path: root/arch
2012-12-03ARM: OMAP: counter: add locking to read_persistent_clockColin Cross
commit 9d7d6e363b06934221b81a859d509844c97380df upstream. read_persistent_clock uses a global variable, use a spinlock to ensure non-atomic updates to the variable don't overlap and cause time to move backwards. Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: R Sricharan <r.sricharan@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03powerpc/eeh: Lock module while handling EEH eventGavin Shan
commit feadf7c0a1a7c08c74bebb4a13b755f8c40e3bbc upstream. The EEH core is talking with the PCI device driver to determine the action (purely reset, or PCI device removal). During the period, the driver might be unloaded and in turn causes kernel crash as follows: EEH: Detected PCI bus error on PHB#4-PE#10000 EEH: This PCI device has failed 3 times in the last hour lpfc 0004:01:00.0: 0:2710 PCI channel disable preparing for reset Unable to handle kernel paging request for data at address 0x00000490 Faulting instruction address: 0xd00000000e682c90 cpu 0x1: Vector: 300 (Data Access) at [c000000fc75ffa20] pc: d00000000e682c90: .lpfc_io_error_detected+0x30/0x240 [lpfc] lr: d00000000e682c8c: .lpfc_io_error_detected+0x2c/0x240 [lpfc] sp: c000000fc75ffca0 msr: 8000000000009032 dar: 490 dsisr: 40000000 current = 0xc000000fc79b88b0 paca = 0xc00000000edb0380 softe: 0 irq_happened: 0x00 pid = 3386, comm = eehd enter ? for help [c000000fc75ffca0] c000000fc75ffd30 (unreliable) [c000000fc75ffd30] c00000000004fd3c .eeh_report_error+0x7c/0xf0 [c000000fc75ffdc0] c00000000004ee00 .eeh_pe_dev_traverse+0xa0/0x180 [c000000fc75ffe70] c00000000004ffd8 .eeh_handle_event+0x68/0x300 [c000000fc75fff00] c0000000000503a0 .eeh_event_handler+0x130/0x1a0 [c000000fc75fff90] c000000000020138 .kernel_thread+0x54/0x70 1:mon> The patch increases the reference of the corresponding driver modules while EEH core does the negotiation with PCI device driver so that the corresponding driver modules can't be unloaded during the period and we're safe to refer the callbacks. Reported-by: Alexey Kardashevskiy <aik@ozlabs.ru> Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [ herton: backported for 3.5, adjusted driver assignments, return 0 instead of NULL, assume dev is not NULL ] Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03KVM: x86: invalid opcode oops on SET_SREGS with OSXSAVE bit set (CVE-2012-4461)Petr Matousek
commit 6d1068b3a98519247d8ba4ec85cd40ac136dbdf9 upstream. On hosts without the XSAVE support unprivileged local user can trigger oops similar to the one below by setting X86_CR4_OSXSAVE bit in guest cr4 register using KVM_SET_SREGS ioctl and later issuing KVM_RUN ioctl. invalid opcode: 0000 [#2] SMP Modules linked in: tun ip6table_filter ip6_tables ebtable_nat ebtables ... Pid: 24935, comm: zoog_kvm_monito Tainted: G D 3.2.0-3-686-pae EIP: 0060:[<f8b9550c>] EFLAGS: 00210246 CPU: 0 EIP is at kvm_arch_vcpu_ioctl_run+0x92a/0xd13 [kvm] EAX: 00000001 EBX: 000f387e ECX: 00000000 EDX: 00000000 ESI: 00000000 EDI: 00000000 EBP: ef5a0060 ESP: d7c63e70 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 Process zoog_kvm_monito (pid: 24935, ti=d7c62000 task=ed84a0c0 task.ti=d7c62000) Stack: 00000001 f70a1200 f8b940a9 ef5a0060 00000000 00200202 f8769009 00000000 ef5a0060 000f387e eda5c020 8722f9c8 00015bae 00000000 ed84a0c0 ed84a0c0 c12bf02d 0000ae80 ef7f8740 fffffffb f359b740 ef5a0060 f8b85dc1 0000ae80 Call Trace: [<f8b940a9>] ? kvm_arch_vcpu_ioctl_set_sregs+0x2fe/0x308 [kvm] ... [<c12bfb44>] ? syscall_call+0x7/0xb Code: 89 e8 e8 14 ee ff ff ba 00 00 04 00 89 e8 e8 98 48 ff ff 85 c0 74 1e 83 7d 48 00 75 18 8b 85 08 07 00 00 31 c9 8b 95 0c 07 00 00 <0f> 01 d1 c7 45 48 01 00 00 00 c7 45 1c 01 00 00 00 0f ae f0 89 EIP: [<f8b9550c>] kvm_arch_vcpu_ioctl_run+0x92a/0xd13 [kvm] SS:ESP 0068:d7c63e70 QEMU first retrieves the supported features via KVM_GET_SUPPORTED_CPUID and then sets them later. So guest's X86_FEATURE_XSAVE should be masked out on hosts without X86_FEATURE_XSAVE, making kvm_set_cr4 with X86_CR4_OSXSAVE fail. Userspaces that allow specifying guest cpuid with X86_FEATURE_XSAVE even on hosts that do not support it, might be susceptible to this attack from inside the guest as well. Allow setting X86_CR4_OSXSAVE bit only if host has XSAVE support. Signed-off-by: Petr Matousek <pmatouse@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03sparc64: not any error from do_sigaltstack() should fail rt_sigreturn()Al Viro
commit fae2ae2a900a5c7bb385fe4075f343e7e2d5daa2 upstream. If a signal handler is executed on altstack and another signal comes, we will end up with rt_sigreturn() on return from the second handler getting -EPERM from do_sigaltstack(). It's perfectly OK, since we are not asking to change the settings; in fact, they couldn't have been changed during the second handler execution exactly because we'd been on altstack all along. 64bit sigreturn on sparc treats any error from do_sigaltstack() as "SIGSEGV now"; we need to switch to the same semantics we are using on other architectures. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03PARISC: fix user-triggerable panic on pariscAl Viro
