If no irq chip in kernel, ioctl KVM_IRQ_LINE will return -EFAULT.
But I see in other place such as KVM_[GET|SET]IRQCHIP, -ENXIO is
return. So this patch used -ENXIO instead of -EFAULT.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
The ioctl KVM_IA64_VCPU_GET_STACK does not set the error code if
copy_to_user() fail, and 0 will be return, we should use -EFAULT
instead of 0 in this case, so this patch fixed it.
This patch use generic linux function native_store_idt()
instead of kvm_get_idt(), and also removed the useless
function kvm_get_idt().
Often an exception can help point out where things start to go wrong.
Signed-off-by: Avi Kivity <avi@redhat.com>
Reading rip is expensive on vmx, so move it inside the tracepoint so we only
incur the cost if tracing is enabled.
The prep_new_page() in page allocator calls set_page_private(page, 0).
So we don't need to reinitialize private of page.
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Avi Kivity<avi@redhat.com>
This patch does:
- no need call tracepoint_synchronize_unregister() when kvm module
is unloaded since ftrace can handle it
- cleanup ftrace's macro
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
If fail to create the vcpu, we should not create the debugfs
for it.
Acked-by: Alexander Graf <agraf@suse.de>
Cc: stable@kernel.org
This patch fixed possible memory leak in kvm_arch_vcpu_create()
under s390, which would happen when kvm_arch_vcpu_create() fails.
Acked-by: Carsten Otte <cotte@de.ibm.com>
LMSW is present in both group tables. It was marked privileged only in
one of them. Intel analog of VMMCALL is already marked privileged.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
These bits are ignored by the hardware too. Implement this
for nested svm too.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
This patch adds the correct handling of the nested io
permission bitmap. Old behavior was to not lookup the port
in the iopm but only reinject an io intercept to the guest.
There is a generic function now to calculate msrpm offsets.
Use that function in nested_svm_exit_handled_msr() remove
the duplicate logic (which had a bug anyway).
This patch optimizes the way the msrpm of the host and the
guest are merged. The old code merged the 2 msrpm pages
completly. This code needed to touch 24kb of memory for that
operation. The optimized variant this patch introduces
merges only the parts where the host msrpm may contain zero
bits. This reduces the amount of memory which is touched to
48 bytes.
This patch introduces a list with all msrs a guest might
have direct access to and changes the svm_vcpu_init_msrpm
function to use this list.
It also adds a check to set_msr_interception which triggers
a warning if a developer changes a msr intercept that is not
in the list.
The algorithm to find the offset in the msrpm for a given
msr is needed at other places too. Move that logic to its
own function.
The nested_svm_exit_handled_msr() returned an bool which is
a bug. I worked by accident because the exected integer
return values match with the true and false values. This
patch changes the return value to int and let the function
return the correct values.
arch/x86/kvm/kvm_timer.h:13: ERROR: code indent should use tabs where possible
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
Implement jmp far opcode ff/5. It is used by multiboot loader.
Add decoding of Ep type of argument used by callf/jmpf.
segment_base() is used only by vmx so move it there.
fix segment_base() to properly check for null segment selector and
avoid accessing NULL pointer if ldt selector in null.
Linux now has native_store_gdt() to do the same. Use it instead of
kvm local version.
When injecting an vmexit.intr into the nested hypervisor
there might be leftover values in the exit_info fields.
Clear them to not confuse nested hypervisors.
If we have the following situation with nested svm:
1. Host KVM intercepts cr0 writes
2. Guest hypervisor intercepts only selective cr0 writes
Then we get an cr0 write intercept which is handled on the
host. But that intercepts may actually be a selective cr0
intercept for the guest. This patch checks for this
condition and injects a selective cr0 intercept if needed.
The vcpu->arch.cr0 variable is already set in the
architecture specific set_cr0 callbacks. There is no need to
set it in the common code.
This allows the architecture code to keep the old arch.cr0
value if it wants. This is required for nested svm to decide
if a selective_cr0 exit needs to be injected.
