path: root/arch
2017-09-13ARM: 8692/1: mm: abort uaccess retries upon fatal signalMark Rutland
commit 746a272e44141af24a02f6c9b0f65f4c4598ed42 upstream. When there's a fatal signal pending, arm's do_page_fault() implementation returns 0. The intent is that we'll return to the faulting userspace instruction, delivering the signal on the way. However, if we take a fatal signal during fixing up a uaccess, this results in a return to the faulting kernel instruction, which will be instantly retried, resulting in the same fault being taken forever. As the task never reaches userspace, the signal is not delivered, and the task is left unkillable. While the task is stuck in this state, it can inhibit the forward progress of the system. To avoid this, we must ensure that when a fatal signal is pending, we apply any necessary fixup for a faulting kernel instruction. Thus we will return to an error path, and it is up to that code to make forward progress towards delivering the fatal signal. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Steve Capper <steve.capper@arm.com> Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-07kvm: arm/arm64: Force reading uncached stage2 PGDSuzuki K Poulose
commit 2952a6070e07ebdd5896f1f5b861acad677caded upstream. Make sure we don't use a cached value of the KVM stage2 PGD while resetting the PGD. Cc: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com> Reviewed-by: Christoffer Dall <cdall@linaro.org> Signed-off-by: Christoffer Dall <cdall@linaro.org> Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-07kvm: arm/arm64: Fix race in resetting stage2 PGDSuzuki K Poulose
commit 6c0d706b563af732adb094c5bf807437e8963e84 upstream. In kvm_free_stage2_pgd() we check the stage2 PGD before holding the lock and proceed to take the lock if it is valid. And we unmap the page tables, followed by releasing the lock. We reset the PGD only after dropping this lock, which could cause a race condition where another thread waiting on or even holding the lock, could potentially see that the PGD is still valid and proceed to perform a stage2 operation and later encounter a NULL PGD. [223090.242280] Unable to handle kernel NULL pointer dereference at virtual address 00000040 [223090.262330] PC is at unmap_stage2_range+0x8c/0x428 [223090.262332] LR is at kvm_unmap_hva_handler+0x2c/0x3c [223090.262531] Call trace: [223090.262533] [<ffff0000080adb78>] unmap_stage2_range+0x8c/0x428 [223090.262535] [<ffff0000080adf40>] kvm_unmap_hva_handler+0x2c/0x3c [223090.262537] [<ffff0000080ace2c>] handle_hva_to_gpa+0xb0/0x104 [223090.262539] [<ffff0000080af988>] kvm_unmap_hva+0x5c/0xbc [223090.262543] [<ffff0000080a2478>] kvm_mmu_notifier_invalidate_page+0x50/0x8c [223090.262547] [<ffff0000082274f8>] __mmu_notifier_invalidate_page+0x5c/0x84 [223090.262551] [<ffff00000820b700>] try_to_unmap_one+0x1d0/0x4a0 [223090.262553] [<ffff00000820c5c8>] rmap_walk+0x1cc/0x2e0 [223090.262555] [<ffff00000820c90c>] try_to_unmap+0x74/0xa4 [223090.262557] [<ffff000008230ce4>] migrate_pages+0x31c/0x5ac [223090.262561] [<ffff0000081f869c>] compact_zone+0x3fc/0x7ac [223090.262563] [<ffff0000081f8ae0>] compact_zone_order+0x94/0xb0 [223090.262564] [<ffff0000081f91c0>] try_to_compact_pages+0x108/0x290 [223090.262569] [<ffff0000081d5108>] __alloc_pages_direct_compact+0x70/0x1ac [223090.262571] [<ffff0000081d64a0>] __alloc_pages_nodemask+0x434/0x9f4 [223090.262572] [<ffff0000082256f0>] alloc_pages_vma+0x230/0x254 [223090.262574] [<ffff000008235e5c>] do_huge_pmd_anonymous_page+0x114/0x538 [223090.262576] [<ffff000008201bec>] handle_mm_fault+0xd40/0x17a4 [223090.262577] [<ffff0000081fb324>] __get_user_pages+0x12c/0x36c [223090.262578] [<ffff0000081fb804>] get_user_pages_unlocked+0xa4/0x1b8 [223090.262579] [<ffff0000080a3ce8>] __gfn_to_pfn_memslot+0x280/0x31c [223090.262580] [<ffff0000080a3dd0>] gfn_to_pfn_prot+0x4c/0x5c [223090.262582] [<ffff0000080af3f8>] kvm_handle_guest_abort+0x240/0x774 [223090.262584] [<ffff0000080b2bac>] handle_exit+0x11c/0x1ac [223090.262586] [<ffff0000080ab99c>] kvm_arch_vcpu_ioctl_run+0x31c/0x648 [223090.262587] [<ffff0000080a1d78>] kvm_vcpu_ioctl+0x378/0x768 [223090.262590] [<ffff00000825df5c>] do_vfs_ioctl+0x324/0x5a4 [223090.262591] [<ffff00000825e26c>] SyS_ioctl+0x90/0xa4 [223090.262595] [<ffff000008085d84>] el0_svc_naked+0x38/0x3c This patch moves the stage2 PGD manipulation under the lock. Reported-by: Alexander Graf <agraf@suse.de> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Radim Krčmář <rkrcmar@redhat.com> Reviewed-by: Christoffer Dall <cdall@linaro.org> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Christoffer Dall <cdall@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-07alpha: uapi: Add support for __SANE_USERSPACE_TYPES__Ben Hutchings
commit cec80d82142ab25c71eee24b529cfeaf17c43062 upstream. This fixes compiler errors in perf such as: tests/attr.c: In function 'store_event': tests/attr.c:66:27: error: format '%llu' expects argument of type 'long long unsigned int', but argument 6 has type '__u64 {aka long unsigned int}' [-Werror=format=] snprintf(path, PATH_MAX, "%s/event-%d-%llu-%d", dir, ^ Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Tested-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Matt Turner <mattst88@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-02arm64: fpsimd: Prevent registers leaking across execDave Martin
commit 096622104e14d8a1db4860bd557717067a0515d2 upstream. There are some tricky dependencies between the different stages of flushing the FPSIMD register state during exec, and these can race with context switch in ways that can cause the old task's regs to leak across. In particular, a context switch during the memset() can cause some of the task's old FPSIMD registers to reappear. Disabling preemption for this small window would be no big deal for performance: preemption is already disabled for similar scenarios like updating the FPSIMD registers in sigreturn. So, instead of rearranging things in ways that might swap existing subtle bugs for new ones, this patch just disables preemption around the FPSIMD state flushing so that races of this type can't occur here. This brings fpsimd_flush_thread() into line with other code paths. Fixes: 674c242c9323 ("arm64: flush FP/SIMD state correctly after execve()") Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Dave Martin <Dave.Martin@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-02x86/io: Add "memory" clobber to insb/insw/insl/outsb/outsw/outslArnd Bergmann
