commit 40a1ef95da85843696fc3ebe5fce39b0db32669f upstream.
For some reason they didn't get replaced so far by their
paravirt equivalents, resulting in code to be run with
interrupts disabled that doesn't expect so (causing, in the
observed case, a BUG_ON() to trigger) when syscall auditing is
enabled.
David (Cc-ed) came up with an identical fix, so likely this can
be taken to count as an ack from him.
Reported-by: Peter Moody <pmoody@google.com>
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/5108E01902000078000BA9C5@nat28.tlf.novell.com
Tested-by: Peter Moody <pmoody@google.com>
commit e43b3cec711a61edf047adf6204d542f3a659ef8 upstream.
early_pci_allowed() and read_pci_config_16() are only available if
CONFIG_PCI is defined.
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com>
commit 712ba9e9afc4b3d3d6fa81565ca36fe518915c01 upstream.
efi.runtime_version is erroneously being set to the value of the
vendor's firmware revision instead of that of the implemented EFI
specification. We can't deduce which EFI functions are available based
on the revision of the vendor's firmware since the version scheme is
likely to be unique to each vendor.
What we really need to know is the revision of the implemented EFI
specification, which is available in the EFI System Table header.
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Cc: Seiji Aguchi <seiji.aguchi@hds.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
commit b8f2c21db390273c3eaf0e5308faeaeb1e233840 upstream.
Update efi_call_phys_prelog to install an identity mapping of all available
memory. This corrects a bug on very large systems with more then 512 GB in
which bios would not be able to access addresses above not in the mapping.
The result is a crash that looks much like this.
BUG: unable to handle kernel paging request at 000000effd870020
IP: [<0000000078bce331>] 0x78bce330
PGD 0
Oops: 0000 [#1] SMP
Modules linked in:
CPU 0
Pid: 0, comm: swapper/0 Tainted: G W 3.8.0-rc1-next-20121224-medusa_ntz+ #2 Intel Corp. Stoutland Platform
RIP: 0010:[<0000000078bce331>] [<0000000078bce331>] 0x78bce330
RSP: 0000:ffffffff81601d28 EFLAGS: 00010006
RAX: 0000000078b80e18 RBX: 0000000000000004 RCX: 0000000000000004
RDX: 0000000078bcf958 RSI: 0000000000002400 RDI: 8000000000000000
RBP: 0000000078bcf760 R08: 000000effd870000 R09: 0000000000000000
R10: 0000000000000000 R11: 00000000000000c3 R12: 0000000000000030
R13: 000000effd870000 R14: 0000000000000000 R15: ffff88effd870000
FS: 0000000000000000(0000) GS:ffff88effe400000(0000) knlGS:0000000000000000
CR2: 000000effd870020 CR3: 000000000160c000 CR4: 00000000000006b0
Process swapper/0 (pid: 0, threadinfo ffffffff81600000, task ffffffff81614400)
Stack:
0000000078b80d18 0000000000000004 0000000078bced7b ffff880078b81fff
0000000000000000 0000000000000082 0000000078bce3a8 0000000000002400
0000000060000202 0000000078b80da0 0000000078bce45d ffffffff8107cb5a
Call Trace:
[<ffffffff8107cb5a>] ? on_each_cpu+0x77/0x83
[<ffffffff8102f4eb>] ? change_page_attr_set_clr+0x32f/0x3ed
[<ffffffff81035946>] ? efi_call4+0x46/0x80
[<ffffffff816c5abb>] ? efi_enter_virtual_mode+0x1f5/0x305
[<ffffffff816aeb24>] ? start_kernel+0x34a/0x3d2
[<ffffffff816ae5ed>] ? repair_env_string+0x60/0x60
[<ffffffff816ae2be>] ? x86_64_start_reservations+0xba/0xc1
[<ffffffff816ae120>] ? early_idt_handlers+0x120/0x120
[<ffffffff816ae419>] ? x86_64_start_kernel+0x154/0x163
Code: Bad RIP value.
RIP [<0000000078bce331>] 0x78bce330
RSP <ffffffff81601d28>
---[ end trace ead828934fef5eab ]---
Signed-off-by: Nathan Zimmer <nzimmer@sgi.com>
Signed-off-by: Robin Holt <holt@sgi.com>
commit c903f0456bc69176912dee6dd25c6a66ee1aed00 upstream.
At the moment the MSR driver only relies upon file system
checks. This means that anything as root with any capability set
can write to MSRs. Historically that wasn't very interesting but
on modern processors the MSRs are such that writing to them
provides several ways to execute arbitary code in kernel space.
Sample code and documentation on doing this is circulating and
MSR attacks are used on Windows 64bit rootkits already.
In the Linux case you still need to be able to open the device
file so the impact is fairly limited and reduces the security of
some capability and security model based systems down towards
that of a generic "root owns the box" setup.
Therefore they should require CAP_SYS_RAWIO to prevent an
elevation of capabilities. The impact of this is fairly minimal
on most setups because they don't have heavy use of
capabilities. Those using SELinux, SMACK or AppArmor rules might
want to consider if their rulesets on the MSR driver could be
tighter.
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit 568dca15aa2a0f4ddee255894ec393a159f13147 upstream.
