path: root/arch
2009-07-29Merge branch 'drm-radeon-kms' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-radeon-kms' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (35 commits) drm/radeon: set fb aperture sizes for framebuffer handoff. drm/ttm: fix highuser vs dma32 confusion. drm/radeon: Fix size used for benchmarking BO copies. drm/radeon: Add radeon.test parameter for running BO GPU copy tests. drm/radeon/kms: allow interruptible waits for objects. drm/ttm: powerpc: Fix Highmem cache flushing. x86: Export kmap_atomic_prot() needed for TTM. drm/ttm: Fix ttm in-kernel copying of pages with non-standard caching attributes. drm/ttm: Fix an oops and sync object leak. drm/radeon/kms: vram sizing on certain r100 chips needs workaround. drm/radeon: Pay more attention to object placement requested by userspace. drm/radeon: Fall back to evicting BOs with memcpy if necessary. drm/radeon: Don't unreserve twice on failure to validate. drm/radeon/kms: fix bandwidth computation on avivo hardware drm/radeon/kms: add initial colortiling support. drm/radeon/kms: fix hotspot handling on pre-avivo chips drm/radeon/kms: enable frac fb divs on rs600/rs690/rs740 drm/radeon/kms: add PLL flag to prefer frequencies <= the target freq drm/radeon/kms: block RN50 from using 3D engine. drm/radeon/kms: fix VRAM sizing like DDX does it. ...
2009-07-29x86: Export kmap_atomic_prot() needed for TTM.Thomas Hellstrom
This functionality is needed to kmap_atomic() highmem pages that may potentially have or are about to set up other mappings with non-standard caching attributes. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-07-27mm: Remove duplicate definitions in MIPS and SHBenjamin Herrenschmidt
Those definitions are already provided by asm-generic Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-27Merge branch 'fixes-for-linus' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
* 'fixes-for-linus' of git://git.monstr.eu/linux-2.6-microblaze: microblaze: Makefile cleanup microblaze: Typo fix for cpu param inconsistency microblaze: Add support for R_MICROBLAZE_64_NONE microblaze: Get module loading working microblaze: remove sys_ipc microblaze: Support unaligned address for put/get_user macros microblaze: Detect new Microblaze 7.20 versions microblaze: Fix do_page_fault for no context microblaze: Add _PAGE_FILE macros to pgtable.h microblaze: Fix put_user macro for 64bits arguments microblaze: Clear print messages for DTB passing via r7 microblaze: Not to clear r7 after copying DTB to kernel microblaze: Add messages about FDT blob microblaze: Final support for statically linked DTB microblaze: remove duplicated #include microblaze: Define tlb_flush macro
2009-07-27Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: geode: Mark mfgpt irq IRQF_TIMER to prevent resume failure x86, amd: Don't probe for extended APIC ID if APICs are disabled x86, mce: Rename incorrect macro name "CONFIG_X86_THRESHOLD" x86-64: Fix bad_srat() to clear all state x86, mce: Fix set_trigger() accessor x86: Fix movq immediate operand constraints in uaccess.h x86: Fix movq immediate operand constraints in uaccess_64.h x86: Add reboot fixup for SBC-fitPC2 x86: Include all of .data.* sections in _edata on 64-bit x86: Add quirk for Intel DG45ID board to avoid low memory corruption
2009-07-27Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] zcrypt: fix scheduling of hrtimer ap_poll_timer [S390] vdso: clock_gettime of CLOCK_THREAD_CPUTIME_ID with noexec=on [S390] vdso: fix per cpu area allocation [S390] hibernation: fix register corruption on machine checks [S390] hibernation: fix lowcore handling
2009-07-27mm: Pass virtual address to [__]p{te,ud,md}_free_tlb()Benjamin Herrenschmidt
mm: Pass virtual address to [__]p{te,ud,md}_free_tlb() Upcoming paches to support the new 64-bit "BookE" powerpc architecture will need to have the virtual address corresponding to PTE page when freeing it, due to the way the HW table walker works. Basically, the TLB can be loaded with "large" pages that cover the whole virtual space (well, sort-of, half of it actually) represented by a PTE page, and which contain an "indirect" bit indicating that this TLB entry RPN points to an array of PTEs from which the TLB can then create direct entries. Thus, in order to invalidate those when PTE pages are deleted, we need the virtual address to pass to tlbilx or tlbivax instructions. The old trick of sticking it somewhere in the PTE page struct page sucks too much, the address is almost readily available in all call sites and almost everybody implemets these as macros, so we may as well add the argument everywhere. I added it to the pmd and pud variants for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Howells <dhowells@redhat.com> [MN10300 & FRV] Acked-by: Nick Piggin <npiggin@suse.de> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-27microblaze: Makefile cleanupSam Ravnborg
