commit 5e0fb5df2ee871b841f96f9cb6a7f2784e96aa4e upstream.
ioremap() calls pud_free_pmd_page() / pmd_free_pte_page() when it creates
a pud / pmd map. The following preconditions are met at their entry.
- All pte entries for a target pud/pmd address range have been cleared.
- System-wide TLB purges have been peformed for a target pud/pmd address
range.
The preconditions assure that there is no stale TLB entry for the range.
Speculation may not cache TLB entries since it requires all levels of page
entries, including ptes, to have P & A-bits set for an associated address.
However, speculation may cache pud/pmd entries (paging-structure caches)
when they have P-bit set.
Add a system-wide TLB purge (INVLPG) to a single page after clearing
pud/pmd entry's P-bit.
SDM 4.10.4.1, Operation that Invalidate TLBs and Paging-Structure Caches,
states that:
INVLPG invalidates all paging-structure caches associated with the
current PCID regardless of the liner addresses to which they correspond.
Fixes: 28ee90fe6048 ("x86/mm: implement free pmd/pte page interfaces")
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: mhocko@suse.com
Cc: akpm@linux-foundation.org
Cc: hpa@zytor.com
Cc: cpandya@codeaurora.org
Cc: linux-mm@kvack.org
Cc: Joerg Roedel <joro@8bytes.org>
Cc: stable@vger.kernel.org
Cc: Michal Hocko <mhocko@suse.com>
Cc: <stable@vger.kernel.org>
Link: https://lkml.kernel.org/r/20180627141348.21777-4-toshi.kani@hpe.com
commit 785a19f9d1dd8a4ab2d0633be4656653bd3de1fc upstream.
The following kernel panic was observed on ARM64 platform due to a stale
TLB entry.
1. ioremap with 4K size, a valid pte page table is set.
2. iounmap it, its pte entry is set to 0.
3. ioremap the same address with 2M size, update its pmd entry with
a new value.
4. CPU may hit an exception because the old pmd entry is still in TLB,
which leads to a kernel panic.
Commit b6bdb7517c3d ("mm/vmalloc: add interfaces to free unmapped page
table") has addressed this panic by falling to pte mappings in the above
case on ARM64.
To support pmd mappings in all cases, TLB purge needs to be performed
in this case on ARM64.
Add a new arg, 'addr', to pud_free_pmd_page() and pmd_free_pte_page()
so that TLB purge can be added later in seprate patches.
[toshi.kani@hpe.com: merge changes, rewrite patch description]
Signed-off-by: Chintan Pandya <cpandya@codeaurora.org>
Cc: mhocko@suse.com
Cc: hpa@zytor.com
Link: https://lkml.kernel.org/r/20180627141348.21777-3-toshi.kani@hpe.com
commit af839b4e546613aed1fbd64def73956aa98631e7 upstream.
There is a copy-paste error where sha256_mb_mgr_get_comp_job_avx2()
copies the SHA-256 digest state from sha256_mb_mgr::args::digest to
job_sha256::result_digest. Consequently, the sha256_mb algorithm
sometimes calculates the wrong digest. Fix it.
Reproducer using AF_ALG:
#include <assert.h>
#include <linux/if_alg.h>
#include <stdio.h>
#include <string.h>
#include <sys/socket.h>
#include <unistd.h>
static const __u8 expected[32] =
"\xad\x7f\xac\xb2\x58\x6f\xc6\xe9\x66\xc0\x04\xd7\xd1\xd1\x6b\x02"
"\x4f\x58\x05\xff\x7c\xb4\x7c\x7a\x85\xda\xbd\x8b\x48\x89\x2c\xa7";
int main()
int fd;
struct sockaddr_alg addr = {
.salg_type = "hash",
.salg_name = "sha256_mb",
__u8 data[4096] = { 0 };
__u8 digest[32];
int ret;
int i;
fd = socket(AF_ALG, SOCK_SEQPACKET, 0);
bind(fd, (void *)&addr, sizeof(addr));
fork();
fd = accept(fd, 0, 0);
do {
ret = write(fd, data, 4096);
assert(ret == 4096);
ret = read(fd, digest, 32);
assert(ret == 32);
} while (memcmp(digest, expected, 32) == 0);
printf("wrong digest: ");
for (i = 0; i < 32; i++)
printf("%02x", digest[i]);
printf("\n");
Output was:
wrong digest: ad7facb2000000000000000000000000ffffffef7cb47c7a85dabd8b48892ca7
Fixes: 172b1d6b5a93 ("crypto: sha256-mb - fix ctx pointer and digest copy")
Cc: <stable@vger.kernel.org> # v4.8+
commit f967db0b9ed44ec3057a28f3b28efc51df51b835 upstream.
