path: root/arch
2011-06-13Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ftrace: Revert 8ab2b7efd ftrace: Remove unnecessary disabling of irqs kprobes/trace: Fix kprobe selftest for gcc 4.6 ftrace: Fix possible undefined return code oprofile, dcookies: Fix possible circular locking dependency oprofile: Fix locking dependency in sync_start() oprofile: Free potentially owned tasks in case of errors oprofile, x86: Add comments to IBS LVT offset initialization
2011-06-13Merge branches 'x86-urgent-for-linus' and 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: devicetree: Add missing early_init_dt_setup_initrd_arch stub x86: cpu-hotplug: Prevent softirq wakeup on wrong CPU * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Prevent potential NULL dereference in irq_set_irq_wake()
2011-06-13Merge branch 's5p-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung * 's5p-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: S3C2410: remove the now empty mach-s3c2410/irq.c ARM: S3C24XX: Move s3c24xx_irq_syscore_ops to plat-s3c24xx/irq.c ARM: S3C24xx: Fix missing struct for s3c2410_dma_chan ARM: SAMSUNG: Remove unused onenand plat functions ARM: EXYNOS4: Remove compiler warning on exynos4_pwm4_resume ARM: S5P: Fix compilation error for exynos4_defconfig ARM: S5P: Should be S3C_VA_USB_HSPHY instead of S5P_VA_XX ARM: S5P64X0: Fix SPI platform device name ARM: S5PV210: Fix possible null pointer dereference
2011-06-12Merge branch 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6: gpio/basic_mmio: add missing include of spinlock_types.h gpio/nomadik: fix sleepmode for elder Nomadik
2011-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (55 commits) ISDN, hfcsusb: Don't leak in hfcsusb_ph_info() netpoll: call dev_put() on error in netpoll_setup() net: ep93xx_eth: fix DMA API violations net: ep93xx_eth: drop GFP_DMA from call to dma_alloc_coherent() net: ep93xx_eth: allocate buffers using kmalloc() net: ep93xx_eth: pass struct device to DMA API functions ep93xx: set DMA masks for the ep93xx_eth vlan: Fix the ingress VLAN_FLAG_REORDER_HDR check dl2k: EEPROM CRC calculation wrong endianess on bigendian machine NET: am79c961: fix assembler warnings NET: am79c961: ensure multicast filter is correctly set at open NET: am79c961: ensure asm() statements are marked volatile ethtool.h: fix typos ep93xx_eth: Update MAINTAINERS ipv4: Fix packet size calculation for raw IPsec packets in __ip_append_data netpoll: prevent netpoll setup on slave devices net: pmtu_expires fixes gianfar:localized filer table iwlegacy: fix channel switch locking mac80211: fix IBSS teardown race ...
2011-06-11ep93xx: set DMA masks for the ep93xx_ethMika Westerberg
Since the driver uses the DMA API, we should pass it valid DMA masks. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: Petr Stetiar <ynezz@true.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc32, leon: bugfix in LEON SMP interrupt init sparc32, sun4m: bugfix in SMP IPI traphandler sparc: Remove unnecessary semicolons Add support for allocating irqs for bootbus devices Do not skip interrupt sources in sun4d interrupt handler and acknowledge interrupts correctly Restructure sun4d_build_device_irq so that timer interrupts can be allocated sparc: PCIC_PCI needs SPARC32 dependency sparc: Do not select GENERIC_HARDIRQS_NO_DEPRECATED sparc32,leon: add GRPCI2 PCI Host driver sparc32,leon: added LEON-common low-level PCI routines sparc32: added CONFIG_PCIC_PCI Kconfig setting
2011-06-09sparc32, leon: bugfix in LEON SMP interrupt initDaniel Hellstrom
During converting per-cpu ticker to genirq layer some IRQ initialization code was removed by commit 2cf9530420e446bb61f665d02afeb81070106900 ("sparc32,leon: per-cpu ticker use genirq per-cpu handler"). This patch reintroduces the code at the same place it was removed from. IRQ12 - IRQ14 will crash on LEON SMP without this patch because it will run the SUN4M IRQ trap handler. Reported-by: Jan Andersson <jan@gaisler.com> Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-09sparc32, sun4m: bugfix in SMP IPI traphandlerDaniel Hellstrom
