commit 5dedade6dfa243c130b85d1e4daba6f027805033 upstream.
... similarly to the cpuid_<reg>() variants.
Link: http://lkml.kernel.org/r/20170109114147.5082-2-bp@alien8.de
Cc: Evalds Iodzevics <evalds.iodzevics@gmail.com>
[ Upstream commit 1493e0f944f3c319d11e067c185c904d01c17ae5 ]
We have to properly retry again by returning -EINVAL immediately in case
somebody else instantiated the table concurrently. We missed to add the
goto in this function only. The code now matches the other, similar
shadowing functions.
We are overwriting an existing region 2 table entry. All allocated pages
are added to the crst_list to be freed later, so they are not lost
forever. However, when unshadowing the region 2 table, we wouldn't trigger
unshadowing of the original shadowed region 3 table that we replaced. It
would get unshadowed when the original region 3 table is modified. As it's
not connected to the page table hierarchy anymore, it's not going to get
used anymore. However, for a limited time, this page table will stick
around, so it's in some sense a temporary memory leak.
Identified by manual code inspection. I don't think this classifies as
stable material.
Fixes: 998f637cc4b9 ("s390/mm: avoid races on region/segment/page table shadowing")
Signed-off-by: David Hildenbrand <david@redhat.com>
Link: https://lore.kernel.org/r/20200403153050.20569-4-david@redhat.com
Reviewed-by: Claudio Imbrenda <imbrenda@linux.ibm.com>
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
[ Upstream commit af6cf95c4d003fccd6c2ecc99a598fb854b537e7 ]
When building ppc64 defconfig, Clang errors (trimmed for brevity):
arch/powerpc/platforms/maple/setup.c:365:1: error: attribute declaration
must precede definition [-Werror,-Wignored-attributes]
machine_device_initcall(maple, maple_cpc925_edac_setup);
machine_device_initcall expands to __define_machine_initcall, which in
turn has the macro machine_is used in it, which declares mach_##name
with an __attribute__((weak)). define_machine actually defines
mach_##name, which in this file happens before the declaration, hence
the warning.
To fix this, move define_machine after machine_device_initcall so that
the declaration occurs before the definition, which matches how
machine_device_initcall and define_machine work throughout
arch/powerpc.
While we're here, remove some spaces before tabs.
Fixes: 8f101a051ef0 ("edac: cpc925 MC platform device setup")
Reported-by: Nick Desaulniers <ndesaulniers@google.com>
Suggested-by: Ilie Halip <ilie.halip@gmail.com>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Link: https://lore.kernel.org/r/20200323222729.15365-1-natechancellor@gmail.com
[ Upstream commit 872f27103874a73783aeff2aac2b41a489f67d7c ]
/proc/cpuinfo should not print information about CPU 0 when it is offline.
Fixes: 281eaa8cb67c ("s390/cpuinfo: simplify locking and skip offline cpus early")
Signed-off-by: Alexander Gordeev <agordeev@linux.ibm.com>
Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com>
[heiko.carstens@de.ibm.com: shortened commit message]
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
commit 94a5d8790e79ab78f499d2d9f1ff2cab63849d9f upstream.
Without including psci.h and arm-smccc.h, we now get a build failure in
some configurations:
arch/arm64/kernel/cpu_errata.c: In function 'arm64_update_smccc_conduit':
arch/arm64/kernel/cpu_errata.c:278:10: error: 'psci_ops' undeclared (first use in this function); did you mean 'sysfs_ops'?
arch/arm64/kernel/cpu_errata.c: In function 'arm64_set_ssbd_mitigation':
arch/arm64/kernel/cpu_errata.c:311:3: error: implicit declaration of function 'arm_smccc_1_1_hvc' [-Werror=implicit-function-declaration]
arm_smccc_1_1_hvc(ARM_SMCCC_ARCH_WORKAROUND_2, state, NULL);
commit 396d2e878f92ec108e4293f1c77ea3bc90b414ff upstream.
The host reports support for the synthetic feature X86_FEATURE_SSBD
when any of the three following hardware features are set:
CPUID.(EAX=7,ECX=0):EDX.SSBD[bit 31]
CPUID.80000008H:EBX.AMD_SSBD[bit 24]
CPUID.80000008H:EBX.VIRT_SSBD[bit 25]
Either of the first two hardware features implies the existence of the
IA32_SPEC_CTRL MSR, but CPUID.80000008H:EBX.VIRT_SSBD[bit 25] does
not. Therefore, CPUID.(EAX=7,ECX=0):EDX.SSBD[bit 31] should only be
set in the guest if CPUID.(EAX=7,ECX=0):EDX.SSBD[bit 31] or
CPUID.80000008H:EBX.AMD_SSBD[bit 24] is set on the host.
Fixes: 0c54914d0c52a ("KVM: x86: use Intel speculation bugs and features as derived in generic x86 code")
Signed-off-by: Jim Mattson <jmattson@google.com>
Reviewed-by: Jacob Xu <jacobhxu@google.com>
Reviewed-by: Peter Shier <pshier@google.com>
Reported-by: Eric Biggers <ebiggers@kernel.org>
[bwh: Backported to 4.x: adjust indentation]
[ Upstream commit aa4113340ae6c2811e046f08c2bc21011d20a072 ]
In the current implementation, the call to loadcam_multi() is wrapped
between switch_to_as1() and restore_to_as0() calls so, when it tries
to create its own temporary AS=1 TLB1 entry, it ends up duplicating
the existing one created by switch_to_as1(). Add a check to skip
creating the temporary entry if already running in AS=1.
Fixes: d9e1831a4202 ("powerpc/85xx: Load all early TLB entries at once")
Cc: stable@vger.kernel.org # v4.4+
Signed-off-by: Laurentiu Tudor <laurentiu.tudor@nxp.com>
Acked-by: Scott Wood <oss@buserror.net>
Link: https://lore.kernel.org/r/20200123111914.2565-1-laurentiu.tudor@nxp.com
commit c7def7fbdeaa25feaa19caf4a27c5d10bd8789e4 upstream.
