commit 3c9fa24ca7c9c47605672916491f79e8ccacb9e6 upstream.
The functions that were used in the emulation of fxrstor, fxsave, sgdt and
sidt were originally meant for task switching, and as such they did not
check privilege levels. This is very bad when the same functions are used
in the emulation of unprivileged instructions. This is CVE-2018-10853.
The obvious fix is to add a new argument to ops->read_std and ops->write_std,
which decides whether the access is a "system" access or should use the
processor's CPL.
Fixes: 129a72a0d3c8 ("KVM: x86: Introduce segmented_write_std", 2017-01-12)
commit ce14e868a54edeb2e30cb7a7b104a2fc4b9d76ca upstream.
Int the next patch the emulator's .read_std and .write_std callbacks will
grow another argument, which is not needed in kvm_read_guest_virt and
kvm_write_guest_virt_system's callers. Since we have to make separate
functions, let's give the currently existing names a nicer interface, too.
Cc: stable@vger.kernel.org
commit 79367a65743975e5cac8d24d08eccc7fdae832b0 upstream.
Wrap the common invocation of ctxt->ops->read_std and ctxt->ops->write_std, so
as to have a smaller patch when the functions grow another argument.
commit 02f39b2379fb81557ae864ec8f85421c0250c954 upstream.
The crypto code was checking both use_eager_fpu() and
defined(X86_FEATURE_EAGER_FPU). The latter was nonsensical, so
remove it. This will avoid breakage when we remove
X86_FEATURE_EAGER_FPU.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Cc: pbonzini@redhat.com
Link: http://lkml.kernel.org/r/1475627678-20788-2-git-send-email-riel@redhat.com
commit 4ecd16ec7059390b430af34bd8bc3ca2b5dcef9a upstream.
Systems without an FPU are generally old and therefore use lazy FPU
switching. Unsurprisingly, math emulation in eager FPU mode is a
bit buggy. Fix it.
There were two bugs involving kernel code trying to use the FPU
registers in eager mode even if they didn't exist and one BUG_ON()
that was incorrect.
Cc: Sai Praneeth Prakhya <sai.praneeth.prakhya@intel.com>
Cc: yu-cheng yu <yu-cheng.yu@intel.com>
Link: http://lkml.kernel.org/r/b4b8d112436bd6fab866e1b4011131507e8d7fbe.1453675014.git.luto@kernel.org
commit 5ed73f40735c68d8a656b46d09b1885d3b8740ae upstream.
In eager fpu mode, having deactivated FPU without immediately
reloading some other context is illegal. Therefore, to recover from
FNSAVE, we can't just deactivate the state -- we need to reload it
if we're not actively context switching.
We had this wrong in fpu__save() and fpu__copy(). Fix both.
__kernel_fpu_begin() was fine -- add a comment.
This fixes a warning triggerable with nofxsr eagerfpu=on.
Link: http://lkml.kernel.org/r/60662444e13c76f06e23c15c5dcdba31b4ac3d67.1453675014.git.luto@kernel.org
commit ca6938a1cd8a1c5e861a99b67f84ac166fc2b9e7 upstream.
Since commit:
58122bf1d856 ("x86/fpu: Default eagerfpu=on on all CPUs")
... in Linux 4.6, eager FPU mode has been the default on all x86
systems, and no one has reported any regressions.
This patch removes the ability to enable lazy mode: use_eager_fpu()
becomes "return true" and all of the FPU mode selection machinery is
removed.
Link: http://lkml.kernel.org/r/1475627678-20788-3-git-send-email-riel@redhat.com
commit 6e6867093de35141f0a76b66ac13f9f2e2c8e77a upstream.
i486 derived cores like Intel Quark support only the very old,
legacy x87 FPU (FSAVE/FRSTOR, CPUID bit FXSR is not set), and
our FPU code wasn't handling the saving and restoring there
properly in the 'eagerfpu' case.
