commit e571c58f313d35c56e0018470e3375ddd1fd320e upstream.
Skip the futex_atomic_cmpxchg_inatomic() test in futex_init(). It causes a
fatal exception on 68030 (and presumably 68020 also).
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Link: http://lkml.kernel.org/r/alpine.LNX.2.00.1403061006440.5525@nippy.intranet
commit 03b8c7b623c80af264c4c8d6111e5c6289933666 upstream.
If an architecture has futex_atomic_cmpxchg_inatomic() implemented and there
is no runtime check necessary, allow to skip the test within futex_init().
This allows to get rid of some code which would always give the same result,
and also allows the compiler to optimize a couple of if statements away.
Cc: Finn Thain <fthain@telegraphics.com.au>
Link: http://lkml.kernel.org/r/20140302120947.GA3641@osiris
[geert: Backported to v3.10..v3.13]
commit 61fb4bfc010b0d2940f7fd87acbce6a0f03217cb upstream.
Despite the switch to right UART driver (prev patch), serial console
still doesn't work due to missing CONFIG_SERIAL_OF_PLATFORM
Also fix the default cmdline in DT to not refer to out-of-tree
ARC framebuffer driver for console.
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
Cc: Francois Bedard <Francois.Bedard@synopsys.com>
commit 6eda477b3c54b8236868c8784e5e042ff14244f0 upstream.
The Synopsys APB DW UART has a couple of special features that are not
in the System C model. In 3.8, the 8250_dw driver didn't really use these
features, but from 3.9 onwards, the 8250_dw driver has become incompatible
with our model.
Signed-off-by: Mischa Jonker <mjonker@synopsys.com>
commit 825600c0f20e595daaa7a6dd8970f84fa2a2ee57 upstream.
On x86 uniprocessor systems topology_physical_package_id() returns -1
which causes rapl_cpu_prepare() to leave rapl_pmu variable uninitialized
which leads to GPF in rapl_pmu_init().
See arch/x86/kernel/cpu/perf_event_intel_rapl.c.
It turns out that physical_package_id and core_id can actually be
retreived for uniprocessor systems too. Enabling them also fixes
rapl_pmu code.
Signed-off-by: Artem Fetishev <artem_fetishev@epam.com>
Cc: Stephane Eranian <eranian@google.com>
commit 5926f87fdaad4be3ed10cec563bf357915e55a86 upstream.
This reverts commit a9c8e4beeeb64c22b84c803747487857fe424b68.
PTEs in Xen PV guests must contain machine addresses if _PAGE_PRESENT
is set and pseudo-physical addresses is _PAGE_PRESENT is clear.
This is because during a domain save/restore (migration) the page
table entries are "canonicalised" and uncanonicalised". i.e., MFNs are
converted to PFNs during domain save so that on a restore the page
table entries may be rewritten with the new MFNs on the destination.
This canonicalisation is only done for PTEs that are present.
This change resulted in writing PTEs with MFNs if _PAGE_PROTNONE (or
_PAGE_NUMA) was set but _PAGE_PRESENT was clear. These PTEs would be
migrated as-is which would result in unexpected behaviour in the
destination domain. Either a) the MFN would be translated to the
wrong PFN/page; b) setting the _PAGE_PRESENT bit would clear the PTE
because the MFN is no longer owned by the domain; or c) the present
bit would not get set.
Symptoms include "Bad page" reports when munmapping after migrating a
domain.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 26a865f4aa8e66a6d94958de7656f7f1b03c6c56 upstream.
After free_loaded_vmcs executes, the "loaded_vmcs" structure
is kfreed, and now vmx->loaded_vmcs points to a kfreed area.
Subsequent free_loaded_vmcs then attempts to manipulate
vmx->loaded_vmcs.
Switch the order to avoid the problem.
https://bugzilla.redhat.com/show_bug.cgi?id=1047892
Reviewed-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
commit 37f6a4e237303549c8676dfe1fd1991ceab512eb upstream.
Rom Freiman <rom@stratoscale.com> notes other code paths vulnerable to
bug fixed by 989c6b34f6a9480e397b.
commit 989c6b34f6a9480e397b170cc62237e89bf4fdb9 upstream.
It is possible for __direct_map to be called on invalid root_hpa
(-1), two examples:
1) try_async_pf -> can_do_async_pf
-> vmx_interrupt_allowed -> nested_vmx_vmexit
2) vmx_handle_exit -> vmx_interrupt_allowed -> nested_vmx_vmexit
Then to load_vmcs12_host_state and kvm_mmu_reset_context.
Check for this possibility, let fault exception be regenerated.
BZ: https://bugzilla.redhat.com/show_bug.cgi?id=924916
commit af87d2fe95444d107e0c0cf0ba7e20e6716a7bfd upstream.
As Ben suggested, the patch prints PHB diag-data with multiple
fields in one line and omits the line if the fields of that
line are all zero.
