path: root/arch
2017-12-25sparc32: Export vac_cache_size to fix build errorGuenter Roeck
commit 9d262d95114cf2e2ac5e0ff358347fa2e214eda5 upstream. sparc32:allmodconfig fails to build with the following error. ERROR: "vac_cache_size" [drivers/infiniband/sw/rxe/rdma_rxe.ko] undefined! Fixes: cb8864559631 ("infiniband: Fix alignment of mmap cookies ...") Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Cc: Doug Ledford <dledford@redhat.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25MIPS: math-emu: Fix final emulation phase for certain instructionsAleksandar Markovic
commit 409fcace9963c1e8d2cb0f7ac62e8b34d47ef979 upstream. Fix final phase of <CLASS|MADDF|MSUBF|MAX|MIN|MAXA|MINA>.<D|S> emulation. Provide proper generation of SIGFPE signal and updating debugfs FP exception stats in cases of any exception flags set in preceding phases of emulation. CLASS.<D|S> instruction may generate "Unimplemented Operation" FP exception. <MADDF|MSUBF>.<D|S> instructions may generate "Inexact", "Unimplemented Operation", "Invalid Operation", "Overflow", and "Underflow" FP exceptions. <MAX|MIN|MAXA|MINA>.<D|S> instructions can generate "Unimplemented Operation" and "Invalid Operation" FP exceptions. The proper final processing of the cases when any FP exception flag is set is achieved by replacing "break" statement with "goto copcsr" statement. With such solution, this patch brings the final phase of emulation of the above instructions consistent with the one corresponding to the previously implemented emulation of other related FPU instructions (ADD, SUB, etc.). Fixes: 38db37ba069f ("MIPS: math-emu: Add support for the MIPS R6 CLASS FPU instruction") Fixes: e24c3bec3e8e ("MIPS: math-emu: Add support for the MIPS R6 MADDF FPU instruction") Fixes: 83d43305a1df ("MIPS: math-emu: Add support for the MIPS R6 MSUBF FPU instruction") Fixes: a79f5f9ba508 ("MIPS: math-emu: Add support for the MIPS R6 MAX{, A} FPU instruction") Fixes: 4e9561b20e2f ("MIPS: math-emu: Add support for the MIPS R6 MIN{, A} FPU instruction") Signed-off-by: Aleksandar Markovic <aleksandar.markovic@mips.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Douglas Leung <douglas.leung@mips.com> Cc: Goran Ferenc <goran.ferenc@mips.com> Cc: "Maciej W. Rozycki" <macro@imgtec.com> Cc: Miodrag Dinic <miodrag.dinic@mips.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Petar Jovanovic <petar.jovanovic@mips.com> Cc: Raghu Gandham <raghu.gandham@mips.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/17581/ Signed-off-by: James Hogan <jhogan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25kvm, mm: account kvm related kmem slabs to kmemcgShakeel Butt
[ Upstream commit 46bea48ac241fe0b413805952dda74dd0c09ba8b ] The kvm slabs can consume a significant amount of system memory and indeed in our production environment we have observed that a lot of machines are spending significant amount of memory that can not be left as system memory overhead. Also the allocations from these slabs can be triggered directly by user space applications which has access to kvm and thus a buggy application can leak such memory. So, these caches should be accounted to kmemcg. Signed-off-by: Shakeel Butt <shakeelb@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25ARM: dma-mapping: disallow dma_get_sgtable() for non-kernel managed memoryRussell King
[ Upstream commit 916a008b4b8ecc02fbd035cfb133773dba1ff3d7 ] dma_get_sgtable() tries to create a scatterlist table containing valid struct page pointers for the coherent memory allocation passed in to it. However, memory can be declared via dma_declare_coherent_memory(), or via other reservation schemes which means that coherent memory is not guaranteed to be backed by struct pages. In such cases, the resulting scatterlist table contains pointers to invalid pages, which causes kernel oops later. This patch adds detection of such memory, and refuses to create a scatterlist table for such memory. Reported-by: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25ARM: dts: am335x-evmsk: adjust mmc2 param to allow suspendReizer, Eyal
[ Upstream commit 9bcf53f34a2c1cebc45cc12e273dcd5f51fbc099 ] mmc2 used for wl12xx was missing the keep-power-in suspend parameter. As a result the board couldn't reach suspend state. Signed-off-by: Eyal Reizer <eyalr@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25ARM: dts: ti: fix PCI bus dtc warningsRob Herring
[ Upstream commit 7d79f6098d82f8c09914d7799bc96891ad9c3baf ] dtc recently added PCI bus checks. Fix these warnings. Signed-off-by: Rob Herring <robh@kernel.org> Cc: "Benoît Cousson" <bcousson@baylibre.com> Cc: Tony Lindgren <tony@atomide.com> Cc: linux-omap@vger.kernel.org Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25KVM: VMX: Fix enable VPID conditionsWanpeng Li
[ Upstream commit 08d839c4b134b8328ec42f2157a9ca4b93227c03 ] This can be reproduced by running L2 on L1, and disable VPID on L0 if w/o commit "KVM: nVMX: Fix nested VPID vmx exec control", the L2 crash as below: KVM: entry failed, hardware error 0x7 EAX=00000000 EBX=00000000 ECX=00000000 EDX=000306c3 ESI=00000000 EDI=00000000 EBP=00000000 ESP=00000000 EIP=0000fff0 EFL=00000002 [-------] CPL=0 II=0 A20=1 SMM=0 HLT=0 ES =0000 00000000 0000ffff 00009300 CS =f000 ffff0000 0000ffff 00009b00 SS =0000 00000000 0000ffff 00009300 DS =0000 00000000 0000ffff 00009300 FS =0000 00000000 0000ffff 00009300 GS =0000 00000000 0000ffff 00009300 LDT=0000 00000000 0000ffff 00008200 TR =0000 00000000 0000ffff 00008b00 GDT= 00000000 0000ffff IDT= 00000000 0000ffff CR0=60000010 CR2=00000000 CR3=00000000 CR4=00000000 DR0=0000000000000000 DR1=0000000000000000 DR2=0000000000000000 DR3=0000000000000000 DR6=00000000ffff0ff0 DR7=0000000000000400 EFER=0000000000000000 Reference SDM 30.3 INVVPID: Protected Mode Exceptions - #UD - If not in VMX operation. - If the logical processor does not support VPIDs (IA32_VMX_PROCBASED_CTLS2[37]=0). - If the logical processor supports VPIDs (IA32_VMX_PROCBASED_CTLS2[37]=1) but does not support the INVVPID instruction (IA32_VMX_EPT_VPID_CAP[32]=0). So we should check both VPID enable bit in vmx exec control and INVVPID support bit in vmx capability MSRs to enable VPID. This patch adds the guarantee to not enable VPID if either INVVPID or single-context/all-context invalidation is not exposed in vmx capability MSRs. Reviewed-by: David Hildenbrand <david@redhat.com> Reviewed-by: Jim Mattson <jmattson@google.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25KVM: x86: correct async page present tracepointWanpeng Li
