path: root/arch
2011-01-17powerpc: perf: Fix frequency calculation for overflowing countersAnton Blanchard
When profiling a benchmark that is almost 100% userspace, I noticed some wildly inaccurate profiles that showed almost all time spent in the kernel. Closer examination shows we were programming a tiny number of cycles into the PMU after each overflow (about ~200 away from the next overflow). This gets us stuck in a loop which we eventually break out of by throttling the PMU (there are regular throttle/unthrottle events in the log). It looks like we aren't setting event->hw.last_period to something same and the frequency to period calculations in perf are going haywire. With the following patch we find the correct period after a few interrupts and stay there. I also see no more throttle events. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: linuxppc-dev@lists.ozlabs.org Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> LKML-Reference: <20110117161742.5feb3761@kryten> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-17alpha: fix WARN_ON in __local_bh_enable()Ivan Kokshaysky
Interrupts ought to be disabled _before_ irq_enter(). Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Matt Turner <mattst88@monolith.freenet-rz.de>
2011-01-17alpha: fix breakage caused by df9ee29270Ivan Kokshaysky
Commit df9ee29270 made arch_local_irq_save and arch_local_irq_restore static inline which with -Werror trips up on __set_hae() and _set_hae() which are extern inline. The naive solution is to make __set_hae() and set_hae() static inline but for reasons described in commit d559d4a24a3fe this breaks the generic kernel build. Instead, since this is architecture specific code, this patch hard wires in the architecture specific method f disabling and enabling interrupts. Tested-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-01-17alpha: add GENERIC_HARDIRQS_NO__DO_IRQ to KconfigMatt Turner
Acked-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-01-17alpha/osf_sys: remove unused MAX_SELECT_SECONDSNamhyung Kim
Remove the leftover from the commit 14e2acd86865 ("select: fix alpha OSF wrapper"). Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-01-17alpha: change to new Makefile flag variablesmatt mooney
Signed-off-by: matt mooney <mfm@muteddisk.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-01-17alpha: kill off alpha_do_IRQKyle McMartin
Good riddance... Nuke a pile of redundant handlers that the generic code takes care of as well. Tested-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-01-17alpha: irq clean upKyle McMartin
Stop touching irq_desc[irq] directly, instead use accessor functions provided. Use irq_has_action instead of directly testing the irq_desc. Tested-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-01-17alpha: use set_irq_chip and push down __do_IRQ to the machine typesKyle McMartin
Also kill superfluous IRQ_DISABLED initialization, since that's the default state of the irq_desc[i].status field. Tested-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-01-16parisc: fix compile breakage caused by inlining maybe_mkwriteJames Bottomley
On PARISC, we have an include of linux/mm.h inside our asm/pgtable.h, so this patch commit 14fd403f2146f740942d78af4e0ee59396ad8eab Author: Andrea Arcangeli <aarcange@redhat.com> Date: Thu Jan 13 15:46:37 2011 -0800 thp: export maybe_mkwrite causes us an unsatisfiable use of pte_mkwrite in linux/mm.h. The fix is to avoid including linux/mm.h in our pgtable.h, which unbreaks the build. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-16microblaze: Fix asm/pgtable.hMichal Simek
Function ptep_test_and_clear_young have had wrong the first argument. It is also necessary to add __HAVE macros for ptep_test_and_clear_young and ptep_get_and_clear functions. Error log: In file included from linux/arch/microblaze/include/asm/pgtable.h:570, from arch/microblaze/mm/pgtable.c:35: include/asm-generic/pgtable.h:23: error: conflicting types for 'ptep_test_and_clear_young' linux/arch/microblaze/include/asm/pgtable.h:449: error: previous definition of 'ptep_test_and_clear_young' was here include/asm-generic/pgtable.h:73: error: redefinition of 'ptep_get_and_clear' linux/arch/microblaze/include/asm/pgtable.h:462: error: previous definition of 'ptep_get_and_clear' was here Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-01-16microblaze: Fix missing pagemap.hMichal Simek