commit 7206f9bf108eb9513d170c73f151367a1bdf3dbf upstream. The x86 version of insb/insw/insl uses an inline assembly that does not have the target buffer listed as an output. This can confuse the compiler, leading it to think that a subsequent access of the buffer is uninitialized: drivers/net/wireless/wl3501_cs.c: In function ‘wl3501_mgmt_scan_confirm’: drivers/net/wireless/wl3501_cs.c:665:9: error: ‘sig.status’ is used uninitialized in this function [-Werror=uninitialized] drivers/net/wireless/wl3501_cs.c:668:12: error: ‘sig.cap_info’ may be used uninitialized in this function [-Werror=maybe-uninitialized] drivers/net/sb1000.c: In function 'sb1000_rx': drivers/net/sb1000.c:775:9: error: 'st[0]' is used uninitialized in this function [-Werror=uninitialized] drivers/net/sb1000.c:776:10: error: 'st[1]' may be used uninitialized in this function [-Werror=maybe-uninitialized] drivers/net/sb1000.c:784:11: error: 'st[1]' may be used uninitialized in this function [-Werror=maybe-uninitialized] I tried to mark the exact input buffer as an output here, but couldn't figure it out. As suggested by Linus, marking all memory as clobbered however is good enough too. For the outs operations, I also add the memory clobber, to force the input to be written to local variables. This is probably already guaranteed by the "asm volatile", but it can't hurt to do this for symmetry. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Borislav Petkov <bp@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tom Lendacky <thomas.lendacky@amd.com> Link: http://lkml.kernel.org/r/20170719125310.2487451-5-arnd@arndb.de Link: https://lkml.org/lkml/2017/7/12/605 Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-02arm64: mm: abort uaccess retries upon fatal signalMark Rutland
commit 289d07a2dc6c6b6f3e4b8a62669320d99dbe6c3d upstream. When there's a fatal signal pending, arm64's do_page_fault() implementation returns 0. The intent is that we'll return to the faulting userspace instruction, delivering the signal on the way. However, if we take a fatal signal during fixing up a uaccess, this results in a return to the faulting kernel instruction, which will be instantly retried, resulting in the same fault being taken forever. As the task never reaches userspace, the signal is not delivered, and the task is left unkillable. While the task is stuck in this state, it can inhibit the forward progress of the system. To avoid this, we must ensure that when a fatal signal is pending, we apply any necessary fixup for a faulting kernel instruction. Thus we will return to an error path, and it is up to that code to make forward progress towards delivering the fatal signal. Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Laura Abbott <labbott@redhat.com> Reviewed-by: Steve Capper <steve.capper@arm.com> Tested-by: Steve Capper <steve.capper@arm.com> Reviewed-by: James Morse <james.morse@arm.com> Tested-by: James Morse <james.morse@arm.com> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30ARCv2: PAE40: Explicitly set MSB counterpart of SLC region ops addressesAlexey Brodkin
commit 7d79cee2c6540ea64dd917a14e2fd63d4ac3d3c0 upstream. It is necessary to explicitly set both SLC_AUX_RGN_START1 and SLC_AUX_RGN_END1 which hold MSB bits of the physical address correspondingly of region start and end otherwise SLC region operation is executed in unpredictable manner Without this patch, SLC flushes on HSDK (IOC disabled) were taking seconds. Reported-by: Vladimir Kondratiev <vladimir.kondratiev@intel.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> [vgupta: PAR40 regs only written if PAE40 exist] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24perf/x86: Fix LBR related crashes on Intel AtomStephane Eranian
commit 6fc2e83077b05a061afe9b24f2fdff7a0434eb67 upstream. This patches fixes the LBR kernel crashes on Intel Atom. The kernel was assuming that if the CPU supports 64-bit format LBR, then it has an LBR_SELECT MSR. Atom uses 64-bit LBR format but does not have LBR_SELECT. That was causing NULL pointer dereferences in a couple of places. Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: kan.liang@intel.com Fixes: 96f3eda67fcf ("perf/x86/intel: Fix static checker warning in lbr enable") Link: http://lkml.kernel.org/r/1449182000-31524-2-git-send-email-eranian@google.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Denys Zagorui <dzagorui@cisco.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24x86/asm/64: Clear AC on NMI entriesAndy Lutomirski
commit e93c17301ac55321fc18e0f8316e924e58a83c8c upstream. This closes a hole in our SMAP implementation. This patch comes from grsecurity. Good catch! Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/314cc9f294e8f14ed85485727556ad4f15bb1659.1502159503.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24mm: revert x86_64 and arm64 ELF_ET_DYN_BASE base changesKees Cook
commit c715b72c1ba406f133217b509044c38d8e714a37 upstream. Moving the x86_64 and arm64 PIE base from 0x555555554000 to 0x000100000000 broke AddressSanitizer. This is a partial revert of: eab09532d400 ("binfmt_elf: use ELF_ET_DYN_BASE only for PIE") 02445990a96e ("arm64: move ELF_ET_DYN_BASE to 4GB / 4MB") The AddressSanitizer tool has hard-coded expectations about where executable mappings are loaded. The motivation for changing the PIE base in the above commits was to avoid the Stack-Clash CVEs that allowed executable mappings to get too close to heap and stack. This was mainly a problem on 32-bit, but the 64-bit bases were moved too, in an effort to proactively protect those systems (proofs of concept do exist that show 64-bit collisions, but other recent changes to fix stack accounting and setuid behaviors will minimize the impact). The new 32-bit PIE base is fine for ASan (since it matches the ET_EXEC base), so only the 64-bit PIE base needs to be reverted to let x86 and arm64 ASan binaries run again. Future changes to the 64-bit PIE base on these architectures can be made optional once a more dynamic method for dealing with AddressSanitizer is found. (e.g. always loading PIE into the mmap region for marked binaries.) Link: http://lkml.kernel.org/r/20170807201542.GA21271@beast Fixes: eab09532d400 ("binfmt_elf: use ELF_ET_DYN_BASE only for PIE") Fixes: 02445990a96e ("arm64: move ELF_ET_DYN_BASE to 4GB / 4MB") Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: Kostya Serebryany <kcc@google.com> Acked-by: Will Deacon <will.deacon@arm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24crypto: x86/sha1 - Fix reads beyond the number of blocks passedmegha.dey@linux.intel.com