[ Upstream commit 24dccf83a121b8a4ad5c2ad383a8184ef6c266ee ] After async pf setup successfully, there is a broadcast wakeup w/ special token 0xffffffff which tells vCPU that it should wake up all processes waiting for APFs though there is no real process waiting at the moment. The async page present tracepoint print prematurely and fails to catch the special token setup. This patch fixes it by moving the async page present tracepoint after the special token setup. Before patch: qemu-system-x86-8499 [006] ...1 5973.473292: kvm_async_pf_ready: token 0x0 gva 0x0 After patch: qemu-system-x86-8499 [006] ...1 5973.473292: kvm_async_pf_ready: token 0xffffffff gva 0x0 Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25kvm: vmx: Flush TLB when the APIC-access address changesJim Mattson
[ Upstream commit fb6c8198431311027c3434d4e94ab8bc040f7aea ] Quoting from the Intel SDM, volume 3, section 28.3.3.4: Guidelines for Use of the INVEPT Instruction: If EPT was in use on a logical processor at one time with EPTP X, it is recommended that software use the INVEPT instruction with the "single-context" INVEPT type and with EPTP X in the INVEPT descriptor before a VM entry on the same logical processor that enables EPT with EPTP X and either (a) the "virtualize APIC accesses" VM-execution control was changed from 0 to 1; or (b) the value of the APIC-access address was changed. In the nested case, the burden falls on L1, unless L0 enables EPT in vmcs02 when L1 doesn't enable EPT in vmcs12. Signed-off-by: Jim Mattson <jmattson@google.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25arm: kprobes: Align stack to 8-bytes in test codeJon Medhurst
[ Upstream commit 974310d047f3c7788a51d10c8d255eebdb1fa857 ] kprobes test cases need to have a stack that is aligned to an 8-byte boundary because they call other functions (and the ARM ABI mandates that alignment) and because test cases include 64-bit accesses to the stack. Unfortunately, GCC doesn't ensure this alignment for inline assembler and for the code in question seems to always misalign it by pushing just the LR register onto the stack. We therefore need to explicitly perform stack alignment at the start of each test case. Without this fix, some test cases will generate alignment faults on systems where alignment is enforced. Even if the kernel is configured to handle these faults in software, triggering them is ugly. It also exposes limitations in the fault handling code which doesn't cope with writes to the stack. E.g. when handling this instruction strd r6, [sp, #-64]! the fault handling code will write to a stack location below the SP value at the point the fault occurred, which coincides with where the exception handler has pushed the saved register context. This results in corruption of those registers. Signed-off-by: Jon Medhurst <tixy@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25arm: kprobes: Fix the return address of multiple kretprobesMasami Hiramatsu
[ Upstream commit 06553175f585b52509c7df37d6f4a50aacb7b211 ] This is arm port of commit 737480a0d525 ("kprobes/x86: Fix the return address of multiple kretprobes"). Fix the return address of subsequent kretprobes when multiple kretprobes are set on the same function. For example: # cd /sys/kernel/debug/tracing # echo "r:event1 sys_symlink" > kprobe_events # echo "r:event2 sys_symlink" >> kprobe_events # echo 1 > events/kprobes/enable # ln -s /tmp/foo /tmp/bar (without this patch) # cat trace | grep -v ^# ln-82 [000] dn.2 68.446525: event1: (kretprobe_trampoline+0x0/0x18 <- SyS_symlink) ln-82 [000] dn.2 68.447831: event2: (ret_fast_syscall+0x0/0x1c <- SyS_symlink) (with this patch) # cat trace | grep -v ^# ln-81 [000] dn.1 39.463469: event1: (ret_fast_syscall+0x0/0x1c <- SyS_symlink) ln-81 [000] dn.1 39.464701: event2: (ret_fast_syscall+0x0/0x1c <- SyS_symlink) Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: KUMANO Syuhei <kumano.prog@gmail.com> Signed-off-by: Jon Medhurst <tixy@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25kvm: fix usage of uninit spinlock in avic_vm_destroy()Dmitry Vyukov
[ Upstream commit 3863dff0c3dd72984395c93b12383b393c5c3989 ] If avic is not enabled, avic_vm_init() does nothing and returns early. However, avic_vm_destroy() still tries to destroy what hasn't been created. The only bad consequence of this now is that avic_vm_destroy() uses svm_vm_data_hash_lock that hasn't been initialized (and is not meant to be used at all if avic is not enabled). Return early from avic_vm_destroy() if avic is not enabled. It has nothing to destroy. Signed-off-by: Dmitry Vyukov <dvyukov@google.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: "Radim Krčmář" <rkrcmar@redhat.com> Cc: David Hildenbrand <david@redhat.com> Cc: kvm@vger.kernel.org Cc: syzkaller@googlegroups.com Reviewed-by: David Hildenbrand <david@redhat.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25arm64: Initialise high_memory global variable earlierSteve Capper
commit f24e5834a2c3f6c5f814a417f858226f0a010ade upstream. The high_memory global variable is used by cma_declare_contiguous(.) before it is defined. We don't notice this as we compute __pa(high_memory - 1), and it looks like we're processing a VA from the direct linear map. This problem becomes apparent when we flip the kernel virtual address space and the linear map is moved to the bottom of the kernel VA space. This patch moves the initialisation of high_memory before it used. Fixes: f7426b983a6a ("mm: cma: adjust address limit to avoid hitting low/high memory boundary") Signed-off-by: Steve Capper <steve.capper@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20pinctrl: adi2: Fix Kconfig build problemLinus Walleij
