path: root/arch
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68k: Revive reporting of spurious interrupts m68knommu: Move forward declaration of do_IRQ() from machdep.h to irq.h m68k: fix some atomic operation asm address modes for ColdFire m68k: use CPU_HAS_NO_BITFIELDS for signal functions m68k: merge and clean up delay.h files m68knommu: correctly use trap_init m68knommu: merge ColdFire 5206 and 5206e platform code m68k: merge mmu and non-mmu bitops.h m68k: merge MMU and non MMU versions of system.h m68k: merge MMU and non-MMU versions of asm/hardirq.h m68k: merge the non-mmu and mmu versions of module.c m68knommu: Fix printk() format in free_initrd_mem() m68knommu: Make empty_zero_page "void *", like on m68k
2011-07-25Merge branch 'for-3.1' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.1' of git://linux-nfs.org/~bfields/linux: nfsd: don't break lease on CLAIM_DELEGATE_CUR locks: rename lock-manager ops nfsd4: update nfsv4.1 implementation notes nfsd: turn on reply cache for NFSv4 nfsd4: call nfsd4_release_compoundargs from pc_release nfsd41: Deny new lock before RECLAIM_COMPLETE done fs: locks: remove init_once nfsd41: check the size of request nfsd41: error out when client sets maxreq_sz or maxresp_sz too small nfsd4: fix file leak on open_downgrade nfsd4: remember to put RW access on stateid destruction NFSD: Added TEST_STATEID operation NFSD: added FREE_STATEID operation svcrpc: fix list-corrupting race on nfsd shutdown rpc: allow autoloading of gss mechanisms svcauth_unix.c: quiet sparse noise svcsock.c: include sunrpc.h to quiet sparse noise nfsd: Remove deprecated nfsctl system call and related code. NFSD: allow OP_DESTROY_CLIENTID to be only op in COMPOUND Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25mach-ux500: add lm3530 ALS platform data for U5500Linus Walleij
From: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com> platform data for simple backlight driver for LM3530 in the u5500 platform Signed-off-by: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Lee Jones <lee.jones@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25notifiers: sys: move reboot notifiers into reboot.hAmerigo Wang
It is not necessary to share the same notifier.h. This patch already moves register_reboot_notifier() and unregister_reboot_notifier() from kernel/notifier.c to kernel/sys.c. [amwang@redhat.com: make allyesconfig succeed on ppc64] Signed-off-by: WANG Cong <amwang@redhat.com> Cc: David Miller <davem@davemloft.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Greg KH <greg@kroah.com> Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: remove dead codeRichard Weinberger
GCC 4.6's -Wunused-but-set-variable found some dead code. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: adjust size of pid_bufRichard Weinberger
Linux can have pids up to 4*1024*1024. To handle such huge numbers pid_buf needs to be larger. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: implement a x86_64 vDSORichard Weinberger
Until now UML had no x86_64 vDSO. So glibc always used the vsyscall page for gettimeday() and friends. Calls to gettimeday() returned falsely the host time and confused some programs. This patch adds a vDSO which turns all __vdso_* calls into a system call so that UML can trap them. As glibc still uses the vsyscall page for static binaries this patch improves the situation only for dynamic binaries. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: set __HAVE_ARCH_GATE_AREA for x86_64Richard Weinberger
Implement arch_vma_name() and make get_gate_vma(), in_gate_area() and in_gate_area_no_mm() a nop. We need arch_vma_name() to support vDSO. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: Set __HAVE_ARCH_GATE_AREA for i386Richard Weinberger
When UML is unable to reuse the host's vDSO FIXADDR_USER_START is zero. To handle this special case correclty we have to implement custom gate area helper methods. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: disable scan_elf_aux() on x86_64Richard Weinberger
Reusing the host's vDSO makes only sense on x86_32. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25uml: free resourcesDavidlohr Bueso
When creating the temp file there's a memory and file descriptor leak upon error. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Richard Weinberger <richard@nod.at> Reviewed-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25uml: drivers/slip_user.c memory leak fixVitaliy Ivanov
Do not free memory when you failed to allocate it. Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25uml: helper.c warning correctionsVitaliy Ivanov
Fix this warning: arch/um/os-Linux/helper.c: In function `helper_child': arch/um/os-Linux/helper.c:38:7: warning: ignoring return value of `write', declared with attribute warn_unused_result [richard@nod.at: happens only with -D_FORTIFY_SOURCE=2] Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25uml: cow_user.c warning correctionsVitaliy Ivanov
