Commit 41061cdb98 ("KVM: emulate: do not initialize memopp") removes a
check for non-NULL under incorrect assumptions. An undefined instruction
with a ModR/M byte with Mod=0 and R/M-5 (e.g. 0xc7 0x15) will attempt
to dereference a null pointer here.
Fixes: 41061cdb98a0bec464278b4db8e894a3121671f5
Message-Id: <1477592752-126650-2-git-send-email-osh@google.com>
Signed-off-by: Owen Hofmann <osh@google.com>
After a successful VM-entry with the "VMCS shadowing" VM-execution
control set, the shadow VMCS referenced by the VMCS link pointer field
in the current VMCS becomes active on the logical processor.
A VMCS that is made active on more than one logical processor may become
corrupted. Therefore, before an active VMCS can be migrated to another
logical processor, the first logical processor must execute a VMCLEAR
for the active VMCS. VMCLEAR both ensures that all VMCS data are written
to memory and makes the VMCS inactive.
Signed-off-by: Jim Mattson <jmattson@google.com>
Reviewed-By: David Matlack <dmatlack@google.com>
Message-Id: <1477668579-22555-1-git-send-email-jmattson@google.com>
Since commit a545ab6a0085 ("kvm: x86: add tsc_offset field to struct
kvm_vcpu_arch", 2016-09-07) the offset between host and L1 TSC is
cached and need not be fished out of the VMCS or VMCB. This means
that we can implement adjust_tsc_offset_guest and read_l1_tsc
entirely in generic code. The simplification is particularly
significant for VMX code, where vmx->nested.vmcs01_tsc_offset
was duplicating what is now in vcpu->arch.tsc_offset. Therefore
the vmcs01_tsc_offset can be dropped completely.
More importantly, this fixes KVM_GET_CLOCK/KVM_SET_CLOCK
which, after commit 108b249c453d ("KVM: x86: introduce get_kvmclock_ns",
2016-09-01) called read_l1_tsc while the VMCS was not loaded.
It thus returned bogus values on Intel CPUs.
Fixes: 108b249c453dd7132599ab6dc7e435a7036c193f
Reported-by: Roman Kagan <rkagan@virtuozzo.com>
Reviewed-by: Radim Krčmář <rkrcmar@redhat.com>
At smp_prepare_cpus() we set present cpu mask as part of init
for all CPUs at range [0-max_cpus].
This is done without checking if this mask is already being set.
At platform of eznps this mask is already being initialized at
smp_init_cpus() by using hook plat_smp_ops.init_early_smp().
So to avoid overriding of present cpu mask we check the number of
bits which are set in this mask. At the begin only bit for boot CPU
is set so if number of bits already set is no more than one we can be
assure that there is no overriding of this mask.
Signed-off-by: Noam Camus <noamca@mellanox.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
Now when we have properly working performance counters in nSIM
even with interrupt support (fix should be a part of upcoming
nSIM engineering build 2016.12-005) we may enable perf support
by default for all platforms that use nSIM for ARC cores simulation.
Note 1: PCT node was missing for some reason in nsimosci.dts
while all other nSIM-related .dts files already had
PCT node for quite some time, so adding it now.
Note 2: All defconfigs were regenerated with "make savedefconfig"
which led to some clean-ups in nsimosci_hs_smp_defconfig:
CONFIG_FRAMEBUFFER_CONSOLE=y was removed because it is
automatically selected now by DRM.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Pull ARM fixes from Russell King:
"A fix for a regression on ARMv4T CPUs, and wiring up the new pkey
syscalls for ARM"
* 'fixes' of git://git.armlinux.org.uk/~rmk/linux-arm:
ARM: wire up new pkey syscalls
ARM: fix oops when using older ARMv4T CPUs
Pull sparc fixes from David Miller:
"Several sparc64 bug fixes here:
1) Make the user copy routines on sparc64 return a properly accurate
residual length when an exception occurs.
2) We can get enormous kernel TLB range flush requests from vmalloc
unmaps, so handle these more gracefully by doing full flushes
instead of going page-by-page.
3) Cope properly with negative branch offsets in sparc jump-label
support, from James Clarke.
4) Some old-style decl GCC warning fixups from Tobias Klauser"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
sparc64: Handle extremely large kernel TLB range flushes more gracefully.
sparc64: Fix illegal relative branches in hypervisor patched TLB cross-call code.
sparc64: Fix instruction count in comment for __hypervisor_flush_tlb_pending.
sparc64: Handle extremely large kernel TSB range flushes sanely.
sparc: Handle negative offsets in arch_jump_label_transform
sparc64: Fix illegal relative branches in hypervisor patched TLB code.
sparc64: Delete now unused user copy fixup functions.
sparc64: Delete now unused user copy assembler helpers.
sparc64: Convert U3copy_{from,to}_user to accurate exception reporting.
sparc64: Convert NG2copy_{from,to}_user to accurate exception reporting.
sparc64: Convert NGcopy_{from,to}_user to accurate exception reporting.
sparc64: Convert NG4copy_{from,to}_user to accurate exception reporting.
sparc64: Convert U1copy_{from,to}_user to accurate exception reporting.
sparc64: Convert GENcopy_{from,to}_user to accurate exception reporting.
sparc64: Convert copy_in_user to accurate exception reporting.
sparc64: Prepare to move to more saner user copy exception handling.
sparc64: Delete __ret_efault.
sparc32: Fix old style declaration GCC warnings
sparc64: Fix old style declaration GCC warnings
sparc64: Setup a scheduling domain for highest level cache.
