path: root/arch
2006-06-20Merge git://git.infradead.org/~dwmw2/rbtree-2.6Linus Torvalds
* git://git.infradead.org/~dwmw2/rbtree-2.6: [RBTREE] Switch rb_colour() et al to en_US spelling of 'color' for consistency Update UML kernel/physmem.c to use rb_parent() accessor macro [RBTREE] Update hrtimers to use rb_parent() accessor macro. [RBTREE] Add explicit alignment to sizeof(long) for struct rb_node. [RBTREE] Merge colour and parent fields of struct rb_node. [RBTREE] Remove dead code in rb_erase() [RBTREE] Update JFFS2 to use rb_parent() accessor macro. [RBTREE] Update eventpoll.c to use rb_parent() accessor macro. [RBTREE] Update key.c to use rb_parent() accessor macro. [RBTREE] Update ext3 to use rb_parent() accessor macro. [RBTREE] Change rbtree off-tree marking in I/O schedulers. [RBTREE] Add accessor macros for colour and parent fields of rb_node
2006-06-20Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (22 commits) [ARM] 3559/1: S3C2442: core and serial port [ARM] 3557/1: S3C24XX: centralise and cleanup uart registration [ARM] 3558/1: SMDK24XX: LED platform devices [ARM] 3534/1: add spi support to lubbock platform [ARM] 3554/1: ARM: Fix dyntick locking [ARM] 3553/1: S3C24XX: earlier print of cpu idcode info [ARM] 3552/1: S3C24XX: Move VA of GPIO for low-level debug [ARM] 3551/1: S3C24XX: PM code failes to compile with CONFIG_DCACHE_WRITETHROUGH [ARM] 3550/1: OSIRIS: fix serial port map for 1:1 [ARM] 3548/1: Fix the ARMv6 CPU id in compressed/head.S [ARM] 3335/1: Old-abi Thumb sys_syscall broken [ARM] 3467/1: [3/3] Support for Philips PNX4008 platform: defconfig [ARM] 3466/1: [2/3] Support for Philips PNX4008 platform: chip support [ARM] 3465/1: [1/3] Support for Philips PNX4008 platform: headers [ARM] 3407/1: lpd7x: documetation update [ARM] 3406/1: lpd7x: compilation fix for smc91x [ARM] 3405/1: lpd7a40x: CPLD ssp driver [ARM] 3404/1: lpd7a40x: AMBA CLCD support [ARM] 3403/1: lpd7a40x: updated default configurations [ARM] 3402/1: lpd7a40x: serial driver bug fix ...
2006-06-19Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (51 commits) [MIPS] Make timer interrupt frequency configurable from kconfig. [MIPS] Correct HAL2 Kconfig description [MIPS] Fix R4K cache macro names [MIPS] Add Missing R4K Cache Macros to IP27 & IP32 [MIPS] Support for the RM9000-based Basler eXcite smart camera platform. [MIPS] Support for the R5500-based NEC EMMA2RH Mark-eins board [MIPS] Support SNI RM200C SNI in big endian mode and R5000 processors. [MIPS] SN: include asm/sn/types.h for nasid_t. [MIPS] Random fixes for sb1250 [MIPS] Fix bcm1480 compile [MIPS] Remove support for NEC DDB5476. [MIPS] Remove support for NEC DDB5074. [MIPS] Cleanup memory managment initialization. [MIPS] SN: Declare bridge_pci_ops. [MIPS] Remove unused function alloc_pci_controller. [MIPS] IP27: Extract pci_ops into separate file. [MIPS] IP27: Use symbolic constants instead of magic numbers. [MIPS] vr41xx: remove unnecessay items from vr41xx/Kconfig. [MIPS] IP27: Cleanup N/M mode configuration. [MIPS] IP27: Throw away old unused hacks. ...