ioremap() supports pmd mappings on x86-PAE. However, kernel's pmd
tables are not shared among processes on x86-PAE. Therefore, any
update to sync'd pmd entries need re-syncing. Freeing a pte page
also leads to a vmalloc fault and hits the BUG_ON in vmalloc_sync_one().
Disable free page handling on x86-PAE. pud_free_pmd_page() and
pmd_free_pte_page() simply return 0 if a given pud/pmd entry is present.
This assures that ioremap() does not update sync'd pmd entries at the
cost of falling back to pte mappings.
Reported-by: Joerg Roedel <joro@8bytes.org>
Cc: mhocko@suse.com
Cc: hpa@zytor.com
Link: https://lkml.kernel.org/r/20180627141348.21777-2-toshi.kani@hpe.com
commit 0a957467c5fd46142bc9c52758ffc552d4c5e2f7 upstream.
i8259.h uses inb/outb and thus needs to include asm/io.h to avoid the
following build error, as seen with x86_64:defconfig and CONFIG_SMP=n.
In file included from drivers/rtc/rtc-cmos.c:45:0:
arch/x86/include/asm/i8259.h: In function 'inb_pic':
arch/x86/include/asm/i8259.h:32:24: error:
implicit declaration of function 'inb'
arch/x86/include/asm/i8259.h: In function 'outb_pic':
arch/x86/include/asm/i8259.h:45:2: error:
implicit declaration of function 'outb'
Reported-by: Sebastian Gottschall <s.gottschall@dd-wrt.com>
Suggested-by: Sebastian Gottschall <s.gottschall@dd-wrt.com>
Fixes: 447ae3166702 ("x86: Don't include linux/irq.h from asm/hardirq.h")
commit 1eb46908b35dfbac0ec1848d4b1e39667e0187e9 upstream.
allmodconfig+CONFIG_INTEL_KVM=n results in the following build error.
ERROR: "l1tf_vmx_mitigation" [arch/x86/kvm/kvm.ko] undefined!
Fixes: 5b76a3cff011 ("KVM: VMX: Tell the nested hypervisor to skip L1D flush on vmentry")
Reported-by: Meelis Roos <mroos@linux.ee>
Cc: Meelis Roos <mroos@linux.ee>
commit f8b64d08dde2714c62751d18ba77f4aeceb161d3 upstream.
Move smp_num_siblings and cpu_llc_id to cpu/common.c so that they're
always present as symbols and not only in the CONFIG_SMP case. Then,
other code using them doesn't need ugly ifdeffery anymore. Get rid of
some ifdeffery.
Signed-off-by: Borislav Petkov <bpetkov@suse.de>
Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Link: http://lkml.kernel.org/r/1524864877-111962-2-git-send-email-suravee.suthikulpanit@amd.com
commit b89b41d0b8414690ec0030c134b8bde209e6d06c upstream.
Current cpu_core_id fixup causes downcored F17h configurations to be
incorrect:
NODE: 0
processor 0 core id : 0
processor 1 core id : 1
processor 2 core id : 2
processor 3 core id : 4
processor 4 core id : 5
processor 5 core id : 0
NODE: 1
processor 6 core id : 2
processor 7 core id : 3
processor 8 core id : 4
processor 9 core id : 0
processor 10 core id : 1
processor 11 core id : 2
Code that relies on the cpu_core_id, like match_smt(), for example,
which builds the thread siblings masks used by the scheduler, is
mislead.
