path: root/arch
2008-01-03[IA64] Update Altix nofault codeRuss Anderson
Montecito and Montvale behaves slightly differently than previous Itanium processors, resulting in the MCA due to a failed PIO read to sometimes surfacing outside the nofault code. This code is based on discussions with Intel CPU architects and verified at customer sites. Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-01-01Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Fix build failure on Cell when CONFIG_SPU_FS=y
2008-01-02[POWERPC] Fix build failure on Cell when CONFIG_SPU_FS=yPaul Mackerras
Commit aed3a8c9bb1a8623a618232087c5ff62718e3b9a introduced a definition of notify_spus_active in .../cell/spu_syscalls.c, and another definition under #ifndef MODULE in .../cell/spufs/sched.c. The latter is not necessary and causes the build to fail when CONFIG_SPU_FS=y, so this removes it. It also removes the export of do_notify_spus_active, which is unnecessary. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jeremy Kerr <jk@ozlabs.org>
2008-01-01fix lguest rmmod "bad pgd"Rusty Russell
After 17d57a9206b4de6ad082ac9f2d2346985abbd2aa ("x86: fix x86-32 early fixmap initialization.") removing lg.ko caused a printk from vunmap: mm/memory.c:115: bad pgd 004b3027. On the second use after module load, the kernel crashes. This fixes the immediate problem (accessed and dirty bits not set as expected in pmd_none_or_clear_bad). I can't see why this would cause a crash, but I haven't been able to reproduce it once this is applied. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-28[POWERPC] PS3: Fix printing of os-area magic numbersGeoff Levand
Fix a bug in the printing of the os-area magic numbers which assumed that magic numbers were zero terminated strings. The magic numbers are represented in memory as integers. If the os-area sections are not initialized correctly they could contained random data that would be printed to the display. Also unify the handling of header and db magic numbers and make both of type array of u8. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-28[POWERPC] Oprofile: Remove dependency on spufs moduleBob Nelson
This removes an OProfile dependency on the spufs module. This dependency was causing a problem for multiplatform systems that are built with support for Oprofile on Cell but try to load the oprofile module on a non-Cell system. Signed-off-by: Bob Nelson <rrnelson@us.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Acked-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-26[SPARC64]: Implement pci_resource_to_user()David S. Miller
This makes libpciaccess able to mmap() resources of the device properly. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-25Revert "x86: fix show cpuinfo cpu number always zero"Linus Torvalds
This reverts commit fbdcf18df73758b2e187ab94678b30cd5f6ff9f9. As pointed out by Yanmin Zhang, the problem was already fixed differently (and correctly), and rather than fix anything, it actually causes us to create a sub-optimal sched-domains hierarchy (not setting up the domain belonging to the core) when CONFIG_X86_HT=y. Requested-by: Yanmin Zhang <yanmin_zhang@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-23uml: user of helper_wait() got missed when it got extra argumentsAl Viro
2007-12-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC32]: Spelling fixes [SPARC64]: Spelling fixes [SPARC64]: Fix OOPS in dma_sync_*_for_device()
2007-12-21x86: intel_cacheinfo.c: cpu cache info entry for Intel TolapaiJason Gaston
This patch adds a cpu cache info entry for the Intel Tolapai cpu. Signed-off-by: Jason Gaston <jason.d.gaston@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-21x86: fix die() to not be preemptibleIngo Molnar
Andrew "Eagle Eye" Morton noticed that we use raw_local_save_flags() instead of raw_local_irq_save(flags) in die(). This allows the preemption of oopsing contexts - which is highly undesirable. It also causes CONFIG_DEBUG_PREEMPT to complain, as reported by Miles Lane. this bug was introduced via: commit 39743c9ef717fd4f2b5583f010115c5f2482b8ae Author: Andi Kleen <ak@suse.de> Date: Fri Oct 19 20:35:03 2007 +0200 x86: use raw locks during oopses - spin_lock_irqsave(&die.lock, flags); + __raw_spin_lock(&die.lock); + raw_local_save_flags(flags); that is not a correct open-coding of spin_lock_irqsave(): both the ordering is wrong (irqs should be disabled _first_), and the wrong flags-saving API was used. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-12-20[SPARC32]: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-20[SPARC64]: Spelling fixesJoe Perches