Add missing linux/pagemap.h to solve compilation error. Error log: In file included from linux/arch/microblaze/include/asm/tlb.h:17, from mm/pgtable-generic.c:9: include/asm-generic/tlb.h: In function 'tlb_flush_mmu': include/asm-generic/tlb.h:76: error: implicit declaration of function 'release_pages' include/asm-generic/tlb.h: In function 'tlb_remove_page': include/asm-generic/tlb.h:105: error: implicit declaration of function 'page_cache_release' Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-01-15dt/flattree: Return virtual address from early_init_dt_alloc_memory_arch()Grant Likely
The physical address is never used by the device tree code when allocating memory for unflattening. Change the architecture's alloc hook to return the virutal address instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-15Merge branches 'core-fixes-for-linus', 'x86-fixes-for-linus', ↵Linus Torvalds
'timers-fixes-for-linus' and 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: avoid pointless blocked-task warnings rcu: demote SRCU_SYNCHRONIZE_DELAY from kernel-parameter status rtmutex: Fix comment about why new_owner can be NULL in wake_futex_pi() * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, olpc: Add missing Kconfig dependencies x86, mrst: Set correct APB timer IRQ affinity for secondary cpu x86: tsc: Fix calibration refinement conditionals to avoid divide by zero x86, ia64, acpi: Clean up x86-ism in drivers/acpi/numa.c * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: timekeeping: Make local variables static time: Rename misnamed minsec argument of clocks_calc_mult_shift() * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: Remove syscall_exit_fields tracing: Only process module tracepoints once perf record: Add "nodelay" mode, disabled by default perf sched: Fix list of events, dropping unsupported ':r' modifier Revert "perf tools: Emit clearer message for sys_perf_event_open ENOENT return" perf top: Fix annotate segv perf evsel: Fix order of event list deletion
2011-01-15Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (161 commits) ARM: pxa: fix building issue of missing physmap.h ARM: mmp: PXA910 drive strength FAST using wrong value ARM: mmp: MMP2 drive strength FAST using wrong value ARM: pxa: fix recursive calls in pxa_low_gpio_chip AT91: Support for gsia18s board AT91: Acme Systems FOX Board G20 board files AT91: board-sam9m10g45ek.c: Remove duplicate inclusion of mach/hardware.h ARM: pxa: fix suspend/resume array index miscalculation ARM: pxa: use cpu_has_ipr() consistently in irq.c ARM: pxa: remove unused variable in clock-pxa3xx.c ARM: pxa: fix warning in zeus.c ARM: sa1111: fix typo in sa1111_retrigger_lowirq() ARM mxs: clkdev related compile fixes ARM i.MX mx31_3ds: Fix MC13783 regulator names ARM: plat-stmp3xxx: irq_data conversion. ARM: plat-spear: irq_data conversion. ARM: plat-orion: irq_data conversion. ARM: plat-omap: irq_data conversion. ARM: plat-nomadik: irq_data conversion. ARM: plat-mxc: irq_data conversion. ... Fix up trivial conflict in arch/arm/plat-omap/gpio.c (Lennert Buytenhek's irq_data conversion clashing with some omap irq updates)
2011-01-15Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: fix missing branch in __error_a ARM: fix /proc/$PID/stack on SMP ARM: Fix build regression on SA11x0, PXA, and H720x targets ARM: 6625/1: use memblock memory regions for "System RAM" I/O resources ARM: fix wrongly patched constants ARM: 6624/1: fix dependency for CONFIG_SMP_ON_UP ARM: 6623/1: Thumb-2: Fix out-of-range offset for Thumb-2 in proc-v7.S ARM: 6622/1: fix dma_unmap_sg() documentation ARM: 6621/1: bitops: remove condition code clobber for CLZ ARM: 6620/1: Change misleading warning when CONFIG_CMDLINE_FORCE is used ARM: 6619/1: nommu: avoid mapping vectors page when !CONFIG_MMU ARM: sched_clock: make minsec argument to clocks_calc_mult_shift() zero ARM: sched_clock: allow init_sched_clock() to be called early ARM: integrator: fix compile warning in cpu.c ARM: 6616/1: Fix ep93xx-fb init/exit annotations ARM: twd: fix display of twd frequency ARM: udelay: prevent math rounding resulting in short udelays