commit 441a179dafc0f99fc8b3a8268eef66958621082e upstream. int sys32_rt_sigprocmask(int how, compat_sigset_t __user *set, compat_sigset_t __user *oset, unsigned int sigsetsize) { sigset_t old_set, new_set; int ret; if (set && get_sigset32(set, &new_set, sigsetsize)) ... static int get_sigset32(compat_sigset_t __user *up, sigset_t *set, size_t sz) { compat_sigset_t s; int r; if (sz != sizeof *set) panic("put_sigset32()"); In other words, rt_sigprocmask(69, (void *)69, 69) done by 32bit process will promptly panic the box. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03PARISC: fix virtual aliasing issue in get_shared_area()James Bottomley
commit 949a05d03490e39e773e8652ccab9157e6f595b4 upstream. On Thu, 2012-11-01 at 16:45 -0700, Michel Lespinasse wrote: > Looking at the arch/parisc/kernel/sys_parisc.c implementation of > get_shared_area(), I do have a concern though. The function basically > ignores the pgoff argument, so that if one creates a shared mapping of > pages 0-N of a file, and then a separate shared mapping of pages 1-N > of that same file, both will have the same cache offset for their > starting address. > > This looks like this would create obvious aliasing issues. Am I > misreading this ? I can't understand how this could work good enough > to be undetected, so there must be something I'm missing here ??? This turns out to be correct and we need to pay attention to the pgoff as well as the address when creating the virtual address for the area. Fortunately, the bug is rarely triggered as most applications which use pgoff tend to use large values (git being the primary one, and it uses pgoff in multiples of 16MB) which are larger than our cache coherency modulus, so the problem isn't often seen in practise. Reported-by: Michel Lespinasse <walken@google.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03x86, microcode, AMD: Add support for family 16h processorsBoris Ostrovsky
commit 36c46ca4f322a7bf89aad5462a3a1f61713edce7 upstream. Add valid patch size for family 16h processors. [ hpa: promoting to urgent/stable since it is hw enabling and trivial ] Signed-off-by: Boris Ostrovsky <boris.ostrovsky@amd.com> Acked-by: Andreas Herrmann <herrmann.der.user@googlemail.com> Link: http://lkml.kernel.org/r/1353004910-2204-1-git-send-email-boris.ostrovsky@amd.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03x86, efi: Fix processor-specific memcpy() build errorMatt Fleming
commit 0f905a43ce955b638139bd84486194770a6a2c08 upstream. Building for Athlon/Duron/K7 results in the following build error, arch/x86/boot/compressed/eboot.o: In function `__constant_memcpy3d': eboot.c:(.text+0x385): undefined reference to `_mmx_memcpy' arch/x86/boot/compressed/eboot.o: In function `efi_main': eboot.c:(.text+0x1a22): undefined reference to `_mmx_memcpy' because the boot stub code doesn't link with the kernel proper, and therefore doesn't have access to the 3DNow version of memcpy. So, follow the example of misc.c and #undef memcpy so that we use the version provided by misc.c. See https://bugzilla.kernel.org/show_bug.cgi?id=50391 Reported-by: Al Viro <viro@zeniv.linux.org.uk> Reported-by: Ryan Underwood <nemesis@icequake.net> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03x86-32: Fix invalid stack address while in softirqRobert Richter
commit 1022623842cb72ee4d0dbf02f6937f38c92c3f41 upstream. In 32 bit the stack address provided by kernel_stack_pointer() may point to an invalid range causing NULL pointer access or page faults while in NMI (see trace below). This happens if called in softirq context and if the stack is empty. The address at &regs->sp is then out of range. Fixing this by checking if regs and &regs->sp are in the same stack context. Otherwise return the previous stack pointer stored in struct thread_info. If that address is invalid too, return address of regs. BUG: unable to handle kernel NULL pointer dereference at 0000000a IP: [<c1004237>] print_context_stack+0x6e/0x8d *pde = 00000000 Oops: 0000 [#1] SMP Modules linked in: Pid: 4434, comm: perl Not tainted 3.6.0-rc3-oprofile-i386-standard-g4411a05 #4 Hewlett-Packard HP xw9400 Workstation/0A1Ch EIP: 0060:[<c1004237>] EFLAGS: 00010093 CPU: 0 EIP is at print_context_stack+0x6e/0x8d EAX: ffffe000 EBX: 0000000a ECX: f4435f94 EDX: 0000000a ESI: f4435f94 EDI: f4435f94 EBP: f5409ec0 ESP: f5409ea0 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 CR0: 8005003b CR2: 0000000a CR3: 34ac9000 CR4: 000007d0 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: ffff0ff0 DR7: 00000400 Process perl (pid: 4434, ti=f5408000 task=f5637850 task.ti=f4434000) Stack: 000003e8 ffffe000 00001ffc f4e39b00 00000000 0000000a f4435f94 c155198c f5409ef0 c1003723 c155198c f5409f04 00000000 f5409edc 00000000 00000000 f5409ee8 f4435f94 f5409fc4 00000001 f5409f1c c12dce1c 00000000 c155198c Call Trace: [<c1003723>] dump_trace+0x7b/0xa1 [<c12dce1c>] x86_backtrace+0x40/0x88 [<c12db712>] ? oprofile_add_sample+0x56/0x84 [<c12db731>] oprofile_add_sample+0x75/0x84 [<c12ddb5b>] op_amd_check_ctrs+0x46/0x260 [<c12dd40d>] profile_exceptions_notify+0x23/0x4c [<c1395034>] nmi_handle+0x31/0x4a [<c1029dc5>] ? ftrace_define_fields_irq_handler_entry+0x45/0x45 [<c13950ed>] do_nmi+0xa0/0x2ff [<c1029dc5>] ? ftrace_define_fields_irq_handler_entry+0x45/0x45 [<c13949e5>] nmi_stack_correct+0x28/0x2d [<c1029dc5>] ? ftrace_define_fields_irq_handler_entry+0x45/0x45 [<c1003603>] ? do_softirq+0x4b/0x7f <IRQ> [<c102a06f>] irq_exit+0x35/0x5b [<c1018f56>] smp_apic_timer_interrupt+0x6c/0x7a [<c1394746>] apic_timer_interrupt+0x2a/0x30 Code: 89 fe eb 08 31 c9 8b 45 0c ff 55 ec 83 c3 04 83 7d 10 00 74 0c 3b 5d 10 73 26 3b 5d e4 73 0c eb 1f 3b 5d f0 76 1a 3b 5d e8 73 15 <8b> 13 89 d0 89 55 e0 e8 ad 42 03 00 85 c0 8b 55 e0 75 a6 eb cc EIP: [<c1004237>] print_context_stack+0x6e/0x8d SS:ESP 0068:f5409ea0 CR2: 000000000000000a ---[ end trace 62afee3481b00012 ]--- Kernel panic - not syncing: Fatal exception in interrupt V2: * add comments to kernel_stack_pointer() * always return a valid stack address by falling back to the address of regs Reported-by: Yang Wei <wei.yang@windriver.com> Signed-off-by: Robert Richter <robert.richter@amd.com> Link: http://lkml.kernel.org/r/20120912135059.GZ8285@erda.amd.