Patrik Kluba reports that the preempt count becomes invalid due
to the preempt_enable() call being unbalanced with a
preempt_disable() call in the vfp assembly routines. This happens
because preempt_enable() and preempt_disable() update preempt
counts under PREEMPT_COUNT=y but the vfp assembly routines do so
under PREEMPT=y. In a configuration where PREEMPT=n and
DEBUG_ATOMIC_SLEEP=y, PREEMPT_COUNT=y and so the preempt_enable()
call in VFP_bounce() keeps subtracting from the preempt count
until it goes negative.
Fix this by always using PREEMPT_COUNT to decided when to update
preempt counts in the ARM assembly code.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Reported-by: Patrik Kluba <pkluba@dension.com>
Tested-by: Patrik Kluba <pkluba@dension.com>
commit 36224d0fe0f34cdde66a381708853ebadeac799c upstream.
Make BGA as the default version as we are supposed to just have
to specify when we use the PQFP version.
Issue was existing since commit:
3e90772 (ARM: at91: fix at91rm9200 soc subtype handling).
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit 15653371c67c3fbe359ae37b720639dd4c7b42c5 upstream.
Subhash Jadavani reported this partial backtrace:
Now consider this call stack from MMC block driver (this is on the ARMv7
based board):
[<c001b50c>] (v7_dma_inv_range+0x30/0x48) from [<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c)
[<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c) from [<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c)
[<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c) from [<c0017ff8>] (dma_map_sg+0x3c/0x114)
This is caused by incrementing the struct page pointer, and running off
the end of the sparsemem page array. Fix this by incrementing by pfn
instead, and convert the pfn to a struct page.
Suggested-by: James Bottomley <JBottomley@Parallels.com>
Tested-by: Subhash Jadavani <subhashj@codeaurora.org>
commit 9174adbee4a9a49d0139f5d71969852b36720809 upstream.
This fixes CVE-2013-0190 / XSA-40
There has been an error on the xen_failsafe_callback path for failed
iret, which causes the stack pointer to be wrong when entering the
iret_exc error path. This can result in the kernel crashing.
In the classic kernel case, the relevant code looked a little like:
popl %eax # Error code from hypervisor
jz 5f
addl $16,%esp
jmp iret_exc # Hypervisor said iret fault
5: addl $16,%esp
# Hypervisor said segment selector fault
Here, there are two identical addls on either option of a branch which
appears to have been optimised by hoisting it above the jz, and
converting it to an lea, which leaves the flags register unaffected.
In the PVOPS case, the code looks like:
popl_cfi %eax # Error from the hypervisor
lea 16(%esp),%esp # Add $16 before choosing fault path
CFI_ADJUST_CFA_OFFSET -16
jz 5f
addl $16,%esp # Incorrectly adjust %esp again
jmp iret_exc
It is possible unprivileged userspace applications to cause this
behaviour, for example by loading an LDT code selector, then changing
the code selector to be not-present. At this point, there is a race
condition where it is possible for the hypervisor to return back to
userspace from an interrupt, fault on its own iret, and inject a
failsafe_callback into the kernel.
This bug has been present since the introduction of Xen PVOPS support
in commit 5ead97c84 (xen: Core Xen implementation), in 2.6.23.
Signed-off-by: Frediano Ziglio <frediano.ziglio@citrix.com>
Signed-off-by: Andrew Cooper <andrew.cooper3@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit a9acc5365dbda29f7be2884efb63771dc24bd815 upstream.
SNB graphics devices have a bug that prevent them from accessing certain
memory ranges, namely anything below 1M and in the pages listed in the
table. So reserve those at boot if set detect a SNB gfx device on the
CPU to avoid GPU hangs.
Stephane Marchesin had a similar patch to the page allocator awhile
back, but rather than reserving pages up front, it leaked them at
allocation time.
[ hpa: made a number of stylistic changes, marked arrays as static
const, and made less verbose; use "memblock=debug" for full
verbosity. ]
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: CAI Qian <caiqian@redhat.com>
commit ed4f20943cd4c7b55105c04daedf8d63ab6d499c upstream.
Converting a 64 Bit TOD format value to nanoseconds means that the value
must be divided by 4.096. In order to achieve that we multiply with 125
and divide by 512.
When used within sched_clock() this triggers an overflow after appr.
417 days. Resulting in a sched_clock() return value that is much smaller
than previously and therefore may cause all sort of weird things in
subsystems that rely on a monotonic sched_clock() behaviour.
To fix this implement a tod_to_ns() helper function which converts TOD
values without overflow and call this function from both places that
open coded the conversion: sched_clock() and kvm_s390_handle_wait().
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
commit 4a71997a3279a339e7336ea5d0cd27282e2dea44 upstream.
Ensure that the aux table is properly initialized, even when optional features
are missing. Without this, the FDPIC loader did not work. This was meant to
be included in commit d5ab780305bb6d60a7b5a74f18cf84eb6ad153b1.
Signed-off-by: Thomas Schwinge <thomas@codesourcery.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
commit e43a028752fed049e4bd94ef895542f96d79fa74 upstream.
When remembering the direction of a DCR transaction, we should write
to the same variable that we interpret on later when doing vcpu_run
again.
