In auto-suspend, removed power downs for HSIC from
PADS_CFG1 register.
Bug 1011912
Change-Id: I646c196ef9b822ae8d9e12a0f918507fcdd16f0b
Signed-off-by: srinivas <sthaduvai@nvidia.com>
Reviewed-on: http://git-master/r/116044
Reviewed-by: Simone Willett <swillett@nvidia.com>
Removed the unnecessary function prototypes in Tegra2 wakeups header
Change-Id: Ia41ce72947902cbc483cc85eaefb3a81d091a9b8
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/111817
Change-Id: I6b6348ec3b604bbf9b8e40fe551023cf94b0b153
Reviewed-on: http://git-master/r/117083
There is already implemented full outer clean routine in
arch/arm/mm/cache-l2x0.c.
Make it possible to use it through outer_cache interface,
like other outer maintenance functions.
bug 983964
Change-Id: I47f1fad536c151c255e6a42d6517114c334ddfef
Reviewed-on: http://git-master/r/116074
Reviewed-by: Kirill Artamonov <kartamonov@nvidia.com>
Tested-by: Kirill Artamonov <kartamonov@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Justin Paver <jpaver@nvidia.com>
Enable target PLLX port(LP/G) before cluster switch and disable
the previous PLLX port(LP/G) after cluster switch is finished.
Seeing a power improvement of ~10mW when core operates at
max. voltage and max. frequency.
Bug 997358
Signed-off-by: Prem Sasidharan <psasidharan@nvidia.com>
Change-Id: I9d05245977f9f63a8f4c53b1c6797118d2d8b903
Reviewed-on: http://git-master/r/113399
Made TDM1 as 16 channels so that both devices
work in the same configuration.
Bug 1008391
Signed-off-by: Nitin Pai <npai@nvidia.com>
Reviewed-on: http://git-master/r/112090
(cherry picked from commit 4d042a0e613ba1c2d715d6ed47daddd61be14a28)
Change-Id: I622b046b3b36147b82d47f612febb7ae7ba0767c
Reviewed-on: http://git-master/r/116059
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Propagate error to the caller when switching between alternative
cpu dvfs tables. Change dvfs table during cpu hotplug operation
only after the new edp limit is set, and abort bringing cpu core
on-line in case of failure in applying new (less conservative)
table. When cpu core is removed change dvfs table before setting
new edp limit, and ignore error (it is safe to continue with more
conservative table).
Signed-off-by: Alex Frid <afrid@nvidia.com>
(cherry picked from commit 951710ec179fd620a2251d0815ca7bff15da014b)
Change-Id: Ib1ad8e41093fb9bee75d3d6bd18d0ac406da8271
Reviewed-on: http://git-master/r/114779
Fix issues causing the kernel build to fail with CONFIG_SMP not set.
Change-Id: I8c7a49970e55354e38ce41d2d1e0dab00ba78f24
Signed-off-by: Alex Waterman <alexw@nvidia.com>
Reviewed-on: http://git-master/r/114317
Code clean up of usb phy driver
Change-Id: If951ed461b096be76938504d9e1073a70f59860a
Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-on: http://git-master/r/115339
(cherry picked from commit 6d4046a6f2170dadaf5647f0bf47aa546dd705b0)
Reviewed-on: http://git-master/r/104055
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Allow 3mv tolerance on minimum voltage side for cpu voltage.
This saves power when system require 900/975mV.
bug 997415
Change-Id: I273cdeda6980f5ddf50be7980bced443b386dae8
Reviewed-on: http://git-master/r/110524
Tegra wake source interrupts are only enabled before suspend
bug 904746
Change-Id: Ie9722199b4541f2bac77e47d0c8c7e65d5d8b54d
Reviewed-on: http://git-master/r/115655
Made se.cbus optional so that se clock can be derived
from other clocks and not just from the clocks which drive cbus.
Added config option for the same.
Bug 978870
Change-Id: I7b5bf405efb58bbb53143f52d2bfe0ebcf6b8322
Signed-off-by: Mohit Kataria <mkataria@nvidia.com>
Reviewed-on: http://git-master/r/110827
(cherry picked from commit 35e9017b79a3a4b4e0b4098cd2e63ad24018d3de)
Reviewed-on: http://git-master/r/106397
Fixed bug where pm register was being called multiple times.