In restore_tm_sigcontexts() we take the trap value directly from the
user sigcontext with no checking:
err |= __get_user(regs->trap, &sc->gp_regs[PT_TRAP]);
This means we can be in the kernel with an arbitrary regs->trap value.
Although that's not immediately problematic, there is a risk we could
trigger one of the uses of CHECK_FULL_REGS():
#define CHECK_FULL_REGS(regs) BUG_ON(regs->trap & 1)
It can also cause us to unnecessarily save non-volatile GPRs again in
save_nvgprs(), which shouldn't be problematic but is still wrong.
It's also possible it could trick the syscall restart machinery, which
relies on regs->trap not being == 0xc00 (see 9a81c16b5275 ("powerpc:
fix double syscall restarts")), though I haven't been able to make
that happen.
Finally it doesn't match the behaviour of the non-TM case, in
restore_sigcontext() which zeroes regs->trap.
So change restore_tm_sigcontexts() to zero regs->trap.
This was discovered while testing Nick's upcoming rewrite of the
syscall entry path. In that series the call to save_nvgprs() prior to
signal handling (do_notify_resume()) is removed, which leaves the
low-bit of regs->trap uncleared which can then trigger the FULL_REGS()
WARNs in setup_tm_sigcontexts().
Fixes: 2b0a576d15e0 ("powerpc: Add new transactional memory state to the signal context")
Cc: stable@vger.kernel.org # v3.9+
Link: https://lore.kernel.org/r/20200401023836.3286664-1-mpe@ellerman.id.au
commit 6c7c851f1b666a8a455678a0b480b9162de86052 upstream.
Show the full diag statistic table and not just parts of it.
The issue surfaced in a KVM guest with a number of vcpus
defined smaller than NR_DIAG_STAT.
Fixes: 1ec2772e0c3c ("s390/diag: add a statistic for diagnose calls")
Signed-off-by: Michael Mueller <mimu@linux.ibm.com>
commit fc2266011accd5aeb8ebc335c381991f20e26e33 upstream.
For thumb instructions, call_undef_hook() in traps.c first reads a u16,
and if the u16 indicates a T32 instruction (u16 >= 0xe800), a second
u16 is read, which then makes up the the lower half-word of a T32
instruction. For T16 instructions, the second u16 is not read,
which makes the resulting u32 opcode always have the upper half set to
0.
However, having the upper half of instr_mask in the undef_hook set to 0
masks out the upper half of all thumb instructions - both T16 and T32.
This results in trapped T32 instructions with the lower half-word equal
to the T16 encoding of setend (b650) being matched, even though the upper
half-word is not 0000 and thus indicates a T32 opcode.
An example of such a T32 instruction is eaa0b650, which should raise a
SIGILL since T32 instructions with an eaa prefix are unallocated as per
Arm ARM, but instead works as a SETEND because the second half-word is set
to b650.
This patch fixes the issue by extending instr_mask to include the
upper u32 half, which will still match T16 instructions where the upper
half is 0, but not T32 instructions.
Fixes: 2d888f48e056 ("arm64: Emulate SETEND for AArch32 tasks")
Cc: <stable@vger.kernel.org> # 4.0.x-
Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Signed-off-by: Fredrik Strupe <fredrik@strupe.net>
commit dbef2808af6c594922fe32833b30f55f35e9da6d upstream.
If KVM wasn't used at all before we crash the cleanup procedure fails with
BUG: unable to handle page fault for address: ffffffffffffffc8
#PF: supervisor read access in kernel mode
#PF: error_code(0x0000) - not-present page
PGD 23215067 P4D 23215067 PUD 23217067 PMD 0
Oops: 0000 [#8] SMP PTI
CPU: 0 PID: 3542 Comm: bash Kdump: loaded Tainted: G D 5.6.0-rc2+ #823
RIP: 0010:crash_vmclear_local_loaded_vmcss.cold+0x19/0x51 [kvm_intel]
The root cause is that loaded_vmcss_on_cpu list is not yet initialized,
we initialize it in hardware_enable() but this only happens when we start
a VM.
Previously, we used to have a bitmap with enabled CPUs and that was
preventing [masking] the issue.
Initialized loaded_vmcss_on_cpu list earlier, right before we assign
crash_vmclear_loaded_vmcss pointer. blocked_vcpu_on_cpu list and
blocked_vcpu_on_cpu_lock are moved altogether for consistency.
Fixes: 31603d4fc2bb ("KVM: VMX: Always VMCLEAR in-use VMCSes during crash with kexec support")
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Message-Id: <20200401081348.1345307-1-vkuznets@redhat.com>
Reviewed-by: Sean Christopherson <sean.j.christopherson@intel.com>
commit 31603d4fc2bb4f0815245d496cb970b27b4f636a upstream.
VMCLEAR all in-use VMCSes during a crash, even if kdump's NMI shootdown
interrupted a KVM update of the percpu in-use VMCS list.
Because NMIs are not blocked by disabling IRQs, it's possible that
crash_vmclear_local_loaded_vmcss() could be called while the percpu list
of VMCSes is being modified, e.g. in the middle of list_add() in
vmx_vcpu_load_vmcs(). This potential corner case was called out in the
original commit[*], but the analysis of its impact was wrong.
Skipping the VMCLEARs is wrong because it all but guarantees that a
loaded, and therefore cached, VMCS will live across kexec and corrupt
memory in the new kernel. Corruption will occur because the CPU's VMCS
cache is non-coherent, i.e. not snooped, and so the writeback of VMCS
memory on its eviction will overwrite random memory in the new kernel.
The VMCS will live because the NMI shootdown also disables VMX, i.e. the
in-progress VMCLEAR will #UD, and existing Intel CPUs do not flush the
VMCS cache on VMXOFF.
Furthermore, interrupting list_add() and list_del() is safe due to
crash_vmclear_local_loaded_vmcss() using forward iteration. list_add()
ensures the new entry is not visible to forward iteration unless the
entire add completes, via WRITE_ONCE(prev->next, new). A bad "prev"
pointer could be observed if the NMI shootdown interrupted list_del() or
list_add(), but list_for_each_entry() does not consume ->prev.