2006-06-19Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] sets nforce2 minimum PLL divider to 2. [CPUFREQ] Make powernow-k7 work on SMP kernels. [CPUFREQ] cpufreq core {d,}printk adjustments [CPUFREQ] dprintk adjustments to cpufreq-speedstep-centrino [CPUFREQ] dprintk adjustments to cpufreq-nforce2 [CPUFREQ] Prepare powernow-k8 for future CPUs. [CPUFREQ] Make acpi-cpufreq 'sticky'. [CPUFREQ] Remove strange No-op from longrun.c [CPUFREQ] Remove more freq_table reinitialisations. [CPUFREQ] Fix another redundant initialisation in freq_table [CPUFREQ] Remove duplicate assignment in freq_table [CPUFREQ] CodingStyle nits in cpufreq_stats.c [CPUFREQ] Remove duplicate assignment from cpufreq-nforce2 [CPUFREQ] Remove pointless reinitialisations in acpi-cpufreq [CPUFREQ] Remove pointless reinitialisation from powernow-k8 [CPUFREQ] Remove redundant initialisation from longhaul. [CPUFREQ] Clean up longhaul's speed pretty-printer [CPUFREQ] Disambiguate loop indexes in powernow-k7 [CPUFREQ] Typo in powernow-k8
2006-06-19[MIPS] Make timer interrupt frequency configurable from kconfig.Atsushi Nemoto
Make HZ configurable. DECSTATION can select 128/256/1024 HZ, JAZZ can only select 100 HZ, others can select 100/128/250/256/1000/1024 HZ if not explicitly specified). Also remove all mach-xxx/param.h files and update all defconfigs according to current HZ value. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Support for the RM9000-based Basler eXcite smart camera platform.Ralf Baechle
Signed-off-by: Thomas Koeller <thomas.koeller@baslerweb.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Support for the R5500-based NEC EMMA2RH Mark-eins boarddmitry pervushin
Signed-off-by: dmitry pervushin <dpervushin@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Support SNI RM200C SNI in big endian mode and R5000 processors.Thomas Bogendoerfer
Added support for RM200C machines with big endian firmware Added support for RM200-C40 (R5000 support) Signed-off-by: Florian Lohoff <flo@rfc822.org> Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Random fixes for sb1250Thiemo Seufer
Random improvements for sb1250: Silence compiler warnings, a bugfix for the profiling code, and a comment typo. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Fix bcm1480 compileThiemo Seufer
Fix compilation for bcm1480, a hpt is only available on sb1250/bcm112x. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Remove support for NEC DDB5476.Ralf Baechle
As warned several times before. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Remove support for NEC DDB5074.Ralf Baechle
2006-06-19[MIPS] Cleanup memory managment initialization.Ralf Baechle
Historically plat_mem_setup did the entire platform initialization. This was rather impractical because it meant plat_mem_setup had to get away without any kind of memory allocator. To keep old code from breaking plat_setup was just renamed to plat_setup and a second platform initialization hook for anything else was introduced. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Remove unused function alloc_pci_controller.Ralf Baechle
2006-06-19[MIPS] IP27: Extract pci_ops into separate file.Ralf Baechle
2006-06-19[MIPS] IP27: Use symbolic constants instead of magic numbers.Ralf Baechle
2006-06-19[MIPS] vr41xx: remove unnecessay items from vr41xx/Kconfig.Yoichi Yuasa
Remove unnecessary items from vr41xx/Kconfig. SYS_HA_CPU_VR41XX has already been selected by MACH_VR41XX. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] IP27: Cleanup N/M mode configuration.Ralf Baechle
2006-06-19[MIPS] APM emu supportRodolfo Giometti
Signed-off-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] SN: Rename SGI_SN0_N_MODE -> SGI_SN_N_MODE.Ralf Baechle
It's not SN0-specific. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Cleanup ARCH_DISCONTIGMEM_ENABLE and NUMA configuration.Ralf Baechle
IP27 configuration isn't the only NUMA system - it just happens to be the currently only supported MIPS NUMA system. So move the necessary options back into the main MIPS Kconfig file. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] C99-ify struct resource initialization.Ralf Baechle
2006-06-19[MIPS] Remove duplicate declarations from Alchemy code.Ralf Baechle