With the patch applied, the PHB3 diag-data dump looks like:
PHB3 PHB#3 Diag-data (Version: 1)
brdgCtl: 00000002
RootSts: 0000000f 00400000 b0830008 00100147 00002000
nFir: 0000000000000000 0030006e00000000 0000000000000000
PhbSts: 0000001c00000000 0000000000000000
Lem: 0000000000100000 42498e327f502eae 0000000000000000
InAErr: 8000000000000000 8000000000000000 0402030000000000 0000000000000000
PE[ 8] A/B: 8480002b00000000 8000000000000000
[ The current diag data is so big that it overflows the printk
buffer pretty quickly in cases when we get a handful of errors
at once which can happen. --BenH
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
commit 947166043732b69878123bf31f51933ad0316080 upstream.
The PHB diag-data is important to help locating the root cause for
EEH errors such as frozen PE or fenced PHB. However, the EEH core
enables IO path by clearing part of HW registers before collecting
this data causing it to be corrupted.
This patch fixes this by dumping the PHB diag-data immediately when
frozen/fenced state on PE or PHB is detected for the first time in
eeh_ops::get_state() or next_error() backend.
CC: <stable@vger.kernel.org>
commit 7e4e7867b1e551b7b8f326da3604c47332972bc6 upstream.
For one PCI error relevant OPAL event, we possibly have multiple
EEH errors for that. For example, multiple frozen PEs detected on
different PHBs. Unfortunately, we didn't cover the case. The patch
enumarates the return value from eeh_ops::next_error() and change
eeh_handle_special_event() and eeh_ops::next_error() to handle all
existing EEH errors.
As Ben pointed out, we needn't list_for_each_entry_safe() since we
are not deleting any PHB from the hose_list and the EEH serialized
lock should be held while purging EEH events. The patch covers those
suggestions as well.
commit 93aef2a789778e7ec787179fc9b34ca4885a5ef3 upstream.
Prior to the completion of PCI enumeration, we actively detects
EEH errors on PCI config cycles and dump PHB diag-data if necessary.
The EEH backend also dumps PHB diag-data in case of frozen PE or
fenced PHB. However, we are using different functions to dump the
PHB diag-data for those 2 cases.
The patch merges the functions for dumping PHB diag-data to one so
that we can avoid duplicate code. Also, we never dump PHB3 diag-data
during PCI config cycles with frozen PE. The patch fixes it as well.
commit 63238f2cc5518e1c45a3418fc0ac0f560dafe7ef upstream.
The following build error is seen if CONFIG_32BIT is undefined,
CONFIG_64BIT is defined, and CONFIG_MIPS32_O32 is undefined.
asm/syscall.h: In function 'mips_get_syscall_arg':
arch/mips/include/asm/syscall.h:32:16: error: unused variable 'usp' [-Werror=unused-variable]
cc1: all warnings being treated as errors
Fixes: c0ff3c53d4f9 ('MIPS: Enable HAVE_ARCH_TRACEHOOK')
Acked-by: David Daney <david.daney@cavium.com>
Signed-off-by: John Crispin <blogic@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/6160/
commit fdfaf64e75397567257e1051931f9a3377360665 upstream.
Commit a998d4342337 claimed to introduce negative offset support to x86 jit,
but it couldn't be working, since at the time of the execution
of LD+ABS or LD+IND instructions via call into
bpf_internal_load_pointer_neg_helper() the %edx (3rd argument of this func)
had junk value instead of access size in bytes (1 or 2 or 4).
Store size into %edx instead of %ecx (what original commit intended to do)
Fixes: a998d4342337 ("bpf jit: Let the x86 jit handle negative offsets")
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Cc: Jan Seiffert <kaffeemonster@googlemail.com>
Cc: Eric Dumazet <edumazet@google.com>
commit 4c235cb9e35407bdb4a2debeef4dc8721e8f91f2 upstream.
Commit 65939301acdb (arm: set initrd_start/initrd_end for fdt scan)
caused the FDT initrd_start and initrd_end to override the
phys_initrd_start and phys_initrd_size set by the initrd= kernel
parameter. With this patch initrd_start and initrd_end will be
overridden if phys_initrd_start and phys_initrd_size are set by the
kernel initrd= parameter.
Fixes: 65939301acdb (arm: set initrd_start/initrd_end for fdt scan)
Signed-off-by: Ben Peddell <klightspeed@killerwolves.net>
Acked-by: Jason Cooper <jason@lakedaemon.net>
commit 84fe6826c28f69d8708bd575faed7f75e6b6f57f upstream.
Page table entries on ARM64 are 64 bits, and some pte functions such as
pte_dirty return a bitwise-and of a flag with the pte value. If the
flag to be tested resides in the upper 32 bits of the pte, then we run
into the danger of the result being dropped if downcast.
For example:
gather_stats(page, md, pte_dirty(*pte), 1);
where pte_dirty(*pte) is downcast to an int.