Hyper-V as a guest wants to write this bit. This patch
ignores it.
This patch implements the emulation of the vm_cr msr for
nested svm.
This patch adds a tracepoint to get information about the
most important intercept bitmasks from the nested vmcb.
A recent change broke tracing of the nested vmcb address. It
was reported as 0 all the time. This patch fixes it.
This patch implements the NMI intercept checking for nested
svm.
Without resetting the MMU the gva_to_pga function will not
work reliably when the vcpu is running in nested context.
This patch removes whitespace errors, fixes comment formats
and most of checkpatch warnings. Now vim does not show
c-space-errors anymore.
Call directly into the vendor services for getting/setting rflags in
emulate_instruction to ensure injected TF survives the emulation.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
RF is not required for injecting TF as the latter will trigger only
after an instruction execution anyway. So do not touch RF when arming or
disarming guest single-step mode.
When in guest debugging mode, we have to reinject those #BP software
exceptions that are caused by guest-injected INT3. As older AMD
processors do not support the required nRIP VMCB field, try to emulate
it by moving RIP past the instruction on exception injection. Fix it up
again in case the injection failed and we were able to catch this. This
does not work for unintercepted faults, but it is better than doing
nothing.
Based on Gleb's suggestion: Add a helper kvm_is_linear_rip that matches
a given linear RIP against the current one. Use this for guest
single-stepping, more users will follow.
Move svm_queue_exception past skip_emulated_instruction to allow calling
it later on.
This restores the deferred VCPU kicking before 956f97cf. We need this
over -rt as wake_up* requires non-atomic context in this configuration.
When we destory a vcpu, we should also make sure to kill all pending
timers that could still be up. When not doing this, hrtimers might
dereference null pointers trying to call our code.
This patch fixes spontanious kernel panics seen after closing VMs.
Signed-off-by: Alexander Graf <alex@csgraf.de>
While converting the kzalloc we used to allocate our vcpu struct to
vmalloc, I forgot to memset the contents to zeros. That broke quite
a lot.
This patch memsets it to zero again.
So far user space was not able to save and restore debug registers for
migration or after reset. Plug this hole.
The interrupt shadow created by STI or MOV-SS-like operations is part of
the VCPU state and must be preserved across migration. Transfer it in
the spare padding field of kvm_vcpu_events.interrupt.
As a side effect we now have to make vmx_set_interrupt_shadow robust
against both shadow types being set. Give MOV SS a higher priority and
skip STI in that case to avoid that VMX throws a fault on next entry.
To avoid that user space migrates a pending software exception or
interrupt, mask them out on KVM_GET_VCPU_EVENTS. Without this, user
space would try to reinject them, and we would have to reconstruct the
proper instruction length for VMX event injection. Now the pending event
will be reinjected via executing the triggering instruction again.
The nested_svm_intr() function does not execute the vmexit
anymore. Therefore we may still be in the nested state after
that function ran. This patch changes the nested_svm_intr()
function to return wether the irq window could be enabled.
vcpu->run is initialized on vcpu creation and can never be NULL
here.
We used to use get_free_pages to allocate our vcpu struct. Unfortunately
that call failed on me several times after my machine had a big enough
uptime, as memory became too fragmented by then.
Fortunately, we don't need it to be page aligned any more! We can just
vmalloc it and everything's great.
We don't need as complex code. I had some thinkos while writing it, figuring
I needed to support PPC32 paths on PPC64 which would have required DR=0, but
everything just runs fine with DR=1.
So let's make the functions simple C call wrappers that reserve some space on
the stack for the respective functions to clobber.
Fixes out-of-RMA-access (and thus guest FPU loading) on the PS3.
We had code to make use of the secondary htab buckets, but kept that
disabled because it was unstable when I put it in.
I checked again if that's still the case and apparently it was only
exposing some instability that was there anyways before. I haven't
seen any badness related to usage of secondary htab entries so far.
This should speed up guest memory allocations by quite a bit, because
we now have more space to put PTEs in.
