path: root/arch
2011-05-20Merge commit '317f394160e9beb97d19a84c39b7e5eb3d7815a8'David S. Miller
Conflicts: arch/sparc/kernel/smp_32.c With merge conflict help from Daniel Hellstrom. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6
2011-05-16sparc32,leon: Remove unnecessary page_address calls in LEON DMA API.Kristoffer Glembo
The function mmu_inval_dma_area takes a virtual address as a parameter which is problematic in case the buffer is located in highmem and the mapping currently is unavailable. Since the function was only implemented for LEON this patch removes calls to it in non LEON code paths and renames it to dma_make_coherent which instead takes a physical address (which for now is unused since we flush the whole cache). This way it is possible to remove several unnecessary calls to page_address which will fail if the virtual mapping is unavailable. Signed-off-by: Kristoffer Glembo <kristoffer@gaisler.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16sparc: convert old cpumask API into new oneKOSAKI Motohiro
Adapt new API. Almost change is trivial, most important change are to remove following like =operator. cpumask_t cpu_mask = *mm_cpumask(mm); cpus_allowed = current->cpus_allowed; Because cpumask_var_t is =operator unsafe. These usage might prevent kernel core improvement. No functional change. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16sparc32, sun4d: Implemented SMP IPIs support for SUN4D machinesDaniel Hellstrom
The sun4d does not seem to have a distingstion between soft and hard IRQs. When generating IPIs the generated IRQ looks like a hard IRQ, this patch adds a "IPI check" in the sun4d irq trap handler at a predefined IRQ number (SUN4D_IPI_IRQ). Before generating an IPI a per-cpu memory structure is modified for the "IPI check" to successfully detect a IPI request to a specific processor, the check clears the IPI work requested. All three IPIs (resched, single and cpu-mask) use the same IRQ number. The IPI IRQ should preferrably be on a separate IRQ and definitly not shared with IRQ handlers requesting IRQ with IRQF_SHARED. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16sparc32, sun4m: Implemented SMP IPIs support for SUN4M machinesDaniel Hellstrom
Implement the three IPIs (resched, single and cpu-mask) generation and interrupt handler catch. The sun4m has 15 soft-IRQs and three of them is used with this patch, the three IPIs was previously implemented with the cross-call IRQ15 which does not work with locking routines such as spinlocks because IRQ15 is NMI, it may cause deadlock. The IRQ trap handler code assumes (in the same spritit as the old it seems) that hard interrupts will be generated until handled (level), when a IRQ happens the IRQ pending register is checked for pending soft-IRQs. When both hard and soft IRQ happens at the same time only soft-IRQs are handled. The old code implemented a soft-IRQ traphandler at IRQ14 which called smp_reschedule_irq which in turn called set_need_resched. It seems to be an old relic and is replaced with the interrupt traphander exit code RESTORE_ALL, it calls schedule() when appropriate. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16sparc32,leon: Implemented SMP IPIs for LEON CPUDaniel Hellstrom
This patch implements SMP IPIs on LEON using software generated IRQs to signal between CPUs. The IPI IRQ number is set by using the ipi_num property in the device tree, or defaults to 13. LEON SMP systems should reserve IRQ 13 (and IRQ 15) to Linux in order for the defaults to work. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16sparc32: implement SMP IPIs using the generic functionsDaniel Hellstrom
The current sparc32 SMP IPI generation is implemented the cross call function. The cross call function uses IRQ15 the NMI, this is has the effect that IPIs will interrupt IRQ critical areas and hang the system. Typically on/after spin_lock_irqsave calls can be aborted. The cross call functionality must still exist to flush cache/TLBS. This patch provides CPU models a custom way to implement generation of IPIs on the generic code's request. The typical approach is to generate an IRQ for each IPI case. After this patch each sparc32 SMP CPU model needs to implement IPIs in order to function properly. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16sparc32,leon: SMP power down implementationDaniel Hellstrom
2011-05-16sparc32,leon: added some SMP commentsDaniel Hellstrom