2011-01-15parisc: fix compile breakage caused by inlining maybe_mkwriteJames Bottomley
on Parisc, we have an include of linux/mm.h inside our asm/pgtable.h, so this patch commit 14fd403f2146f740942d78af4e0ee59396ad8eab Author: Andrea Arcangeli <aarcange@redhat.com> Date: Thu Jan 13 15:46:37 2011 -0800 thp: export maybe_mkwrite Causes us an unsatisfiable use of pte_mkwrite in linux/mm.h The fix is obviously not to include linux/mm.h in our pgtable.h, which unbreaks the build. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-15parisc : Remove broken line wrapping handling pdc_iodc_print()Guy Martin
Remove the broken line wrapping handling in pdc_iodc_print(). It is broken in 3 ways : - It doesn't keep track of the current screen position, it just assumes that the new buffer will be printed at the begining of the screen. - It doesn't take in account that non printable characters won't increase the current position on the screen. - And last but not least, it triggers a kernel panic if a backspace is the first char in the provided buffer : Backtrace: [<0000000040128ec4>] pdc_console_write+0x44/0x78 [<0000000040128f18>] pdc_console_tty_write+0x20/0x38 [<000000004032f1ac>] n_tty_write+0x2a4/0x550 [<000000004032b158>] tty_write+0x1e0/0x2d8 [<00000000401bb420>] vfs_write+0xb8/0x188 [<00000000401bb630>] sys_write+0x68/0xb8 [<0000000040104eb8>] syscall_exit+0x0/0x14 Most terminals handle the line wrapping just fine. I've confirmed that it works correctly on a C8000 with both vga and serial output. Signed-off-by: Guy Martin <gmsoft@tuxicoman.be> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-15Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable
2011-01-15Merge branch 'devel' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable
2011-01-15ARM: fix missing branch in __error_aRussell King
When DEBUG_LL is not set, we don't want __error_a re-entering __lookup_machine_type - we want it to go to the error function. This used to be the case before we reorganized the layout for hotplug cpu, as we used to fall through to __error. With the changed layout, we need an explicit branch here instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-15ARM: pxa: fix building issue of missing physmap.hEric Miao
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-01-15ARM: mmp: PXA910 drive strength FAST using wrong valuePhilip Rakity
Drive strength for PXA910 is a 2 bit value but because of the mapping in plat-pxa/mfp.h needs to be shifted up one bit to handle real location in mfp registers. (MMP2 and PXA910 drive strength start at bit 11 while PXA168 starts at bit 10). Values 0, 1, 2, and 3 effectively need to be 0, 2, 4, and 6 to fit into register. 8 does not work. Signed-off-by: Philip Rakity <prakity@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-01-15ARM: mmp: MMP2 drive strength FAST using wrong valuePhilip Rakity
Drive strength for MMP2 is a 2 bit value but because of the mapping in plat-pxa/mfp.h needs to be shifted up one bit to handle real location in mfp registers. (MMP2 and PXA910 drive strength start at bit 11 while PXA168 starts at bit 10). Values 0, 1, 2, and 3 effectively need to be 0, 2, 4, and 6 to fit into register. 8 does not work. Signed-off-by: Philip Rakity <prakity@marvell.com> Tested-by: John Watlington <wad@laptop.org> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-01-15ARM: pxa: fix recursive calls in pxa_low_gpio_chipEric Miao
Signed-off-by: Eric Miao <eric.y.miao@gmail.com> Tested-by: Marek Vasut <marek.vasut@gmail.com>
2011-01-15ARM: fix /proc/$PID/stack on SMPRussell King
Rabin Vincent reports: | On SMP, this BUG() in save_stack_trace_tsk() can be easily triggered | from user space by reading /proc/$PID/stack, where $PID is any pid but | the current process: | | if (tsk != current) { | #ifdef CONFIG_SMP | /* | * What guarantees do we have here that 'tsk' | * is not running on another CPU? | */ | BUG(); | #else Fix this by replacing the BUG() with an entry to terminate the stack trace, returning an empty trace - I'd rather not expose the dwarf unwinder to a volatile stack of a running thread. Reported-by: Rabin Vincent <rabin@rab.in> Tested-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-15ARM: Fix build regression on SA11x0, PXA, and H720x targetsRussell King