Signed-off-by: CAI Qian <caiqian@redhat.com>
commit 3b4bc7bccc7857274705b05cf81a0c72cfd0b0dd upstream.
This patch fixes some code that implements a work-around to a hardware bug in
the ac97 controller on the pxa27x. A bug in the controller's warm reset
functionality requires that the mfp used by the controller as the AC97_nRESET
line be temporarily reconfigured as a generic output gpio (AF0) and manually
held high for the duration of the warm reset cycle. This is what was done in
the original code, but it was broken long ago by commit fb1bf8cd
([ARM] pxa: introduce processor specific pxa27x_assert_ac97reset())
which changed the mfp to a GPIO input instead of a high output.
The fix requires the ac97 controller to obtain the gpio via gpio_request_one(),
with arguments that configure the gpio as an output initially driven high.
Tested on a palm treo 680 machine. Reportedly, this broken code only prevents a
warm reset on hardware that lacks a pull-up on the line, which appears to be the
case for me.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
commit 2bbf0a1427c377350f001fbc6260995334739ad7 upstream.
The Way Access Filter in recent AMD CPUs may hurt the performance of
some workloads, caused by aliasing issues in the L1 cache.
This patch disables it on the affected CPUs.
The issue is similar to that one of last year:
http://lkml.indiana.edu/hypermail/linux/kernel/1107.3/00041.html
This new patch does not replace the old one, we just need another
quirk for newer CPUs.
The performance penalty without the patch depends on the
circumstances, but is a bit less than the last year's 3%.
The workloads affected would be those that access code from the same
physical page under different virtual addresses, so different
processes using the same libraries with ASLR or multiple instances of
PIE-binaries. The code needs to be accessed simultaneously from both
cores of the same compute unit.
More details can be found here:
http://developer.amd.com/Assets/SharedL1InstructionCacheonAMD15hCPU.pdf
CPUs affected are anything with the core known as Piledriver.
That includes the new parts of the AMD A-Series (aka Trinity) and the
just released new CPUs of the FX-Series (aka Vishera).
The model numbering is a bit odd here: FX CPUs have model 2,
A-Series has model 10h, with possible extensions to 1Fh. Hence the
range of model ids.
Signed-off-by: Andre Przywara <osp@andrep.de>
Link: http://lkml.kernel.org/r/1351700450-9277-1-git-send-email-osp@andrep.de
commit 8add1ecb81f541ef2fcb0b85a5470ad9ecfb4a84 upstream.
When poweroff machine, kernel_power_off() call disable_nonboot_cpus().
And if we have HOTPLUG_CPU configured, disable_nonboot_cpus() is not an
empty function but attempt to actually disable the nonboot cpus. Since
system state is SYSTEM_POWER_OFF, play_dead() won't be called and thus
disable_nonboot_cpus() hangs. Therefore, we make this patch to avoid
poweroff failure.
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Signed-off-by: Hongliang Tao <taohl@lemote.com>
Signed-off-by: Hua Yan <yanh@lemote.com>
Cc: Yong Zhang <yong.zhang@windriver.com>
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/4211/
commit e6449c9b2d90c1bd9a5985bf05ddebfd1631cd6b upstream.
The missing NULL terminator can cause a panic on
PPC405 boards during boot:
Linux/PowerPC load: console=ttyS0,115200 root=/dev/mtdblock1 rootfstype=squashfs,jffs2 noinitrd init=/etc/preinit
Finalizing device tree... flat tree at 0x6a5160
bootconsole [udbg0] enabled
Page fault in user mode with in_atomic() = 1 mm = (null)
NIP = c0275f50 MSR = fffffffe
Oops: Weird page fault, sig: 11 [#1]
PowerPC 40x Platform
Modules linked in:
NIP: c0275f50 LR: c0275f60 CTR: c0280000
REGS: c0275eb0 TRAP: 636f7265 Not tainted (3.7.1)
MSR: fffffffe <VEC,VSX,EE,PR,FP,ME,SE,BE,IR,DR,PMM,RI> CR: c06a6190 XER: 00000001
TASK = c02662a8[0] 'swapper' THREAD: c0274000
GPR00: c0275ec0 c000c658 c027c4bf 00000000 c0275ee0 c000a0ec c020a1a8 c020a1f0
GPR08: c020f631 c020f404 c025f078 c025f080 c0275f10
Call Trace:
---[ end trace 31fd0ba7d8756001 ]---
Kernel panic - not syncing: Attempted to kill the idle task!
The panic happens since commit 9597abe00c1bab2aedce6b49866bf6d1e81c9eed
(sections: fix section conflicts in arch/powerpc), however the root
cause of this is that the NULL terminator were not added in commit
a4f740cf33f7f6c164bbde3c0cdbcc77b0c4997c (of/flattree: Add of_flat_dt_match()
helper function).
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
commit ce73ec6db47af84d1466402781ae0872a9e7873c upstream.
The locking in update_vsyscall_tz() is not only unnecessary because the vdso
code copies the data unproteced in __kernel_gettimeofday() but also
introduces a hard to reproduce race condition between update_vsyscall()
and update_vsyscall_tz(), which causes user space process to loop
forever in vdso code.
The following patch removes the locking from update_vsyscall_tz().
