commit ff7f3efb9abf986f4ecd8793a9593f7ca4d6431a upstream.
The current Tilera boot infrastructure now provides the initramfs
to Linux as a Tilera-hypervisor file named "initramfs", rather than
"initramfs.cpio.gz", as before. (This makes it reasonable to use
other compression techniques than gzip on the file without having to
worry about the name causing confusion.) Adapt to use the new name,
but also fall back to checking for the old name.
Cc'ing to stable so that older kernels will remain compatible with
newer Tilera boot infrastructure.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
[bwh: Backported to 3.2: adjust context]
flush_signal_handlers() needs to know whether sigaction::sa_restorer
is defined, not whether SA_RESTORER is defined. Define the
__ARCH_HAS_SA_RESTORER macro to indicate this.
Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side
struct sigaction declarations'.
commit 66db3feb486c01349f767b98ebb10b0c3d2d021b upstream.
The increment of "to" in copy_user_handle_tail() will have incremented
before a failure has been noted. This causes us to skip a byte in the
failure case.
Only do the increment when assured there is no failure.
Signed-off-by: CQ Tang <cq.tang@intel.com>
Link: http://lkml.kernel.org/r/20130318150221.8439.993.stgit@phlsvslse11.ph.intel.com
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
commit d63ac5f6cf31c8a83170a9509b350c1489a7262b upstream.
Commit 44ae3ab3358e962039c36ad4ae461ae9fb29596c forgot to update
the entry for the 970MP rev 1.0 processor when moving some CPU
features bits to the MMU feature bit mask. This breaks booting
on some rare G5 models using that chip revision.
Reported-by: Phileas Fogg <phileas-fogg@mail.ru>
commit f6a70a07079518280022286a1dceb797d12e1edf upstream.
Our flush_tlb_kernel_range() implementation calls __tlb_flush_mm() with
&init_mm as argument. __tlb_flush_mm() however will only flush tlbs
for the passed in mm if its mm_cpumask is not empty.
For the init_mm however its mm_cpumask has never any bits set. Which in
turn means that our flush_tlb_kernel_range() implementation doesn't
work at all.
This can be easily verified with a vmalloc/vfree loop which allocates
a page, writes to it and then frees the page again. A crash will follow
almost instantly.
To fix this remove the cpumask_empty() check in __tlb_flush_mm() since
there shouldn't be too many mms with a zero mm_cpumask, besides the
init_mm of course.
commit 2a6e06b2aed6995af401dcd4feb5e79a0c7ea554 upstream.
Commit 1d9d8639c063 ("perf,x86: fix kernel crash with PEBS/BTS after
suspend/resume") fixed a crash when doing PEBS performance profiling
after resuming, but in using init_debug_store_on_cpu() to restore the
DS_AREA mtrr it also resulted in a new WARN_ON() triggering.
init_debug_store_on_cpu() uses "wrmsr_on_cpu()", which in turn uses CPU
cross-calls to do the MSR update. Which is not really valid at the
early resume stage, and the warning is quite reasonable. Now, it all
happens to _work_, for the simple reason that smp_call_function_single()
ends up just doing the call directly on the CPU when the CPU number
matches, but we really should just do the wrmsr() directly instead.
This duplicates the wrmsr() logic, but hopefully we can just remove the
wrmsr_on_cpu() version eventually.
Reported-and-tested-by: Parag Warudkar <parag.lkml@gmail.com>
commit 1d9d8639c063caf6efc2447f5f26aa637f844ff6 upstream.
This patch fixes a kernel crash when using precise sampling (PEBS)
after a suspend/resume. Turns out the CPU notifier code is not invoked
on CPU0 (BP). Therefore, the DS_AREA (used by PEBS) is not restored properly
by the kernel and keeps it power-on/resume value of 0 causing any PEBS
measurement to crash when running on CPU0.
The workaround is to add a hook in the actual resume code to restore
the DS Area MSR value. It is invoked for all CPUS. So for all but CPU0,
the DS_AREA will be restored twice but this is harmless.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Stephane Eranian <eranian@google.com>
commit f2fe09b055e2549de41fb107b34c60bac4a1b0cf upstream.
Masked out PMXEVTYPER.NSH means that we can't enable profiling at PL2,
regardless of the settings in the HDCR.
This patch fixes the broken mask.
Reported-by: Christoffer Dall <cdall@cs.columbia.edu>
commit 884ac2978a295b7df3c4a686d3bff6932bbbb460 upstream.
There is no hypercall to setup multiple MSI per PCI device.
As such with these two new commits:
- 08261d87f7d1b6253ab3223756625a5c74532293
PCI/MSI: Enable multiple MSIs with pci_enable_msi_block_auto()
- 5ca72c4f7c412c2002363218901eba5516c476b1
AHCI: Support multiple MSIs
we would call the PHYSDEVOP_map_pirq 'nvec' times with the same
contents of the PCI device. Sander discovered that we would get
the same PIRQ value 'nvec' times and return said values to the
caller. That of course meant that the device was configured only
with one MSI and AHCI would fail with:
ahci 0000:00:11.0: version 3.0
xen: registering gsi 19 triggering 0 polarity 1
xen: --> pirq=19 -> irq=19 (gsi=19)
(XEN) [2013-02-27 19:43:07] IOAPIC[0]: Set PCI routing entry (6-19 -> 0x99 -> IRQ 19 Mode:1 Active:1)
ahci 0000:00:11.0: AHCI 0001.0200 32 slots 4 ports 6 Gbps 0xf impl SATA mode
ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part
ahci: probe of 0000:00:11.0 failed with error -22
That is b/c in ahci_host_activate the second call to
devm_request_threaded_irq would return -EINVAL as we passed in
(on the second run) an IRQ that was never initialized.
Reported-and-Tested-by: Sander Eikelenboom <linux@eikelenboom.it>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit b255188f90e2bade1bd11a986dd1ca4861869f4d upstream.
