path: root/arch
2008-02-01Merge branch 'task_killable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'task_killable' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: (22 commits) Remove commented-out code copied from NFS NFS: Switch from intr mount option to TASK_KILLABLE Add wait_for_completion_killable Add wait_event_killable Add schedule_timeout_killable Use mutex_lock_killable in vfs_readdir Add mutex_lock_killable Use lock_page_killable Add lock_page_killable Add fatal_signal_pending Add TASK_WAKEKILL exit: Use task_is_* signal: Use task_is_* sched: Use task_contributes_to_load, TASK_ALL and TASK_NORMAL ptrace: Use task_is_* power: Use task_is_* wait: Use TASK_NORMAL proc/base.c: Use task_is_* proc/array.c: Use TASK_REPORT perfmon: Use task_is_* ... Fixed up conflicts in NFS/sunrpc manually..
2008-02-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: asm-generic/tlb.h: build fix x86: uninline __pte_free_tlb() and __pmd_free_tlb() x86: fix small sparse warning x86: fix sparse warning in kernel/scx200_32.c x86: early_ioremap_reset fix 2 x86: c_p_a clflush_cache_range fix x86: change_page_attr_clear fix x86: fix sparse warnings in intel_cacheinfo.c
2008-01-31x86: uninline __pte_free_tlb() and __pmd_free_tlb()Ingo Molnar
this also removes an include file dependency. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-31x86: fix small sparse warningHarvey Harrison
arch/x86/kernel/ds.c:226:9: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-31x86: fix sparse warning in kernel/scx200_32.cHarvey Harrison
arch/x86/kernel/scx200_32.c:68:72: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-31x86: early_ioremap_reset fix 2Huang, Ying
This patch fixes a bug of early_ioremap_reset(), which had been fixed before by "convert the boot time page table to the kernels native format" patch. But that patch has been reverted now. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-31x86: c_p_a clflush_cache_range fixHuang, Ying
Because in i386 early boot stage, boot_cpu_data may be not available, which makes clflush_cach_range() into infinite loop, which is called by change_page_attr(). This patch fixes this by setting boot_cpu_data.x86_clflush_size in early_cpu_detect(). Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-31x86: change_page_attr_clear fixHuang, Ying
This patch replaces __change_page_attr_set_clr() with change_page_attr_set_clr() in change_page_attr_clear() to flush the TLB/cache properly. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-31x86: fix sparse warnings in intel_cacheinfo.cHarvey Harrison
arch/x86/kernel/cpu/intel_cacheinfo.c:355:7: warning: symbol 'i' shadows an earlier one arch/x86/kernel/cpu/intel_cacheinfo.c:296:39: originally declared here arch/x86/kernel/cpu/intel_cacheinfo.c:367:18: warning: incorrect type in argument 2 (different signedness) arch/x86/kernel/cpu/intel_cacheinfo.c:367:18: expected unsigned int *eax arch/x86/kernel/cpu/intel_cacheinfo.c:367:18: got int * arch/x86/kernel/cpu/intel_cacheinfo.c:367:28: warning: incorrect type in argument 3 (different signedness) arch/x86/kernel/cpu/intel_cacheinfo.c:367:28: expected unsigned int *ebx arch/x86/kernel/cpu/intel_cacheinfo.c:367:28: got int * arch/x86/kernel/cpu/intel_cacheinfo.c:367:38: warning: incorrect type in argument 4 (different signedness) arch/x86/kernel/cpu/intel_cacheinfo.c:367:38: expected unsigned int *ecx arch/x86/kernel/cpu/intel_cacheinfo.c:367:38: got int * arch/x86/kernel/cpu/intel_cacheinfo.c:367:48: warning: incorrect type in argument 5 (different signedness) arch/x86/kernel/cpu/intel_cacheinfo.c:367:48: expected unsigned int *edx arch/x86/kernel/cpu/intel_cacheinfo.c:367:48: got int * Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-31POWERPC: Set dma_data correctly for direct_ops on pasemiOlof Johansson
More late-caught fallout from the mainline merge. Commit 35e4a6e26d0c6bc7f32087db61f0fb3666531183 ("[POWERPC] Use archdata.dma_data in dma_direct_ops and add the offset") claimed "Now that all platforms using dma_direct_offset setup the archdata.dma_data correctly, ..." ..but nope -- the pasemi iommu setup code that disables translation on the DMA pci device didn't set dma_data correctly. This fixes it. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31Merge branch 'for-2.6.25' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'for-2.6.25' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (454 commits) [POWERPC] Cell IOMMU fixed mapping support [POWERPC] Split out the ioid fetching/checking logic [POWERPC] Add support to cell_iommu_setup_page_tables() for multiple windows [POWERPC] Split out the IOMMU logic from cell_dma_dev_setup() [POWERPC] Split cell_iommu_setup_hardware() into two parts [POWERPC] Split out the logic that allocates struct iommus [POWERPC] Allocate the hash table under 1G on cell [POWERPC] Add set_dma_ops() to match get_dma_ops() [POWERPC] 83xx: Clean up / convert mpc83xx board DTS files to v1 format. [POWERPC] 85xx: Only invalidate TLB0 and TLB1 [POWERPC] 83xx: Fix typo in mpc837x compatible entries [POWERPC] 85xx: convert sbc85* boards to use machine_device_initcall [POWERPC] 83xx: rework platform Kconfig [POWERPC] 85xx: rework platform Kconfig [POWERPC] 86xx: Remove unused IRQ defines [POWERPC] QE: Explicitly set address-cells and size cells for muram [POWERPC] Convert StorCenter DTS file to /dts-v1/ format. [POWERPC] 86xx: Convert all 86xx DTS files to /dts-v1/ format. [PPC] Remove 85xx from arch/ppc [PPC] Remove 83xx from arch/ppc ...