Locking is not only unnecessary because the vdso code copies the data
unprotected in __kernel_gettimeofday() but also erroneous because updating
the tb_update_count is not atomic and introduces a hard to reproduce race
condition between update_vsyscall() and update_vsyscall_tz(), which further
causes user space process to loop forever in vdso code.
The below scenario describes the race condition,
x==0 Boot CPU other CPU
proc_P: x==0
timer interrupt
update_vsyscall
x==1 x++;sync settimeofday
update_vsyscall_tz
x==2 x++;sync
x==3 sync;x++
sync;x++
proc_P: x==3 (loops until x becomes even)
Because the ++ operator would be implemented as three instructions and not
atomic on powerpc.
A similar change was made for x86 in commit 6c260d58634
("x86: vdso: Remove bogus locking in update_vsyscall_tz")
Signed-off-by: Shan Hai <shan.hai@windriver.com>
commit 11ee7e99f35ecb15f59b21da6a82d96d2cd3fcc8 upstream.
If we build a kernel with CONFIG_RELOCATABLE=y CONFIG_CRASH_DUMP=n,
the kernel fails when we run at a non zero offset. It turns out
we were incorrectly wrapping some of the relocatable kernel code
with CONFIG_CRASH_DUMP.
commit c24bf9b4cc6a0f330ea355d73bfdf1dae7e63a05 upstream.
The inb/outb macros for CRIS are broken from a number of points of view,
missing () around parameters and they have an unprotected if statement
in them. This was breaking the compile of IPMI on CRIS and thus I was
being annoyed by build regressions, so I fixed them.
Plus I don't think they would have worked at all, since the data values
were missing "&" and the outsl had a "3" instead of a "4" for the size.
From what I can tell, this stuff is not used at all, so this can't be
any more broken than it was before, anyway.
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Mikael Starvik <starvik@axis.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
commit e6ee4b2b57a8e0d8e551031173de080b338d3969 upstream.
Commit 34ae6c96a6a7 ("ARM: 7298/1: realview: fix mapping of MPCore
private memory region") accidentally broke the definition for the base
address of the private peripheral region on revision B Realview-EB
boards.
This patch uses the correct address for REALVIEW_EB11MP_PRIV_MEM_BASE.
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Tested-by: Florian Fainelli <florian@openwrt.org>
commit 7bf9b7bef881aac820bf1f2e9951a17b09bd7e04 upstream.
find_vma() is *not* safe when somebody else is removing vmas. Not just
the return value might get bogus just as you are getting it (this instance
doesn't try to dereference the resulting vma), the search itself can get
buggered in rather spectacular ways. IOW, ->mmap_sem really, really is
not optional here.
commit 864aa04cd02979c2c755cb28b5f4fe56039171c0 upstream.
When updating the page protection map after calculating the user_pgprot
value, the base protection map is temporarily stored in an unsigned long
type, causing truncation of the protection bits when LPAE is enabled.
This effectively means that calls to mprotect() will corrupt the upper
page attributes, clearing the XN bit unconditionally.
This patch uses pteval_t to store the intermediate protection values,
preserving the upper bits for 64-bit descriptors.
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
[ Upstream commit 6cb9c3697585c47977c42c5cc1b9fc49247ac530 ]
Modifying the huge pte's requires that all the underlying pte's be
modified.
Version 2: added missing flush_tlb_page()
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Cc: sparclinux@vger.kernel.org
range of model ids.
commit 6acf5a8c931da9d26c8dd77d784daaf07fa2bff0 upstream.
HPET_TN_FSB is not a proper mask bit; it merely toggles between MSI and
legacy interrupt delivery. The proper mask bit is HPET_TN_ENABLE, so
use both bits when (un)masking the interrupt.
Link: http://lkml.kernel.org/r/5093E09002000078000A60E6@nat28.tlf.novell.com
CONFIG_VFPv3 set
commit 39141ddfb63a664f26d3f42f64ee386e879b492c upstream.
After commit 846a136881b8f73c1f74250bf6acfaa309cab1f2 ("ARM: vfp: fix
saving d16-d31 vfp registers on v6+ kernels"), the OMAP 2430SDP board
started crashing during boot with omap2plus_defconfig:
[ 3.875122] mmcblk0: mmc0:e624 SD04G 3.69 GiB
[ 3.915954] mmcblk0: p1
[ 4.086639] Internal error: Oops - undefined instruction: 0 [#1] SMP ARM
[ 4.093719] Modules linked in:
[ 4.096954] CPU: 0 Not tainted (3.6.0-02232-g759e00b #570)
[ 4.103149] PC is at vfp_reload_hw+0x1c/0x44
[ 4.107666] LR is at __und_usr_fault_32+0x0/0x8
It turns out that the context save/restore fix unmasked a latent bug
in commit 5aaf254409f8d58229107b59507a8235b715a960 ("ARM: 6203/1: Make
VFPv3 usable on ARMv6"). When CONFIG_VFPv3 is set, but the kernel is
booted on a pre-VFPv3 core, the code attempts to save and restore the
d16-d31 VFP registers. These are only present on non-D16 VFPv3+, so
this results in an undefined instruction exception. The code didn't
crash before commit 846a136 because the save and restore code was
only touching d0-d15, present on all VFP.