Paolo Pisati reports that IPv6 triggers this warning:
BUG: scheduling while atomic: swapper/0/0/0x40000100
Modules linked in:
[<c001b1c4>] (unwind_backtrace+0x0/0xf0) from [<c0503c5c>] (__schedule_bug+0x48/0x5c)
[<c0503c5c>] (__schedule_bug+0x48/0x5c) from [<c0508608>] (__schedule+0x700/0x740)
[<c0508608>] (__schedule+0x700/0x740) from [<c007007c>] (__cond_resched+0x24/0x34)
[<c007007c>] (__cond_resched+0x24/0x34) from [<c05086dc>] (_cond_resched+0x3c/0x44)
[<c05086dc>] (_cond_resched+0x3c/0x44) from [<c0021f6c>] (do_alignment+0x178/0x78c)
[<c0021f6c>] (do_alignment+0x178/0x78c) from [<c00083e0>] (do_DataAbort+0x34/0x98)
[<c00083e0>] (do_DataAbort+0x34/0x98) from [<c0509a60>] (__dabt_svc+0x40/0x60)
Exception stack(0xc0763d70 to 0xc0763db8)
3d60: e97e805e e97e806e 2c000000 11000000
3d80: ea86bb00 0000002c 00000011 e97e807e c076d2a8 e97e805e e97e806e 0000002c
3da0: 3d000000 c0763dbc c04b98fc c02a8490 00000113 ffffffff
[<c0509a60>] (__dabt_svc+0x40/0x60) from [<c02a8490>] (__csum_ipv6_magic+0x8/0xc8)
Fix this by using probe_kernel_address() stead of __get_user().
Reported-by: Paolo Pisati <p.pisati@gmail.com>
Tested-by: Paolo Pisati <p.pisati@gmail.com>
commit 5e4ba617c1b584b2e376f31a63bd4e734109318a upstream.
Martin Storsjö reports that the sequence:
ee312ac1 vsub.f32 s4, s3, s2
ee702ac0 vsub.f32 s5, s1, s0
e59f0028 ldr r0, [pc, #40]
ee111a90 vmov r1, s3
on Raspberry Pi (implementor 41 architecture 1 part 20 variant b rev 5)
where s3 is a denormal and s2 is zero results in incorrect behaviour -
the instruction "vsub.f32 s5, s1, s0" is not executed:
VFP: bounce: trigger ee111a90 fpexc d0000780
VFP: emulate: INST=0xee312ac1 SCR=0x00000000
As we can see, the instruction triggering the exception is the "vmov"
instruction, and we emulate the "vsub.f32 s4, s3, s2" but fail to
properly take account of the FPEXC_FP2V flag in FPEXC. This is because
the test for the second instruction register being valid is bogus, and
will always skip emulation of the second instruction.
Reported-by: Martin Storsjö <martin@martin.st>
Tested-by: Martin Storsjö <martin@martin.st>
This reverts commit 066f289835f09a3f744d6bac96f25e25d20b3ded which was
6a040ce72598159a74969a2d01ab0ba5ee6536b3 upstream.
This was not needed and is not suitable for 3.2.y.
Reported-by: Michael Neuling <mikey@neuling.org>
commit d911e03d097bdc01363df5d81c43f69432eb785c upstream.
Since ed4f209 "s390/time: fix sched_clock() overflow" a new helper function
is used to avoid overflows when converting TOD format values to nanosecond
values.
The kvm interrupt code formerly however only worked by accident because of
an overflow. It tried to program a timer that would expire in more than ~29
years. Because of the old TOD-to-nanoseconds overflow bug the real expiry
value however was much smaller, but now it isn't anymore.
This however triggers yet another bug in the function that programs the clock
comparator s390_next_ktime(): if the absolute "expires" value is after 2042
this will result in an overflow and the programmed value is lower than the
current TOD value which immediatly triggers a clock comparator (= timer)
interrupt.
Since the timer isn't expired it will be programmed immediately again and so
on... the result is a dead system.
To fix this simply program the maximum possible value if an overflow is
detected.
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit 7c10093692ed2e6f318387d96b829320aa0ca64c upstream.
On non-BIOS platforms it is possible that the BIOS data area contains
garbage instead of being zeroed or something equivalent (firmware
people: we are talking of 1.5K here, so please do the sane thing.)
We need on the order of 20-30K of low memory in order to boot, which
may grow up to < 64K in the future. We probably want to avoid the
lowest of the low memory. At the same time, it seems extremely
unlikely that a legitimate EBDA would ever reach down to the 128K
(which would require it to be over half a megabyte in size.) Thus,
pick 128K as the cutoff for "this is insane, ignore." We may still
end up reserving a bunch of extra memory on the low megabyte, but that
is not really a major issue these days. In the worst case we lose
512K of RAM.
This code really should be merged with trim_bios_range() in
arch/x86/kernel/setup.c, but that is a bigger patch for a later merge
window.
Reported-by: Darren Hart <dvhart@linux.intel.com>
Cc: Matt Fleming <matt.fleming@intel.com>
Link: http://lkml.kernel.org/n/tip-oebml055yyfm8yxmria09rja@git.kernel.org
commit 8520e443aa56cc157b015205ea53e7b9fc831291 upstream.
Disable hard IRQ before kexec a new kernel image.
Not doing it can result in corrupted data in the memory segments
reserved for the new kernel.
Signed-off-by: Phileas Fogg <phileas-fogg@mail.ru>
commit fb834c7acc5e140cf4f9e86da93a66de8c0514da upstream.
commit 1de63d60cd5b ("efi: Clear EFI_RUNTIME_SERVICES rather than
EFI_BOOT by "noefi" boot parameter") attempted to make "noefi" true to
its documentation and disable EFI runtime services to prevent the
bricking bug described in commit e0094244e41c ("samsung-laptop:
Disable on EFI hardware"). However, it's not possible to clear
EFI_RUNTIME_SERVICES from an early param function because
EFI_RUNTIME_SERVICES is set in efi_init() *after* parse_early_param().
This resulted in "noefi" effectively becoming a no-op and no longer
providing users with a way to disable EFI, which is bad for those
users that have buggy machines.
Reported-by: Walt Nelson Jr <walt0924@gmail.com>
Cc: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Link: http://lkml.kernel.org/r/1361392572-25657-1-git-send-email-matt@console-pimps.org
[bwh: Backported to 3.2: efi_runtime_init() is not a separate function,
so put a whole set of statements in an if (!disable_runtime) block]
commit 76eaca031f0af2bb303e405986f637811956a422 upstream.
There is a loophole between Xen's current implementation of
pv-spinlocks and the scheduler. This was triggerable through
a testcase until v3.6 changed the TLB flushing code. The
problem potentially is still there just not observable in the
same way.