Three new IPIs were introduced by commit ecbc42b70acbc6327adefe9635db93fcf62bf59d ("sparc32, sun4m: Implemented SMP IPIs support for SUN4M machines"), the old handler was already prepared for IPIs but handled only IRQ14 and IRQ13, this patch adds support for the new IPI at IRQ12. The IPI trap handler looks at the mask rather than the pending IRQ/IPI, this bug may have masked the problem above, introduced by the same commit. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-09gpio/nomadik: fix sleepmode for elder NomadikLinus Walleij
The mach-nomadik machine did not compile properly due to bad ux500-specific functions being called. Introduce new state variables to fix this up. Reported-by: Axel Lin <axel.lin@gmail.com> Cc: Alessandro Rubini <rubini@unipv.it> Cc: Prafulla Wadaskar <prafulla.wadaskar@st.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-09Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Force page alignment for initrd reserved memory dtc/powerpc: remove obsolete .gitignore entries powerpc/85xx: fix race bug of calling request_irq after enable elbc interrupts powerpc/book3e: Fix CPU feature handling on e5500 in 32-bit mode powerpc/fsl_rio: Fix compile error when CONFIG_FSL_RIO not set
2011-06-09Merge branch 'unicore32' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/epip/linux-2.6-unicore32 * 'unicore32' of git://git.kernel.org/pub/scm/linux/kernel/git/epip/linux-2.6-unicore32: unicore32: using generic-y format for one line asm-generic files unicore32: change PERCPU to PERCPU_SECTION unicore32: add KBUILD_DEFCONFIG with unicore32_defconfig (old debug_defconfig) unicore32: change zImage physical address, though it's PIC codes unicore32: move rtc-puv3.c to drivers/rtc directory
2011-06-09exec: delay address limit change until point of no returnMathias Krause
Unconditionally changing the address limit to USER_DS and not restoring it to its old value in the error path is wrong because it prevents us using kernel memory on repeated calls to this function. This, in fact, breaks the fallback of hard coded paths to the init program from being ever successful if the first candidate fails to load. With this patch applied switching to USER_DS is delayed until the point of no return is reached which makes it possible to have a multi-arch rootfs with one arch specific init binary for each of the (hard coded) probed paths. Since the address limit is already set to USER_DS when start_thread() will be invoked, this redundancy can be safely removed. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-09x86: devicetree: Add missing early_init_dt_setup_initrd_arch stubFlorian Fainelli
This patch fixes the following build failure: drivers/built-in.o: In function `early_init_dt_check_for_initrd': /home/florian/dev/kernel/x86/linux-2.6-x86/drivers/of/fdt.c:571: undefined reference to `early_init_dt_setup_initrd_arch' make: *** [.tmp_vmlinux1] Error 1 which happens as soon as we enable initrd support on a x86 devicetree platform such as Intel CE4100. Signed-off-by: Florian Fainelli <ffainelli@freebox.fr> Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: Maxime Bizon <mbizon@freebox.fr> Acked-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: stable@kernel.org # 2.6.39 Link: http://lkml.kernel.org/r/201106061015.50039.ffainelli@freebox.fr Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-06-09unicore32: using generic-y format for one line asm-generic filesGuan Xuetao
The patch adds one-line asm-generic files in arch/unicore32/include/asm/Kbuild Also, remove the old implementation in arch/unicore32/Makefile see commit from Sam Ravnborg <d8ecc5cd8e227bc318513b5306ae88a474b8886d> kbuild: asm-generic support Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-06-09unicore32: change PERCPU to PERCPU_SECTIONGuan Xuetao
The patch changes PERCPU to PERCPU_SECTION see commit from Tejun Heo <0415b00d175e0d8945e6785aad21b5f157976ce0> percpu: Always align percpu output section to PAGE_SIZE Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Tejun Heo <tj@kernel.org>
2011-06-09unicore32: add KBUILD_DEFCONFIG with unicore32_defconfig (old debug_defconfig)Guan Xuetao
Rename debug_defconfig to unicore32_defconfig, which is a minimal config for PKUnity-v3 (130nm) SoC board. Also, add KBUILD_DEFCONFIG to use 'make defconfig'. Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-06-09unicore32: change zImage physical address, though it's PIC codesGuan Xuetao