commit 8861249c740fc4af9ddc5aee321eafefb960d7c6 upstream. It was reported that the sha1 AVX2 function(sha1_transform_avx2) is reading ahead beyond its intended data, and causing a crash if the next block is beyond page boundary: http://marc.info/?l=linux-crypto-vger&m=149373371023377 This patch makes sure that there is no overflow for any buffer length. It passes the tests written by Jan Stancek that revealed this problem: https://github.com/jstancek/sha1-avx2-crash I have re-enabled sha1-avx2 by reverting commit b82ce24426a4071da9529d726057e4e642948667 Fixes: b82ce24426a4 ("crypto: sha1-ssse3 - Disable avx2") Originally-by: Ilya Albrekht <ilya.albrekht@intel.com> Tested-by: Jan Stancek <jstancek@redhat.com> Signed-off-by: Megha Dey <megha.dey@linux.intel.com> Reported-by: Jan Stancek <jstancek@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-12KVM: arm/arm64: Handle hva aging while destroying the vmSuzuki K Poulose
commit 7e5a672289c9754d07e1c3b33649786d3d70f5e4 upstream. The mmu_notifier_release() callback of KVM triggers cleaning up the stage2 page table on kvm-arm. However there could be other notifier callbacks in parallel with the mmu_notifier_release(), which could cause the call backs ending up in an empty stage2 page table. Make sure we check it for all the notifier callbacks. Fixes: commit 293f29363 ("kvm-arm: Unmap shadow pagetables properly") Reported-by: Alex Graf <agraf@suse.de> Reviewed-by: Christoffer Dall <cdall@linaro.org> Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-12sparc64: Prevent perf from running during super critical sectionsRob Gardner
commit fc290a114fc6034b0f6a5a46e2fb7d54976cf87a upstream. This fixes another cause of random segfaults and bus errors that may occur while running perf with the callgraph option. Critical sections beginning with spin_lock_irqsave() raise the interrupt level to PIL_NORMAL_MAX (14) and intentionally do not block performance counter interrupts, which arrive at PIL_NMI (15). But some sections of code are "super critical" with respect to perf because the perf_callchain_user() path accesses user space and may cause TLB activity as well as faults as it unwinds the user stack. One particular critical section occurs in switch_mm: spin_lock_irqsave(&mm->context.lock, flags); ... load_secondary_context(mm); tsb_context_switch(mm); ... spin_unlock_irqrestore(&mm->context.lock, flags); If a perf interrupt arrives in between load_secondary_context() and tsb_context_switch(), then perf_callchain_user() could execute with the context ID of one process, but with an active TSB for a different process. When the user stack is accessed, it is very likely to incur a TLB miss, since the h/w context ID has been changed. The TLB will then be reloaded with a translation from the TSB for one process, but using a context ID for another process. This exposes memory from one process to another, and since it is a mapping for stack memory, this usually causes the new process to crash quickly. This super critical section needs more protection than is provided by spin_lock_irqsave() since perf interrupts must not be allowed in. Since __tsb_context_switch already goes through the trouble of disabling interrupts completely, we fix this by moving the secondary context load down into this better protected region. Orabug: 25577560 Signed-off-by: Dave Aldridge <david.j.aldridge@oracle.com> Signed-off-by: Rob Gardner <rob.gardner@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-12bpf, s390: fix jit branch offset related to ldimm64Daniel Borkmann
[ Upstream commit b0a0c2566f28e71e5e32121992ac8060cec75510 ] While testing some other work that required JIT modifications, I run into test_bpf causing a hang when JIT enabled on s390. The problematic test case was the one from ddc665a4bb4b (bpf, arm64: fix jit branch offset related to ldimm64), and turns out that we do have a similar issue on s390 as well. In bpf_jit_prog() we update next instruction address after returning from bpf_jit_insn() with an insn_count. bpf_jit_insn() returns either -1 in case of error (e.g. unsupported insn), 1 or 2. The latter is only the case for ldimm64 due to spanning 2 insns, however, next address is only set to i + 1 not taking actual insn_count into account, thus fix is to use insn_count instead of 1. bpf_jit_enable in mode 2 provides also disasm on s390: Before fix: 000003ff800349b6: a7f40003 brc 15,3ff800349bc ; target 000003ff800349ba: 0000 unknown 000003ff800349bc: e3b0f0700024 stg %r11,112(%r15) 000003ff800349c2: e3e0f0880024 stg %r14,136(%r15) 000003ff800349c8: 0db0 basr %r11,%r0 000003ff800349ca: c0ef00000000 llilf %r14,0 000003ff800349d0: e320b0360004 lg %r2,54(%r11) 000003ff800349d6: e330b03e0004 lg %r3,62(%r11) 000003ff800349dc: ec23ffeda065 clgrj %r2,%r3,10,3ff800349b6 ; jmp 000003ff800349e2: e3e0b0460004 lg %r14,70(%r11) 000003ff800349e8: e3e0b04e0004 lg %r14,78(%r11) 000003ff800349ee: b904002e lgr %r2,%r14 000003ff800349f2: e3b0f0700004 lg %r11,112(%r15) 000003ff800349f8: e3e0f0880004 lg %r14,136(%r15) 000003ff800349fe: 07fe bcr 15,%r14 After fix: 000003ff80ef3db4: a7f40003 brc 15,3ff80ef3dba 000003ff80ef3db8: 0000 unknown 000003ff80ef3dba: e3b0f0700024 stg %r11,112(%r15) 000003ff80ef3dc0: e3e0f0880024 stg %r14,136(%r15) 000003ff80ef3dc6: 0db0 basr %r11,%r0 000003ff80ef3dc8: c0ef00000000 llilf %r14,0 000003ff80ef3dce: e320b0360004 lg %r2,54(%r11) 000003ff80ef3dd4: e330b03e0004 lg %r3,62(%r11) 000003ff80ef3dda: ec230006a065 clgrj %r2,%r3,10,3ff80ef3de6 ; jmp 000003ff80ef3de0: e3e0b0460004 lg %r14,70(%r11) 000003ff80ef3de6: e3e0b04e0004 lg %r14,78(%r11) ; target 000003ff80ef3dec: b904002e lgr %r2,%r14 000003ff80ef3df0: e3b0f0700004 lg %r11,112(%r15) 000003ff80ef3df6: e3e0f0880004 lg %r14,136(%r15) 000003ff80ef3dfc: 07fe bcr 15,%r14 test_bpf.ko suite runs fine after the fix. Fixes: 054623105728 ("s390/bpf: Add s390x eBPF JIT compiler backend") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Tested-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11ARM: 8632/1: ftrace: fix syscall name matchingRabin Vincent