Build errors similar this appeared in todays kautobuild for the above targets: In file included from arch/arm/include/asm/pgtable.h:461, from arch/arm/mach-pxa/generic.c:26: include/asm-generic/pgtable.h: In function 'ptep_test_and_clear_young': include/asm-generic/pgtable.h:29: error: dereferencing pointer to incomplete type None of the .c files including asm/pgtable.h with this error is using this header, so simply remove the include. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-14xen: export arbitrary_virt_to_machineStephen Rothwell
Fixes this build error: ERROR: "arbitrary_virt_to_machine" [drivers/xen/xen-gntdev.ko] undefined! Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-14Merge branch 'for_rmk' of git://github.com/at91linux/linux-2.6-at91 into ↵Russell King
devel-stable
2011-01-14ARM: 6625/1: use memblock memory regions for "System RAM" I/O resourcesDima Zavin
Do not use memory bank info to request the "system ram" resources as they do not track holes created by memblock_remove inside machine's reserve callback. If the removed memory is passed as platform_device's ioresource, then drivers that call request_mem_region would fail due to a conflict with the incorrectly configured system ram resource. Instead, iterate through the regions of memblock.memory and add those as "System RAM" resources. Signed-off-by: Dima Zavin <dima@android.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-14Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (27 commits) omap4: Fix ULPI PHY init for ES1.0 SDP omap3: beaglexm: fix power on of DVI omap3: igep3: Add omap_reserve functionality omap3: beaglexm: fix DVI reset GPIO omap3: beaglexm: fix EHCI power up GPIO dir omap3: igep2: Add keypad support omap3: igep3: Fix IGEP module second MMC channel power supply omap3: igep3: Add USB EHCI support for IGEP module omap3: clocks: Fix build error 'CK_3430ES2' undeclared here arm: omap4: pandaboard: turn on PHY reference clock at init omap2plus: prm: Trvial build break fix for undefined reference to 'omap2_prm_read_mod_reg' omap2plus: voltage: Trivial linking fix for 'EINVAL' undeclared omap2plus: voltage: Trivial linking fix 'undefined reference' omap2plus: voltage: Trivial warning fix 'no return statement' omap2plus: clockdomain: Trivial fix for build break because of clktrctrl_mask arm: omap: gpio: don't access irq_desc array directly omap2+: pm_bus: make functions used as pointers as static OMAP: GPIO: fix _set_gpio_triggering() for OMAP2+ OMAP2+: TWL: include pm header for init protos OMAP2+: TWL: make conversion routines static ... Fix up conflicts in arch/arm/mach-omap2/board-omap3beagle.c ("DVI reset GPIO" vs "use generic DPI panel driver")
2011-01-14Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] fix ia64 build failure in pmdp_get_and_clear
2011-01-14x86, olpc: Add missing Kconfig dependenciesH. Peter Anvin
OLPC uses select for OLPC_OPENFIRMWARE, which means OLPC has to enforce the dependencies for OLPC_OPENFIRMWARE. Make sure it does so. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Daniel Drake <dsd@laptop.org> Cc: Andres Salomon <dilinger@queued.net> Cc: Grant Likely <grant.likely@secretlab.ca> LKML-Reference: <20100923162846.D8D409D401B@zog.reactivated.net> Cc: <stable@kernel.org> 2.6.37
2011-01-14x86, mrst: Set correct APB timer IRQ affinity for secondary cpuJacob Pan
Offlining the secondary CPU causes the timer irq affinity to be set to CPU 0. When the secondary CPU is back online again, the wrong irq affinity will be used. This patch ensures secondary per CPU timer always has the correct IRQ affinity when enabled. Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com> LKML-Reference: <1294963604-18111-1-git-send-email-jacob.jun.pan@linux.intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: <stable@kernel.org> 2.6.37
2011-01-14[IA64] fix ia64 build failure in pmdp_get_and_clearAndrea Arcangeli