U-boot will load the kernel image to 48M physical memory address. The patch changes it to the correct address, though it's PIC codes. Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-06-09unicore32: move rtc-puv3.c to drivers/rtc directoryGuan Xuetao
The patch moves rtc driver for PKUnity-v3 SoC from arch/unicore32/kernel/ to drivers/rtc/, with renaming it to rtc-puv3.c. Also, Kconfig, Makefile, and MAINTAINERS are modified correspondingly. Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-06-09powerpc: Force page alignment for initrd reserved memoryBenjamin Herrenschmidt
When using 64K pages with a separate cpio rootfs, U-Boot will align the rootfs on a 4K page boundary. When the memory is reserved, and subsequent early memblock_alloc is called, it will allocate memory between the 64K page alignment and reserved memory. When the reserved memory is subsequently freed, it is done so by pages, causing the early memblock_alloc requests to be re-used, which in my case, caused the device-tree to be clobbered. This patch forces the reserved memory for initrd to be kernel page aligned, and will move the device tree if it overlaps with the range extension of initrd. This patch will also consolidate the identical function free_initrd_mem() from mm/init_32.c, init_64.c to mm/mem.c, and adds the same range extension when freeing initrd. free_initrd_mem() is also moved to the __init section. Many thanks to Milton Miller for his input on this patch. [BenH: Fixed build without CONFIG_BLK_DEV_INITRD] Signed-off-by: Dave Carroll <dcarroll@astekcorp.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-06-09Merge remote branch 'kumar/merge' into mergeBenjamin Herrenschmidt
2011-06-09Merge remote branch 'gcl/powerpc/merge' into mergeBenjamin Herrenschmidt
2011-06-08dtc/powerpc: remove obsolete .gitignore entriesWolfram Sang
dtc was moved and .gitignores have been added to the new location. So, we can delete the old, forgotten ones. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-08Merge branch 'stable/bug.fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/bug.fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: off by one errors in multicalls.c xen: use the trigger info we already have to choose the irq handler
2011-06-08Merge branch 'urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/urgent
2011-06-08x86: cpu-hotplug: Prevent softirq wakeup on wrong CPUThomas Gleixner
After a newly plugged CPU sets the cpu_online bit it enables interrupts and goes idle. The cpu which brought up the new cpu waits for the cpu_online bit and when it observes it, it sets the cpu_active bit for this cpu. The cpu_active bit is the relevant one for the scheduler to consider the cpu as a viable target. With forced threaded interrupt handlers which imply forced threaded softirqs we observed the following race: cpu 0 cpu 1 bringup(cpu1); set_cpu_online(smp_processor_id(), true); local_irq_enable(); while (!cpu_online(cpu1)); timer_interrupt() -> wake_up(softirq_thread_cpu1); -> enqueue_on(softirq_thread_cpu1, cpu0); ^^^^ cpu_notify(CPU_ONLINE, cpu1); -> sched_cpu_active(cpu1) -> set_cpu_active((cpu1, true); When an interrupt happens before the cpu_active bit is set by the cpu which brought up the newly onlined cpu, then the scheduler refuses to enqueue the woken thread which is bound to that newly onlined cpu on that newly onlined cpu due to the not yet set cpu_active bit and selects a fallback runqueue. Not really an expected and desirable behaviour. So far this has only been observed with forced hard/softirq threading, but in theory this could happen without forced threaded hard/softirqs as well. It's probably unobservable as it would take a massive interrupt storm on the newly onlined cpu which causes the softirq loop to wake up the softirq thread and an even longer delay of the cpu which waits for the cpu_online bit. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Peter Zijlstra <peterz@infradead.org> Cc: stable@kernel.org # 2.6.39
2011-06-07Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86/amd-iommu: Fix boot crash with hidden PCI devices x86/amd-iommu: Use only per-device dma_ops x86/amd-iommu: Fix 3 possible endless loops
