path: root/arch
2011-02-01Merge branches 'for-2.6.38' and 'tegra-arch' into for-2.6.39Mark Brown
2011-02-01ARM: tegra: Add to struct harmony_audio_platform_dataStephen Warren
Add fields to describe all the audio-related GPIOs on Harmony, except for the codec's GPIO IRQ, which will be passed in its i2c_board_info. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-26ASoC: sh: fsi: modify selection method of I2S/PCM/SPDIF formatKuninori Morimoto
Current format selection of FSI-codecs depended on platform information for FSI, and chip default settings for codecs. It is not understandable/formal method. This patch modify FSI and FSI-codecs to use snd_soc_dai_set_fmt. But FSI can use I2S/PCM and SPDIF format today. It can be selected to I2S/PCM by snd_soc_dai_set_fmt, but can not select SPDIF. So, this patch change FSI platform information to have DAI/SPDIF mode. If platform selects DAI mode (default), FSI-codecs can select I2S/PCM by snd_soc_dai_set_fmt, and if it is SPDIF mode, FSI become SPDIF format. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-25Merge branch 'tegra-arch' into for-2.6.39Mark Brown
2011-01-25ARM: tegra: Add Harmony sound platform data typeStephen Warren
Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Colin Cross <ccross@google.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-25ASoC: sh: fsi-hdmi: Add FSI port and HDMI selectionKuninori Morimoto
This patch add platform_device_id which can control PortA/PortB for FSI2-HDMI from platform data. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-21ASoC: sh: fsi: Add snd_soc_dai_set_fmt supportKuninori Morimoto
This patch add snd_soc_dai_ops :: set_fmt to FSI driver and select master/slave clock mode by snd_soc_dai_set_fmt on fsi-xxx.c instead of platform infomation code. This patch remove fsi_is_master function which is no longer needed. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-18Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Clear irqstack thread_info x86: Make relocatable kernel work with new binutils
2011-01-18Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (26 commits) MIPS: Malta: enable Cirrus FB console MIPS: add CONFIG_VIRTUALIZATION for virtio support MIPS: Implement __read_mostly MIPS: ath79: add common WMAC device for AR913X based boards MIPS: ath79: Add initial support for the Atheros AP81 reference board MIPS: ath79: add common SPI controller device SPI: Add SPI controller driver for the Atheros AR71XX/AR724X/AR913X SoCs MIPS: ath79: add common GPIO buttons device MIPS: ath79: add common watchdog device MIPS: ath79: add common GPIO LEDs device MIPS: ath79: add initial support for the Atheros PB44 reference board MIPS: ath79: utilize the MIPS multi-machine support MIPS: ath79: add GPIOLIB support MIPS: Add initial support for the Atheros AR71XX/AR724X/AR931X SoCs MIPS: jump label: Add MIPS support. MIPS: Use WARN() in uasm for better diagnostics. MIPS: Optimize TLB handlers for Octeon CPUs MIPS: Add LDX and LWX instructions to uasm. MIPS: Use BBIT instructions in TLB handlers MIPS: Declare uasm bbit0 and bbit1 functions. ...
