The C99 specification states in section 6.11.5:
The placement of a storage-class specifier other than at the beginning
of the declaration specifiers in a declaration is an obsolescent
feature.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com>
Fix misspelling of firmware.
Signed-off-by: Nick Andrew <nick@nick-andrew.net>
Signed-off-by: Uwe Kleine-Koenig <ukleinek@strlen.de>
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6:
i2c-core: Some style cleanups
i2c-piix4: Add support for the Broadcom HT1100 chipset
i2c-piix4: Add support to SB800 SMBus changes
i2c-pca-platform: Use defaults if no platform_data given
i2c-algo-pca: Use timeout for checking the state machine
i2c-algo-pca: Rework waiting for a free bus
i2c-algo-pca: Add PCA9665 support
i2c: Adapt debug macros for KERN_* constants
i2c-davinci: Fix timeout handling
i2c: Adapter timeout is in jiffies
i2c: Set a default timeout value for all adapters
i2c: Add missing KERN_* constants to printks
i2c-algo-pcf: Handle timeout correctly
i2c-algo-pcf: Style cleanups
eeprom/at24: Remove EXPERIMENTAL
i2c-nforce2: Add support for MCP67, MCP73, MCP78S and MCP79
i2c: Clarify which clients are auto-removed
i2c: Let checkpatch shout on users of the legacy model
i2c: Document the different ways to instantiate i2c devices
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (422 commits)
[ARM] 5435/1: fix compile warning in sanity_check_meminfo()
[ARM] 5434/1: ARM: OMAP: Fix mailbox compile for 24xx
[ARM] pxa: fix the bad assumption that PCMCIA sockets always start with 0
[ARM] pxa: fix Colibri PXA300 and PXA320 LCD backlight pins
imxfb: Fix TFT mode
i.MX21/27: remove ifdef CONFIG_FB_IMX
imxfb: add clock support
mxc: add arch_reset() function
clkdev: add possibility to get a clock based on the device name
i.MX1: remove fb support from mach-imx
[ARM] pxa: build arch/arm/plat-pxa/mfp.c only when PXA3xx or ARCH_MMP defined
Gemini: Add support for Teltonika RUT100
Gemini: gpiolib based GPIO support v2
MAINTAINERS: add myself as Gemini architecture maintainer
ARM: Add Gemini architecture v3
[ARM] OMAP: Fix compile for omap2_init_common_hw()
MAINTAINERS: Add myself as Faraday ARM core variant maintainer
ARM: Add support for FA526 v2
[ARM] acorn,ebsa110,footbridge,integrator,sa1100: Convert asm/io.h to linux/io.h
[ARM] collie: fix two minor formatting nits
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6:
Blackfin arch: be less noisy when gets a gpio conflict after kernel has booted
Blackfin arch: add RSI's definitions to bf514 and bf516
Blackfin arch: add link-time asserts to make sure on-chip regions dont overflow
Blackfin arch: sport spi needs 6 gpio pins
Blackfin arch: add sport-spi related resource stuff to board file
Blackfin arch: Blacklist Hibernate (PM_SUSPEND_MEM) on BF561 as well
Blackfin arch: Privide BF537-STAMP platform data of ADP5520 Multifunction driver
Blackfin arch: enable the platfrom PATA driver with CF Cards
Blackfin arch: clean up sports header file
Blackfin arch: convert BF5{18,27,48}_FAMILY to CONFIG_BF{51,52,54}x
Blackfin arch: bf51x processors also have 8 timers
Blackfin arch: add a check to make sure only Blackfin GPIOs may generate IRQs
Blackfin arch: update default kernel configuration
Blackfin arch: include linux headers that this one uses definitions from fro sport drivers
* 'percpu-cpumask-x86-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (682 commits)
percpu: fix spurious alignment WARN in legacy SMP percpu allocator
percpu: generalize embedding first chunk setup helper
percpu: more flexibility for @dyn_size of pcpu_setup_first_chunk()
percpu: make x86 addr <-> pcpu ptr conversion macros generic
linker script: define __per_cpu_load on all SMP capable archs
x86: UV: remove uv_flush_tlb_others() WARN_ON
percpu: finer grained locking to break deadlock and allow atomic free
percpu: move fully free chunk reclamation into a work
percpu: move chunk area map extension out of area allocation
percpu: replace pcpu_realloc() with pcpu_mem_alloc() and pcpu_mem_free()
x86, percpu: setup reserved percpu area for x86_64
percpu, module: implement reserved allocation and use it for module percpu variables
percpu: add an indirection ptr for chunk page map access