[ Upstream commit 270c8cf1cacc69cb8d99dea812f06067a45e4609 ] ARM has a few system calls (most notably mmap) for which the names of the functions which are referenced in the syscall table do not match the names of the syscall tracepoints. As a consequence of this, these tracepoints are not made available. Implement arch_syscall_match_sym_name to fix this and allow tracing even these system calls. Signed-off-by: Rabin Vincent <rabinv@axis.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11x86/boot: Add missing declaration of string functionsNicholas Mc Guire
[ Upstream commit fac69d0efad08fc15e4dbfc116830782acc0dc9a ] Add the missing declarations of basic string functions to string.h to allow a clean build. Fixes: 5be865661516 ("String-handling functions for the new x86 setup code.") Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org> Link: http://lkml.kernel.org/r/1483781911-21399-1-git-send-email-hofrat@osadl.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11sparc64: Measure receiver forward progress to avoid send mondo timeoutJane Chu
[ Upstream commit 9d53caec84c7c5700e7c1ed744ea584fff55f9ac ] A large sun4v SPARC system may have moments of intensive xcall activities, usually caused by unmapping many pages on many CPUs concurrently. This can flood receivers with CPU mondo interrupts for an extended period, causing some unlucky senders to hit send-mondo timeout. This problem gets worse as cpu count increases because sometimes mappings must be invalidated on all CPUs, and sometimes all CPUs may gang up on a single CPU. But a busy system is not a broken system. In the above scenario, as long as the receiver is making forward progress processing mondo interrupts, the sender should continue to retry. This patch implements the receiver's forward progress meter by introducing a per cpu counter 'cpu_mondo_counter[cpu]' where 'cpu' is in the range of 0..NR_CPUS. The receiver increments its counter as soon as it receives a mondo and the sender tracks the receiver's counter. If the receiver has stopped making forward progress when the retry limit is reached, the sender declares send-mondo-timeout and panic; otherwise, the receiver is allowed to keep making forward progress. In addition, it's been observed that PCIe hotplug events generate Correctable Errors that are handled by hypervisor and then OS. Hypervisor 'borrows' a guest cpu strand briefly to provide the service. If the cpu strand is simultaneously the only cpu targeted by a mondo, it may not be available for the mondo in 20msec, causing SUN4V mondo timeout. It appears that 1 second is the agreed wait time between hypervisor and guest OS, this patch makes the adjustment. Orabug: 25476541 Orabug: 26417466 Signed-off-by: Jane Chu <jane.chu@oracle.com> Reviewed-by: Steve Sistare <steven.sistare@oracle.com> Reviewed-by: Anthony Yznaga <anthony.yznaga@oracle.com> Reviewed-by: Rob Gardner <rob.gardner@oracle.com> Reviewed-by: Thomas Tai <thomas.tai@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11ARM: dts: armada-38x: Fix irq type for pca955Gregory CLEMENT
commit 8d4514173211586c6238629b1ef1e071927735f5 upstream. As written in the datasheet the PCA955 can only handle low level irq and not edge irq. Without this fix the interrupt is not usable for pca955: the gpio-pca953x driver already set the irq type as low level which is incompatible with edge type, then the kernel prevents using the interrupt: "irq: type mismatch, failed to map hwirq-18 for /soc/internal-regs/gpio@18100!" Fixes: 928413bd859c ("ARM: mvebu: Add Armada 388 General Purpose Development Board support") Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11KVM: async_pf: make rcu irq exit if not triggered from idle taskWanpeng Li
commit 337c017ccdf2653d0040099433fc1a2b1beb5926 upstream. WARNING: CPU: 5 PID: 1242 at kernel/rcu/tree_plugin.h:323 rcu_note_context_switch+0x207/0x6b0 CPU: 5 PID: 1242 Comm: unity-settings- Not tainted 4.13.0-rc2+ #1 RIP: 0010:rcu_note_context_switch+0x207/0x6b0 Call Trace: __schedule+0xda/0xba0 ? kvm_async_pf_task_wait+0x1b2/0x270 schedule+0x40/0x90 kvm_async_pf_task_wait+0x1cc/0x270 ? prepare_to_swait+0x22/0x70 do_async_page_fault+0x77/0xb0 ? do_async_page_fault+0x77/0xb0 async_page_fault+0x28/0x30 RIP: 0010:__d_lookup_rcu+0x90/0x1e0 I encounter this when trying to stress the async page fault in L1 guest w/ L2 guests running. Commit 9b132fbe5419 (Add rcu user eqs exception hooks for async page fault) adds rcu_irq_enter/exit() to kvm_async_pf_task_wait() to exit cpu idle eqs when needed, to protect the code that needs use rcu. However, we need to call the pair even if the function calls schedule(), as seen from the above backtrace. This patch fixes it by informing the RCU subsystem exit/enter the irq towards/away from idle for both n.halted and !n.halted. Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06arm64: mm: fix show_pte KERN_CONT falloutMark Rutland
[ Upstream commit 6ef4fb387d50fa8f3bffdffc868b57e981cdd709 ] Recent changes made KERN_CONT mandatory for continued lines. In the absence of KERN_CONT, a newline may be implicit inserted by the core printk code. In show_pte, we (erroneously) use printk without KERN_CONT for continued prints, resulting in output being split across a number of lines, and not matching the intended output, e.g. [ff000000000000] *pgd=00000009f511b003 , *pud=00000009f4a80003 , *pmd=0000000000000000 Fix this by using pr_cont() for all the continuations. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06ARM: s3c2410_defconfig: Fix invalid values for NF_CT_PROTO_*Krzysztof Kozlowski
[ Upstream commit 3ef01c968fbfb21c2f16281445d30a865ee4412c ] NF_CT_PROTO_DCCP/SCTP/UDPLITE were switched from tristate to boolean so defconfig needs to be adjusted to silence warnings: warning: symbol value 'm' invalid for NF_CT_PROTO_DCCP warning: symbol value 'm' invalid for NF_CT_PROTO_SCTP warning: symbol value 'm' invalid for NF_CT_PROTO_UDPLITE Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06ARM64: zynqmp: Fix i2c node's compatible stringMoritz Fischer