2011-06-07Merge branch 'kvm-updates/3.0' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/3.0' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: Initialize kvm before registering the mmu notifier KVM: x86: use proper port value when checking io instruction permission KVM: add missing void __user * cast to access_ok() call
2011-06-07MN10300: Add missing _sdata declarationDavid Howells
_sdata needs to be declared in the linker script now as of commit a2d063ac216c ("extable, core_kernel_data(): Make sure all archs define _sdata") Signed-off-by: David Howells <dhowells@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-07MN10300: die_if_no_fixup() shouldn't use get_user() as it doesn't call set_fs()David Howells
die_if_no_fixup() shouldn't use get_user() as it doesn't call set_fs() to indicate that it wants to probe a kernel address. Instead it should use probe_kernel_read(). This fixes the problem of gdb seeing SIGILL rather than SIGTRAP when hitting the KGDB special breakpoint upon SysRq+g being seen. The problem was that die_if_no_fixup() was failing to read the opcode of the instruction that caused the exception, and thus not fixing up the exception. This caused gdb to get a S04 response to the $? request in its remote protocol rather than S05 - which would then cause it to continue with $C04 rather than $c in an attempt to pass the signal onto the inferior process. The kernel, however, does not support $Cnn, and so objects by returning an E22 response, indicating an error. gdb does not expect this and prints: warning: Remote failure reply: E22 and then returns to the gdb command prompt unable to continue. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-07MN10300: Fix one of the kernel debugger cacheflush variantsDavid Howells
One of the kernel debugger cacheflush variants escaped proper testing. Two of the labels are wrong, being derived from the code that was copied to construct the variant. The first label results in the following assembler message: AS arch/mn10300/mm/cache-dbg-flush-by-reg.o arch/mn10300/mm/cache-dbg-flush-by-reg.S: Assembler messages: arch/mn10300/mm/cache-dbg-flush-by-reg.S:123: Error: symbol `debugger_local_cache_flushinv_no_dcache' is already defined And the second label results in the following linker message: arch/mn10300/mm/built-in.o:(.text+0x1d39): undefined reference to `mn10300_local_icache_inv_range_reg_end' arch/mn10300/mm/built-in.o:(.text+0x1d39): relocation truncated to fit: R_MN10300_PCREL16 against undefined symbol `mn10300_local_icache_inv_range_reg_end' To test this file the following configuration pieces must be set: CONFIG_AM34=y CONFIG_MN10300_CACHE_WBACK=y CONFIG_MN10300_DEBUGGER_CACHE_FLUSH_BY_REG=y CONFIG_MN10300_CACHE_MANAGE_BY_REG=y CONFIG_AM34_HAS_CACHE_SNOOP=n Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-07Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] fix kvm defines for 31 bit compile [S390] use generic RCU page-table freeing code [S390] qdio: Split SBAL entry flags [S390] kvm-s390: fix stfle facilities numbers >=64 [S390] kvm-s390: Fix host crash on misbehaving guests
2011-06-07Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (21 commits) ARM: OMAP4: MMC: increase delay for pbias arm: omap2plus: move NAND_BLOCK_SIZE out of boards omap4: hwmod: Enable the keypad omap3: Free Beagle rev gpios when they are read, so others can read them later arm: omap3: beagle: Ensure msecure is mux'd to be able to set the RTC omap: rx51: Don't power up speaker amplifier at bootup omap: rx51: Set regulator V28_A always on ARM: OMAP4: MMC: no regulator off during probe for eMMC arm: omap2plus: fix ads7846 pendown gpio request ARM: OMAP2: Add missing iounmap in omap4430_phy_init ARM: omap4: Pass core and wakeup mux tables to omap4_mux_init ARM: omap2+: mux: Allow board mux settings to be NULL OMAP4: fix return value of omap4_l3_init OMAP: iovmm: fix SW flags passed by user arch/arm/mach-omap1/dma.c: Invert calls to platform_device_put and platform_device_del OMAP2+: mux: fix compilation warnings OMAP: SRAM: Fix warning: format '%08lx' expects type 'long unsigned int' arm: omap3: cm-t3517: fix section mismatch warning OMAP2+: Fix 9 section mismatch(es) warnings from mach-omap2/built-in.o ARM: OMAP2: Add missing include of linux/gpio.h ...