In addition to removing the temporary disabling of VMCLEAR, open code
loaded_vmcs_init() in __loaded_vmcs_clear() and reorder VMCLEAR so that
the VMCS is deleted from the list only after it's been VMCLEAR'd.
Deleting the VMCS before VMCLEAR would allow a race where the NMI
shootdown could arrive between list_del() and vmcs_clear() and thus
neither flow would execute a successful VMCLEAR. Alternatively, more
code could be moved into loaded_vmcs_init(), but that gets rather silly
as the only other user, alloc_loaded_vmcs(), doesn't need the smp_wmb()
and would need to work around the list_del().
Update the smp_*() comments related to the list manipulation, and
opportunistically reword them to improve clarity.
[*] https://patchwork.kernel.org/patch/1675731/#3720461
Fixes: 8f536b7697a0 ("KVM: VMX: provide the vmclear function and a bitmap to support VMCLEAR in kdump")
Signed-off-by: Sean Christopherson <sean.j.christopherson@intel.com>
Message-Id: <20200321193751.24985-2-sean.j.christopherson@intel.com>
Reviewed-by: Vitaly Kuznetsov <vkuznets@redhat.com>
commit edd4fa37baa6ee8e44dc65523b27bd6fe44c94de upstream.
Reallocate a rmap array and recalcuate large page compatibility when
moving an existing memslot to correctly handle the alignment properties
of the new memslot. The number of rmap entries required at each level
is dependent on the alignment of the memslot's base gfn with respect to
that level, e.g. moving a large-page aligned memslot so that it becomes
unaligned will increase the number of rmap entries needed at the now
unaligned level.
Not updating the rmap array is the most obvious bug, as KVM accesses
garbage data beyond the end of the rmap. KVM interprets the bad data as
pointers, leading to non-canonical #GPs, unexpected #PFs, etc...
general protection fault: 0000 [#1] SMP
CPU: 0 PID: 1909 Comm: move_memory_reg Not tainted 5.4.0-rc7+ #139
Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS 0.0.0 02/06/2015
RIP: 0010:rmap_get_first+0x37/0x50 [kvm]
Code: <48> 8b 3b 48 85 ff 74 ec e8 6c f4 ff ff 85 c0 74 e3 48 89 d8 5b c3
RSP: 0018:ffffc9000021bbc8 EFLAGS: 00010246
RAX: ffff00617461642e RBX: ffff00617461642e RCX: 0000000000000012
RDX: ffff88827400f568 RSI: ffffc9000021bbe0 RDI: ffff88827400f570
RBP: 0010000000000000 R08: ffffc9000021bd00 R09: ffffc9000021bda8
R10: ffffc9000021bc48 R11: 0000000000000000 R12: 0030000000000000
R13: 0000000000000000 R14: ffff88827427d700 R15: ffffc9000021bce8
FS: 00007f7eda014700(0000) GS:ffff888277a00000(0000) knlGS:0000000000000000
CR2: 00007f7ed9216ff8 CR3: 0000000274391003 CR4: 0000000000162eb0
Call Trace:
kvm_mmu_slot_set_dirty+0xa1/0x150 [kvm]
__kvm_set_memory_region.part.64+0x559/0x960 [kvm]
kvm_set_memory_region+0x45/0x60 [kvm]
kvm_vm_ioctl+0x30f/0x920 [kvm]
do_vfs_ioctl+0xa1/0x620
ksys_ioctl+0x66/0x70
__x64_sys_ioctl+0x16/0x20
do_syscall_64+0x4c/0x170
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x7f7ed9911f47
Code: <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 21 6f 2c 00 f7 d8 64 89 01 48
RSP: 002b:00007ffc00937498 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 0000000001ab0010 RCX: 00007f7ed9911f47
RDX: 0000000001ab1350 RSI: 000000004020ae46 RDI: 0000000000000004
RBP: 000000000000000a R08: 0000000000000000 R09: 00007f7ed9214700
R10: 00007f7ed92149d0 R11: 0000000000000246 R12: 00000000bffff000
R13: 0000000000000003 R14: 00007f7ed9215000 R15: 0000000000000000
Modules linked in: kvm_intel kvm irqbypass
---[ end trace 0c5f570b3358ca89 ]---
The disallow_lpage tracking is more subtle. Failure to update results
in KVM creating large pages when it shouldn't, either due to stale data
or again due to indexing beyond the end of the metadata arrays, which
can lead to memory corruption and/or leaking data to guest/userspace.
Note, the arrays for the old memslot are freed by the unconditional call
to kvm_free_memslot() in __kvm_set_memory_region().
Fixes: 05da45583de9b ("KVM: MMU: large page support")
Reviewed-by: Peter Xu <peterx@redhat.com>
commit 4d4cee96fb7a3cc53702a9be8299bf525be4ee98 upstream.
Whenever we get an -EFAULT, we failed to read in guest 2 physical
address space. Such addressing exceptions are reported via a program
intercept to the nested hypervisor.
We faked the intercept, we have to return to guest 2. Instead, right
now we would be returning -EFAULT from the intercept handler, eventually
crashing the VM.
the correct thing to do is to return 1 as rc == 1 is the internal
representation of "we have to go back into g2".
Addressing exceptions can only happen if the g2->g3 page tables
reference invalid g2 addresses (say, either a table or the final page is
not accessible - so something that basically never happens in sane
environments.
Fixes: a3508fbe9dc6 ("KVM: s390: vsie: initial support for nested virtualization")
Cc: <stable@vger.kernel.org> # v4.8+
Link: https://lore.kernel.org/r/20200403153050.20569-3-david@redhat.com
[borntraeger@de.ibm.com: fix patch description]
commit a1d032a49522cb5368e5dfb945a85899b4c74f65 upstream.
In case we have a region 1 the following calculation
(31 + ((gmap->asce & _ASCE_TYPE_MASK) >> 2)*11)
results in 64. As shifts beyond the size are undefined the compiler is
free to use instructions like sllg. sllg will only use 6 bits of the
shift value (here 64) resulting in no shift at all. That means that ALL
addresses will be rejected.
The can result in endless loops, e.g. when prefix cannot get mapped.
