This fixes the Ethernet PHY reset and interrupt handling.
Clarify exact Apalis iMX6Q/D module type and Ixora carrier board in
model node.
While at it also make sure the compatible node fits into 80 char length
lines.
With the 3.14.28 release of the kernel imx6_stop_mode_poweroff() does not
enter stop mode.
Thus the function does not switch of power but returns.
This seems to be caused by the second processor which has been stopped.
Set the WFI event mask for the stopped processor works around the issue.
Otherwise power_machine_power_off() returns and e.g. unexpected interrupts
create stack traces.
Enable RTL8192CU driver to support LM006 USB WiFi adapter.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
With compilers which follow the C99 standard (like modern versions of gcc and
clang), "extern inline" does the wrong thing (emits code for an externally
linkable version of the inline function). "static inline" is the correct choice
instead.
Author: Behan Webster <behanw@converseincode.com>
Signed-off-by: Behan Webster <behanw@converseincode.com>
Reviewed-by: Mark Charlebois <charlebm@gmail.com>
(cherry picked from commit 76ae03828756bac2c1fa2c7eff7485e5f815dbdb)
linkable version of the inline function). In this case using static inline
and removing the NULL version of return_address in return_address.c does
the right thing.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
(cherry picked from commit aeea3592a13bf12861943e44fc48f1f270941f8d)
The ldb driver which controls the LVDS output got heavily overhauled and
its configuration from the cmdline seem no longer working.
This adds a configuration to the device tree which can be activated from the
cmdline with:
video=mxcfb0:dev=ldb
Newer systemd variants need network namespace support for various
services such as systemd-hostnamed or systemd-localed.
(cherry picked from commit 4bb3acd58f8d2074cd8e7a6ddb914a0954d0906a)
Remove duplicate CONFIG_STMPE_ADC from both defconfigs.
While at it also remove obsolete commented out
CONFIG_NET_VENDOR_ATHEROS being not set on Colibri iMX6.
We do provide the line in jack, so add it in the routing.
This allows for easier disabling of unused cameras.
Increase SPEED field from 50MHz to 100MHz the avoid pixel flickering on RGB666 at Full HD resolutions.
(cherry picked from commit a700491ac9cc18d27ddfadee3a7787039485ed40)
arch/arm/boot/dts/imx6qdl-colibri.dtsi
commit 5202ebd189bac35987bf79335fe4568aabbf2b0e:
The capacitive touch 10" display does react badly react badly to the
current pad control settings.
E.g. only the upper half of the display was somewhat readable with the
lower half being whitish.
(cherry picked from commit 47c017b98ce9359f890363b4095c87235a6f81d6)
While at it cleanup node names.
Use commit e11011a0578101b2f0f9a066d13beeb2c2da5fcc on all device-trees:
Rather than defining our own KEY_WAKEUP include the official input
dt-bindings.
While at it update copyright date range as well.
Prepare for the needed changes to use the capacitive touch controller
on Fusion F07, Fusion F10A displays.
In order to use it uncomment the define PCAP and recompile and deploy
the device tree
Forward port of 3.10.17, commit e5925f53b4c6021d03a7a694d0512712036e83e6
Use USBC_DET feature of Standard Colibri SODIMM pin 137 for USB
device/host switching using the generic extcon USB GPIO implementation.
dt-bindings.
Enable extcon USB GPIO support in the default kernel configuration.
Device tree nodes are already treated as objects, and we already want to
expose them to userspace which is done using the /proc filesystem today.
Right now the kernel has to do a lot of work to keep the /proc view in
sync with the in-kernel representation. If device_nodes are switched to
be kobjects then the device tree code can be a whole lot simpler. It
also turns out that switching to using /sysfs from /proc results in
smaller code and data size, and the userspace ABI won't change if
/proc/device-tree symlinks to /sys/firmware/devicetree/base.
v7: Add missing sysfs_bin_attr_init()
v6: Add __of_add_property() early init fixes from Pantelis
v5: Rename firmware/ofw to firmware/devicetree
Fix updating property values in sysfs
v4: Fixed build error on Powerpc
Fixed handling of dynamic nodes on powerpc
v3: Fixed handling of duplicate attribute and child node names
v2: switch to using sysfs bin_attributes which solve the problem of
reporting incorrect property size.
Tested-by: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
(cherry picked from commit 75b57ecf9d1d1e17d099ab13b8f48e6e038676be)
Commit 21f2aae91e902aad ("leds: leds-gpio: Add support for GPIO
descriptors") already converted most of the driver to use GPIO descriptors.
What is still missing is the platform specific hook gpio_blink_set() and
board files which pass legacy GPIO numbers to this driver in platform data.
In this patch we handle the former and convert gpio_blink_set() to take
GPIO descriptor instead. In order to do this we convert the existing four
users to accept GPIO descriptor and translate it to legacy GPIO number in
the platform code. This effectively "pushes" legacy GPIO number usage from
the driver to platforms.
Also add comment to the remaining block describing that it is legacy code
path and we are getting rid of it eventually.