This patch adds a double logical invert to all the pte_ accessors to
ensure predictable downcasting.
Signed-off-by: Steve Capper <steve.capper@linaro.org>
[steve.capper@linaro.org: rebased patch to leave pte_write alone to
allow for merge with 3.13 stable]
commit 87c99203fea897fbdd84b681ad9fced2517dcf98 upstream.
The file uses u16 type but doesn't include its definition explicitly
I was getting this error when including this header in my driver:
arch/mips/include/asm/mipsregs.h:644:33: error: unknown type name ‘u16’
Signed-off-by: Qais Yousef <qais.yousef@imgtec.com>
Reviewed-by: Steven J. Hill <Steven.Hill@imgtec.com>
Patchwork: http://patchwork.linux-mips.org/patch/6212/
commit 731bd6a93a6e9172094a2322bd0ee964bb1f4d63 upstream.
For non-eager fpu mode, thread's fpu state is allocated during the first
fpu usage (in the context of device not available exception). This
(math_state_restore()) can be a blocking call and hence we enable
interrupts (which were originally disabled when the exception happened),
allocate memory and disable interrupts etc.
But the eager-fpu mode, call's the same math_state_restore() from
kernel_fpu_end(). The assumption being that tsk_used_math() is always
set for the eager-fpu mode and thus avoid the code path of enabling
interrupts, allocating fpu state using blocking call and disable
interrupts etc.
But the below issue was noticed by Maarten Baert, Nate Eldredge and
few others:
If a user process dumps core on an ecrypt fs while aesni-intel is loaded,
we get a BUG() in __find_get_block() complaining that it was called with
interrupts disabled; then all further accesses to our ecrypt fs hang
and we have to reboot.
The aesni-intel code (encrypting the core file that we are writing) needs
the FPU and quite properly wraps its code in kernel_fpu_{begin,end}(),
the latter of which calls math_state_restore(). So after kernel_fpu_end(),
interrupts may be disabled, which nobody seems to expect, and they stay
that way until we eventually get to __find_get_block() which barfs.
For eager fpu, most the time, tsk_used_math() is true. At few instances
during thread exit, signal return handling etc, tsk_used_math() might
be false.
In kernel_fpu_end(), for eager-fpu, call math_state_restore()
only if tsk_used_math() is set. Otherwise, don't bother. Kernel code
path which cleared tsk_used_math() knows what needs to be done
with the fpu state.
Reported-by: Maarten Baert <maarten-baert@hotmail.com>
Reported-by: Nate Eldredge <nate@thatsmathematics.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Suresh Siddha <sbsiddha@gmail.com>
Link: http://lkml.kernel.org/r/1391410583.3801.6.camel@europa
Cc: George Spelvin <linux@horizon.com>
commit 596f3142d2b7be307a1652d59e7b93adab918437 upstream.
We always disable cr8 intercept in its handler, but only re-enable it
if handling KVM_REQ_EVENT, so there can be a window where we do not
intercept cr8 writes, which allows an interrupt to disrupt a higher
priority task.
Fix this by disabling intercepts in the same function that re-enables
them when needed. This fixes BSOD in Windows 2008.
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 847d7970defb45540735b3fb4e88471c27cacd85 upstream.
For systems with multiple servers and routed fabric, all
northbridges get assigned to the first server. Fix this by also
using the node reported from the PCI bus. For single-fabric
systems, the northbriges are on PCI bus 0 by definition, which
are on NUMA node 0 by definition, so this is invarient on most
systems.
Tested on fam10h and fam15h single and multi-fabric systems and
candidate for stable.
Signed-off-by: Daniel J Blueman <daniel@numascale.com>
Acked-by: Steffen Persvold <sp@numascale.com>
Acked-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/1394710981-3596-1-git-send-email-daniel@numascale.com
commit b01d4e68933ec23e43b1046fa35d593cefcf37d1 upstream.
It's an enum, not a #define, you can't use it in asm files.
Introduced in commit 5fa10196bdb5 ("x86: Ignore NMIs that come in during
early boot"), and sadly I didn't compile-test things like I should have
before pushing out.
My weak excuse is that the x86 tree generally doesn't introduce stupid
things like this (and the ARM pull afterwards doesn't cause me to do a
compile-test either, since I don't cross-compile).
Cc: Don Zickus <dzickus@redhat.com>
Cc: H. Peter Anvin <hpa@linux.intel.com>
commit 5fa10196bdb5f190f595ebd048490ee52dddea0f upstream.
Don Zickus reports:
A customer generated an external NMI using their iLO to test kdump
worked. Unfortunately, the machine hung. Disabling the nmi_watchdog
made things work.
I speculated the external NMI fired, caused the machine to panic (as
expected) and the perf NMI from the watchdog came in and was latched.
My guess was this somehow caused the hang.