[ Upstream commit 1c363531dd814dc4fe10865722bf6b0f72ce4673 ] The build robot is complaining on Blackfin: drivers/pinctrl/pinctrl-adi2.c: In function 'port_setup': >> drivers/pinctrl/pinctrl-adi2.c:221:21: error: dereferencing pointer to incomplete type 'struct gpio_port_t' writew(readw(&regs->port_fer) & ~BIT(offset), ^~ drivers/pinctrl/pinctrl-adi2.c: In function 'adi_gpio_ack_irq': >> drivers/pinctrl/pinctrl-adi2.c:266:18: error: dereferencing pointer to incomplete type 'struct bfin_pint_regs' if (readl(&regs->invert_set) & pintbit) ^~ It seems the driver need to include <asm/gpio.h> and <asm/irq.h> to compile. The Blackfin architecture was re-defining the Kconfig PINCTRL symbol which is not OK, so replaced this with PINCTRL_BLACKFIN_ADI2 which selects PINCTRL and PINCTRL_ADI2 just like most arches do. Further, the old GPIO driver symbol GPIO_ADI was possible to select at the same time as selecting PINCTRL. This was not working because the arch-local <asm/gpio.h> header contains an explicit #ifndef PINCTRL clause making compilation break if you combine them. The same is true for DEBUG_MMRS. Make sure the ADI2 pinctrl driver is not selected at the same time as the old GPIO implementation. (This should be converted to use gpiolib or pincontrol and move to drivers/...) Also make sure the old GPIO_ADI driver or DEBUG_MMRS is not selected at the same time as the new PINCTRL implementation, and only make PINCTRL_ADI2 selectable for the Blackfin families that actually have it. This way it is still possible to add e.g. I2C-based pin control expanders on the Blackfin. Cc: Steven Miao <realmz6@gmail.com> Cc: Huanhuan Feng <huanhuan.feng@analog.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20powerpc/perf/hv-24x7: Fix incorrect comparison in memordMichael Ellerman
[ Upstream commit 05c14c03138532a3cb2aa29c2960445c8753343b ] In the hv-24x7 code there is a function memord() which tries to implement a sort function return -1, 0, 1. However one of the conditions is incorrect, such that it can never be true, because we will have already returned. I don't believe there is a bug in practice though, because the comparisons are an optimisation prior to calling memcmp(). Fix it by swapping the second comparision, so it can be true. Reported-by: David Binderman <dcb314@hotmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20arm64: prevent regressions in compressed kernel image size when upgrading to ↵Nick Desaulniers
binutils 2.27 [ Upstream commit fd9dde6abcb9bfe6c6bee48834e157999f113971 ] Upon upgrading to binutils 2.27, we found that our lz4 and gzip compressed kernel images were significantly larger, resulting is 10ms boot time regressions. As noted by Rahul: "aarch64 binaries uses RELA relocations, where each relocation entry includes an addend value. This is similar to x86_64. On x86_64, the addend values are also stored at the relocation offset for relative relocations. This is an optimization: in the case where code does not need to be relocated, the loader can simply skip processing relative relocations. In binutils-2.25, both bfd and gold linkers did this for x86_64, but only the gold linker did this for aarch64. The kernel build here is using the bfd linker, which stored zeroes at the relocation offsets for relative relocations. Since a set of zeroes compresses better than a set of non-zero addend values, this behavior was resulting in much better lz4 compression. The bfd linker in binutils-2.27 is now storing the actual addend values at the relocation offsets. The behavior is now consistent with what it does for x86_64 and what gold linker does for both architectures. The change happened in this upstream commit: https://sourceware.org/git/?p=binutils-gdb.git;a=commit;h=1f56df9d0d5ad89806c24e71f296576d82344613 Since a bunch of zeroes got replaced by non-zero addend values, we see the side effect of lz4 compressed image being a bit bigger. To get the old behavior from the bfd linker, "--no-apply-dynamic-relocs" flag can be used: $ LDFLAGS="--no-apply-dynamic-relocs" make With this flag, the compressed image size is back to what it was with binutils-2.25. If the kernel is using ASLR, there aren't additional runtime costs to --no-apply-dynamic-relocs, as the relocations will need to be applied again anyway after the kernel is relocated to a random address. If the kernel is not using ASLR, then presumably the current default behavior of the linker is better. Since the static linker performed the dynamic relocs, and the kernel is not moved to a different address at load time, it can skip applying the relocations all over again." Some measurements: $ ld -v GNU ld (binutils-2.25-f3d35cf6) 2.25.51.20141117 ^ $ ls -l vmlinux -rwxr-x--- 1 ndesaulniers eng 300652760 Oct 26 11:57 vmlinux $ ls -l Image.lz4-dtb -rw-r----- 1 ndesaulniers eng 16932627 Oct 26 11:57 Image.lz4-dtb $ ld -v GNU ld (binutils-2.27-53dd00a1) 2.27.0.20170315 ^ pre patch: $ ls -l vmlinux -rwxr-x--- 1 ndesaulniers eng 300376208 Oct 26 11:43 vmlinux $ ls -l Image.lz4-dtb -rw-r----- 1 ndesaulniers eng 18159474 Oct 26 11:43 Image.lz4-dtb post patch: $ ls -l vmlinux -rwxr-x--- 1 ndesaulniers eng 300376208 Oct 26 12:06 vmlinux $ ls -l Image.lz4-dtb -rw-r----- 1 ndesaulniers eng 16932466 Oct 26 12:06 Image.lz4-dtb By Siqi's measurement w/ gzip: binutils 2.27 with this patch (with --no-apply-dynamic-relocs): Image 41535488 Image.gz 13404067 binutils 2.27 without this patch (without --no-apply-dynamic-relocs): Image 41535488 Image.gz 14125516 Any compression scheme should be able to get better results from the longer runs of zeros, not just GZIP and LZ4. 10ms boot time savings isn't anything to get excited about, but users of arm64+compression+bfd-2.27 should not have to pay a penalty for no runtime improvement. Reported-by: Gopinath Elanchezhian <gelanchezhian@google.com> Reported-by: Sindhuri Pentyala <spentyala@google.com> Reported-by: Wei Wang <wvw@google.com> Suggested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Suggested-by: Rahul Chaudhry <rahulchaudhry@google.com> Suggested-by: Siqi Lin <siqilin@google.com> Suggested-by: Stephen Hines <srhines@google.com> Signed-off-by: Nick Desaulniers <ndesaulniers@google.com> Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> [will: added comment to Makefile] Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20powerpc/ipic: Fix status get and status clearChristophe Leroy
[ Upstream commit 6b148a7ce72a7f87c81cbcde48af014abc0516a9 ] IPIC Status is provided by register IPIC_SERSR and not by IPIC_SERMR which is the mask register. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20powerpc/opal: Fix EBUSY bug in acquiring tokensWilliam A. Kennington III
[ Upstream commit 71e24d7731a2903b1ae2bba2b2971c654d9c2aa6 ] The current code checks the completion map to look for the first token that is complete. In some cases, a completion can come in but the token can still be on lease to the caller processing the completion. If this completed but unreleased token is the first token found in the bitmap by another tasks trying to acquire a token, then the __test_and_set_bit call will fail since the token will still be on lease. The acquisition will then fail with an EBUSY. This patch reorganizes the acquisition code to look at the opal_async_token_map for an unleased token. If the token has no lease it must have no outstanding completions so we should never see an EBUSY, unless we have leased out too many tokens. Since opal_async_get_token_inrerruptible is protected by a semaphore, we will practically never see EBUSY anymore. Fixes: 8d7248232208 ("powerpc/powernv: Infrastructure to support OPAL async completion") Signed-off-by: William A. Kennington III <wak@google.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20powerpc/powernv/cpufreq: Fix the frequency read by /proc/cpuinfoShriya