2011-06-07sparc: Remove unnecessary semicolonsJoe Perches
Semicolons are not necessary after switch/while/for/if braces so remove them. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-07Add support for allocating irqs for bootbus devicesoftedal
Some devices that can generate interrupts are connected directly to the CPU through the bootbus on sun4d. This patch allows IRQs to be allocated for such devices. The information used for allocating interrupts for sbus devices are present at the corresponding SBI node. For bootbus devices this information is present in the bootbus node. Signed-off-by: Kjetil Oftedal <oftedal@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-07Do not skip interrupt sources in sun4d interrupt handler and acknowledge ↵oftedal
interrupts correctly During the introduction of genirq on sparc32 bugs were introduced in the interrupt handler for sun4d. The interrupts handler checks the status of the various sbus interfaces in the system and generates a virtual interrupt, based upon the location of the interrupt source. This lookup was broken by restructuring the code in such a way that index and shift operations were performed prior to comparing this against the values read from the interrupt controllers. This could cause the handler to loop eternally as the interrupt source could be skipped before any check was performed. Additionally sun4d_encode_irq performs shifting internally, so it should not be performed twice. In sun4d_unmask interrupts were not correctly acknowledged, as the corresponding bit it the interrupt mask was not actually cleared. Signed-off-by: Kjetil Oftedal <oftedal@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-07Restructure sun4d_build_device_irq so that timer interrupts can be allocatedoftedal
sun4d_build_device_irq was called without a valid platform_device when the system timer was initialized on sun4d systems. This caused a NULL pointer crash. Josip Rodin suggested that the current sun4d_build_device_irq should be split into two functions. So that the timer initialization could skip the slot and sbus interface detection code in sun4d_build_device_irq, as this does not make sence due to the timer interrupts not being generated from a device located on sbus. Signed-off-by: Kjetil Oftedal <oftedal@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-07x86/amd-iommu: Fix boot crash with hidden PCI devicesJoerg Roedel
Some PCIe cards ship with a PCI-PCIe bridge which is not visible as a PCI device in Linux. But the device-id of the bridge is present in the IOMMU tables which causes a boot crash in the IOMMU driver. This patch fixes by removing these cards from the IOMMU handling. This is a pure -stable fix, a real fix to handle this situation appriatly will follow for the next merge window. Cc: stable@kernel.org # > 2.6.32 Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-06-06x86/amd-iommu: Use only per-device dma_opsJoerg Roedel
Unfortunatly there are systems where the AMD IOMMU does not cover all devices. This breaks with the current driver as it initializes the global dma_ops variable. This patch limits the AMD IOMMU to the devices listed in the IVRS table fixing DMA for devices not covered by the IOMMU. Cc: stable@kernel.org Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-06-06x86/amd-iommu: Fix 3 possible endless loopsJoerg Roedel
The driver contains several loops counting on an u16 value where the exit-condition is checked against variables that can have values up to 0xffff. In this case the loops will never exit. This patch fixed 3 such loops. Cc: stable@kernel.org Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-06-06[S390] fix kvm defines for 31 bit compileMartin Schwidefsky
KVM is not available for 31 bit but the KVM defines cause warnings: arch/s390/include/asm/pgtable.h: In function 'ptep_test_and_clear_user_dirty': arch/s390/include/asm/pgtable.h:817: warning: integer constant is too large for 'unsigned long' type arch/s390/include/asm/pgtable.h:818: warning: integer constant is too large for 'unsigned long' type arch/s390/include/asm/pgtable.h: In function 'ptep_test_and_clear_user_young': arch/s390/include/asm/pgtable.h:837: warning: integer constant is too large for 'unsigned long' type arch/s390/include/asm/pgtable.h:838: warning: integer constant is too large for 'unsigned long' type Add 31 bit versions of the KVM defines to remove the warnings. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-06-06[S390] use generic RCU page-table freeing codeMartin Schwidefsky
Replace the s390 specific rcu page-table freeing code with the generic variant. This requires to duplicate the definition for the struct mmu_table_batch as s390 does not use the generic tlb flush code. While we are at it remove the restriction that page table fragments can not be reused after a single fragment has been freed with rcu and split out allocation and freeing of page tables with pgstes. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-06-06[S390] qdio: Split SBAL entry flagsJan Glauber