It appears that the latched NMI stays latched until the early page
table generation on 64 bits, which causes exceptions to happen which
end in IRET, which re-enable NMI. Therefore, ignore NMIs that come in
during early execution, until we have proper exception handling.
Reported-and-tested-by: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/r/1394221143-29713-1-git-send-email-dzickus@redhat.com
commit 052450fdc55894a39fbae93d9bbe43947956f663 upstream.
Due to a problem in the MFD Kconfig it was not possible to
compile the UCB battery driver for the Collie SA1100 system,
in turn making it impossible to compile in the battery driver.
(See patch "mfd: include all drivers in subsystem menu".)
After fixing the MFD Kconfig (separate patch) a compile error
appears in the Collie battery driver due to the <mach/collie.h>
implicitly requiring <mach/hardware.h> through <linux/gpio.h>
via <mach/gpio.h> prior to commit
40ca061b "ARM: 7841/1: sa1100: remove complex GPIO interface".
Fix this up by including the required header into
<mach/collie.h>.
Cc: Andrea Adami <andrea.adami@gmail.com>
Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
commit 006fa2599bf0daf107cbb7a8a99fcfb9a998a169 upstream.
With noMMU, CONFIG_PAGE_OFFSET was not being set correctly. As there's
no MMU, PAGE_OFFSET should be equal to PHYS_OFFSET in all cases. This
commit makes that explicit.
Since we do this, we don't need to mess around in asm/memory.h with
ifdefs to sort this out, so let's get rid of that, and there's no point
offering the "Memory split" option for noMMU as that's meaningless
there.
Fixes: b9b32bf70f2f ("ARM: use linker magic for vectors and vector stubs")
commit a5b2cf5b1af424ee3dd9e3ce6d5cea18cb927e67 upstream.
The 64bit relocation code places a few symbols in the text segment.
These symbols are only 4 byte aligned where they need to be 8 byte
aligned. Add an explicit alignment.
Tested-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
commit 621b5060e823301d0cba4cb52a7ee3491922d291 upstream.
When we fork/clone we currently don't copy any of the TM state to the new
thread. This results in a TM bad thing (program check) when the new process is
switched in as the kernel does a tmrechkpt with TEXASR FS not set. Also, since
R1 is from userspace, we trigger the bad kernel stack pointer detection. So we
end up with something like this:
Bad kernel stack pointer 0 at c0000000000404fc
cpu 0x2: Vector: 700 (Program Check) at [c00000003ffefd40]
pc: c0000000000404fc: restore_gprs+0xc0/0x148
lr: 0000000000000000
sp: 0
msr: 9000000100201030
current = 0xc000001dd1417c30
paca = 0xc00000000fe00800 softe: 0 irq_happened: 0x01
pid = 0, comm = swapper/2
WARNING: exception is not recoverable, can't continue
The below fixes this by flushing the TM state before we copy the task_struct to
the clone. To do this we go through the tmreclaim patch, which removes the
checkpointed registers from the CPU and transitions the CPU out of TM suspend
mode. Hence we need to call tmrechkpt after to restore the checkpointed state
and the TM mode for the current task.
To make this fail from userspace is simply:
tbegin
li r0, 2
sc
<boom>
Kudos to Adhemerval Zanella Neto for finding this.
Signed-off-by: Michael Neuling <mikey@neuling.org>
cc: Adhemerval Zanella Neto <azanella@br.ibm.com>
commit b053940df41808f0f27568eb36820d10a8a987f8 upstream.
This fixes a subtle issue with cache flush which could potentially cause
random userspace crashes because of stale icache lines.
This error crept in when consolidating the cache flush code
Fixes: bd12976c3664 (ARC: cacheflush refactor #3: Unify the {d,i}cache)
Cc: arc-linux-dev@synopsys.com
commit e306dfd06fcb44d21c80acb8e5a88d55f3d1cf63 upstream.
The frame PC value in the unwind code used to just take the saved LR
value and use that. That's incorrect as a stack trace, since it shows
the return path stack, not the call path stack.
In particular, it shows faulty information in case the bl is done as
the very last instruction of one label, since the return point will be
in the next label. That can easily be seen with tail calls to panic(),
which is marked __noreturn and thus doesn't have anything useful after it.
Easiest here is to just correct the unwind code and do a -4, to get the
actual call site for the backtrace instead of the return site.
commit e2fd1374c705abe4661df3fb6fadb3879c7c1846 upstream.
Most in-kernel users want registers spilled on the kernel stack and
don't require PS.EXCM to be set. That means that they don't need fixup
routine and could reuse regular window overflow mechanism for that,
which makes spill routine very simple.
Suggested-by: Chris Zankel <chris@zankel.net>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 3251f1e27a5a17f0efd436cfd1e7b9896cfab0a0 upstream.
We need it saved because it contains a3 where we track which register
windows we still need to spill, and fixup handler may call C exception
handlers. Also fix comments.
commit 26e61e8939b1fe8729572dabe9a9e97d930dd4f6 upstream.