Implement __pmd macro for ia64 too. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-01-14AT91: Support for gsia18s boardIgor Plyatov
The GS_IA18_S (GMS) is a carrier board from GeoSIG Ltd used with the Stamp9G20 SoM from Taskit company. It operate as an internet accelerometer. Signed-off-by: Igor Plyatov <plyatov@gmail.com> [nicolas.ferre@atmel.com: rm Kconfig, whitespace fixes, change machine name] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-01-14AT91: Acme Systems FOX Board G20 board filesSergio Tanzilli
Signed-off-by: Sergio Tanzilli <tanzilli@acmesystems.it> [nicolas.ferre@atmel.com: whitespace fixes, change machine name] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-01-14AT91: board-sam9m10g45ek.c: Remove duplicate inclusion of mach/hardware.hJesper Juhl
Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-01-14Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI/PM: Report wakeup events before resuming devices PCI/PM: Use pm_wakeup_event() directly for reporting wakeup events PCI: sysfs: Update ROM to include default owner write access x86/PCI: make Broadcom CNB20LE driver EMBEDDED and EXPERIMENTAL x86/PCI: don't use native Broadcom CNB20LE driver when ACPI is available PCI/ACPI: Request _OSC control once for each root bridge (v3) PCI: enable pci=bfsort by default on future Dell systems PCI/PCIe: Clear Root PME Status bits early during system resume PCI: pci-stub: ignore zero-length id parameters x86/PCI: irq and pci_ids patch for Intel Patsburg PCI: Skip id checking if no id is passed PCI: fix __pci_device_probe kernel-doc warning PCI: make pci_restore_state return void PCI: Disable ASPM if BIOS asks us to PCI: Add mask bit definition for MSI-X table PCI: MSI: Move MSI-X entry definition to pci_regs.h Fix up trivial conflicts in drivers/net/{skge.c,sky2.c} that had in the meantime been converted to not use legacy PCI power management, and thus no longer use pci_restore_state() at all (and that caused trivial conflicts with the "make pci_restore_state return void" patch)
2011-01-14x86: tsc: Fix calibration refinement conditionals to avoid divide by zeroJohn Stultz
Konrad Wilk reported that the new delayed calibration crashes with a divide by zero on Xen. The reason is that Xen sets the pmtimer address, but reading from it returns 0xffffff. That results in the ref_start and ref_stop value being the same, so the delta is zero which causes the divide by zero later in the calculation. The conditional (!hpet && !ref_start && !ref_stop) which sanity checks the calibration reference values doesn't really make sense. If the refs are null, but hpet is on, we still want to break out. The div by zero would be possible to trigger by chance if both reads from the hardware provided the exact same value (due to hardware wrapping). So checking if both the ref values are the same should handle if we don't have hardware (both null) or if they are the same value (either by invalid hardware, or by chance), avoiding the div by zero issue. [ tglx: Applied the same fix to native_calibrate_tsc() where this check was copied from ] Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: John Stultz <johnstul@us.ibm.com> LKML-Reference: <1295024788-15619-1-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-14Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (59 commits) mfd: ab8500-core chip version cut 2.0 support mfd: Flag WM831x /IRQ as a wake source mfd: Convert WM831x away from legacy I2C PM operations regulator: Support MAX8998/LP3974 DVS-GPIO mfd: Support LP3974 RTC i2c: Convert SCx200 driver from using raw PCI to platform device x86: OLPC: convert olpc-xo1 driver from pci device to platform device mfd: MAX8998/LP3974 hibernation support mfd/ab8500: remove spi support mfd: Remove ARCH_U8500 dependency from AB8500 misc: Make AB8500_PWM driver depend on U8500 due to PWM breakage mfd: Add __devexit annotation for vx855_remove mfd: twl6030 irq_data conversion. gpio: Fix cs5535 printk warnings misc: Fix cs5535 printk warnings mfd: Convert Wolfson MFD drivers to use irq_data accessor function mfd: Convert TWL4030 to new irq_ APIs mfd: Convert tps6586x driver to new irq_ API mfd: Convert tc6393xb driver to new irq_ APIs mfd: Convert t7166xb driver to new irq_ API ...