2007-12-19x86: fix show cpuinfo cpu number always zeroMike Travis
when called by setup_arch) after smp_store_cpu_info() had set it to the correct value. The error shows up in 'cat /proc/cpuinfo' will all cpus = 0. Signed-off-by: Mike Travis <travis@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: Christoph Lameter <clameter@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Suresh B Siddha <suresh.b.siddha@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-19x86_32: disable_pse must be __cpuinitdataAdrian Bunk
CONFIG_HOTPLUG_CPU=y: WARNING: vmlinux.o(.text+0xfa52): Section mismatch: reference to .init.data:disable_pse (between 'identify_cpu' and 'identify_secondary_cpu') [ akpm@linux-foundation.org: initializer fix. ] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-19x86_32: select_idle_routine() must be __cpuinitAdrian Bunk
CONFIG_HOTPLUG_CPU=y: WARNING: vmlinux.o(.text+0x1199a): Section mismatch: reference to .init.text.5:select_idle_routine (between 'init_intel' and 'init_nexgen') Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-19x86 smpboot_32.c section fixesAdrian Bunk
CONFIG_HOTPLUG_CPU=y: WARNING: vmlinux.o(.text+0x22c60): Section mismatch: reference to .init.data:cpu_idle_tasks (between 'do_boot_cpu' and 'do_warm_boot_cpu') WARNING: vmlinux.o(.text+0x22c99): Section mismatch: reference to .init.data:cpu_idle_tasks (between 'do_boot_cpu' and 'do_warm_boot_cpu') WARNING: vmlinux.o(.text+0x2359b): Section mismatch: reference to .init.data:smp_b_stepping (between 'smp_store_cpu_info' and 'cpu_exit_clear') WARNING: vmlinux.o(.text+0x235a0): Section mismatch: reference to .init.data:smp_b_stepping (between 'smp_store_cpu_info' and 'cpu_exit_clear') Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-19x86 apic_32.c section fixAdrian Bunk
CONFIG_HOTPLUG_CPU=y: WARNING: vmlinux.o(.text+0x2390d): Section mismatch: reference to .init.text.5:setup_local_APIC (between 'start_secondary' and 'check_tsc_warp') Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-19Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Adjust CMCI mask on CPU hotplug [IA64] make flush_tlb_kernel_range() an inline function [IA64] Guard elfcorehdr_addr with #if CONFIG_PROC_FS [IA64] Fix Altix BTE error return status [IA64] Remove assembler warnings on head.S [IA64] Remove compiler warinings about uninitialized variable in irq_ia64.c [IA64] set_thread_area fails in IA32 chroot [IA64] print kernel release in OOPS to make kerneloops.org happy [IA64] Two trivial spelling fixes [IA64] Avoid unnecessary TLB flushes when allocating memory [IA64] ia32 nopage [IA64] signal: remove redundant code in setup_sigcontext() IA64: Slim down __clear_bit_unlock
2007-12-19[IA64] Adjust CMCI mask on CPU hotplugHidetoshi Seto
Currently CMCI mask of hot-added CPU is always disabled after CPU hotplug. We should adjust this mask depending on CMC polling state. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-19[IA64] make flush_tlb_kernel_range() an inline functionJan Beulich
This fixes an unused variable warning in mm/vmalloc.c. Tony: also fix resulting fallout in uncached.c with a typo in args to flush_tlb_kernel_range(). Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-19[IA64] Guard elfcorehdr_addr with #if CONFIG_PROC_FSSimon Horman
Access to elfcorehdr_addr needs to be guarded by #if CONFIG_PROC_FS as well as the existing #if guards. Fixes the following build problem: arch/ia64/hp/common/built-in.o: In function `sba_init':arch/ia64/hp/common/sba_iommu.c:2043: undefined reference to `elfcorehdr_addr' :arch/ia64/hp/common/sba_iommu.c:2043: undefined reference to `elfcorehdr_addr' Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-19[IA64] Fix Altix BTE error return statusRuss Anderson
The Altix shub2 BTE error detail bits are in a different location than on shub1. The current code does not take this into account resulting in all shub2 BTE failures mapping to "unknown". This patch reads the error detail bits from the proper location, so the correct BTE failure reason is returned for both shub1 and shub2. Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-19[IA64] Remove assembler warnings on head.SHidetoshi Seto