Fix by implementing a request from Russell King to add a new HWCAP
flag that affirmatively indicates the presence of the d16-d31
registers:
http://marc.info/?l=linux-arm-kernel&m=135013547905283&w=2
and some feedback from Måns to clarify the name of the HWCAP flag.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Dave Martin <dave.martin@linaro.org>
Cc: Måns Rullgård <mans.rullgard@linaro.org>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 644c154186386bb1fa6446bc5e037b9ed098db46 upstream.
When a cpu enters S3 state, the FPU state is lost.
After resuming for S3, if we try to lazy restore the FPU for a process running
on the same CPU, this will result in a corrupted FPU context.
Ensure that "fpu_owner_task" is properly invalided when (re-)initializing a CPU,
so nobody will try to lazy restore a state which doesn't exist in the hardware.
Tested with a 64-bit kernel on a 4-core Ivybridge CPU with eagerfpu=off,
by doing thousands of suspend/resume cycles with 4 processes doing FPU
operations running. Without the patch, a process is killed after a
few hundreds cycles by a SIGFPE.
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
Cc: Duncan Laurie <dlaurie@chromium.org>
Cc: Olof Johansson <olofj@chromium.org>
Link: http://lkml.kernel.org/r/1354306532-1014-1-git-send-email-vpalatin@chromium.org
commit 1dc831bf53fddcc6443f74a39e72db5bcea4f15d upstream.
- The code relies on rc_pci_fixup being called, which only happens
when CONFIG_PCI_QUIRKS is enabled, so add that to Kconfig. Omitting
this causes a booting failure with a non-obvious cause.
- Update rc_pci_fixup to set the class properly, copying the
more modern style from other places
- Correct the rc_pci_fixup comment
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit d356cf5a74afa32b40decca3c9dd88bc3cd63eb5 upstream.
PMU interrupts start at IRQ_DOVE_PMU_START, not IRQ_DOVE_PMU_START + 1.
Fix the condition. (It may have been less likely to occur had the code
been written "if (irq >= IRQ_DOVE_PMU_START" which imho is the easier
to understand notation, and matches the normal way of thinking about
these things.)
commit 5d3df935426271016b895aecaa247101b4bfa35e upstream.
Fix the acknowledgement of PMU interrupts on Dove: some Dove hardware
has not been sensibly designed so that interrupts can be handled in a
race free manner. The PMU is one such instance.
The pending (aka 'cause') register is a bunch of RW bits, meaning that
these bits can be both cleared and set by software (confirmed on the
Armada-510 on the cubox.)
Hardware sets the appropriate bit when an interrupt is asserted, and
software is required to clear the bits which are to be processed. If
we write ~(1 << bit), then we end up asserting every other interrupt
except the one we're processing. So, we need to do a read-modify-write
cycle to clear the asserted bit.
However, any interrupts which occur in the middle of this cycle will
also be written back as zero, which will also clear the new interrupts.
The upshot of this is: there is _no_ way to safely clear down interrupts
in this register (and other similarly behaving interrupt pending
registers on this device.) The patch below at least stops us creating
new interrupts.
commit cb57a2b4cff7edf2a4e32c0163200e9434807e0a upstream.
Modules, in particular oprofile (and possibly other similar tools)
need kernel_stack_pointer(), so export it using EXPORT_SYMBOL_GPL().
Cc: Yang Wei <wei.yang@windriver.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Jun Zhang <jun.zhang@intel.com>
Link: http://lkml.kernel.org/r/20120912135059.GZ8285@erda.amd.com
Cc: Robert Richter <rric@kernel.org>
Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
Cc: Philip Müller <philm@manjaro.org>
commit 9d7d6e363b06934221b81a859d509844c97380df upstream.
read_persistent_clock uses a global variable, use a spinlock to
ensure non-atomic updates to the variable don't overlap and cause
time to move backwards.
Signed-off-by: Colin Cross <ccross@android.com>
Signed-off-by: R Sricharan <r.sricharan@ti.com>
[bwh: Backported to 3.2: adjust context]
commit feadf7c0a1a7c08c74bebb4a13b755f8c40e3bbc upstream.
The EEH core is talking with the PCI device driver to determine the
action (purely reset, or PCI device removal). During the period, the
driver might be unloaded and in turn causes kernel crash as follows:
EEH: Detected PCI bus error on PHB#4-PE#10000
EEH: This PCI device has failed 3 times in the last hour
lpfc 0004:01:00.0: 0:2710 PCI channel disable preparing for reset
Unable to handle kernel paging request for data at address 0x00000490
Faulting instruction address: 0xd00000000e682c90
cpu 0x1: Vector: 300 (Data Access) at [c000000fc75ffa20]
pc: d00000000e682c90: .lpfc_io_error_detected+0x30/0x240 [lpfc]
lr: d00000000e682c8c: .lpfc_io_error_detected+0x2c/0x240 [lpfc]
sp: c000000fc75ffca0
msr: 8000000000009032
dar: 490
dsisr: 40000000
current = 0xc000000fc79b88b0
paca = 0xc00000000edb0380 softe: 0 irq_happened: 0x00
pid = 3386, comm = eehd
enter ? for help
[c000000fc75ffca0] c000000fc75ffd30 (unreliable)
[c000000fc75ffd30] c00000000004fd3c .eeh_report_error+0x7c/0xf0
[c000000fc75ffdc0] c00000000004ee00 .eeh_pe_dev_traverse+0xa0/0x180
[c000000fc75ffe70] c00000000004ffd8 .eeh_handle_event+0x68/0x300
[c000000fc75fff00] c0000000000503a0 .eeh_event_handler+0x130/0x1a0
[c000000fc75fff90] c000000000020138 .kernel_thread+0x54/0x70
1:mon>
The patch increases the reference of the corresponding driver modules
while EEH core does the negotiation with PCI device driver so that the
corresponding driver modules can't be unloaded during the period and
we're safe to refer the callbacks.