2011-01-14x86/PCI: make Broadcom CNB20LE driver EMBEDDED and EXPERIMENTALBjorn Helgaas
This functionality is known to be incomplete, so discourage its use in general-purpose kernels. The only reason to use this driver is to support PCI hotplug on CNB20LE- based machines that don't have ACPI, and there are very few such systems. Reference: https://bugzilla.redhat.com/show_bug.cgi?id=665109 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-01-14x86/PCI: don't use native Broadcom CNB20LE driver when ACPI is availableBjorn Helgaas
The broadcom_bus.c quirk was written (without benefit of documentation) to support PCI hotplug on an old system that doesn't have ACPI. As such, we should only use it when the system doesn't have ACPI. If the system does have ACPI and we need the host bridge description, we should get it from the ACPI _CRS method. On machines older than 2008, we currently ignore _CRS, but that doesn't mean we should use broadcom_bus.c. It means we should either (a) do what we've done in the past and assume everything in the PCI gap is routed to bus 0 (so hotplug may not work), or (b) arrange to use _CRS. This patch does (a). Reference: https://bugzilla.redhat.com/show_bug.cgi?id=665109 Acked-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-01-14PCI: enable pci=bfsort by default on future Dell systemsNarendra_K@Dell.com
This patch enables pci=bfsort by default on future Dell systems. It reads SMBIOS type 0xB1 vendor specific record and sets pci=bfsort accordingly. Offset Name Length Value Description 04 Flags0 Word Varies Bits 9-10 - 10:9 = 00 Unknown - 10:9 = 01 Breadth First - 10:9 = 10 Depth First - 10:9 = 11 Reserved 1. Any time pci=bfsort has to be enabled on a system, we need to add the model number of the system to the white list. With this patch, that is not required. 2. Typically, model number has to be added to the white list when the system is under development. With this change, that is not required. Signed-off-by: Jordan Hargrave <jordan_hargrave@dell.com> Signed-off-by: Narendra K <narendra_k@dell.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-01-14Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] MAINTAINERS: Update zcrypt driver entry [S390] Randomize PIEs [S390] Randomise the brk region [S390] Add is_32bit_task() helper function [S390] Randomize lower bits of stack address [S390] Randomize mmap start address [S390] Rearrange mmap.c [S390] Enable flexible mmap layout for 64 bit processes [S390] vdso: dont map at mmap_base [S390] reduce miminum gap between stack and mmap_base [S390] mmap: consider stack address randomization [S390] Update default configuration [S390] cio: path_event overindication after resume
2011-01-14ARM: pxa: fix suspend/resume array index miscalculationMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-01-14ARM: pxa: use cpu_has_ipr() consistently in irq.cMarek Vasut
2011-01-14ARM: pxa: remove unused variable in clock-pxa3xx.cMarek Vasut
2011-01-14ARM: pxa: fix warning in zeus.cMarek Vasut
2011-01-14ARM: sa1111: fix typo in sa1111_retrigger_lowirq()Pavel Machek
Signed-off-by: Pavel Machek <pma@sysgo.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