x86: make embedding percpu allocator return excessive free space
percpu: use negative for auto for pcpu_setup_first_chunk() arguments
percpu: improve first chunk initial area map handling
percpu: cosmetic renames in pcpu_setup_first_chunk()
percpu: clean up percpu constants
x86: un-__init fill_pud/pmd/pte
x86: remove vestigial fix_ioremap prototypes
Manually merge conflicts in arch/ia64/kernel/irq_ia64.c
Waiting for a free bus now accepts the timeout value in jiffies and does
proper checking using time_before.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] Fix kstat_this_cpu build breakage
arch/arm/include/asm/elf.h
arch/arm/kernel/module.c
sound/soc/pxa/pxa2xx-i2s.c
Compiling recent 2.6.29-rc kernels for ARM gives me the following warning:
arch/arm/mm/mmu.c: In function 'sanity_check_meminfo':
arch/arm/mm/mmu.c:697: warning: comparison between pointer and integer
This is because commit 3fd9825c42c784a59b3b90bdf073f49d4bb42a8d
"[ARM] 5402/1: fix a case of wrap-around in sanity_check_meminfo()"
in 2.6.29-rc5-git4 added a comparison of a pointer with PAGE_OFFSET,
which is an integer.
Fixed by casting PAGE_OFFSET to void *.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
Acked-by: Nicolas Pitre <nico@cam.org>
OMAP34XX_MAILBOX_BASE must be defined both for 24xx and 34xx.
Once the kernel has booted - be less noisy when someone does a modprobe
(and gets a gpio conflict).
Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel
ADP5520 Multifunction LCD Backlight and Keypad Input Device Driver
Provide option to use the platfrom PATA driver with CF Cards
on the CF-IDE-NAND Add-On-Card in Common Memory Mode
Remove redundancy of the name err_irq
convert BF5{18,27,48}_FAMILY to CONFIG_BF{51,52,54}x as the defines
are redundant in these cases
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Reported-by: Matthias Meier <matthias.j.meier@gmx.net>
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Signed-off-by: Eric Miao <eric.miao@marvell.com>
sport drivers
arch/sparc/kernel/time_64.c
drivers/gpu/drm/drm_proc.c
Manual merge to resolve build warning due to phys_addr_t type change
on x86:
drivers/gpu/drm/drm_info.c
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (166 commits)
Revert "ax25: zero length frame filtering in AX25"
Revert "netrom: zero length frame filtering in NetRom"
cfg80211: default CONFIG_WIRELESS_OLD_REGULATORY to n
mac80211/iwlwifi: move virtual A-MDPU queue bookkeeping to iwlwifi
mac80211: fix aggregation to not require queue stop
mac80211: add skb length sanity checking
mac80211: unify and fix TX aggregation start
mac80211: clean up __ieee80211_tx args
mac80211: rework the pending packets code
mac80211: fix A-MPDU queue assignment
mac80211: rewrite fragmentation
iwlwifi: show current driver status in user readable format
b43: Add BCM4307 PCI-ID
cfg80211: fix locking in nl80211_set_wiphy
mac80211: fix RX path
ath5k: properly drop packets from ops->tx
ar9170: single module build
ath9k: fix dma mapping leak of rx buffer upon rmmod
rt2x00: New USB ID for rt73usb
ath5k: warn and correct rate for unknown hw rate indexes
Sparc was missed in commit 2b1c6bd77d4e6a727ffac8630cd154b2144b751a
("generic compat_sys_ustat"). We definitely need it, since our
__kernel_ino_t is "unsigned long".
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (37 commits)
fs: avoid I_NEW inodes
Merge code for single and multiple-instance mounts
Remove get_init_pts_sb()
Move common mknod_ptmx() calls into caller
Parse mount options just once and copy them to super block
Unroll essentials of do_remount_sb() into devpts
vfs: simple_set_mnt() should return void
fs: move bdev code out of buffer.c
constify dentry_operations: rest
constify dentry_operations: configfs
constify dentry_operations: sysfs
constify dentry_operations: JFS
constify dentry_operations: OCFS2
constify dentry_operations: GFS2
constify dentry_operations: FAT
constify dentry_operations: FUSE
constify dentry_operations: procfs
constify dentry_operations: ecryptfs
constify dentry_operations: CIFS
constify dentry_operations: AFS
The last user of do_pipe is in arch/alpha/, after replacing it with
do_pipe_flags, the do_pipe can be totally dropped.