What could happen was (is):
1. CPU n tries to schedule task x away and goes into a slow
wait for the runq lock of CPU n-# (must be one with a lower
number).
2. CPU n-#, while processing softirqs, tries to balance domains
and goes into a slow wait for its own runq lock (for updating
some records). Since this is a spin_lock_irqsave in softirq
context, interrupts will be re-enabled for the duration of
the poll_irq hypercall used by Xen.
3. Before the runq lock of CPU n-# is unlocked, CPU n-1 receives
an interrupt (e.g. endio) and when processing the interrupt,
tries to wake up task x. But that is in schedule and still
on_cpu, so try_to_wake_up goes into a tight loop.
4. The runq lock of CPU n-# gets unlocked, but the message only
gets sent to the first waiter, which is CPU n-# and that is
busily stuck.
5. CPU n-# never returns from the nested interruption to take and
release the lock because the scheduler uses a busy wait.
And CPU n never finishes the task migration because the unlock
notification only went to CPU n-#.
To avoid this and since the unlocking code has no real sense of
which waiter is best suited to grab the lock, just send the IPI
to all of them. This causes the waiters to return from the hyper-
call (those not interrupted at least) and do active spinlocking.
BugLink: http://bugs.launchpad.net/bugs/1011792
Acked-by: Jan Beulich <JBeulich@suse.com>
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
commit fa5ce5f94c0f2bfa41ba68d2d2524298e1fc405e upstream.
New ARM binutils don't allow extraneous whitespace inside
of brackets, which causes this error on all mach-w90x900
defconfigs:
arch/arm/kernel/entry-armv.S: Assembler messages:
arch/arm/kernel/entry-armv.S:214: Error: ARM register expected -- `ldr r0,[ r6,#(0x10C)]'
arch/arm/kernel/entry-armv.S:214: Error: ARM register expected -- `ldr r0,[ r6,#(0x110)]'
arch/arm/kernel/entry-armv.S:430: Error: ARM register expected -- `ldr r0,[ r6,#(0x10C)]'
arch/arm/kernel/entry-armv.S:430: Error: ARM register expected -- `ldr r0,[ r6,#(0x110)]'
This removes the whitespace in order to build the kernel
again.
Cc: Wan ZongShun <mcuos.com@gmail.com>
commit 2815774bb38445006074e16251b9ef5123bdc616 upstream.
Recent assembler versions complain about extraneous
whitespace inside [] brackets. This fixes all of
these instances for the samsung platforms. We should
backport this to all kernels that might need to
be built with new binutils.
arch/arm/kernel/entry-armv.S:214: Error: ARM register expected -- `ldr r2,[ r6,#(0x10)]'
arch/arm/kernel/entry-armv.S:214: Error: ARM register expected -- `ldr r0,[ r6,#(0x14)]'
arch/arm/kernel/entry-armv.S:430: Error: ARM register expected -- `ldr r2,[ r6,#(0x10)]'
arch/arm/kernel/entry-armv.S:430: Error: ARM register expected -- `ldr r0,[ r6,#(0x14)]'
arch/arm/mach-s3c24xx/sleep-s3c2410.S: Assembler messages:
arch/arm/mach-s3c24xx/sleep-s3c2410.S:48: Error: ARM register expected -- `ldr r7,[ r4 ]'
arch/arm/mach-s3c24xx/sleep-s3c2410.S:49: Error: ARM register expected -- `ldr r8,[ r5 ]'
arch/arm/mach-s3c24xx/sleep-s3c2410.S:50: Error: ARM register expected -- `ldr r9,[ r6 ]'
arch/arm/mach-s3c24xx/sleep-s3c2410.S:64: Error: ARM register expected -- `streq r7,[ r4 ]'
arch/arm/mach-s3c24xx/sleep-s3c2410.S:65: Error: ARM register expected -- `streq r8,[ r5 ]'
arch/arm/mach-s3c24xx/sleep-s3c2410.S:66: Error: ARM register expected -- `streq r9,[ r6 ]'
arch/arm/kernel/debug.S: Assembler messages:
arch/arm/kernel/debug.S:83: Error: ARM register expected -- `ldr r2,[ r2,#((0x0B0)+(((0x56000000)-(0x50000000))+(0xF6000000+(0x01000000))))-((0)+(((0x56000000)-(0x50000000))+(0xF6000000+(0x01000000))))]'
arch/arm/kernel/debug.S:83: Error: ARM register expected -- `ldr r2,[ r3,#(0x18)]'
arch/arm/kernel/debug.S:85: Error: ARM register expected -- `ldr r2,[ r2,#((0x0B0)+(((0x56000000)-(0x50000000))+(0xF6000000+(0x01000000))))-((0)+(((0x56000000)-(0x50000000))+(0xF6000000+(0x01000000))))]'
arch/arm/kernel/debug.S:85: Error: ARM register expected -- `ldr r2,[ r3,#(0x18)]'
arch/arm/mach-s3c24xx/pm-h1940.S: Assembler messages:
arch/arm/mach-s3c24xx/pm-h1940.S:33: Error: ARM register expected -- `ldr pc,[ r0,#((0x0B8)+(((0x56000000)-(0x50000000))+(0xF6000000+(0x01000000))))-(((0x56000000)-(0x50000000))+(0xF6000000+(0x01000000)))]'
arch/arm/mach-s3c24xx/sleep-s3c2412.S: Assembler messages:
arch/arm/mach-s3c24xx/sleep-s3c2412.S:60: Error: ARM register expected -- `ldrne r9,[ r1 ]'
arch/arm/mach-s3c24xx/sleep-s3c2412.S:61: Error: ARM register expected -- `strne r9,[ r1 ]'
arch/arm/mach-s3c24xx/sleep-s3c2412.S:62: Error: ARM register expected -- `ldrne r9,[ r2 ]'
arch/arm/mach-s3c24xx/sleep-s3c2412.S:63: Error: ARM register expected -- `strne r9,[ r2 ]'
arch/arm/mach-s3c24xx/sleep-s3c2412.S:64: Error: ARM register expected -- `ldrne r9,[ r3 ]'
arch/arm/mach-s3c24xx/sleep-s3c2412.S:65: Error: ARM register expected -- `strne r9,[ r3 ]'
arch/arm/kernel/debug.S:83: Error: ARM register expected -- `ldr r2,[ r3,#(0x08)]'
arch/arm/kernel/debug.S:83: Error: ARM register expected -- `ldr r2,[ r3,#(0x10)]'
arch/arm/kernel/debug.S:85: Error: ARM register expected -- `ldr r2,[ r3,#(0x08)]'
arch/arm/kernel/debug.S:85: Error: ARM register expected -- `ldr r2,[ r3,#(0x10)]'
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Cc: Ben Dooks <ben-linux@fluff.org>
[bwh: Backported to 3.2: adjust filenames]
commit 1de63d60cd5b0d33a812efa455d5933bf1564a51 upstream.