2011-05-12sparc: add {read,write}*_be routinesJan Andersson
This patch adds {read,write}*_be big endian memory access routines to the io.h header used on SPARC32 and SPARC64. Tested on SPARC32 (LEON) Signed-off-by: Jan Andersson <jan@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11sparc32: Fixed unaligned memory copying in function ↵Tkhai Kirill
__csum_partial_copy_sparc_generic When we are in the label cc_dword_align, registers %o0 and %o1 have the same last 2 bits, but it's not guaranteed one of them is zero. So we can get unaligned memory access in label ccte. Example of parameters which lead to this: %o0=0x7ff183e9, %o1=0x8e709e7d, %g1=3 With the parameters I had a memory corruption, when the additional 5 bytes were rewritten. This patch corrects the error. One comment to the patch. We don't care about the third bit in %o1, because cc_end_cruft stores word or less. Signed-off-by: Tkhai Kirill <tkhai@yandex.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sparc32,leon: don't rely on bootloader to mask IRQsDaniel Hellstrom
2011-04-21sparc32,leon: operate on boot-cpu IRQ controller registersDaniel Hellstrom
* proper initialization of boot_cpu_id (no hardcoding to 0) * use boot_cpu_id index to address into the IRQ controller where appropriate Each CPU has a separate set of IRQ controller registers, this patch makes sure that the boot-cpu registers are used instead of CPU0's. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sparc32: always define boot_cpu_idDaniel Hellstrom
Define boot_cpu_id in single-processor kernels as well. This is to support architectures which can boot on other than CPU0. Sam Ravnborg has written the cleanup parts by extracting boot_cpu_id from smp_32.c into setup_32.c and cleaned up sun4d_irq.c. boot_cpu_id was initialized before BSS was cleared in sun4c_continue_boot, instead boot_cpu_id is set to 0xff to avoid BSS. If boot_cpu_id is untouched (0xff) by bootup code it will be overwritten to 0. boot_cpu_id4 is automatically calculated in common code. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sparc32: removed unused code, implemented by generic codeDaniel Hellstrom
2011-04-21sparc32: fix sparcstation 5 bootSam Ravnborg
The sparcstation 5 I have available has no MID property for the CPU. This resulted in a panic when booting a SMP kernel on this box. The assigned field in cpu_data is never used, so if we fail to read the MID property then inform user and continue booting. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sparc32: avoid build warning at mm/percpu.c:1647Sam Ravnborg
Fix following warning: mm/percpu.c: In function 'pcpu_embed_first_chunk': mm/percpu.c:1647:3: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'unsigned int' Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> [sam: added warning message to changelog, use _AC()] Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sparc32: always register a PROM based early consoleSam Ravnborg
Do not require user to add "-p" to boot arguments to see early info printed to prom console. This is similar to the sparc64 functionality - which was added with: 3c62a2d3477ff7725210db57aec3d2806fa10c20 ("[SPARC64]: Always register a PROM based early console.") Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sparc32: probe for cpu info only during startupSam Ravnborg
We did a cpu_probe() call each time a CPU got online - which only effect was to save latest CPU/FPU info for use by show_cpuinfo(). Use same setup as for sparc64 where we probe for this info during startup, and only once. This allowed us to annotate a few functions __init which again fixed the following section mismatch warnings: WARNING: vmlinux.o(.text+0x65f0): Section mismatch in reference from the function set_cpu_and_fpu() to the (unknown reference) .init.rodata:(unknown) WARNING: vmlinux.o(.text+0x65f8): Section mismatch in reference from the function set_cpu_and_fpu() to the (unknown reference) .init.rodata:(unknown) WARNING: vmlinux.o(.text+0x664c): Section mismatch in reference from the function set_cpu_and_fpu() to the variable .init.rodata:manufacturer_info WARNING: vmlinux.o(.text+0x6650): Section mismatch in reference from the function set_cpu_and_fpu() to the variable .init.rodata:manufacturer_info Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sparc: consolidate show_cpuinfo in cpu.cSam Ravnborg