2011-01-18MIPS: Malta: enable Cirrus FB consoleAurelien Jarno
While most users of a physical Malta board are using the serial port as the console, a lot of QEMU users would prefer to interact with a graphical console. Enable the Cirrus FB support in the Malta default configuration to make that possible. Note that the default console will still be the serial port, users have to pass "console=tty0" to the kernel to use the Cirrus FB. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2001/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: add CONFIG_VIRTUALIZATION for virtio supportAurelien Jarno
Add CONFIG_VIRTUALIZATION to the MIPS architecture and include the the virtio code there. Used to enable the virtio drivers under QEMU. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2002/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Implement __read_mostlyDavid Daney
Just do what everyone else is doing by placing __read_mostly things in the .data.read_mostly section. mips_io_port_base can not be read-only (const) and writable (__read_mostly) at the same time. One of them has to go, so I chose to eliminate the __read_mostly. It will still get stuck in a portion of memory that is not adjacent to things that are written, and thus not be on a dirty cache line, for whatever that is worth. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1702/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: add common WMAC device for AR913X based boardsGabor Juhos
Add common platform_device and helper code to make the registration of the built-in wireless MAC easier on the Atheros AR9130/AR9132 based boards. Also register the WMAC device on the AR81 board. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Imre Kaloz <kaloz@openwrt.org>, Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1962/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: Add initial support for the Atheros AP81 reference boardGabor Juhos
Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1952/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: add common SPI controller deviceGabor Juhos
Several boards are using the built-in SPI controller of the AR71XX/AR724X/AR913X SoCs. This patch adds common platform_device and helper code to register it. Additionally, the patch registers the SPI bus on the PB44 board. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1956/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18SPI: Add SPI controller driver for the Atheros AR71XX/AR724X/AR913X SoCsGabor Juhos
The Atheros AR71XX/AR724X/AR913X SoCs have a built-in SPI controller. This patch implements a driver for that. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: spi-devel-general@lists.sourceforge.net Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: linux-mips@linux-mips.org Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1960/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: add common GPIO buttons deviceGabor Juhos
Almost all boards have one or more push buttons connected to GPIO lines. This patch adds common code to register a platform_device for them. The patch also adds support for the buttons on the PB44 board. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1954/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: add common watchdog deviceGabor Juhos
All supported SoCs have a built-in hardware watchdog driver. This patch registers a platform_device for that to make it usable. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1955/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: add common GPIO LEDs deviceGabor Juhos
Almost all boards have one or more LEDs connected to GPIO lines. This patch adds common code to register a platform_device for them. The patch also adds support for the LEDs on the PB44 board. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1953/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: add initial support for the Atheros PB44 reference boardGabor Juhos
Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Imre Kaloz <kaloz@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1950/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: utilize the MIPS multi-machine supportGabor Juhos
Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Imre Kaloz <kaloz@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1949/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: ath79: add GPIOLIB supportGabor Juhos
This patch implements generic GPIO routines for the built-in GPIO controllers of the Atheros AR71XX/AR724X/AR913X SoCs. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1948/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Add initial support for the Atheros AR71XX/AR724X/AR931X SoCsGabor Juhos
This patch adds initial support for various Atheros SoCs based on the MIPS 24Kc core. The following models are supported at the moment: - AR7130 - AR7141 - AR7161 - AR9130 - AR9132 - AR7240 - AR7241 - AR7242 The current patch contains minimal support only, but the resulting kernel can boot into user-space with using of an initramfs image on various boards which are using these SoCs. Support for more built-in devices and individual boards will be implemented in further patches. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Cc: linux-mips@linux-mips.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Cc: Kathy Giori <Kathy.Giori@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1947/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: jump label: Add MIPS support.David Daney