Change-Id: I32f7b10547275e0a9bdad1073f9842589180c0f8
Signed-off-by: Joshua Primero <jprimero@nvidia.com>
Reviewed-on: http://git-master/r/116203
Set E_INPUT and PUPD bit of GPIO_PU4 used for dock
detect event for cardhu a02+ board versions and
hence enable pcie hotplug for them.
Bug 955043
Bug 1009086
Bug 1016722
Change-Id: Ibb66e5bc6fd9cf5333a81988b975b611fe9c5312
Signed-off-by: Jay Agarwal <jagarwal@nvidia.com>
Reviewed-on: http://git-master/r/115692
Reviewed-by: Krishna Thota <kthota@nvidia.com>
Flashed modem should start with hsic_active signal as low.
The hsic register is done at falling edge of ap_wake.
Bug 1006183
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/112781
(cherry picked from commit 6437d1453d2a7694c2efa183cff135297f9f45e3)
Change-Id: I7bf355088096788b030fd861ef257a9f635c66e7
Reviewed-on: http://git-master/r/115610
Tested-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Change-Id: I12be16dbc2614224ba852216a645d0f84c795334
Reviewed-on: http://git-master/r/115929
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Changing the CPU min. frequency to 51MHz. This helps
in bringing down the core power to 46mW.
Bug 1005275
Change-Id: I61daa59866be7baf8ebb741000904422cb095e85
(cherry picked from commit afbb34d5871b69df328d5aae37f69f25a8946514)
Reviewed-on: http://git-master/r/115452
Reviewed-by: Wen Yi <wyi@nvidia.com>
Tested-by: Wen Yi <wyi@nvidia.com>
1. Enable USB3 for both android and L4T
2. Enable R8169 for android, already enabled for L4T
Bug 956573
Change-Id: If8d7cf653a5cd2b02352ad07fee3a56c3f568d3a
Reviewed-on: http://git-master/r/113856
Added Tegra3 sdmmc4 dvfs table and downgraded sdmmc 2/4 maximum
clock limits based on recent characterization results.
Bug 817679
Bug 841336
Change-Id: I88ddeaabf0739efc0f9c18c41cace331792d4d43
Reviewed-on: http://git-master/r/107780
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Tested-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Ported Peter's original change 86413 to main.
board-p1852-panel.c:
Add support for primary and secondary LVDS displays, and secondary HDMI display.
board-p1852-pinmux.c:
Add configuration for HDMI and LVDS
board-p1852.c:
board-p1852.h:
Support for determining which p1852 sku is in use
hdmi.c:If no edid retrieved, but there's a hardwired mode, enable it
(used to support HDMI->LVDS output on p1852 sku 2)
devices.c:added secondary display data.
Bug 977859
Bug 994011
Change-Id: Ide8fb6bf7dd873b1d50269fb98d7c1687e4d9073
Signed-off-by: Dongfang Shi <dshi@nvidia.com>
Reviewed-on: http://git-master/r/100438
XMM modem fails at auto-suspend on hsic. Fixing this issue
by enabling PMC sleepwalk code conditionally and only at
phy-on and phy-off routines.
Bug 991709
Reviewed-on: http://git-master/r/109324
(cherry picked from commit 100f818a16ce97411a98ddb0e2c5c9e73a9e654a)
Change-Id: If6f92b8b36f856fa633cb411ac20dbe6e862890c
Reviewed-on: http://git-master/r/115612
This is a WAR solution that allows for the turning on
SD DPD feature.
The original issue is that enabling SD DPD immediately after device comes
out of LP0 causes ULPI disconnect. The root cause of that is
not known.
The WAR is to delay the enabling of SD DPD for 100ms after
device comes out of LP0.
Bug 929628
Change-Id: I3c5e35ace422e5441535c2c0fe18545b53bbddc4
Signed-off-by: Wen Yi <wyi@nvidia.com>
(cherry picked from commit bffb7b917d52a3523af80db21322ec7ba5fd33f9)
Reviewed-on: http://git-master/r/113392
This reverts commit 8924926cdb77c6ab270867d4caef7a8cdacd11f2.