Reported-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
[ herton: backported for 3.5, adjusted driver assignments, return 0
instead of NULL, assume dev is not NULL ]
Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
commit 6d1068b3a98519247d8ba4ec85cd40ac136dbdf9 upstream.
On hosts without the XSAVE support unprivileged local user can trigger
oops similar to the one below by setting X86_CR4_OSXSAVE bit in guest
cr4 register using KVM_SET_SREGS ioctl and later issuing KVM_RUN
ioctl.
invalid opcode: 0000 [#2] SMP
Modules linked in: tun ip6table_filter ip6_tables ebtable_nat ebtables
Pid: 24935, comm: zoog_kvm_monito Tainted: G D 3.2.0-3-686-pae
EIP: 0060:[<f8b9550c>] EFLAGS: 00210246 CPU: 0
EIP is at kvm_arch_vcpu_ioctl_run+0x92a/0xd13 [kvm]
EAX: 00000001 EBX: 000f387e ECX: 00000000 EDX: 00000000
ESI: 00000000 EDI: 00000000 EBP: ef5a0060 ESP: d7c63e70
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
Process zoog_kvm_monito (pid: 24935, ti=d7c62000 task=ed84a0c0
task.ti=d7c62000)
Stack:
00000001 f70a1200 f8b940a9 ef5a0060 00000000 00200202 f8769009 00000000
ef5a0060 000f387e eda5c020 8722f9c8 00015bae 00000000 ed84a0c0 ed84a0c0
c12bf02d 0000ae80 ef7f8740 fffffffb f359b740 ef5a0060 f8b85dc1 0000ae80
Call Trace:
[<f8b940a9>] ? kvm_arch_vcpu_ioctl_set_sregs+0x2fe/0x308 [kvm]
[<c12bfb44>] ? syscall_call+0x7/0xb
Code: 89 e8 e8 14 ee ff ff ba 00 00 04 00 89 e8 e8 98 48 ff ff 85 c0 74
1e 83 7d 48 00 75 18 8b 85 08 07 00 00 31 c9 8b 95 0c 07 00 00 <0f> 01
d1 c7 45 48 01 00 00 00 c7 45 1c 01 00 00 00 0f ae f0 89
EIP: [<f8b9550c>] kvm_arch_vcpu_ioctl_run+0x92a/0xd13 [kvm] SS:ESP
0068:d7c63e70
QEMU first retrieves the supported features via KVM_GET_SUPPORTED_CPUID
and then sets them later. So guest's X86_FEATURE_XSAVE should be masked
out on hosts without X86_FEATURE_XSAVE, making kvm_set_cr4 with
X86_CR4_OSXSAVE fail. Userspaces that allow specifying guest cpuid with
X86_FEATURE_XSAVE even on hosts that do not support it, might be
susceptible to this attack from inside the guest as well.
Allow setting X86_CR4_OSXSAVE bit only if host has XSAVE support.
Signed-off-by: Petr Matousek <pmatouse@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit fae2ae2a900a5c7bb385fe4075f343e7e2d5daa2 upstream.
If a signal handler is executed on altstack and another signal comes,
we will end up with rt_sigreturn() on return from the second handler
getting -EPERM from do_sigaltstack(). It's perfectly OK, since we
are not asking to change the settings; in fact, they couldn't have been
changed during the second handler execution exactly because we'd been
on altstack all along. 64bit sigreturn on sparc treats any error from
do_sigaltstack() as "SIGSEGV now"; we need to switch to the same semantics
we are using on other architectures.
commit 441a179dafc0f99fc8b3a8268eef66958621082e upstream.
int sys32_rt_sigprocmask(int how, compat_sigset_t __user *set, compat_sigset_t __user *oset,
unsigned int sigsetsize)
sigset_t old_set, new_set;
int ret;
if (set && get_sigset32(set, &new_set, sigsetsize))
static int
get_sigset32(compat_sigset_t __user *up, sigset_t *set, size_t sz)
compat_sigset_t s;
int r;
if (sz != sizeof *set) panic("put_sigset32()");
In other words, rt_sigprocmask(69, (void *)69, 69) done by 32bit process
will promptly panic the box.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 949a05d03490e39e773e8652ccab9157e6f595b4 upstream.