There was a serious problem in samsung-laptop that its platform driver is
designed to run under BIOS and running under EFI can cause the machine to
become bricked or can cause Machine Check Exceptions.
Discussion about this problem:
https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557
https://bugzilla.kernel.org/show_bug.cgi?id=47121
The patches to fix this problem:
efi: Make 'efi_enabled' a function to query EFI facilities
83e68189745ad931c2afd45d8ee3303929233e7f
samsung-laptop: Disable on EFI hardware
e0094244e41c4d0c7ad69920681972fc45d8ce34
Unfortunately this problem comes back again if users specify "noefi" option.
This parameter clears EFI_BOOT and that driver continues to run even if running
under EFI. Refer to the document, this parameter should clear
EFI_RUNTIME_SERVICES instead.
Documentation/kernel-parameters.txt:
noefi [X86] Disable EFI runtime services support.
Documentation/x86/x86_64/uefi.txt:
- If some or all EFI runtime services don't work, you can try following
kernel command line parameters to turn off some or all EFI runtime
services.
noefi turn off all EFI runtime services
Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com>
Link: http://lkml.kernel.org/r/511C2C04.2070108@jp.fujitsu.com
commit 0ee364eb316348ddf3e0dfcd986f5f13f528f821 upstream.
A user reported the following oops when a backup process reads
/proc/kcore:
BUG: unable to handle kernel paging request at ffffbb00ff33b000
IP: [<ffffffff8103157e>] kern_addr_valid+0xbe/0x110
Call Trace:
[<ffffffff811b8aaa>] read_kcore+0x17a/0x370
[<ffffffff811ad847>] proc_reg_read+0x77/0xc0
[<ffffffff81151687>] vfs_read+0xc7/0x130
[<ffffffff811517f3>] sys_read+0x53/0xa0
[<ffffffff81449692>] system_call_fastpath+0x16/0x1b
Investigation determined that the bug triggered when reading
system RAM at the 4G mark. On this system, that was the first
address using 1G pages for the virt->phys direct mapping so the
PUD is pointing to a physical address, not a PMD page.
The problem is that the page table walker in kern_addr_valid() is
not checking pud_large() and treats the physical address as if
it was a PMD. If it happens to look like pmd_none then it'll
silently fail, probably returning zeros instead of real data. If
the data happens to look like a present PMD though, it will be
walked resulting in the oops above.
This patch adds the necessary pud_large() check.
Unfortunately the problem was not readily reproducible and now
they are running the backup program without accessing
/proc/kcore so the patch has not been validated but I think it
makes sense.
Reviewed-by: Rik van Riel <riel@redhat.coM>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20130211145236.GX21389@suse.de
commit 32068f6527b8f1822a30671dedaf59c567325026 upstream.
Enable hyperv_clocksource only if its advertised as a feature.
XenServer 6 returns the signature which is checked in
ms_hyperv_platform(), but it does not offer all features. Currently the
clocksource is enabled unconditionally in ms_hyperv_init_platform(), and
the result is a hanging guest.
Hyper-V spec Bit 1 indicates the availability of Partition Reference
Counter. Register the clocksource only if this bit is set.
The guest in question prints this in dmesg:
[ 0.000000] Hypervisor detected: Microsoft HyperV
[ 0.000000] HyperV: features 0x70, hints 0x0
This bug can be reproduced easily be setting 'viridian=1' in a HVM domU
.cfg file. A workaround without this patch is to boot the HVM guest with
'clocksource=jiffies'.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Link: http://lkml.kernel.org/r/1359940959-32168-1-git-send-email-kys@microsoft.com
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
commit cb214ede7657db458fd0b2a25ea0b28dbf900ebc upstream.
When a HP ProLiant DL980 G7 Server boots a regular kernel,
there will be intermittent lost interrupts which could
result in a hang or (in extreme cases) data loss.
The reason is that this system only supports x2apic physical
mode, while the kernel boots with a logical-cluster default
setting.
This bug can be worked around by specifying the "x2apic_phys" or
"nox2apic" boot option, but we want to handle this system
without requiring manual workarounds.
The BIOS sets ACPI_FADT_APIC_PHYSICAL in FADT table.
As all apicids are smaller than 255, BIOS need to pass the
control to the OS with xapic mode, according to x2apic-spec,
chapter 2.9.
Current code handle x2apic when BIOS pass with xapic mode
enabled:
When user specifies x2apic_phys, or FADT indicates PHYSICAL:
1. During madt oem check, apic driver is set with xapic logical
or xapic phys driver at first.
2. enable_IR_x2apic() will enable x2apic_mode.
3. if user specifies x2apic_phys on the boot line, x2apic_phys_probe()
will install the correct x2apic phys driver and use x2apic phys mode.
Otherwise it will skip the driver will let x2apic_cluster_probe to
take over to install x2apic cluster driver (wrong one) even though FADT
indicates PHYSICAL, because x2apic_phys_probe does not check
FADT PHYSICAL.
Add checking x2apic_fadt_phys in x2apic_phys_probe() to fix the
problem.
Signed-off-by: Stoney Wang <song-bo.wang@hp.com>
[ updated the changelog and simplified the code ]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Link: http://lkml.kernel.org/r/1360263182-16226-1-git-send-email-yinghai@kernel.org
commit ea0dcf903e7d76aa5d483d876215fedcfdfe140f upstream.
Provide systems that do not support x2apic cluster mode
a mechanism to select x2apic physical mode using the
FADT FORCE_APIC_PHYSICAL_DESTINATION_MODE bit.
