path: root/arch
2011-03-22Merge branch 'for-paul' of git://gitorious.org/linux-omap-dss2/linuxPaul Mundt
Conflicts: arch/arm/mach-omap2/board-overo.c Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: FS: lookup_mnt() is only used in the core fs routines now bfs: fix bitmap size argument to find_first_zero_bit() fs: Use BUG_ON(!mnt) at dentry_open(). fs: devpts_pty_new() return -ENOMEM if dentry allocation failed nfs: lock() vs unlock() typo pstore: fix leaking ->i_private introduce sys_syncfs to sync a single file system Small typo fix... Filesystem: fifo: Fixed coding style issue. fs/inode: Fix kernel-doc format for inode_init_owner select: remove unused MAX_SELECT_SECONDS vfs: cleanup do_vfs_ioctl()
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6: [PARISC] Convert to new irq_chip functions [PARISC] fix per-cpu flag problem in the cpu affinity checkers [PARISC] fix vmap flush/invalidate eliminate special FLUSH flag from page table parisc: flush pages through tmpalias space
2011-03-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc: Add {open_by,name_to}_handle_at and clock_adjtime syscalls. sparc: Implement of_iomap(). sparc: Implement of_address_to_resource(). sparc: Provide NO_IRQ definition.
2011-03-21Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/ptrace: Remove BUG_ON when full register set not available powerpc: Factoring mpic cpu id fetching into a function powerpc: Make MPIC honor the "pic-no-reset" device tree property powerpc: Document the Open PIC device tree binding powerpc/pci: Fix crash in PCI code on ppc64 when matching device nodes
2011-03-21introduce sys_syncfs to sync a single file systemSage Weil
It is frequently useful to sync a single file system, instead of all mounted file systems via sync(2): - On machines with many mounts, it is not at all uncommon for some of them to hang (e.g. unresponsive NFS server). sync(2) will get stuck on those and may never get to the one you do care about (e.g., /). - Some applications write lots of data to the file system and then want to make sure it is flushed to disk. Calling fsync(2) on each file introduces unnecessary ordering constraints that result in a large amount of sub-optimal writeback/flush/commit behavior by the file system. There are currently two ways (that I know of) to sync a single super_block: - BLKFLSBUF ioctl on the block device: That also invalidates the bdev mapping, which isn't usually desirable, and doesn't work for non-block file systems. - 'mount -o remount,rw' will call sync_filesystem as an artifact of the current implemention. Relying on this little-known side effect for something like data safety sounds foolish. Both of these approaches require root privileges, which some applications do not have (nor should they need?) given that sync(2) is an unprivileged operation. This patch introduces a new system call syncfs(2) that takes an fd and syncs only the file system it references. Maybe someday we can $ sync /some/path and not get sync: ignoring all arguments The syscall is motivated by comments by Al and Christoph at the last LSF. syncfs(2) seems like an appropriate name given statfs(2). A similar ioctl was also proposed a while back, see http://marc.info/?l=linux-fsdevel&m=127970513829285&w=2 Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: asm-generic: support clock_adjtime() in <asm-generic/unistd.h> arch/tile: fix futex sanitization definition/prototype mismatch
2011-03-21powerpc/ptrace: Remove BUG_ON when full register set not availableMike Wolf
In some cases during a threaded core dump not all the threads will have a full register set. This happens when the signal causing the core dump races with a thread exiting. The race happens when the exiting thread has entered the kernel for the last time before the signal arrives, but doesn't get far enough through the exit code to avoid being included in the core dump. So we get a thread included in the core dump which is never going to go out to userspace again and only has a partial register set recorded Normally we would catch each thread as it is about to go into userspace and capture the full register set then. However, this exiting thread is never going to go out to userspace again, so we have no way to capture its full register set. It doesn't really matter, though, as this is a thread which is effectively already dead. So instead of hitting a BUG() in this case (a really bad choice of action in the first place), we use a poison value for the register values. [BenH]: Some cosmetic/stylistic changes and fix build on ppc32 Signed-off-by: Mike Wolf <mjw@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-21powerpc: Factoring mpic cpu id fetching into a functionMeador Inge