Fixes: 4be130a08420 ("s390/mm: add shadow gmap support")
Tested-by: Janosch Frank <frankja@linux.ibm.com>
Reported-by: Janosch Frank <frankja@linux.ibm.com>
Link: https://lore.kernel.org/r/20200403153050.20569-2-david@redhat.com
[borntraeger@de.ibm.com: fix patch description, remove WARN_ON_ONCE]
commit 3d51507f29f2153a658df4a0674ec5b592b62085 upstream.
All exception entry points must have ASM_CLAC right at the
beginning. The general_protection entry is missing one.
Fixes: e59d1b0a2419 ("x86-32, smap: Add STAC/CLAC instructions to 32-bit kernel entry")
Reviewed-by: Frederic Weisbecker <frederic@kernel.org>
Reviewed-by: Alexandre Chartre <alexandre.chartre@oracle.com>
Reviewed-by: Andy Lutomirski <luto@kernel.org>
Link: https://lkml.kernel.org/r/20200225220216.219537887@linutronix.de
commit 792a402c2840054533ef56279c212ef6da87d811 upstream.
There is a potential NULL pointer dereference in case kzalloc()
fails and returns NULL.
Fix this by adding a NULL check on *cd*
This bug was detected with the help of Coccinelle.
Fixes: 64b139f97c01 ("MIPS: OCTEON: irq: add CIB and other fixes")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
commit ecb9c790999fd6c5af0f44783bd0217f0b89ec2b upstream.
The value in "new" is constructed from "old" such that all bits defined
as reserved by the ACPI spec[1] are left untouched. But if those bits
do not happen to be all zero, "new < 3" will not evaluate to true.
The firmware of the laptop(s) Medion MD63490 / Akoya P15648 comes with
garbage inside the "FACS" ACPI table. The starting value is
old=0x4944454d, therefore new=0x4944454e, which is >= 3. Mask off
the reserved bits.
[1] https://uefi.org/sites/default/files/resources/ACPI_6_2.pdf
Link: https://bugzilla.kernel.org/show_bug.cgi?id=206553
Cc: All applicable <stable@vger.kernel.org>
Signed-off-by: Jan Engelhardt <jengelh@inai.de>
[ Upstream commit 81a34892c2c7c809f9c4e22c5ac936ae673fb9a2 ]
The load address is compared with LOAD_PHYSICAL_ADDR using a signed
comparison currently (using jge instruction).
When loading a 64-bit kernel using the new efi32_pe_entry() point added by:
97aa276579b2 ("efi/x86: Add true mixed mode entry point into .compat section")
using Qemu with -m 3072, the firmware actually loads us above 2Gb,
resulting in a very early crash.
Use the JAE instruction to perform a unsigned comparison instead, as physical
addresses should be considered unsigned.
Signed-off-by: Arvind Sankar <nivedita@alum.mit.edu>
Signed-off-by: Ard Biesheuvel <ardb@kernel.org>
Link: https://lore.kernel.org/r/20200301230436.2246909-6-nivedita@alum.mit.edu
Link: https://lore.kernel.org/r/20200308080859.21568-14-ardb@kernel.org
commit 61cf61d81e326163ce1557ceccfca76e11d0e57c upstream.
__early_cpu_boot_status is of type long. Use quad
assembler directive to allocate proper size.
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Arun KS <arunks@codeaurora.org>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
commit 6f5459da2b8736720afdbd67c4bd2d1edba7d0e3 upstream.
Building an arm64 defconfig with clang's integrated assembler, this error
occurs:
<instantiation>:2:2: error: unrecognized instruction mnemonic
_ASM_EXTABLE 9999b, 9f
arch/arm64/mm/cache.S:50:1: note: while in macro instantiation
user_alt 9f, "dc cvau, x4", "dc civac, x4", 0
While GNU as seems fine with case-sensitive macro instantiations, clang
doesn't, so use the actual macro name (_asm_extable) as in the rest of
the file.
Also checked that the generated assembly matches the GCC output.
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Tested-by: Nick Desaulniers <ndesaulniers@google.com>
Fixes: 290622efc76e ("arm64: fix "dc cvau" cache operation on errata-affected core")
Link: https://github.com/ClangBuiltLinux/linux/issues/924
Signed-off-by: Ilie Halip <ilie.halip@gmail.com>
Signed-off-by: Will Deacon <will@kernel.org>
commit dfa7ea303f56a3a8b1ed3b91ef35af2da67ca4ee upstream.
The L3 interconnect's memory map is from 0x0 to
0xffffffff. Out of this, System memory (SDRAM) can be
accessed from 0x80000000 to 0xffffffff (2GB)
OMAP5 does support 4GB of SDRAM but upper 2GB can only be
accessed by the MPU subsystem.
Add the dma-ranges property to reflect the physical address limit
of the L3 bus.
Cc: stable@kernel.org
Signed-off-by: Roger Quadros <rogerq@ti.com>
commit cfb5d65f25959f724081bae8445a0241db606af6 upstream.
DRA7 does support 4GB of SDRAM but upper 2GB can only be
of the L3 bus.
Issues ere observed only with SATA on DRA7-EVM with 4GB RAM
and CONFIG_ARM_LPAE enabled. This is because the controller
supports 64-bit DMA and its driver sets the dma_mask to 64-bit
thus resulting in DMA accesses beyond L3 limit of 2G.
Setting the correct bus_dma_limit fixes the issue.
[ Upstream commit c4409905cd6eb42cfd06126e9226b0150e05a715 ]
Re-execution after an emulation decode failure is only intended to
handle a case where two or vCPUs race to write a shadowed page, i.e.
we should never re-execute an instruction as part of MMIO emulation.
As handle_ept_misconfig() is only used for MMIO emulation, it should
pass EMULTYPE_NO_REEXECUTE when using the emulator to skip an instr
in the fast-MMIO case where VM_EXIT_INSTRUCTION_LEN is invalid.
And because the cr2 value passed to x86_emulate_instruction() is only
destined for use when retrying or reexecuting, we can simply call
emulate_instruction().
Fixes: d391f1207067 ("x86/kvm/vmx: do not use vm-exit instruction length
for fast MMIO when running nested")
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit d0bab0c39e32d39a8c5cddca72e5b4a3059fe050 upstream.