[ Upstream commit cd77b5ce208c153260ed7882d8910f2395bfaabd ] The call to /proc/cpuinfo in turn calls cpufreq_quick_get() which returns the last frequency requested by the kernel, but may not reflect the actual frequency the processor is running at. This patch makes a call to cpufreq_get() instead which returns the current frequency reported by the hardware. Fixes: fb5153d05a7d ("powerpc: powernv: Implement ppc_md.get_proc_freq()") Signed-off-by: Shriya <shriyak@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20Revert "x86/acpi: Set persistent cpuid <-> nodeid mapping when booting"Dou Liyang
[ Upstream commit c962cff17dfa11f4a8227ac16de2b28aea3312e4 ] Revert: dc6db24d2476 ("x86/acpi: Set persistent cpuid <-> nodeid mapping when booting") The mapping of "cpuid <-> nodeid" is established at boot time via ACPI tables to keep associations of workqueues and other node related items consistent across cpu hotplug. But, ACPI tables are unreliable and failures with that boot time mapping have been reported on machines where the ACPI table and the physical information which is retrieved at actual hotplug is inconsistent. Revert the mapping implementation so it can be replaced with a less error prone approach. Signed-off-by: Dou Liyang <douly.fnst@cn.fujitsu.com> Tested-by: Xiaolong Ye <xiaolong.ye@intel.com> Cc: rjw@rjwysocki.net Cc: linux-acpi@vger.kernel.org Cc: guzheng1@huawei.com Cc: izumi.taku@jp.fujitsu.com Cc: lenb@kernel.org Link: http://lkml.kernel.org/r/1488528147-2279-2-git-send-email-douly.fnst@cn.fujitsu.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20openrisc: fix issue handling 8 byte get_user callsStafford Horne
[ Upstream commit 154e67cd8e8f964809d0e75e44bb121b169c75b3 ] Was getting the following error with allmodconfig: ERROR: "__get_user_bad" [lib/test_user_copy.ko] undefined! This was simply a missing break statement, causing an unwanted fall through. Signed-off-by: Stafford Horne <shorne@gmail.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20KVM: nVMX: do not warn when MSR bitmap address is not backedRadim Krčmář
[ Upstream commit 05d8d34611139f8435af90ac54b65eb31e82e388 ] Before trying to do nested_get_page() in nested_vmx_merge_msr_bitmap(), we have already checked that the MSR bitmap address is valid (4k aligned and within physical limits). SDM doesn't specify what happens if the there is no memory mapped at the valid address, but Intel CPUs treat the situation as if the bitmap was configured to trap all MSRs. KVM already does that by returning false and a correct handling doesn't need the guest-trigerrable warning that was reported by syzkaller: (The warning was originally there to catch some possible bugs in nVMX.) ------------[ cut here ]------------ WARNING: CPU: 0 PID: 7832 at arch/x86/kvm/vmx.c:9709 nested_vmx_merge_msr_bitmap arch/x86/kvm/vmx.c:9709 [inline] WARNING: CPU: 0 PID: 7832 at arch/x86/kvm/vmx.c:9709 nested_get_vmcs12_pages+0xfb6/0x15c0 arch/x86/kvm/vmx.c:9640 Kernel panic - not syncing: panic_on_warn set ... CPU: 0 PID: 7832 Comm: syz-executor1 Not tainted 4.10.0+ #229 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:15 [inline] dump_stack+0x2ee/0x3ef lib/dump_stack.c:51 panic+0x1fb/0x412 kernel/panic.c:179 __warn+0x1c4/0x1e0 kernel/panic.c:540 warn_slowpath_null+0x2c/0x40 kernel/panic.c:583 nested_vmx_merge_msr_bitmap arch/x86/kvm/vmx.c:9709 [inline] nested_get_vmcs12_pages+0xfb6/0x15c0 arch/x86/kvm/vmx.c:9640 enter_vmx_non_root_mode arch/x86/kvm/vmx.c:10471 [inline] nested_vmx_run+0x6186/0xaab0 arch/x86/kvm/vmx.c:10561 handle_vmlaunch+0x1a/0x20 arch/x86/kvm/vmx.c:7312 vmx_handle_exit+0xfc0/0x3f00 arch/x86/kvm/vmx.c:8526 vcpu_enter_guest arch/x86/kvm/x86.c:6982 [inline] vcpu_run arch/x86/kvm/x86.c:7044 [inline] kvm_arch_vcpu_ioctl_run+0x1418/0x4840 arch/x86/kvm/x86.c:7205 kvm_vcpu_ioctl+0x673/0x1120 arch/x86/kvm/../../../virt/kvm/kvm_main.c:2570 Reported-by: Dmitry Vyukov <dvyukov@google.com> Reviewed-by: Jim Mattson <jmattson@google.com> [Jim Mattson explained the bare metal behavior: "I believe this behavior would be documented in the chipset data sheet rather than the SDM, since the chipset returns all 1s for an unclaimed read."] Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20crypto: salsa20 - fix blkcipher_walk API usageEric Biggers
commit ecaaab5649781c5a0effdaf298a925063020500e upstream. When asked to encrypt or decrypt 0 bytes, both the generic and x86 implementations of Salsa20 crash in blkcipher_walk_done(), either when doing 'kfree(walk->buffer)' or 'free_page((unsigned long)walk->page)', because walk->buffer and walk->page have not been initialized. The bug is that Salsa20 is calling blkcipher_walk_done() even when nothing is in 'walk.nbytes'. But blkcipher_walk_done() is only meant to be called when a nonzero number of bytes have been provided. The broken code is part of an optimization that tries to make only one call to salsa20_encrypt_bytes() to process inputs that are not evenly divisible by 64 bytes. To fix the bug, just remove this "optimization" and use the blkcipher_walk API the same way all the other users do. Reproducer: #include <linux/if_alg.h> #include <sys/socket.h> #include <unistd.h> int main() { int algfd, reqfd; struct sockaddr_alg addr = { .salg_type = "skcipher", .salg_name = "salsa20", }; char key[16] = { 0 }; algfd = socket(AF_ALG, SOCK_SEQPACKET, 0); bind(algfd, (void *)&addr, sizeof(addr)); reqfd = accept(algfd, 0, 0); setsockopt(algfd, SOL_ALG, ALG_SET_KEY, key, sizeof(key)); read(reqfd, key, sizeof(key)); } Reported-by: syzbot <syzkaller@googlegroups.com> Fixes: eb6f13eb9f81 ("[CRYPTO] salsa20_generic: Fix multi-page processing") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-16powerpc/64: Fix checksum folding in csum_tcpudp_nofold and ip_fast_csum_nofoldPaul Mackerras