Fix this warning: arch/um/drivers/cow_user.c: In function `absolutize': arch/um/drivers/cow_user.c:189:7: warning: ignoring return value of `chdir', declared with attribute warn_unused_result [richard@nod.at: happens only with -D_FORTIFY_SOURCE=2] Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25uml: drivers/net_user.c memory leak fixVitaliy Ivanov
Perform memory cleanup on exit. On receiving invalid 'pid' we still should clean 'output' variable. Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: reinstate kernel version in generated .configGeert Uytterhoeven
Commit 0954828fcbf3 ("kconfig: replace KERNELVERSION usage by the mainmenu's prompt") made the kernel version disappear from the generated .config file when configuring for UML. As UML's Kconfig doesn't have a mainmenu, kconfig falls back to the default string "Linux Kernel Configuration". Add a suitable mainmenu to the main UML Kconfig file to fix this. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: add netpoll supportRichard Weinberger
To make netconsole usable on UML, its ethernet driver needs netpoll support. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: fix _FORTIFY_SOURCE=2 support for kernel modulesRichard Weinberger
When UML is compiled with _FORTIFY_SOURCE we have to export all _chk() functions which are used in modules. For now it's only the case for __sprintf_chk(). Tested-by: Florian Fainelli <florian@openwrt.org> Reported-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Richard Weinberger <richard@nod.at> Acked-by: Vitaliy Ivanov <vitalivanov@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: clean up delay functionsRichard Weinberger
Both sys-i386 and sys-x86_64 support now ndelay(). The delay functions are based on arch/x86/lib/delay.c. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so this set_fs(USER_DS) is redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: clean up vm-flags.hRichard Weinberger
There is no need to define VM_{STACK,DATA}_DEFAULT_FLAGS as variable. It's also useless to test for TIF_IA32 as 64bit UML has no IA32 emulation. Signed-off-by: Richard Weinberger <richard@nod.at> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25cris, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so those calls to set_fs(USER_DS) are redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25cris: fix some build warnings in pinmux.cWANG Cong
Fix some harmless warnings such as arch/cris/arch-v32/mach-a3/pinmux.c:273: warning: ISO C90 forbids mixed declarations and code: Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25m68k, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so those calls to set_fs(USER_DS) are redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25m32r, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so this set_fs(USER_DS) is redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25alpha, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so this set_fs(USER_DS) is redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25h8300, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so those calls to set_fs(USER_DS) are redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25sparc64: implement get_user_pages_fast()David S. Miller
Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25sparc64: add support for _PAGE_SPECIALDavid S. Miller
Luckily there are still a few software PTE bits remaining and they even match up in both the sun4u and sun4v pte layouts. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25sparc64: use RCU page table freeingDavid S. Miller
Make use of the generic RCU page table freeing on Sparc64, doing so allows for race-free software page-table walkers like gup_fast(). Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25sparc64: kill page table quicklistsDavid S. Miller
With the recent mmu_gather changes that included generic RCU freeing of page-tables, it is now quite straightforward to implement gup_fast() on sparc64. This patch: Remove the page table quicklists. They are pointless and make it harder to use RCU page table freeing and share code with other architectures. BTW, this is the second time this has happened, see commit 3c936465249f ("[SPARC64]: Kill pgtable quicklists and use SLAB.") Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25xtensa: fix a build error in arch/xtensa/include/asm/uaccess.hWANG Cong
Fix the following build error: arch/xtensa/include/asm/uaccess.h:403: error: implicit declaration of function 'prefetch' arch/xtensa/include/asm/uaccess.h:412: error: implicit declaration of function 'prefetchw' Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25xtensa: prevent arbitrary read in ptraceDan Rosenberg