Reviewed the Makefile on request by Michal and this is the resulting changes. o Use ':=' for assignmnet so we do not re-evaluate for each use o Use $(shell echo xxx) to remove "" o Replaced CFLAGS_KERNEL with KBUILD_CFLAGS The settings are equally relevant for modules and the linked kernel o Dropped LDFLAGS_BLOB - it is no longer used o Refactored assignmnets to libs-y and core-y o Use MMU for the MMU specific extension. "MMUEXT" was hurting my eyes and I did not wanted it spread to m68k Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-27microblaze: Typo fix for cpu param inconsistencyMichal Simek
2009-07-27microblaze: Add support for R_MICROBLAZE_64_NONEMichal Simek
For example reiserfs use this relocation type. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-27microblaze: Get module loading workingJohn Williams
New reloc type R_MICROBLAZE_32_PCREL_LO requires a null handler (no work to do). Remove legacy hack for broken linker pre gcc-4.1.1, that required us to extract an offset from the code, add it to the addend, then rewrite the instruction. Fixup the invalid reloc type error output. Boot tested with the xilinx_emaclite ethernet driver. Signed-off-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-27microblaze: remove sys_ipcArnd Bergmann
The ipc system call is now unused in microblaze, as the system call table points directly to the indidual system calls for IPC. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-27microblaze: Support unaligned address for put/get_user macrosMichal Simek
This patch add support for cases where load/store instruction in put/get_user macro gets unaligned pointer to data and this address is not valid. I prevent all cases which can failed. I had to disable first stage of unaligned handler which is used only for noMMU kernel and the whole work is done when interrupt is enabled. You have enable HW support for detect unaligned access in Microblaze. This patch fixed three LTP tests: getpeername01, getsockname01, socketpair01 Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-27microblaze: Detect new Microblaze 7.20 versionsMichal Simek
2009-07-27microblaze: Fix do_page_fault for no contextMichal Simek
Calling fixup when we are in kernel mode. This prevent fault for copy_to/from_user. This fault was find thanks to writev01/03/04 LTP tests. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-27microblaze: Add _PAGE_FILE macros to pgtable.hMichal Simek
We need to define _PAGE_FILE macro and change pte functions. Microblaze use the same MMU as PowerPC that's why we define _PAGE_FILE in the same style. This change fixed remap_file_pages01 LTP test. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-27microblaze: Fix put_user macro for 64bits argumentsMichal Simek
For 64bits arguments gcc caused that put_user macro works with wrong value because of optimalization. Adding volatile caused that gcc not optimized it. It is possible to use (as Blackfin do) two put_user macros with 32bits arguments but there is one more instruction which is due to duplication zero return value which is called put_user_asm macro. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-27microblaze: Clear print messages for DTB passing via r7Michal Simek
It is necessary to zeroed r7 when r7 points to bad dtb - this caused that we have correct messages about compiled-in dtb or passing via r7 Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-27microblaze: Not to clear r7 after copying DTB to kernelMichal Simek
I can't clear r7 because if I do it I lose information where DTB come from. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-27microblaze: Add messages about FDT blobMichal Simek
Print accurate message about place where FDT blob is. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-27microblaze: Final support for statically linked DTBJohn Williams
If r7 is zero at kernel boot, or does not point to a valid DTB, then we fall back to a DTB (assumed to be) linked statically in the kernel, instead of blindly copying bogus cruft into the kernel DTB memory region Signed-off-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-27microblaze: remove duplicated #includeHuang Weiyi
Remove duplicated #include('s) in arch/microblaze/include/asm/io.h Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-27microblaze: Define tlb_flush macroMichal Simek
This fix remove bug which we had till now in all Microblaze MMU code. Primary tested on mmap01 LTP test. We forget to flush invalid tlb which were changed - we used them and there were wrong old data which wasn't correct. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-24[S390] vdso: clock_gettime of CLOCK_THREAD_CPUTIME_ID with noexec=onMartin Schwidefsky