Bug 924452
Bug 929628
(cherry picked from commit 142b34993404c853579864f7b7b4f320fb92a715)
Change-Id: I9d49703799e32d410beba18938e94e4b641eea6f
(cherry picked from commit 8de60b7a832bfbbf09e75def756379dbb2d14c3e)
Reviewed-on: http://git-master/r/113387
Do not clear sleep walk pointer for utmip port after remote
wakeup is detected. This should be cleared after control
is given to USB master from PMC.
Bug 999208
Change-Id: I9f498521989c6421f0043dc1b4364591d4907423
(cherry picked from commit e4dbecfe031cbacd4f22bbbcdf971ab11ad81ee8)
Reviewed-on: http://git-master/r/112938
Update function prototype along with:
commit 6cbf4c7465b7b70936cb422b509da0ad0829c306
ARM: tegra: iovmm: Allow alloc_client to take struct device
Change-Id: I11d173429413ab268f6ab789d90f321e3d33de2c
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/115391
This patch enables to replace iovmm*.ko family with
tegra-{smmu,gart}.ko if needed in kernel config. To use IOMMU as
backend engine, Enable TEGRA_IOMMU_{GART,SMMU} under IOMMU in config,
and automatically disable IOVMM.
IOVMM is equivalent to IOMMU_API. TEGRA_IOVMM_GART is equivalent to
TEGRA_IOMMU_GART. TEGRA_IOVMM_SMMU is equivalent to TEGRA_IOMMU_SMMU.
Change-Id: I73408e927eb3f21e1db4e73700aaf415f4949166
Reviewed-on: http://git-master/r/115011
Replace IOVMM backend functions with the standard IOMMU API
ones. Instead of modifying the actual C-files in drivers, MACROs in
iovmm.h does the all work.
Change-Id: I27dc893555ca1495588852261e3ba1e3e5619764
Reviewed-on: http://git-master/r/114460
So far Tegra3 EMC DFS allowed only scaling rates that can be divided
down from two fixed rate plls: memory PLLM, and peripheral PLLP. PLLM
is always running at maximum SDRAM rate set at boot time, while PLLP
rate 408MHz is fixed across all Tegra3 platforms.
This commit implements dynamic re-locking of PLLM at run time. Now
memory pll can lock either at boot rate or additional auxiliary rate
that is selected as follows: auxiliary PLLM rate must be present in
EMC DFS table, it must exactly match one of the rate steps for Tegra3
graphics bus with PLLC clock source (cbus), and must not be a proper
factor of boot PLLM rate or PLLP fixed rate.
When switching PLLM between boot and auxiliary rate, PLLC is used as
backup memory pll, and during this time cbus is locked at auxiliary
rate. In addition system bus is forced to temporarily use PLLP as
a clock source (this is necessary as sbus main clock source is PLLM
secondary divider PLLM_OUT1).
Limitations:
- only one auxiliary rate is supported, and it should be below PLLM
boot rate, but above half of boot rate
- dynamic re-lock is allowed only on LPDDR2 platforms
- no clock other than EMC and system bus could use PLLM as a source;
so for dynamic re-lock to work CONFIG_TEGRA_PLLM_RESTRICTED must be
selected, and VI clock (not covered by PLLM restricted configuration)
must be moved to PLLP.
Bug 1005576
Change-Id: I6177107c89c3cbe975a1d940927efa1ed0ea61ec
Reviewed-on: http://git-master/r/111438
(cherry picked from commit dc4d468a6acabfb268e7a7f44b45bb7354e9a99a)
Reviewed-on: http://git-master/r/114760
Reviewed-by: Jihoon Bang <jbang@nvidia.com>
Increase the boost_up_threshold to 85 for ULP audio
bug 1009849
Change-Id: I4b1b746f445f5c2804befa52ae95c69b6b467083
Signed-off-by: Vandana Salve <vsalve@nvidia.com>
Reviewed-on: http://git-master/r/114620
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Bug 1005576
Signed-off-by: Peter Zu <pzu@nvidia.com>
Reviewed-on: http://git-master/r/112036
(cherry picked from commit 1f1e6d22e771336fb9e0b91bbabf12fa89f0c57c)
Change-Id: If65aba6aaa0a400c960a2d2b1315a07fa44dcefe
Reviewed-on: http://git-master/r/115054
In this case we want to include a file in the same directory. We
should be using "" with include instead of <>. This fixes a an
issue using the chromeos toolchain (4.6.3+) where fuse.h is not
found while compiling usb_phy.c.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
Change-Id: I0c6bdf6768cd89740ed0444b2b46289057dfad6a
Reviewed-on: http://git-master/r/114608
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Allowed Tegra3 memory PLLM rate change, provided it is disabled.