2006-06-19[MIPS] arch/mips/au1000/time.c cleanupSergei Shtylyov
Mark au1xxx_timer_setup() __init, just because it is. Get rid of unneeded extern's (note that (*do_gettimeoffset)() is already declared by <asm/time.c>) and an unused variable. Kill some whitespace... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Remove unused instances of prom_build_cpu_map.Ralf Baechle
2006-06-19[MIPS] Qemu system shutdown supportThiemo Seufer
2006-06-19[MIPS] Unify mips_fpu_soft_struct and mips_fpu_hard_structs.Atsushi Nemoto
The struct mips_fpu_soft_struct and mips_fpu_hard_struct are completely same now and the kernel fpu emulator assumes that. This patch unifies them to mips_fpu_struct and get rid of mips_fpu_union. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Remove prototype for non-existing function.Ralf Baechle
2006-06-19[MIPS] Wind River 4KC PPMC Eval Board SupportMark.Zhan
Support for the GT-64120-based Wind River 4KC PPMC Evaluation board. Signed-off-by: Rongkai.Zhan <Rongkai.zhan@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Au1xxx: board specific irq code cleanupHerbert Valerio Riedel
Convert sizeof/sizeof use to use of ARRAY_SIZE macro, and annotate irqmap structures as __initdata. Signed-off-by: Herbert Valerio Riedel <hvr@gnu.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] IP27: Fix collision with hardcoded interrupt number.Ralf Baechle
2006-06-19[PATCH] Fix BCM1480 doubled process accounting times.[MIPS] James E Wilson
Running a UP kernel on a bcm1480 board, I get nonsensical timing results, like this: release@unknown:~/tmp$ time ./a.out real 0m22.906s user 0m45.792s sys 0m0.010s According to my watch, this program took 23 seconds to run, so the real time clock is OK. It is process accounting that is broken. I tracked this down to a problem with the function bcm1480_timer_interrupt in the file sibyte/bcm1480/time.c. This function calls ll_timer_interrupt for cpu0, and ll_local_timer_interrupt for all cpus. However, both of these functions do process accounting. Thus processes running on cpu0 end up with doubled times. This is very obvious in a UP kernel where all processes run on cpu0. The correct way to do this is to only call ll_local_timer interrupt if this is not cpu0. This can be seen in the mips-board/generic/time.c file, and also in the sibyte/sb1250/time.c file, both of which handle this correctly. I fixed the bcm1480/time.c file by copying over the correct code from the sb1250/time.c file. With this fix, I now get sensible results. release@unknown:~/tmp$ time ./a.out real 0m22.903s user 0m22.894s sys 0m0.006s Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Mark PNX8550 support broken.Ralf Baechle
Broken in too many way for me to fix it for 2.6.17. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Fix optimization for size build.Ralf Baechle
It took a while longer than on other architectures but gcc has finally started to strike us as well ... This also fixes the damage by 6edfba1b33c701108717f4e036320fc39abe1912. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] IP22: Fix ISA driver builds if CONFIG_EISA is selected.Ralf Baechle
2006-06-19[MIPS] Cobalt: Fix undefined reference to disable_early_printk.Yoichi Yuasa
2006-06-19[MIPS] Fix fpu_save_double on 64-bit.Atsushi Nemoto
> Without this fix, _save_fp() in 64-bit kernel is seriously broken. > > ffffffff8010bec0 <_save_fp>: > ffffffff8010bec0: 400d6000 mfc0 t1,c0_status > ffffffff8010bec4: 000c7140 sll t2,t0,0x5 > ffffffff8010bec8: 05c10011 bgez t2,ffffffff8010bf10 <_save_fp+0x50> > ffffffff8010becc: 00000000 nop > ffffffff8010bed0: f4810328 sdc1 $f1,808(a0) > ... Fix register usage in fpu_save_double() and make fpu_restore_double() more symmetric with fpu_save_double(). Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Malta: Handle byteswapping hardare bug in big endian mode.Elizabeth Oldham
The SOC-it system controller running in big endian mode might forget byteswapping when DMAing to the last word of physical memory. Fixed by ignoring the last page of memory. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-18[ARM] 3559/1: S3C2442: core and serial portBen Dooks
