path: root/arch
2011-10-24x86: Fix S4 regressionTakashi Iwai
Commit 4b239f458 ("x86-64, mm: Put early page table high") causes a S4 regression since 2.6.39, namely the machine reboots occasionally at S4 resume. It doesn't happen always, overall rate is about 1/20. But, like other bugs, once when this happens, it continues to happen. This patch fixes the problem by essentially reverting the memory assignment in the older way. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: <stable@kernel.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Yinghai Lu <yinghai.lu@oracle.com> [ We'll hopefully find the real fix, but that's too late for 3.1 now ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-23Merge branch 'samsung-fixes-4' of git://github.com/kgene/linux-samsungLinus Torvalds
* 'samsung-fixes-4' of git://github.com/kgene/linux-samsung: ARM: S3C24XX: Fix s3c24xx build errors if !CONFIG_PM ARM: S5P: fix offset calculation on gpio-interrupt
2011-10-22ARM: S3C24XX: Fix s3c24xx build errors if !CONFIG_PMDomenico Andreoli
v2: - register_syscore_ops(&s3c24xx_irq_syscore_ops) does not need to be conditionally compiled out, it is already optimized out on !CONFIG_PM - fix also s3c2412 and s3c2416 affected by the same build issue v1: s3c2440.c fails to build if !CONFIG_PM because in such case s3c2410_pm_syscore_ops is not defined. Same error should happen also in s3c2410.c and s3c2442.c Signed-off-by: Domenico Andreoli <cavokz@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-10-21ARM: S5P: fix offset calculation on gpio-interruptMarek Szyprowski
Offsets of the irq controller registers were calculated correctly only for first GPIO bank. This patch fixes calculation of the register offsets for all GPIO banks. Reported-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-10-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc: Add alignment flag to PCI expansion resources sparc: Avoid calling sigprocmask() sparc: Use set_current_blocked() sparc32,leon: SRMMU MMU Table probe fix
2011-10-19sparc: Add alignment flag to PCI expansion resourcesKjetil Oftedal
Currently no type of alignment is specified for PCI expansion roms while parsing the openfirmware tree. This causes calls to pci_map_rom() to fail. IORESOURCE_SIZEALIGN is the default alignment used for rom resouces in pci/probe.c, and has been verified to work with various cards on a ultra 10. Signed-off-By: Kjetil Oftedal <oftedal@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-16Merge branch 'fixes' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'fixes' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: ARM: 7128/1: vic: Don't write to the read-only register VIC_IRQ_STATUS ARM: 7122/1: localtimer: add header linux/errno.h explicitly ARM: 7117/1: perf: fix HW_CACHE_* events on Cortex-A9 ARM: 7113/1: mm: Align bank start to MAX_ORDER_NR_PAGES
2011-10-15ARM: 7128/1: vic: Don't write to the read-only register VIC_IRQ_STATUSZoltan Devai
This is unneeded and causes an abort on the SPMP8000 platform. Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Zoltan Devai <zoss@devai.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-15ARM: 7122/1: localtimer: add header linux/errno.h explicitlyShawn Guo
Per the text in Documentation/SubmitChecklist as below, we should explicitly have header linux/errno.h in localtimer.h for ENXIO reference. 1: If you use a facility then #include the file that defines/declares that facility. Don't depend on other header files pulling in ones that you use. Otherwise, we may run into some compiling error like the following one, if any file includes localtimer.h without CONFIG_LOCAL_TIMERS defined. arch/arm/include/asm/localtimer.h: In function ‘local_timer_setup’: arch/arm/include/asm/localtimer.h:53:10: error: ‘ENXIO’ undeclared (first use in this function) Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-15ARM: 7117/1: perf: fix HW_CACHE_* events on Cortex-A9Will Deacon
Using COHERENT_LINE_{MISS,HIT} for cache misses and references respectively is completely wrong. Instead, use the L1D events which are a better and more useful approximation despite ignoring instruction traffic. Reported-by: Alasdair Grant <alasdair.grant@arm.com> Reported-by: Matt Horsnell <matt.horsnell@arm.com> Reported-by: Michael Williams <michael.williams@arm.com> Cc: stable@kernel.org Cc: Jean Pihet <j-pihet@ti.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-14Merge branch 'stable' of git://github.com/cmetcalf-tilera/linux-tileLinus Torvalds