On a system with only one CPU online, when another one CPU panics while
starting-up, smp_send_stop() will fail to send any STOP message to the
other already online core, resulting in a system still responsive and
alive at the end of the panic procedure.
[ 186.700083] CPU3: shutdown
[ 187.075462] CPU2: shutdown
[ 187.162869] CPU1: shutdown
[ 188.689998] ------------[ cut here ]------------
[ 188.691645] kernel BUG at arch/arm64/kernel/cpufeature.c:886!
[ 188.692079] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 188.692444] Modules linked in:
[ 188.693031] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 5.6.0-rc4-00001-g338d25c35a98 #104
[ 188.693175] Hardware name: Foundation-v8A (DT)
[ 188.693492] pstate: 200001c5 (nzCv dAIF -PAN -UAO)
[ 188.694183] pc : has_cpuid_feature+0xf0/0x348
[ 188.694311] lr : verify_local_elf_hwcaps+0x84/0xe8
[ 188.694410] sp : ffff800011b1bf60
[ 188.694536] x29: ffff800011b1bf60 x28: 0000000000000000
[ 188.694707] x27: 0000000000000000 x26: 0000000000000000
[ 188.694801] x25: 0000000000000000 x24: ffff80001189a25c
[ 188.694905] x23: 0000000000000000 x22: 0000000000000000
[ 188.694996] x21: ffff8000114aa018 x20: ffff800011156a38
[ 188.695089] x19: ffff800010c944a0 x18: 0000000000000004
[ 188.695187] x17: 0000000000000000 x16: 0000000000000000
[ 188.695280] x15: 0000249dbde5431e x14: 0262cbe497efa1fa
[ 188.695371] x13: 0000000000000002 x12: 0000000000002592
[ 188.695472] x11: 0000000000000080 x10: 00400032b5503510
[ 188.695572] x9 : 0000000000000000 x8 : ffff800010c80204
[ 188.695659] x7 : 00000000410fd0f0 x6 : 0000000000000001
[ 188.695750] x5 : 00000000410fd0f0 x4 : 0000000000000000
[ 188.695836] x3 : 0000000000000000 x2 : ffff8000100939d8
[ 188.695919] x1 : 0000000000180420 x0 : 0000000000180480
[ 188.696253] Call trace:
[ 188.696410] has_cpuid_feature+0xf0/0x348
[ 188.696504] verify_local_elf_hwcaps+0x84/0xe8
[ 188.696591] check_local_cpu_capabilities+0x44/0x128
[ 188.696666] secondary_start_kernel+0xf4/0x188
[ 188.697150] Code: 52805001 72a00301 6b01001f 54000ec0 (d4210000)
[ 188.698639] ---[ end trace 3f12ca47652f7b72 ]---
[ 188.699160] Kernel panic - not syncing: Attempted to kill the idle task!
[ 188.699546] Kernel Offset: disabled
[ 188.699828] CPU features: 0x00004,20c02008
[ 188.700012] Memory Limit: none
[ 188.700538] ---[ end Kernel panic - not syncing: Attempted to kill the idle task! ]---
[root@arch ~]# echo Helo
Helo
[root@arch ~]# cat /proc/cpuinfo | grep proce
processor : 0
Make smp_send_stop() account also for the online status of the calling CPU
while evaluating how many CPUs are effectively online: this way, the right
number of STOPs is sent, so enforcing a proper freeze of the system at the
end of panic even under the above conditions.
Fixes: 08e875c16a16c ("arm64: SMP support")
Reported-by: Dave Martin <Dave.Martin@arm.com>
Signed-off-by: Cristian Marussi <cristian.marussi@arm.com>
commit 763802b53a427ed3cbd419dbba255c414fdd9e7c upstream.
Commit 3f8fd02b1bf1 ("mm/vmalloc: Sync unmappings in
__purge_vmap_area_lazy()") introduced a call to vmalloc_sync_all() in
the vunmap() code-path. While this change was necessary to maintain
correctness on x86-32-pae kernels, it also adds additional cycles for
architectures that don't need it.
Specifically on x86-64 with CONFIG_VMAP_STACK=y some people reported
severe performance regressions in micro-benchmarks because it now also
calls the x86-64 implementation of vmalloc_sync_all() on vunmap(). But
the vmalloc_sync_all() implementation on x86-64 is only needed for newly
created mappings.
To avoid the unnecessary work on x86-64 and to gain the performance
back, split up vmalloc_sync_all() into two functions:
* vmalloc_sync_mappings(), and
* vmalloc_sync_unmappings()
Most call-sites to vmalloc_sync_all() only care about new mappings being
synchronized. The only exception is the new call-site added in the
above mentioned commit.
Shile Zhang directed us to a report of an 80% regression in reaim
throughput.
Fixes: 3f8fd02b1bf1 ("mm/vmalloc: Sync unmappings in __purge_vmap_area_lazy()")
Reported-by: kernel test robot <oliver.sang@intel.com>
Reported-by: Shile Zhang <shile.zhang@linux.alibaba.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Tested-by: Borislav Petkov <bp@suse.de>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [GHES]
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Link: http://lkml.kernel.org/r/20191009124418.8286-1-joro@8bytes.org
Link: https://lists.01.org/hyperkitty/list/lkp@lists.01.org/thread/4D3JPPHBNOSPFK2KEPC6KGKS6J25AIDB/
Link: http://lkml.kernel.org/r/20191113095530.228959-1-shile.zhang@linux.alibaba.com
[ Upstream commit 27f13774654ea6bd0b6fc9b97cce8d19e5735661 ]
'dma-ranges' in a PCI bridge node does correctly set dma masks for PCI
devices not described in the DT. Certain DRA7 platforms (e.g., DRA76)
has RAM above 32-bit boundary (accessible with LPAE config) though the
PCIe bridge will be able to access only 32-bits. Add 'dma-ranges'
property in PCIe RC DT nodes to indicate the host bridge can access
only 32 bits.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
[ Upstream commit cb0cc635c7a9fa8a3a0f75d4d896721819c63add ]
Selecting CONFIG_DEBUG_INFO_BTF results in the below warning from ld:
ld: warning: orphan section `.BTF' from `.btf.vmlinux.bin.o' being placed in section `.BTF'
Include .BTF section in vmlinux explicitly to fix the same.
Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Link: https://lore.kernel.org/r/20200220113132.857132-1-naveen.n.rao@linux.vnet.ibm.com
commit f87b1c49bc675da30d8e1e8f4b60b800312c7b90 upstream.
When the uaccess .fixup section was renamed to .text.fixup, one case was
missed. Under ld.bfd, the orphaned section was moved close to .text
(since they share the "ax" bits), so things would work normally on
uaccess faults. Under ld.lld, the orphaned section was placed outside
the .text section, making it unreachable.
Link: https://github.com/ClangBuiltLinux/linux/issues/282
Link: https://bugs.chromium.org/p/chromium/issues/detail?id=1020633#c44
Link: https://lore.kernel.org/r/nycvar.YSQ.7.76.1912032147340.17114@knanqh.ubzr
Link: https://lore.kernel.org/lkml/202002071754.F5F073F1D@keescook/
Fixes: c4a84ae39b4a5 ("ARM: 8322/1: keep .text and .fixup regions closer together")
Reviewed-by: Ard Biesheuvel <ardb@kernel.org>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit 45939ce292b4b11159719faaf60aba7d58d5fe33 upstream.
It is possible for a system with an ARMv8 timer to run a 32-bit kernel.
When this happens we will unconditionally have the vDSO code remove the
__vdso_gettimeofday and __vdso_clock_gettime symbols because
cntvct_functional() returns false since it does not match that
compatibility string.
Fixes: ecf99a439105 ("ARM: 8331/1: VDSO initialization, mapping, and synchronization")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit f967140dfb7442e2db0868b03b961f9c59418a1b ]
Enable the sampling check in kernel/events/core.c::perf_event_open(),
which returns the more appropriate -EOPNOTSUPP.
BEFORE:
$ sudo perf record -a -e instructions,l3_request_g1.caching_l3_cache_accesses true
Error:
The sys_perf_event_open() syscall returned with 22 (Invalid argument) for event (l3_request_g1.caching_l3_cache_accesses).
/bin/dmesg | grep -i perf may provide additional information.
With nothing relevant in dmesg.
AFTER:
Error:
l3_request_g1.caching_l3_cache_accesses: PMU Hardware doesn't support sampling/overflow-interrupts. Try 'perf stat'
Fixes: c43ca5091a37 ("perf/x86/amd: Add support for AMD NB and L2I "uncore" counters")
Signed-off-by: Kim Phillips <kim.phillips@amd.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Link: https://lkml.kernel.org/r/20200311191323.13124-1-kim.phillips@amd.com
commit 8d92e992a785f35d23f845206cf8c6cafbc264e0 upstream.
The default defintions use fill pattern 0x90 for padding which for ARC
generates unintended "ldh_s r12,[r0,0x20]" corresponding to opcode 0x9090
So use ".align 4" which insert a "nop_s" instruction instead.
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit 342993f96ab24d5864ab1216f46c0b199c2baf8e upstream.
After commit 07721feee46b ("KVM: nVMX: Don't emulate instructions in guest
mode") Hyper-V guests on KVM stopped booting with:
kvm_nested_vmexit: rip fffff802987d6169 reason EPT_VIOLATION info1 181
info2 0 int_info 0 int_info_err 0
kvm_page_fault: address febd0000 error_code 181
kvm_emulate_insn: 0:fffff802987d6169: f3 a5
kvm_emulate_insn: 0:fffff802987d6169: f3 a5 FAIL
kvm_inj_exception: #UD (0x0)
"f3 a5" is a "rep movsw" instruction, which should not be intercepted
at all. Commit c44b4c6ab80e ("KVM: emulate: clean up initializations in
init_decode_cache") reduced the number of fields cleared by
init_decode_cache() claiming that they are being cleared elsewhere,
'intercept', however, is left uncleared if the instruction does not have
any of the "slow path" flags (NotImpl, Stack, Op3264, Sse, Mmx, CheckPerm,
NearBranch, No16 and of course Intercept itself).
Fixes: c44b4c6ab80e ("KVM: emulate: clean up initializations in init_decode_cache")
Fixes: 07721feee46b ("KVM: nVMX: Don't emulate instructions in guest mode")
Suggested-by: Paolo Bonzini <pbonzini@redhat.com>
commit fc37a1632d40c80c067eb1bc235139f5867a2667 upstream.
PowerVM systems running compatibility mode on a few Power8 revisions are
still vulnerable to the hardware defect that loses PMU exceptions arriving
prior to a context switch.
The software fix for this issue is enabled through the CPU_FTR_PMAO_BUG
cpu_feature bit, nevertheless this bit also needs to be set for PowerVM
compatibility mode systems.
Fixes: 68f2f0d431d9ea4 ("powerpc: Add a cpu feature CPU_FTR_PMAO_BUG")
Signed-off-by: Desnes A. Nunes do Rosario <desnesn@linux.ibm.com>
Reviewed-by: Leonardo Bras <leonardo@linux.ibm.com>
Link: https://lore.kernel.org/r/20200227134715.9715-1-desnesn@linux.ibm.com
commit 512a928affd51c2dc631401e56ad5ee5d5dd68b6 upstream.
This function is not only needed by the platform suspend code, but is also
reused as the CPU resume function when the ARM cores can be powered down
completely in deep idle, which is the case on i.MX6SX and i.MX6UL(L).
Providing the static inline stub whenever CONFIG_SUSPEND is disabled means
that those platforms will hang on resume from cpuidle if suspend is disabled.
So there are two problems:
- The static inline stub masks the linker error
- The function is not available where needed
Fix both by just building the function unconditionally, when
CONFIG_SOC_IMX6 is enabled. The actual code is three instructions long,
so it's arguably ok to just leave it in for all i.MX6 kernel configurations.
Fixes: 05136f0897b5 ("ARM: imx: support arm power off in cpuidle for i.mx6sx")
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Signed-off-by: Ahmad Fatoum <a.fatoum@pengutronix.de>
Signed-off-by: Rouven Czerwinski <r.czerwinski@pengutronix.de>
commit 7155c44624d061692b4c13aa8343f119c67d4fc0 upstream.