This patch removes the following assembler warning messages. AS arch/ia64/kernel/head.o arch/ia64/kernel/head.S: Assembler messages: arch/ia64/kernel/head.S:1179: Warning: Use of 'ld8' violates RAW dependency 'CR[PTA]' (data) arch/ia64/kernel/head.S:1179: Warning: Only the first path encountering the conflict is reported arch/ia64/kernel/head.S:1178: Warning: This is the location of the conflicting usage arch/ia64/kernel/head.S:1180: Warning: Use of 'ld8' violates RAW dependency 'CR[PTA]' (data) arch/ia64/kernel/head.S:1180: Warning: Only the first path encountering the conflict is reported arch/ia64/kernel/head.S:1178: Warning: This is the location of the conflicting usage : arch/ia64/kernel/head.S:1213: Warning: Use of 'ldf.fill.nta' violates RAW dependency 'CR[PTA]' (data) arch/ia64/kernel/head.S:1213: Warning: Only the first path encountering the conflict is reported arch/ia64/kernel/head.S:1178: Warning: This is the location of the conflicting usage Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-19[IA64] Remove compiler warinings about uninitialized variable in irq_ia64.cKenji Kaneshige
This patch removes the following compiler warning messages. CC arch/ia64/kernel/irq_ia64.o arch/ia64/kernel/irq_ia64.c: In function 'create_irq': arch/ia64/kernel/irq_ia64.c:343: warning: 'domain.bits[0u]' may be used uninitialized in this function arch/ia64/kernel/irq_ia64.c: In function 'assign_irq_vector': arch/ia64/kernel/irq_ia64.c:203: warning: 'domain.bits[0u]' may be used uninitialized in this function Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-19[IA64] set_thread_area fails in IA32 chrootIan Wienand
I tried to upgrade an IA32 chroot on my IA64 to a new glibc with TLS. It kept dying because set_thread_area was returning -ESRCH (bugs.debian.org/451939). I instrumented arch/ia64/ia32/sys_ia32.c:get_free_idx() and ended up seeing output like [pid] idx desc->a desc->b ----------------------------- [2710] 0 -> c6b0ffff 40dff31b [2710] 1 -> 0 0 [2710] 2 -> 0 0 [2710] 0 -> c6b0ffff 40dff31b [2710] 1 -> c6b0ffff 40dff31b [2710] 2 -> 0 0 [2711] 0 -> c6b0ffff 40dff31b [2711] 1 -> c6b0ffff 40dff31b [2711] 2 -> 48c0ffff 40dff317 which suggested to me that TLS pointers were surviving exec() calls, leading to GDT pointers filling up and the eventual failure of get_free_idx(). I think the solution is flushing the tls array on exec. Signed-Off-By: Ian Wienand <ianw@gelato.unsw.edu.au> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-18[IA64] print kernel release in OOPS to make kerneloops.org happyLuck, Tony
The ia64 oops message doesn't include the kernel version, which makes it hard to automatically categorize oops messages scraped from mailing lists and bug databases. Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-18[IA64] Two trivial spelling fixesJoe Perches
s/addres/address/ s/performanc/performance/ Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-18[IA64] Avoid unnecessary TLB flushes when allocating memoryde Dinechin, Christophe (Integrity VM)
Improve performance of memory allocations on ia64 by avoiding a global TLB purge to purge a single page from the file cache. This happens whenever we evict a page from the buffer cache to make room for some other allocation. Test case: Run 'find /usr -type f | xargs cat > /dev/null' in the background to fill the buffer cache, then run something that uses memory, e.g. 'gmake -j50 install'. Instrumentation showed that the number of global TLB purges went from a few millions down to about 170 over a 12 hours run of the above. The performance impact is particularly noticeable under virtualization, because a virtual TLB is generally both larger and slower to purge than a physical one. Signed-off-by: Christophe de Dinechin <ddd@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-18[IA64] ia32 nopageNick Piggin
Convert ia64's ia32 support from nopage to fault. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-18[IA64] signal: remove redundant code in setup_sigcontext()Shi Weihua