So, limit the fixup to pre-F17h machines. The new value for cpu_core_id
for F17h and later will represent the CPUID_Fn8000001E_EBX[CoreId],
which is guaranteed to be unique for each core within a socket.
This way we have:
NODE: 0
processor 5 core id : 6
NODE: 1
processor 6 core id : 8
processor 7 core id : 9
processor 8 core id : 10
processor 9 core id : 12
processor 10 core id : 13
processor 11 core id : 14
[ Heavily massaged. ]
Cc: Yazen Ghannam <Yazen.Ghannam@amd.com>
Link: http://lkml.kernel.org/r/20170731085159.9455-2-bp@alien8.de
commit 792adb90fa724ce07c0171cbc96b9215af4b1045 upstream.
The introduction of generic_max_swapfile_size and arch-specific versions has
broken linking on x86 with CONFIG_SWAP=n due to undefined reference to
'generic_max_swapfile_size'. Fix it by compiling the x86-specific
max_swapfile_size() only with CONFIG_SWAP=y.
Reported-by: Tomas Pruzina <pruzinat@gmail.com>
Fixes: 377eeaa8e11f ("x86/speculation/l1tf: Limit swap file size to MAX_PA/2")
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
apic_id_is_primary_thread
commit d0055f351e647f33f3b0329bff022213bf8aa085 upstream.
The function has an inline "return false;" definition with CONFIG_SMP=n
but the "real" definition is also visible leading to "redefinition of
‘apic_id_is_primary_thread’" compiler error.
Guard it with #ifdef CONFIG_SMP
Fixes: 6a4d2657e048 ("x86/smp: Provide topology_is_primary_thread()")
commit 07d981ad4cf1e78361c6db1c28ee5ba105f96cc1 upstream
The kernel unnecessarily prevents late microcode loading when SMT is
disabled. It should be safe to allow it if all the primary threads are
online.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Borislav Petkov <bp@suse.de>
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
commit 30ec26da9967d0d785abc24073129a34c3211777 upstream.
Avoid loading microcode if any of the CPUs are offline, and issue a
warning. Having different microcode revisions on the system at any time
is outright dangerous.
[ Borislav: Massage changelog. ]
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
Tested-by: Tom Lendacky <thomas.lendacky@amd.com>
Tested-by: Ashok Raj <ashok.raj@intel.com>
Reviewed-by: Tom Lendacky <thomas.lendacky@amd.com>
Cc: Arjan Van De Ven <arjan.van.de.ven@intel.com>
Link: http://lkml.kernel.org/r/1519352533-15992-4-git-send-email-ashok.raj@intel.com
Link: https://lkml.kernel.org/r/20180228102846.13447-5-bp@alien8.de
commit 1063711b57393c1999248cccb57bebfaf16739e7 upstream
The mmio tracer sets io mapping PTEs and PMDs to non present when enabled
without inverting the address bits, which makes the PTE entry vulnerable
for L1TF.
Make it use the right low level macros to actually invert the address bits
to protect against L1TF.
In principle this could be avoided because MMIO tracing is not likely to be
enabled on production machines, but the fix is straigt forward and for
consistency sake it's better to get rid of the open coded PTE manipulation.
commit 958f79b9ee55dfaf00c8106ed1c22a2919e0028b upstream
set_memory_np() is used to mark kernel mappings not present, but it has
it's own open coded mechanism which does not have the L1TF protection of
inverting the address bits.
Replace the open coded PTE manipulation with the L1TF protecting low level
PTE routines.
Passes the CPA self test.
[ dwmw2: Pull in pud_mkhuge() from commit a00cc7d9dd, and pfn_pud() ]
commit 0768f91530ff46683e0b372df14fd79fe8d156e5 upstream
Some cases in THP like:
- MADV_FREE
- mprotect
- split
mark the PMD non present for temporarily to prevent races. The window for
an L1TF attack in these contexts is very small, but it wants to be fixed
for correctness sake.
Use the proper low level functions for pmd/pud_mknotpresent() to address
this.
commit f22cc87f6c1f771b57c407555cfefd811cdd9507 upstream
For kernel mappings PAGE_PROTNONE is not necessarily set for a non present
mapping, but the inversion logic explicitely checks for !PRESENT and
PROT_NONE.