Changes from v1: (based on Suresh's comments)
- removed #ifdef CONFIG_ACPI
- removed #include <linux/acpi.h>
Signed-off-by: Greg Pearson <greg.pearson@hp.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Link: http://lkml.kernel.org/r/1335313436-32020-1-git-send-email-greg.pearson@hp.com
commit e575a86fdc50d013bf3ad3aa81d9100e8e6cc60d upstream.
Without this patch, it is trivial to determine kernel page
mappings by examining the error code reported to dmesg[1].
Instead, declare the entire kernel memory space as a violation
of a present page.
Additionally, since show_unhandled_signals is enabled by
default, switch branch hinting to the more realistic
expectation, and unobfuscate the setting of the PF_PROT bit to
improve readability.
[1] http://vulnfactory.org/blog/2013/02/06/a-linux-memory-trick/
Reported-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Suggested-by: Brad Spengler <spender@grsecurity.net>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Link: http://lkml.kernel.org/r/20130207174413.GA12485@www.outflux.net
commit f03574f2d5b2d6229dcdf2d322848065f72953c7 upstream.
This code was an optimization for 32-bit NUMA systems.
It has probably been the cause of a number of subtle bugs over
the years, although the conditions to excite them would have
been hard to trigger. Essentially, we remap part of the kernel
linear mapping area, and then sometimes part of that area gets
freed back in to the bootmem allocator. If those pages get
used by kernel data structures (say mem_map[] or a dentry),
there's no big deal. But, if anyone ever tried to use the
linear mapping for these pages _and_ cared about their physical
address, bad things happen.
For instance, say you passed __GFP_ZERO to the page allocator
and then happened to get handed one of these pages, it zero the
remapped page, but it would make a pte to the _old_ page.
There are probably a hundred other ways that it could screw
with things.
We don't need to hang on to performance optimizations for
these old boxes any more. All my 32-bit NUMA systems are long
dead and buried, and I probably had access to more than most
people.
This code is causing real things to break today:
https://lkml.org/lkml/2013/1/9/376
I looked in to actually fixing this, but it requires surgery
to way too much brittle code, as well as stuff like
per_cpu_ptr_to_phys().
[ hpa: Cc: this for -stable, since it is a memory corruption issue.
However, an alternative is to simply mark NUMA as depends BROKEN
rather than EXPERIMENTAL in the X86_32 subclause... ]
Link: http://lkml.kernel.org/r/20130131005616.1C79F411@kernel.stglabs.ibm.com
[bwh: For 3.2, using the suggested alternative]
commit 15bc8d8457875f495c59d933b05770ba88d1eacb upstream.
On store status we need to copy the current state of registers
into a save area. Currently we might save stale versions:
The sie state descriptor doesnt have fields for guest ACRS,FPRS,
those registers are simply stored in the host registers. The host
program must copy these away if needed. We do that in vcpu_put/load.
If we now do a store status in KVM code between vcpu_put/load, the
saved values are not up-to-date. Lets collect the ACRS/FPRS before
saving them.
This also fixes some strange problems with hotplug and virtio-ccw,
since the low level machine check handler (on hotplug a machine check
will happen) will revalidate all registers with the content of the
save area.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
[bwh: Backported to 3.2 as done in 3.0 by Jiri Slaby]
Cc: Jiri Slaby <jslaby@suse.cz>
commit d107a204154ddd79339203c2deeb7433f0cf6777 upstream.
The Chip Select Configuration Register must be programmed to 0x2 in
order to achieve the correct behavior of the Static Memory Controller.
Without this patch devices wired to DFI and accessed through SMC cannot
be accessed after resume from S2.
Do not rely on the boot loader to program the CSMSADRCFG register by
programming it in the kernel smemc module.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
commit 7139bc1579901b53db7e898789e916ee2fb52d78 upstream.
This patch goes a long way toward fixing the minifail bug, and
it significantly improves the stability of SMP machines such as
the rp3440. When write protecting a page for COW, we need to
purge the existing translation. Otherwise, the COW break
doesn't occur as expected because the TLB may still have a stale entry
which allows writes.
[jejb: fix up checkpatch errors]
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 6a040ce72598159a74969a2d01ab0ba5ee6536b3 upstream.
The DDW code uses a eeh_dev struct from the pci_dev. However, this is
not set until eeh_add_device_late is called.
Since pci_bus_add_devices is called before eeh_add_device_late, the PCI
devices are added to the bus, making drivers' probe hooks to be called.
These will call set_dma_mask, which will call the DDW code, which will
require the eeh_dev struct from pci_dev. This would result in a crash,
due to a NULL dereference.
Calling eeh_add_device_late after pci_bus_add_devices would make the
system BUG, because device files shouldn't be added to devices there
were not added to the system. So, a new function is needed to add such
files only after pci_bus_add_devices have been called.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
Acked-by: Gavin Shan <shangw@linux.vnet.ibm.com>
commit 13d2b4d11d69a92574a55bfd985cfb0ca77aebdc upstream.
