Provide proper configuration for VGEN3, to make sure it's is always powered
which allows that rail to be automatically switched to 1.8 volts
for proper UHS-I operation. By default it's disabled.
With UHS-I enabled:
[ 104.153898] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
[ 104.166202] mmcblk1: mmc1:59b4 USD00 15.0 GiB
[ 104.173923] mmcblk1: p1
root@colibri-imx6:~# hdparm -t /dev/mmcblk1
/dev/mmcblk1:
Timing buffered disk reads: 226 MB in 3.01 seconds = 75.01 MB/sec
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
On our i.MX6 SOC, the DIGPROG register is used for represent the
SOC ID and silicon revision. The revision has two part: MAJOR and
MINOR. each is represented in 8 bits in the register.
bits [15:8]: reflect the MAJOR part of the revision;
bits [7:0]: reflect the MINOR part of the revision;
In our linux kernel, the soc revision is represented in 8 bits. MAJOR
part and MINOR each occupy 4 bits.
previous method does NOT take care about the MAJOR part in DIGPROG register.
So reformat the revision read from the HW to compatible the revision format
used in kernel.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
(cherry picked from commit cf6fa1477149d4bddd096c71b46fa6c4cf9cf750)
Switch on 22 kOhm pull ups and lower the I2C frequency to around 40kHz
to get a more reliable communication.
(cherry picked from commit ffb2a2a59869415921e816614749ad5e48f9c077)
Several modules have issues with HS400 at 100MHz at room temperature
but they seem to work fine at HS400 at 200MHz. Do not restrict
frequency for now.
This reverts commit 166fb4842e780f63c31622af706335e7dcd48c24.
A9, A12 and A17
In order to prevent aliasing attacks on the branch predictor,
invalidate the BTB on CPUs that are known to be affected when taking
a prefetch abort on a address that is outside of a user task limit.
(cherry picked from commit a07373c8c365746583f25f49fee41b1bc0ff94b2)
[jason: adapted to 4.1]
Signed-off-by: Jason Liu <jason.hui.liu@nxp.com>
In order to avoid aliasing attacks against the branch predictor,
some implementations require to invalidate the BTB when switching
from one user context to another.
For this, we reuse the existing implementation for Cortex-A8, and
apply it to A9, A12 and A17.
(cherry picked commit from efcd0e857a656bbd1c1da15ff984ad6402332c61)
Commit 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
changed many more clocks than only the SPDIF core clock as stated in
the commit message.
The MLB clock has been added and this causes SPDIF regression as
reported by Xavi Drudis Ferran and also in this forum post:
https://forum.digikey.com/thread/34240
The MX6Q Reference Manual does not mention that MLB is a clock related
to SPDIF, so change it back to a dummy clock to restore SPDIF
functionality.
Thanks to Ambika for providing the fix at:
https://community.nxp.com/thread/387131
Fixes: 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
Cc: <stable@vger.kernel.org> # 4.4.x
Reported-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
(cherry picked from commit f065e9e4addd75c21bb976bb2558648bf4f61de6)
Tested playback and record on pulseaudio with 44.1kHz samples.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Now that the PWM work enable them.
While at it move the backlight pwm settings into the carrier board
file were it belongs. Periode and polarity are carrier board / display
dependent.
Update #pwm-cells to 3 in order to support PWM signal polarity
control.
All PWM clock instances have their clock gate. Add these consistently.
Fixes freezing the kernel when one of these instances is used with
IMX6UL_CLK_DUMMY as its clock source.
Add a device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT.
This is done by splitting out common nodes / properties into
common *dtsi files and keep only the differences in a separate
files.
During temperature testing modules print the following error every
now and then:
[ 12.231006] mmc0: Timeout waiting for hardware interrupt. retries left=0 opcode=12
Often the SDHC controller/driver does not recover from the issue
which leads to a Kernel panic (e.g. during boot the kernel can not
mount the root fs).