The combination of noexec=on and a clock_gettime call with clock id CLOCK_THREAD_CPUTIME_ID is broken. The vdso code switches to the access register mode to get access to the per-cpu data structure to execute the magic ectg instruction. After the ectg instruction the code always switches back to the primary mode but for noexec=on the correct mode is the secondary mode. The effect of the bug is that the user space program looses the access to all mappings without PROT_EXEC, e.g. the stack. The problem is fixed by restoring the mode that has been active before the switch to the access register mode. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-07-24[S390] vdso: fix per cpu area allocationHeiko Carstens
vdso per cpu area allocation in smp_prepare_cpus() happens with GFP_KERNEL but irqs disabled. Triggers this one: Badness at kernel/lockdep.c:2280 Modules linked in: CPU: 0 Not tainted 2.6.30 #2 Process swapper (pid: 1, task: 000000003fe88000, ksp: 000000003fe87eb8) Krnl PSW : 0400c00180000000 0000000000083360 (lockdep_trace_alloc+0xec/0xf8) [...] Call Trace: ([<00000000000832b6>] lockdep_trace_alloc+0x42/0xf8) [<00000000000b1880>] __alloc_pages_internal+0x3e8/0x5c4 [<00000000000b1b4a>] __get_free_pages+0x3a/0xb0 [<0000000000026546>] vdso_alloc_per_cpu+0x6a/0x18c [<00000000005eff82>] smp_prepare_cpus+0x322/0x594 [<00000000005e8232>] kernel_init+0x76/0x398 [<000000000001bb1e>] kernel_thread_starter+0x6/0xc [<000000000001bb18>] kernel_thread_starter+0x0/0xc Fix this by moving the allocation out of the irqs disabled section. Reported-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-07-24[S390] hibernation: fix register corruption on machine checksHeiko Carstens
swsusp_arch_suspend() actually saves all cpu register contents on hibernation. Machine checks must be disabled since swsusp_arch_suspend() stores register contents to their lowcore save areas. That's the same place where register contents on machine checks would be saved. To avoid register corruption disable machine checks. We must also disable machine checks in the new psw mask for program checks, since swsusp_arch_suspend() may generate program checks. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-07-24[S390] hibernation: fix lowcore handlingHeiko Carstens
Our swsusp_arch_suspend() backend implementation disables prefixing by setting the contents of the prefix register to 0. However afterwards common code functions are called which might access percpu data structures. Since the lowcore contains e.g. the percpu base pointer this isn't a good idea. So fix this by copying the hibernating cpu's lowcore to absolute address zero. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-07-24x86: geode: Mark mfgpt irq IRQF_TIMER to prevent resume failureThomas Gleixner
Timer interrupts are excluded from being disabled during suspend. The clock events code manages the disabling of clock events on its own because the timer interrupt needs to be functional before the resume code reenables the device interrupts. The mfgpt timer request its interrupt without setting the IRQF_TIMER flag so suspend_device_irqs() disables it as well which results in a fatal resume failure. Adding IRQF_TIMER to the interupt flags when requesting the mrgpt timer interrupt solves the problem. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <new-submission> Cc: Andres Salomon <dilinger@debian.org> Cc: stable@kernel.org
2009-07-22Merge branch 'perf-counters-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-perf * 'perf-counters-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-perf: (31 commits) perf_counter tools: Give perf top inherit option perf_counter tools: Fix vmlinux symbol generation breakage perf_counter: Detect debugfs location perf_counter: Add tracepoint support to perf list, perf stat perf symbol: C++ demangling perf: avoid structure size confusion by using a fixed size perf_counter: Fix throttle/unthrottle event logging perf_counter: Improve perf stat and perf record option parsing perf_counter: PERF_SAMPLE_ID and inherited counters perf_counter: Plug more stack leaks perf: Fix stack data leak perf_counter: Remove unused variables perf_counter: Make call graph option consistent perf_counter: Add perf record option to log addresses perf_counter: Log vfork as a fork event perf_counter: Synthesize VDSO mmap event perf_counter: Make sure we dont leak kernel memory to userspace perf_counter tools: Fix index boundary check perf_counter: Fix the tracepoint channel to perfcounters perf_counter, x86: Extend perf_counter Pentium M support ...