This fixes CVE-2013-0228 / XSA-42
Drew Jones while working on CVE-2013-0190 found that that unprivileged guest user
in 32bit PV guest can use to crash the > guest with the panic like this:
general protection fault: 0000 [#1] SMP
last sysfs file: /sys/devices/vbd-51712/block/xvda/dev
Modules linked in: sunrpc ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4
iptable_filter ip_tables ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6
xt_state nf_conntrack ip6table_filter ip6_tables ipv6 xen_netfront ext4
mbcache jbd2 xen_blkfront dm_mirror dm_region_hash dm_log dm_mod [last
unloaded: scsi_wait_scan]
Pid: 1250, comm: r Not tainted 2.6.32-356.el6.i686 #1
EIP: 0061:[<c0407462>] EFLAGS: 00010086 CPU: 0
EIP is at xen_iret+0x12/0x2b
EAX: eb8d0000 EBX: 00000001 ECX: 08049860 EDX: 00000010
ESI: 00000000 EDI: 003d0f00 EBP: b77f8388 ESP: eb8d1fe0
DS: 0000 ES: 007b FS: 0000 GS: 00e0 SS: 0069
Process r (pid: 1250, ti=eb8d0000 task=c2953550 task.ti=eb8d0000)
Stack:
00000000 0027f416 00000073 00000206 b77f8364 0000007b 00000000 00000000
Call Trace:
Code: c3 8b 44 24 18 81 4c 24 38 00 02 00 00 8d 64 24 30 e9 03 00 00 00
8d 76 00 f7 44 24 08 00 00 02 80 75 33 50 b8 00 e0 ff ff 21 e0 <8b> 40
10 8b 04 85 a0 f6 ab c0 8b 80 0c b0 b3 c0 f6 44 24 0d 02
EIP: [<c0407462>] xen_iret+0x12/0x2b SS:ESP 0069:eb8d1fe0
general protection fault: 0000 [#2]
---[ end trace ab0d29a492dcd330 ]---
Kernel panic - not syncing: Fatal exception
Pid: 1250, comm: r Tainted: G D ---------------
Call Trace:
[<c08476df>] ? panic+0x6e/0x122
[<c084b63c>] ? oops_end+0xbc/0xd0
[<c084b260>] ? do_general_protection+0x0/0x210
[<c084a9b7>] ? error_code+0x73/
Petr says: "
I've analysed the bug and I think that xen_iret() cannot cope with
mangled DS, in this case zeroed out (null selector/descriptor) by either
xen_failsafe_callback() or RESTORE_REGS because the corresponding LDT
entry was invalidated by the reproducer. "
Jan took a look at the preliminary patch and came up a fix that solves
this problem:
"This code gets called after all registers other than those handled by
IRET got already restored, hence a null selector in %ds or a non-null
one that got loaded from a code or read-only data descriptor would
cause a kernel mode fault (with the potential of crashing the kernel
as a whole, if panic_on_oops is set)."
The way to fix this is to realize that the we can only relay on the
registers that IRET restores. The two that are guaranteed are the
%cs and %ss as they are always fixed GDT selectors. Also they are
inaccessible from user mode - so they cannot be altered. This is
the approach taken in this patch.
Another alternative option suggested by Jan would be to relay on
the subtle realization that using the %ebp or %esp relative references uses
the %ss segment. In which case we could switch from using %eax to %ebp and
would not need the %ss over-rides. That would also require one extra
instruction to compensate for the one place where the register is used
as scaled index. However Andrew pointed out that is too subtle and if
further work was to be done in this code-path it could escape folks attention
and lead to accidents.
Reviewed-by: Petr Matousek <pmatouse@redhat.com>
Reported-by: Petr Matousek <pmatouse@redhat.com>
Reviewed-by: Andrew Cooper <andrew.cooper3@citrix.com>
Signed-off-by: Jan Beulich <jbeulich@suse.com>
commit 9899d11f654474d2d54ea52ceaa2a1f4db3abd68 upstream.
putreg() assumes that the tracee is not running and pt_regs_access() can
safely play with its stack. However a killed tracee can return from
ptrace_stop() to the low-level asm code and do RESTORE_REST, this means
that debugger can actually read/modify the kernel stack until the tracee
does SAVE_REST again.
set_task_blockstep() can race with SIGKILL too and in some sense this
race is even worse, the very fact the tracee can be woken up breaks the
logic.
As Linus suggested we can clear TASK_WAKEKILL around the arch_ptrace()
call, this ensures that nobody can ever wakeup the tracee while the
debugger looks at it. Not only this fixes the mentioned problems, we
can do some cleanups/simplifications in arch_ptrace() paths.
Probably ptrace_unfreeze_traced() needs more callers, for example it
makes sense to make the tracee killable for oom-killer before
access_process_vm().
While at it, add the comment into may_ptrace_stop() to explain why
ptrace_stop() still can't rely on SIGKILL and signal_pending_state().
Reported-by: Salman Qazi <sqazi@google.com>
Reported-by: Suleiman Souhlal <suleiman@google.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 95cf00fa5d5e2a200a2c044c84bde8389a237e02 upstream.
Afaics the usage of update_debugctlmsr() and TIF_BLOCKSTEP in
step.c was always very wrong.
1. update_debugctlmsr() was simply unneeded. The child sleeps
TASK_TRACED, __switch_to_xtra(next_p => child) should notice
TIF_BLOCKSTEP and set/clear DEBUGCTLMSR_BTF after resume if
needed.
2. It is wrong. The state of DEBUGCTLMSR_BTF bit in CPU register
should always match the state of current's TIF_BLOCKSTEP bit.
3. Even get_debugctlmsr() + update_debugctlmsr() itself does not
look right. Irq can change other bits in MSR_IA32_DEBUGCTLMSR
register or the caller can be preempted in between.
4. It is not safe to play with TIF_BLOCKSTEP if task != current.
DEBUGCTLMSR_BTF and TIF_BLOCKSTEP should always match each
other if the task is running. The tracee is stopped but it
can be SIGKILL'ed right before set/clear_tsk_thread_flag().
However, now that uprobes uses user_enable_single_step(current)
we can't simply remove update_debugctlmsr(). So this patch adds
the additional "task == current" check and disables irqs to avoid
the race with interrupts/preemption.
Unfortunately this patch doesn't solve the last problem, we need
another fix. Probably we should teach ptrace_stop() to set/clear
single/block stepping after resume.
And afaics there is yet another problem: perf can play with
MSR_IA32_DEBUGCTLMSR from nmi, this obviously means that even
__switch_to_xtra() has problems.
commit 848e8f5f0ad3169560c516fff6471be65f76e69f upstream.
No functional changes, preparation for the next fix and for uprobes
single-step fixes.
Move the code playing with TIF_BLOCKSTEP/DEBUGCTLMSR_BTF into the
new helper, set_task_blockstep().
Acked-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
commit 40a1ef95da85843696fc3ebe5fce39b0db32669f upstream.
For some reason they didn't get replaced so far by their
paravirt equivalents, resulting in code to be run with
interrupts disabled that doesn't expect so (causing, in the
observed case, a BUG_ON() to trigger) when syscall auditing is
enabled.
David (Cc-ed) came up with an identical fix, so likely this can
be taken to count as an ack from him.
Reported-by: Peter Moody <pmoody@google.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/5108E01902000078000BA9C5@nat28.tlf.novell.com
Tested-by: Peter Moody <pmoody@google.com>
commit 712ba9e9afc4b3d3d6fa81565ca36fe518915c01 upstream.
efi.runtime_version is erroneously being set to the value of the
vendor's firmware revision instead of that of the implemented EFI
specification. We can't deduce which EFI functions are available based
on the revision of the vendor's firmware since the version scheme is
likely to be unique to each vendor.