Signed-off-by: Cheng Renquan <crquan@gmail.com>
Acked-by: Richard Henderson <rth@twiddle.net>
Due to a different size of ino_t ustat needs a compat handler, but
currently only x86 and mips provide one. Add a generic compat_sys_ustat
and switch all architectures over to it. Instead of doing various
user copy hacks compat_sys_ustat just reimplements sys_ustat as
it's trivial. This was suggested by Arnd Bergmann.
Found by Eric Sandeen when running xfstests/017 on ppc64, which causes
stack smashing warnings on RHEL/Fedora due to the too large amount of
data writen by the syscall.
arch/ia64/kernel/irq_ia64.c: In function 'ia64_handle_irq':
arch/ia64/kernel/irq_ia64.c:498: error: 'struct kernel_stat' has no member named 'irqs'
arch/ia64/kernel/irq_ia64.c:500: error: 'struct kernel_stat' has no member named 'irqs'
arch/ia64/kernel/irq_ia64.c: In function 'ia64_process_pending_intr':
arch/ia64/kernel/irq_ia64.c:556: error: 'struct kernel_stat' has no member named 'irqs'
arch/ia64/kernel/irq_ia64.c:558: error: 'struct kernel_stat' has no member named 'irqs'
Fix build breakage due to recent kstat_this_cpu changes in:
d7e51e66899f95dabc89b4d4c6674a6e50fa37fc
sparseirq: make some func to be used with genirq
Signed-off-by: Jes Sorensen <jes@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
arch/parisc/kernel/irq.c
arch/x86/include/asm/fixmap_64.h
arch/x86/include/asm/setup.h
kernel/irq/handle.c
Semantic merge:
arch/x86/include/asm/fixmap.h
Compile in the framebuffer device unconditionally to fix pcm038
compilation without framebuffer support.
This patch adds arch_reset() function for all mxc platforms.
It also removes (unsused) arch/arm/mach-mx2/system.c file.
This patch has been tested on i.MX1/27/31/35
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
This adds clk_get_sys to get a clock without the associated struct
device.
The lack of an include file currently breaks compilation of
mx1ads_defconfig. As framebuffer support is not actively used for
mach-imx and the whole architecture will be replaced by mach-mx1
soon, just remove fb support.
As explained by Benjamin Herrenschmidt:
> CPU 0 is running the context, task->mm == task->active_mm == your
> context. The CPU is in userspace happily churning things.
> CPU 1 used to run it, not anymore, it's now running fancyfsd which
> is a kernel thread, but current->active_mm still points to that
> same context.
> Because there's only one "real" user, mm_users is 1 (but mm_count is
> elevated, it's just that the presence on CPU 1 as active_mm has no
> effect on mm_count().
> At this point, fancyfsd decides to invalidate a mapping currently mapped
> by that context, for example because a networked file has changed
> remotely or something like that, using unmap_mapping_ranges().
> So CPU 1 goes into the zapping code, which eventually ends up calling
> flush_tlb_pending(). Your test will succeed, as current->active_mm is
> indeed the target mm for the flush, and mm_users is indeed 1. So you
> will -not- send an IPI to the other CPU, and CPU 0 will continue happily
> accessing the pages that should have been unmapped.
To fix this problem, check ->mm instead of ->active_mm, and this
means:
> So if you test current->mm, you effectively account for mm_users == 1,
> so the only way the mm can be active on another processor is as a lazy
> mm for a kernel thread. So your test should work properly as long
> as you don't have a HW that will do speculative TLB reloads into the
> TLB on that other CPU (and even if you do, you flush-on-switch-in should
> get rid of any crap here).
And therefore we should be OK.
Convert the UML network device to use internal network device stats.
arch/sparc/kernel/time_64.c: In function ‘timer_interrupt’:
arch/sparc/kernel/time_64.c:732: error: ‘struct kernel_stat’ has no member named ‘irqs’
make[1]: *** [arch/sparc/kernel/time_64.o] Error 1