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Jun Zhang <jun.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26Revert "serial: omap: fix software flow control"Felipe Balbi
commit a4f743851f74fc3e0cc40c13082e65c24139f481 upstream. This reverts commit 957ee7270d632245b43f6feb0e70d9a5e9ea6cf6 (serial: omap: fix software flow control). As Russell has pointed out, that commit isn't fixing Software Flow Control at all, and it actually makes it even more broken. It was agreed to revert this commit and use Russell's latest UART patches instead. Signed-off-by: Felipe Balbi <balbi@ti.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26s390/signal: set correct address space controlMartin Schwidefsky
commit fa968ee215c0ca91e4a9c3a69ac2405aae6e5d2f upstream. If user space is running in primary mode it can switch to secondary or access register mode, this is used e.g. in the clock_gettime code of the vdso. If a signal is delivered to the user space process while it has been running in access register mode the signal handler is executed in access register mode as well which will result in a crash most of the time. Set the address space control bits in the PSW to the default for the execution of the signal handler and make sure that the previous address space control is restored on signal return. Take care that user space can not switch to the kernel address space by modifying the registers in the signal frame. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26m68k: fix sigset_t accessor functionsAndreas Schwab
commit 34fa78b59c52d1db3513db4c1a999db26b2e9ac2 upstream. The sigaddset/sigdelset/sigismember functions that are implemented with bitfield insn cannot allow the sigset argument to be placed in a data register since the sigset is wider than 32 bits. Remove the "d" constraint from the asm statements. The effect of the bug is that sending RT signals does not work, the signal number is truncated modulo 32. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26s390/gup: add missing TASK_SIZE check to get_user_pages_fast()Heiko Carstens
commit d55c4c613fc4d4ad2ba0fc6fa2b57176d420f7e4 upstream. When walking page tables we need to make sure that everything is within bounds of the ASCE limit of the task's address space. Otherwise we might calculate e.g. a pud pointer which is not within a pud and dereference it. So check against TASK_SIZE (which is the ASCE limit) before walking page tables. Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-17xen/mmu: Use Xen specific TLB flush instead of the generic one.Konrad Rzeszutek Wilk
commit 95a7d76897c1e7243d4137037c66d15cbf2cce76 upstream. As Mukesh explained it, the MMUEXT_TLB_FLUSH_ALL allows the hypervisor to do a TLB flush on all active vCPUs. If instead we were using the generic one (which ends up being xen_flush_tlb) we end up making the MMUEXT_TLB_FLUSH_LOCAL hypercall. But before we make that hypercall the kernel will IPI all of the vCPUs (even those that were asleep from the hypervisor perspective). The end result is that we needlessly wake them up and do a TLB flush when we can just let the hypervisor do it correctly. This patch gives around 50% speed improvement when migrating idle guest's from one host to another. Oracle-bug: 14630170 Tested-by: Jingjie Jiang <jingjie.jiang@oracle.com> Suggested-by: Mukesh Rathor <mukesh.rathor@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-05Revert: ARM: SAMSUNG: Add naming of s3c64xx-spi devicesGreg Kroah-Hartman
This reverts commit baa526f45d3f096a1cd9f14b668203a03bbab6f9, which is commit 308b3afb97dc342e9c4f958d8b4c459ae0e22bd7 upstream. To quote Colin Cross: This patch breaks Exynos5 spi on 3.4.17. The patch with the bug that this patch was supposed to address went in to 3.6 and not 3.4, so this patch causes a driver name mismatch when applied to 3.4. Cc: Colin Cross <ccross@google.com> Cc: Heiko Stuebner <heiko@sntech.de> Cc: Sylwester Nawrocki <s.nawrocki@samsung.com> Cc: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31x86, mm: Use memblock memory loop instead of e820_RAMYinghai Lu
commit 1f2ff682ac951ed82cc043cf140d2851084512df upstream. We need to handle E820_RAM and E820_RESERVED_KERNEL at the same time. Also memblock has page aligned range for ram, so we could avoid mapping partial pages. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/CAE9FiQVZirvaBMFYRfXMmWEcHbKSicQEHz4VAwUv0xFCk51ZNw@mail.gmail.com Acked-by: Jacob Shin <jacob.shin@amd.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31x86: efi: Turn off efi_enabled after setup on mixed fw/kernelOlof Johansson