2008-01-31[POWERPC] Cell IOMMU fixed mapping supportMichael Ellerman
This patch adds support for setting up a fixed IOMMU mapping on certain cell machines. For 64-bit devices this avoids the performance overhead of mapping and unmapping pages at runtime. 32-bit devices are unable to use the fixed mapping. The fixed mapping is established at boot, and maps all of physical memory 1:1 into device space at some offset. On machines with < 30 GB of memory we setup the fixed mapping immediately above the normal IOMMU window. For example a machine with 4GB of memory would end up with the normal IOMMU window from 0-2GB and the fixed mapping window from 2GB to 6GB. In this case a 64-bit device wishing to DMA to 1GB would be told to DMA to 3GB, plus any offset required by firmware. The firmware offset is encoded in the "dma-ranges" property. On machines with 30GB or more of memory, we are unable to place the fixed mapping above the normal IOMMU window as we would run out of address space. Instead we move the normal IOMMU window to coincide with the hash page table, this region does not need to be part of the fixed mapping as no device should ever be DMA'ing to it. We then setup the fixed mapping from 0 to 32GB. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-31[POWERPC] Split out the ioid fetching/checking logicMichael Ellerman
Split out the ioid fetching and checking logic so we can use it elsewhere in a subsequent patch. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-31[POWERPC] Add support to cell_iommu_setup_page_tables() for multiple windowsMichael Ellerman
Add support to cell_iommu_setup_page_tables() for handling two windows, the dynamic window and the fixed window. A fixed window size of 0 indicates that there is no fixed window at all. Currently there are no callers who pass a non-zero fixed window, but the upcoming fixed IOMMU mapping patch will change that. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-31[POWERPC] Split out the IOMMU logic from cell_dma_dev_setup()Michael Ellerman
Split the IOMMU logic out from cell_dma_dev_setup() into a separate function. If we're not using dma_direct_ops or dma_iommu_ops we don't know what the hell's going on, so BUG. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-31[POWERPC] Split cell_iommu_setup_hardware() into two partsMichael Ellerman
Split cell_iommu_setup_hardware() into two parts. Split the page table setup into cell_iommu_setup_page_tables() and the bits that kick the hardware into cell_iommu_enable_hardware(). Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-31[POWERPC] Split out the logic that allocates struct iommusMichael Ellerman
Split out the logic that allocates a struct iommu into a separate function. This can fail however the calling code has never cared - so just return if we can't allocate an iommu. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-31[POWERPC] Allocate the hash table under 1G on cellMichael Ellerman
In order to support the fixed IOMMU mapping (in a subsequent patch), we need the hash table to be inside the IOMMUs DMA window. This is usually 2G, but let's make sure the hash table is under 1G as that will satisfy the IOMMU requirements and also means the hash table will be on node 0. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: alpha: fix x86.git merge build error ia64: on UP percpu variables are not small memory model x86: fix arch/x86/kernel/test_nx.c modular build bug s390: use generic percpu linux-2.6.git POWERPC: use generic per cpu ia64: use generic percpu SPARC64: use generic percpu percpu: change Kconfig to HAVE_SETUP_PER_CPU_AREA modules: fold percpu_modcopy into module.c x86: export copy_from_user_ll_nocache[_nozero] x86: fix duplicated TIF on 64-bit
2008-01-31Merge branch 'linux-2.6'Paul Mackerras
2008-01-31Merge branch 'for-2.6.25' of git://git.secretlab.ca/git/linux-2.6-mpc52xxPaul Mackerras
2008-01-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (27 commits) lguest: use __PAGE_KERNEL instead of _PAGE_KERNEL lguest: Use explicit includes rateher than indirect lguest: get rid of lg variable assignments lguest: change gpte_addr header lguest: move changed bitmap to lg_cpu lguest: move last_pages to lg_cpu lguest: change last_guest to last_cpu lguest: change spte_addr header lguest: per-vcpu lguest pgdir management lguest: make pending notifications per-vcpu lguest: makes special fields be per-vcpu lguest: per-vcpu lguest task management lguest: replace lguest_arch with lg_cpu_arch. lguest: make registers per-vcpu lguest: make emulate_insn receive a vcpu struct. lguest: map_switcher_in_guest() per-vcpu lguest: per-vcpu interrupt processing. lguest: per-vcpu lguest timers lguest: make hypercalls use the vcpu struct lguest: make write() operation smp aware ... Manual conflict resolved (maybe even correctly, who knows) in drivers/lguest/x86/core.c