In order not to be left behind, we add jump label support for MIPS. Tested on 64-bit big endian (Octeon), and 32-bit little endian (malta/qemu). Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jason Baron <jbaron@redhat.com> Patchwork: https://patchwork.linux-mips.org/patch/1923/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Use WARN() in uasm for better diagnostics.David Daney
On the off chance that uasm ever warns about overflow, there is no way to know what the offending instruction is. Change the printks to WARNs, so we can get a nice stack trace. It has the added benefit of being much more noticeable than the short single line warning message, so is less likely to be ignored. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1905/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Optimize TLB handlers for Octeon CPUsDavid Daney
Octeon can use scratch registers in the TLB handlers. Octeon II can use LDX instructions. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1904/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Add LDX and LWX instructions to uasm.David Daney
Needed by Octeon II optimized TLB handlers. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Pachwork: https://patchwork.linux-mips.org/patch/1903/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Use BBIT instructions in TLB handlersDavid Daney
If the CPU supports BBIT0 and BBIT1, use them in TLB handlers as they are more efficient than an AND followed by an branch and then restoring the clobbered register. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1873/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Declare uasm bbit0 and bbit1 functions.David Daney
these are already defined, but declaring them allow them to be used outside of uasm.c. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1872/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Use C0_KScratch (if present) to hold PGD pointer.David Daney
Decide at runtime to use either Context or KScratch to hold the PGD pointer. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1876/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Add DINSM to uasm.David Daney
Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1875/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Probe for presence of KScratch registers.David Daney
Probe c0_config4 for KScratch registers and report them in /proc/cpuinfo. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1877/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Add generic support for multiple machines within a single kernelGabor Juhos
This patch adds a generic solution to support multiple machines based on a given SoC within a single kernel image. It is implemented already for several other architectures but MIPS has no generic support for that yet. [Ralf: This competes with DT but DT is a much more complex solution and this code has been used by OpenWRT for a long time so for now DT is a bad reason to stop the merge but longer term this should be migrated to DT.] Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: linux-mips@linux-mips.org Cc: kaloz@openwrt.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1814/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Use printf extension %pR for struct resourceJoe Perches
Using %pR standardizes the struct resource output. Signed-off-by: Joe Perches <joe@perches.com> To: Jiri Kosina <trivial@kernel.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1772/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Sibyte: Use vzalloc in sbbus profilerJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> To: Jiri Kosina <trivial@kernel.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1756/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6 * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6: parisc: fix compile breakage caused by inlining maybe_mkwrite parisc : Remove broken line wrapping handling pdc_iodc_print()
2011-01-18Merge branch 'next' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
* 'next' of git://git.monstr.eu/linux-2.6-microblaze: microblaze: Fix asm/pgtable.h microblaze: Fix missing pagemap.h
2011-01-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: (25 commits) m68knommu: fix broken setting of irq_chip and handler m68knommu: switch to using -mcpu= flags for ColdFire targets m68knommu: arch/m68knommu/Kconfig whitespace cleanup m68knommu: create optimal separate instruction and data cache for ColdFire m68knommu: support ColdFire caches that do copyback and write-through m68knommu: support version 2 ColdFire split cache m68knommu: make cache push code ColdFire generic m68knommu: clean up ColdFire cache control code m68knommu: move inclusion of ColdFire v4 cache registers m68knommu: merge bit definitions for version 3 ColdFire cache controller m68knommu: create bit definitions for the version 2 ColdFire cache controller m68knommu: remove empty __iounmap() it is no used m68knommu: remove kernel_map() code, it is not used m68knommu: remove do_page_fault(), it is not used m68knommu: use user stack pointer hardware on some ColdFire cores m68knommu: remove command line printing DEBUG m68knommu: remove fasthandler interrupt code m68knommu: move UART addressing to part specific includes m68knommu: fix clock rate value reported for ColdFire 54xx parts m68knommu: move ColdFire CPU names into their headers ...