So after we made eagerfpu the default for all CPU types:
58122bf1d856 x86/fpu: Default eagerfpu=on on all CPUs
these old FPU designs broke. First, Andy Shevchenko reported a splat:
WARNING: CPU: 0 PID: 823 at arch/x86/include/asm/fpu/internal.h:163 fpu__clear+0x8c/0x160
which was us trying to execute FXRSTOR on those machines even though
they don't support it.
After taking care of that, Bryan O'Donoghue reported that a simple FPU
test still failed because we weren't initializing the FPU state properly
on those machines.
Take care of all that.
Reported-and-tested-by: Bryan O'Donoghue <pure.logic@nexus-software.ie>
Reported-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Yu-cheng <yu-cheng.yu@intel.com>
Link: http://lkml.kernel.org/r/20160311113206.GD4312@pd.tnic
commit a65050c6f17e52442716138d48d0a47301a8344b upstream.
Leonid Shatz noticed that the SDM interpretation of the following
recent commit:
394db20ca240741 ("x86/fpu: Disable AVX when eagerfpu is off")
... is incorrect and that the original behavior of the FPU code was correct.
Because AVX is not stated in CR0 TS bit description, it was mistakenly
believed to be not supported for lazy context switch. This turns out
to be false:
Intel Software Developer's Manual Vol. 3A, Sec. 2.5 Control Registers:
'TS Task Switched bit (bit 3 of CR0) -- Allows the saving of the x87 FPU/
MMX/SSE/SSE2/SSE3/SSSE3/SSE4 context on a task switch to be delayed until
an x87 FPU/MMX/SSE/SSE2/SSE3/SSSE3/SSE4 instruction is actually executed
by the new task.'
Intel Software Developer's Manual Vol. 2A, Sec. 2.4 Instruction Exception
Specification:
'AVX instructions refer to exceptions by classes that include #NM
"Device Not Available" exception for lazy context switch.'
So revert the commit.
Reported-by: Leonid Shatz <leonid.shatz@ravellosystems.com>
Signed-off-by: Yu-cheng Yu <yu-cheng.yu@intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Ravi V. Shankar <ravi.v.shankar@intel.com>
Link: http://lkml.kernel.org/r/1457569734-3785-1-git-send-email-yu-cheng.yu@intel.com
commit f363938c70a04e6bc99023a5e0c44ef7879b903f upstream.
After fixing FPU option parsing, we now parse the 'no387' boot option
too early: no387 clears X86_FEATURE_FPU before it's even probed, so
the boot CPU promptly re-enables it.
I suspect it gets even more confused on SMP.
Fix the probing code to leave X86_FEATURE_FPU off if it's been
disabled by setup_clear_cpu_cap().
Fixes: 4f81cbafcce2 ("x86/fpu: Fix early FPU command-line parsing")
commit 58122bf1d856a4ea9581d62a07c557d997d46a19 upstream.
We have eager and lazy FPU modes, introduced in:
304bceda6a18 ("x86, fpu: use non-lazy fpu restore for processors supporting xsave")
The result is rather messy. There are two code paths in almost all
of the FPU code, and only one of them (the eager case) is tested
frequently, since most kernel developers have new enough hardware
that we use eagerfpu.
It seems that, on any remotely recent hardware, eagerfpu is a win:
glibc uses SSE2, so laziness is probably overoptimistic, and, in any
case, manipulating TS is far slower that saving and restoring the
full state. (Stores to CR0.TS are serializing and are poorly
optimized.)
To try to shake out any latent issues on old hardware, this changes
the default to eager on all CPUs. If no performance or functionality
problems show up, a subsequent patch could remove lazy mode entirely.
Link: http://lkml.kernel.org/r/ac290de61bf08d9cfc2664a4f5080257ffc1075a.1453675014.git.luto@kernel.org
commit 394db20ca240741a08d472173db13d6f6a6e5a28 upstream.
When "eagerfpu=off" is given as a command-line input, the kernel
should disable AVX support.