[ Upstream commit c415f9e8304a1d235ef118d912f374ee2e46c45d ] The Zynq Ultrascale MP uses version 1.4 of the Cadence IP core which fixes some silicon bugs that needed software workarounds in Version 1.0 that was used on Zynq systems. Signed-off-by: Moritz Fischer <mdf@kernel.org> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Sören Brinkmann <soren.brinkmann@xilinx.com> Cc: Rob Herring <robh+dt@kernel.org> Acked-by: Sören Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06ARM64: zynqmp: Fix W=1 dtc 1.4 warningsMichal Simek
[ Upstream commit 4ea2a6be9565455f152c12f80222af1582ede0c7 ] The patch removes these warnings reported by dtc 1.4: Warning (unit_address_vs_reg): Node /amba_apu has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06openrisc: Add _text symbol to fix ksym build errorStafford Horne
[ Upstream commit 086cc1c31a0ec075dac02425367c871bb65bc2c9 ] The build robot reports: .tmp_kallsyms1.o: In function `kallsyms_relative_base': >> (.rodata+0x8a18): undefined reference to `_text' This is when using 'make alldefconfig'. Adding this _text symbol to mark the start of the kernel as in other architecture fixes this. Signed-off-by: Stafford Horne <shorne@gmail.com> Acked-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06ARM: dts: n900: Mark eMMC slot with no-sdio and no-sd flagsPali Rohár
[ Upstream commit 4cf48f1d7520a4d325af58eded4d8090e1b40be7 ] Trying to initialize eMMC slot as SDIO or SD cause failure in n900 port of qemu. eMMC itself is not detected and is not working. Real Nokia N900 harware does not have this problem. As eMMC is really not SDIO or SD based such change is harmless and will fix support for qemu. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06x86/mce/AMD: Make the init code more robustThomas Gleixner
[ Upstream commit 0dad3a3014a0b9e72521ff44f17e0054f43dcdea ] If mce_device_init() fails then the mce device pointer is NULL and the AMD mce code happily dereferences it. Add a sanity check. Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de> Reported-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06Revert "powerpc/numa: Fix percpu allocations to be NUMA aware"Greg Kroah-Hartman
This reverts commit 8c92870bdbf20b5fa5150a2c8bf53ab498516b24 which is commit ba4a648f12f4cd0a8003dd229b6ca8a53348ee4b upstream. Michal Hocko writes: JFYI. We have encountered a regression after applying this patch on a large ppc machine. While the patch is the right thing to do it doesn't work well with the current vmalloc area size on ppc and large machines where NUMA nodes are very far from each other. Just for the reference the boot fails on such a machine with bunch of warning preceeding it. See http://lkml.kernel.org/r/20170724134240.GL25221@dhcp22.suse.cz It seems the right thing to do is to enlarge the vmalloc space on ppc but this is not the case in the upstream kernel yet AFAIK. It is also questionable whether that is a stable material but I will decision on you here. We have reverted this patch from our 4.4 based kernel. Newer kernels do not have enlarged vmalloc space yet AFAIK so they won't work properly eiter. This bug is quite rare though because you need a specific HW configuration to trigger the issue - namely NUMA nodes have to be far away from each other in the physical memory space. Cc: Michal Hocko <mhocko@kernel.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06KVM: PPC: Book3S HV: Save/restore host values of debug registersPaul Mackerras
commit 7ceaa6dcd8c6f59588428cec37f3c8093dd1011f upstream. At present, HV KVM on POWER8 and POWER9 machines loses any instruction or data breakpoint set in the host whenever a guest is run. Instruction breakpoints are currently only used by xmon, but ptrace and the perf_event subsystem can set data breakpoints as well as xmon. To fix this, we save the host values of the debug registers (CIABR, DAWR and DAWRX) before entering the guest and restore them on exit. To provide space to save them in the stack frame, we expand the stack frame allocated by kvmppc_hv_entry() from 112 to 144 bytes. [paulus@ozlabs.org - Adjusted stack offsets since we aren't saving POWER9-specific registers.] Fixes: b005255e12a3 ("KVM: PPC: Book3S HV: Context-switch new POWER8 SPRs", 2014-01-08) Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06KVM: PPC: Book3S HV: Reload HTM registers explicitlyPaul Mackerras
Commit 46a704f8409f ("KVM: PPC: Book3S HV: Preserve userspace HTM state properly", 2017-06-15) added code which assumes that the kernel is able to handle a TM (transactional memory) unavailable interrupt from userspace by reloading the TM-related registers and enabling TM for the process. That ability was added in the 4.9 kernel; earlier kernel versions simply panic on getting the TM unavailable interrupt. Since commit 46a704f8409f has been backported to the 4.4 stable tree as commit 824b9506e4f2, 4.4.75 and subsequent versions are vulnerable to a userspace-triggerable panic. This patch fixes the problem by explicitly reloading the TM-related registers before returning to userspace, rather than disabling TM for the process. Commit 46a704f8409f also failed to enable TM for the kernel, leading to a TM unavailable interrupt in the kernel, causing an oops. This fixes that problem too, by enabling TM before accessing the TM registers. That problem is fixed upstream by the patch "KVM: PPC: Book3S HV: Enable TM before accessing TM registers". Fixes: 824b9506e4f2 ("KVM: PPC: Book3S HV: Preserve userspace HTM state properly") Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06KVM: PPC: Book3S HV: Restore critical SPRs to host values on guest exitPaul Mackerras