This patch removes some redundant code in the function setup_sigcontext(). The registers ar.ccv,b7,r14,ar.csd,ar.ssd,r2-r3 and r16-r31 are not restored in restore_sigcontext() when (flags & IA64_SC_FLAG_IN_SYSCALL) is true. So we don't need to zero those variables in setup_sigcontext(). Signed-off-by: Shi Weihua <shiwh@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-18x86: fix "Kernel panic - not syncing: IO-APIC + timer doesn't work!"Ingo Molnar
this is the tale of a full day spent debugging an ancient but elusive bug. after booting up thousands of random .config kernels, i finally happened to generate a .config that produced the following rare bootup failure on 32-bit x86: | ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1 | ..MP-BIOS bug: 8254 timer not connected to IO-APIC | ...trying to set up timer (IRQ0) through the 8259A ... failed. | ...trying to set up timer as Virtual Wire IRQ... failed. | ...trying to set up timer as ExtINT IRQ... failed :(. | Kernel panic - not syncing: IO-APIC + timer doesn't work! Boot with apic=debug | and send a report. Then try booting with the 'noapic' option this bug has been reported many times during the years, but it was never reproduced nor fixed. the bug that i hit was extremely sensitive to .config details. First i did a .config-bisection - suspecting some .config detail. That led to CONFIG_X86_MCE: enabling X86_MCE magically made the bug disappear and the system would boot up just fine. Debugging my way through the MCE code ended up identifying two unlikely candidates: the thing that made a real difference to the hang was that X86_MCE did two printks: Intel machine check architecture supported. Intel machine check reporting enabled on CPU#1. Adding the same printks to a !CONFIG_X86_MCE kernel made the bug go away! this left timing as the main suspect: i experimented with adding various udelay()s to the arch/x86/kernel/io_apic_32.c:check_timer() function, and the race window turned out to be narrower than 30 microseconds (!). That made debugging especially funny, debugging without having printk ability before the bug hits is ... interesting ;-) eventually i started suspecting IRQ activities - those are pretty much the only thing that happen this early during bootup and have the timescale of a few dozen microseconds. Also, check_timer() changes the IRQ hardware in various creative ways, so the main candidate became IRQ0 interaction. i've added a counter to track timer irqs (on which core they arrived, at what exact time, etc.) and found that no timer IRQ would arrive after the bug condition hits - even if we re-enable IRQ0 and re-initialize the i8259A, but that we'd get a small number of timer irqs right around the time when we call the check_timer() function. Eventually i got the following backtrace triggered from debug code in the timer interrupt: ...trying to set up timer as Virtual Wire IRQ... failed. ...trying to set up timer as ExtINT IRQ... Pid: 1, comm: swapper Not tainted (2.6.24-rc5 #57) EIP: 0060:[<c044d57e>] EFLAGS: 00000246 CPU: 0 EIP is at _spin_unlock_irqrestore+0x5/0x1c EAX: c0634178 EBX: 00000000 ECX: c4947d63 EDX: 00000246 ESI: 00000002 EDI: 00010031 EBP: c04e0f2e ESP: f7c41df4 DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 CR0: 8005003b CR2: ffe04000 CR3: 00630000 CR4: 000006d0 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: ffff0ff0 DR7: 00000400 [<c05f5784>] setup_IO_APIC+0x9c3/0xc5c the spin_unlock() was called from init_8259A(). Wait ... we have an IRQ0 entry while we are in the middle of setting up the local APIC, the i8259A and the PIT?? That is certainly not how it's supposed to work! check_timer() was supposed to be called with irqs turned off - but this eroded away sometime in the past. This code would still work most of the time because this code runs very quickly, but just the right timing conditions are present and IRQ0 hits in this small, ~30 usecs window, timer irqs stop and the system does not boot up. Also, given how early this is during bootup, the hang is very deterministic - but it would only occur on certain machines (and certain configs). The fix was quite simple: disable/restore interrupts properly in this function. With that in place the test-system now boots up just fine. (64-bit x86 io_apic_64.c had the same bug.) Phew! One down, only 1500 other kernel bugs are left ;-) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-18x86: kprobes bugfixMasami Hiramatsu