Since PLLM can deviate from boot configuration now, and on Tegra3 it
is controlled by PMC override registers (not CAR module registers):
- Re-factored PLLM initialization, resume, and set rate operations
accordingly (enable and disable ops already used PMC override).
- Made sure that boot configuration is restored on entry to LP0 to
match memory timing saved in scratch registers.
Bug 1005576
Change-Id: Iac6297455bec709a8e12d71deccab62c18905ea7
Reviewed-on: http://git-master/r/110937
(cherry picked from commit b53f88c68543a2b0ddb4545bb3b389b42eeb95d8)
Reviewed-on: http://git-master/r/114759
On Tegra3 added source rate to EMC clock source selection structure,
and re-factored EMC DVFS initialization accordingly.
Bug 1005576
Change-Id: I155e982bef2431a76cf5e5085070d4e654a7b49b
Reviewed-on: http://git-master/r/110935
(cherry picked from commit bf52c26c532a9ebabc4fc8a1fb5fc9d88be85e66)
Reviewed-on: http://git-master/r/114758
Added shared bus backup rate entry to clock descriptor; initialized
it for cbus (currently the only shared bus with backup source).
Bug 1005576
Change-Id: I8124aa87f1dc307e42417da8f78797cfaf71e5dc
Reviewed-on: http://git-master/r/110934
(cherry picked from commit bc5ed688929c3c0ca920b5e9663cf9c6fb85c00f)
Reviewed-on: http://git-master/r/114757
On Tegra3 changed cpu rate threshold for maximum emc rate request from
750MHz to 925MHz. Adjusted cpu frequency table to provide entries close
to the new threshold for all Tegra3 skus.
Bug 998044
Bug 1003521
Change-Id: I6e6df1958db9d55ad64cf35a5e9fe6ec74b8d4ea
Reviewed-on: http://git-master/r/106946
Tested-by: Aleksandr Frid <afrid@nvidia.com>
time does not increase in LP0 because GPIO4 is configured as POR.
Change to active_low and pull push to fix the issue.
Bug 1014548
Change-Id: I13c65ac6a4f3ae9158c58922e1ad6982f24bb103
Signed-off-by: Chandler Zhang <chazhang@nvidia.com>
Reviewed-on: http://git-master/r/114866
Reviewed-by: Shridhar Rasal <srasal@nvidia.com>
Tested-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-by: Jinyoung Park <jinyoungp@nvidia.com>
Backlight value was inverted for panels with PM313.
This assumed the panel was the 15", but because the
10.1" (AUO) is more prevalent and doesn't have the
inverted backlight signal we no longer need to
invert it. Note this will fix the backlight issue
for AUO E1198 boards but break it for 15".
Bug 962636
Reviewed-on: http://git-master/r/#change,93965
Signed-off-by: Graziano Misuraca <gmisuraca@nvidia.com>
Change-Id: Icb65592eb2df21e349e5a759a780e4438a0f5b26
Reviewed-on: http://git-master/r/95728
Add 12.75mhz emc frequency for Samsung K4P8G304EB-FGC2
LPDDR2 1GB memory chip.
Bug 1011100
Change-Id: Ibbbb3f002c36c31cd2806051803ddd3ba9daa63b
(cherry picked from commit a37cb14dc441005ddd977b6a83f41df817179d79)
Reviewed-on: http://git-master/r/113383
As a part of effort to bring in 437MHz clock frequency in EMC,
We need to move VI from PLL_M to PLL_P.