Remove the PROT_NONE check and make the inversion unconditional for all not
present mappings.
commit bc2d8d262cba5736332cbc866acb11b1c5748aa9 upstream
Josh reported that the late SMT evaluation in cpu_smt_state_init() sets
cpu_smt_control to CPU_SMT_NOT_SUPPORTED in case that 'nosmt' was supplied
on the kernel command line as it cannot differentiate between SMT disabled
by BIOS and SMT soft disable via 'nosmt'. That wreckages the state and
makes the sysfs interface unusable.
Rework this so that during bringup of the non boot CPUs the availability of
SMT is determined in cpu_smt_allowed(). If a newly booted CPU is not a
'primary' thread then set the local cpu_smt_available marker and evaluate
this explicitely right after the initial SMP bringup has finished.
SMT evaulation on x86 is a trainwreck as the firmware has all the
information _before_ booting the kernel, but there is no interface to query
it.
Fixes: 73d5e2b47264 ("cpu/hotplug: detect SMT disabled by BIOS")
Reported-by: Josh Poimboeuf <jpoimboe@redhat.com>
commit 5b76a3cff011df2dcb6186c965a2e4d809a05ad4 upstream
When nested virtualization is in use, VMENTER operations from the nested
hypervisor into the nested guest will always be processed by the bare metal
hypervisor, and KVM's "conditional cache flushes" mode in particular does a
flush on nested vmentry. Therefore, include the "skip L1D flush on
vmentry" bit in KVM's suggested ARCH_CAPABILITIES setting.
Add the relevant Documentation.
commit 8e0b2b916662e09dd4d09e5271cdf214c6b80e62 upstream
Bit 3 of ARCH_CAPABILITIES tells a hypervisor that L1D flush on vmentry is
not needed. Add a new value to enum vmx_l1d_flush_state, which is used
either if there is no L1TF bug at all, or if bit 3 is set in ARCH_CAPABILITIES.
commit ea156d192f5257a5bf393d33910d3b481bf8a401 upstream
Three changes to the content of the sysfs file:
- If EPT is disabled, L1TF cannot be exploited even across threads on the
same core, and SMT is irrelevant.
- If mitigation is completely disabled, and SMT is enabled, print "vulnerable"
instead of "vulnerable, SMT vulnerable"
- Reorder the two parts so that the main vulnerability state comes first
and the detail on SMT is second.
commit cd28325249a1ca0d771557ce823e0308ad629f98 upstream
This lets userspace read the MSR_IA32_ARCH_CAPABILITIES and check that all
requested features are available on the host.
commit 518e7b94817abed94becfe6a44f1ece0d4745afe upstream
Linux (among the others) has checks to make sure that certain features
aren't enabled on a certain family/model/stepping if the microcode version
isn't greater than or equal to a known good version.
By exposing the real microcode version, we're preventing buggy guests that
don't check that they are running virtualized (i.e., they should trust the
hypervisor) from disabling features that are effectively not buggy.
Suggested-by: Filippo Sironi <sironi@amazon.de>
Signed-off-by: Wanpeng Li <wanpengli@tencent.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: Liran Alon <liran.alon@oracle.com>
Cc: Nadav Amit <nadav.amit@gmail.com>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
commit 66421c1ec340096b291af763ed5721314cdd9c5c upstream
Introduce kvm_get_msr_feature() to handle the msrs which are supported
by different vendors and sharing the same emulation logic.
commit d1d93fa90f1afa926cb060b7f78ab01a65705b4d upstream
In order to determine if LFENCE is a serializing instruction on AMD
processors, MSR 0xc0011029 (MSR_F10H_DECFG) must be read and the state
of bit 1 checked. This patch will add support to allow a guest to
properly make this determination.