Pull networking fixes from David Miller:
"Lots of fixes, mostly drivers as is usually the case.
1) Don't treat zero DMA address as invalid in vmxnet3, from Alexey
Khoroshilov.
2) Fix element timeouts in netfilter's nft_dynset, from Anders K.
Pedersen.
3) Don't put aead_req crypto struct on the stack in mac80211, from
Ard Biesheuvel.
4) Several uninitialized variable warning fixes from Arnd Bergmann.
5) Fix memory leak in cxgb4, from Colin Ian King.
6) Fix bpf handling of VLAN header push/pop, from Daniel Borkmann.
7) Several VRF semantic fixes from David Ahern.
8) Set skb->protocol properly in ip6_tnl_xmit(), from Eli Cooper.
9) Socket needs to be locked in udp_disconnect(), from Eric Dumazet.
10) Div-by-zero on 32-bit fix in mlx4 driver, from Eugenia Emantayev.
11) Fix stale link state during failover in NCSCI driver, from Gavin
Shan.
12) Fix netdev lower adjacency list traversal, from Ido Schimmel.
13) Propvide proper handle when emitting notifications of filter
deletes, from Jamal Hadi Salim.
14) Memory leaks and big-endian issues in rtl8xxxu, from Jes Sorensen.
15) Fix DESYNC_FACTOR handling in ipv6, from Jiri Bohac.
16) Several routing offload fixes in mlxsw driver, from Jiri Pirko.
17) Fix broadcast sync problem in TIPC, from Jon Paul Maloy.
18) Validate chunk len before using it in SCTP, from Marcelo Ricardo
Leitner.
19) Revert a netns locking change that causes regressions, from Paul
Moore.
20) Add recursion limit to GRO handling, from Sabrina Dubroca.
21) GFP_KERNEL in irq context fix in ibmvnic, from Thomas Falcon.
22) Avoid accessing stale vxlan/geneve socket in data path, from
Pravin Shelar"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (189 commits)
geneve: avoid using stale geneve socket.
vxlan: avoid using stale vxlan socket.
qede: Fix out-of-bound fastpath memory access
net: phy: dp83848: add dp83822 PHY support
enic: fix rq disable
tipc: fix broadcast link synchronization problem
ibmvnic: Fix missing brackets in init_sub_crq_irqs
ibmvnic: Fix releasing of sub-CRQ IRQs in interrupt context
Revert "ibmvnic: Fix releasing of sub-CRQ IRQs in interrupt context"
arch/powerpc: Update parameters for csum_tcpudp_magic & csum_tcpudp_nofold
net/mlx4_en: Save slave ethtool stats command
net/mlx4_en: Fix potential deadlock in port statistics flow
net/mlx4: Fix firmware command timeout during interrupt test
net/mlx4_core: Do not access comm channel if it has not yet been initialized
net/mlx4_en: Fix panic during reboot
net/mlx4_en: Process all completions in RX rings after port goes up
net/mlx4_en: Resolve dividing by zero in 32-bit system
net/mlx4_core: Change the default value of enable_qos
net/mlx4_core: Avoid setting ports to auto when only one port type is supported
net/mlx4_core: Fix the resource-type enum in res tracker to conform to FW spec
Commit 01cfbad "ipv4: Update parameters for csum_tcpudp_magic to their
original types" changed parameters for csum_tcpudp_magic and
csum_tcpudp_nofold for many platforms but not for PowerPC.
Fixes: 01cfbad "ipv4: Update parameters for csum_tcpudp_magic to their original types"
Cc: Alexander Duyck <aduyck@mirantis.com>
Signed-off-by: Ivan Vecera <ivecera@redhat.com>
Acked-by: Alexander Duyck <alexander.h.duyck@intel.com>
Pull x86 bugfix from Thomas Gleixner:
"A single bugfix for the recent changes related to registering the boot
cpu when this has not happened before prefill_possible_map().
The main problem with this change got fixed already, but we missed the
case where the local APIC is not yet mapped, when prefill_possible_map()
is invoked, so the registration of the boot cpu which has the APIC bit
set in CPUID will explode.