Bug 1005576
Signed-off-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-on: http://git-master/r/112704
(cherry picked from commit c175857e80355857b55e8eb2012c12e94e532835)
Change-Id: Icd314c01625f5c4765b0215735ceafb7d3f25d1e
Reviewed-on: http://git-master/r/114241
Allow tegra_iovmm_alloc_client() to take struct device * instead of
const char *name w/ __tegra_iovmm_alloc_client(). This is necessary to
support IOVMM and IOMMU simultaneously.
Change-Id: I18df5001bfe0ece8f9f15b636eb11def9f228dfb
Reviewed-on: http://git-master/r/114215
Replace TEGRA_{SMMU,GART}_{BASE,SIZE} with TEGRA_IOMMU_{BASE,SIZE} to
deal with SMMU/GART in unified manner.
This is necessary for DMA mapping API to pass the appropriate IOMMU
address for SMMU and GART in the same code in nvmap.
[Hiroshi Doyu: Squash nvmap parts into "nvmap: API conversion" patch.]
Change-Id: I75429dd56554f880f144c375d2c20e8e8948ceee
Reviewed-on: http://git-master/r/114212
Migrating from IOVMM_SMMU to IOMMU_SMMU.
Change-Id: If5bca4a3bce15d59641f11dfea3ad6da2a8efbf5
Reviewed-on: http://git-master/r/114211
Change-Id: I80c384d1aa4b1e45a4542acbde6b904f4a014aff
Signed-off-by: Sai Charan Gurrappadi <sgurrappadi@nvidia.com>
Reviewed-on: http://git-master/r/113679
Reviewed-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
Fixed bug where skin cooling device is being bound to nct
device instead of skin thermal device.
bug 1007726
Change-Id: Ia6316735da8895fd4f4c20c0a76cd6796dafdf9b
Reviewed-on: http://git-master/r/113563
Disabled USB1 VBUS wake up on board revisions prior to E1291-A03 and
E1198-A02. We see repeated LP0 wakeups if the wake source is enabled.
bug 980993
Change-Id: I080696924aaea06f973392fe7682fecc7574bf02
Reviewed-on: http://git-master/r/103627
Earlier implementation only allowed single wake source
for a particular irq in wake table. Changed implementation
to support multiple wake sources ==> single irq mapping.
bug 980993
Change-Id: Iacb00487531129ef19c53128824aba802e80350e
Reviewed-on: http://git-master/r/103140
Use regulator instead of USB OTG callback to control USB VBUS.
Bug 997805
Change-Id: Icd2869f51e312c52b272a6e32fa8c7ab8763a5ac
Reviewed-on: http://git-master/r/112900
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Add platform callback to initialize and enable FIQ serial
debugger
Bug 970018
Change-Id: Icdf571f7698e10de661a0ce94694de9fb9c70271
Signed-off-by: Kamal Kannan Balagopalan <kbalagopalan@nvidia.com>
Reviewed-on: http://git-master/r/110955
Dump all registers and callstack immediately after entering
the FIQ handler.
Bug 970018
Change-Id: Iab48f5a942b45015a9def0839cf3ef721dda8a5c
Reviewed-on: http://git-master/r/110954
Reviewed-by: Xin Xie <xxie@nvidia.com>
Reviewed-by: Steve Kuo <stevek@nvidia.com>
When the system resumes from lp1 for usb wake event we are seeing
the below warning message:
usb_phy_bringup_host_controller: timeout waiting for PORT_SUSPEND
The above warning message are seen only for lp1 resume and not for
lp0 resume.
This is happening only for lp1 resume because in
usb_phy_bringup_host_controller(), the port is suspended only
if we are not resuming from remote wakeup, in
case of lp0 remote_wake flag is set to true but not in case of lp1.
This is because in lp1, pmc is not responsible for waking the
system but it's the flow controller and hence UTMIP_WALK_PTR_VAL(inst)
will return 0 due to this remote wakeup flag was getting reset to
false.
Bug 985396
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Change-Id: I67fcf21d77cbc627315164b6e1c4f27b0b9ae2c3
Reviewed-on: http://git-master/r/110064