The difference between "fsl,etsec2-mdio" and "gianfar" has to do with
the .get_tbipa function, which calculates the address of the TBIPA
register automatically, if not explicitly specified. [ see
drivers/net/ethernet/freescale/fsl_pq_mdio.c ]. On LS1021A, the TBIPA
register is at offset 0x30 within the port register block, which is what
the "gianfar" method of calculating addresses actually does.
Luckily, the bad "compatible" is inconsequential for ls1021a.dtsi,
because the TBIPA register is explicitly specified via the second "reg"
(<0x0 0x2d10030 0x0 0x4>), so the "get_tbipa" function is dead code.
Nonetheless it's good to restore it to its correct value.
Background discussion:
https://www.spinics.net/lists/stable/msg361156.html
Fixes: c7861adbe37f ("ARM: dts: ls1021: Fix SGMII PCS link remaining down after PHY disconnect")
Reported-by: Pavel Machek <pavel@denx.de>
Signed-off-by: Vladimir Oltean <olteanv@gmail.com>
commit 735a6dd02222d8d070c7bb748f25895239ca8c92 upstream.
Explicitly set X86_FEATURE_OSPKE via set_cpu_cap() instead of calling
get_cpu_cap() to pull the feature bit from CPUID after enabling CR4.PKE.
Invoking get_cpu_cap() effectively wipes out any {set,clear}_cpu_cap()
changes that were made between this_cpu->c_init() and setup_pku(), as
all non-synthetic feature words are reinitialized from the CPU's CPUID
values.
Blasting away capability updates manifests most visibility when running
on a VMX capable CPU, but with VMX disabled by BIOS. To indicate that
VMX is disabled, init_ia32_feat_ctl() clears X86_FEATURE_VMX, using
clear_cpu_cap() instead of setup_clear_cpu_cap() so that KVM can report
which CPU is misconfigured (KVM needs to probe every CPU anyways).
Restoring X86_FEATURE_VMX from CPUID causes KVM to think VMX is enabled,
ultimately leading to an unexpected #GP when KVM attempts to do VMXON.
Arguably, init_ia32_feat_ctl() should use setup_clear_cpu_cap() and let
KVM figure out a different way to report the misconfigured CPU, but VMX
is not the only feature bit that is affected, i.e. there is precedent
that tweaking feature bits via {set,clear}_cpu_cap() after ->c_init()
is expected to work. Most notably, x86_init_rdrand()'s clearing of
X86_FEATURE_RDRAND when RDRAND malfunctions is also overwritten.
Fixes: 0697694564c8 ("x86/mm/pkeys: Actually enable Memory Protection Keys in the CPU")
Reported-by: Jacob Keller <jacob.e.keller@intel.com>
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Tested-by: Jacob Keller <jacob.e.keller@intel.com>
Link: https://lkml.kernel.org/r/20200226231615.13664-1-sean.j.christopherson@intel.com
commit bef8e2dfceed6daeb6ca3e8d33f9c9d43b926580 upstream.
Pointer on the memory allocated by 'alloc_progmem()' is stored in
'v->load_addr'. So this is this memory that should be freed by
'release_progmem()'.
'release_progmem()' is only a call to 'kfree()'.
With the current code, there is both a double free and a memory leak.
Fix it by passing the correct pointer to 'release_progmem()'.
Fixes: e01402b115ccc ("More AP / SP bits for the 34K, the Malta bits and things. Still wants")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Signed-off-by: Paul Burton <paulburton@kernel.org>
Cc: ralf@linux-mips.org
Cc: linux-mips@vger.kernel.org
Cc: kernel-janitors@vger.kernel.org
storage_key_init_range
commit 380324734956c64cd060e1db4304f3117ac15809 upstream.
Clang warns:
In file included from ../arch/s390/purgatory/purgatory.c:10:
In file included from ../include/linux/kexec.h:18:
In file included from ../include/linux/crash_core.h:6:
In file included from ../include/linux/elfcore.h:5:
In file included from ../include/linux/user.h:1:
In file included from ../arch/s390/include/asm/user.h:11:
../arch/s390/include/asm/page.h:45:6: warning: converting the result of
'<<' to a boolean always evaluates to false
[-Wtautological-constant-compare]
if (PAGE_DEFAULT_KEY)
../arch/s390/include/asm/page.h:23:44: note: expanded from macro
'PAGE_DEFAULT_KEY'
#define PAGE_DEFAULT_KEY (PAGE_DEFAULT_ACC << 4)
1 warning generated.
Explicitly compare this against zero to silence the warning as it is
intended to be used in a boolean context.
Fixes: de3fa841e429 ("s390/mm: fix compile for PAGE_DEFAULT_KEY != 0")
Link: https://github.com/ClangBuiltLinux/linux/issues/860
Link: https://lkml.kernel.org/r/20200214064207.10381-1-natechancellor@gmail.com
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit 23520b2def95205f132e167cf5b25c609975e959 upstream.
When pv_eoi_get_user() fails, 'val' may remain uninitialized and the return
value of pv_eoi_get_pending() becomes random. Fix the issue by initializing
the variable.
Signed-off-by: Miaohe Lin <linmiaohe@huawei.com>
commit 35a571346a94fb93b5b3b6a599675ef3384bc75c upstream.
Consult the 'unconditional IO exiting' and 'use IO bitmaps' VM-execution
controls when checking instruction interception. If the 'use IO bitmaps'
VM-execution control is 1, check the instruction access against the IO
bitmaps to determine if the instruction causes a VM-exit.
Signed-off-by: Oliver Upton <oupton@google.com>
commit e71237d3ff1abf9f3388337cfebf53b96df2020d upstream.
Checks against the IO bitmap are useful for both instruction emulation
and VM-exit reflection. Refactor the IO bitmap checks into a helper
function.
[ Upstream commit 07721feee46b4b248402133228235318199b05ec ]
vmx_check_intercept is not yet fully implemented. To avoid emulating
instructions disallowed by the L1 hypervisor, refuse to emulate
instructions by default.