commit b492f7e4e07a28e706db26cf4943bb0911435426 upstream. These functions compute an IP checksum by computing a 64-bit sum and folding it to 32 bits (the "nofold" in their names refers to folding down to 16 bits). However, doing (u32) (s + (s >> 32)) is not sufficient to fold a 64-bit sum to 32 bits correctly. The addition can produce a carry out from bit 31, which needs to be added in to the sum to produce the correct result. To fix this, we copy the from64to32() function from lib/checksum.c and use that. Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-16s390: always save and restore all registers on context switchHeiko Carstens
commit fbbd7f1a51965b50dd12924841da0d478f3da71b upstream. The switch_to() macro has an optimization to avoid saving and restoring register contents that aren't needed for kernel threads. There is however the possibility that a kernel thread execve's a user space program. In such a case the execve'd process can partially see the contents of the previous process, which shouldn't be allowed. To avoid this, simply always save and restore register contents on context switch. Fixes: fdb6d070effba ("switch_to: dont restore/save access & fpu regs for kernel threads") Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14sparc64/mm: set fields in deferred pagesPavel Tatashin
[ Upstream commit 2a20aa171071a334d80c4e5d5af719d8374702fc ] Without deferred struct page feature (CONFIG_DEFERRED_STRUCT_PAGE_INIT), flags and other fields in "struct page"es are never changed prior to first initializing struct pages by going through __init_single_page(). With deferred struct page feature enabled there is a case where we set some fields prior to initializing: mem_init() { register_page_bootmem_info(); free_all_bootmem(); ... } When register_page_bootmem_info() is called only non-deferred struct pages are initialized. But, this function goes through some reserved pages which might be part of the deferred, and thus are not yet initialized. mem_init register_page_bootmem_info register_page_bootmem_info_node get_page_bootmem .. setting fields here .. such as: page->freelist = (void *)type; free_all_bootmem() free_low_memory_core_early() for_each_reserved_mem_region() reserve_bootmem_region() init_reserved_page() <- Only if this is deferred reserved page __init_single_pfn() __init_single_page() memset(0) <-- Loose the set fields here We end up with similar issue as in the previous patch, where currently we do not observe problem as memory is zeroed. But, if flag asserts are changed we can start hitting issues. Also, because in this patch series we will stop zeroing struct page memory during allocation, we must make sure that struct pages are properly initialized prior to using them. The deferred-reserved pages are initialized in free_all_bootmem(). Therefore, the fix is to switch the above calls. Link: http://lkml.kernel.org/r/20171013173214.27300-4-pasha.tatashin@oracle.com Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Reviewed-by: Steven Sistare <steven.sistare@oracle.com> Reviewed-by: Daniel Jordan <daniel.m.jordan@oracle.com> Reviewed-by: Bob Picco <bob.picco@oracle.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Alexander Potapenko <glider@google.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Michal Hocko <mhocko@kernel.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14powerpc/powernv/ioda2: Gracefully fail if too many TCE levels requestedAlexey Kardashevskiy
[ Upstream commit 7aafac11e308d37ed3c509829bb43d80c1811ac3 ] The IODA2 specification says that a 64 DMA address cannot use top 4 bits (3 are reserved and one is a "TVE select"); bottom page_shift bits cannot be used for multilevel table addressing either. The existing IODA2 table allocation code aligns the minimum TCE table size to PAGE_SIZE so in the case of 64K system pages and 4K IOMMU pages, we have 64-4-12=48 bits. Since 64K page stores 8192 TCEs, i.e. needs 13 bits, the maximum number of levels is 48/13 = 3 so we physically cannot address more and EEH happens on DMA accesses. This adds a check that too many levels were requested. It is still possible to have 5 levels in the case of 4K system page size. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> Acked-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14axonram: Fix gendisk handlingJan Kara
[ Upstream commit 672a2c87c83649fb0167202342ce85af9a3b4f1c ] It is invalid to call del_gendisk() when disk->queue is NULL. Fix error handling in axon_ram_probe() to avoid doing that. Also del_gendisk() does not drop a reference to gendisk allocated by alloc_disk(). That has to be done by put_disk(). Add that call where needed. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14arm64: KVM: Survive unknown traps from guestsMark Rutland
[ Upstream commit ba4dd156eabdca93501d92a980ba27fa5f4bbd27 ] Currently we BUG() if we see an ESR_EL2.EC value we don't recognise. As configurable disables/enables are added to the architecture (controlled by RES1/RES0 bits respectively), with associated synchronous exceptions, it may be possible for a guest to trigger exceptions with classes that we don't recognise. While we can't service these exceptions in a manner useful to the guest, we can avoid bringing down the host. Per ARM DDI 0487A.k_iss10775, page D7-1937, EC values within the range 0x00 - 0x2c are reserved for future use with synchronous exceptions, and EC values within the range 0x2d - 0x3f may be used for either synchronous or asynchronous exceptions. The patch makes KVM handle any unknown EC by injecting an UNDEFINED exception into the guest, with a corresponding (ratelimited) warning in the host dmesg. We could later improve on this with with a new (opt-in) exit to the host userspace. Cc: Dave Martin <dave.martin@arm.com> Cc: Suzuki K Poulose <suzuki.poulose@arm.com> Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14arm: KVM: Survive unknown traps from guestsMark Rutland
[ Upstream commit f050fe7a9164945dd1c28be05bf00e8cfb082ccf ] Currently we BUG() if we see a HSR.EC value we don't recognise. As configurable disables/enables are added to the architecture (controlled by RES1/RES0 bits respectively), with associated synchronous exceptions, it may be possible for a guest to trigger exceptions with classes that we don't recognise. While we can't service these exceptions in a manner useful to the guest, we can avoid bringing down the host. Per ARM DDI 0406C.c, all currently unallocated HSR EC encodings are reserved, and per ARM DDI 0487A.k_iss10775, page G6-4395, EC values within the range 0x00 - 0x2c are reserved for future use with synchronous exceptions, and EC values within the range 0x2d - 0x3f may be used for either synchronous or asynchronous exceptions. The patch makes KVM handle any unknown EC by injecting an UNDEFINED exception into the guest, with a corresponding (ratelimited) warning in the host dmesg. We could later improve on this with with a new (opt-in) exit to the host userspace. Cc: Dave Martin <dave.martin@arm.com> Cc: Suzuki K Poulose <suzuki.poulose@arm.com> Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14KVM: nVMX: reset nested_run_pending if the vCPU is going to be resetWanpeng Li