The Task Switched bit used for lazy context switching does not
support AVX. If AVX is enabled without eagerfpu context
switching, one task's AVX state could become corrupted or leak
to other tasks. This is a bug and has bad security implications.
This only affects systems that have AVX/AVX2/AVX512 and this
issue will be found only when one actually uses AVX/AVX2/AVX512
_AND_ does eagerfpu=off.
Reference: Intel Software Developer's Manual Vol. 3A
x87 FPU/ MMX/SSE/SSE2/SSE3/SSSE3/SSE4 context on a task switch
to be delayed until an x87 FPU/MMX/SSE/SSE2/SSE3/SSSE3/SSE4
instruction is actually executed by the new task.
Sec. 13.4.1 Using the TS Flag to Control the Saving of the X87
FPU and SSE State
When the TS flag is set, the processor monitors the instruction
stream for x87 FPU, MMX, SSE instructions. When the processor
detects one of these instructions, it raises a
device-not-available exeception (#NM) prior to executing the
instruction.
Link: http://lkml.kernel.org/r/1452119094-7252-5-git-send-email-yu-cheng.yu@intel.com
commit a5fe93a549c54838063d2952dd9643b0b18aa67f upstream.
This issue is a fallout from the command-line parsing move.
should disable MPX support. The decision for turning off MPX was
made in fpu__init_system_ctx_switch(), which is after the
selection of the XSAVE format. This patch fixes it by getting
that decision done earlier in fpu__init_system_xstate().
Link: http://lkml.kernel.org/r/1452119094-7252-4-git-send-email-yu-cheng.yu@intel.com
commit 362f924b64ba0f4be2ee0cb697690c33d40be721 upstream.
Those are stupid and code should use static_cpu_has_safe() or
boot_cpu_has() instead. Kill the least used and unused ones.
The remaining ones need more careful inspection before a conversion can
happen. On the TODO.
Link: http://lkml.kernel.org/r/1449481182-27541-4-git-send-email-bp@alien8.de
Cc: David Sterba <dsterba@suse.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Chris Mason <clm@fb.com>
Cc: Josef Bacik <jbacik@fb.com>
commit ed29210cd6a67425026e78aa298fa434e11a74e3 upstream.
It is used nowhere.
Signed-off-by: Juergen Gross <jgross@suse.com>
Link: http://lkml.kernel.org/r/1447761943-770-1-git-send-email-jgross@suse.com
commit 4f81cbafcce2c603db7865e9d0e461f7947d77d4 upstream.
The function fpu__init_system() is executed before
parse_early_param(). This causes wrong FPU configuration. This
patch fixes this issue by parsing boot_command_line in the
beginning of fpu__init_system().
With all four patches in this series, each parameter disables
features as the following:
eagerfpu=off: eagerfpu, avx, avx2, avx512, mpx
no387: fpu
nofxsr: fxsr, fxsropt, xmm
noxsave: xsave, xsaveopt, xsaves, xsavec, avx, avx2, avx512,
mpx, xgetbv1 noxsaveopt: xsaveopt
noxsaves: xsaves
Link: http://lkml.kernel.org/r/1452119094-7252-2-git-send-email-yu-cheng.yu@intel.com
commit 0fde7ad71ee371ede73b3f326e58f9e8d102feb6 upstream.
arch/sparc/kernel/ds.c: In function ‘register_services’:
arch/sparc/kernel/ds.c:912:3: error: ‘strcpy’: writing at least 1 byte
into a region of size 0 overflows the destination
Reported-by: Anatoly Pugachev <matorola@gmail.com>
commit 28e4213dd331e944e7fca1954a946829162ed9d4 upstream.
Having PR_FP_MODE_FRE (i.e. Config5.FRE) set without PR_FP_MODE_FR (i.e.