Suggested-by: Linus Walleij <linus.walleij@linaro.org>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
(cherry picked from commit c673a2b4008103525a3cf21bedf15ffac37bfef0)
The forthcoming patch will make <acpi/acpi.h> to be visible to all kernel
source code. Thus for the architectures that do not support ACPI and
haven't implemented <asm/acenv.h>, we need to make it excluded.
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
(cherry picked from commit d334c823b27401721591e0f1220050a41af08165)
<asm/acpi.h>
There is a mis-order inclusion for <asm/acpi.h>.
As we will enforce including <linux/acpi.h> for all Linux ACPI users, we
can find the inclusion order is as follows:
<linux/acpi.h>
<acpi/acpi.h>
<acpi/platform/acenv.h>
(acenv.h before including aclinux.h)
<acpi/platform/aclinux.h>
(aclinux.h before including asm/acpi.h)
<asm/acpi.h> @Redundant@
(ACPICA specific stuff)
(Linux ACPI specific stuff) ? - - - - - - - - - - - - +
(aclinux.h after including asm/acpi.h) @Invisible@ |
(acenv.h after including aclinux.h) @Invisible@ |
other ACPICA headers @Invisible@ |
<acpi/acpi_bus.h> |
<acpi/acpi_drivers.h> |
<asm/acpi.h> (Excluded) |
(Linux ACPI specific stuff) ! <- - - - - - - - - - - - - +
NOTE that, in ACPICA, <acpi/platform/acenv.h> is more like Kconfig
generated <generated/autoconf.h> for Linux, it is meant to be included
before including any ACPICA code.
In the above figure, there is a question mark for "Linux ACPI specific
stuff" in <asm/acpi.h> which should be included after including all other
ACPICA header files. Thus they really need to be moved to the position
marked with exclaimation mark or the definitions in the blocks marked with
"@Invisible@" will be invisible to such architecture specific "Linux ACPI
specific stuff" header blocks. This leaves 2 issues:
1. All environmental definitions in these blocks should have a copy in the
area marked with "@Redundant@" if they are required by the "Linux ACPI
specific stuff".
2. We cannot use any ACPICA defined types in <asm/acpi.h>.
This patch splits architecture specific ACPICA stuff from <asm/acpi.h> to
fix this issue.
(cherry picked from commit 07d8391433380fc72f999d99c554b1cfedea9778)
Use consistently MXM3<space><number> or SODIMM<space><number>
rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
The v1_0 denotes the Apalis module version, not the evaluation board version.
When compiling a kernel without CONFIG_MULTI_CACHE enabled the
dma access functions end up not being exported. Fix it.
Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
(cherry picked from commit 22f692548037e39809c32759b5600ee066ef59e9)
Evaluate the device tree to find out about the used phy mode rather than
using a hardcoded value of 125MHz valid for RGMII only.
After the system has been shutdown with PMIC_ON_REQ and VCC_BATT is supplied
from a battery it will never restart either by RESET or power cycle.
So use the PMIC_STBY_REQ after shutdown to switch of power rails.
arch/arm/mach-imx/pm-imx6.c
drivers/regulator/pfuze100-regulator.c
(cherry picked from commit 02110528b45ae331d89f7e7bb6a29b5494ec0be1)
arch/arm/mach-imx/mach-imx6q.c
The WEIM signals are not accessible so remove the driver from the config and
set it to disabled in the device tree.
(cherry picked from commit 6c2f7b22f5aa9572d35a3ddd7d14b653cf606550)
arch/arm/configs/apalis_imx6_defconfig
gst-inspect mfw_v4lsrc
gst-launch mfw_v4lsrc capture-mode=5 device=/dev/video2 ! mfw_v4lsink
(cherry picked from commit 943e92ef3b9822cd278eff806b001c14c7bebb83)
GPIO number 0 *is* legal and must be accepted.
Set .ena_gpio to -ENODEV on regulators having no GPIO in preparation
of a code change to accept GPIO 0 in the config.
(cherry picked from commit c87ddbb1325a448d56a920513206592f03bca117)
arch/arm/mach-imx/gpc.c
drivers/regulator/88pm8607.c
drivers/regulator/ab8500-ext.c
drivers/regulator/ab8500.c
drivers/regulator/ad5398.c
drivers/regulator/arizona-micsupp.c
drivers/regulator/isl6271a-regulator.c
drivers/regulator/lp3972.c
drivers/regulator/max1586.c
drivers/regulator/max8660.c
drivers/regulator/max8925-regulator.c
drivers/regulator/max8952.c
drivers/regulator/max8998.c
drivers/regulator/mc13783-regulator.c
drivers/regulator/s2mps11.c
drivers/regulator/tps65217-regulator.c
drivers/regulator/tps6524x-regulator.c
drivers/regulator/wm831x-dcdc.c
drivers/regulator/wm831x-ldo.c
Fix PCIe operation by disabling RC/EP test mode which according to the
following community forum post is only used on the PCIe EP/RC
validation system and otherwise prevent PCIe from working properly:
https://community.freescale.com/thread/328257
Enable the TouchRevolution Fusion 7 and 10 multi-touch controller driver
to be built as a module.
While at it remove NEW_LEDS which is enabled through dependencies.