[ Upstream commit 2f707d97982286b307ef2a9b034e19aabc1abb56 ] Reported by syzkaller: WARNING: CPU: 1 PID: 27742 at arch/x86/kvm/vmx.c:11029 nested_vmx_vmexit+0x5c35/0x74d0 arch/x86/kvm/vmx.c:11029 CPU: 1 PID: 27742 Comm: a.out Not tainted 4.10.0+ #229 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:15 [inline] dump_stack+0x2ee/0x3ef lib/dump_stack.c:51 panic+0x1fb/0x412 kernel/panic.c:179 __warn+0x1c4/0x1e0 kernel/panic.c:540 warn_slowpath_null+0x2c/0x40 kernel/panic.c:583 nested_vmx_vmexit+0x5c35/0x74d0 arch/x86/kvm/vmx.c:11029 vmx_leave_nested arch/x86/kvm/vmx.c:11136 [inline] vmx_set_msr+0x1565/0x1910 arch/x86/kvm/vmx.c:3324 kvm_set_msr+0xd4/0x170 arch/x86/kvm/x86.c:1099 do_set_msr+0x11e/0x190 arch/x86/kvm/x86.c:1128 __msr_io arch/x86/kvm/x86.c:2577 [inline] msr_io+0x24b/0x450 arch/x86/kvm/x86.c:2614 kvm_arch_vcpu_ioctl+0x35b/0x46a0 arch/x86/kvm/x86.c:3497 kvm_vcpu_ioctl+0x232/0x1120 arch/x86/kvm/../../../virt/kvm/kvm_main.c:2721 vfs_ioctl fs/ioctl.c:43 [inline] do_vfs_ioctl+0x1bf/0x1790 fs/ioctl.c:683 SYSC_ioctl fs/ioctl.c:698 [inline] SyS_ioctl+0x8f/0xc0 fs/ioctl.c:689 entry_SYSCALL_64_fastpath+0x1f/0xc2 The syzkaller folks reported a nested_run_pending warning during userspace clear VMX capability which is exposed to L1 before. The warning gets thrown while doing (*(uint32_t*)0x20aecfe8 = (uint32_t)0x1); (*(uint32_t*)0x20aecfec = (uint32_t)0x0); (*(uint32_t*)0x20aecff0 = (uint32_t)0x3a); (*(uint32_t*)0x20aecff4 = (uint32_t)0x0); (*(uint64_t*)0x20aecff8 = (uint64_t)0x0); r[29] = syscall(__NR_ioctl, r[4], 0x4008ae89ul, 0x20aecfe8ul, 0, 0, 0, 0, 0, 0); i.e. KVM_SET_MSR ioctl with struct kvm_msrs { .nmsrs = 1, .pad = 0, .entries = { {.index = MSR_IA32_FEATURE_CONTROL, .reserved = 0, .data = 0} } } The VMLANCH/VMRESUME emulation should be stopped since the CPU is going to reset here. This patch resets the nested_run_pending since the CPU is going to be reset hence there should be nothing pending. Reported-by: Dmitry Vyukov <dvyukov@google.com> Suggested-by: Radim Krčmář <rkrcmar@redhat.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: David Hildenbrand <david@redhat.com> Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Reviewed-by: David Hildenbrand <david@redhat.com> Reviewed-by: Jim Mattson <jmattson@google.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14kvm: nVMX: VMCLEAR should not cause the vCPU to shut downJim Mattson
[ Upstream commit 587d7e72aedca91cee80c0a56811649c3efab765 ] VMCLEAR should silently ignore a failure to clear the launch state of the VMCS referenced by the operand. Signed-off-by: Jim Mattson <jmattson@google.com> [Changed "kvm_write_guest(vcpu->kvm" to "kvm_vcpu_write_guest(vcpu".] Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ARM: OMAP2+: Release device node after it is no longer needed.Guenter Roeck
[ Upstream commit b92675d998a9fa37fe9e0e35053a95b4a23c158b ] The device node returned by of_find_node_by_name() needs to be released after it is no longer needed to avoid a device node leak. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ARM: OMAP2+: Fix device node reference countsGuenter Roeck
[ Upstream commit 10e5778f54765c96fe0c8f104b7a030e5b35bc72 ] After commit 0549bde0fcb1 ("of: fix of_node leak caused in of_find_node_opts_by_path"), the following error may be reported when running omap images. OF: ERROR: Bad of_node_put() on /ocp@68000000 CPU: 0 PID: 0 Comm: swapper Not tainted 4.10.0-rc7-next-20170210 #1 Hardware name: Generic OMAP3-GP (Flattened Device Tree) [<c0310604>] (unwind_backtrace) from [<c030bbf4>] (show_stack+0x10/0x14) [<c030bbf4>] (show_stack) from [<c05add8c>] (dump_stack+0x98/0xac) [<c05add8c>] (dump_stack) from [<c05af1b0>] (kobject_release+0x48/0x7c) [<c05af1b0>] (kobject_release) from [<c0ad1aa4>] (of_find_node_by_name+0x74/0x94) [<c0ad1aa4>] (of_find_node_by_name) from [<c1215bd4>] (omap3xxx_hwmod_is_hs_ip_block_usable+0x24/0x2c) [<c1215bd4>] (omap3xxx_hwmod_is_hs_ip_block_usable) from [<c1215d5c>] (omap3xxx_hwmod_init+0x180/0x274) [<c1215d5c>] (omap3xxx_hwmod_init) from [<c120faa8>] (omap3_init_early+0xa0/0x11c) [<c120faa8>] (omap3_init_early) from [<c120fb2c>] (omap3430_init_early+0x8/0x30) [<c120fb2c>] (omap3430_init_early) from [<c1204710>] (setup_arch+0xc04/0xc34) [<c1204710>] (setup_arch) from [<c1200948>] (start_kernel+0x68/0x38c) [<c1200948>] (start_kernel) from [<8020807c>] (0x8020807c) of_find_node_by_name() drops the reference to the passed device node. The commit referenced above exposes this problem. To fix the problem, use of_get_child_by_name() instead of of_find_node_by_name(); of_get_child_by_name() does not drop the reference count of passed device nodes. While semantically different, we only look for immediate children of the passed device node, so of_get_child_by_name() is a more appropriate function to use anyway. Release the reference to the device node obtained with of_get_child_by_name() after it is no longer needed to avoid another device node leak. While at it, clean up the code and change the return type of omap3xxx_hwmod_is_hs_ip_block_usable() to bool to match its use and the return type of of_device_is_available(). Cc: Qi Hou <qi.hou@windriver.com> Cc: Peter Rosin <peda@axentia.se> Cc: Rob Herring <robh@kernel.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14powerpc/64: Fix checksum folding in csum_add()Shile Zhang
[ Upstream commit 6ad966d7303b70165228dba1ee8da1a05c10eefe ] Paul's patch to fix checksum folding, commit b492f7e4e07a ("powerpc/64: Fix checksum folding in csum_tcpudp_nofold and ip_fast_csum_nofold") missed a case in csum_add(). Fix it. Signed-off-by: Shile Zhang <shile.zhang@nokia.com> Acked-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14powerpc: Fix compiling a BE kernel with a powerpc64le toolchainNicholas Piggin