commit 4c3bb4ccd074e1a0552078c0bf94c662367a1658 upstream. This restores several special-purpose registers (SPRs) to sane values on guest exit that were missed before. TAR and VRSAVE are readable and writable by userspace, and we need to save and restore them to prevent the guest from potentially affecting userspace execution (not that TAR or VRSAVE are used by any known program that run uses the KVM_RUN ioctl). We save/restore these in kvmppc_vcpu_run_hv() rather than on every guest entry/exit. FSCR affects userspace execution in that it can prohibit access to certain facilities by userspace. We restore it to the normal value for the task on exit from the KVM_RUN ioctl. IAMR is normally 0, and is restored to 0 on guest exit. However, with a radix host on POWER9, it is set to a value that prevents the kernel from executing user-accessible memory. On POWER9, we save IAMR on guest entry and restore it on guest exit to the saved value rather than 0. On POWER8 we continue to set it to 0 on guest exit. PSPB is normally 0. We restore it to 0 on guest exit to prevent userspace taking advantage of the guest having set it non-zero (which would allow userspace to set its SMT priority to high). UAMOR is normally 0. We restore it to 0 on guest exit to prevent the AMR from being used as a covert channel between userspace processes, since the AMR is not context-switched at present. [paulus@ozlabs.org - removed IAMR bits that are only needed on POWER9; adjusted FSCR save/restore for lack of fscr field in thread_struct.] Fixes: b005255e12a3 ("KVM: PPC: Book3S HV: Context-switch new POWER8 SPRs", 2014-01-08) Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06KVM: PPC: Book3S HV: Context-switch EBB registers properlyPaul Mackerras
commit ca8efa1df1d15a1795a2da57f9f6aada6ed6b946 upstream. This adds code to save the values of three SPRs (special-purpose registers) used by userspace to control event-based branches (EBBs), which are essentially interrupts that get delivered directly to userspace. These registers are loaded up with guest values when entering the guest, and their values are saved when exiting the guest, but we were not saving the host values and restoring them before going back to userspace. On POWER8 this would only affect userspace programs which explicitly request the use of EBBs and also use the KVM_RUN ioctl, since the only source of EBBs on POWER8 is the PMU, and there is an explicit enable bit in the PMU registers (and those PMU registers do get properly context-switched between host and guest). On POWER9 there is provision for externally-generated EBBs, and these are not subject to the control in the PMU registers. Since these registers only affect userspace, we can save them when we first come in from userspace and restore them before returning to userspace, rather than saving/restoring the host values on every guest entry/exit. Similarly, we don't need to worry about their values on offline secondary threads since they execute in the context of the idle task, which never executes in userspace. Fixes: b005255e12a3 ("KVM: PPC: Book3S HV: Context-switch new POWER8 SPRs", 2014-01-08) Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06powerpc/pseries: Fix of_node_put() underflow during reconfig removeLaurent Vivier
commit 4fd1bd443e80b12f0a01a45fb9a793206b41cb72 upstream. As for commit 68baf692c435 ("powerpc/pseries: Fix of_node_put() underflow during DLPAR remove"), the call to of_node_put() must be removed from pSeries_reconfig_remove_node(). dlpar_detach_node() and pSeries_reconfig_remove_node() both call of_detach_node(), and thus the node should not be released in both cases. Fixes: 0829f6d1f69e ("of: device_node kobject lifecycle fixes") Signed-off-by: Laurent Vivier <lvivier@redhat.com> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27MIPS: Fix a typo: s/preset/present/ in r2-to-r6 emulation error messageMaciej W. Rozycki
commit 27fe2200dad2de8207a694024a7b9037dff1b280 upstream. This is a user-visible message, so we want it to be spelled correctly. Fixes: 5f9f41c474be ("MIPS: kernel: Prepare the JR instruction for emulation on MIPS R6") Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/16400/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27MIPS: Send SIGILL for linked branches in `__compute_return_epc_for_insn'Maciej W. Rozycki
commit fef40be6da856afead4177aaa9d869a66fb3381f upstream. Fix commit 319824eabc3f ("MIPS: kernel: branch: Do not emulate the branch likelies on MIPS R6") and also send SIGILL rather than returning -SIGILL for BLTZAL, BLTZALL, BGEZAL and BGEZALL instruction encodings no longer supported in R6, except where emulated. Returning -SIGILL is never correct as the API defines this function's result upon error to be -EFAULT and a signal actually issued. Fixes: 319824eabc3f ("MIPS: kernel: branch: Do not emulate the branch likelies on MIPS R6") Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/16398/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27MIPS: Rename `sigill_r6' to `sigill_r2r6' in `__compute_return_epc_for_insn'Maciej W. Rozycki
commit 1f4edde422961397cf4470b347958c13c6a740bb upstream. Use the more accurate `sigill_r2r6' name for the label used in the case of sending SIGILL in the absence of the instruction emulator for an earlier ISA level instruction that has been removed as from the R6 ISA, so that the `sigill_r6' name is freed for the situation where an R6 instruction is not supposed to be interpreted, because the executing processor does not support the R6 ISA. Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/16397/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27MIPS: Send SIGILL for BPOSGE32 in `__compute_return_epc_for_insn'Maciej W. Rozycki
commit 7b82c1058ac1f8f8b9f2b8786b1f710a57a870a8 upstream. Fix commit e50c0a8fa60d ("Support the MIPS32 / MIPS64 DSP ASE.") and send SIGILL rather than SIGBUS whenever an unimplemented BPOSGE32 DSP ASE instruction has been encountered in `__compute_return_epc_for_insn' as our Reserved Instruction exception handler would in response to an attempt to actually execute the instruction. Sending SIGBUS only makes sense for the unaligned PC case, since moved to `__compute_return_epc'. Adjust function documentation accordingly, correct formatting and use `pr_info' rather than `printk' as the other exit path already does. Fixes: e50c0a8fa60d ("Support the MIPS32 / MIPS64 DSP ASE.") Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/16396/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27MIPS: math-emu: Prevent wrong ISA mode instruction emulationMaciej W. Rozycki