2009-07-22x86, amd: Don't probe for extended APIC ID if APICs are disabledJeremy Fitzhardinge
If we've logically disabled apics, don't probe the PCI space for the AMD extended APIC ID. [ Impact: prevent boot crash under Xen. ] Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Reported-by: Bastian Blank <bastian@waldi.eu.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-07-22perf_counter: Remove unused variablesPeter Zijlstra
Fix a gcc unused variables warning. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
2009-07-21x86, mce: Rename incorrect macro name "CONFIG_X86_THRESHOLD"Hidehiro Kawai
CONFIG_X86_THRESHOLD used in arch/x86/kernel/irqinit.c is always undefined. Rename it to the correct name "CONFIG_X86_MCE_THRESHOLD". Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> LKML-Reference: <4A667FD4.3010509@hitachi.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-07-21x86-64: Fix bad_srat() to clear all stateAndi Kleen
Need to clear both nodes and nodes_add state for start/end. Signed-off-by: Andi Kleen <ak@linux.intel.com> LKML-Reference: <20090718065657.GA2898@basil.fritz.box> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: stable@kernel.org
2009-07-21x86, mce: Fix set_trigger() accessorJan Beulich
Fix the condition checking the result of strchr() (which previously could result in an oops), and make the function return the number of bytes actively used. [ Impact: fix oops ] Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <andi@firstfloor.org> LKML-Reference: <4A5F04B7020000780000AB59@vpn.id2.novell.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-07-20x86: Fix movq immediate operand constraints in uaccess.hH. Peter Anvin
The movq instruction, generated by __put_user_asm() when used for 64-bit data, takes a sign-extended immediate ("e") not a zero-extended immediate ("Z"). Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Uros Bizjak <ubizjak@gmail.com> Cc: stable@kernel.org
2009-07-20x86: Fix movq immediate operand constraints in uaccess_64.hUros Bizjak
arch/x86/include/asm/uaccess_64.h uses wrong asm operand constraint ("ir") for movq insn. Since movq sign-extends its immediate operand, "er" constraint should be used instead. Attached patch changes all uses of __put_user_asm in uaccess_64.h to use "er" when "q" insn suffix is involved. Patch was compile tested on x86_64 with defconfig. Signed-off-by: Uros Bizjak <ubizjak@gmail.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: stable@kernel.org
2009-07-20x86: Add reboot fixup for SBC-fitPC2Denis Turischev
The CompuLab SBC-fitPC2 board needs to reboot via BIOS. Signed-off-by: Denis Turischev <denis@compulab.co.il> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-07-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: vmlinux.lds.h: restructure BSS linker script macros kconfig: initialize the screen before using curses(3) functions kconfig: variable argument lists needs `stdarg.h' kbuild, deb-pkg: fix install scripts for posix sh
2009-07-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (21 commits) Blackfin: define HARDIRQ_BITS again for now arch/blackfin: Add kmalloc NULL tests Blackfin: add CPLB entries for Core B on-chip L1 SRAM regions Blackfin: work around anomaly 05000189 Blackfin: drop per-cpu loops_per_jiffy tracking Blackfin: fix bugs in GPIO resume code Blackfin: bf537-stamp: fix irq decl for AD7142 Blackfin: fix handling of IPEND in interrupt context save Blackfin: drop duplicate runtime checking of anomaly 05000448 Blackfin: fix incomplete renaming of the bfin-twi-lcd driver Blackfin: fix wrong CTS inversion Blackfin: update handling of anomaly 364 (wrong rev id in BF527-0.1) Blackfin: fix early_dma_memcpy() handling of busy channels Blackfin: handle BF561 Core B memory regions better when SMP=n Blackfin: fix miscompilation in lshrdi3 Blackfin: fix silent crash when no uClinux MTD filesystem exists Blackfin: restore exception banner when dumping crash info Blackfin: work around anomaly 05000281 Blackfin: update anomaly lists to match latest sheets/usage Blackfin: drop dead flash_probe call ...