2008-01-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: PPC: Fix powerpc vio_find_name to not use devices_subsys Driver core: add bus_find_device_by_name function Module: check to see if we have a built in module with the same name x86: fix runtime error in arch/x86/kernel/cpu/mcheck/mce_amd_64.c Driver core: Fix up build when CONFIG_BLOCK=N
2008-01-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: (249 commits) KVM: Move apic timer migration away from critical section KVM: Put kvm_para.h include outside __KERNEL__ KVM: Fix unbounded preemption latency KVM: Initialize the mmu caches only after verifying cpu support KVM: MMU: Fix dirty page setting for pages removed from rmap KVM: Portability: Move kvm_fpu to asm-x86/kvm.h KVM: x86 emulator: Only allow VMCALL/VMMCALL trapped by #UD KVM: MMU: Merge shadow level check in FNAME(fetch) KVM: MMU: Move kvm_free_some_pages() into critical section KVM: MMU: Switch to mmu spinlock KVM: MMU: Avoid calling gfn_to_page() in mmu_set_spte() KVM: Add kvm_read_guest_atomic() KVM: MMU: Concurrent guest walkers KVM: Disable vapic support on Intel machines with FlexPriority KVM: Accelerated apic support KVM: local APIC TPR access reporting facility KVM: Print data for unimplemented wrmsr KVM: MMU: Add cache miss statistic KVM: MMU: Coalesce remote tlb flushes KVM: Expose ioapic to ia64 save/restore APIs ...
2008-01-30x86: fix arch/x86/kernel/test_nx.c modular build bugIngo Molnar
fix this modular build bug: > CC [M] arch/x86/kernel/test_nx.o > {standard input}: Assembler messages: > {standard input}:58: Error: cannot represent relocation type BFD_RELOC_64 > {standard input}:59: Error: cannot represent relocation type BFD_RELOC_64 > make[2]: *** [arch/x86/kernel/test_nx.o] Error 1 > make[1]: *** [arch/x86/kernel] Error 2 Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30SPARC64: use generic percputravis@sgi.com
Sparc64 has a way of providing the base address for the per cpu area of the currently executing processor in a global register. Sparc64 also provides a way to calculate the address of a per cpu area from a base address instead of performing an array lookup. Cc: David Miller <davem@davemloft.net> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30percpu: change Kconfig to HAVE_SETUP_PER_CPU_AREAtravis@sgi.com
Change: config ARCH_SETS_UP_PER_CPU_AREA to: config HAVE_SETUP_PER_CPU_AREA Cc: Andi Kleen <ak@suse.de> Cc: Tony Luck <tony.luck@intel.com> Cc: David Miller <davem@davemloft.net> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: linuxppc-dev@ozlabs.org Cc: linux-ia64@vger.kernel.org Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30modules: fold percpu_modcopy into module.ctravis@sgi.com
percpu_modcopy() is defined multiple times in arch files. However, the only user is module.c. Put a static definition into module.c and remove the definitions from the arch files. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: export copy_from_user_ll_nocache[_nozero]Andrew Morton
Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30[SCSI] remove use_sg_chainingJames Bottomley
With the sg table code, every SCSI driver is now either chain capable or broken (or has sg_tablesize set so chaining is never activated), so there's no need to have a check in the host template. Also tidy up the code by moving the scatterlist size defines into the SCSI includes and permit the last entry of the scatterlist pools not to be a power of two. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30KVM: Move apic timer migration away from critical sectionAvi Kivity
Migrating the apic timer in the critical section is not very nice, and is absolutely horrible with the real-time port. Move migration to the regular vcpu execution path, triggered by a new bitflag. Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Fix unbounded preemption latencyAvi Kivity
When preparing to enter the guest, if an interrupt comes in while preemption is disabled but interrupts are still enabled, we miss a preemption point. Fix by explicitly checking whether we need to reschedule. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Initialize the mmu caches only after verifying cpu supportAvi Kivity
Otherwise we re-initialize the mmu caches, which will fail since the caches are already registered, which will cause us to deinitialize said caches. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: MMU: Fix dirty page setting for pages removed from rmapIzik Eidus
Right now rmap_remove won't set the page as dirty if the shadow pte pointed to this page had write access and then it became readonly. This patches fixes that, by setting the page as dirty for spte changes from write to readonly access. Signed-off-by: Izik Eidus <izike@qumranet.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: x86 emulator: Only allow VMCALL/VMMCALL trapped by #UDSheng Yang