commit 13769ebad0c42738831787e27c7c7f982e7da579 upstream. Terminate FPU emulation immediately whenever an ISA mode switch has been observed. This is so that we do not interpret machine code in the wrong mode, for example when a regular MIPS FPU instruction has been placed in a delay slot of a jump that switches into the MIPS16 mode, as with the following code (taken from a GCC test suite case): 00400650 <set_fast_math>: 400650: 3c020100 lui v0,0x100 400654: 03e00008 jr ra 400658: 44c2f800 ctc1 v0,c1_fcsr 40065c: 00000000 nop [...] 004012d0 <__libc_csu_init>: 4012d0: f000 6a02 li v0,2 4012d4: f150 0b1c la v1,3f9430 <_DYNAMIC-0x6df0> 4012d8: f400 3240 sll v0,16 4012dc: e269 addu v0,v1 4012de: 659a move gp,v0 4012e0: f00c 64f6 save a0-a2,48,ra,s0-s1 4012e4: 673c move s1,gp 4012e6: f010 9978 lw v1,-32744(s1) 4012ea: d204 sw v0,16(sp) 4012ec: eb40 jalr v1 4012ee: 653b move t9,v1 4012f0: f010 997c lw v1,-32740(s1) 4012f4: f030 9920 lw s1,-32736(s1) 4012f8: e32f subu v1,s1 4012fa: 326b sra v0,v1,2 4012fc: d206 sw v0,24(sp) 4012fe: 220c beqz v0,401318 <__libc_csu_init+0x48> 401300: 6800 li s0,0 401302: 99e0 lw a3,0(s1) 401304: 4801 addiu s0,1 401306: 960e lw a2,56(sp) 401308: 4904 addiu s1,4 40130a: 950d lw a1,52(sp) 40130c: 940c lw a0,48(sp) 40130e: ef40 jalr a3 401310: 653f move t9,a3 401312: 9206 lw v0,24(sp) 401314: ea0a cmp v0,s0 401316: 61f5 btnez 401302 <__libc_csu_init+0x32> 401318: 6476 restore 48,ra,s0-s1 40131a: e8a0 jrc ra Here `set_fast_math' is called from `40130e' (`40130f' with the ISA bit) and emulation triggers for the CTC1 instruction. As it is in a jump delay slot emulation continues from `401312' (`401313' with the ISA bit). However we have no path to handle MIPS16 FPU code emulation, because there are no MIPS16 FPU instructions. So the default emulation path is taken, interpreting a 32-bit word fetched by `get_user' from `401313' as a regular MIPS instruction, which is: 401313: f5ea0a92 sdc1 $f10,2706(t7) This makes the FPU emulator proceed with the supposed SDC1 instruction and consequently makes the program considered here terminate with SIGSEGV. A similar although less severe issue exists with pure-microMIPS processors in the case where similarly an FPU instruction is emulated in a delay slot of a register jump that (incorrectly) switches into the regular MIPS mode. A subsequent instruction fetch from the jump's target is supposed to cause an Address Error exception, however instead we proceed with regular MIPS FPU emulation. For simplicity then, always terminate the emulation loop whenever a mode change is detected, denoted by an ISA mode bit flip. As from commit 377cb1b6c16a ("MIPS: Disable MIPS16/microMIPS crap for platforms not supporting these ASEs.") the result of `get_isa16_mode' can be hardcoded to 0, so we need to examine the ISA mode bit by hand. This complements commit 102cedc32a6e ("MIPS: microMIPS: Floating point support.") which added JALX decoding to FPU emulation. Fixes: 102cedc32a6e ("MIPS: microMIPS: Floating point support.") Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/16393/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27MIPS: Fix unaligned PC interpretation in `compute_return_epc'Maciej W. Rozycki
commit 11a3799dbeb620bf0400b1fda5cc2c6bea55f20a upstream. Fix a regression introduced with commit fb6883e5809c ("MIPS: microMIPS: Support handling of delay slots.") and defer to `__compute_return_epc' if the ISA bit is set in EPC with non-MIPS16, non-microMIPS hardware, which will then arrange for a SIGBUS due to an unaligned instruction reference. Returning EPC here is never correct as the API defines this function's result to be either a negative error code on failure or one of 0 and BRANCH_LIKELY_TAKEN on success. Fixes: fb6883e5809c ("MIPS: microMIPS: Support handling of delay slots.") Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/16395/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27MIPS: Actually decode JALX in `__compute_return_epc_for_insn'Maciej W. Rozycki
commit a9db101b735a9d49295326ae41f610f6da62b08c upstream. Complement commit fb6883e5809c ("MIPS: microMIPS: Support handling of delay slots.") and actually decode the regular MIPS JALX major instruction opcode, the handling of which has been added with the said commit for EPC calculation in `__compute_return_epc_for_insn'. Fixes: fb6883e5809c ("MIPS: microMIPS: Support handling of delay slots.") Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/16394/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27MIPS: Save static registers before sysmipsJames Hogan
commit 49955d84cd9ccdca5a16a495e448e1a06fad9e49 upstream. The MIPS sysmips system call handler may return directly from the MIPS_ATOMIC_SET case (mips_atomic_set()) to syscall_exit. This path restores the static (callee saved) registers, however they won't have been saved on entry to the system call. Use the save_static_function() macro to create a __sys_sysmips wrapper function which saves the static registers before calling sys_sysmips, so that the correct static register state is restored by syscall_exit. Fixes: f1e39a4a616c ("MIPS: Rewrite sysmips(MIPS_ATOMIC_SET, ...) in C with inline assembler") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/16149/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27MIPS: Fix MIPS I ISA /proc/cpuinfo reportingMaciej W. Rozycki
commit e5f5a5b06e51a36f6ddf31a4a485358263953a3d upstream. Correct a commit 515a6393dbac ("MIPS: kernel: proc: Add MIPS R6 support to /proc/cpuinfo") regression that caused MIPS I systems to show no ISA levels supported in /proc/cpuinfo, e.g.: system type : Digital DECstation 2100/3100 machine : Unknown processor : 0 cpu model : R3000 V2.0 FPU V2.0 BogoMIPS : 10.69 wait instruction : no microsecond timers : no tlb_entries : 64 extra interrupt vector : no hardware watchpoint : no isa : ASEs implemented : shadow register sets : 1 kscratch registers : 0 package : 0 core : 0 VCED exceptions : not available VCEI exceptions : not available and similarly exclude `mips1' from the ISA list for any processors below MIPSr1. This is because the condition to show `mips1' on has been made `cpu_has_mips_r1' rather than newly-introduced `cpu_has_mips_1'. Use the correct condition then. Fixes: 515a6393dbac ("MIPS: kernel: proc: Add MIPS R6 support to /proc/cpuinfo") Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/16758/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27x86/ioapic: Pass the correct data to unmask_ioapic_irq()Seunghun Han