The following code snippet: unsigned int cpu = 0; if (mpic->flags & MPIC_PRIMARY) cpu = hard_smp_processor_id(); is seen in several places in the 'mpic.c' code. This changeset factors that pattern out into a helper function called 'mpic_processor_id'. Signed-off-by: Meador Inge <meador_inge@mentor.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-21powerpc: Make MPIC honor the "pic-no-reset" device tree propertyMeador Inge
This property, defined in the Open PIC binding, tells the kernel not to use the reset bit in the global configuration register. Additionally, its presence mandates that only sources which are actually used (i.e. appear in the device tree) should have their VECPRI bits initialized. Although, "pic-no-reset" can be used for the same use cases that "protected-sources" is covering, the "protected-sources" implementation was left completely intact. This is a more pragmatic approach as there are already several existing systems which use protected sources. If "pic-no-reset" *and* "protected-sources" are both used, however, then "pic-no-reset" takes precedence in terms of the init behavior and the sanity checks done by protected sources will still take place. Signed-off-by: Meador Inge <meador_inge@mentor.com> Cc: Hollis Blanchard <hollis_blanchard@mentor.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-21powerpc/pci: Fix crash in PCI code on ppc64 when matching device nodesBenjamin Herrenschmidt
Commit b5d937de0367d26f65b9af1aef5f2c34c1939be0 has a bug which causes basically a NULL dereference in the PCI code during boot on ppc64 machines. fetch_dev_dn() is called when dev->dev.of_node is NULL, so using that as the starting point for the search makes no sense. It should instead start from the device node of the PHB. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (64 commits) Input: tsc2005 - remove 'disable' sysfs attribute Input: tsc2005 - add open/close Input: tsc2005 - handle read errors from SPI layer Input: tsc2005 - do not rearm timer in hardirq handler Input: tsc2005 - don't use work for 'pen up' handling Input: tsc2005 - do not use 0 in place of NULL Input: tsc2005 - use true/false for boolean variables Input: tsc2005 - hide selftest attribute if we can't reset Input: tsc2005 - rework driver initialization code Input: tsc2005 - set up bus type in input device Input: tsc2005 - set up parent device Input: tsc2005 - clear driver data after unbinding Input: tsc2005 - add module description Input: tsc2005 - remove driver banner message Input: tsc2005 - remove incorrect module alias Input: tsc2005 - convert to using dev_pm_ops Input: tsc2005 - use spi_get/set_drvdata() Input: introduce tsc2005 driver Input: xen-kbdfront - move to drivers/input/misc Input: xen-kbdfront - add grant reference for shared page ...
2011-03-20arch/tile: fix futex sanitization definition/prototype mismatchChris Metcalf
Commit 8d7718aa082aaf30a0b4989e1f04858952f941bc changed "int" to "u32" in the prototypes but not the definition. I missed this when I saw the patch go by on LKML. We cast "u32 *" to "int *" since we are tying into the underlying atomics framework, and atomic_t uses int as its value type. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Reviewed-by: Michel Lespinasse <walken@google.com>
2011-03-18Merge branch 'next' into for-linusDmitry Torokhov
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (53 commits) mmc: dw_mmc: support mmc power control with regulator mmc: dw_mmc: fix suspend/resume operation mmc: dw_mmc: add quirks for unreliable card detect, and capabilities mmc: tmio: fix address in kunmap_atomic() calls mmc: core: reset card voltage after power off mmc: core: export function mmc_do_release_host() mmc: sdio: remember new card RCA when redetecting card mmc: dw_mmc: Remove set-but-unused variable. mmc: sdhci-esdhc-imx: add card detect on custom GPIO for mx25/35 mmc: sdhci-esdhc: broken card detection is not a default quirk mmc: sdhci-esdhc-imx: add write protect on custom GPIO on mx25/35 mmc: msm_sdcc: remove needless cache flush after dma_unmap_sg() mmc: sh_mmcif: support aggressive clock gating mmc: check if mmc cards < 2GB do sector addressing mmc: core: comment on why sdio_reset is done at init time mmc: dw_mmc: support DDR mode mmc: via-sdmmc: Remove set-but-unused variable. mmc: cb710: Return err value in cb710_wait_while_busy() mmc: sdhci-pci: Remove set-but-unused variable. mmc: mxs-mmc: add mmc host driver for i.MX23/28 ...