I should have seen that issue earlier, but all I can do now is feeling
embarassed"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/smpboot: Init apic mapping before usage
Pull ARM SoC fixes from Olof Johansson:
"We haven't seen a whole lot of fixes for the first two weeks since the
merge window, but here is the batch that we have at the moment.
Nothing sticks out as particularly bad or scary, it's mostly a handful
of smaller fixes to several platforms. The Uniphier reset controller
changes could probably have been delayed to 4.10, but they're not
scary and just plumbing up driver changes that went in during the
merge window.
We're also adding another maintainer to Marvell Berlin platforms, to
help out when Sebastian is too busy. Yay teamwork!"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: imx: mach-imx6q: Fix the PHY ID mask for AR8031
ARM: dts: vf610: fix IRQ flag of global timer
ARM: imx: gpc: Fix the imx_gpc_genpd_init() error path
ARM: imx: gpc: Initialize all power domains
arm64: dts: Updated NAND DT properties for NS2 SVK
arm64: dts: uniphier: change MIO node to SD control node
ARM: dts: uniphier: change MIO node to SD control node
reset: uniphier: rename MIO reset to SD reset for Pro5, PXs2, LD20 SoCs
arm64: uniphier: select ARCH_HAS_RESET_CONTROLLER
ARM: uniphier: select ARCH_HAS_RESET_CONTROLLER
arm64: dts: Add timer erratum property for LS2080A and LS1043A
arm64: dts: rockchip: remove the abuse of keep-power-in-suspend
ARM: multi_v7_defconfig: Enable Intel e1000e driver
MAINTAINERS: add myself as Marvell berlin SoC maintainer
bus: qcom-ebi2: depend on ARCH_QCOM or COMPILE_TEST
ARM: dts: fix the SD card on the Snowball
arm64: dts: rockchip: remove always-on and boot-on from vcc_sd
arm64: dts: marvell: fix clocksource for CP110 master SPI0
ARM: mvebu: Select corediv clk for all mvebu v7 SoC
git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into fixes
Correct regulator handling on Rockchip arm64 boards to make
bind/unbind calls work correctly and remove a sdio-only
property from non-sdio mmc hosts, that accidentially was
added there.
* tag 'v4.9-rockchip-dts64-fixes1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip:
http://github.com/Broadcom/stblinux into fixes
This pull request contains a single fix for Broadcom ARM64-based SoCs:
- Ray adds the required bus width and OOB sector size properties to the
Northstar 2 SVK reference board in order for the NAND controller to work
properly
* tag 'arm-soc/for-4.9/devicetree-arm64-fixes' of http://github.com/Broadcom/stblinux:
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into fixes
The i.MX fixes for 4.9:
- A couple of patches from Fabio to fix the GPC power domain regression
which is caused by PM Domain core change 0159ec670763dd
("PM / Domains: Verify the PM domain is present when adding a
provider"), and a related kernel crash seen with multi_v7_defconfig
build.
- Correct the PHY ID mask for AR8031 to match phy driver code.
- Apply new added timer erratum A008585 for LS1043A and LS2080A SoC.
- Correct vf610 global timer IRQ flag to avoid warning from gic driver
after commit 992345a58e0c ("irqchip/gic: WARN if setting the
interrupt type for a PPI fails").
* tag 'imx-fixes-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux:
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-uniphier into fixes
UniPhier ARM SoC fixes for v4.9
- Add "select ARCH_HAS_RESET_CONTROLLER" in Kconfig
- Rename wrongly-named mioctrl to sdctrl
* tag 'uniphier-fixes-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-uniphier:
The recent changes, which forced the registration of the boot cpu on UP
systems, which do not have ACPI tables, have been fixed for systems w/o
local APIC, but left a wreckage for systems which have neither ACPI nor
mptables, but the CPU has an APIC, e.g. virtualbox.
The boot process crashes in prefill_possible_map() as it wants to register
the boot cpu, which needs to access the local apic, but the local APIC is
not yet mapped.
There is no reason why init_apic_mapping() can't be invoked before
prefill_possible_map(). So instead of playing another silly early mapping
game, as the ACPI/mptables code does, we just move init_apic_mapping()
before the call to prefill_possible_map().
In hindsight, I should have noticed that combination earlier.
Sorry for the churn (also in stable)!
Fixes: ff8560512b8d ("x86/boot/smp: Don't try to poke disabled/non-existent APIC")
Reported-and-debugged-by: Michal Necasek <michal.necasek@oracle.com>
Reported-and-tested-by: Wolfgang Bauer <wbauer@tmo.at>
Cc: prarit@redhat.com
Cc: ville.syrjala@linux.intel.com
Cc: michael.thayer@oracle.com
Cc: knut.osmundsen@oracle.com
Cc: frank.mehnert@oracle.com
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1610282114380.5053@nanos
Pull ACPI fixes from Rafael Wysocki:
"These fix recent ACPICA regressions, an older PCI IRQ management
regression, and an incorrect return value of a function in the APEI
code.