We have all the cpu related info in cpu.c - so move the remaining functions to support /proc/cpuinfo to this file. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sparc32: fix section mismatch warnings in apc, pmc and time_32Sam Ravnborg
In all cases there were a struct of_device_id variable defined __initdata. But it was referenced from struct platform_driver.of_match_table which is not guaranteed to be used during init only. So drop the __initdata annotation. This fixes following warnings: WARNING: arch/sparc/kernel/built-in.o(.data+0x810): Section mismatch in reference from the variable clock_driver to the variable .init.data:clock_match The variable clock_driver references the variable __initdata clock_match If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console WARNING: arch/sparc/kernel/built-in.o(.data+0xcec): Section mismatch in reference from the variable apc_driver to the variable .init.data:apc_match The variable apc_driver references the variable __initdata apc_match If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console WARNING: arch/sparc/kernel/built-in.o(.data+0xd60): Section mismatch in reference from the variable pmc_driver to the variable .init.data:pmc_match The variable pmc_driver references the variable __initdata pmc_match If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sparc32,leon: implement genirq CPU affinityDaniel Hellstrom
A simple implementation of CPU affinity, the first CPU in the affinity CPU mask always takes the IRQ. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sparc32, leon: code cleanup of timer/IRQ controller initializationDaniel Hellstrom
Cleaned up leon_init_timers() by removing unnecessary double checking and one indentation level. Changed LEON_IMASK to LEON_IMASK(cpu). Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sparc32,leon: cleaned away code from the LEON2 daysDaniel Hellstrom
2011-04-21sparc32,leon: per-cpu ticker use genirq per-cpu handlerDaniel Hellstrom
2011-04-21sparc32,leon: add support for extended interrupt controllerDaniel Hellstrom
The extended IRQ controller gives the LEON 16 more IRQs. The patch installs a custom handler for the exetended controller IRQ, where a register is read and the "real" IRQ causing IRQ is determined. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sparc32, leon: must protect IRQ controller register with spinlockDaniel Hellstrom
The LEON interrupt controller has one single mask register for all IRQs per CPU, even though the genirq layer protects us from accessing the same IRQ at the same time other IRQs share the same mask register and may thus interfere. Some other IRQ controllers has a mask register or similar per IRQ instead which makes spinlocks unncessary. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19sparc32: genirq supportSam Ravnborg
The conversion of sparc32 to genirq is based on original work done by David S. Miller. Daniel Hellstrom has helped in the conversion and implemented the shutdowm functionality. Marcel van Nies <morcles@gmail.com> has tested this on Sparc Station 20 Test status: sun4c - not tested sun4m,pci - not tested sun4m,sbus - tested (Sparc Classic, Sparc Station 5, Sparc Station 20) sun4d - not tested leon - tested on various combinations of leon boards, including SMP variants generic Introduce use of GENERIC_HARDIRQS and GENERIC_IRQ_SHOW Allocate 64 IRQs - which is enough even for SS2000 Use a table of irq_bucket to maintain uses IRQs irq_bucket is also used to chain several irq's that must be called when the same intrrupt is asserted Use irq_link to link a interrupt source to the irq All plafforms must now supply their own build_device_irq method handler_irq rewriten to use generic irq support floppy Read FLOPPY_IRQ from platform device Use generic request_irq to register the floppy interrupt Rewrote sparc_floppy_irq to use the generic irq support pcic: Introduce irq_chip Store mask in chip_data for use in mask/unmask functions Add build_device_irq for pcic Use pcic_build_device_irq in pci_time_init allocate virtual irqs in pcic_fill_irq sun4c: Introduce irq_chip Store mask in chip_data for use in mask/unmask functions Add build_device_irq for sun4c Use sun4c_build_device_irq in sun4c_init_timers sun4m: Introduce irq_chip Introduce dedicated mask/unmask methods Introduce sun4m_handler_data that allow easy access to necessary data in the mask/unmask functions Add a helper method to enable profile_timer (used from smp) Added sun4m_build_device_irq Use sun4m_build_device_irq in