2011-03-18Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300 * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300: MN10300: Clear ASB2364 peripheral interrupt masks before enabling interrupts MN10300: Fix the ASB2364 gdbport UART register defs MN10300: Fix ASB2364 FPGA register defs MN10300: Select GENERIC_HARDIRQS_NO_DEPRECATED MN10300: Select HAVE_GENERIC_HARDIRQS rather than GENERIC_HARDIRQS MN10300: Convert ASB2364 FPGA irq_chip to new functions MN10300: Convert ipi irq_chip to new functions MN10300: Convert serial irq_chip to new functions MN10300: Convert cpu irq_chips to new functions MN10300: Remove unused mn10300_intc_* functions MN10300: Remove stale irq_chip.end - V2 MN10300: Use clockevents_calc_mult_shift() MN10300: Use clocksource_register_hz() MN10300: Remove stale code
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (32 commits) Blackfin: ip0x: fix unused variable warning Blackfin: punt unused HDMA masks Blackfin: wire up new syscalls Blackfin/ipipe: restore pipeline bits in irqflags Blackfin/ipipe: fix deferred pipeline sync for the root stage Blackfin/ipipe: upgrade to I-pipe mainline Blackfin: cpufreq: fix typos Blackfin: enable GENERIC_HARDIRQS_NO_DEPRECATED Blackfin: SMP: convert to irq chip functions Blackfin: use accessor functions in show_interrupts() Blackfin: use proper wrapper functions for modifying irq status Blackfin: convert gpio irq_chip to new functions Blackfin: convert mac irq_chip to new functions Blackfin: convert error irq_chip to new functions Blackfin: convert internal irq_chip to new functions Blackfin: convert core irq_chip to new functions Blackfin: use proper wrappers for irq_desc Blackfin: optimize startup code Blackfin: SMP: work around anomaly 05000491 Blackfin: SMP: implement cpu_freq support ...
2011-03-18sparc: Add {open_by,name_to}_handle_at and clock_adjtime syscalls.David S. Miller
2011-03-18sparc: Implement of_iomap().David S. Miller
Grab the pre-computed resource and map using of_ioremap(). Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-18sparc: Implement of_address_to_resource().David S. Miller
Similarly to irq_of_parse_and_map(), find the platform_device object and return the pre-computed resource. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-18sparc: Provide NO_IRQ definition.David S. Miller
2011-03-18Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: label: remove #include of ACPI header to avoid warnings PCI: label: Fix compilation error when CONFIG_ACPI is unset PCI: pre-allocate additional resources to devices only after successful allocation of essential resources. PCI: introduce reset_resource() PCI: data structure agnostic free list function PCI: refactor io size calculation code PCI: do not create quirk I/O regions below PCIBIOS_MIN_IO for ICH PCI hotplug: acpiphp: set current_state to D0 in register_slot PCI: Export ACPI _DSM provided firmware instance number and string name to sysfs PCI: add more checking to ICH region quirks PCI: aer-inject: Override PCIe AER Mask Registers PCI: fix tlan build when CONFIG_PCI is not enabled PCI: remove quirk for pre-production systems PCI: Avoid potential NULL pointer dereference in pci_scan_bridge PCI/lpc: irq and pci_ids patch for Intel DH89xxCC DeviceIDs PCI: sysfs: Fix failure path for addition of "vpd" attribute