2009-07-20blackfin: fix wrong CTS inversionSonic Zhang
The Blackfin serial headers were inverting the CTS value leading to wrong handling of the CTS line which broke CTS/RTS handling completely. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-18Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: ARM: Realview & Versatile: Fix i2c_board_info definitions [ARM] 5608/1: Updated U300 defconfig [ARM] 5606/1: Fix ep93xx watchdog driver headers [ARM] 5594/1: Correct U300 VIC init PM setting [ARM] 5595/1: ep93xx: missing header in dma-m2p.c [ARM] Kirkwood: Correct header define [ARM] pxa: fix ULPI_{DIR,NXT,STP} MFP defines backlight: fix pwm_bl.c to notify platform code when suspending [ARM] pxa: use kzalloc() in pxa_init_gpio_chip() [ARM] pxa: correct I2CPWR clock for pxa3xx pxamci: correct DMA flow control ARM: add support for the EET board, based on the i.MX31 pcm037 module pcm037: add MT9T031 camera support Armadillo 500 add NAND flash device support (resend). ARM MXC: Armadillo 500 add NOR flash device support (resend). mx31: remove duplicated #include
2009-07-18ARM: Realview & Versatile: Fix i2c_board_info definitionsRussell King
Fix i2c_board_info definitions - we were defining the 'type' field of these structures twice since the first argument of I2C_BOARD_INFO sets this field. Move the second definition into I2C_BOARD_INFO(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Jean Delvare <khali@linux-fr.org> Acked-by: Ben Dooks <ben-linux@fluff.org>
2009-07-18x86: Include all of .data.* sections in _edata on 64-bitCatalin Marinas
The .data.read_mostly and .data.cacheline_aligned sections aren't covered by the _sdata .. _edata range on x86-64. This affects kmemleak reporting leading to possible false positives by not scanning the whole data section. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Tested-by: Alexey Fisher <bug-track@fisher-privat.net> Acked-by: Sam Ravnborg <sam@ravnborg.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> LKML-Reference: <1247565175.28240.37.camel@pc1117.cambridge.arm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Sam Ravnborg <sam@ravnborg.org>
2009-07-18x86: Add quirk for Intel DG45ID board to avoid low memory corruptionAlexey Fisher
AMI BIOS with low memory corruption was found on Intel DG45ID board (Bug 13710). Add this board to the blacklist - in the (somewhat optimistic) hope of future boards/BIOSes from Intel not having this bug. Also see: http://bugzilla.kernel.org/show_bug.cgi?id=13736 Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Cc: ykzhao <yakui.zhao@intel.com> Cc: alan@lxorguk.ukuu.org.uk Cc: <stable@kernel.org> LKML-Reference: <1247660169-4503-1-git-send-email-bug-track@fisher-privat.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-18vmlinux.lds.h: restructure BSS linker script macrosTim Abbott
The BSS section macros in vmlinux.lds.h currently place the .sbss input section outside the bounds of [__bss_start, __bss_end]. On all architectures except for microblaze that handle both .sbss and __bss_start/__bss_end, this is wrong: the .sbss input section is within the range [__bss_start, __bss_end]. Relatedly, the example code at the top of the file actually has __bss_start/__bss_end defined twice; I believe the right fix here is to define them in the BSS_SECTION macro but not in the BSS macro. Another problem with the current macros is that several architectures have an ALIGN(4) or some other small number just before __bss_stop in their linker scripts. The BSS_SECTION macro currently hardcodes this to 4; while it should really be an argument. It also ignores its sbss_align argument; fix that. mn10300 is the only user at present of any of the macros touched by this patch. It looks like mn10300 actually was incorrectly converted to use the new BSS() macro (the alignment of 4 prior to conversion was a __bss_stop alignment, but the argument to the BSS macro is a start alignment). So fix this as well. I'd like acks from Sam and David on this one. Also CCing Paul, since he has a patch from me which will need to be updated to use BSS_SECTION(0, PAGE_SIZE, 4) once this gets merged. Signed-off-by: Tim Abbott <tabbott@ksplice.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-07-17Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/fyu/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/fyu/linux-2.6: Revert "Neither asm/types.h nor linux/types.h is required for arch/ia64/include/asm/fpu.h" Add dma_debug_init() for ia64 Fix ia64 compilation IS_ERR and PTE_ERR errors.
2009-07-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: x86/pci: insert ioapic resource before assigning unassigned resources
2009-07-17Revert "Neither asm/types.h nor linux/types.h is required for ↵Aurelien Jarno
arch/ia64/include/asm/fpu.h" asm/fpu.h uses the __IA64_UL macro which is declared in asm/types.h, so this include is really required. Without it, GNU libc fails to build. This reverts commit 2678c07b07ac2076675e5d57653bdf02e9af1950. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Acked-by: Fenghua Yu <fenghua.yu@intel.com>
2009-07-17Add dma_debug_init() for ia64fujita
The commit 9916219579d078c80377dd3988c2cc213536d868 was supposed to add CONFIG_DMA_API_DEBUG support to IA64 however I forgot to add dma_debug_init(). Signed-off-by: fujita <fujita@tulip.osrg.net> Acked-by: Fenghua Yu <fenghua.yu@intel.com>
2009-07-17Fix ia64 compilation IS_ERR and PTE_ERR errors.Fenghua Yu
When building ia64 kernel with CONFIG_XEN_SYS_HYPERVISOR, compiler reports errors: drivers/xen/sys-hypervisor.c: In function ‘uuid_show’: drivers/xen/sys-hypervisor.c:125: error: implicit declaration of function ‘IS_ERR’ drivers/xen/sys-hypervisor.c:126: error: implicit declaration of function ‘PTR_ERR’ This patch fixes the errors. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Isaku Yamahata <yamahata@valinux.co.jp>