[ Upstream commit 4dc831aa88132f835cefe876aa0206977c4d7710 ] GCC can compile with either endian, but the default ABI version is set based on the default endianness of the toolchain. Alan Modra says: you need both -mbig and -mabi=elfv1 to make a powerpc64le gcc generate powerpc64 code The opposite is true for powerpc64 when generating -mlittle it requires -mabi=elfv2 to generate v2 ABI, which we were already doing. This change adds ABI annotations together with endianness for all cases, LE and BE. This fixes the case of building a BE kernel with a toolchain that is LE by default. Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Tested-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14powerpc/64: Invalidate process table caching after setting process tablePaul Mackerras
[ Upstream commit 7a70d7288c926ae88e0c773fbb506aa374e99c2d ] The POWER9 MMU reads and caches entries from the process table. When we kexec from one kernel to another, the second kernel sets its process table pointer but doesn't currently do anything to make the CPU invalidate any cached entries from the old process table. This adds a tlbie (TLB invalidate entry) instruction with parameters to invalidate caching of the process table after the new process table is installed. Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14x86/hpet: Prevent might sleep splat on resumeThomas Gleixner
[ Upstream commit bb1a2c26165640ba2cbcfe06c81e9f9d6db4e643 ] Sergey reported a might sleep warning triggered from the hpet resume path. It's caused by the call to disable_irq() from interrupt disabled context. The problem with the low level resume code is that it is not accounted as a special system_state like we do during the boot process. Calling the same code during system boot would not trigger the warning. That's inconsistent at best. In this particular case it's trivial to replace the disable_irq() with disable_hardirq() because this particular code path is solely used from system resume and the involved hpet interrupts can never be force threaded. Reported-and-tested-by: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1703012108460.3684@nanos Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14x86/platform/uv/BAU: Fix HUB errors by remove initial write to sw-ack registerAndrew Banman
[ Upstream commit 1b17c6df852851b40c3c27c66b8fa2fd99cf25d8 ] Writing to the software acknowledge clear register when there are no pending messages causes a HUB error to assert. The original intent of this write was to clear the pending bits before start of operation, but this is an incorrect method and has been determined to be unnecessary. Signed-off-by: Andrew Banman <abanman@hpe.com> Acked-by: Mike Travis <mike.travis@hpe.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: akpm@linux-foundation.org Cc: rja@hpe.com Cc: sivanich@hpe.com Link: http://lkml.kernel.org/r/1487351269-181133-1-git-send-email-abanman@hpe.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ARM: OMAP2+: gpmc-onenand: propagate error on initialization failureLadislav Michl
[ Upstream commit 7807e086a2d1f69cc1a57958cac04fea79fc2112 ] gpmc_probe_onenand_child returns success even on gpmc_onenand_init failure. Fix that. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ARM: 8657/1: uaccess: consistently check object sizesKees Cook
[ Upstream commit 32b143637e8180f5d5cea54320c769210dea4f19 ] In commit 76624175dcae ("arm64: uaccess: consistently check object sizes"), the object size checks are moved outside the access_ok() so that bad destinations are detected before hitting the "memset(dest, 0, size)" in the copy_from_user() failure path. This makes the same change for arm, with attention given to possibly extracting the uaccess routines into a common header file for all architectures in the future. Suggested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ARM: avoid faulting on qemuRussell King
commit 3aaf33bebda8d4ffcc0fc8ef39e6c1ac68823b11 upstream. When qemu starts a kernel in a bare environment, the default SCR has the AW and FW bits clear, which means that the kernel can't modify the PSR A or PSR F bits, and means that FIQs and imprecise aborts are always masked. When running uboot under qemu, the AW and FW SCR bits are set, and the kernel functions normally - and this is how real hardware behaves. Fix this for qemu by ignoring the FIQ bit. Fixes: 8bafae202c82 ("ARM: BUG if jumping to usermode address in kernel mode") Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Cc: Alex Shi <alex.shi@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ARM: BUG if jumping to usermode address in kernel modeRussell King
commit 8bafae202c82dc257f649ea3c275a0f35ee15113 upstream. Detect if we are returning to usermode via the normal kernel exit paths but the saved PSR value indicates that we are in kernel mode. This could occur due to corrupted stack state, which has been observed with "ftracetest". This ensures that we catch the problem case before we get to user code. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Cc: Alex Shi <alex.shi@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14arm64: fpsimd: Prevent registers leaking from dead tasksDave Martin
commit 071b6d4a5d343046f253a5a8835d477d93992002 upstream. Currently, loading of a task's fpsimd state into the CPU registers is skipped if that task's state is already present in the registers of that CPU. However, the code relies on the struct fpsimd_state * (and by extension struct task_struct *) to unambiguously identify a task. There is a particular case in which this doesn't work reliably: when a task exits, its task_struct may be recycled to describe a new task. Consider the following scenario: 1) Task P loads its fpsimd state onto cpu C. per_cpu(fpsimd_last_state, C) := P; P->thread.fpsimd_state.cpu := C; 2) Task X is scheduled onto C and loads its fpsimd state on C. per_cpu(fpsimd_last_state, C) := X; X->thread.fpsimd_state.cpu := C; 3) X exits, causing X's task_struct to be freed. 4) P forks a new child T, which obtains X's recycled task_struct. T == X. T->thread.fpsimd_state.cpu == C (inherited from P). 