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (308 commits) ALSA: sound/pci/asihpi: check adapter index in hpi_ioctl ALSA: aloop - Fix possible IRQ lock inversion ALSA: sound/core: merge list_del()/list_add_tail() to list_move_tail() ALSA: ctxfi - use list_move() instead of list_del()/list_add() combination ALSA: firewire - msleep needs delay.h ALSA: firewire-lib, firewire-speakers: handle packet queueing errors ALSA: firewire-lib: allocate DMA buffer separately ALSA: firewire-lib: use no-info SYT for packets without SYT sample ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driver ALSA: hda - Remove an unused variable in patch_realtek.c ALSA: hda - pin-adc-mux-dmic auto-configuration of 92HD8X codecs ALSA: hda - fix digital mic selection in mixer on 92HD8X codecs ALSA: hda - Move default input-src selection to init part ALSA: hda - Initialize special cases for input src in init phase ALSA: ctxfi - Clear input settings before initialization ALSA: ctxfi - Fix SPDIF status retrieval ALSA: ctxfi - Fix incorrect SPDIF status bit mask ALSA: ctxfi - Fix microphone boost codes/comments ALSA: atiixp - Fix wrong time-out checks during ac-link reset ALSA: intel8x0m: append 'm' to "r_intel8x0" ...
2011-03-18Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Flush TLB if PGD entry is changed in i386 PAE mode x86, dumpstack: Correct stack dump info when frame pointer is available x86: Clean up csum-copy_64.S a bit x86: Fix common misspellings x86: Fix misspelling and align params x86: Use PentiumPro-optimized partial_csum() on VIA C7
2011-03-18Merge branches 'irq-fixes-for-linus' and 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Fix incorrect unlock in __setup_irq() cris: Use generic show_interrupts() genirq: show_interrupts: Check desc->name before printing it blindly cris: Use accessor functions to set IRQ_PER_CPU flag cris: Fix irq conversion fallout * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched, kernel-doc: Fix runqueue_is_locked() description
2011-03-18Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits) trace, filters: Initialize the match variable in process_ops() properly trace, documentation: Fix branch profiling location in debugfs oprofile, s390: Cleanups oprofile, s390: Remove hwsampler_files.c and merge it into init.c perf: Fix tear-down of inherited group events perf: Reorder & optimize perf_event_context to remove alignment padding on 64 bit builds perf: Handle stopped state with tracepoints perf: Fix the software events state check perf, powerpc: Handle events that raise an exception without overflowing perf, x86: Use INTEL_*_CONSTRAINT() for all PEBS event constraints perf, x86: Clean up SandyBridge PEBS events perf lock: Fix sorting by wait_min perf tools: Version incorrect with some versions of grep perf evlist: New command to list the names of events present in a perf.data file perf script: Add support for H/W and S/W events perf script: Add support for dumping symbols perf script: Support custom field selection for output perf script: Move printing of 'common' data from print_event and rename perf tracing: Remove print_graph_cpu and print_graph_proc from trace-event-parse perf script: Change process_event prototype ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-18MN10300: Clear ASB2364 peripheral interrupt masks before enabling interruptsDavid Howells
Clear the interrupt mask registers of ASB2364 peripherals before enabling interrupts so that any peripherals that weren't dealt with by the bootloader after a reboot (if there was one) won't cause an interrupt storm when interrupts are first enabled before the drivers are initialised. Also, attempt to reset the peripherals attached to the FPGA. Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Fix the ASB2364 gdbport UART register defsDavid Howells
Fix the ASB2364 gdbport UART register definitions. These registers are actually 2 bytes apart, not 4 (which the ASB2303 and ASB2305 are). Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Fix ASB2364 FPGA register defsDavid Howells
Fix the definition of the ASB2364 FPGA IRQ detect registers. They accidentally got defined to be the same as the mask registers when the patches were being ported to the upstream kernel. Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Select GENERIC_HARDIRQS_NO_DEPRECATEDThomas Gleixner
All chips converted. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Select HAVE_GENERIC_HARDIRQS rather than GENERIC_HARDIRQSDavid Howells
