevant code looked a little like: popl %eax # Error code from hypervisor jz 5f addl $16,%esp jmp iret_exc # Hypervisor said iret fault 5: addl $16,%esp # Hypervisor said segment selector fault Here, there are two identical addls on either option of a branch which appears to have been optimised by hoisting it above the jz, and converting it to an lea, which leaves the flags register unaffected. In the PVOPS case, the code looks like: popl_cfi %eax # Error from the hypervisor lea 16(%esp),%esp # Add $16 before choosing fault path CFI_ADJUST_CFA_OFFSET -16 jz 5f addl $16,%esp # Incorrectly adjust %esp again jmp iret_exc It is possible unprivileged userspace applications to cause this behaviour, for example by loading an LDT code selector, then changing the code selector to be not-present. At this point, there is a race condition where it is possible for the hypervisor to return back to userspace from an interrupt, fault on its own iret, and inject a failsafe_callback into the kernel. This bug has been present since the introduction of Xen PVOPS support in commit 5ead97c84 (xen: Core Xen implementation), in 2.6.23. Signed-off-by: Frediano Ziglio <frediano.ziglio@citrix.com> Signed-off-by: Andrew Cooper <andrew.cooper3@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06ARM: 7628/1: head.S: map one extra section for the ATAG/DTB areaNicolas Pitre
commit 6f16f4998f98e42e3f2dedf663cfb691ff0324af upstream. We currently use a temporary 1MB section aligned to a 1MB boundary for mapping the provided device tree until the final page table is created. However, if the device tree happens to cross that 1MB boundary, the end of it remains unmapped and the kernel crashes when it attempts to access it. Given no restriction on the location of that DTB, it could end up with only a few bytes mapped at the end of a section. Solve this issue by mapping two consecutive sections. Signed-off-by: Nicolas Pitre <nico@linaro.org> Tested-by: Sascha Hauer <s.hauer@pengutronix.de> Tested-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> [bwh: Backported to 3.2: - Adjust context - The mapping is not conditional; drop the 'ne' suffixes] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06ARM: 7627/1: Predicate preempt logic on PREEMP_COUNT not PREEMPT aloneStephen Boyd
commit 568dca15aa2a0f4ddee255894ec393a159f13147 upstream. Patrik Kluba reports that the preempt count becomes invalid due to the preempt_enable() call being unbalanced with a preempt_disable() call in the vfp assembly routines. This happens because preempt_enable() and preempt_disable() update preempt counts under PREEMPT_COUNT=y but the vfp assembly routines do so under PREEMPT=y. In a configuration where PREEMPT=n and DEBUG_ATOMIC_SLEEP=y, PREEMPT_COUNT=y and so the preempt_enable() call in VFP_bounce() keeps subtracting from the preempt count until it goes negative. Fix this by always using PREEMPT_COUNT to decided when to update preempt counts in the ARM assembly code. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Reported-by: Patrik Kluba <pkluba@dension.com> Tested-by: Patrik Kluba <pkluba@dension.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06s390/time: fix sched_clock() overflowHeiko Carstens
commit ed4f20943cd4c7b55105c04daedf8d63ab6d499c upstream. Converting a 64 Bit TOD format value to nanoseconds means that the value must be divided by 4.096. In order to achieve that we multiply with 125 and divide by 512. When used within sched_clock() this triggers an overflow after appr. 417 days. Resulting in a sched_clock() return value that is much smaller than previously and therefore may cause all sort of weird things in subsystems that rely on a monotonic sched_clock() behaviour. To fix this implement a tod_to_ns() helper function which converts TOD values without overflow and call this function from both places that open coded the conversion: sched_clock() and kvm_s390_handle_wait(). Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06sh: Fix FDPIC binary loaderThomas Schwinge
commit 4a71997a3279a339e7336ea5d0cd27282e2dea44 upstream. Ensure that the aux table is properly initialized, even when optional features are missing. Without this, the FDPIC loader did not work. This was meant to be included in commit d5ab780305bb6d60a7b5a74f18cf84eb6ad153b1. Signed-off-by: Thomas Schwinge <thomas@codesourcery.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06ALSA: pxa27x: fix ac97 warm resetMike Dunn