Lowering the frequency to 100MHz proves to be stable and affects
effective bandwith by less than 5%.
There are macros specifying the bmode pins for i.MX 6UL and ULL.
Don't use the UL macros.
Add 900MHz/1.25V setpoint according the latest datasheet(Rev.1,2/2017),
we add a 25mV voltage margin to cover the IR frop and board tolerance.
(cherry picked from commit 9c31f7bf938adb9a808ea7bf637ccecf53f6e7be)
(cherry picked from commit c27010d99a3d91703ea2d1a3f9630a9dedc3f86f)
According to the latest datasheet(Rev.1,02/2017), when the internal LDO
is enabled, the ARM core can run at 900MHz. We need to check the
speed grading fuse to determine the max ARM core frequency.
(cherry picked from commit cc0edd14c5fc3b5590302572687b08f80563c683)
(cherry picked from commit c0821bb630b5a993a7cb8405f228f8bbd9e0bef7)
imx6ull RDP
Update imx6ull header file with the latest imx6ull RDP.
- add new pin function definitions.
- update pin function changes.
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
Reviewed-by: Richard Zhu <hongxing.zhu@nxp.com>
(cherry picked from commit 2c32aec9f6b910e03c7d422ad524352663547f52)
imx6ull.dtsi contains the values for 800/900MHz i.MX 6ULL.
Don't override the values here with wrong cpu voltages.
This fixes the i.MX6ULL 512MB boot freeze and it fixes
the SoC temperature sensor.
We use the second ethernet MAC for the on module ethernet.
Use an alias so that U-Boot fixes up the device tree to assign the
MAC address corresponding to the serial number to the second MAC and
uses the (serial# + 0x100000) one for the first MAC.
By default one can only use channels 0 and 1.
The AD channels on the SODIMM are connected as follows:
AD0 channel 0
AD1 channel 1
AD2 channel 8
AD3 channel 9
Move all entries for node cpu0 together.
This brings in the configuration changes needed for backports.
Also remove drivers not used in a Colibri iMX6ULL.
Synchronize the defconfigs with changes done in meta-toradex-nxp.
Normalize the defconfigs by
make ..._defconfig
make savedevconig
cp defconfig arch/arm/configs/..._defconfig
Enable atmel mxt multi-touch controller driver to be built as a
module.
Add atmel mxt multitouch controller driver which is interfaced over I2C bus.
This controller is used by the Logic Technologies, Capacitive Touch Display
7" Parallel (LT161010-2NHC).
Enable atmel mxt multi-touch controller driver to be built as a module.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Add new gpio hog group for atmel mxt ts GPIOs.
module.
They currently don't work. Activating them from the sysfs does
freeze the kernel.
For some reason USDHC and USB access crashes the kernel if the
OCOTP clock is not enabled. It seems not to be software related
since there is no direct access from the USDHC/Chipidea USB
driver to the OCOTP IP. It might be that the hardware checks
the fuses to determine if the particular SoC is supposed to
let user access a certain peripheral...
The file uses linux,keycode = <KEY_POWER>;, so include
the header which defines KEY_POWER.
i.MX6 SL/UL/ULL use a different node in the device tree for with ocotp.
So change to the relevant compatible string for these SoCs.
With the move from the 3.14.52 to the 4.1 kernel the way the weim
node defines chipselects changed.
A phandle to the gpr node is needed.
Only the following 4 configuration can be specified in the ranges property:
CS0(128M), CS1 (0M), CS2(0M), CS3(0M)
CS0(64M), CS1(64M), CS2(0M), CS3(0M)
CS0(64M), CS1(32M), CS2(32M), CS3(0M)
CS0(32M), CS1(32M), CS2(32M), CS3(32M)
Add support for the latest addition to the Colibri iMX7 familiy,
Colibri iMX7 Dual 1GB with eMMC storage.