Prevent an arbitrary kernel read. Check the user pointer with access_ok() before copying data in. [akpm@linux-foundation.org: s/EIO/EFAULT/] Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: Christian Zankel <chris@zankel.net> Cc: Oleg Nesterov <oleg@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fs: take the ACL checks to common code bury posix_acl_..._masq() variants kill boilerplates around posix_acl_create_masq() generic_acl: no need to clone acl just to push it to set_cached_acl() kill boilerplate around posix_acl_chmod_masq() reiserfs: cache negative ACLs for v1 stat format xfs: cache negative ACLs if there is no attribute fork 9p: do no return 0 from ->check_acl without actually checking vfs: move ACL cache lookup into generic code CIFS: Fix oops while mounting with prefixpath xfs: Fix wrong return value of xfs_file_aio_write fix devtmpfs race caam: don't pass bogus S_IFCHR to debugfs_create_...() get rid of create_proc_entry() abuses - proc_mkdir() is there for purpose asus-wmi: ->is_visible() can't return negative fix jffs2 ACLs on big-endian with 16bit mode_t 9p: close ACL leaks ocfs2_init_acl(): fix a leak VFS : mount lock scalability for internal mounts
2011-07-25Merge branch 'next/deletion' of ↵Linus Torvalds
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/deletion' of git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: mach-loki: delete ARM: mach-s3c2400: delete ARM: mach-s3c24a0: delete
2011-07-25Merge branch 'next/cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (133 commits) ARM: EXYNOS4: Change devname for FIMD clkdev ARM: S3C64XX: Cleanup mach/regs-fb.h from mach-s3c64xx ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210 ARM: S5PC100: Cleanup mach/regs-fb.h from mach-s5pc100 ARM: S3C24XX: Use generic s3c_set_platdata for devices ARM: S3C64XX: Use generic s3c_set_platdata for OneNAND ARM: SAMSUNG: Use generic s3c_set_platdata for NAND ARM: SAMSUNG: Use generic s3c_set_platdata for USB OHCI ARM: SAMSUNG: Use generic s3c_set_platdata for HWMON ARM: SAMSUNG: Use generic s3c_set_platdata for FB ARM: SAMSUNG: Use generic s3c_set_platdata for TS ARM: S3C64XX: Add PWM backlight support on SMDK6410 ARM: S5P64X0: Add PWM backlight support on SMDK6450 ARM: S5P64X0: Add PWM backlight support on SMDK6440 ARM: S5PC100: Add PWM backlight support on SMDKC100 ARM: S5PV210: Add PWM backlight support on SMDKV210 ARM: EXYNOS4: Add PWM backlight support on SMDKC210 ARM: EXYNOS4: Add PWM backlight support on SMDKV310 ARM: SAMSUNG: Create a common infrastructure for PWM backlight support clocksource: convert 32-bit down counting clocksource on S5PV210/S5P64X0 ... Fix up trivial conflict in arch/arm/mach-imx/mach-scb9328.c
2011-07-25Merge branch 'next/fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (35 commits) ARM: msm: platsmp: determine number of CPU cores at boot time ARM: Tegra: Seaboard: Fix I2C bus numbering for ADT7461 ARM: Tegra: Trimslice: Tri-state DAP3 pinmux ARM: orion5x: fixup 5181 MPP mask check ARM: mxs-dma: include <linux/dmaengine.h> ARM: i.MX53: consistently use MX53_UART_PAD_CTRL for uart txd/rxd/rts/cts ARM: i.MX53: UARTn_CTS pin should not change RTS input select ARM: i.MX53: UARTn_TXD pin should not change RXD input select ARM: mx25: Fix typo on CAN1_RX pad setting iomux-mx53: add missing 'IOMUX_CONFIG_SION' for some I2C pad definitions ARM: NUC93X: add UL suffix to VMALLOC_END to ensure it is properly typed ARM: LPC32XXX: add UL suffix to VMALLOC_END to ensure it is properly typed ARM: CNS3XXX: add UL suffix to VMALLOC_END to ensure it is properly typed ARM: i.MX53: Fix IOMUX type o's ARM i.MX dma: Fix burstsize settings mach-mx5: fix the I2C clock parents ARM: mxs/tx28: according to the TX28's datasheet D4-D7 are not used for MMC0 ARM i.MX23/28: platform-mxsfb: Add missing include of linux/dma-mapping.h ARM: mx53: Fix some interrupts marked as reserved. MXC: iomux-v3: correct NO_PAD_CTRL definition ... Fix up trivial conflict in arch/arm/mach-imx/mach-mx31_3ds.c
2011-07-25Merge branch 'tegra/fixes' of ↵Arnd Bergmann
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc into next/fixes
2011-07-24Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] s5pv210: make needlessly global symbols static [CPUFREQ] exynos4210: make needlessly global symbols static [CPUFREQ] S3C6410: Add some lower frequencies for 800MHz base clock operation [CPUFREQ] S5PV210: Add reboot notifier to prevent system hang [CPUFREQ] S5PV210: Adjust udelay prior to voltage scaling down [CPUFREQ] S5PV210: Lock a mutex while changing the cpu frequency [CPUFREQ] S5PV210: Add pm_notifier to prevent system unstable [CPUFREQ] S5PV210: Add arm/int voltage control support [CPUFREQ] S5PV210: Add additional symantics for "relation" in cpufreq with pm [CPUFREQ] S3C64xx: Notify transition complete as soon as frequency changed [CPUFREQ] S3C6410: Support 800MHz operation in cpufreq [CPUFREQ] s5pv210-cpufreq.c: Add missing clk_put [CPUFREQ] Move compile for S3C64XX cpufreq to /drivers/cpufreq [CPUFREQ] Remove some vi noise that escaped into the Makefile. [CPUFREQ] Move ARM Samsung cpufreq drivers to drivers/cpufreq/ [CPUFREQ/S3C64xx] Move S3C64xx CPUfreq driver into drivers/cpufreq [CPUFREQ] Handle CPUs with different capabilities in acpi-cpufreq
2011-07-25m68k: Revive reporting of spurious interruptsGeert Uytterhoeven
commit 2502b667ea835ee16685c74b2a0d89ba8afe117a ("Change the m68knommu irq handling to use the generic irq framework.") removed the reporting of spurious interrupts on nommu (68328 and 68360). Bring it back in a generic way, using "atomic_t irq_err_count", as that's what most of the other architectures are using. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68knommu: Move forward declaration of do_IRQ() from machdep.h to irq.hGeert Uytterhoeven