Select HAVE_GENERIC_HARDIRQS rather than GENERIC_HARDIRQS in MN10300's main Kconfig file to avoid this warning: warning: (MN10300) selects GENERIC_HARDIRQS which has unmet direct dependencies (HAVE_GENERIC_HARDIRQS) Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Convert ASB2364 FPGA irq_chip to new functionsThomas Gleixner
2011-03-18MN10300: Convert ipi irq_chip to new functionsThomas Gleixner
2011-03-18MN10300: Convert serial irq_chip to new functionsThomas Gleixner
2011-03-18MN10300: Convert cpu irq_chips to new functionsThomas Gleixner
2011-03-18MN10300: Remove unused mn10300_intc_* functionsThomas Gleixner
No users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Remove stale irq_chip.end - V2Thomas Gleixner
irq_chip.end is obsolete with the removal of __do_IRQ(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Use clockevents_calc_mult_shift()Thomas Gleixner
Use clockevents_calc_mult_shift() instead of the homebrewn function in mn10300/kernel/time.c. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Use clocksource_register_hz()Thomas Gleixner
clocksource_register_hz() calculates the shift/mult pair for the clocksource. Remove the mn10300 duplicate implementation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18MN10300: Remove stale codeThomas Gleixner
mn10300 implements clocksource and clockevents and selects them unconditionally in Kconfig. Remove the stale code which seems to be a leftover of the conversion. Cleanup the configuration switches as well. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2011-03-18Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (62 commits) powerpc/85xx: Fix signedness bug in cache-sram powerpc/fsl: 85xx: document cache sram bindings powerpc/fsl: define binding for fsl mpic interrupt controllers powerpc/fsl_msi: Handle msi-available-ranges better drivers/serial/ucc_uart.c: Add of_node_put to avoid memory leak powerpc/85xx: Fix SPE float to integer conversion failure powerpc/85xx: Update sata controller compatible for p1022ds board ATA: Add FSL sata v2 controller support powerpc/mpc8xxx_gpio: simplify searching for 'fsl, qoriq-gpio' compatiable powerpc/8xx: remove obsolete mgsuvd board powerpc/82xx: rename and update mgcoge board support powerpc/83xx: rename and update kmeter1 powerpc/85xx: Workaroudn e500 CPU erratum A005 powerpc/fsl_pci: Add support for FSL PCIe controllers v2.x powerpc/85xx: Fix writing to spin table 'cpu-release-addr' on ppc64e powerpc/pseries: Disable MSI using new interface if possible powerpc: Enable GENERIC_HARDIRQS_NO_DEPRECATED. powerpc: core irq_data conversion. powerpc: sysdev/xilinx_intc irq_data conversion. powerpc: sysdev/uic irq_data conversion. ... Fix up conflicts in arch/powerpc/sysdev/fsl_msi.c (due to getting rid of of_platform_driver in arch/powerpc)
2011-03-18x86: Flush TLB if PGD entry is changed in i386 PAE modeShaohua Li
According to intel CPU manual, every time PGD entry is changed in i386 PAE mode, we need do a full TLB flush. Current code follows this and there is comment for this too in the code. But current code misses the multi-threaded case. A changed page table might be used by several CPUs, every such CPU should flush TLB. Usually this isn't a problem, because we prepopulate all PGD entries at process fork. But when the process does munmap and follows new mmap, this issue will be triggered. When it happens, some CPUs keep doing page faults: http://marc.info/?l=linux-kernel&m=129915020508238&w=2 Reported-by: Yasunori Goto<y-goto@jp.fujitsu.com> Tested-by: Yasunori Goto<y-goto@jp.fujitsu.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Shaohua Li<shaohua.li@intel.com> Cc: Mallick Asit K <asit.k.mallick@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-mm <linux-mm@kvack.org> Cc: stable <stable@kernel.org> LKML-Reference: <1300246649.2337.95.camel@sli10-conroe> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-18x86, dumpstack: Correct stack dump info when frame pointer is availableNamhyung Kim