commit 5189c2a7c7769ee9d037d76c1a7b8550ccf3481c upstream. When 32-bit EFI is used with 64-bit kernel (or vice versa), turn off efi_enabled once setup is done. Beyond setup, it is normally used to determine if runtime services are available and we will have none. This will resolve issues stemming from efivars modprobe panicking on a 32/64-bit setup, as well as some reboot issues on similar setups. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=45991 Reported-by: Marko Kohtala <marko.kohtala@gmail.com> Reported-by: Maxim Kammerer <mk@dee.su> Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31efi: Defer freeing boot services memory until after ACPI initJosh Triplett
commit 785107923a83d8456bbd8564e288a24d84109a46 upstream. Some new ACPI 5.0 tables reference resources stored in boot services memory, so keep that memory around until we have ACPI and can extract data from it. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Link: http://lkml.kernel.org/r/baaa6d44bdc4eb0c58e5d1b4ccd2c729f854ac55.1348876882.git.josh@joshtriplett.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Matt Fleming <matt@console-pimps.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31x86, mm: Undo incorrect revert in arch/x86/mm/init.cYinghai Lu
commit f82f64dd9f485e13f29f369772d4a0e868e5633a upstream. Commit 844ab6f9 x86, mm: Find_early_table_space based on ranges that are actually being mapped added back some lines back wrongly that has been removed in commit 7b16bbf97 Revert "x86/mm: Fix the size calculation of mapping tables" remove them again. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/CAE9FiQW_vuaYQbmagVnxT2DGsYc=9tNeAbdBq53sYkitPOwxSQ@mail.gmail.com Acked-by: Jacob Shin <jacob.shin@amd.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31x86, mm: Find_early_table_space based on ranges that are actually being mappedJacob Shin
commit 844ab6f993b1d32eb40512503d35ff6ad0c57030 upstream. Current logic finds enough space for direct mapping page tables from 0 to end. Instead, we only need to find enough space to cover mr[0].start to mr[nr_range].end -- the range that is actually being mapped by init_memory_mapping() This is needed after 1bbbbe779aabe1f0768c2bf8f8c0a5583679b54a, to address the panic reported here: https://lkml.org/lkml/2012/10/20/160 https://lkml.org/lkml/2012/10/21/157 Signed-off-by: Jacob Shin <jacob.shin@amd.com> Link: http://lkml.kernel.org/r/20121024195311.GB11779@jshin-Toonie Tested-by: Tom Rini <trini@ti.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31ARM: at91: at91sam9g10: fix SOC type detectionIvan Shugov
commit 3d9a0183dd3423353e9e363bcc261c1220d05f9f upstream. Newer at91sam9g10 SoC revision can't be detected, so the kernel can't boot with this kind of kernel panic: "AT91: Impossible to detect the SOC type" CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: Atmel AT91SAM9G10-EK Ignoring tag cmdline (using the default kernel command line) bootconsole [earlycon0] enabled Memory policy: ECC disabled, Data cache writeback Kernel panic - not syncing: AT91: Impossible to detect the SOC type [<c00133d4>] (unwind_backtrace+0x0/0xe0) from [<c02366dc>] (panic+0x78/0x1cc) [<c02366dc>] (panic+0x78/0x1cc) from [<c02fa35c>] (at91_map_io+0x90/0xc8) [<c02fa35c>] (at91_map_io+0x90/0xc8) from [<c02f9860>] (paging_init+0x564/0x6d0) [<c02f9860>] (paging_init+0x564/0x6d0) from [<c02f7914>] (setup_arch+0x464/0x704) [<c02f7914>] (setup_arch+0x464/0x704) from [<c02f44f8>] (start_kernel+0x6c/0x2d4) [<c02f44f8>] (start_kernel+0x6c/0x2d4) from [<20008040>] (0x20008040) The reason for this is that the Debug Unit Chip ID Register has changed between Engineering Sample and definitive revision of the SoC. Changing the check of cidr to socid will address the problem. We do not integrate this check to the list just above because we also have to make sure that the extended id is disregarded. Signed-off-by: Ivan Shugov <ivan.shugov@gmail.com> [nicolas.ferre@atmel.com: change commit message] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31ARM: at91/i2c: change id to let i2c-gpio workBo Shen
commit 7840487cd6298f9f931103b558290d8d98d41c49 upstream. The i2c core driver will turn the platform device ID to busnum When using platfrom device ID as -1, it means dynamically assigned the busnum. When writing code, we need to make sure the busnum, and call i2c_register_board_info(int busnum, ...) to register device if using -1, we do not know the value of busnum In order to solve this issue, set the platform device ID as a fix number Here using 0 to match the busnum used in i2c_regsiter_board_info() Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31ARM: SAMSUNG: Add naming of s3c64xx-spi devicesHeiko Stuebner
commit 308b3afb97dc342e9c4f958d8b4c459ae0e22bd7 upstream. Commit a5238e360b71 (spi: s3c64xx: move controller information into driver data) introduced separate device names for the different subtypes of the spi controller but forgot to set these in the relevant machines. To fix this introduce a s3c64xx_spi_setname function and populate all Samsung arches with the correct names. The function resides in a new header, as the s3c64xx-spi.h contains driver platform data and should therefore at some later point move out of the Samsung include dir. Tested on a s3c2416-based machine. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> [s.nawrocki@samsung.com: tested on mach-exynos] Tested-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31x86, mm: Trim memory in memblock to be page alignedYinghai Lu