Kprobes for x86-64 may cause a kernel crash if it inserted on "iret" instruction. "call absolute" is invalid on x86-64, so we don't need treat it. - Change the processing order as same as x86-32. - Add "iret"(0xcf) case. - Remove next_rip local variable. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-18x86: jprobe bugfixMasami Hiramatsu
jprobe for x86-64 may cause kernel page fault when the jprobe_return() is called from incorrect function. - Use jprobe_saved_regs instead getting it from stack. (Especially on x86-64, it may get incorrect data, because pt_regs can not be get by using container_of(rsp)) - Change the type of stack pointer to unsigned long *. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-18oprofile: op_model_athlon.c support for AMD family 10h barcelona performance ↵Barry Kasindorf
counters This patch is for controlling the upper 32bits of the event ctrl msrs. This includes the upper 4 bits of the event select and the Guest Only and Host Only bits This patch is necessary to make Event Based Profiling work reliably on a Family 10h processor [akpm@linux-foundation.org: checkpatch.pl fixes] Signed-off-by: Barry Kasindorf <barry.kasindorf@amd.com> Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-17alpha: build fixesIvan Kokshaysky
This fixes some of the alpha-specific build problems, except a) modpost warning about COMMON symbol "saved_config" and b) nasty final link failure with gcc-4.x, -Os and scsi-disk driver configured built-in (due to jump table in .rodata referencing discarded .exit.text). - build failure with gcc-4.2.x: fix up casts in cia_io* routines to avoid warnings ('discards qualifiers from pointer target type'), which are failures, thanks to -Werror; - modpost warnings: add missing __init qualifier for titan and marvel; for non-generic build, move machine vectors from .data to .data.init.refok section; - unbreak CPU-specific optimization: rearrange cpuflags-y assignments so that extended -mcpu value (ev56, pca56, ev67) overrides basic one (ev5, ev6) and not vice versa. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17alpha: strncpy/strncat fixesIvan Kokshaysky
First of all, thanks to Bob Tracy <rct@frus.com> and Michael Cree <mcree@orcon.net.nz> for testing. Especially to Bob, as he has done titanic multi-day git-bisect work that finally helped to reproduce and nail down the bug (http://bugzilla.kernel.org/show_bug.cgi?id=9457). [ev6-]stxncpy.S: it's t12, not t2 register that is supposed to contain the last byte offset upon return. As a result of wrong register use (which was my fault back in 2003, IIRC), under some circumstances extra terminating zero bytes were added to destination string. This particularly led to incorrect DEVPATH strings generated in uevent and therefore to udev problems. strncpy.S: unrelated bug I found while testing the above fix - destination is not properly zero-padded then a byte count exceeds source length. Actually this is addition to strncpy fix from last year. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Bob Tracy <rct@frus.com> Cc: Michael Cree <mcree@orcon.net.nz> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17uml: stop gdb from deleting breakpoints when running UMLStanislaw Gruszka
Sometimes when UML is debugged gdb miss breakpoints. When process traced by gdb do fork, debugger remove breakpoints from child address space. There is possibility to trace more than one fork, but this not work with UML, I guess (only guess) there is a deadlock - gdb waits for UML and UML waits for gdb. When clone() is called with SIGCHLD and CLONE_VM flags, gdb see this as PTRACE_EVENT_FORK not as PTRACE_EVENT_CLONE and remove breakpoints from child and at the same time from traced process, because either have the same address space. Maybe it is possible to do fix in gdb, but I'm not sure if there is easy way to find out if traced and child processes share memory. So I do fix for UML, it simply do not call clone() with both SIGCHLD and CLONE_VM flags together. Additionally __WALL flag is used for waitpid() to assure not miss clone and normal process events. [ jdike - checkpatch fixes ] Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17revert "Hibernation: Use temporary page tables for kernel text mapping on ↵Andrew Morton