What we really need to know is the revision of the implemented EFI
specification, which is available in the EFI System Table header.
Cc: Seiji Aguchi <seiji.aguchi@hds.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
commit c94082656dac74257f63e91f78d5d458ac781fa5 upstream.
The traps are referred to by their numbers and it can be difficult to
understand them while reading the code without context. This patch adds
enumeration of the trap numbers and replaces the numbers with the correct
enum for x86.
Link: http://lkml.kernel.org/r/20120310000710.GA32667@www.outflux.net
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cherry-picked-for: v2.3.37
Signed-off-by: John Kacur <jkacur@redhat.com>
commit e43b3cec711a61edf047adf6204d542f3a659ef8 upstream.
early_pci_allowed() and read_pci_config_16() are only available if
CONFIG_PCI is defined.
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
commit ab3cd8670e0b3fcde7f029e1503ed3c5138e9571 upstream.
Mark static arrays as __initconst so they get removed when the init
sections are flushed.
Reported-by: Mathias Krause <minipli@googlemail.com>
Link: http://lkml.kernel.org/r/75F4BEE6-CB0E-4426-B40B-697451677738@googlemail.com
commit a9acc5365dbda29f7be2884efb63771dc24bd815 upstream.
SNB graphics devices have a bug that prevent them from accessing certain
memory ranges, namely anything below 1M and in the pages listed in the
table. So reserve those at boot if set detect a SNB gfx device on the
CPU to avoid GPU hangs.
Stephane Marchesin had a similar patch to the page allocator awhile
back, but rather than reserving pages up front, it leaked them at
allocation time.
[ hpa: made a number of stylistic changes, marked arrays as static
const, and made less verbose; use "memblock=debug" for full
verbosity. ]
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 83e68189745ad931c2afd45d8ee3303929233e7f upstream.
Originally 'efi_enabled' indicated whether a kernel was booted from
EFI firmware. Over time its semantics have changed, and it now
indicates whether or not we are booted on an EFI machine with
bit-native firmware, e.g. 64-bit kernel with 64-bit firmware.
The immediate motivation for this patch is the bug report at,
which details how running a platform driver on an EFI machine that is
designed to run under BIOS can cause the machine to become
bricked. Also, the following report,
details how running said driver can also cause Machine Check
Exceptions. Drivers need a new means of detecting whether they're
running on an EFI machine, as sadly the expression,
if (!efi_enabled)
hasn't been a sufficient condition for quite some time.
Users actually want to query 'efi_enabled' for different reasons -
what they really want access to is the list of available EFI
facilities.
For instance, the x86 reboot code needs to know whether it can invoke
the ResetSystem() function provided by the EFI runtime services, while
the ACPI OSL code wants to know whether the EFI config tables were
mapped successfully. There are also checks in some of the platform
driver code to simply see if they're running on an EFI machine (which
would make it a bad idea to do BIOS-y things).
This patch is a prereq for the samsung-laptop fix patch.
Cc: David Airlie <airlied@linux.ie>
Cc: Corentin Chary <corentincj@iksaif.net>
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Peter Jones <pjones@redhat.com>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Steve Langasek <steve.langasek@canonical.com>
Cc: Konrad Rzeszutek Wilk <konrad@kernel.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
- Adjust context (a lot)
- Add efi_is_native() function from commit 5189c2a7c776
('x86: efi: Turn off efi_enabled after setup on mixed fw/kernel')
- Make efi_init() bail out when booted non-native, as it would previously
not be called in this case
- Drop inapplicable changes to start_kernel()]
commit c903f0456bc69176912dee6dd25c6a66ee1aed00 upstream.
At the moment the MSR driver only relies upon file system
checks. This means that anything as root with any capability set
can write to MSRs. Historically that wasn't very interesting but
on modern processors the MSRs are such that writing to them
provides several ways to execute arbitary code in kernel space.
Sample code and documentation on doing this is circulating and
MSR attacks are used on Windows 64bit rootkits already.
In the Linux case you still need to be able to open the device
file so the impact is fairly limited and reduces the security of
some capability and security model based systems down towards
that of a generic "root owns the box" setup.
Therefore they should require CAP_SYS_RAWIO to prevent an
elevation of capabilities. The impact of this is fairly minimal
on most setups because they don't have heavy use of
capabilities. Those using SELinux, SMACK or AppArmor rules might
want to consider if their rulesets on the MSR driver could be
tighter.
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit b8f2c21db390273c3eaf0e5308faeaeb1e233840 upstream.
Update efi_call_phys_prelog to install an identity mapping of all available
memory. This corrects a bug on very large systems with more then 512 GB in
which bios would not be able to access addresses above not in the mapping.
The result is a crash that looks much like this.
BUG: unable to handle kernel paging request at 000000effd870020
IP: [<0000000078bce331>] 0x78bce330
PGD 0
Oops: 0000 [#1] SMP
Modules linked in:
CPU 0
Pid: 0, comm: swapper/0 Tainted: G W 3.8.0-rc1-next-20121224-medusa_ntz+ #2 Intel Corp. Stoutland Platform
RIP: 0010:[<0000000078bce331>] [<0000000078bce331>] 0x78bce330
RSP: 0000:ffffffff81601d28 EFLAGS: 00010006
RAX: 0000000078b80e18 RBX: 0000000000000004 RCX: 0000000000000004
RDX: 0000000078bcf958 RSI: 0000000000002400 RDI: 8000000000000000
RBP: 0000000078bcf760 R08: 000000effd870000 R09: 0000000000000000
R10: 0000000000000000 R11: 00000000000000c3 R12: 0000000000000030
R13: 000000effd870000 R14: 0000000000000000 R15: ffff88effd870000
FS: 0000000000000000(0000) GS:ffff88effe400000(0000) knlGS:0000000000000000
CR2: 000000effd870020 CR3: 000000000160c000 CR4: 00000000000006b0
Process swapper/0 (pid: 0, threadinfo ffffffff81600000, task ffffffff81614400)
Stack:
0000000078b80d18 0000000000000004 0000000078bced7b ffff880078b81fff
0000000000000000 0000000000000082 0000000078bce3a8 0000000000002400
0000000060000202 0000000078b80da0 0000000078bce45d ffffffff8107cb5a
Call Trace:
[<ffffffff8107cb5a>] ? on_each_cpu+0x77/0x83
[<ffffffff8102f4eb>] ? change_page_attr_set_clr+0x32f/0x3ed
[<ffffffff81035946>] ? efi_call4+0x46/0x80
[<ffffffff816c5abb>] ? efi_enter_virtual_mode+0x1f5/0x305
[<ffffffff816aeb24>] ? start_kernel+0x34a/0x3d2
[<ffffffff816ae5ed>] ? repair_env_string+0x60/0x60
[<ffffffff816ae2be>] ? x86_64_start_reservations+0xba/0xc1
[<ffffffff816ae120>] ? early_idt_handlers+0x120/0x120
[<ffffffff816ae419>] ? x86_64_start_kernel+0x154/0x163
Code: Bad RIP value.