commit 6ede1fd3cb404c0016de6ac529df46d561bd558b upstream. We will not map partial pages, so need to make sure memblock allocation will not allocate those bytes out. Also we will use for_each_mem_pfn_range() to loop to map memory range to keep them consistent. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/CAE9FiQVZirvaBMFYRfXMmWEcHbKSicQEHz4VAwUv0xFCk51ZNw@mail.gmail.com Acked-by: Jacob Shin <jacob.shin@amd.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31ARM: 7559/1: smp: switch away from the idmap before updating init_mm.mm_countWill Deacon
commit 5f40b909728ad784eb43aa309d3c4e9bdf050781 upstream. When booting a secondary CPU, the primary CPU hands two sets of page tables via the secondary_data struct: (1) swapper_pg_dir: a normal, cacheable, shared (if SMP) mapping of the kernel image (i.e. the tables used by init_mm). (2) idmap_pgd: an uncached mapping of the .idmap.text ELF section. The idmap is generally used when enabling and disabling the MMU, which includes early CPU boot. In this case, the secondary CPU switches to swapper as soon as it enters C code: struct mm_struct *mm = &init_mm; unsigned int cpu = smp_processor_id(); /* * All kernel threads share the same mm context; grab a * reference and switch to it. */ atomic_inc(&mm->mm_count); current->active_mm = mm; cpumask_set_cpu(cpu, mm_cpumask(mm)); cpu_switch_mm(mm->pgd, mm); This causes a problem on ARMv7, where the identity mapping is treated as strongly-ordered leading to architecturally UNPREDICTABLE behaviour of exclusive accesses, such as those used by atomic_inc. This patch re-orders the secondary_start_kernel function so that we switch to swapper before performing any exclusive accesses. Reported-by: Gilles Chanteperdrix <gilles.chanteperdrix@xenomai.org> Cc: David McKay <david.mckay@st.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28sparc64: Be less verbose during vmemmap population.David S. Miller
[ Upstream commit 2856cc2e4d0852c3ddaae9dcb19cb9396512eb08 ] On a 2-node machine with 256GB of ram we get 512 lines of console output, which is just too much. This mimicks Yinghai Lu's x86 commit c2b91e2eec9678dbda274e906cc32ea8f711da3b (x86_64/mm: check and print vmemmap allocation continuous) except that we aren't ever going to get contiguous block pointers in between calls so just print when the virtual address or node changes. This decreases the output by an order of 16. Also demote this to KERN_DEBUG. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28sparc64: do not clobber personality flags in sys_sparc64_personality()Jiri Kosina
[ Upstream commit a27032eee8cb6e16516f13c8a9752e9d5d4cc430 ] There are multiple errors in how sys_sparc64_personality() handles personality flags stored in top three bytes. - directly comparing current->personality against PER_LINUX32 doesn't work in cases when any of the personality flags stored in the top three bytes are used. - directly forcefully setting personality to PER_LINUX32 or PER_LINUX discards any flags stored in the top three bytes Fix the first one by properly using personality() macro to compare only PER_MASK bytes. Fix the second one by setting only the bits that should be set, instead of overwriting the whole value. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28sparc64: Fix bit twiddling in sparc_pmu_enable_event().David S. Miller
[ Upstream commit e793d8c6740f8fe704fa216e95685f4d92c4c4b9 ] There was a serious disconnect in the logic happening in sparc_pmu_disable_event() vs. sparc_pmu_enable_event(). Event disable is implemented by programming a NOP event into the PCR. However, event enable was not reversing this operation. Instead, it was setting the User/Priv/Hypervisor trace enable bits. That's not sparc_pmu_enable_event()'s job, that's what sparc_pmu_enable() and sparc_pmu_disable() do . The intent of sparc_pmu_enable_event() is clear, since it first clear out the event type encoding field. So fix this by OR'ing in the event encoding rather than the trace enable bits. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28sparc64: Like x86 we should check current->mm during perf backtrace generation.David S. Miller
[ Upstream commit 08280e6c4c2e8049ac61d9e8e3536ec1df629c0d ] If the MM is not active, only report the top-level PC. Do not try to access the address space. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28sparc64: fix ptrace interaction with force_successful_syscall_return()Al Viro
[ Upstream commit 55c2770e413e96871147b9406a9c41fe9bc5209c ] we want syscall_trace_leave() called on exit from any syscall; skipping its call in case we'd done force_successful_syscall_return() is broken... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28xen/x86: don't corrupt %eip when returning from a signal handlerDavid Vrabel