sun4m_init_timers TODO: There is no replacement for smp_rotate that always scheduled next CPU as interrupt target upon an interrupt sun4d: Introduce irq_chip Introduce dedicated mask/unmask methods Introduce sun4d_handler_data that allow easy access to necessary data in mask/unmask fuctions Rewrote sun4d_handler_irq to use generic irq support TODO: The original implmentation of enable/disable had: if (irq < NR_IRQS) return; The new implmentation does not distingush between SBUS and cpu interrupts. I am no sure what is right here. I assume we need to do something for the cpu interrupts. I have not succeeded booting my sun4d box (with or without this patch) and my understanding of this platfrom is limited. So I would be a bit suprised if this works. leon: Introduce irq_chip Store mask in chip_data for use in mask/unmask functions Add build_device_irq for leon Use leon_build_device_irq in leon_init_timers Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Daniel Hellstrom <daniel@gaisler.com> Tested-by: Daniel Hellstrom <daniel@gaisler.com> Tested-by: Marcel van Nies <morcles@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19sparc32: cleanup code for pci initSam Ravnborg
Move the ifdeffery to a header file to make the logic more obvious where we decide between PCI or SBUS init Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19sparc32,sun4d: rename sbus_tid to board_to_cpu in irq supportSam Ravnborg
The new name reflects the actual usage much better. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, gart: Make sure GART does not map physmem above 1TB x86, gart: Set DISTLBWALKPRB bit always x86, gart: Convert spaces to tabs in enable_gart_translation
2011-04-19Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf, x86: Fix AMD family 15h FPU event constraints perf, x86: Fix pre-defined cache-misses event for AMD family 15h cpus perf evsel: Fix use of inherit perf hists browser: Fix seg fault when annotate null symbol
2011-04-19perf, x86: Fix AMD family 15h FPU event constraintsRobert Richter
Depending on the unit mask settings some FPU events may be scheduled only on cpu counter #3. This patch fixes this. Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@googlemail.com> Link: http://lkml.kernel.org/r/1302913676-14352-3-git-send-email-robert.richter@amd.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-19perf, x86: Fix pre-defined cache-misses event for AMD family 15h cpusAndre Przywara
With AMD cpu family 15h a unit mask was introduced for the Data Cache Miss event (0x041/L1-dcache-load-misses). We need to enable bit 0 (first data cache miss or streaming store to a 64 B cache line) of this mask to proper count data cache misses. Now we set this bit for all families and models. In case a PMU does not implement a unit mask for event 0x041 the bit is ignored. Signed-off-by: Andre Przywara <andre.przywara@amd.com> Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1302913676-14352-2-git-send-email-robert.richter@amd.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-18Merge branch 'for-39-rc4' of git://codeaurora.org/quic/kernel/davidb/linux-msmLinus Torvalds
* 'for-39-rc4' of git://codeaurora.org/quic/kernel/davidb/linux-msm: msm: timer: fix missing return value msm: Remove extraneous ffa device check
2011-04-18x86, gart: Make sure GART does not map physmem above 1TBJoerg Roedel
The GART can only map physical memory below 1TB. Make sure the gart driver in the kernel does not try to map memory above 1TB. Cc: <stable@kernel.org> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Link: http://lkml.kernel.org/r/1303134346-5805-5-git-send-email-joerg.roedel@amd.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2011-04-18x86, gart: Set DISTLBWALKPRB bit alwaysJoerg Roedel
The DISTLBWALKPRB bit must be set for the GART because the gatt table is mapped UC. But the current code does not set the bit at boot when the BIOS setup the aperture correctly. Fix that by setting this bit when enabling the GART instead of the other places. Cc: <stable@kernel.org> Cc: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Link: http://lkml.kernel.org/r/1303134346-5805-4-git-send-email-joerg.roedel@amd.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2011-04-18x86, gart: Convert spaces to tabs in enable_gart_translationJoerg Roedel