RIP [<0000000078bce331>] 0x78bce330
RSP <ffffffff81601d28>
---[ end trace ead828934fef5eab ]---
Signed-off-by: Nathan Zimmer <nzimmer@sgi.com>
Signed-off-by: Robin Holt <holt@sgi.com>
commit 15653371c67c3fbe359ae37b720639dd4c7b42c5 upstream.
Subhash Jadavani reported this partial backtrace:
Now consider this call stack from MMC block driver (this is on the ARMv7
based board):
[<c001b50c>] (v7_dma_inv_range+0x30/0x48) from [<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c)
[<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c) from [<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c)
[<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c) from [<c0017ff8>] (dma_map_sg+0x3c/0x114)
This is caused by incrementing the struct page pointer, and running off
the end of the sparsemem page array. Fix this by incrementing by pfn
instead, and convert the pfn to a struct page.
Suggested-by: James Bottomley <JBottomley@Parallels.com>
Tested-by: Subhash Jadavani <subhashj@codeaurora.org>
commit d3286144c92ec876da9e30320afa875699b7e0f1 upstream.
Guests can trigger MMIO exits using dcbf. Since we don't emulate cache
incoherent MMIO, just do nothing and move on.
Reported-by: Ben Collins <ben.c@servergy.com>
Tested-by: Ben Collins <ben.c@servergy.com>
commit 9174adbee4a9a49d0139f5d71969852b36720809 upstream.
This fixes CVE-2013-0190 / XSA-40
There has been an error on the xen_failsafe_callback path for failed
iret, which causes the stack pointer to be wrong when entering the
iret_exc error path. This can result in the kernel crashing.
In the classic kernel case, the relevant code looked a little like:
popl %eax # Error code from hypervisor
jz 5f
addl $16,%esp
jmp iret_exc # Hypervisor said iret fault
5: addl $16,%esp
# Hypervisor said segment selector fault
Here, there are two identical addls on either option of a branch which
appears to have been optimised by hoisting it above the jz, and
converting it to an lea, which leaves the flags register unaffected.
In the PVOPS case, the code looks like:
popl_cfi %eax # Error from the hypervisor
lea 16(%esp),%esp # Add $16 before choosing fault path
CFI_ADJUST_CFA_OFFSET -16
jz 5f
addl $16,%esp # Incorrectly adjust %esp again
jmp iret_exc
It is possible unprivileged userspace applications to cause this
behaviour, for example by loading an LDT code selector, then changing
the code selector to be not-present. At this point, there is a race
condition where it is possible for the hypervisor to return back to
userspace from an interrupt, fault on its own iret, and inject a
failsafe_callback into the kernel.
This bug has been present since the introduction of Xen PVOPS support
in commit 5ead97c84 (xen: Core Xen implementation), in 2.6.23.
Signed-off-by: Frediano Ziglio <frediano.ziglio@citrix.com>
Signed-off-by: Andrew Cooper <andrew.cooper3@citrix.com>
commit 6f16f4998f98e42e3f2dedf663cfb691ff0324af upstream.
We currently use a temporary 1MB section aligned to a 1MB boundary for
mapping the provided device tree until the final page table is created.
However, if the device tree happens to cross that 1MB boundary, the end
of it remains unmapped and the kernel crashes when it attempts to access
it. Given no restriction on the location of that DTB, it could end up
with only a few bytes mapped at the end of a section.
Solve this issue by mapping two consecutive sections.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Sascha Hauer <s.hauer@pengutronix.de>
Tested-by: Tomasz Figa <t.figa@samsung.com>
- Adjust context
- The mapping is not conditional; drop the 'ne' suffixes]
commit 568dca15aa2a0f4ddee255894ec393a159f13147 upstream.
Patrik Kluba reports that the preempt count becomes invalid due
to the preempt_enable() call being unbalanced with a
preempt_disable() call in the vfp assembly routines. This happens
because preempt_enable() and preempt_disable() update preempt
counts under PREEMPT_COUNT=y but the vfp assembly routines do so
under PREEMPT=y. In a configuration where PREEMPT=n and
DEBUG_ATOMIC_SLEEP=y, PREEMPT_COUNT=y and so the preempt_enable()
call in VFP_bounce() keeps subtracting from the preempt count
until it goes negative.
Fix this by always using PREEMPT_COUNT to decided when to update
preempt counts in the ARM assembly code.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Reported-by: Patrik Kluba <pkluba@dension.com>
Tested-by: Patrik Kluba <pkluba@dension.com>
commit ed4f20943cd4c7b55105c04daedf8d63ab6d499c upstream.
Converting a 64 Bit TOD format value to nanoseconds means that the value
must be divided by 4.096. In order to achieve that we multiply with 125
and divide by 512.
When used within sched_clock() this triggers an overflow after appr.
417 days. Resulting in a sched_clock() return value that is much smaller
than previously and therefore may cause all sort of weird things in
subsystems that rely on a monotonic sched_clock() behaviour.
To fix this implement a tod_to_ns() helper function which converts TOD
values without overflow and call this function from both places that
open coded the conversion: sched_clock() and kvm_s390_handle_wait().
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
commit 4a71997a3279a339e7336ea5d0cd27282e2dea44 upstream.
Ensure that the aux table is properly initialized, even when optional features
are missing. Without this, the FDPIC loader did not work. This was meant to
be included in commit d5ab780305bb6d60a7b5a74f18cf84eb6ad153b1.
Signed-off-by: Thomas Schwinge <thomas@codesourcery.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