commit 3b4bc7bccc7857274705b05cf81a0c72cfd0b0dd upstream. This patch fixes some code that implements a work-around to a hardware bug in the ac97 controller on the pxa27x. A bug in the controller's warm reset functionality requires that the mfp used by the controller as the AC97_nRESET line be temporarily reconfigured as a generic output gpio (AF0) and manually held high for the duration of the warm reset cycle. This is what was done in the original code, but it was broken long ago by commit fb1bf8cd ([ARM] pxa: introduce processor specific pxa27x_assert_ac97reset()) which changed the mfp to a GPIO input instead of a high output. The fix requires the ac97 controller to obtain the gpio via gpio_request_one(), with arguments that configure the gpio as an output initially driven high. Tested on a palm treo 680 machine. Reportedly, this broken code only prevents a warm reset on hardware that lacks a pull-up on the line, which appears to be the case for me. Signed-off-by: Mike Dunn <mikedunn@newsguy.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-16sparc: huge_ptep_set_* functions need to call set_huge_pte_at()Dave Kleikamp
[ Upstream commit 6cb9c3697585c47977c42c5cc1b9fc49247ac530 ] Modifying the huge pte's requires that all the underlying pte's be modified. Version 2: added missing flush_tlb_page() Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: sparclinux@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-16powerpc: Add missing NULL terminator to avoid boot panic on PPC40xGabor Juhos
commit e6449c9b2d90c1bd9a5985bf05ddebfd1631cd6b upstream. The missing NULL terminator can cause a panic on PPC405 boards during boot: Linux/PowerPC load: console=ttyS0,115200 root=/dev/mtdblock1 rootfstype=squashfs,jffs2 noinitrd init=/etc/preinit Finalizing device tree... flat tree at 0x6a5160 bootconsole [udbg0] enabled Page fault in user mode with in_atomic() = 1 mm = (null) NIP = c0275f50 MSR = fffffffe Oops: Weird page fault, sig: 11 [#1] PowerPC 40x Platform Modules linked in: NIP: c0275f50 LR: c0275f60 CTR: c0280000 REGS: c0275eb0 TRAP: 636f7265 Not tainted (3.7.1) MSR: fffffffe <VEC,VSX,EE,PR,FP,ME,SE,BE,IR,DR,PMM,RI> CR: c06a6190 XER: 00000001 TASK = c02662a8[0] 'swapper' THREAD: c0274000 GPR00: c0275ec0 c000c658 c027c4bf 00000000 c0275ee0 c000a0ec c020a1a8 c020a1f0 GPR08: c020f631 c020f404 c025f078 c025f080 c0275f10 Call Trace: ---[ end trace 31fd0ba7d8756001 ]--- Kernel panic - not syncing: Attempted to kill the idle task! The panic happens since commit 9597abe00c1bab2aedce6b49866bf6d1e81c9eed (sections: fix section conflicts in arch/powerpc), however the root cause of this is that the NULL terminator were not added in commit a4f740cf33f7f6c164bbde3c0cdbcc77b0c4997c (of/flattree: Add of_flat_dt_match() helper function). Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-16powerpc/vdso: Remove redundant locking in update_vsyscall_tz()Shan Hai
commit ce73ec6db47af84d1466402781ae0872a9e7873c upstream. The locking in update_vsyscall_tz() is not only unnecessary because the vdso code copies the data unproteced in __kernel_gettimeofday() but also introduces a hard to reproduce race condition between update_vsyscall() and update_vsyscall_tz(), which causes user space process to loop forever in vdso code. The following patch removes the locking from update_vsyscall_tz(). Locking is not only unnecessary because the vdso code copies the data unprotected in __kernel_gettimeofday() but also erroneous because updating the tb_update_count is not atomic and introduces a hard to reproduce race condition between update_vsyscall() and update_vsyscall_tz(), which further causes user space process to loop forever in vdso code. The below scenario describes the race condition, x==0 Boot CPU other CPU proc_P: x==0 timer interrupt update_vsyscall x==1 x++;sync settimeofday update_vsyscall_tz x==2 x++;sync x==3 sync;x++ sync;x++ proc_P: x==3 (loops until x becomes even) Because the ++ operator would be implemented as three instructions and not atomic on powerpc. A similar change was made for x86 in commit 6c260d58634 ("x86: vdso: Remove bogus locking in update_vsyscall_tz") Signed-off-by: Shan Hai <shan.hai@windriver.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03ARM: missing ->mmap_sem around find_vma() in swp_emulate.cAl Viro
commit 7bf9b7bef881aac820bf1f2e9951a17b09bd7e04 upstream. find_vma() is *not* safe when somebody else is removing vmas. Not just the return value might get bogus just as you are getting it (this instance doesn't try to dereference the resulting vma), the search itself can get buggered in rather spectacular ways. IOW, ->mmap_sem really, really is not optional here. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03CRIS: fix I/O macrosCorey Minyard
commit c24bf9b4cc6a0f330ea355d73bfdf1dae7e63a05 upstream. The inb/outb macros for CRIS are broken from a number of points of view, missing () around parameters and they have an unprotected if statement in them. This was breaking the compile of IPMI on CRIS and thus I was being annoyed by build regressions, so I fixed them. Plus I don't think they would have worked at all, since the data values were missing "&" and the outsl had a "3" instead of a "4" for the size. From what I can tell, this stuff is not used at all, so this can't be any more broken than it was before, anyway. Signed-off-by: Corey Minyard <cminyard@mvista.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Mikael Starvik <starvik@axis.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03MIPS: Fix poweroff failure when HOTPLUG_CPU configured.Huacai Chen