* 'stable' of git://github.com/cmetcalf-tilera/linux-tile: tile: revert change from <asm/atomic.h> to <linux/atomic.h> in asm files
2011-10-14Merge branch 'x86-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tipLinus Torvalds
* 'x86-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip: x86: Default to vsyscall=native for now
2011-10-14x86, mrst: use a temporary variable for SFI irqMika Westerberg
SFI tables reside in RAM and should not be modified once they are written. Current code went to set pentry->irq to zero which causes subsequent reads to fail with invalid SFI table checksum. This will break kexec as the second kernel fails to validate SFI tables. To fix this we use temporary variable for irq number. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-13tile: revert change from <asm/atomic.h> to <linux/atomic.h> in asm filesChris Metcalf
The 32-bit TILEPro support uses some #defines in <asm/atomic_32.h> for atomic support routines in assembly. To make this more explicit, I've turned those includes into includes of <asm/atomic_32.h>, which should hopefully make it clear that they shouldn't be bombed into <linux/atomic.h> in any cleanups. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-10-12sparc: Avoid calling sigprocmask()David S. Miller
Use set_current_blocked() instead. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-12sparc: Use set_current_blocked()Matt Fleming
As described in e6fa16ab ("signal: sigprocmask() should do retarget_shared_pending()") the modification of current->blocked is incorrect as we need to check whether the signal we're about to block is pending in the shared queue. Cc: Oleg Nesterov <oleg@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-11x86: Default to vsyscall=native for nowAdrian Bunk
This UML breakage: linux-2.6.30.1[3800] vsyscall fault (exploit attempt?) ip:ffffffffff600000 cs:33 sp:7fbfb9c498 ax:ffffffffff600000 si:0 di:606790 linux-2.6.30.1[3856] vsyscall fault (exploit attempt?) ip:ffffffffff600000 cs:33 sp:7fbfb13168 ax:ffffffffff600000 si:0 di:606790 Is caused by commit 3ae36655 ("x86-64: Rework vsyscall emulation and add vsyscall= parameter") - the vsyscall emulation code is not fully cooked yet as UML relies on some rather fragile SIGSEGV semantics. Linus suggested in https://lkml.org/lkml/2011/8/9/376 to default to vsyscall=native for now, this patch implements that. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Andrew Lutomirski <luto@mit.edu> Cc: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/20111005214047.GE14406@localhost.pp.htv.fi Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-10Merge branch 'fixes' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'fixes' of git://git.linaro.org/people/arnd/arm-soc: ARM: mach-ux500: enable fix for ARM errata 754322 ARM: OMAP: musb: Remove a redundant omap4430_phy_init call in usb_musb_init ARM: OMAP: Fix i2c init for twl4030 ARM: OMAP4: MMC: fix power and audio issue, decouple USBC1 from MMC1
2011-10-10ARM: tegra: fix compilation error due to mach/hardware.h removalMarc Dietrich
This fixes a compilation error in cpu-tegra.c which was introduced in dc8d966bccde ("ARM: convert PCI defines to variables") which removed the now obsolete mach/hardware.h from the mach-tegra subtree. Signed-off-by: Marc Dietrich <marvin24@gmx.de> Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-10Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (29 commits) MIPS: Call oops_enter, oops_exit in die staging/octeon: Software should check the checksum of no tcp/udp packets MIPS: Octeon: Enable C0_UserLocal probing. MIPS: No branches in delay slots for huge pages in handle_tlbl MIPS: Don't clobber CP0_STATUS value for CONFIG_MIPS_MT_SMTC MIPS: Octeon: Select CONFIG_HOLES_IN_ZONE MIPS: PM: Use struct syscore_ops instead of sysdevs for PM (v2) MIPS: Compat: Use 32-bit wrapper for compat_sys_futex. MIPS: Do not use EXTRA_CFLAGS MIPS: Alchemy: DB1200: Disable cascade IRQ in handler SERIAL: Lantiq: Set timeout in uart_port MIPS: Lantiq: Fix setting the PCI bus speed on AR9 MIPS: Lantiq: Fix external interrupt sources MIPS: tlbex: Fix build error in R3000 code. MIPS: Alchemy: Include Au1100 in PM code. MIPS: Alchemy: Fix typo in MAC0 registration MIPS: MSP71xx: Fix build error. MIPS: Handle __put_user() sleeping. MIPS: Allow forced irq threading MIPS: i8259: Mark cascade interrupt non-threaded ...