On Thu, 2012-11-01 at 16:45 -0700, Michel Lespinasse wrote:
> Looking at the arch/parisc/kernel/sys_parisc.c implementation of
> get_shared_area(), I do have a concern though. The function basically
> ignores the pgoff argument, so that if one creates a shared mapping of
> pages 0-N of a file, and then a separate shared mapping of pages 1-N
> of that same file, both will have the same cache offset for their
> starting address.
> This looks like this would create obvious aliasing issues. Am I
> misreading this ? I can't understand how this could work good enough
> to be undetected, so there must be something I'm missing here ???
This turns out to be correct and we need to pay attention to the pgoff as
well as the address when creating the virtual address for the area.
Fortunately, the bug is rarely triggered as most applications which use pgoff
tend to use large values (git being the primary one, and it uses pgoff in
multiples of 16MB) which are larger than our cache coherency modulus, so the
problem isn't often seen in practise.
Reported-by: Michel Lespinasse <walken@google.com>
commit 36c46ca4f322a7bf89aad5462a3a1f61713edce7 upstream.
Add valid patch size for family 16h processors.
[ hpa: promoting to urgent/stable since it is hw enabling and trivial ]
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@amd.com>
Acked-by: Andreas Herrmann <herrmann.der.user@googlemail.com>
Link: http://lkml.kernel.org/r/1353004910-2204-1-git-send-email-boris.ostrovsky@amd.com
commit 0f905a43ce955b638139bd84486194770a6a2c08 upstream.
Building for Athlon/Duron/K7 results in the following build error,
arch/x86/boot/compressed/eboot.o: In function `__constant_memcpy3d':
eboot.c:(.text+0x385): undefined reference to `_mmx_memcpy'
arch/x86/boot/compressed/eboot.o: In function `efi_main':
eboot.c:(.text+0x1a22): undefined reference to `_mmx_memcpy'
because the boot stub code doesn't link with the kernel proper, and
therefore doesn't have access to the 3DNow version of memcpy. So,
follow the example of misc.c and #undef memcpy so that we use the
version provided by misc.c.
See https://bugzilla.kernel.org/show_bug.cgi?id=50391
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Reported-by: Ryan Underwood <nemesis@icequake.net>
commit 1022623842cb72ee4d0dbf02f6937f38c92c3f41 upstream.
In 32 bit the stack address provided by kernel_stack_pointer() may
point to an invalid range causing NULL pointer access or page faults
while in NMI (see trace below). This happens if called in softirq
context and if the stack is empty. The address at ®s->sp is then
out of range.
Fixing this by checking if regs and ®s->sp are in the same stack
context. Otherwise return the previous stack pointer stored in struct
thread_info. If that address is invalid too, return address of regs.
BUG: unable to handle kernel NULL pointer dereference at 0000000a
IP: [<c1004237>] print_context_stack+0x6e/0x8d
*pde = 00000000
Oops: 0000 [#1] SMP
Modules linked in:
Pid: 4434, comm: perl Not tainted 3.6.0-rc3-oprofile-i386-standard-g4411a05 #4 Hewlett-Packard HP xw9400 Workstation/0A1Ch
EIP: 0060:[<c1004237>] EFLAGS: 00010093 CPU: 0
EIP is at print_context_stack+0x6e/0x8d
EAX: ffffe000 EBX: 0000000a ECX: f4435f94 EDX: 0000000a
ESI: f4435f94 EDI: f4435f94 EBP: f5409ec0 ESP: f5409ea0
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
CR0: 8005003b CR2: 0000000a CR3: 34ac9000 CR4: 000007d0
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: ffff0ff0 DR7: 00000400
Process perl (pid: 4434, ti=f5408000 task=f5637850 task.ti=f4434000)
Stack:
000003e8 ffffe000 00001ffc f4e39b00 00000000 0000000a f4435f94 c155198c
f5409ef0 c1003723 c155198c f5409f04 00000000 f5409edc 00000000 00000000
f5409ee8 f4435f94 f5409fc4 00000001 f5409f1c c12dce1c 00000000 c155198c
Call Trace:
[<c1003723>] dump_trace+0x7b/0xa1
[<c12dce1c>] x86_backtrace+0x40/0x88
[<c12db712>] ? oprofile_add_sample+0x56/0x84
[<c12db731>] oprofile_add_sample+0x75/0x84
[<c12ddb5b>] op_amd_check_ctrs+0x46/0x260
[<c12dd40d>] profile_exceptions_notify+0x23/0x4c
[<c1395034>] nmi_handle+0x31/0x4a
[<c1029dc5>] ? ftrace_define_fields_irq_handler_entry+0x45/0x45
[<c13950ed>] do_nmi+0xa0/0x2ff
[<c13949e5>] nmi_stack_correct+0x28/0x2d
[<c1003603>] ? do_softirq+0x4b/0x7f
<IRQ>
[<c102a06f>] irq_exit+0x35/0x5b
[<c1018f56>] smp_apic_timer_interrupt+0x6c/0x7a
[<c1394746>] apic_timer_interrupt+0x2a/0x30
Code: 89 fe eb 08 31 c9 8b 45 0c ff 55 ec 83 c3 04 83 7d 10 00 74 0c 3b 5d 10 73 26 3b 5d e4 73 0c eb 1f 3b 5d f0 76 1a 3b 5d e8 73 15 <8b> 13 89 d0 89 55 e0 e8 ad 42 03 00 85 c0 8b 55 e0 75 a6 eb cc
EIP: [<c1004237>] print_context_stack+0x6e/0x8d SS:ESP 0068:f5409ea0
CR2: 000000000000000a
---[ end trace 62afee3481b00012 ]---
Kernel panic - not syncing: Fatal exception in interrupt
V2:
* add comments to kernel_stack_pointer()
* always return a valid stack address by falling back to the address
of regs
Reported-by: Yang Wei <wei.yang@windriver.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
commit a4f743851f74fc3e0cc40c13082e65c24139f481 upstream.