Add the MSR feature callback operation to svm.c and add MSR 0xc0011029
to the list of MSR-based features. If LFENCE is serializing, then the
feature is supported, allowing the hypervisor to set the value of the
MSR that guest will see. Support is also added to write (hypervisor only)
and read the MSR value for the guest. A write by the guest will result in
a #GP. A read by the guest will return the value as set by the host. In
this way, the support to expose the feature to the guest is controlled by
the hypervisor.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
commit 801e459a6f3a63af9d447e6249088c76ae16efc4 upstream
Provide a new KVM capability that allows bits within MSRs to be recognized
as features. Two new ioctls are added to the /dev/kvm ioctl routine to
retrieve the list of these MSRs and then retrieve their values. A kvm_x86_ops
callback is used to determine support for the listed MSR-based features.
[Tweaked documentation. - Radim]
commit 18b57ce2eb8c8b9a24174a89250cf5f57c76ecdc upstream
For VMEXITs caused by external interrupts, vmx_handle_external_intr()
indirectly calls into the interrupt handlers through the host's IDT.
It follows that these interrupts get accounted for in the
kvm_cpu_l1tf_flush_l1d per-cpu flag.
The subsequently executed vmx_l1d_flush() will thus be aware that some
interrupts have happened and conduct a L1d flush anyway.
Setting l1tf_flush_l1d from vmx_handle_external_intr() isn't needed
anymore. Drop it.
Signed-off-by: Nicolai Stange <nstange@suse.de>
commit ffcba43ff66c7dab34ec700debd491d2a4d319b4 upstream
The last missing piece to having vmx_l1d_flush() take interrupts after
VMEXIT into account is to set the kvm_cpu_l1tf_flush_l1d per-cpu flag on
irq entry.
Issue calls to kvm_set_cpu_l1tf_flush_l1d() from entering_irq(),
ipi_entering_ack_irq(), smp_reschedule_interrupt() and
uv_bau_message_interrupt().
Suggested-by: Paolo Bonzini <pbonzini@redhat.com>
commit 447ae316670230d7d29430e2cbf1f5db4f49d14c upstream
The next patch in this series will have to make the definition of
irq_cpustat_t available to entering_irq().
Inclusion of asm/hardirq.h into asm/apic.h would cause circular header
dependencies like
asm/smp.h
asm/apic.h
asm/hardirq.h
linux/irq.h
linux/topology.h
linux/smp.h
asm/smp.h
or
linux/gfp.h
linux/mmzone.h
asm/mmzone.h
asm/mmzone_64.h
asm/smp.h
asm/apic.h
asm/hardirq.h
linux/irq.h
linux/irqdesc.h
linux/kobject.h
linux/sysfs.h
linux/kernfs.h
linux/idr.h
linux/gfp.h
and others.
This causes compilation errors because of the header guards becoming
effective in the second inclusion: symbols/macros that had been defined
before wouldn't be available to intermediate headers in the #include chain
anymore.
A possible workaround would be to move the definition of irq_cpustat_t
into its own header and include that from both, asm/hardirq.h and
asm/apic.h.
However, this wouldn't solve the real problem, namely asm/harirq.h
unnecessarily pulling in all the linux/irq.h cruft: nothing in
asm/hardirq.h itself requires it. Also, note that there are some other
archs, like e.g. arm64, which don't have that #include in their
asm/hardirq.h.
Remove the linux/irq.h #include from x86' asm/hardirq.h.
Fix resulting compilation errors by adding appropriate #includes to *.c
files as needed.
Note that some of these *.c files could be cleaned up a bit wrt. to their
set of #includes, but that should better be done from separate patches, if
at all.
[dwmw2: More fixes for EFI and Xen in 4.9]
commit 45b575c00d8e72d69d75dd8c112f044b7b01b069 upstream
Part of the L1TF mitigation for vmx includes flushing the L1D cache upon
VMENTRY.
L1D flushes are costly and two modes of operations are provided to users:
"always" and the more selective "conditional" mode.
If operating in the latter, the cache would get flushed only if a host side
code path considered unconfined had been traversed. "Unconfined" in this
context means that it might have pulled in sensitive data like user data
or kernel crypto keys.