Vince "Super Tester" Weaver reported a new round of syscall fuzzing (Trinity) failures,
with perf WARN_ON()s triggering. He also provided traces of the failures.
This is I think the relevant bit:
> pec_1076_warn-2804 [000] d... 147.926153: x86_pmu_disable: x86_pmu_disable
> pec_1076_warn-2804 [000] d... 147.926153: x86_pmu_state: Events: {
> pec_1076_warn-2804 [000] d... 147.926156: x86_pmu_state: 0: state: .R config: ffffffffffffffff ( (null))
> pec_1076_warn-2804 [000] d... 147.926158: x86_pmu_state: 33: state: AR config: 0 (ffff88011ac99800)
> pec_1076_warn-2804 [000] d... 147.926159: x86_pmu_state: }
> pec_1076_warn-2804 [000] d... 147.926160: x86_pmu_state: n_events: 1, n_added: 0, n_txn: 1
> pec_1076_warn-2804 [000] d... 147.926161: x86_pmu_state: Assignment: {
> pec_1076_warn-2804 [000] d... 147.926162: x86_pmu_state: 0->33 tag: 1 config: 0 (ffff88011ac99800)
> pec_1076_warn-2804 [000] d... 147.926163: x86_pmu_state: }
> pec_1076_warn-2804 [000] d... 147.926166: collect_events: Adding event: 1 (ffff880119ec8800)
So we add the insn:p event (fd[23]).
At this point we should have:
n_events = 2, n_added = 1, n_txn = 1
> pec_1076_warn-2804 [000] d... 147.926170: collect_events: Adding event: 0 (ffff8800c9e01800)
> pec_1076_warn-2804 [000] d... 147.926172: collect_events: Adding event: 4 (ffff8800cbab2c00)
We try and add the {BP,cycles,br_insn} group (fd[3], fd[4], fd[15]).
These events are 0:cycles and 4:br_insn, the BP event isn't x86_pmu so
that's not visible.
group_sched_in()
pmu->start_txn() /* nop - BP pmu */
event_sched_in()
event->pmu->add()
So here we should end up with:
0: n_events = 3, n_added = 2, n_txn = 2
4: n_events = 4, n_added = 3, n_txn = 3
But seeing the below state on x86_pmu_enable(), the must have failed,
because the 0 and 4 events aren't there anymore.
Looking at group_sched_in(), since the BP is the leader, its
event_sched_in() must have succeeded, for otherwise we would not have
seen the sibling adds.
But since neither 0 or 4 are in the below state; their event_sched_in()
must have failed; but I don't see why, the complete state: 0,0,1:p,4
fits perfectly fine on a core2.
However, since we try and schedule 4 it means the 0 event must have
succeeded! Therefore the 4 event must have failed, its failure will
have put group_sched_in() into the fail path, which will call:
event_sched_out()
event->pmu->del()
on 0 and the BP event.
Now x86_pmu_del() will reduce n_events; but it will not reduce n_added;
giving what we see below:
n_event = 2, n_added = 2, n_txn = 2
> pec_1076_warn-2804 [000] d... 147.926177: x86_pmu_enable: x86_pmu_enable
> pec_1076_warn-2804 [000] d... 147.926177: x86_pmu_state: Events: {
> pec_1076_warn-2804 [000] d... 147.926179: x86_pmu_state: 0: state: .R config: ffffffffffffffff ( (null))
> pec_1076_warn-2804 [000] d... 147.926181: x86_pmu_state: 33: state: AR config: 0 (ffff88011ac99800)
> pec_1076_warn-2804 [000] d... 147.926182: x86_pmu_state: }
> pec_1076_warn-2804 [000] d... 147.926184: x86_pmu_state: n_events: 2, n_added: 2, n_txn: 2
> pec_1076_warn-2804 [000] d... 147.926184: x86_pmu_state: Assignment: {
> pec_1076_warn-2804 [000] d... 147.926186: x86_pmu_state: 0->33 tag: 1 config: 0 (ffff88011ac99800)
> pec_1076_warn-2804 [000] d... 147.926188: x86_pmu_state: 1->0 tag: 1 config: 1 (ffff880119ec8800)
> pec_1076_warn-2804 [000] d... 147.926188: x86_pmu_state: }
> pec_1076_warn-2804 [000] d... 147.926190: x86_pmu_enable: S0: hwc->idx: 33, hwc->last_cpu: 0, hwc->last_tag: 1 hwc->state: 0
So the problem is that x86_pmu_del(), when called from a
group_sched_in() that fails (for whatever reason), and without x86_pmu
TXN support (because the leader is !x86_pmu), will corrupt the n_added
state.
Reported-and-Tested-by: Vince Weaver <vincent.weaver@maine.edu>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Dave Jones <davej@redhat.com>
Link: http://lkml.kernel.org/r/20140221150312.GF3104@twins.programming.kicks-ass.net
commit c091c71ad2218fc50a07b3d1dab85783f3b77efd upstream.