x86_64" Revert commit efa4d2fb047b25a6be67fe92178a2a78da6b3f6a ("Hibernation: Use temporary page tables for kernel text mapping on x86_64") because it causes my t61p to reboot right at the end of resume-from-disk. For reasons unknown at this time. Cc: Pavel Machek <pavel@ucw.cz> Cc: Andi Kleen <ak@suse.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 4694/1: IXP4xx: Update clockevent support for shutdown and resume [ARM] 4710/1: Fix coprocessor 14 usage for debug messages via ICEDCC [ARM] 4690/1: PXA: fix CKEN corruption in PXA27x AC97 cold reset code [ARM] 4667/1: CM-X270 fixes
2007-12-17[ARM] 4694/1: IXP4xx: Update clockevent support for shutdown and resumeKevin Hilman
Add proper support for CLOCK_EVT_MODE_RESUME and in the process fix CLOCK_EVT_MODE_SHUTDOWN so that only the enable bits are toggled for both. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-12-17[ARM] 4710/1: Fix coprocessor 14 usage for debug messages via ICEDCCUwe Kleine-König
According to ARM7TDMI Technical Reference Manual (ARM DDI 0210C) writing to the DCC data write register coproc dest registers are 1 and 0, not 0 and 1. ARM920T TRM (ARM DDI 0151C) agrees on that. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-12-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC32]: Silence sparc32 warnings on missing syscalls. [SPARC64]: Fix two kernel linear mapping setup bugs.
2007-12-17Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Make PS3_SYS_MANAGER default y, not m [POWERPC] Fix rounding bug in emulation for double float operating [POWERPC] iSeries: don't printk with HV spinlock held [POWERPC] 82xx: mpc8272ads, pq2fads: Update defconfig with CONFIG_FS_ENET_MDIO_FCC [POWRPC] CPM2: Eliminate section mismatch warning in cpm2_reset(). [POWERPC] Kill non-existent symbols from ksyms and commproc.h [POWERPC] Fix typo #ifdef -> #ifndef
2007-12-14[MIPS] Ensure that ST0_FR is never set on a 32 bit kernelChris Dearman
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-12-14[MIPS] time: Delete weak definition of plat_time_init() due to gcc bug.Ralf Baechle
Frank Rowand <frank.rowand@am.sony.com> reports: > In linux-2.6.24-rc4 the Toshiba RBTX4927 hangs on boot. > > The cause is that plat_time_init() from arch/mips/tx4927/common/ > tx4927_setup.c does not override the __weak plat_time_init() from > arch/mips/kernel/time.c. This is due to a compiler bug in gcc 4.1.1. The > bug is reported to not exist in earlier versions of gcc, and to be fixed in > 4.1.2. The problem is that the __weak plat_time_init() is empty and thus > gets optimized out of existence (thus the linker is never given the option > to replace the __weak function). [ He meant the call to plat_time_init() from time_init() gets optimized away ] > For more info on the gcc bug see > > http://gcc.gnu.org/bugzilla/show_bug.cgi?id=27781 > > The attached patch is one workaround. Another possible workaround [ His patch adds -fno-unit-at-a-time for time.c ] > would be to change the __weak plat_time_init() to be a non-empty > function. The __weak definition of plat_time_init was only ever meant to be a migration helper to keep platforms that don't have a plat_time_init compiling. A few greps says that all platforms now supply their own plat_time_init() so the weak definition is no longer needed. So I instead delete it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-12-14[MIPS] PCI: Make pcibios_fixup_device_resources ignore legacy resources.Ralf Baechle
There might be other reasons why a resource might be marked as fixed such as a PCI UART holding the system console but until we use IORESOURCE_PCI_FIXED that way also this will work. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-12-14[MIPS] Atlas, Malta: Don't free firmware memory on free_initmem.Ralf Baechle
A proper fix for this needs to turn a few MIPS-generic bits which I don't want at this stage. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-12-14[MIPS] Alchemy: fix off by two error in __fixup_bigphys_addr()Sergei Shtylyov
the PCI specific code in this function doesn't check for the address range being under the upper bound of the PCI memory window correctly -- fix this, somewhat beautifying the code around the check, while at it... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