The need for L1D flushes is tracked by means of the per-vcpu flag
l1tf_flush_l1d. KVM exit handlers considered unconfined set it. A
vmx_l1d_flush() subsequently invoked before the next VMENTER will conduct a
L1d flush based on its value and reset that flag again.
Currently, interrupts delivered "normally" while in root operation between
VMEXIT and VMENTER are not taken into account. Part of the reason is that
these don't leave any traces and thus, the vmx code is unable to tell if
any such has happened.
As proposed by Paolo Bonzini, prepare for tracking all interrupts by
introducing a new per-cpu flag, "kvm_cpu_l1tf_flush_l1d". It will be in
strong analogy to the per-vcpu ->l1tf_flush_l1d.
A later patch will make interrupt handlers set it.
For the sake of cache locality, group kvm_cpu_l1tf_flush_l1d into x86'
per-cpu irq_cpustat_t as suggested by Peter Zijlstra.
Provide the helpers kvm_set_cpu_l1tf_flush_l1d(),
kvm_clear_cpu_l1tf_flush_l1d() and kvm_get_cpu_l1tf_flush_l1d(). Make them
trivial resp. non-existent for !CONFIG_KVM_INTEL as appropriate.
Let vmx_l1d_flush() handle kvm_cpu_l1tf_flush_l1d in the same way as
l1tf_flush_l1d.
Suggested-by: Peter Zijlstra <peterz@infradead.org>
commit 9aee5f8a7e30330d0a8f4c626dc924ca5590aba5 upstream
An upcoming patch will extend KVM's L1TF mitigation in conditional mode
to also cover interrupts after VMEXITs. For tracking those, stores to a
new per-cpu flag from interrupt handlers will become necessary.
In order to improve cache locality, this new flag will be added to x86's
irq_cpustat_t.
Make some space available there by shrinking the ->softirq_pending bitfield
from 32 to 16 bits: the number of bits actually used is only NR_SOFTIRQS,
i.e. 10.
commit 5b6ccc6c3b1a477fbac9ec97a0b4c1c48e765209 upstream
Currently, vmx_vcpu_run() checks if l1tf_flush_l1d is set and invokes
vmx_l1d_flush() if so.
This test is unncessary for the "always flush L1D" mode.
Move the check to vmx_l1d_flush()'s conditional mode code path.
Notes:
- vmx_l1d_flush() is likely to get inlined anyway and thus, there's no
extra function call.
- This inverts the (static) branch prediction, but there hadn't been any
explicit likely()/unlikely() annotations before and so it stays as is.
commit 427362a142441f08051369db6fbe7f61c73b3dca upstream
The vmx_l1d_flush_always static key is only ever evaluated if
vmx_l1d_should_flush is enabled. In that case however, there are only two
L1d flushing modes possible: "always" and "conditional".
The "conditional" mode's implementation tends to require more sophisticated
logic than the "always" mode.
Avoid inverted logic by replacing the 'vmx_l1d_flush_always' static key
with a 'vmx_l1d_flush_cond' one.
There is no change in functionality.
commit 379fd0c7e6a391e5565336a646f19f218fb98c6c upstream
vmx_l1d_flush() gets invoked only if l1tf_flush_l1d is true. There's no
point in setting l1tf_flush_l1d to true from there again.
commit 288d152c23dcf3c09da46c5c481903ca10ebfef7 upstream
The slow path in vmx_l1d_flush() reads from vmx_l1d_flush_pages in order
to evict the L1d cache.
However, these pages are never cleared and, in theory, their data could be
leaked.
More importantly, KSM could merge a nested hypervisor's vmx_l1d_flush_pages
to fewer than 1 << L1D_CACHE_ORDER host physical pages and this would break
the L1d flushing algorithm: L1D on x86_64 is tagged by physical addresses.
Fix this by initializing the individual vmx_l1d_flush_pages with a
different pattern each.
Rename the "empty_zp" asm constraint identifier in vmx_l1d_flush() to
"flush_pages" to reflect this change.
Fixes: a47dd5f06714 ("x86/KVM/VMX: Add L1D flush algorithm")
commit d90a7a0ec83fb86622cd7dae23255d3c50a99ec8 upstream
Introduce the 'l1tf=' kernel command line option to allow for boot-time
switching of mitigation that is used on processors affected by L1TF.