commit a349e23d1cf746f8bdc603dcc61fae9ee4a695f6 upstream. In 32 bit guests, if a userspace process has %eax == -ERESTARTSYS (-512) or -ERESTARTNOINTR (-513) when it is interrupted by an event /and/ the process has a pending signal then %eip (and %eax) are corrupted when returning to the main process after handling the signal. The application may then crash with SIGSEGV or a SIGILL or it may have subtly incorrect behaviour (depending on what instruction it returned to). The occurs because handle_signal() is incorrectly thinking that there is a system call that needs to restarted so it adjusts %eip and %eax to re-execute the system call instruction (even though user space had not done a system call). If %eax == -514 (-ERESTARTNOHAND (-514) or -ERESTART_RESTARTBLOCK (-516) then handle_signal() only corrupted %eax (by setting it to -EINTR). This may cause the application to crash or have incorrect behaviour. handle_signal() assumes that regs->orig_ax >= 0 means a system call so any kernel entry point that is not for a system call must push a negative value for orig_ax. For example, for physical interrupts on bare metal the inverse of the vector is pushed and page_fault() sets regs->orig_ax to -1, overwriting the hardware provided error code. xen_hypervisor_callback() was incorrectly pushing 0 for orig_ax instead of -1. Classic Xen kernels pushed %eax which works as %eax cannot be both non-negative and -RESTARTSYS (etc.), but using -1 is consistent with other non-system call entry points and avoids some of the tests in handle_signal(). There were similar bugs in xen_failsafe_callback() of both 32 and 64-bit guests. If the fault was corrected and the normal return path was used then 0 was incorrectly pushed as the value for orig_ax. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Acked-by: Jan Beulich <JBeulich@suse.com> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28x86: Exclude E820_RESERVED regions and memory holes above 4 GB from direct ↵Jacob Shin
mapping. commit 1bbbbe779aabe1f0768c2bf8f8c0a5583679b54a upstream. On systems with very large memory (1 TB in our case), BIOS may report a reserved region or a hole in the E820 map, even above the 4 GB range. Exclude these from the direct mapping. [ hpa: this should be done not just for > 4 GB but for everything above the legacy region (1 MB), at the very least. That, however, turns out to require significant restructuring. That work is well underway, but is not suitable for rc/stable. ] Signed-off-by: Jacob Shin <jacob.shin@amd.com> Link: http://lkml.kernel.org/r/1319145326-13902-1-git-send-email-jacob.shin@amd.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28s390: fix linker script for 31 bit buildsHeiko Carstens
commit c985cb37f1b39c2c8035af741a2a0b79f1fbaca7 upstream. Because of a change in the s390 arch backend of binutils (commit 23ecd77 "Pick the default arch depending on the target size" in binutils repo) 31 bit builds will fail since the linker would now try to create 64 bit binary output. Fix this by setting OUTPUT_ARCH to s390:31-bit instead of s390. Thanks to Andreas Krebbel for figuring out the issue. Fixes this build error: LD init/built-in.o s390x-4.7.2-ld: s390:31-bit architecture of input file `arch/s390/kernel/head.o' is incompatible with s390:64-bit output Cc: Andreas Krebbel <Andreas.Krebbel@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28oprofile, x86: Fix wrapping bug in op_x86_get_ctrl()Dan Carpenter
commit 44009105081b51417f311f4c3be0061870b6b8ed upstream. The "event" variable is a u16 so the shift will always wrap to zero making the line a no-op. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28arch/tile: avoid generating .eh_frame information in modulesChris Metcalf
commit 627072b06c362bbe7dc256f618aaa63351f0cfe6 upstream. The tile tool chain uses the .eh_frame information for backtracing. The vmlinux build drops any .eh_frame sections at link time, but when present in kernel modules, it causes a module load failure due to the presence of unsupported pc-relative relocations. When compiling to use compiler feedback support, the compiler by default omits .eh_frame information, so we don't see this problem. But when not using feedback, we need to explicitly suppress the .eh_frame. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21xen/bootup: allow read_tscp call for Xen PV guests.Konrad Rzeszutek Wilk
commit cd0608e71e9757f4dae35bcfb4e88f4d1a03a8ab upstream. The hypervisor will trap it. However without this patch, we would crash as the .read_tscp is set to NULL. This patch fixes it and sets it to the native_read_tscp call. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21xen/bootup: allow {read|write}_cr8 pvops call.Konrad Rzeszutek Wilk
commit 1a7bbda5b1ab0e02622761305a32dc38735b90b2 upstream. We actually do not do anything about it. Just return a default value of zero and if the kernel tries to write anything but 0 we BUG_ON. This fixes the case when an user tries to suspend the machine and it blows up in save_processor_state b/c 'read_cr8' is set to NULL and we get: kernel BUG at /home/konrad/ssd/linux/arch/x86/include/asm/paravirt.h:100! invalid opcode: 0000 [#1] SMP Pid: 2687, comm: init.late Tainted: G O 3.6.0upstream-00002-gac264ac-dirty #4 Bochs Bochs RIP: e030:[<ffffffff814d5f42>] [<ffffffff814d5f42>] save_processor_state+0x212/0x270 .. snip.. Call Trace: [<ffffffff810733bf>] do_suspend_lowlevel+0xf/0xac [<ffffffff8107330c>] ? x86_acpi_suspend_lowlevel+0x10c/0x150 [<ffffffff81342ee2>] acpi_suspend_enter+0x57/0xd5 Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21ARM: 7541/1: Add ARM ERRATA 775420 workaroundSimon Horman