GFP_ATOMIC is not a single gfp flag, but a macro which expands to the other
flags, where meaningful is the LACK of __GFP_WAIT flag. To check if caller
wants to perform an atomic allocation, the code must test for a lack of the
__GFP_WAIT flag. This patch fixes the issue introduced in v3.5-rc1.
commit e0cf957614976896111e676e5134ac98ee227d3d upstream.
We need to unmangle the full address, not just the register
number, and we also need to support the real indirect bit
being set for in-kernel uses.
commit 2f3f38e4d3d03dd4125cc9a1f49ab3cc91d8d670 upstream.
The OPAL firmware functions opal_xscom_read and opal_xscom_write
take a 64-bit argument for the XSCOM (PCB) address in order to
support the indirect mode on P8.
commit f5295bd8ea8a65dc5eac608b151386314cb978f1 upstream.
In copy_oldmem_page, the current check using max_pfn and min_low_pfn to
decide if the page is backed or not, is not valid when the memory layout is
not continuous.
This happens when running as a QEMU/KVM guest, where RTAS is mapped higher
in the memory. In that case max_pfn points to the end of RTAS, and a hole
between the end of the kdump kernel and RTAS is not backed by PTEs. As a
consequence, the kdump kernel is crashing in copy_oldmem_page when accessing
in a direct way the pages in that hole.
This fix relies on the memblock's service memblock_is_region_memory to
check if the read page is part or not of the directly accessible memory.
Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Tested-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
commit 41dd03a94c7d408d2ef32530545097f7d1befe5c upstream.
Currently we're storing a host endian RTAS token in
rtas_stop_self_args.token. We then pass that directly to rtas. This is
fine on big endian however on little endian the token is not what we
expect.
This will typically result in hitting:
panic("Alas, I survived.\n");
To fix this we always use the stop-self token in host order and always
convert it to be32 before passing this to rtas.
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
commit 573ebfa6601fa58b439e7f15828762839ccd306a upstream.
The new ELFv2 little-endian ABI increases the stack redzone -- the
area below the stack pointer that can be used for storing data --
from 288 bytes to 512 bytes. This means that we need to allow more
space on the user stack when delivering a signal to a 64-bit process.
To make the code a bit clearer, we define new USER_REDZONE_SIZE and
KERNEL_REDZONE_SIZE symbols in ptrace.h. For now, we leave the
kernel redzone size at 288 bytes, since increasing it to 512 bytes
would increase the size of interrupt stack frames correspondingly.
Gcc currently only makes use of 288 bytes of redzone even when
compiling for the new little-endian ABI, and the kernel cannot
currently be compiled with the new ABI anyway.
In the future, hopefully gcc will provide an option to control the
amount of redzone used, and then we could reduce it even more.
This also changes the code in arch_compat_alloc_user_space() to
preserve the expanded redzone. It is not clear why this function would
ever be used on a 64-bit process, though.
commit 1b385cbdd74aa803e966e01e5fe49490d6044e30 upstream.
Commit e504c9098ed6 (kvm, vmx: Fix lazy FPU on nested guest, 2013-11-13)
highlighted a real problem, but the fix was subtly wrong.
nested_read_cr0 is the CR0 as read by L2, but here we want to look at
the CR0 value reflecting L1's setup. In other words, L2 might think
that TS=0 (so nested_read_cr0 has the bit clear); but if L1 is actually
running it with TS=1, we should inject the fault into L1.
The effective value of CR0 in L2 is contained in vmcs12->guest_cr0, use
it.
Fixes: e504c9098ed6acd9e1079c5e10e4910724ad429f
Reported-by: Kashyap Chamarty <kchamart@redhat.com>
Reported-by: Stefan Bader <stefan.bader@canonical.com>
Tested-by: Kashyap Chamarty <kchamart@redhat.com>
Tested-by: Anthoine Bourgeois <bourgeois@bertin.fr>
commit a08d3b3b99efd509133946056531cdf8f3a0c09b upstream.
The problem occurs when the guest performs a pusha with the stack
address pointing to an mmio address (or an invalid guest physical
address) to start with, but then extending into an ordinary guest
physical address. When doing repeated emulated pushes
emulator_read_write sets mmio_needed to 1 on the first one. On a
later push when the stack points to regular memory,
mmio_nr_fragments is set to 0, but mmio_is_needed is not set to 0.
As a result, KVM exits to userspace, and then returns to
complete_emulated_mmio. In complete_emulated_mmio
vcpu->mmio_cur_fragment is incremented. The termination condition of
vcpu->mmio_cur_fragment == vcpu->mmio_nr_fragments is never achieved.
The code bounces back and fourth to userspace incrementing
mmio_cur_fragment past it's buffer. If the guest does nothing else it
eventually leads to a a crash on a memcpy from invalid memory address.