Specifics:
- Fix three ACPICA issues related to the interpreter locking and
introduced by recent changes in that area (Lv Zheng).
- Fix a PCI IRQ management regression introduced during the 4.7 cycle
and related to the configuration of shared IRQs on systems with an
ISA bus (Sinan Kaya).
- Fix up a return value of one function in the APEI code (Punit
Agrawal)"
* tag 'acpi-4.9-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPICA: Dispatcher: Fix interpreter locking around acpi_ev_initialize_region()
ACPICA: Dispatcher: Fix an unbalanced lock exit path in acpi_ds_auto_serialize_method()
ACPICA: Dispatcher: Fix order issue of method termination
ACPI / APEI: Fix incorrect return value of ghes_proc()
ACPI/PCI: pci_link: Include PIRQ_PENALTY_PCI_USING for ISA IRQs
ACPI/PCI: pci_link: penalize SCI correctly
ACPI/PCI/IRQ: assign ISA IRQ directly during early boot stages
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc
Pull ARC updates from Vineet Gupta:
- support IDU intc for UP builds
- support gz, lzma compressed uImage [Daniel Mentz]
- adjust /proc/cpuinfo for non-continuous cpu ids [Noam Camus]
- syscall for userspace cmpxchg assist for configs lacking hardware atomics
- rework of boot log printing mainly for identifying older arc700 cores
- retiring some old code, build toggles
* tag 'arc-4.9-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc:
ARC: module: print pretty section names
ARC: module: elide loop to save reference to .eh_frame
ARC: mm: retire ARC_DBG_TLB_MISS_COUNT...
ARC: build: retire old toggles
ARC: boot log: refactor cpu name/release printing
ARC: boot log: remove awkward space comma from MMU line
ARC: boot log: don't assume SWAPE instruction support
ARC: boot log: refactor printing abt features not captured in BCRs
ARCv2: boot log: print IOC exists as well as enabled status
ARCv2: IOC: use @ioc_enable not @ioc_exist where intended
ARC: syscall for userspace cmpxchg assist
ARC: fix build warning in elf.h
ARC: Adjust cpuinfo for non-continuous cpu ids
ARC: [build] Support gz, lzma compressed uImage
ARCv2: intc: untangle SMP, MCIP and IDU
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc fixes from Michael Ellerman:
"Fixes marked for stable:
- Convert cmp to cmpd in idle enter sequence (Segher Boessenkool)
- cxl: Fix leaking pid refs in some error paths (Vaibhav Jain)
- Re-fix race condition between going idle and entering guest (Paul Mackerras)
- Fix race condition in setting lock bit in idle/wakeup code (Paul Mackerras)
- radix: Use tlbiel only if we ever ran on the current cpu (Aneesh Kumar K.V)
- relocation, register save fixes for system reset interrupt (Nicholas Piggin)
Fixes for code merged this cycle:
- Fix CONFIG_ALIVEC typo in restore_tm_state() (Valentin Rothberg)
- KVM: PPC: Book3S HV: Fix build error when SMP=n (Michael Ellerman)"
* tag 'powerpc-4.9-4' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux:
powerpc/64s: relocation, register save fixes for system reset interrupt
powerpc/mm/radix: Use tlbiel only if we ever ran on the current cpu
powerpc/process: Fix CONFIG_ALIVEC typo in restore_tm_state()
powerpc/64: Fix race condition in setting lock bit in idle/wakeup code
powerpc/64: Re-fix race condition between going idle and entering guest
powerpc: Convert cmp to cmpd in idle enter sequence
Pull perf fixes from Ingo Molnar:
"Misc kernel fixes: a virtualization environment related fix, an uncore
PMU driver removal handling fix, a PowerPC fix and new events for
Knights Landing"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/intel: Honour the CPUID for number of fixed counters in hypervisors
perf/powerpc: Don't call perf_event_disable() from atomic context
perf/core: Protect PMU device removal with a 'pmu_bus_running' check, to fix CONFIG_DEBUG_TEST_DRIVER_REMOVE=y kernel panic
perf/x86/intel/cstate: Add C-state residency events for Knights Landing
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes from Will Deacon:
"Three arm64 fixes for -rc3. They're all pretty straightforward: a
couple of NUMA issues from the Huawei folks and a thinko in
__page_to_voff that seems to be benign, but is certainly better off
fixed.