It is not machine-specific, but common irq infrastructure. Also add the missing asmlinkage, to match its definition. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68k: fix some atomic operation asm address modes for ColdFireGreg Ungerer
The ColdFire processors have a much more limited set of addressing modes that can be used for most instructions. A number of the atomic operations have already been fixed to limit the addressing modes used with add and sub instructions when building for ColdFire. But we missed a few. Fix the remaining atomic operations to be clean for ColdFire processors. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68k: use CPU_HAS_NO_BITFIELDS for signal functionsGreg Ungerer
When reworking bitops.h to be clean for all processor types we introduced a CONFIG_CPU_HAS_NO_BITFIELDS define to signal whether this processor type supported the bit field instructions. The ARCH_SIG_BITOPS functions for m68k use these instruction types. We should base the use of these functions (or the generic versions) on the CONFIG_CPU_HAS_NO_BITFIELDS define. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68k: merge and clean up delay.h filesGreg Ungerer
The real difference between the mmu and non-mmu varients of the delay.h files has nothing to do with having an mmu or not. It is processor family differences that means slightly different code. Merge the delay_mm.h and delay_no.h files back into a single file. The primarly difference we need to deal with is whether the processor supports a 32bit * 32bit -> 64bit multiply. Without it we need to do some shift scaling as well as use a 32bit * 32bit -> 32bit multiply. If building for a multi-CPU type kernel then we must use the simpler mult/shift scaling. This version of delay code allows the CPU32 family to use a 64bit mul, since it supports this instruction, the old code did not. The changes use macros where appropriate to try and optimize constant sized udelay times. And it removes the use of a fixed lib function for the non-mmu case. Code size on typical kernel configurations is similar, or only larger by a few tens of bytes. Also removed the unused muldiv() code from delay_mm.h. Build and run tested on ColdFire and ARAnyM. Build tested only on 68328 and 68360 (CPU32). Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68knommu: correctly use trap_initGreg Ungerer
Currently trap_init() is an empty function for m68knommu. Instead the vectors are being setup as part of the IRQ initialization. This is inconsistent with m68k and other architectures. Change the local init_vectors() to be trap_init(), and init the vectors at the correct time during startup. This will help merge of m68k and m68knommu trap code in the furture. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68knommu: merge ColdFire 5206 and 5206e platform codeGreg Ungerer
The ColdFire 5206 and 5206e CPU families are almost identical, we can easily merge the platform support code for them. All the differences are dealt with in the current include/asm/5206sim.h. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68k: merge mmu and non-mmu bitops.hGreg Ungerer
The following patch merges the mmu and non-mmu versions of the m68k bitops.h files. Now there is a good deal of difference between the two files, but none of it is actually an mmu specific difference. It is all about the specific m68k/coldfire varient we are targeting. So it makes an awful lot of sense to merge these into a single bitops.h. There is a number of ways I can see to factor this code. The approach I have taken here is to keep the various versions of each macro/function type together. This means that there is some ifdefery with each to handle each CPU type. I have added some comments in a couple of appropriate places to try and make it clear what the differences we are dealing with are. Specifically the instruction and addressing mode differences we have to deal with. The merged form keeps the same underlying optimizations for each CPU type for all the general bit clear/set/change and find bit operations. It does switch to using the generic le operations though, instead of any local varients. Build tested on ColdFire, 68328, 68360 (which is cpu32) and 68020+. Run tested on ColdFire and ARAnyM. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-07-25m68k: merge MMU and non MMU versions of system.hGreg Ungerer
The non-MMU m68k targets can use the same asm/system.h as the MMU targets. So switch the current system_mm.h to be system.h and remove system_no.h. The assembly support code for the non-MMU resume functions needs to be modified to match the now common switch_to() macro. Specifically this means correctly saving and restoring the status flags in the case of the ColdFire resume, and some reordering of the code to not use registers before they are saved or after they are restored. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