However if a guest code can cause the vm to be destroyed in another
vcpu with excellent timing, then kvm_clear_async_pf_completion_queue
can be used by the guest to control the data that's pointed to by the
call to cancel_work_item, which can be used to gain execution.
Fixes: f78146b0f9230765c6315b2e14f56112513389ad
Signed-off-by: Andrew Honig <ahonig@google.com>
commit 8d80390cfc9434d5aa4fb9e5f9768a66b30cb8a6 upstream.
For avr32 cross compiler, do not define '__linux__' internally, so it
will cause issue with allmodconfig.
The related error:
CC [M] fs/coda/psdev.o
In file included from include/linux/coda.h:64,
from fs/coda/psdev.c:45:
include/uapi/linux/coda.h:221: error: expected specifier-qualifier-list before 'u_quad_t'
The related toolchain version (which only download, not re-compile):
[root@gchen linux-next]# /upstream/toolchain/download/avr32-gnu-toolchain-linux_x86/bin/avr32-gcc -v
Using built-in specs.
Target: avr32
Configured with: /data2/home/toolsbuild/jenkins-knuth/workspace/avr32-gnu-toolchain/src/gcc/configure --target=avr32 --host=i686-pc-linux-gnu --build=x86_64-pc-linux-gnu --prefix=/home/toolsbuild/jenkins-knuth/workspace/avr32-gnu-toolchain/avr32-gnu-toolchain-linux_x86 --enable-languages=c,c++ --disable-nls --disable-libssp --disable-libstdcxx-pch --with-dwarf2 --enable-version-specific-runtime-libs --disable-shared --enable-doc --with-mpfr-lib=/home/toolsbuild/jenkins-knuth/workspace/avr32-gnu-toolchain/avr32-gnu-toolchain-linux_x86/lib --with-mpfr-include=/home/toolsbuild/jenkins-knuth/workspace/avr32-gnu-toolchain/avr32-gnu-toolchain-linux_x86/include --with-gmp=/home/toolsbuild/jenkins-knuth/workspace/avr32-gnu-toolchain/avr32-gnu-toolchain-linux_x86 --with-mpc=/home/toolsbuild/jenkins-knuth/workspace/avr32-gnu-toolchain/avr32-gnu-toolchain-linux_x86 --enable-__cxa_atexit --disable-shared --with-newlib --with-pkgversion=AVR_32_bit_GNU_Toolchain_3.4.2_435 --with-bugurl=http://www
.atmel.com/avr
Thread model: single
gcc version 4.4.7 (AVR_32_bit_GNU_Toolchain_3.4.2_435)
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
Acked-by: Hans-Christian Egtvedt <hegtvedt@cisco.com>
commit 5745d6a41a4f4aec29e2ccd591c6fb09ed73a955 upstream.
Causing this:
In file included from arch/avr32/boards/mimc200/fram.c:13:
include/linux/miscdevice.h:51: error: field 'list' has incomplete type
include/linux/miscdevice.h:55: error: expected specifier-qualifier-list before 'mode_t'
arch/avr32/boards/mimc200/fram.c:42: error: 'THIS_MODULE' undeclared here (not in a function)
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
commit 5b2e198e50f6ba57081586b853163ea1bb95f1a8 upstream.
When doing reset in order to recover the affected PE, we issue
hot reset on PE primary bus if it's not root bus. Otherwise, we
issue hot or fundamental reset on root port or PHB accordingly.
For the later case, we didn't cover the situation where PE only
includes root port and it potentially causes kernel crash upon
EEH error to the PE.
The patch reworks the logic of EEH reset to improve the code
readability and also avoid the kernel crash.
Reported-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
commit 1a18a66446f3f289b05b634f18012424d82aa63a upstream.
Guenter Roeck has got the following call trace on a p2020 board:
Kernel stack overflow in process eb3e5a00, r1=eb79df90
CPU: 0 PID: 2838 Comm: ssh Not tainted 3.13.0-rc8-juniper-00146-g19eca00 #4
task: eb3e5a00 ti: c0616000 task.ti: ef440000
NIP: c003a420 LR: c003a410 CTR: c0017518
REGS: eb79dee0 TRAP: 0901 Not tainted (3.13.0-rc8-juniper-00146-g19eca00)
MSR: 00029000 <CE,EE,ME> CR: 24008444 XER: 00000000
GPR00: c003a410 eb79df90 eb3e5a00 00000000 eb05d900 00000001 65d87646 00000000
GPR08: 00000000 020b8000 00000000 00000000 44008442
NIP [c003a420] __do_softirq+0x94/0x1ec
LR [c003a410] __do_softirq+0x84/0x1ec
Call Trace:
[eb79df90] [c003a410] __do_softirq+0x84/0x1ec (unreliable)
[eb79dfe0] [c003a970] irq_exit+0xbc/0xc8
[eb79dff0] [c000cc1c] call_do_irq+0x24/0x3c
[ef441f20] [c00046a8] do_IRQ+0x8c/0xf8
[ef441f40] [c000e7f4] ret_from_except+0x0/0x18
--- Exception: 501 at 0xfcda524
LR = 0x10024900
Instruction dump:
7c781b78 3b40000a 3a73b040 543c0024 3a800000 3b3913a0 7ef5bb78 48201bf9
5463103a 7d3b182e 7e89b92e 7c008146 <3ba00000> 7e7e9b78 48000014 57fff87f
Kernel panic - not syncing: kernel stack overflow
Call Trace:
The reason is that we have used the wrong register to calculate the
ksp_limit in commit cbc9565ee826 (powerpc: Remove ksp_limit on ppc64).