2011-10-08Merge branch 'omap/fixes-for-3.1' into fixesArnd Bergmann
2011-10-07sparc32,leon: SRMMU MMU Table probe fixDaniel Hellstrom
The LEON MMU Model (SRMMU) does not implement MMu Table probing in hardware, instead it is implemented in software. However the software implementation does not return the PTE as it should which always results in INVALID entires and the PROM mappings are not inherited as they should during startup. The following patch removes the masking of the PTE. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-07ARM: mach-ux500: enable fix for ARM errata 754322srinidhi kasagar
This applies ARM errata fix 754322 for all ux500 platforms. Cc: stable@kernel.org Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-10-06x86/PCI: use host bridge _CRS info on ASUS M2V-MX SEPaul Menzel
In summary, this DMI quirk uses the _CRS info by default for the ASUS M2V-MX SE by turning on `pci=use_crs` and is similar to the quirk added by commit 2491762cfb47 ("x86/PCI: use host bridge _CRS info on ASRock ALiveSATA2-GLAN") whose commit message should be read for further information. Since commit 3e3da00c01d0 ("x86/pci: AMD one chain system to use pci read out res") Linux gives the following oops: parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE] HDA Intel 0000:20:01.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17 HDA Intel 0000:20:01.0: setting latency timer to 64 BUG: unable to handle kernel paging request at ffffc90011c08000 IP: [<ffffffffa0578402>] azx_probe+0x3ad/0x86b [snd_hda_intel] PGD 13781a067 PUD 13781b067 PMD 1300ba067 PTE 800000fd00000173 Oops: 0009 [#1] SMP last sysfs file: /sys/module/snd_pcm/initstate CPU 0 Modules linked in: snd_hda_intel(+) snd_hda_codec snd_hwdep snd_pcm_oss snd_mixer_oss snd_pcm snd_seq_midi snd_rawmidi snd_seq_midi_event tpm_tis tpm snd_seq tpm_bios psmouse parport_pc snd_timer snd_seq_device parport processor evdev snd i2c_viapro thermal_sys amd64_edac_mod k8temp i2c_core soundcore shpchp pcspkr serio_raw asus_atk0110 pci_hotplug edac_core button snd_page_alloc edac_mce_amd ext3 jbd mbcache sha256_generic cryptd aes_x86_64 aes_generic cbc dm_crypt dm_mod raid1 md_mod usbhid hid sg sd_mod crc_t10dif sr_mod cdrom ata_generic uhci_hcd sata_via pata_via libata ehci_hcd usbcore scsi_mod via_rhine mii nls_base [last unloaded: scsi_wait_scan] Pid: 1153, comm: work_for_cpu Not tainted 2.6.37-1-amd64 #1 M2V-MX SE/System Product Name RIP: 0010:[<ffffffffa0578402>] [<ffffffffa0578402>] azx_probe+0x3ad/0x86b [snd_hda_intel] RSP: 0018:ffff88013153fe50 EFLAGS: 00010286 RAX: ffffc90011c08000 RBX: ffff88013029ec00 RCX: 0000000000000006 RDX: 0000000000000000 RSI: 0000000000000246 RDI: 0000000000000246 RBP: ffff88013341d000 R08: 0000000000000000 R09: 0000000000000040 R10: 0000000000000286 R11: 0000000000003731 R12: ffff88013029c400 R13: 0000000000000000 R14: 0000000000000000 R15: ffff88013341d090 FS: 0000000000000000(0000) GS:ffff8800bfc00000(0000) knlGS:00000000f7610ab0 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffffc90011c08000 CR3: 0000000132f57000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process work_for_cpu (pid: 1153, threadinfo ffff88013153e000, task ffff8801303c86c0) Stack: 0000000000000005 ffffffff8123ad65 00000000000136c0 ffff88013029c400 ffff8801303c8998 ffff88013341d000 ffff88013341d090 ffff8801322d9dc8 ffff88013341d208 0000000000000000 0000000000000000 ffffffff811ad232 Call Trace: [<ffffffff8123ad65>] ? __pm_runtime_set_status+0x162/0x186 [<ffffffff811ad232>] ? local_pci_probe+0x49/0x92 [<ffffffff8105afc5>] ? do_work_for_cpu+0x0/0x1b [<ffffffff8105afc5>] ? do_work_for_cpu+0x0/0x1b [<ffffffff8105afd0>] ? do_work_for_cpu+0xb/0x1b [<ffffffff8105fd3f>] ? kthread+0x7a/0x82 [<ffffffff8100a824>] ? kernel_thread_helper+0x4/0x10 [<ffffffff8105fcc5>] ? kthread+0x0/0x82 [<ffffffff8100a820>] ? kernel_thread_helper+0x0/0x10 Code: f4 01 00 00 ef 31 f6 48 89 df e8 29 dd ff ff 85 c0 0f 88 2b 03 00 00 48 89 ef e8 b4 39 c3 e0 8b 7b 40 e8 fc 9d b1 e0 48 8b 43 38 <66> 8b 10 66 89 14 24 8b 43 14 83 e8 03 83 f8 01 77 32 31 d2 be RIP [<ffffffffa0578402>] azx_probe+0x3ad/0x86b [snd_hda_intel] RSP <ffff88013153fe50> CR2: ffffc90011c08000 ---[ end trace 8d1f3ebc136437fd ]--- Trusting the ACPI _CRS information (`pci=use_crs`) fixes this problem. $ dmesg | grep -i crs # with the quirk PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug The match has to be against the DMI board entries though since the vendor entries are not populated. DMI: System manufacturer System Product Name/M2V-MX SE, BIOS 0304 10/30/2007 This quirk should be removed when `pci=use_crs` is enabled for machines from 2006 or earlier or some other solution is implemented. Using coreboot [1] with this board the problem does not exist but this quirk also does not affect it either. To be safe though the check is tightened to only take effect when the BIOS from American Megatrends is used. 15:13 < ruik> but coreboot does not need that 15:13 < ruik> because i have there only one root bus 15:13 < ruik> the audio is behind a bridge $ sudo dmidecode BIOS Information Vendor: American Megatrends Inc. Version: 0304 Release Date: 10/30/2007 [1] http://www.coreboot.org/ Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=30552 Cc: stable@kernel.org (2.6.34) Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: x86@kernel.org Signed-off-by: Paul Menzel <paulepanter@users.sourceforge.net> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-01MIPS: Call oops_enter, oops_exit in dieNathan Lynch
This allows pause_on_oops and mtdoops to work. Signed-off-by: Nathan Lynch <ntl@pobox.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2810/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-01ARM: 7113/1: mm: Align bank start to MAX_ORDER_NR_PAGESLinus Walleij
The VM subsystem assumes that there are valid memmap entries from the bank start aligned to MAX_ORDER_NR_PAGES. On the Ux500 we have a lot of mem=N arguments on the commandline triggering this bug several times over and causing kernel oops messages. Cc: stable@kernel.org Cc: Michael Bohan <mbohan@codeaurora.org> Cc: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Johan Palsson <johan.palsson@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-01Merge branches 'irq-urgent-for-linus', 'x86-urgent-for-linus' and ↵Linus Torvalds
'sched-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip * 'irq-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip: irq: Fix check for already initialized irq_domain in irq_domain_add irq: Add declaration of irq_domain_simple_ops to irqdomain.h * 'x86-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip: x86/rtc: Don't recursively acquire rtc_lock * 'sched-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip: posix-cpu-timers: Cure SMP wobbles sched: Fix up wchan borkage sched/rt: Migrate equal priority tasks to available CPUs
2011-09-30ARM: OMAP: musb: Remove a redundant omap4430_phy_init call in usb_musb_initAxel Lin
Current code calls omap4430_phy_init() twice in usb_musb_init(). Calling omap4430_phy_init() once is enough. This patch removes the first omap4430_phy_init() call, which using an uninitialized pointer as parameter. This patch elimates below build warning: arch/arm/mach-omap2/usb-musb.c: In function 'usb_musb_init': arch/arm/mach-omap2/usb-musb.c:141: warning: 'dev' may be used uninitialized in this function Signed-off-by: Axel Lin <axel.lin@gmail.com> Bjarne Steinsbo <bsteinsbo@gmail.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-30ARM: OMAP: Fix i2c init for twl4030Tony Lindgren
Looks like 2600 kHz rate does not work reliably on 2430, so just use the 100 kHz rate. Otherwise the system often fails to boot properly with: omap_i2c omap_i2c.2: timeout waiting for bus ready omap_i2c omap_i2c.2: timeout waiting for bus ready twl: i2c_write failed to transfer all messages omap_i2c omap_i2c.2: timeout waiting for bus ready twl: i2c_write failed to transfer all messages omap_i2c omap_i2c.2: timeout waiting for bus ready twl: i2c_write failed to transfer all messages twl: clock init err [-110] omap_i2c omap_i2c.2: timeout waiting for bus ready twl: i2c_write failed to transfer all messages TWL4030 Unable to unlock IDCODE registers --110 Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-30ARM: OMAP4: MMC: fix power and audio issue, decouple USBC1 from MMC1Bryan Buckley