Summary:
- couple of NUMA fixes
- thinko in __page_to_voff"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64: mm: fix __page_to_voff definition
arm64/numa: fix incorrect log for memory-less node
arm64/numa: fix pcpu_cpu_distance() to get correct CPU proximity
Pull x86 fixes from Ingo Molnar:
"Misc fixes: three build fixes, an unwinder fix and a microcode loader
fix"
x86/microcode/AMD: Fix more fallout from CONFIG_RANDOMIZE_MEMORY=y
x86: Fix export for mcount and __fentry__
x86/quirks: Hide maybe-uninitialized warning
x86/build: Fix build with older GCC versions
x86/unwind: Fix empty stack dereference in guess unwinder
Now that we have referece to section name string table in
apply_relocate_add(), use it to
- print the name of section being relocated
- print symbol with NULL name (since it refers to a section)
before
| Section to fixup 7000a060
| rela->r_off | rela->addend | sym->st_value | ADDR | VALUE
| 1c 0 7000e000 7000a07c 7000e000 []
| 40 0 7000a000 7000a0a0 7000a000 []
after
| Section to fixup .eh_frame @7000a060
| r_off r_add st_value ADDRESS VALUE
| 1c 0 7000e000 7000a07c 7000e000 [.init.text]
| 40 0 7000a000 7000a0a0 7000a000 [.exit.text]
The loop was really needed in .debug_frame regime where wanted make it
as SH_ALLOC so that apply_relocate_add() would process it. That's not
needed for .eh_frame, so we check this in apply_relocate_add() which
gets called for each section.
Note that we need to save reference to "section name strings" section in
module_frob_arch_sections() since apply_relocate_add() doesn't get that
... given that we have perf counters abel to do the same thing non
intrusively
These are really ancient toggles and tools no longer require them to be
passed. This paves way for deprecating them in long run.
The motivation is to identify ARC750 vs. ARC770 (we currently print
generic "ARC700").
A given ARC700 release could be 750 or 770, with same ARCNUM (or family
identifier which is unfortunate). The existing arc_cpu_tbl[] kept a single
concatenated string for core name and release which thus doesn't work
for 750 vs. 770 identification.
So split this into 2 tables, one with core names and other with release.
And while we are at it, get rid of the range checking for family numbers.
We just document the known to exist cores running Linux and ditch
others.
With this in place, we add detection of ARC750 which is
- cores 0x33 and before
- cores 0x34 and later with MMUv2
This came to light when helping a customer with oldish ARC750 core who
were getting instruction errors because of lack of SWAPE but boot log
was incorrectly printing it as being present
On older arc700 cores, some of the features configured were not present
in Build config registers. To print about them at boot, we just use the
Kconfig option i.e. whether linux is built to use them or not.
So yes this seems bogus, but what else can be done. Moreover if linux is
booting with these enabled, then the Kconfig info is a good indicator
anyways.
Over time these "hacks" accumulated in read_arc_build_cfg_regs() as well
as arc_cpu_mumbojumbo(). so refactor and move all of those in a single
place: read_arc_build_cfg_regs(). This causes some code redcution too:
| bloat-o-meter2 arch/arc/kernel/setup.o.0 arch/arc/kernel/setup.o.1
| add/remove: 0/0 grow/shrink: 2/1 up/down: 64/-132 (-68)
| function old new delta
| setup_processor 610 670 +60
| cpuinfo_arc700 76 80 +4
| arc_cpu_mumbojumbo 752 620 -132
Previously we would not print the case when IOC existed but was not
enabled.
And while at it, reduce one line off boot printing by consolidating
the Peripheral address space and IO-Coherency which in a way
applies to them
git://people.freedesktop.org/~airlied/linux
Pull drm x86/pat regression fixes from Dave Airlie:
"This is a standalone pull request for the fix for a regression
introduced in -rc1 by a change to vm_insert_mixed to start using the
PAT range tracking to validate page protections. With this fix in
place, all the VRAM mappings for GPU drivers ended up at UC instead of
WC.
There are probably better ways to fix this long term, but nothing I'd
considered for -fixes that wouldn't need more settling in time. So
I've just created a new arch API that the drivers can reserve all
their VRAM aperture ranges as WC"
* tag 'drm-x86-pat-regression-fix' of git://people.freedesktop.org/~airlied/linux:
drm/drivers: add support for using the arch wc mapping API.
x86/io: add interface to reserve io memtype for a resource range. (v1.1)
vcpu->arch.wbinvd_dirty_mask may still be used after freeing it,
corrupting memory. For example, the following call trace may set a bit
in an already freed cpu mask:
kvm_arch_vcpu_load
vcpu_load
vmx_free_vcpu_nested
vmx_free_vcpu
kvm_arch_vcpu_free
Fix this by deferring freeing of wbinvd_dirty_mask.
Signed-off-by: Ido Yariv <ido@wizery.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
perf doesn't seem to honour the number of fixed counters specified by CPUID
leaf 0xa. It always assumes that Intel CPUs have at least 3 fixed counters.
So if some of the fixed counters are masked out by the hypervisor, it still
tries to check/set them.
This patch makes perf behave nicer when the kernel is running under a
hypervisor that doesn't expose all the counters.
This patch contains some ideas from Matt Wilson.