Linux 4.1.44
* tag 'v4.1.44': (180 commits)
Linux 4.1.44
mtd: fsl-quadspi: fix macro collision problems with READ/WRITE
pinctrl: samsung: Remove bogus irq_[un]mask from resource management
pinctrl: sunxi: add a missing function of A10/A20 pinctrl driver
pnfs/blocklayout: require 64-bit sector_t
iio: adc: vf610_adc: Fix VALT selection value for REFSEL bits
usb:xhci:Add quirk for Certain failing HP keyboard on reset after resume
usb: quirks: Add no-lpm quirk for Moshi USB to Ethernet Adapter
USB: Check for dropped connection before switching to full speed
uas: Add US_FL_IGNORE_RESIDUE for Initio Corporation INIC-3069
iio: light: tsl2563: use correct event code
staging:iio:resolver:ad2s1210 fix negative IIO_ANGL_VEL read
USB: hcd: Mark secondary HCD as dead if the primary one died
USB: serial: pl2303: add new ATEN device id
USB: serial: cp210x: add support for Qivicon USB ZigBee dongle
USB: serial: option: add D-Link DWM-222 device ID
nfs/flexfiles: fix leak of nfs4_ff_ds_version arrays
fuse: initialize the flock flag in fuse_file on allocation
iscsi-target: Fix iscsi_np reset hung task during parallel delete
iscsi-target: fix memory leak in iscsit_setup_text_cmd()
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
[ Upstream commit 7e5a672289c9754d07e1c3b33649786d3d70f5e4 ]
The mmu_notifier_release() callback of KVM triggers cleaning up
the stage2 page table on kvm-arm. However there could be other
notifier callbacks in parallel with the mmu_notifier_release(),
which could cause the call backs ending up in an empty stage2
page table. Make sure we check it for all the notifier callbacks.
Cc: stable@vger.kernel.org
Fixes: commit 293f29363 ("kvm-arm: Unmap shadow pagetables properly")
Reported-by: Alex Graf <agraf@suse.de>
Reviewed-by: Christoffer Dall <cdall@linaro.org>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
[ Upstream commit fc290a114fc6034b0f6a5a46e2fb7d54976cf87a ]
This fixes another cause of random segfaults and bus errors that may
occur while running perf with the callgraph option.
Critical sections beginning with spin_lock_irqsave() raise the interrupt
level to PIL_NORMAL_MAX (14) and intentionally do not block performance
counter interrupts, which arrive at PIL_NMI (15).
But some sections of code are "super critical" with respect to perf
because the perf_callchain_user() path accesses user space and may cause
TLB activity as well as faults as it unwinds the user stack.
One particular critical section occurs in switch_mm:
spin_lock_irqsave(&mm->context.lock, flags);
load_secondary_context(mm);
tsb_context_switch(mm);
spin_unlock_irqrestore(&mm->context.lock, flags);
If a perf interrupt arrives in between load_secondary_context() and
tsb_context_switch(), then perf_callchain_user() could execute with
the context ID of one process, but with an active TSB for a different
process. When the user stack is accessed, it is very likely to
incur a TLB miss, since the h/w context ID has been changed. The TLB
will then be reloaded with a translation from the TSB for one process,
but using a context ID for another process. This exposes memory from
one process to another, and since it is a mapping for stack memory,
this usually causes the new process to crash quickly.
This super critical section needs more protection than is provided
by spin_lock_irqsave() since perf interrupts must not be allowed in.
Since __tsb_context_switch already goes through the trouble of
disabling interrupts completely, we fix this by moving the secondary
context load down into this better protected region.