The possible values are:
full
Provides all available mitigations for the L1TF vulnerability. Disables
SMT and enables all mitigations in the hypervisors. SMT control via
/sys/devices/system/cpu/smt/control is still possible after boot.
Hypervisors will issue a warning when the first VM is started in
a potentially insecure configuration, i.e. SMT enabled or L1D flush
disabled.
full,force
Same as 'full', but disables SMT control. Implies the 'nosmt=force'
command line option. sysfs control of SMT and the hypervisor flush
control is disabled.
flush
Leaves SMT enabled and enables the conditional hypervisor mitigation.
Hypervisors will issue a warning when the first VM is started in a
disabled.
flush,nosmt
Disables SMT and enables the conditional hypervisor mitigation. SMT
control via /sys/devices/system/cpu/smt/control is still possible
after boot. If SMT is reenabled or flushing disabled at runtime
hypervisors will issue a warning.
flush,nowarn
Same as 'flush', but hypervisors will not warn when
a VM is started in a potentially insecure configuration.
off
Disables hypervisor mitigations and doesn't emit any warnings.
Default is 'flush'.
Let KVM adhere to these semantics, which means:
- 'lt1f=full,force' : Performe L1D flushes. No runtime control
possible.
- 'l1tf=full'
- 'l1tf-flush'
- 'l1tf=flush,nosmt' : Perform L1D flushes and warn on VM start if
SMT has been runtime enabled or L1D flushing
has been run-time enabled
- 'l1tf=flush,nowarn' : Perform L1D flushes and no warnings are emitted.
- 'l1tf=off' : L1D flushes are not performed and no warnings
are emitted.
KVM can always override the L1D flushing behavior using its 'vmentry_l1d_flush'
module parameter except when lt1f=full,force is set.
This makes KVM's private 'nosmt' option redundant, and as it is a bit
non-systematic anyway (this is something to control globally, not on
hypervisor level), remove that option.
Add the missing Documentation entry for the l1tf vulnerability sysfs file
while at it.
Tested-by: Jiri Kosina <jkosina@suse.cz>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: https://lkml.kernel.org/r/20180713142323.202758176@linutronix.de
commit fee0aede6f4739c87179eca76136f83210953b86 upstream
The CPU_SMT_NOT_SUPPORTED state is set (if the processor does not support
SMT) when the sysfs SMT control file is initialized.
That was fine so far as this was only required to make the output of the
control file correct and to prevent writes in that case.
With the upcoming l1tf command line parameter, this needs to be set up
before the L1TF mitigation selection and command line parsing happens.
Link: https://lkml.kernel.org/r/20180713142323.121795971@linutronix.de
commit 895ae47f9918833c3a880fbccd41e0692b37e7d9 upstream
All mitigation modes can be switched at run time with a static key now:
- Use sysfs_streq() instead of strcmp() to handle the trailing new line
from sysfs writes correctly.
- Make the static key management handle multiple invocations properly.
- Set the module parameter file to RW
Link: https://lkml.kernel.org/r/20180713142322.954525119@linutronix.de
commit dd4bfa739a72508b75760b393d129ed7b431daab upstream
Writes to the parameter files are not serialized at the sysfs core
level, so local serialization is required.
Link: https://lkml.kernel.org/r/20180713142322.873642605@linutronix.de
commit 4c6523ec59fe895ea352a650218a6be0653910b1 upstream
Avoid the conditional in the L1D flush control path.
Link: https://lkml.kernel.org/r/20180713142322.790914912@linutronix.de
commit 7db92e165ac814487264632ab2624e832f20ae38 upstream
In preparation of allowing run time control for L1D flushing, move the
setup code to the module parameter handler.
In case of pre module init parsing, just store the value and let vmx_init()
do the actual setup after running kvm_init() so that enable_ept is having
the correct state.
During run-time invoke it directly from the parameter setter to prepare for
run-time control.