Status.FR) is not supported as the lone purpose of Config5.FRE is to
emulate Status.FR=0 handling on FPU hardware that has Status.FR=1
hardwired[1][2]. Also we do not handle this case elsewhere, and assume
throughout our code that TIF_HYBRID_FPREGS and TIF_32BIT_FPREGS cannot
be set both at once for a task, leading to inconsistent behaviour if
this does happen.
Return unsuccessfully then from prctl(2) PR_SET_FP_MODE calls requesting
PR_FP_MODE_FRE to be set with PR_FP_MODE_FR clear. This corresponds to
modes allowed by `mips_set_personality_fp'.
References:
[1] "MIPS Architecture For Programmers, Vol. III: MIPS32 / microMIPS32
Privileged Resource Architecture", Imagination Technologies,
Document Number: MD00090, Revision 6.02, July 10, 2015, Table 9.69
"Config5 Register Field Descriptions", p. 262
[2] "MIPS Architecture For Programmers, Volume III: MIPS64 / microMIPS64
Document Number: MD00091, Revision 6.03, December 22, 2015, Table
9.72 "Config5 Register Field Descriptions", p. 288
Fixes: 9791554b45a2 ("MIPS,prctl: add PR_[GS]ET_FP_MODE prctl options for MIPS")
Signed-off-by: Maciej W. Rozycki <macro@mips.com>
Cc: linux-mips@linux-mips.org
Cc: <stable@vger.kernel.org> # 4.0+
Patchwork: https://patchwork.linux-mips.org/patch/19327/
Signed-off-by: James Hogan <jhogan@kernel.org>
commit c7e814628df65f424fe197dde73bfc67e4a244d7 upstream.
Use 64-bit accesses for 64-bit floating-point general registers with
PTRACE_PEEKUSR, removing the truncation of their upper halves in the
FR=1 mode, caused by commit bbd426f542cb ("MIPS: Simplify FP context
access"), which inadvertently switched them to using 32-bit accesses.
The PTRACE_POKEUSR side is fine as it's never been broken and continues
using 64-bit accesses.
Fixes: bbd426f542cb ("MIPS: Simplify FP context access")
Cc: <stable@vger.kernel.org> # 3.15+
Patchwork: https://patchwork.linux-mips.org/patch/19334/
commit 940d4113f3306e07a1f86541489b686d1a979d54 upstream.
New gcc (4.8 or later) used new shift helper functions.
So we need added new helper to private libgcc.
Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp>
Signed-off-by: Rich Felker <dalias@libc.org>
commit faf37c44a105f3608115785f17cbbf3500f8bc71 upstream.
Clear the PCR (Processor Compatibility Register) on boot to ensure we
are not running in a compatibility mode.
We've seen this cause problems when a crash (and kdump) occurs while
running compat mode guests. The kdump kernel then runs with the PCR
set and causes problems. The symptom in the kdump kernel (also seen in
petitboot after fast-reboot) is early userspace programs taking
sigills on newer instructions (seen in libc).
Signed-off-by: Michael Neuling <mikey@neuling.org>
commit 32c3fa7cdf0c4a3eb8405fc3e13398de019e828b upstream.
For LSE atomics that read and write a register operand, we need to
ensure that these operands are annotated as "early clobber" if the
register is written before all of the input operands have been consumed.
Failure to do so can result in the compiler allocating the same register
to both operands, leading to splats such as:
Unable to handle kernel paging request at virtual address 11111122222221
x1 : 1111111122222222 x0 : 1111111122222221
Process swapper/0 (pid: 1, stack limit = 0x000000008209f908)
Call trace:
test_atomic64+0x1360/0x155c
where x0 has been allocated as both the value to be stored and also the
atomic_t pointer.
This patch adds the missing clobbers.
Cc: Dave Martin <dave.martin@arm.com>
Cc: Robin Murphy <robin.murphy@arm.com>
Reported-by: Mark Salter <msalter@redhat.com>
commit 23a4d7fd34856da8218c4cfc23dba7a6ec0a423a upstream.