Current stack dump code scans entire stack and check each entry contains a pointer to kernel code. If CONFIG_FRAME_POINTER=y it could mark whether the pointer is valid or not based on value of the frame pointer. Invalid entries could be preceded by '?' sign. However this was not going to happen because scan start point was always higher than the frame pointer so that they could not meet. Commit 9c0729dc8062 ("x86: Eliminate bp argument from the stack tracing routines") delayed bp acquisition point, so the bp was read in lower frame, thus all of the entries were marked invalid. This patch fixes this by reverting above commit while retaining stack_frame() helper as suggested by Frederic Weisbecker. End result looks like below: before: [ 3.508329] Call Trace: [ 3.508551] [<ffffffff814f35c9>] ? panic+0x91/0x199 [ 3.508662] [<ffffffff814f3739>] ? printk+0x68/0x6a [ 3.508770] [<ffffffff81a981b2>] ? mount_block_root+0x257/0x26e [ 3.508876] [<ffffffff81a9821f>] ? mount_root+0x56/0x5a [ 3.508975] [<ffffffff81a98393>] ? prepare_namespace+0x170/0x1a9 [ 3.509216] [<ffffffff81a9772b>] ? kernel_init+0x1d2/0x1e2 [ 3.509335] [<ffffffff81003894>] ? kernel_thread_helper+0x4/0x10 [ 3.509442] [<ffffffff814f6880>] ? restore_args+0x0/0x30 [ 3.509542] [<ffffffff81a97559>] ? kernel_init+0x0/0x1e2 [ 3.509641] [<ffffffff81003890>] ? kernel_thread_helper+0x0/0x10 after: [ 3.522991] Call Trace: [ 3.523351] [<ffffffff814f35b9>] panic+0x91/0x199 [ 3.523468] [<ffffffff814f3729>] ? printk+0x68/0x6a [ 3.523576] [<ffffffff81a981b2>] mount_block_root+0x257/0x26e [ 3.523681] [<ffffffff81a9821f>] mount_root+0x56/0x5a [ 3.523780] [<ffffffff81a98393>] prepare_namespace+0x170/0x1a9 [ 3.523885] [<ffffffff81a9772b>] kernel_init+0x1d2/0x1e2 [ 3.523987] [<ffffffff81003894>] kernel_thread_helper+0x4/0x10 [ 3.524228] [<ffffffff814f6880>] ? restore_args+0x0/0x30 [ 3.524345] [<ffffffff81a97559>] ? kernel_init+0x0/0x1e2 [ 3.524445] [<ffffffff81003890>] ? kernel_thread_helper+0x0/0x10 -v5: * fix build breakage with oprofile -v4: * use 0 instead of regs->bp * separate out printk changes -v3: * apply comment from Frederic * add a couple of printk fixes Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Soren Sandmann <ssp@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Robert Richter <robert.richter@amd.com> LKML-Reference: <1300416006-3163-1-git-send-email-namhyung@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-18x86: Clean up csum-copy_64.S a bitIngo Molnar
The many stray whitespaces and other uncleanlinesses made this code almost unreadable to me - so fix those. No changes to the code. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-18x86: Fix common misspellingsLucas De Marchi
They were generated by 'codespell' and then manually reviewed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: trivial@kernel.org LKML-Reference: <1300389856-1099-3-git-send-email-lucas.demarchi@profusion.mobi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-18Merge branch 'linus' into x86/urgentIngo Molnar
Merge reason: Merge upstream commits to avoid conflicts in upcoming patches. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-18Blackfin: ip0x: fix unused variable warningMike Frysinger
The previous commit that changed this code to the common GPIO layers forgot to delete the local and now unused "i" variable. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-03-18Blackfin: punt unused HDMA masksMike Frysinger
No code uses these, and the short define names are polluting the global namespace where they collide with things like common irq files. So just punt the damned things. If in the future we need HDMA support, we can make a standalone header for these things. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