2011-01-18Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf tools: Fix tracepoint id to string perf.data header table perf tools: Fix handling of wildcards in tracepoint event selectors powerpc: perf: Fix frequency calculation for overflowing counters
2011-01-18x86: Clear irqstack thread_infoBrian Gerst
Mathias Merz reported that v2.6.37 failed to boot on his system. Make sure that the thread_info part of the irqstack is initialized to zeroes. Reported-and-Tested-by: Matthias Merz <linux@merz-ka.de> Signed-off-by: Brian Gerst <brgerst@gmail.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <AANLkTimyKXfJ1x8tgwrr1hYnNLrPfgE1NTe4z7L6tUDm@mail.gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-18x86: Make relocatable kernel work with new binutilsShaohua Li
The CONFIG_RELOCATABLE=y option is broken with new binutils, which will make boot panic. According to Lu Hongjiu, the affected binutils are from 2.20.51.0.12 to 2.21.51.0.3, which are release since Oct 22 this year. At least ubuntu 10.10 is using such binutils. See: http://sourceware.org/bugzilla/show_bug.cgi?id=12327 The reason of the boot panic is that we have 'jiffies = jiffies_64;' in vmlinux.lds.S. The jiffies isn't in any section. In kernel build, there is warning saying jiffies is an absolute address and can't be relocatable. At runtime, jiffies will have virtual address 0. Signed-off-by: Shaohua Li<shaohua.li@intel.com> Cc: Lu Hongjiu<hongjiu.lu@intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Sam Ravnborg <sam@ravnborg.org> LKML-Reference: <1295312269.1949.725.camel@sli10-conroe> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-18ARM: S5PV310: Add missing virtual ASoC DMA deviceJassi Brar
Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-01-18ARM: S5PV210: Add missing virtual ASoC DMA deviceJassi Brar
2011-01-18ARM: S5P6450: Add missing virtual ASoC DMA deviceJassi Brar
2011-01-18ARM: S5P6440: Add missing virtual ASoC DMA deviceJassi Brar
2011-01-18ARM: S5P6442: Enable I2S device to work on SMDK6442Jassi Brar
Add missing virtual ASoC DMA device. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> [kgene.kim@samsung.com: minor changed title] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-01-17Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: spi/spi_sh_msiof: fix a wrong free_irq() parameter dt/flattree: Return virtual address from early_init_dt_alloc_memory_arch()
2011-01-17Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (59 commits) mtd: mtdpart: disallow reading OOB past the end of the partition mtd: pxa3xx_nand: NULL dereference in pxa3xx_nand_probe UBI: use mtd->writebufsize to set minimal I/O unit size mtd: initialize writebufsize in the MTD object of a partition mtd: onenand: add mtd->writebufsize initialization mtd: nand: add mtd->writebufsize initialization mtd: cfi: add writebufsize initialization mtd: add writebufsize field to mtd_info struct mtd: OneNAND: OMAP2/3: prevent regulator sleeping while OneNAND is in use mtd: OneNAND: add enable / disable methods to onenand_chip mtd: m25p80: Fix JEDEC ID for AT26DF321 mtd: txx9ndfmc: limit transfer bytes to 512 (ECC provides 6 bytes max) mtd: cfi_cmdset_0002: add support for Samsung K8D3x16UxC NOR chips mtd: cfi_cmdset_0002: add support for Samsung K8D6x16UxM NOR chips mtd: nand: ams-delta: drop omap_read/write, use ioremap mtd: m25p80: add debugging trace in sst_write mtd: nand: ams-delta: select for built-in by default mtd: OneNAND: lighten scary initial bad block messages mtd: OneNAND: OMAP2/3: add support for command line partitioning mtd: nand: rearrange ONFI revision checking, add ONFI 2.3 ... Fix up trivial conflict in drivers/mtd/Kconfig as per DavidW.
2011-01-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mattst88/alpha-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mattst88/alpha-2.6: alpha: fix WARN_ON in __local_bh_enable() alpha: fix breakage caused by df9ee29270 alpha: add GENERIC_HARDIRQS_NO__DO_IRQ to Kconfig alpha/osf_sys: remove unused MAX_SELECT_SECONDS alpha: change to new Makefile flag variables alpha: kill off alpha_do_IRQ alpha: irq clean up alpha: use set_irq_chip and push down __do_IRQ to the machine types
2011-01-17Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (63 commits) ARM: PL08x: cleanup comments Update CONFIG_MD_RAID6_PQ to CONFIG_RAID6_PQ in drivers/dma/iop-adma.c ARM: PL08x: fix a warning Fix dmaengine_submit() return type dmaengine: at_hdmac: fix race while monitoring channel status dmaengine: at_hdmac: flags located in first descriptor dmaengine: at_hdmac: use subsys_initcall instead of module_init dmaengine: at_hdmac: no need set ACK in new descriptor dmaengine: at_hdmac: trivial add precision to unmapping comment dmaengine: at_hdmac: use dma_address to program DMA hardware pch_dma: support new device ML7213 IOH ARM: PL08x: prevent dma_set_runtime_config() reconfiguring memcpy channels ARM: PL08x: allow dma_set_runtime_config() to return errors ARM: PL08x: fix locking between prepare function and submit function ARM: PL08x: introduce 'phychan_hold' to hold on to physical channels ARM: PL08x: put txd's on the pending list in pl08x_tx_submit() ARM: PL08x: rename 'desc_list' as 'pend_list' ARM: PL08x: implement unmapping of memcpy buffers ARM: PL08x: store prep_* flags in async_tx structure ARM: PL08x: shrink srcbus/dstbus in txd structure ...