The return from the ftrace_stub, _mcount, ftrace_caller and
return_to_handler functions is done with "br %r14" and "br %r1".
These are indirect branches as well and need to use execute
trampolines for CONFIG_EXPOLINE=y.
The ftrace_caller function is a special case as it returns to the
start of a function and may only use %r0 and %r1. For a pre z10
machine the standard execute trampoline uses a LARL + EX to do
this, but this requires *two* registers in the range %r1..%r15.
To get around this the 'br %r1' located in the lowcore is used,
then the EX instruction does not need an address register.
But the lowcore trick may only be used for pre z14 machines,
with noexec=on the mapping for the first page may not contain
instructions. The solution for that is an ALTERNATIVE in the
expoline THUNK generated by 'GEN_BR_THUNK %r1' to switch to
EXRL, this relies on the fact that a machine that supports
noexec=on has EXRL as well.
Cc: stable@vger.kernel.org # 4.16
Fixes: f19fbd5ed6 ("s390: introduce execute-trampolines for branches")
[ Upstream commit bee3204ec3c49f6f53add9c3962c9012a5c036fa ]
Currently the kdump kernel becomes very slow if 'noapic' is specified.
Normal kernel doesn't have this bug.
Kernel parameter 'noapic' is used to disable IO-APIC in system for
testing or special purpose. Here the root cause is that in kdump
kernel LAPIC is disabled since commit:
522e664644 ("x86/apic: Disable I/O APIC before shutdown of the local APIC")
In this case we need set up through-local-APIC on boot CPU in
setup_local_APIC().
In normal kernel the legacy irq mode is enabled by the BIOS. If
it is virtual wire mode, the local-APIC has been enabled and set as
through-local-APIC.
Though we fixed the regression introduced by commit 522e664644,
to further improve robustness set up the through-local-APIC mode
explicitly, do not rely on the default boot IRQ mode.
Signed-off-by: Baoquan He <bhe@redhat.com>
Reviewed-by: Eric W. Biederman <ebiederm@xmission.com>
Cc: douly.fnst@cn.fujitsu.com
Cc: joro@8bytes.org
Cc: prarit@redhat.com
Cc: uobergfe@redhat.com
Link: http://lkml.kernel.org/r/20180214054656.3780-7-bhe@redhat.com
[ Rewrote the changelog. ]
[ Upstream commit db6775ca6e0353d2618ca7d5e210fc36ad43bbd4 ]
Using a period after a newline causes bad output.
Fixes: 64b139f97c01 ("MIPS: OCTEON: irq: add CIB and other fixes")
Patchwork: https://patchwork.linux-mips.org/patch/17886/
[ Upstream commit 0a5169add90e43ab45ab1ba34223b8583fcaf675 ]
IRQ parameters for the SoC devices connected directly to I/O APIC lines
(without PCI IRQ routing) may be specified in the Device Tree.
Called from DT IRQ parser, irq_create_fwspec_mapping() calls
irq_domain_alloc_irqs() with a pointer to irq_fwspec structure as @arg.
But x86-specific DT IRQ allocation code casts @arg to of_phandle_args
structure pointer and crashes trying to read the IRQ parameters. The
function was not converted when the mapping descriptor was changed to
irq_fwspec in the generic irqdomain code.
Fixes: 11e4438ee330 ("irqdomain: Introduce a firmware-specific IRQ specifier structure")
Signed-off-by: Ivan Gorinov <ivan.gorinov@intel.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Rob Herring <robh+dt@kernel.org>
Link: https://lkml.kernel.org/r/a234dee27ea60ce76141872da0d6bdb378b2a9ee.1520450752.git.ivan.gorinov@intel.com
[ Upstream commit 628df9dc5ad886b0a9b33c75a7b09710eb859ca1 ]
Commit 08d53aa58cb1 added CRC32 calculation in early_init_dt_verify() and
checking in late initcall of_fdt_raw_init(), making early_init_dt_verify()
mandatory.