Remove OMAP4_USBC1_ICUSB_PWRDNZ_MASK during enable/disable PWRDNZ mode for MMC1_PBIAS and associated extended-drain MMC1 I/O cell. This is in accordance with the control module programming guide. This fixes a bug where if trying to use gpio_98 or gpio_99 and MMC1 at the same time the GPIO signal will be affected by a changing SDMMC1_VDDS. Software must keep MMC1_PBIAS cell and MMC1_IO cell PWRDNZ signals low whenever SDMMC1_VDDS ramps up/down or changes for cell protection purposes. MMC1 is based on SDMMC1_VDDS whereas USBC1 is based on SIM_VDDS therefore they can operate independently. Signed-off-by: Bryan Buckley <bryan.buckley@ti.com> Acked-by: Kishore Kadiyala <kishore.kadiyala@ti.com> Tested-by: Balaji T K <balajitk@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-29Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] cio: fix cio_tpi ignoring adapter interrupts [S390] gmap: always up mmap_sem properly [S390] Do not clobber personality flags on exec
2011-09-29Merge git://github.com/davem330/sparcLinus Torvalds
* git://github.com/davem330/sparc: sparc64: Force the execute bit in OpenFirmware's translation entries. sparc: Make '-p' boot option meaningful again. sparc, exec: remove redundant addr_limit assignment sparc64: Future proof Niagara cpu detection.
2011-09-29powerpc: Fix device-tree matching for Apple U4 bridgeBenjamin Herrenschmidt
Apple Quad G5 has some oddity in it's device-tree which causes the new generic matching code to fail to relate nodes for PCI-E devices below U4 with their respective struct pci_dev. This breaks graphics on those machines among others. This fixes it using a quirk which copies the node pointer from the host bridge for the root complex, which makes the generic code work for the children afterward. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-29sparc64: Force the execute bit in OpenFirmware's translation entries.David S. Miller
In the OF 'translations' property, the template TTEs in the mappings never specify the executable bit. This is the case even though some of these mappings are for OF's code segment. Therefore, we need to force the execute bit on in every mapping. This problem can only really trigger on Niagara/sun4v machines and the history behind this is a little complicated. Previous to sun4v, the sun4u TTE entries lacked a hardware execute permission bit. So OF didn't have to ever worry about setting anything to handle executable pages. Any valid TTE loaded into the I-TLB would be respected by the chip. But sun4v Niagara chips have a real hardware enforced executable bit in their TTEs. So it has to be set or else the I-TLB throws an instruction access exception with type code 6 (protection violation). We've been extremely fortunate to not get bitten by this in the past. The best I can tell is that the OF's mappings for it's executable code were mapped using permanent locked mappings on sun4v in the past. Therefore, the fact that we didn't have the exec bit set in the OF translations we would use did not matter in practice. Thanks to Greg Onufer for helping me track this down. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-26Merge branch 'samsung-fixes-3' of git://github.com/kgene/linux-samsungLinus Torvalds
* 'samsung-fixes-3' of git://github.com/kgene/linux-samsung: ARM: EXYNOS4: Rename sclk_cam clocks for FIMC driver ARM: S5PV210: Rename sclk_cam clocks for FIMC media driver ARM: S5P: fix incorrect loop iterator usage on gpio-interrupt ARM: S3C2443: Fix bit-reset in setrate of clk_armdiv
2011-09-27ARM: EXYNOS4: Rename sclk_cam clocks for FIMC driverSylwester Nawrocki
The sclk_cam clocks are now controlled by the top level FIMC media device driver bound to "s5p-fimc-md" platform device. Rename sclk_cam clocks so they accessible by the corresponding driver. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-27ARM: S5PV210: Rename sclk_cam clocks for FIMC media driverSylwester Nawrocki
2011-09-26Merge branch 'kvm-updates/3.1' of git://github.com/avikivity/kvmLinus Torvalds
* 'kvm-updates/3.1' of git://github.com/avikivity/kvm: KVM: x86 emulator: fix Src2CL decode KVM: MMU: fix incorrect return of spte