The qdio SBAL entry flag is made-up of four different values that are independent of one another. Some of the bits are reserved by the hardware and should not be changed by qdio. Currently all four values are overwritten since the SBAL entry flag is defined as an u32. Split the SBAL entry flag into four u8's as defined by the hardware and don't touch the reserved bits. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-06-06[S390] kvm-s390: fix stfle facilities numbers >=64Christian Borntraeger
Currently KVM masks out the known good facilities only for the first double word, but passed the 2nd double word without filtering. This breaks some code on newer systems: [ 0.593966] ------------[ cut here ]------------ [ 0.594086] WARNING: at arch/s390/oprofile/hwsampler.c:696 [ 0.594213] Modules linked in: [ 0.594321] Modules linked in: [ 0.594439] CPU: 0 Not tainted 3.0.0-rc1 #46 [ 0.594564] Process swapper (pid: 1, task: 00000001effa8038, ksp: 00000001effafab8) [ 0.594735] Krnl PSW : 0704100180000000 00000000004ab89a (hwsampler_setup+0x75a/0x7b8) [ 0.594910] R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:0 CC:1 PM:0 EA:3 [ 0.595120] Krnl GPRS: ffffffff00000000 00000000ffffffea ffffffffffffffea 00000000004a98f8 [ 0.595351] 00000000004aa002 0000000000000001 000000000080e720 000000000088b9f8 [ 0.595522] 000000000080d3e8 0000000000000000 0000000000000000 000000000080e464 [ 0.595725] 0000000000000000 00000000005db198 00000000004ab3a2 00000001effafd98 [ 0.595901] Krnl Code: 00000000004ab88c: c0e5000673ca brasl %r14,57a020 [ 0.596071] 00000000004ab892: a7f4fc77 brc 15,4ab180 [ 0.596276] 00000000004ab896: a7f40001 brc 15,4ab898 [ 0.596454] >00000000004ab89a: a7c8ffa1 lhi %r12,-95 [ 0.596657] 00000000004ab89e: a7f4fc71 brc 15,4ab180 [ 0.596854] 00000000004ab8a2: a7f40001 brc 15,4ab8a4 [ 0.597029] 00000000004ab8a6: a7f4ff22 brc 15,4ab6ea [ 0.597230] 00000000004ab8aa: c0200011009a larl %r2,6cb9de [ 0.597441] Call Trace: [ 0.597511] ([<00000000004ab3a2>] hwsampler_setup+0x262/0x7b8) [ 0.597676] [<0000000000875812>] oprofile_arch_init+0x32/0xd0 [ 0.597834] [<0000000000875788>] oprofile_init+0x28/0x74 [ 0.597991] [<00000000001001be>] do_one_initcall+0x3a/0x170 [ 0.598151] [<000000000084fa22>] kernel_init+0x142/0x1ec [ 0.598314] [<000000000057db16>] kernel_thread_starter+0x6/0xc [ 0.598468] [<000000000057db10>] kernel_thread_starter+0x0/0xc [ 0.598606] Last Breaking-Event-Address: [ 0.598707] [<00000000004ab896>] hwsampler_setup+0x756/0x7b8 [ 0.598863] ---[ end trace ce3179037f4e3e5b ]--- So lets also mask the 2nd double word. Facilites 66,76,76,77 should be fine. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-06-06[S390] kvm-s390: Fix host crash on misbehaving guestsChristian Borntraeger
commit 9ff4cfb3fcfd48b49fdd9be7381b3be340853aa4 ([S390] kvm-390: Let kernel exit SIE instruction on work) fixed a problem of commit commit cd3b70f5d4d82f85d1e1d6e822f38ae098cf7c72 ([S390] virtualization aware cpu measurement) but uncovered another one. If a kvm guest accesses guest real memory that doesnt exist, the page fault handler calls the sie hook, which then rewrites the return psw from sie_inst to either sie_exit or sie_reenter. On return, the page fault handler will then detect the wrong access as a kernel fault causing a kernel oops in sie_reenter or sie_exit. We have to add these two addresses to the exception table to allow graceful exits. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-06-06KVM: x86: use proper port value when checking io instruction permissionMarcelo Tosatti
Commit f6511935f42 moved the permission check for io instructions to the ->check_perm callback. It failed to copy the port value from RDX register for string and "in,out ax,dx" instructions. Fix it by reading RDX register at decode stage when appropriate. Fixes FC8.32 installation. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-06-05Merge branch 'for-linus' of git://android.git.kernel.org/kernel/tegraLinus Torvalds
* 'for-linus' of git://android.git.kernel.org/kernel/tegra: ARM: Tegra: Harmony: Fix conflicting GPIO numbering
2011-06-04ARM: Tegra: Harmony: Fix conflicting GPIO numberingStephen Warren
Currently, both the WM8903 and TPS6586x chips attempt to register with gpiolib using the same GPIO numbers. This causes the audio driver to fail to initialize. To solve this, add a define to board-harmony.h for the TPS6586x, and make board-harmony-power.c use this define, instead of directly referencing TEGRA_NR_GPIOS. This fixes a regression introduced by commit 6f168f2fa60f87e85e0df25e87e2372f22f5eb7c. ARM: tegra: harmony: initialize the TPS65862 PMIC Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Colin Cross <ccross@android.com>
2011-06-03ARM: S3C2410: remove the now empty mach-s3c2410/irq.cHeiko Stuebner
Signed-off-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-06-03ARM: S3C24XX: Move s3c24xx_irq_syscore_ops to plat-s3c24xx/irq.cHeiko Stuebner
s3c24xx_irq_syscore_ops was only defined for s3c2410 cpus leading to compile errors on for example 2412 and 2416. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