The required call to early_init_dt_verify() was not added to the
x86-specific implementation, causing failure to create the sysfs entry in
of_fdt_raw_init().
Fixes: 08d53aa58cb1 ("of/fdt: export fdt blob as /sys/firmware/fdt")
Link: https://lkml.kernel.org/r/c8c7e941efc63b5d25ebf9b6350b0f3df38f6098.1520450752.git.ivan.gorinov@intel.com
[ Upstream commit f5246862f82f1e16bbf84cda4cddf287672b30fe ]
In commit 4f8b50bbbe63 ("irq_work, ppc: Fix up arch hooks") a new
function arch_irq_work_raise() was added without a prototype in header
irq_work.h.
Fix the following warning (treated as error in W=1):
arch/powerpc/kernel/time.c:523:6: error: no previous prototype for ‘arch_irq_work_raise’
Signed-off-by: Mathieu Malaterre <malat@debian.org>
[ Upstream commit 05454c1bde91fb013c0431801001da82947e6b5a ]
According to the QCA u-boot source the "PCIE Phase Lock Loop
Configuration (PCIE_PLL_CONFIG)" register is for all SoCs except the
QCA955X and QCA956X at offset 0x10.
Since the PCIE PLL config register is only defined for the AR724x fix
only this value. The value is wrong since the day it was added and isn't
used by any driver yet.
Signed-off-by: Mathias Kresin <dev@kresin.me>
Patchwork: https://patchwork.linux-mips.org/patch/16048/
[ Upstream commit 0bcc3fb95b97ac2ca223a5a870287b37f56265ac ]
Devices which use level-triggered interrupts under Windows 2016 with
Hyper-V role enabled don't work: Windows disables EOI broadcast in SPIV
unconditionally. Our in-kernel IOAPIC implementation emulates an old IOAPIC
version which has no EOI register so EOI never happens.
The issue was discovered and discussed a while ago:
https://www.spinics.net/lists/kvm/msg148098.html
While this is a guest OS bug (it should check that IOAPIC has the required
capabilities before disabling EOI broadcast) we can workaround it in KVM:
advertising DIRECTED_EOI with in-kernel IOAPIC makes little sense anyway.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
[ Upstream commit 6d97d5aba08b26108f95dc9fb7bbe4d9436c769c ]
Fixes the warning "GIC: PPI13 is secure or misconfigured" by
changing the interrupt type from level_low to edge_raising
Signed-off-by: Philipp Puschmann <pp@emlix.com>
Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
[ Upstream commit e1ebd0e5b9d0a10ba65e63a3514b6da8c6a5a819 ]
Current code in power_pmu_disable() does not clear the sampling
registers like Sampling Instruction Address Register (SIAR) and
Sampling Data Address Register (SDAR) after disabling the PMU. Since
these are userspace readable and could contain kernel addresses, add
code to explicitly clear the content of these registers.
Also add a "context synchronizing instruction" to enforce no further
updates to these registers as suggested by Power ISA v3.0B. From
section 9.4, on page 1108:
"If an mtspr instruction is executed that changes the value of a
Performance Monitor register other than SIAR, SDAR, and SIER, the
change is not guaranteed to have taken effect until after a
subsequent context synchronizing instruction has been executed (see
Chapter 11. "Synchronization Requirements for Context Alterations"
on page 1133)."
Signed-off-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com>
[mpe: Massage change log and add ISA reference]
[ Upstream commit bb19af816025d495376bd76bf6fbcf4244f9a06d ]
The current Branch History Rolling Buffer (BHRB) code does not check
for any privilege levels before updating the data from BHRB. This
could leak kernel addresses to userspace even when profiling only with
userspace privileges. Add proper checks to prevent it.