Signed-off-by: Imre Palik <imrep@amazon.de>
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Cc: Alexander Kozyrev <alexander.kozyrev@intel.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Artyom Kuanbekov <artyom.kuanbekov@intel.com>
Cc: David Carrillo-Cisneros <davidcc@google.com>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Kan Liang <kan.liang@intel.com>
Cc: Matt Wilson <msw@amazon.com>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1477037939-15605-1-git-send-email-imrep.amz@gmail.com
The trinity syscall fuzzer triggered following WARN() on powerpc:
WARNING: CPU: 9 PID: 2998 at arch/powerpc/kernel/hw_breakpoint.c:278
NIP [c00000000093aedc] .hw_breakpoint_handler+0x28c/0x2b0
LR [c00000000093aed8] .hw_breakpoint_handler+0x288/0x2b0
Call Trace:
[c0000002f7933580] [c00000000093aed8] .hw_breakpoint_handler+0x288/0x2b0 (unreliable)
[c0000002f7933630] [c0000000000f671c] .notifier_call_chain+0x7c/0xf0
[c0000002f79336d0] [c0000000000f6abc] .__atomic_notifier_call_chain+0xbc/0x1c0
[c0000002f7933780] [c0000000000f6c40] .notify_die+0x70/0xd0
[c0000002f7933820] [c00000000001a74c] .do_break+0x4c/0x100
[c0000002f7933920] [c0000000000089fc] handle_dabr_fault+0x14/0x48
Followed by a lockdep warning:
[ INFO: suspicious RCU usage. ]
4.8.0-rc5+ #7 Tainted: G W
./include/linux/rcupdate.h:556 Illegal context switch in RCU read-side critical section!
rcu_scheduler_active = 1, debug_locks = 0
2 locks held by ls/2998:
#0: (rcu_read_lock){......}, at: [<c0000000000f6a00>] .__atomic_notifier_call_chain+0x0/0x1c0
#1: (rcu_read_lock){......}, at: [<c00000000093ac50>] .hw_breakpoint_handler+0x0/0x2b0
stack backtrace:
CPU: 9 PID: 2998 Comm: ls Tainted: G W 4.8.0-rc5+ #7
Call Trace:
[c0000002f7933150] [c00000000094b1f8] .dump_stack+0xe0/0x14c (unreliable)
[c0000002f79331e0] [c00000000013c468] .lockdep_rcu_suspicious+0x138/0x180
[c0000002f7933270] [c0000000001005d8] .___might_sleep+0x278/0x2e0
[c0000002f7933300] [c000000000935584] .mutex_lock_nested+0x64/0x5a0
[c0000002f7933410] [c00000000023084c] .perf_event_ctx_lock_nested+0x16c/0x380
[c0000002f7933500] [c000000000230a80] .perf_event_disable+0x20/0x60
[c0000002f7933580] [c00000000093aeec] .hw_breakpoint_handler+0x29c/0x2b0
While it looks like the first WARN() is probably valid, the other one is
triggered by disabling event via perf_event_disable() from atomic context.
The event is disabled here in case we were not able to emulate
the instruction that hit the breakpoint. By disabling the event
we unschedule the event and make sure it's not scheduled back.
But we can't call perf_event_disable() from atomic context, instead
we need to use the event's pending_disable irq_work method to disable it.
Reported-by: Jan Stancek <jstancek@redhat.com>
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Cc: Huang Ying <ying.huang@intel.com>
Cc: Michael Neuling <mikey@neuling.org>
Link: http://lkml.kernel.org/r/20161026094824.GA21397@krava
We needed the physical address of the container in order to compute the
offset within the relocated ramdisk. And we did this by doing __pa() on
the virtual address.
However, __pa() does checks whether the physical address is within
PAGE_OFFSET and __START_KERNEL_map - see __phys_addr() - which fail
if we have CONFIG_RANDOMIZE_MEMORY enabled: we feed a virtual address
which *doesn't* have the randomization offset into a function which uses
PAGE_OFFSET which *does* have that offset.
This makes this check fire:
VIRTUAL_BUG_ON((x > y) || !phys_addr_valid(x));
due to the randomization offset.
The fix is as simple as using __pa_nodebug() because we do that
randomization offset accounting later in that function ourselves.
Reported-by: Bob Peterson <rpeterso@redhat.com>
Tested-by: Bob Peterson <rpeterso@redhat.com>
Cc: Andreas Gruenbacher <agruenba@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: linux-mm <linux-mm@kvack.org>
Cc: stable@vger.kernel.org # 4.9
Link: http://lkml.kernel.org/r/20161027123623.j2jri5bandimboff@pd.tnic
Since commit d86bd1bece6f ("mm/slub: support left redzone") it is no longer
guaranteed that kmalloc(PAGE_SIZE) returns page aligned memory.