When executing a test program called "crashme", we found the KVM guest cannot survive more than ten seconds, then encounterd kernel panic. The basic concept of "crashme" is generating random assembly code and trying to execute it. After some fixes on emulator insn validity judgment, we found it's hard to get the current emulator handle the invalid instructions correctly, for the #UD trap for hypercall patching caused troubles. The problem is, if the opcode itself was OK, but combination of opcode and modrm_reg was invalid, and one operand of the opcode was memory (SrcMem or DstMem), the emulator will fetch the memory operand first rather than checking the validity, and may encounter an error there. For example, ".byte 0xfe, 0x34, 0xcd" has this problem. In the patch, we simply check that if the invalid opcode wasn't vmcall/vmmcall, then return from emulate_instruction() and inject a #UD to guest. With the patch, the guest had been running for more than 12 hours. Signed-off-by: Feng (Eric) Liu <eric.e.liu@intel.com> Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: MMU: Merge shadow level check in FNAME(fetch)Dong, Eddie
Remove the redundant level check when fetching shadow pte for present & non-present spte. Signed-off-by: Yaozu (Eddie) Dong <eddie.dong@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: MMU: Move kvm_free_some_pages() into critical sectionAvi Kivity
If some other cpu steals mmu pages between our check and an attempt to allocate, we can run out of mmu pages. Fix by moving the check into the same critical section as the allocation. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: MMU: Switch to mmu spinlockMarcelo Tosatti
Convert the synchronization of the shadow handling to a separate mmu_lock spinlock. Also guard fetch() by mmap_sem in read-mode to protect against alias and memslot changes. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: MMU: Avoid calling gfn_to_page() in mmu_set_spte()Avi Kivity
Since gfn_to_page() is a sleeping function, and we want to make the core mmu spinlocked, we need to pass the page from the walker context (which can sleep) to the shadow context (which cannot). [marcelo: avoid recursive locking of mmap_sem] Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Add kvm_read_guest_atomic()Marcelo Tosatti
In preparation for a mmu spinlock, add kvm_read_guest_atomic() and use it in fetch() and prefetch_page(). Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: MMU: Concurrent guest walkersMarcelo Tosatti
Do not hold kvm->lock mutex across the entire pagefault code, only acquire it in places where it is necessary, such as mmu hash list, active list, rmap and parent pte handling. Allow concurrent guest walkers by switching walk_addr() to use mmap_sem in read-mode. And get rid of the lockless __gfn_to_page. [avi: move kvm_mmu_pte_write() locking inside the function] [avi: add locking for real mode] [avi: fix cmpxchg locking] Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Disable vapic support on Intel machines with FlexPriorityAvi Kivity
FlexPriority accelerates the tpr without any patching. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Accelerated apic supportAvi Kivity
This adds a mechanism for exposing the virtual apic tpr to the guest, and a protocol for letting the guest update the tpr without causing a vmexit if conditions allow (e.g. there is no interrupt pending with a higher priority than the new tpr). Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: local APIC TPR access reporting facilityAvi Kivity
Add a facility to report on accesses to the local apic tpr even if the local apic is emulated in the kernel. This is basically a hack that allows userspace to patch Windows which tends to bang on the tpr a lot. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Print data for unimplemented wrmsrAvi Kivity
This can help diagnosing what the guest is trying to do. In many cases we can get away with partial emulation of msrs. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: MMU: Add cache miss statisticAvi Kivity
2008-01-30KVM: MMU: Coalesce remote tlb flushesEddie Dong
Host side TLB flush can be merged together if multiple spte need to be write-protected. Signed-off-by: Yaozu (Eddie) Dong <eddie.dong@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Move kvm_vcpu_kick() to x86.cZhang Xiantao
Moving kvm_vcpu_kick() to x86.c. Since it should be common for all archs, put its declarations in <linux/kvm_host.h> Signed-off-by: Zhang Xiantao <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Move ioapic code to common directory.Zhang Xiantao
Move ioapic code to common, since IA64 also needs it. Signed-off-by: Zhang Xiantao <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Move irqchip declarations into new ioapic.h and lapic.hZhang Xiantao
This allows reuse of ioapic in ia64. Signed-off-by: Zhang Xiantao <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