Acked-by: Balbir Singh <bsingharora@gmail.com>
[ Upstream commit f61e64310b75733d782e930d1fb404b84699eed6 ]
As of commit 205e1b7f51e4 ("dma-mapping: warn when there is no
coherent_dma_mask") the Freescale FEC driver is issuing the following
warning on driver initialization on ColdFire systems:
WARNING: CPU: 0 PID: 1 at ./include/linux/dma-mapping.h:516 0x40159e20
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 4.16.0-rc7-dirty #4
Stack from 41833dd8:
41833dd8 40259c53 40025534 40279e26 00000003 00000000 4004e514 41827000
400255de 40244e42 00000204 40159e20 00000009 00000000 00000000 4024531d
40159e20 40244e42 00000204 00000000 00000000 00000000 00000007 00000000
00000000 40279e26 4028d040 40226576 4003ae88 40279e26 418273f6 41833ef8
7fffffff 418273f2 41867028 4003c9a2 4180ac6c 00000004 41833f8c 4013e71c
40279e1c 40279e26 40226c16 4013ced2 40279e26 40279e58 4028d040 00000000
Call Trace:
[<40025534>] 0x40025534
[<4004e514>] 0x4004e514
[<400255de>] 0x400255de
[<40159e20>] 0x40159e20
It is not fatal, the driver and the system continue to function normally.
As per the warning the coherent_dma_mask is not set on this device.
There is nothing special about the DMA memory coherency on this hardware
so we can just set the mask to 32bits in the platform data for the FEC
ethernet devices.
[ Upstream commit 0834d627fbea00c1444075eb3e448e1974da452d ]
In mpic_physmask() we loop over all CPUs up to 32, then get the hard
SMP processor id of that CPU.
Currently that's possibly walking off the end of the paca array, but
in a future patch we will change the paca array to be an array of
pointers, and in that case we will get a NULL for missing CPUs and
oops. eg:
Unable to handle kernel paging request for data at address 0x88888888888888b8
Faulting instruction address: 0xc00000000004e380
Oops: Kernel access of bad area, sig: 11 [#1]
NIP .mpic_set_affinity+0x60/0x1a0
LR .irq_do_set_affinity+0x48/0x100
Fix it by checking the CPU is possible, this also fixes the code if
there are gaps in the CPU numbering which probably never happens on
mpic systems but who knows.
Debugged-by: Nicholas Piggin <npiggin@gmail.com>
[ Upstream commit d13864b68e41c11e4231de90cf358658f6ecea45 ]
This avoids a lot of -Wunused warnings such as:
kernel/debug/debug_core.c: In function ‘kgdb_cpu_enter’:
./arch/sparc/include/asm/cmpxchg_64.h:55:22: warning: value computed is not used [-Wunused-value]
#define xchg(ptr,x) ((__typeof__(*(ptr)))__xchg((unsigned long)(x),(ptr),sizeof(*(ptr))))
./arch/sparc/include/asm/atomic_64.h:86:30: note: in expansion of macro ‘xchg’
#define atomic_xchg(v, new) (xchg(&((v)->counter), new))
kernel/debug/debug_core.c:508:4: note: in expansion of macro ‘atomic_xchg’
atomic_xchg(&kgdb_active, cpu);
[ Upstream commit add5ff7a216ee545a214013f26d1ef2f44a9c9f8 ]
Exit to userspace with KVM_INTERNAL_ERROR_EMULATION if we encounter
an exception in Protected Mode while emulating guest due to invalid
guest state. Unlike Big RM, KVM doesn't support emulating exceptions
in PM, i.e. PM exceptions are always injected via the VMCS. Because
we will never do VMRESUME due to emulation_required, the exception is
never realized and we'll keep emulating the faulting instruction over
and over until we receive a signal.
Exit to userspace iff there is a pending exception, i.e. don't exit
simply on a requested event. The purpose of this check and exit is to
aid in debugging a guest that is in all likelihood already doomed.
Invalid guest state in PM is extremely limited in normal operation,
e.g. it generally only occurs for a few instructions early in BIOS,
and any exception at this time is all but guaranteed to be fatal.