After the above commit we get an error for diag224 because aligned
memory is required. This leads to the following user visible error:
# mount none -t s390_hypfs /sys/hypervisor/
mount: unknown filesystem type 's390_hypfs'
# dmesg | grep hypfs
hypfs.cccfb8: The hardware system does not provide all functions
required by hypfs
hypfs.7a79f0: Initialization of hypfs failed with rc=-61
Fix this problem and use get_free_page() instead of kmalloc() to get
correctly aligned memory.
Cc: stable@vger.kernel.org # v3.6+
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Merge misc fixes from Andrew Morton:
"20 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
drivers/misc/sgi-gru/grumain.c: remove bogus 0x prefix from printk
cris/arch-v32: cryptocop: print a hex number after a 0x prefix
ipack: print a hex number after a 0x prefix
block: DAC960: print a hex number after a 0x prefix
fs: exofs: print a hex number after a 0x prefix
lib/genalloc.c: start search from start of chunk
mm: memcontrol: do not recurse in direct reclaim
CREDITS: update credit information for Martin Kepplinger
proc: fix NULL dereference when reading /proc/<pid>/auxv
mm: kmemleak: ensure that the task stack is not freed during scanning
lib/stackdepot.c: bump stackdepot capacity from 16MB to 128MB
latent_entropy: raise CONFIG_FRAME_WARN by default
kconfig.h: remove config_enabled() macro
ipc: account for kmem usage on mqueue and msg
mm/slab: improve performance of gathering slabinfo stats
mm: page_alloc: use KERN_CONT where appropriate
mm/list_lru.c: avoid error-path NULL pointer deref
h8300: fix syscall restarting
kcov: properly check if we are in an interrupt
mm/slab: fix kmemcg cache creation delayed issue
It makes the result hard to interpret correctly if a base 10 number is
prefixed by 0x. So change to a hex number.
Link: http://lkml.kernel.org/r/20161026125658.25728-6-u.kleine-koenig@pengutronix.de
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
The use of config_enabled() is ambiguous. For config options,
IS_ENABLED(), IS_REACHABLE(), etc. will make intention clearer.
Sometimes config_enabled() has been used for non-config options because
it is useful to check whether the given symbol is defined or not.
I have been tackling on deprecating config_enabled(), and now is the
time to finish this work.
Some new users have appeared for v4.9-rc1, but it is trivial to replace
them:
- arch/x86/mm/kaslr.c
replace config_enabled() with IS_ENABLED() because
CONFIG_X86_ESPFIX64 and CONFIG_EFI are boolean.
- include/asm-generic/export.h
replace config_enabled() with __is_defined().
Then, config_enabled() can be removed now.
Going forward, please use IS_ENABLED(), IS_REACHABLE(), etc. for config
options, and __is_defined() for non-config symbols.
Link: http://lkml.kernel.org/r/1476616078-32252-1-git-send-email-yamada.masahiro@socionext.com
Acked-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Cc: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Cc: Michal Marek <mmarek@suse.com>
Cc: Thomas Garnier <thgarnie@google.com>
Cc: Paul Bolle <pebolle@tiscali.nl>
Back in commit f56141e3e2d9 ("all arches, signal: move restart_block to
struct task_struct"), all architectures and core code were changed to
use task_struct::restart_block. However, when h8300 support was
subsequently restored in v4.2, it was not updated to account for this,
and maintains thread_info::restart_block, which is not kept in sync.
This patch drops the redundant restart_block from thread_info, and moves
h8300 to the common one in task_struct, ensuring that syscall restarting
always works as expected.
Fixes: f56141e3e2d9 ("all arches, signal: move restart_block to struct task_struct")
Link: http://lkml.kernel.org/r/1476714934-11635-1-git-send-email-mark.rutland@arm.com
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: uclinux-h8-devel@lists.sourceforge.jp
Cc: <stable@vger.kernel.org> [4.2+]
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 fixes from Martin Schwidefsky:
"A few more s390 patches for 4.9:
- a fix for an overflow in the dasd driver reported by UBSAN
- fix a regression and add hotplug memory to the zone movable again
- add ignore defines for the pkey system calls
- fix the ouput of the merged stack tracer
- replace printk with pr_cont in arch/s390 where appropriate
- remove the arch specific return_address function again
- ignore reserved channel paths at boot time
- add a missing hugetlb_bad_size call to the arch backend"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/mm: fix zone calculation in arch_add_memory()
s390/dumpstack: use pr_cont within show_stack and die
s390/dumpstack: get rid of return_address again
s390/disassambler: use pr_cont where appropriate
s390/dumpstack: use pr_cont where appropriate
s390/dumpstack: restore reliable indicator for call traces
s390/mm: use hugetlb_bad_size()
s390/cio: don't register chpids in reserved state
s390: ignore pkey system calls
s390/dasd: avoid undefined behaviour
Add the "0x" prefix to the error messages format to make it unambiguous
about what kind of value we're talking about.