commit e708e35ba6d89ff785b225cd07dcccab04fa954a upstream. One of the rarely executed code pathes in check_timer() calls unmask_ioapic_irq() passing irq_get_chip_data(0) as argument. That's wrong as unmask_ioapic_irq() expects a pointer to the irq data of interrupt 0. irq_get_chip_data(0) returns NULL, so the following dereference in unmask_ioapic_irq() causes a kernel panic. The issue went unnoticed in the first place because irq_get_chip_data() returns a void pointer so the compiler cannot do a type check on the argument. The code path was added for machines with broken configuration, but it seems that those machines are either not running current kernels or simply do not longer exist. Hand in irq_get_irq_data(0) as argument which provides the correct data. [ tglx: Rewrote changelog ] Fixes: 4467715a44cc ("x86/irq: Move irq_cfg.irq_2_pin into io_apic.c") Signed-off-by: Seunghun Han <kkamagui@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1500369644-45767-1-git-send-email-kkamagui@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27x86/acpi: Prevent out of bound access caused by broken ACPI tablesSeunghun Han
commit dad5ab0db8deac535d03e3fe3d8f2892173fa6a4 upstream. The bus_irq argument of mp_override_legacy_irq() is used as the index into the isa_irq_to_gsi[] array. The bus_irq argument originates from ACPI_MADT_TYPE_IO_APIC and ACPI_MADT_TYPE_INTERRUPT items in the ACPI tables, but is nowhere sanity checked. That allows broken or malicious ACPI tables to overwrite memory, which might cause malfunction, panic or arbitrary code execution. Add a sanity check and emit a warning when that triggers. [ tglx: Added warning and rewrote changelog ] Signed-off-by: Seunghun Han <kkamagui@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: security@kernel.org Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27MIPS: Negate error syscall return in traceJames Hogan
commit 4f32a39d49b25eaa66d2420f1f03d371ea4cd906 upstream. The sys_exit trace event takes a single return value for the system call, which MIPS passes the value of the $v0 (result) register, however MIPS returns positive error codes in $v0 with $a3 specifying that $v0 contains an error code. As a result erroring system calls are traced returning positive error numbers that can't always be distinguished from success. Use regs_return_value() to negate the error code if $a3 is set. Fixes: 1d7bf993e073 ("MIPS: ftrace: Add support for syscall tracepoints.") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/16651/ Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27MIPS: Fix mips_atomic_set() with EVAJames Hogan
commit 4915e1b043d6286928207b1f6968197b50407294 upstream. EVA linked loads (LLE) and conditional stores (SCE) should be used on EVA kernels for the MIPS_ATOMIC_SET operation of the sysmips system call, or else the atomic set will apply to the kernel view of the virtual address space (potentially unmapped on EVA kernels) rather than the user view (TLB mapped). Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/16151/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27MIPS: Fix mips_atomic_set() retry conditionJames Hogan
commit 2ec420b26f7b6ff332393f0bb5a7d245f7ad87f0 upstream. The inline asm retry check in the MIPS_ATOMIC_SET operation of the sysmips system call has been backwards since commit f1e39a4a616c ("MIPS: Rewrite sysmips(MIPS_ATOMIC_SET, ...) in C with inline assembler") merged in v2.6.32, resulting in the non R10000_LLSC_WAR case retrying until the operation was inatomic, before returning the new value that was probably just written multiple times instead of the old value. Invert the branch condition to fix that particular issue. Fixes: f1e39a4a616c ("MIPS: Rewrite sysmips(MIPS_ATOMIC_SET, ...) in C with inline assembler") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/16148/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27s390/syscalls: Fix out of bounds arguments accessJiri Olsa
commit c46fc0424ced3fb71208e72bd597d91b9169a781 upstream. Zorro reported following crash while having enabled syscall tracing (CONFIG_FTRACE_SYSCALLS): Unable to handle kernel pointer dereference at virtual ... Oops: 0011 [#1] SMP DEBUG_PAGEALLOC SNIP Call Trace: ([<000000000024d79c>] ftrace_syscall_enter+0xec/0x1d8) [<00000000001099c6>] do_syscall_trace_enter+0x236/0x2f8 [<0000000000730f1c>] sysc_tracesys+0x1a/0x32 [<000003fffcf946a2>] 0x3fffcf946a2 INFO: lockdep is turned off. Last Breaking-Event-Address: [<000000000022dd44>] rb_event_data+0x34/0x40 ---[ end trace 8c795f86b1b3f7b9 ]--- The crash happens in syscall_get_arguments function for syscalls with zero arguments, that will try to access first argument (args[0]) in event entry, but it's not allocated. Bail out of there are no arguments. Reported-by: Zorro Lang <zlang@redhat.com> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27x86/xen: allow userspace access during hypercallsMarek Marczykowski-Górecki
commit c54590cac51db8ab5fd30156bdaba34af915e629 upstream. Userspace application can do a hypercall through /dev/xen/privcmd, and some for some hypercalls argument is a pointers to user-provided structure. When SMAP is supported and enabled, hypervisor can't access. So, lets allow it. The same applies to HYPERVISOR_dm_op, where additionally privcmd driver carefully verify buffer addresses. Cc: stable@vger.kernel.org Signed-off-by: Marek Marczykowski-Górecki <marmarek@invisiblethingslab.com> Reviewed-by: Juergen Gross <jgross@suse.com> [HYPERVISOR_dm_op dropped - not present until 4.11] Signed-off-by: Juergen Gross <jgross@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27powerpc/asm: Mark cr0 as clobbered in mftb()Oliver O'Halloran
commit 2400fd822f467cb4c886c879d8ad99feac9cf319 upstream. The workaround for the CELL timebase bug does not correctly mark cr0 as being clobbered. This means GCC doesn't know that the asm block changes cr0 and might leave the result of an unrelated comparison in cr0 across the block, which we then trash, leading to basically random behaviour. Fixes: 859deea949c3 ("[POWERPC] Cell timebase bug workaround") Signed-off-by: Oliver O'Halloran <oohall@gmail.com> [mpe: Tweak change log and flag for stable] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