This reverts commit 957ee7270d632245b43f6feb0e70d9a5e9ea6cf6
(serial: omap: fix software flow control).
As Russell has pointed out, that commit isn't fixing
Software Flow Control at all, and it actually makes
it even more broken.
It was agreed to revert this commit and use Russell's
latest UART patches instead.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
commit fa968ee215c0ca91e4a9c3a69ac2405aae6e5d2f upstream.
If user space is running in primary mode it can switch to secondary
or access register mode, this is used e.g. in the clock_gettime code
of the vdso. If a signal is delivered to the user space process while
it has been running in access register mode the signal handler is
executed in access register mode as well which will result in a crash
most of the time.
Set the address space control bits in the PSW to the default for the
execution of the signal handler and make sure that the previous
address space control is restored on signal return. Take care
that user space can not switch to the kernel address space by
modifying the registers in the signal frame.
commit 34fa78b59c52d1db3513db4c1a999db26b2e9ac2 upstream.
The sigaddset/sigdelset/sigismember functions that are implemented with
bitfield insn cannot allow the sigset argument to be placed in a data
register since the sigset is wider than 32 bits. Remove the "d"
constraint from the asm statements.
The effect of the bug is that sending RT signals does not work, the signal
number is truncated modulo 32.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
commit d55c4c613fc4d4ad2ba0fc6fa2b57176d420f7e4 upstream.
When walking page tables we need to make sure that everything
is within bounds of the ASCE limit of the task's address space.
Otherwise we might calculate e.g. a pud pointer which is not
within a pud and dereference it.
So check against TASK_SIZE (which is the ASCE limit) before
walking page tables.
Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
commit 95a7d76897c1e7243d4137037c66d15cbf2cce76 upstream.
As Mukesh explained it, the MMUEXT_TLB_FLUSH_ALL allows the
hypervisor to do a TLB flush on all active vCPUs. If instead
we were using the generic one (which ends up being xen_flush_tlb)
we end up making the MMUEXT_TLB_FLUSH_LOCAL hypercall. But
before we make that hypercall the kernel will IPI all of the
vCPUs (even those that were asleep from the hypervisor
perspective). The end result is that we needlessly wake them
up and do a TLB flush when we can just let the hypervisor
do it correctly.
This patch gives around 50% speed improvement when migrating
idle guest's from one host to another.
Oracle-bug: 14630170
Tested-by: Jingjie Jiang <jingjie.jiang@oracle.com>
Suggested-by: Mukesh Rathor <mukesh.rathor@oracle.com>
This reverts commit baa526f45d3f096a1cd9f14b668203a03bbab6f9, which is
commit 308b3afb97dc342e9c4f958d8b4c459ae0e22bd7 upstream.
To quote Colin Cross:
This patch breaks Exynos5 spi on 3.4.17. The patch with the bug
that this patch was supposed to address went in to 3.6 and not
3.4, so this patch causes a driver name mismatch when applied to
3.4.
Cc: Colin Cross <ccross@google.com>
Cc: Heiko Stuebner <heiko@sntech.de>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
commit 1f2ff682ac951ed82cc043cf140d2851084512df upstream.
We need to handle E820_RAM and E820_RESERVED_KERNEL at the same time.
Also memblock has page aligned range for ram, so we could avoid mapping
partial pages.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Link: http://lkml.kernel.org/r/CAE9FiQVZirvaBMFYRfXMmWEcHbKSicQEHz4VAwUv0xFCk51ZNw@mail.gmail.com
Acked-by: Jacob Shin <jacob.shin@amd.com>
commit 5189c2a7c7769ee9d037d76c1a7b8550ccf3481c upstream.
When 32-bit EFI is used with 64-bit kernel (or vice versa), turn off
efi_enabled once setup is done. Beyond setup, it is normally used to
determine if runtime services are available and we will have none.
This will resolve issues stemming from efivars modprobe panicking on a
32/64-bit setup, as well as some reboot issues on similar setups.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=45991
Reported-by: Marko Kohtala <marko.kohtala@gmail.com>
Reported-by: Maxim Kammerer <mk@dee.su>
Acked-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Cc: Matthew Garrett <mjg@redhat.com>
commit 785107923a83d8456bbd8564e288a24d84109a46 upstream.
Some new ACPI 5.0 tables reference resources stored in boot services
memory, so keep that memory around until we have ACPI and can extract
data from it.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Link: http://lkml.kernel.org/r/baaa6d44bdc4eb0c58e5d1b4ccd2c729f854ac55.1348876882.git.josh@joshtriplett.org
Cc: Matt Fleming <matt@console-pimps.org>