Cc: "Radim Krčmář" <rkrcmar@redhat.com>
Message-Id: <20161027181445.25319-1-bp@alien8.de>
When the vmalloc area gets fragmented, and because the firmware
mapping area sits between where modules live and the vmalloc area, we
can sometimes receive requests for enormous kernel TLB range flushes.
When this happens the cpu just spins flushing billions of pages and
this triggers the NMI watchdog and other problems.
We took care of this on the TSB side by doing a linear scan of the
table once we pass a certain threshold.
Do something similar for the TLB flush, however we are limited by
the TLB flush facilities provided by the different chip variants.
First of all we use an (mostly arbitrary) cut-off of 256K which is
about 32 pages. This can be tuned in the future.
The huge range code path for each chip works as follows:
1) On spitfire we flush all non-locked TLB entries using diagnostic
acceses.
2) On cheetah we use the "flush all" TLB flush.
3) On sun4v/hypervisor we do a TLB context flush on context 0, which
unlike previous chips does not remove "permanent" or locked
entries.
We could probably do something better on spitfire, such as limiting
the flush to kernel TLB entries or even doing range comparisons.
However that probably isn't worth it since those chips are old and
the TLB only had 64 entries.
Reported-by: James Clarke <jrtc27@jrtc27.com>
Tested-by: James Clarke <jrtc27@jrtc27.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into HEAD
KVM: s390: Fix wrong memory allocation
With commit d86bd1bece6f ("mm/slub: support left redzone") or
with slab debugging the allocation of our diag224 buffer is not
aligned properly. Let's fix this.
This patch does a couple of things. First of all, powernv immediately
explodes when running a relocated kernel, because the system reset
exception for handling sleeps does not do correct relocated branches.
Secondly, the sleep handling code trashes the condition and cfar
registers, which we would like to preserve for debugging purposes (for
non-sleep case exception).
This patch changes the exception to use the standard format that saves
registers before any tests or branches are made. It adds the test for
idle-wakeup as an "extra" to break out of the normal exception path.
Then it branches to a relocated idle handler that calls the various
idle handling functions.
After this patch, POWER8 CPU simulator now boots powernv kernel that is
running at non-zero.
Fixes: 948cf67c4726 ("powerpc: Add NAP mode support on Power7 in HV mode")
Cc: stable@vger.kernel.org # v3.0+
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Acked-by: Gautham R. Shenoy <ego@linux.vnet.ibm.com>
Acked-by: Balbir Singh <bsingharora@gmail.com>
Before this patch, we used tlbiel, if we ever ran only on this core.
That was mostly derived from the nohash usage of the same. But is
incorrect, the ISA 3.0 clarifies tlbiel such that:
"All TLB entries that have all of the following properties are made
invalid on the thread executing the tlbiel instruction"
ie. tlbiel only invalidates TLB entries on the current thread. So if the
mm has been used on any other thread (aka. cpu) then we must broadcast
the invalidate.
This bug could lead to invalid TLB entries if a program runs on multiple
threads of a core.
Hence use tlbiel, if we only ever ran on only the current cpu.
Fixes: 1a472c9dba6b ("powerpc/mm/radix: Add tlbflush routines")
Cc: stable@vger.kernel.org # v4.7+
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
It should be ALTIVEC, not ALIVEC.
Cyril explains: If a thread performs a transaction with altivec and then
gets preempted for whatever reason, this bug may cause the kernel to not
re-enable altivec when that thread runs again. This will result in an
altivec unavailable fault, when that fault happens inside a user
transaction the kernel has no choice but to enable altivec and doom the
transaction.
The result is that transactions using altivec may get aborted more often
than they should.
The difficulty in catching this with a selftest is my deliberate use of
the word may above. Optimisations to avoid FPU/altivec/VSX faults mean
that the kernel will always leave them on for 255 switches. This code
prevents the kernel turning it off if it got to the 256th switch (and
userspace was transactional).
Fixes: dc16b553c949 ("powerpc: Always restore FPU/VEC/VSX if hardware transactional memory in use")
Reviewed-by: Cyril Bur <cyrilbur@gmail.com>
Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com>
Bitwise shifts by amounts greater than or equal to the width of the left
operand are undefined. A malicious guest can exploit this to crash a
32-bit host, due to the BUG_ON(1)'s in handle_{invept,invvpid}.
Message-Id: <1477496318-17681-1-git-send-email-jmattson@google.com>
[Change 1UL to 1, to match the range check on the shift count. - Paolo]
Fix parameter name for __page_to_voff, to match its definition.
At present, we don't see any issue, as page_to_virt's caller
declares 'page'.
Fixes: 9f2875912dac ("arm64: mm: restrict virt_to_page() to the linear mapping")
Acked-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Neeraj Upadhyay <neeraju@codeaurora.org>