[Made commit, added commit msg - Oliver]
commit 7455a8327674e1a7c9a1f5dd1b0743ab6713f6d1 upstream.
Commit 13db77347db1 ("KVM: x86: don't notify userspace IOAPIC on edge
EOI") said, edge-triggered interrupts don't set a bit in TMR, which means
that IOAPIC isn't notified on EOI. And var level indicates level-triggered
interrupt.
But commit 3159d36ad799 ("KVM: x86: use generic function for MSI parsing")
replace var level with irq.level by mistake. Fix it by changing irq.level
to irq.trig_mode.
Fixes: 3159d36ad799 ("KVM: x86: use generic function for MSI parsing")
commit 51dede9c05df2b78acd6dcf6a17d21f0877d2d7b upstream.
Accessing the MCA thresholding controls in sysfs concurrently with CPU
hotplug can lead to a couple of KASAN-reported issues:
BUG: KASAN: use-after-free in sysfs_file_ops+0x155/0x180
Read of size 8 at addr ffff888367578940 by task grep/4019
and
BUG: KASAN: use-after-free in show_error_count+0x15c/0x180
Read of size 2 at addr ffff888368a05514 by task grep/4454
for example. Both result from the fact that the threshold block
creation/teardown code frees the descriptor memory itself instead of
defining proper ->release function and leaving it to the driver core to
take care of that, after all sysfs accesses have completed.
Do that and get rid of the custom freeing code, fixing the above UAFs in
the process.
[ bp: write commit message. ]
Fixes: 95268664390b ("[PATCH] x86_64: mce_amd support for family 0x10 processors")
Link: https://lkml.kernel.org/r/20200214082801.13836-1-bp@alien8.de
commit 6e5cf31fbe651bed7ba1df768f2e123531132417 upstream.
threshold_create_bank() creates a bank descriptor per MCA error
thresholding counter which can be controlled over sysfs. It publishes
the pointer to that bank in a per-CPU variable and then goes on to
create additional thresholding blocks if the bank has such.
However, that creation of additional blocks in
allocate_threshold_blocks() can fail, leading to a use-after-free
through the per-CPU pointer.
Therefore, publish that pointer only after all blocks have been setup
successfully.
Fixes: 019f34fccfd5 ("x86, MCE, AMD: Move shared bank to node descriptor")
Reported-by: Saar Amar <Saar.Amar@microsoft.com>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Link: http://lkml.kernel.org/r/20200128140846.phctkvx5btiexvbx@kili.mountain
[ Upstream commit 061d2c1d593076424c910cb1b64ecdb5c9a6923f ]
In case the start + cache size is more than the max int the
start overflows.
Prevent the same.
Signed-off-by: Shubhrajyoti Datta <shubhrajyoti.datta@xilinx.com>
[ Upstream commit 76950f7162cad51d2200ebd22c620c14af38f718 ]
To perform the reserve_crashkernel() operation kexec uses SECTION_SIZE to
find a memblock in a range.
SECTION_SIZE is not defined for nommu systems. Trying to compile kexec in
these conditions results in a build error:
linux/arch/arm/kernel/setup.c: In function ‘reserve_crashkernel’:
linux/arch/arm/kernel/setup.c:1016:25: error: ‘SECTION_SIZE’ undeclared
(first use in this function); did you mean ‘SECTIONS_WIDTH’?
crash_size, SECTION_SIZE);
SECTIONS_WIDTH
linux/arch/arm/kernel/setup.c:1016:25: note: each undeclared identifier
is reported only once for each function it appears in
linux/scripts/Makefile.build:265: recipe for target 'arch/arm/kernel/setup.o'
failed
Make KEXEC depend on MMU to fix the compilation issue.
Signed-off-by: Vincenzo Frascino <vincenzo.frascino@arm.com>
[ Upstream commit 1fb4124ca9d456656a324f1ee29b7bf942f59ac8 ]
When disabling virtual functions on an SR-IOV adapter we currently do not
correctly remove the EEH state for the now-dead virtual functions. When
removing the pci_dn that was created for the VF when SR-IOV was enabled
we free the corresponding eeh_dev without removing it from the child device
list of the eeh_pe that contained it. This can result in crashes due to the
use-after-free.
Signed-off-by: Oliver O'Halloran <oohall@gmail.com>
Reviewed-by: Sam Bobroff <sbobroff@linux.ibm.com>
Tested-by: Sam Bobroff <sbobroff@linux.ibm.com>
Link: https://lore.kernel.org/r/20190821062655.19735-1-oohall@gmail.com
[ Upstream commit 45f7a0da600d3c409b5ad8d5ddddacd98ddc8840 ]
Currently backtrace from ftraced function does not contain ftraced
function itself. e.g. for "path_openat":
arch_stack_walk+0x15c/0x2d8
stack_trace_save+0x50/0x68
stack_trace_call+0x15e/0x3d8
ftrace_graph_caller+0x0/0x1c <-- ftrace code
do_filp_open+0x7c/0xe8 <-- ftraced function caller
do_open_execat+0x76/0x1b8
open_exec+0x52/0x78
load_elf_binary+0x180/0x1160
search_binary_handler+0x8e/0x288
load_script+0x2a8/0x2b8
__do_execve_file.isra.39+0x6fa/0xb40
__s390x_sys_execve+0x56/0x68
system_call+0xdc/0x2d8
Ftraced function is expected in the backtrace by ftrace kselftests, which
are now failing. It would also be nice to have it for clarity reasons.
"ftrace_caller" itself is called without stack frame allocated for it
and does not store its caller (ftraced function). Instead it simply
allocates a stack frame for "ftrace_trace_function" and sets backchain
to point to ftraced function stack frame (which contains ftraced function
caller in saved r14).
To fix this issue make "ftrace_caller" allocate a stack frame
for itself just to store ftraced function for the stack unwinder.
As a result backtrace looks like the following:
path_openat+0x6/0xd60 <-- ftraced function
open_exec+0x52/0x78
Reported-by: Sven Schnelle <sven.schnelle@ibm.com>
Tested-by: Sven Schnelle <sven.schnelle@ibm.com>