Link: https://lkml.kernel.org/r/20180713142322.694063239@linutronix.de
commit a7b9020b06ec6d7c3f3b0d4ef1a9eba12654f4f7 upstream
If Extended Page Tables (EPT) are disabled or not supported, no L1D
flushing is required. The setup function can just avoid setting up the L1D
flush for the EPT=n case.
Invoke it after the hardware setup has be done and enable_ept has the
correct state and expose the EPT disabled state in the mitigation status as
well.
Link: https://lkml.kernel.org/r/20180713142322.612160168@linutronix.de
commit 2f055947ae5e2741fb2dc5bba1033c417ccf4faa upstream
The VMX module parameter to control the L1D flush should become
writeable.
The MSR list is set up at VM init per guest VCPU, but the run time
switching is based on a static key which is global. Toggling the MSR list
at run time might be feasible, but for now drop this optimization and use
the regular MSR write to make run-time switching possible.
The default mitigation is the conditional flush anyway, so for extra
paranoid setups this will add some small overhead, but the extra code
executed is in the noise compared to the flush itself.
Aside of that the EPT disabled case is not handled correctly at the moment
and the MSR list magic is in the way for fixing that as well.
If it's really providing a significant advantage, then this needs to be
revisited after the code is correct and the control is writable.
Link: https://lkml.kernel.org/r/20180713142322.516940445@linutronix.de
commit 72c6d2db64fa18c996ece8f06e499509e6c9a37e upstream
Store the effective mitigation of VMX in a status variable and use it to
report the VMX state in the l1tf sysfs file.
Link: https://lkml.kernel.org/r/20180713142322.433098358@linutronix.de
commit 390d975e0c4e60ce70d4157e0dd91ede37824603 upstream
If the L1D flush module parameter is set to 'always' and the IA32_FLUSH_CMD
MSR is available, optimize the VMENTER code with the MSR save list.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 989e3992d2eca32c3f1404f2bc91acda3aa122d8 upstream
The IA32_FLUSH_CMD MSR needs only to be written on VMENTER. Extend
add_atomic_switch_msr() with an entry_only parameter to allow storing the
MSR only in the guest (ENTRY) MSR array.
commit 3190709335dd31fe1aeeebfe4ffb6c7624ef971f upstream
This allows to load a different number of MSRs depending on the context:
VMEXIT or VMENTER.
commit ca83b4a7f2d068da79a029d323024aa45decb250 upstream
.. to help find the MSR on either the guest or host MSR list.
commit 33966dd6b2d2c352fae55412db2ea8cfff5df13a upstream
There is no semantic change but this change allows an unbalanced amount of
MSRs to be loaded on VMEXIT and VMENTER, i.e. the number of MSRs to save or
restore on VMEXIT or VMENTER may be different.
Commit 83bafef1a131d1b8743d63658a180948bc880a74 upstream
When L0 establishes (or removes) an MSR entry in the VM-entry or VM-exit
MSR load lists, the change should affect the dormant VMCS as well as the
current VMCS. Moreover, the vmcs02 MSR-load addresses should be
initialized.
[ dwmw2: Pulled in to 4.9 backports for L1TF ]
Signed-off-by: Jim Mattson <jmattson@google.com>
commit c595ceee45707f00f64f61c54fb64ef0cc0b4e85 upstream
Add the logic for flushing L1D on VMENTER. The flush depends on the static
key being enabled and the new l1tf_flush_l1d flag being set.
The flags is set:
- Always, if the flush module parameter is 'always'
- Conditionally at:
- Entry to vcpu_run(), i.e. after executing user space
- From the sched_in notifier, i.e. when switching to a vCPU thread.
- From vmexit handlers which are considered unsafe, i.e. where
sensitive data can be brought into L1D:
- The emulator, which could be a good target for other speculative
execution-based threats,
- The MMU, which can bring host page tables in the L1 cache.
- External interrupts
- Nested operations that require the MMU (see above). That is
vmptrld, vmptrst, vmclear,vmwrite,vmread.
- When handling invept,invvpid
[ tglx: Split out from combo patch and reduced to a single flag ]
[ dwmw2: Backported to 4.9, set l1tf_flush_l1d in svm/vmx code ]