commit 8add1ecb81f541ef2fcb0b85a5470ad9ecfb4a84 upstream. When poweroff machine, kernel_power_off() call disable_nonboot_cpus(). And if we have HOTPLUG_CPU configured, disable_nonboot_cpus() is not an empty function but attempt to actually disable the nonboot cpus. Since system state is SYSTEM_POWER_OFF, play_dead() won't be called and thus disable_nonboot_cpus() hangs. Therefore, we make this patch to avoid poweroff failure. Signed-off-by: Huacai Chen <chenhc@lemote.com> Signed-off-by: Hongliang Tao <taohl@lemote.com> Signed-off-by: Hua Yan <yanh@lemote.com> Cc: Yong Zhang <yong.zhang@windriver.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: Fuxin Zhang <zhangfx@lemote.com> Cc: Zhangjin Wu <wuzhangjin@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/4211/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03powerpc: Fix CONFIG_RELOCATABLE=y CONFIG_CRASH_DUMP=n buildAnton Blanchard
commit 11ee7e99f35ecb15f59b21da6a82d96d2cd3fcc8 upstream. If we build a kernel with CONFIG_RELOCATABLE=y CONFIG_CRASH_DUMP=n, the kernel fails when we run at a non zero offset. It turns out we were incorrectly wrapping some of the relocatable kernel code with CONFIG_CRASH_DUMP. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03ARM: mm: use pteval_t to represent page protection valuesWill Deacon
commit 864aa04cd02979c2c755cb28b5f4fe56039171c0 upstream. When updating the page protection map after calculating the user_pgprot value, the base protection map is temporarily stored in an unsigned long type, causing truncation of the protection bits when LPAE is enabled. This effectively means that calls to mprotect() will corrupt the upper page attributes, clearing the XN bit unconditionally. This patch uses pteval_t to store the intermediate protection values, preserving the upper bits for 64-bit descriptors. Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03x86: hpet: Fix masking of MSI interruptsJan Beulich
commit 6acf5a8c931da9d26c8dd77d784daaf07fa2bff0 upstream. HPET_TN_FSB is not a proper mask bit; it merely toggles between MSI and legacy interrupt delivery. The proper mask bit is HPET_TN_ENABLE, so use both bits when (un)masking the interrupt. Signed-off-by: Jan Beulich <jbeulich@suse.com> Link: http://lkml.kernel.org/r/5093E09002000078000A60E6@nat28.tlf.novell.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03KVM: PPC: 44x: fix DCR read/writeAlexander Graf
commit e43a028752fed049e4bd94ef895542f96d79fa74 upstream. When remembering the direction of a DCR transaction, we should write to the same variable that we interpret on later when doing vcpu_run again. Signed-off-by: Alexander Graf <agraf@suse.de> [bwh: Backported to 3.2: adjust context, indentation] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03s390/kvm: dont announce RRBM supportChristian Borntraeger
commit 87cac8f879a5ecd7109dbe688087e8810b3364eb upstream. Newer kernels (linux-next with the transparent huge page patches) use rrbm if the feature is announced via feature bit 66. RRBM will cause intercepts, so KVM does not handle it right now, causing an illegal instruction in the guest. The easy solution is to disable the feature bit for the guest. This fixes bugs like: Kernel BUG at 0000000000124c2a [verbose debug info unavailable] illegal operation: 0001 [#1] SMP Modules linked in: virtio_balloon virtio_net ipv6 autofs4 CPU: 0 Not tainted 3.5.4 #1 Process fmempig (pid: 659, task: 000000007b712fd0, ksp: 000000007bed3670) Krnl PSW : 0704d00180000000 0000000000124c2a (pmdp_clear_flush_young+0x5e/0x80) R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:3 CC:1 PM:0 EA:3 00000000003cc000 0000000000000004 0000000000000000 0000000079800000 0000000000040000 0000000000000000 000000007bed3918 000000007cf40000 0000000000000001 000003fff7f00000 000003d281a94000 000000007bed383c 000000007bed3918 00000000005ecbf8 00000000002314a6 000000007bed36e0 Krnl Code:>0000000000124c2a: b9810025 ogr %r2,%r5 0000000000124c2e: 41343000 la %r3,0(%r4,%r3) 0000000000124c32: a716fffa brct %r1,124c26 0000000000124c36: b9010022 lngr %r2,%r2 0000000000124c3a: e3d0f0800004 lg %r13,128(%r15) 0000000000124c40: eb22003f000c srlg %r2,%r2,63 [ 2150.713198] Call Trace: [ 2150.713223] ([<00000000002312c4>] page_referenced_one+0x6c/0x27c) [ 2150.713749] [<0000000000233812>] page_referenced+0x32a/0x410 [...] CC: Alex Graf <agraf@suse.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