5) T is scheduled on C. T's fpsimd state is not loaded, because per_cpu(fpsimd_last_state, C) == T (== X) && T->thread.fpsimd_state.cpu == C. (This is the check performed by fpsimd_thread_switch().) So, T gets X's registers because the last registers loaded onto C were those of X, in (2). This patch fixes the problem by ensuring that the sched-in check fails in (5): fpsimd_flush_task_state(T) is called when T is forked, so that T->thread.fpsimd_state.cpu == C cannot be true. This relies on the fact that T is not schedulable until after copy_thread() completes. Once T's fpsimd state has been loaded on some CPU C there may still be other cpus D for which per_cpu(fpsimd_last_state, D) == &X->thread.fpsimd_state. But D is necessarily != C in this case, and the check in (5) must fail. An alternative fix would be to do refcounting on task_struct. This would result in each CPU holding a reference to the last task whose fpsimd state was loaded there. It's not clear whether this is preferable, and it involves higher overhead than the fix proposed in this patch. It would also move all the task_struct freeing work into the context switch critical section, or otherwise some deferred cleanup mechanism would need to be introduced, neither of which seems obviously justified. Fixes: 005f78cd8849 ("arm64: defer reloading a task's FPSIMD state to userland resume") Signed-off-by: Dave Martin <Dave.Martin@arm.com> Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> [will: word-smithed the comment so it makes more sense] Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14KVM: VMX: remove I/O port 0x80 bypass on Intel hostsAndrew Honig
commit d59d51f088014f25c2562de59b9abff4f42a7468 upstream. This fixes CVE-2017-1000407. KVM allows guests to directly access I/O port 0x80 on Intel hosts. If the guest floods this port with writes it generates exceptions and instability in the host kernel, leading to a crash. With this change guest writes to port 0x80 on Intel will behave the same as they currently behave on AMD systems. Prevent the flooding by removing the code that sets port 0x80 as a passthrough port. This is essentially the same as upstream patch 99f85a28a78e96d28907fe036e1671a218fee597, except that patch was for AMD chipsets and this patch is for Intel. Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Jim Mattson <jmattson@google.com> Fixes: fdef3ad1b386 ("KVM: VMX: Enable io bitmaps to avoid IO port 0x80 VMEXITs") Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14arm: KVM: Fix VTTBR_BADDR_MASK BUG_ON off-by-oneMarc Zyngier
commit 5553b142be11e794ebc0805950b2e8313f93d718 upstream. VTTBR_BADDR_MASK is used to sanity check the size and alignment of the VTTBR address. It seems to currently be off by one, thereby only allowing up to 39-bit addresses (instead of 40-bit) and also insufficiently checking the alignment. This patch fixes it. This patch is the 32bit pendent of Kristina's arm64 fix, and she deserves the actual kudos for pinpointing that one. Fixes: f7ed45be3ba52 ("KVM: ARM: World-switch implementation") Reported-by: Kristina Martsenko <kristina.martsenko@arm.com> Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14arm64: KVM: fix VTTBR_BADDR_MASK BUG_ON off-by-oneKristina Martsenko
commit 26aa7b3b1c0fb3f1a6176a0c1847204ef4355693 upstream. VTTBR_BADDR_MASK is used to sanity check the size and alignment of the VTTBR address. It seems to currently be off by one, thereby only allowing up to 47-bit addresses (instead of 48-bit) and also insufficiently checking the alignment. This patch fixes it. As an example, with 4k pages, before this patch we have: PHYS_MASK_SHIFT = 48 VTTBR_X = 37 - 24 = 13 VTTBR_BADDR_SHIFT = 13 - 1 = 12 VTTBR_BADDR_MASK = ((1 << 35) - 1) << 12 = 0x00007ffffffff000 Which is wrong, because the mask doesn't allow bit 47 of the VTTBR address to be set, and only requires the address to be 12-bit (4k) aligned, while it actually needs to be 13-bit (8k) aligned because we concatenate two 4k tables. With this patch, the mask becomes 0x0000ffffffffe000, which is what we want. Fixes: 0369f6a34b9f ("arm64: KVM: EL2 register definitions") Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com> Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Kristina Martsenko <kristina.martsenko@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14powerpc/64s: Initialize ISAv3 MMU registers before setting partition tableNicholas Piggin
commit 371b80447ff33ddac392c189cf884a5a3e18faeb upstream. kexec can leave MMU registers set when booting into a new kernel, the PIDR (Process Identification Register) in particular. The boot sequence does not zero PIDR, so it only gets set when CPUs first switch to a userspace processes (until then it's running a kernel thread with effective PID = 0). This leaves a window where a process table entry and page tables are set up due to user processes running on other CPUs, that happen to match with a stale PID. The CPU with that PID may cause speculative accesses that address quadrant 0 (aka userspace addresses), which will result in cached translations and PWC (Page Walk Cache) for that process, on a CPU which is not in the mm_cpumask and so they will not be invalidated properly. The most common result is the kernel hanging in infinite page fault loops soon after kexec (usually in schedule_tail, which is usually the first non-speculative quadrant 0 access to a new PID) due to a stale PWC. However being a stale translation error, it could result in anything up to security and data corruption problems. Fix this by zeroing out PIDR at boot and kexec. Fixes: 7e381c0ff618 ("powerpc/mm/radix: Add mmu context handling callback for radix") Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14KVM: s390: Fix skey emulation permission checkJanosch Frank
commit ca76ec9ca871e67d8cd0b6caba24aca3d3ac4546 upstream. All skey functions call skey_check_enable at their start, which checks if we are in the PSTATE and injects a privileged operation exception if we are. Unfortunately they continue processing afterwards and perform the operation anyhow as skey_check_enable does not deliver an error if the exception injection was successful. Let's move the PSTATE check into the skey functions and exit them on such an occasion, also we now do not enable skey handling anymore in such a case. Signed-off-by: Janosch Frank <frankja@linux.vnet.ibm.com> Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com> Fixes: a7e19ab ("KVM: s390: handle missing storage-key facility") Reviewed-by: Cornelia Huck <cohuck@redhat.com> Reviewed-by: Thomas Huth <thuth@redhat.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14s390: fix compat system call tableHeiko Carstens
commit e779498df587dd2189b30fe5b9245aefab870eb8 upstream. When wiring up the socket system calls the compat entries were incorrectly set. Not all of them point to the corresponding compat wrapper functions, which clear the upper 33 bits of user space pointers, like it is required. Fixes: 977108f89c989 ("s390: wire up separate socketcalls system calls") Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