Orabug: 25577560
Signed-off-by: Dave Aldridge <david.j.aldridge@oracle.com>
Signed-off-by: Rob Gardner <rob.gardner@oracle.com>
[ Upstream commit b0a0c2566f28e71e5e32121992ac8060cec75510 ]
While testing some other work that required JIT modifications, I
run into test_bpf causing a hang when JIT enabled on s390. The
problematic test case was the one from ddc665a4bb4b (bpf, arm64:
fix jit branch offset related to ldimm64), and turns out that we
do have a similar issue on s390 as well. In bpf_jit_prog() we
update next instruction address after returning from bpf_jit_insn()
with an insn_count. bpf_jit_insn() returns either -1 in case of
error (e.g. unsupported insn), 1 or 2. The latter is only the
case for ldimm64 due to spanning 2 insns, however, next address
is only set to i + 1 not taking actual insn_count into account,
thus fix is to use insn_count instead of 1. bpf_jit_enable in
mode 2 provides also disasm on s390:
Before fix:
000003ff800349b6: a7f40003 brc 15,3ff800349bc ; target
000003ff800349ba: 0000 unknown
000003ff800349bc: e3b0f0700024 stg %r11,112(%r15)
000003ff800349c2: e3e0f0880024 stg %r14,136(%r15)
000003ff800349c8: 0db0 basr %r11,%r0
000003ff800349ca: c0ef00000000 llilf %r14,0
000003ff800349d0: e320b0360004 lg %r2,54(%r11)
000003ff800349d6: e330b03e0004 lg %r3,62(%r11)
000003ff800349dc: ec23ffeda065 clgrj %r2,%r3,10,3ff800349b6 ; jmp
000003ff800349e2: e3e0b0460004 lg %r14,70(%r11)
000003ff800349e8: e3e0b04e0004 lg %r14,78(%r11)
000003ff800349ee: b904002e lgr %r2,%r14
000003ff800349f2: e3b0f0700004 lg %r11,112(%r15)
000003ff800349f8: e3e0f0880004 lg %r14,136(%r15)
000003ff800349fe: 07fe bcr 15,%r14
After fix:
000003ff80ef3db4: a7f40003 brc 15,3ff80ef3dba
000003ff80ef3db8: 0000 unknown
000003ff80ef3dba: e3b0f0700024 stg %r11,112(%r15)
000003ff80ef3dc0: e3e0f0880024 stg %r14,136(%r15)
000003ff80ef3dc6: 0db0 basr %r11,%r0
000003ff80ef3dc8: c0ef00000000 llilf %r14,0
000003ff80ef3dce: e320b0360004 lg %r2,54(%r11)
000003ff80ef3dd4: e330b03e0004 lg %r3,62(%r11)
000003ff80ef3dda: ec230006a065 clgrj %r2,%r3,10,3ff80ef3de6 ; jmp
000003ff80ef3de0: e3e0b0460004 lg %r14,70(%r11)
000003ff80ef3de6: e3e0b04e0004 lg %r14,78(%r11) ; target
000003ff80ef3dec: b904002e lgr %r2,%r14
000003ff80ef3df0: e3b0f0700004 lg %r11,112(%r15)
000003ff80ef3df6: e3e0f0880004 lg %r14,136(%r15)
000003ff80ef3dfc: 07fe bcr 15,%r14
test_bpf.ko suite runs fine after the fix.
Fixes: 054623105728 ("s390/bpf: Add s390x eBPF JIT compiler backend")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Tested-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
[ Upstream commit 270c8cf1cacc69cb8d99dea812f06067a45e4609 ]
ARM has a few system calls (most notably mmap) for which the names of
the functions which are referenced in the syscall table do not match the
names of the syscall tracepoints. As a consequence of this, these
tracepoints are not made available. Implement
arch_syscall_match_sym_name to fix this and allow tracing even these
system calls.
Signed-off-by: Rabin Vincent <rabinv@axis.com>
[ Upstream commit fac69d0efad08fc15e4dbfc116830782acc0dc9a ]
Add the missing declarations of basic string functions to string.h to allow
a clean build.
Fixes: 5be865661516 ("String-handling functions for the new x86 setup code.")