commit 7253b85cc62d6ff84143d96fe6cd54f73736f4d7 upstream. arm: Add ARM ERRATA 775420 workaround Workaround for the 775420 Cortex-A9 (r2p2, r2p6,r2p8,r2p10,r3p0) erratum. In case a date cache maintenance operation aborts with MMU exception, it might cause the processor to deadlock. This workaround puts DSB before executing ISB if an abort may occur on cache maintenance. Based on work by Kouei Abe and feedback from Catalin Marinas. Signed-off-by: Kouei Abe <kouei.abe.cp@rms.renesas.com> [ horms@verge.net.au: Changed to implementation suggested by catalin.marinas@arm.com ] Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21mips,kgdb: fix recursive page fault with CONFIG_KPROBESJason Wessel
commit f0a996eeeda214f4293e234df33b29bec003b536 upstream. This fault was detected using the kgdb test suite on boot and it crashes recursively due to the fact that CONFIG_KPROBES on mips adds an extra die notifier in the page fault handler. The crash signature looks like this: kgdbts:RUN bad memory access test KGDB: re-enter exception: ALL breakpoints killed Call Trace: [<807b7548>] dump_stack+0x20/0x54 [<807b7548>] dump_stack+0x20/0x54 The fix for now is to have kgdb return immediately if the fault type is DIE_PAGE_FAULT and allow the kprobe code to decide what is supposed to happen. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21ARM: vfp: fix saving d16-d31 vfp registers on v6+ kernelsRussell King
commit 846a136881b8f73c1f74250bf6acfaa309cab1f2 upstream. Michael Olbrich reported that his test program fails when built with -O2 -mcpu=cortex-a8 -mfpu=neon, and a kernel which supports v6 and v7 CPUs: volatile int x = 2; volatile int64_t y = 2; int main() { volatile int a = 0; volatile int64_t b = 0; while (1) { a = (a + x) % (1 << 30); b = (b + y) % (1 << 30); assert(a == b); } } and two instances are run. When built for just v7 CPUs, this program works fine. It uses the "vadd.i64 d19, d18, d16" VFP instruction. It appears that we do not save the high-16 double VFP registers across context switches when the kernel is built for v6 CPUs. Fix that. Tested-By: Michael Olbrich <m.olbrich@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13efi: initialize efi.runtime_version to make ↵Seiji Aguchi
query_variable_info/update_capsule workable commit d6cf86d8f23253225fe2a763d627ecf7dfee9dae upstream. A value of efi.runtime_version is checked before calling update_capsule()/query_variable_info() as follows. But it isn't initialized anywhere. <snip> static efi_status_t virt_efi_query_variable_info(u32 attr, u64 *storage_space, u64 *remaining_space, u64 *max_variable_size) { if (efi.runtime_version < EFI_2_00_SYSTEM_TABLE_REVISION) return EFI_UNSUPPORTED; <snip> This patch initializes a value of efi.runtime_version at boot time. Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com> Acked-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Ivan Hu <ivan.hu@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13efi: Build EFI stub with EFI-appropriate optionsMatthew Garrett
commit 9dead5bbb825d7c25c0400e61de83075046322d0 upstream. We can't assume the presence of the red zone while we're still in a boot services environment, so we should build with -fno-red-zone to avoid problems. Change the size of wchar at the same time to make string handling simpler. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Acked-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13score: Add missing RCU idle APIs on idle loopFrederic Weisbecker
commit 0ee23fda59740767324b4340247ca41a2f498ca6 upstream. In the old times, the whole idle task was considered as an RCU quiescent state. But as RCU became more and more successful overtime, some RCU read side critical section have been added even in the code of some architectures idle tasks, for tracing for example. So nowadays, rcu_idle_enter() and rcu_idle_exit() must be called by the architecture to tell RCU about the part in the idle loop that doesn't make use of rcu read side critical sections, typically the part that puts the CPU in low power mode. This is necessary for RCU to find the quiescent states in idle in order to complete grace periods. Add this missing pair of calls in scores's idle loop. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13m32r: Add missing RCU idle APIs on idle loopFrederic Weisbecker
commit 48ae077cfce72591b8fc80e1dcc87806f86fed7f upstream. In the old times, the whole idle task was considered as an RCU quiescent state. But as RCU became more and more successful overtime, some RCU read side critical section have been added even in the code of some architectures idle tasks, for tracing for example. So nowadays, rcu_idle_enter() and rcu_idle_exit() must be called by the architecture to tell RCU about the part in the idle loop that doesn't make use of rcu read side critical sections, typically the part that puts the CPU in low power mode. This is necessary for RCU to find the quiescent states in idle in order to complete grace periods. Add this missing pair of calls in the m32r's idle loop. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13cris: Add missing RCU idle APIs on idle loopFrederic Weisbecker