Probably by copy&paste this function was indented by spaces. Convert this to tabs. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Link: http://lkml.kernel.org/r/1303134346-5805-3-git-send-email-joerg.roedel@amd.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2011-04-18powerpc/powermac: Build fix with SMP and CPU hotplugBenjamin Herrenschmidt
2011-04-18powerpc/perf_event: Skip updating kernel counters if register value shrinksEric B Munson
Because of speculative event roll back, it is possible for some event coutners to decrease between reads on POWER7. This causes a problem with the way that counters are updated. Delta calues are calculated in a 64 bit value and the top 32 bits are masked. If the register value has decreased, this leaves us with a very large positive value added to the kernel counters. This patch protects against this by skipping the update if the delta would be negative. This can lead to a lack of precision in the coutner values, but from my testing the value is typcially fewer than 10 samples at a time. Signed-off-by: Eric B Munson <emunson@mgebm.net> Cc: stable@kernel.org Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-18powerpc: Don't write protect kernel text with CONFIG_DYNAMIC_FTRACE enabledStefan Roese
This problem was noticed on an MPC855T platform. Ftrace did oops when trying to write to the kernel text segment. Many thanks to Joakim for finding the root cause of this problem. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Joakim Tjernlund <joakim.tjernlund@transmode.se> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-18powerpc: Fix oops if scan_dispatch_log is called too earlyAnton Blanchard
We currently enable interrupts before the dispatch log for the boot cpu is setup. If a timer interrupt comes in early enough we oops in scan_dispatch_log: Unable to handle kernel paging request for data at address 0x00000010 ... .scan_dispatch_log+0xb0/0x170 .account_system_vtime+0xa0/0x220 .irq_enter+0x88/0xc0 .do_IRQ+0x48/0x230 The patch below adds a check to scan_dispatch_log to ensure the dispatch log has been allocated. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: <stable@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-18powerpc/pseries: Use a kmem cache for DTL buffersNishanth Aravamudan
PAPR specifies that DTL buffers can not cross AMS environments (aka CMO in the PAPR) and can not cross a memory entitlement granule boundary (4k). This is found in section 14.11.3.2 H_REGISTER_VPA of the PAPR. kmalloc does not guarantee an alignment of the allocation, though, beyond 8 bytes (at least in my understanding). Create a special kmem cache for DTL buffers with the alignment requirement. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-18powerpc/kexec: Fix regression causing compile failure on UPPaul Gortmaker
Recent commit b987812b3fcaf70fdf0037589e5d2f5f2453e6ce caused a compile failure on UP because a considerably large block of the file was included within CONFIG_SMP, hence making a stub function not exposed on UP builds when it needed to be. Relocate the stub to the #else /* ! CONFIG_SMP */ section and also annotate the relevant else/endif so that nobody else falls into the same trap I did. Reported-by: Michael Guntsche <mike@it-loops.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-18Merge remote branch 'kumar/merge' into mergeBenjamin Herrenschmidt
2011-04-17Merge branch 's5p-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung * 's5p-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: SAMSUNG: Fix warning 's3c_pm_show_resume_irqs' defined but not used ARM: SAMSUNG: Fix build failure in PM CRC check code ARM: S5P: Remove unused s3c_pm_check_resume_pin
2011-04-17alpha: Fix uninitialized value in read_persistent_clock.Richard Henderson
Signed-off-by: Richard Henderson <rth@twiddle.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-17alpha: Fix RTC interrupt setup.Richard Henderson
Following commit 091738a266fc ("genirq: Remove real old transition functions") we removed an automatic conversion of no_irq_chip to dummy_irq_chip. This change needs to be propagated back into the alpha backend. Signed-off-by: Richard Henderson <rth@twiddle.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-17alpha: Remove set but unused variables.Richard Henderson
This is a new warning in gcc 4.6. Several of these variables are used within #if 0 code, which probably ought to be removed. Most of the changes are legitimate cleanups. Signed-off-by: Richard Henderson <rth@twiddle.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