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Link: http://lkml.kernel.org/r/1483781911-21399-1-git-send-email-hofrat@osadl.org
[ Upstream commit 9d53caec84c7c5700e7c1ed744ea584fff55f9ac ]
A large sun4v SPARC system may have moments of intensive xcall activities,
usually caused by unmapping many pages on many CPUs concurrently. This can
flood receivers with CPU mondo interrupts for an extended period, causing
some unlucky senders to hit send-mondo timeout. This problem gets worse
as cpu count increases because sometimes mappings must be invalidated on
all CPUs, and sometimes all CPUs may gang up on a single CPU.
But a busy system is not a broken system. In the above scenario, as long
as the receiver is making forward progress processing mondo interrupts,
the sender should continue to retry.
This patch implements the receiver's forward progress meter by introducing
a per cpu counter 'cpu_mondo_counter[cpu]' where 'cpu' is in the range
of 0..NR_CPUS. The receiver increments its counter as soon as it receives
a mondo and the sender tracks the receiver's counter. If the receiver has
stopped making forward progress when the retry limit is reached, the sender
declares send-mondo-timeout and panic; otherwise, the receiver is allowed
to keep making forward progress.
In addition, it's been observed that PCIe hotplug events generate Correctable
Errors that are handled by hypervisor and then OS. Hypervisor 'borrows'
a guest cpu strand briefly to provide the service. If the cpu strand is
simultaneously the only cpu targeted by a mondo, it may not be available
for the mondo in 20msec, causing SUN4V mondo timeout. It appears that 1 second
is the agreed wait time between hypervisor and guest OS, this patch makes
the adjustment.
Orabug: 25476541
Orabug: 26417466
Signed-off-by: Jane Chu <jane.chu@oracle.com>
Reviewed-by: Steve Sistare <steven.sistare@oracle.com>
Reviewed-by: Anthony Yznaga <anthony.yznaga@oracle.com>
Reviewed-by: Rob Gardner <rob.gardner@oracle.com>
Reviewed-by: Thomas Tai <thomas.tai@oracle.com>
[ Upstream commit 8d4514173211586c6238629b1ef1e071927735f5 ]
As written in the datasheet the PCA955 can only handle low level irq and
not edge irq.
Without this fix the interrupt is not usable for pca955: the gpio-pca953x
driver already set the irq type as low level which is incompatible with
edge type, then the kernel prevents using the interrupt:
"irq: type mismatch, failed to map hwirq-18 for
/soc/internal-regs/gpio@18100!"
Fixes: 928413bd859c ("ARM: mvebu: Add Armada 388 General Purpose
Development Board support")
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
[ Upstream commit 337c017ccdf2653d0040099433fc1a2b1beb5926 ]
WARNING: CPU: 5 PID: 1242 at kernel/rcu/tree_plugin.h:323 rcu_note_context_switch+0x207/0x6b0
CPU: 5 PID: 1242 Comm: unity-settings- Not tainted 4.13.0-rc2+ #1
RIP: 0010:rcu_note_context_switch+0x207/0x6b0
Call Trace:
__schedule+0xda/0xba0
? kvm_async_pf_task_wait+0x1b2/0x270
schedule+0x40/0x90
kvm_async_pf_task_wait+0x1cc/0x270
? prepare_to_swait+0x22/0x70
do_async_page_fault+0x77/0xb0
? do_async_page_fault+0x77/0xb0
async_page_fault+0x28/0x30
RIP: 0010:__d_lookup_rcu+0x90/0x1e0
I encounter this when trying to stress the async page fault in L1 guest w/
L2 guests running.
Commit 9b132fbe5419 (Add rcu user eqs exception hooks for async page
fault) adds rcu_irq_enter/exit() to kvm_async_pf_task_wait() to exit cpu
idle eqs when needed, to protect the code that needs use rcu. However,
we need to call the pair even if the function calls schedule(), as seen
from the above backtrace.
This patch fixes it by informing the RCU subsystem exit/enter the irq
towards/away from idle for both n.halted and !n.halted.
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