commit c633f9e788928e91ad11f44df29b47bbbe9550b0 upstream. In the old times, the whole idle task was considered as an RCU quiescent state. But as RCU became more and more successful overtime, some RCU read side critical section have been added even in the code of some architectures idle tasks, for tracing for example. So nowadays, rcu_idle_enter() and rcu_idle_exit() must be called by the architecture to tell RCU about the part in the idle loop that doesn't make use of rcu read side critical sections, typically the part that puts the CPU in low power mode. This is necessary for RCU to find the quiescent states in idle in order to complete grace periods. Add this missing pair of calls in the Cris's idle loop. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Cris <linux-cris-kernel@axis.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13alpha: Add missing RCU idle APIs on idle loopFrederic Weisbecker
commit 4c94cada48f7c660eca582be6032427a5e367117 upstream. In the old times, the whole idle task was considered as an RCU quiescent state. But as RCU became more and more successful overtime, some RCU read side critical section have been added even in the code of some architectures idle tasks, for tracing for example. So nowadays, rcu_idle_enter() and rcu_idle_exit() must be called by the architecture to tell RCU about the part in the idle loop that doesn't make use of rcu read side critical sections, typically the part that puts the CPU in low power mode. This is necessary for RCU to find the quiescent states in idle in order to complete grace periods. Add this missing pair of calls in the Alpha's idle loop. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Michael Cree <mcree@orcon.net.nz> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: alpha <linux-alpha@vger.kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13m68k: Add missing RCU idle APIs on idle loopFrederic Weisbecker
commit 5b57ba37e82a15f345a6a2eb8c01a2b2d94c5eeb upstream. In the old times, the whole idle task was considered as an RCU quiescent state. But as RCU became more and more successful overtime, some RCU read side critical section have been added even in the code of some architectures idle tasks, for tracing for example. So nowadays, rcu_idle_enter() and rcu_idle_exit() must be called by the architecture to tell RCU about the part in the idle loop that doesn't make use of rcu read side critical sections, typically the part that puts the CPU in low power mode. This is necessary for RCU to find the quiescent states in idle in order to complete grace periods. Add this missing pair of calls in the m68k's idle loop. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: m68k <linux-m68k@lists.linux-m68k.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mn10300: Add missing RCU idle APIs on idle loopFrederic Weisbecker
commit 5b0753a90b7a98bc613c3767e9263a1a76d4f900 upstream. In the old times, the whole idle task was considered as an RCU quiescent state. But as RCU became more and more successful overtime, some RCU read side critical section have been added even in the code of some architectures idle tasks, for tracing for example. So nowadays, rcu_idle_enter() and rcu_idle_exit() must be called by the architecture to tell RCU about the part in the idle loop that doesn't make use of rcu read side critical sections, typically the part that puts the CPU in low power mode. This is necessary for RCU to find the quiescent states in idle in order to complete grace periods. Add this missing pair of calls in the mn10300's idle loop. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13frv: Add missing RCU idle APIs on idle loopFrederic Weisbecker
commit 41d8fe5bb3cf91ce2716ac8f43e4b40d802a99c8 upstream. In the old times, the whole idle task was considered as an RCU quiescent state. But as RCU became more and more successful overtime, some RCU read side critical section have been added even in the code of some architectures idle tasks, for tracing for example. So nowadays, rcu_idle_enter() and rcu_idle_exit() must be called by the architecture to tell RCU about the part in the idle loop that doesn't make use of rcu read side critical sections, typically the part that puts the CPU in low power mode. This is necessary for RCU to find the quiescent states in idle in order to complete grace periods. Add this missing pair of calls in the Frv's idle loop. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: David Howells <dhowells@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13xtensa: Add missing RCU idle APIs on idle loopFrederic Weisbecker
commit 11ad47a0edbd62bfc0547cfcdf227a911433f207 upstream. In the old times, the whole idle task was considered as an RCU quiescent state. But as RCU became more and more successful overtime, some RCU read side critical section have been added even in the code of some architectures idle tasks, for tracing for example. So nowadays, rcu_idle_enter() and rcu_idle_exit() must be called by the architecture to tell RCU about the part in the idle loop that doesn't make use of rcu read side critical sections, typically the part that puts the CPU in low power mode. This is necessary for RCU to find the quiescent states in idle in order to complete grace periods. Add this missing pair of calls in the xtensa's idle loop. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