Patch from Ben Dooks Core support for the Samsung S3C2442, and the serial port driver update to allow the serial port blocks to be used. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3557/1: S3C24XX: centralise and cleanup uart registrationBen Dooks
Patch from Ben Dooks All the S3C24XX based devices currently have similar uart blocks, in the same location. Make the process of adding new uart blocks easier by commonising the device definitions and adding a new init function for the cpu code. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3558/1: SMDK24XX: LED platform devicesBen Dooks
Patch from Ben Dooks Platform devices for the LEDs on all the SMDK24XX boards Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3534/1: add spi support to lubbock platformDavid Brownell
Patch from David Brownell This adds the platform device for SSP/SPI controller, and declares the ads7846 device hooked up to it. Not all Lubbock boards appear to populate the connector needed to use this instead of the ucb1400 chip, but it can always be used as a temperature sensor. In short, this is probably most useful as an example of how to provide the configuration data used by the pxa2xx_spi driver. (Last tested against a slightly earlier version of that driver.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3554/1: ARM: Fix dyntick lockingTony Lindgren
Patch from Tony Lindgren This patch fixes some dyntick locking issues on ARM as pointed out by Russell King. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3553/1: S3C24XX: earlier print of cpu idcode infoBen Dooks
Patch from Ben Dooks Move the printk of the CPU information and IDCODE before the checking of the table entry validity to aide in debugging new cpu entries. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3551/1: S3C24XX: PM code failes to compile with CONFIG_DCACHE_WRITETHROUGHBen Dooks
Patch from Ben Dooks If CONFIG_CPU_DCACHE_WRITETHOUGH is set, then the S3C24XX PM code fails to compile, as there is no need to flush the D-cache, the flush function arm920_flush_kern_cache_all() is not compiled. Fix the code to not use this if the config is set. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3550/1: OSIRIS: fix serial port map for 1:1Ben Dooks
Patch from Ben Dooks The default serial port-mapping for the Osiris has the port 2 mapped onto the first serial port, and no port1. Correct this so port 1 is port. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3548/1: Fix the ARMv6 CPU id in compressed/head.SCatalin Marinas
Patch from Catalin Marinas This code was still using the old format for the ARMv6 CPU id and it wasn't flushing the caches on the MPCore CPU (and other ARM1176 cores). The patch changes the mask bits to cope with the new id format. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3335/1: Old-abi Thumb sys_syscall brokenPaul Brook
Patch from Paul Brook The old-abi sys_syscall syscall is broken when called from Thumb mode. It assumes the syscall number is an Arm syscall number (ie. starts from __NR_OABI_SYSCALL_BASE). In thumb mode syscall numbers start from zero. The patch below fixes this by clearing the nigh bits of the syscall number instead of inverting them. Technically this means we accept some invalid syscall numbers, but I can't see how that could be a problem. The two sets of numbers far apart that unimplemented syscalls should still be rejected. Signed-off-by: Paul Brook <paul@codesourcery.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3467/1: [3/3] Support for Philips PNX4008 platform: defconfigVitaly Wool
Patch from Vitaly Wool This patch adds default configuration file PNX4008 ARM platform. It\'s basically the same as the previos one. Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Signed-off-by: Dmitry Pervushin <dpervushin@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3466/1: [2/3] Support for Philips PNX4008 platform: chip supportVitaly Wool
Patch from Vitaly Wool This patch adds basic chip support for PNX4008 ARM platform. It's basically the same as the previous one, but with the rmk's comments taken into account. Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Signed-off-by: Dmitry Pervushin <dpervushin@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