2011-09-26Merge branch 'fixes' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'fixes' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: ARM: 7099/1: futex: preserve oldval in SMP __futex_atomic_op ARM: dma-mapping: free allocated page if unable to map ARM: fix vmlinux.lds.S discarding sections ARM: nommu: fix warning with checksyscalls.sh ARM: 7091/1: errata: D-cache line maintenance operation by MVA may not succeed
2011-09-26[S390] gmap: always up mmap_sem properlyCarsten Otte
If gmap_unmap_segment figures that the segment was not mapped in the first place, it need to up mmap_sem on exit. Cc: <stable@kernel.org> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-09-26[S390] Do not clobber personality flags on execMartin Schwidefsky
Analog to git commit 59e4c3a2fe9cb1681bb2cff508ff79466f7585ba do not clear the additional personality flags on exec. We need to inherit the personality bits in PER_MASK across exec. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-09-26ARM: 7099/1: futex: preserve oldval in SMP __futex_atomic_opWill Deacon
The SMP implementation of __futex_atomic_op clobbers oldval with the status flag from the exclusive store. This causes it to always read as zero when performing the FUTEX_OP_CMP_* operation. This patch updates the ARM __futex_atomic_op implementations to take a tmp argument, allowing us to store the strex status flag without overwriting the register containing oldval. Cc: stable@kernel.org Reported-by: Minho Ban <mhban@samsung.com> Reviewed-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-09-26ARM: dma-mapping: free allocated page if unable to mapRussell King
If the attempt to map a page for DMA fails (eg, because we're out of mapping space) then we must not hold on to the page we allocated for DMA - doing so will result in a memory leak. Cc: <stable@kernel.org> Reported-by: Bryan Phillippe <bp@darkforest.org> Tested-by: Bryan Phillippe <bp@darkforest.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-09-26ARM: S5P: fix incorrect loop iterator usage on gpio-interruptMarek Szyprowski
Loop iterator value after terminating list_for_each_entry() is not NULL. This patch fixes incorrect iterator usage in GPIO interrupt code for SAMSUNG S5P platforms. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-26ARM: S3C2443: Fix bit-reset in setrate of clk_armdivHeiko Stuebner
The changed statement should set the old armdiv bits to 0 and not everything else, before setting the new value. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-25KVM: x86 emulator: fix Src2CL decodeAvi Kivity
Src2CL decode (used for double width shifts) erronously decodes only bit 3 of %rcx, instead of bits 7:0. Fix by decoding %cl in its entirety. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-09-25KVM: MMU: fix incorrect return of spteZhao Jin
__update_clear_spte_slow should return original spte while the current code returns low half of original spte combined with high half of new spte. Signed-off-by: Zhao Jin <cronozhj@gmail.com> Reviewed-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-09-24MIPS: Octeon: Enable C0_UserLocal probing.David Daney
Octeon2 processor cores have a UserLocal register. Remove the hard coded negative probe and allow the standard probing to detect this feature. Signed-off-by: David Daney <david.daney@cavium.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2578/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-09-22Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] kvm: extension capability for new address space layout [S390] kvm: fix address mode switching
2011-09-21sparc: Make '-p' boot option meaningful again.David S. Miller
If "-p" is given on the command line, clear the CON_BOOT flag for the initial early boot PROM console. This is necessary to try and see crash messages that occur between the registry of the VT console and the probing of the first framebuffer or serial console. During this time no console messages are emitted because the VT console registry (even if no backend is registered to it) removes the early console if CON_BOOT is set. Signed-off-by: David S. Miller <davem@davemloft.net>