Just fix it.
As suggested by Benjamin Herrenschmidt, also add the C prototype of the
function in the comment in order to avoid such kind of errors in the
future.
Reported-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Kevin Hao <haokexin@gmail.com>
commit 8859685785bfafadf9bc922dd3a2278e59886947 upstream.
Fix tegra_init_cache() to check whether the system has a PL310 cache
before touching the PL310 registers. This prevents access to non-existent
registers on Tegra114 and later.
Note for stable kernels:
In <= v3.12, the file to patch is arch/arm/mach-tegra/common.c.
commit 28a9f3b078c545064dcf4b46d2c6917554d1642e upstream.
When building a kernel image with only CONFIG_CPU_IDLE but no CONFIG_PM,
we will get the following link error.
LD init/built-in.o
arch/arm/mach-imx/built-in.o: In function `imx6q_enter_wait':
platform-spi_imx.c:(.text+0x25c0): undefined reference to `imx6q_set_lpm'
platform-spi_imx.c:(.text+0x25d4): undefined reference to `imx6q_set_lpm'
arch/arm/mach-imx/built-in.o: In function `imx6q_cpuidle_init':
platform-spi_imx.c:(.init.text+0x75d4): undefined reference to `imx6q_set_chicken_bit'
make[1]: *** [vmlinux] Error 1
Since pm-imx6q.c has been a collection of library functions that access
CCM low-power registers used by not only suspend but also cpuidle and
other drivers, let's build pm-imx6q.c independently of CONFIG_PM to fix
above error.
Reported-by: Lucas Stach <l.stach@pengutronix.de>
Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
is built as module
commit 980386d2d6d49e0b42f48550853ef1ad6aa5d79a upstream.
Fixes: commit 75d3625e0e86b2d8d77b4e9c6f685fd7ea0d5a96
ARM: OMAP2+: gpmc: add DT bindings for OneNAND
OMAP SoC(s) depend on GPMC controller driver to parse GPMC DT child nodes and
register them platform_device for ONENAND driver to probe later. However this does
not happen if generic MTD_ONENAND framework is built as module (CONFIG_MTD_ONENAND=m).
Therefore, when MTD/ONENAND and MTD/ONENAND/OMAP2 modules are loaded, they are unable
to find any matching platform_device and remain un-binded. This causes on board
ONENAND flash to remain un-detected.
This patch causes GPMC controller to parse DT nodes when
CONFIG_MTD_ONENAND=y || CONFIG_MTD_ONENAND=m
Signed-off-by: Pekon Gupta <pekon@ti.com>
built as module
commit 6b187b21c92b6e2c7e8ef0b450181c37a3f31681 upstream.
Fixes: commit bc6b1e7b86f5d8e4a6fc1c0189e64bba4077efe0
ARM: OMAP: gpmc: add DT bindings for GPMC timings and NAND
register them platform_device for NAND driver to probe later. However this does
not happen if generic MTD_NAND framework is built as module (CONFIG_MTD_NAND=m).
Therefore, when MTD/NAND and MTD/NAND/OMAP2 modules are loaded, they are unable
CONFIG_MTD_NAND=y || CONFIG_MTD_NAND=m
commit 39544ac9df20f73e49fc6b9ac19ff533388c82c0 upstream.
Add DSB after icache flush to complete the cache maintenance operation.
Signed-off-by: Vinayak Kale <vkale@apm.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
commit 7c8746a9eb287642deaad0e7c2cdf482dce5e4be upstream.
When unlocking a spinlock, we require the following, strictly ordered
sequence of events:
<barrier> /* dmb */
<unlock>
<barrier> /* dsb */
<sev>
Whilst the code does indeed reflect this in terms of the architecture,
the final <barrier> + <sev> have been contracted into a single inline
asm without a "memory" clobber, therefore the compiler is at liberty to
reorder the unlock to the end of the above sequence. In such a case,
a waiting CPU may be woken up before the lock has been unlocked, leading
to extremely poor performance.
This patch reworks the dsb_sev() function to make use of the dsb()
macro and ensure ordering against the unlock.
Reported-by: Mark Rutland <mark.rutland@arm.com>