Non-vectored interrupts, e.g. INIT, SIPI and SMI, can be cleanly
handled/emulated, while checking for vectored interrupts, e.g. INTR
and NMI, without hitting false positives would add a fair amount of
complexity for almost no benefit (getting hit by lightning seems
more likely than encountering this specific scenario).
Add a WARN_ON_ONCE to vmx_queue_exception() if we try to inject an
exception via the VMCS and emulation_required is true.
Signed-off-by: Sean Christopherson <sean.j.christopherson@intel.com>
[ Upstream commit e3e288121408c3abeed5af60b87b95c847143845 ]
The pmd_set_huge() and pud_set_huge() functions are used from
the generic ioremap() code to establish large mappings where this
is possible.
But the generic ioremap() code does not check whether the
PMD/PUD entries are already populated with a non-leaf entry,
so that any page-table pages these entries point to will be
lost.
Further, on x86-32 with SHARED_KERNEL_PMD=0, this causes a
BUG_ON() in vmalloc_sync_one() when PMD entries are synced
from swapper_pg_dir to the current page-table. This happens
because the PMD entry from swapper_pg_dir was promoted to a
huge-page entry while the current PGD still contains the
non-leaf entry. Because both entries are present and point
to a different page, the BUG_ON() triggers.
This was actually triggered with pti-x32 enabled in a KVM
virtual machine by the graphics driver.
A real and better fix for that would be to improve the
page-table handling in the generic ioremap() code. But that is
out-of-scope for this patch-set and left for later work.
Reported-by: David H. Gutteridge <dhgutteridge@sympatico.ca>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: David Laight <David.Laight@aculab.com>
Cc: Eduardo Valentin <eduval@amazon.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Juergen Gross <jgross@suse.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Waiman Long <llong@redhat.com>
Cc: aliguori@amazon.com
Cc: daniel.gruss@iaik.tugraz.at
Cc: hughd@google.com
Cc: keescook@google.com
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20180411152437.GC15462@8bytes.org
[ Upstream commit 96a598996f6ac518ac79839ecbb17c91af91f4f7 ]
When responding to a debug trap (breakpoint) in userspace, the
kernel's trap handler raised SIGTRAP but returned from the trap via a
code path that ignored pending signals, resulting in an infinite loop
re-executing the trapping instruction.
[ Upstream commit 73b9160d0dfe44dfdaffd6465dc1224c38a4a73c ]
Define vdso_start, vdso_end as array to avoid compile-time analysis error
for the case of built with CONFIG_FORTIFY_SOURCE.
and, since vdso_start, vdso_end are used in vdso.c only,
move extern-declaration from vdso.h to vdso.c.
If kernel is built with CONFIG_FORTIFY_SOURCE,
compile-time error happens at this code.
- if (memcmp(&vdso_start, "177ELF", 4))
The size of "&vdso_start" is recognized as 1 byte, but n is 4,
So that compile-time error is reported.
Signed-off-by: Jinbum Park <jinb.park7@gmail.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
[ Upstream commit debd574f4195e205ba505b25e19b2b797f4bcd94 ]
The current code for initializing the VRMA (virtual real memory area)
for HPT guests requires the page size of the backing memory to be one
of 4kB, 64kB or 16MB. With a radix host we have the possibility that
the backing memory page size can be 2MB or 1GB. In these cases, if the
guest switches to HPT mode, KVM will not initialize the VRMA and the
guest will fail to run.
In fact it is not necessary that the VRMA page size is the same as the
backing memory page size; any VRMA page size less than or equal to the
backing memory page size is acceptable. Therefore we now choose the
largest page size out of the set {4k, 64k, 16M} which is not larger
than the backing memory page size.
Signed-off-by: Paul Mackerras <paulus@ozlabs.org>
CPU hotplug operations
[ Upstream commit 4596749339e06dc7a424fc08a15eded850ed78b7 ]
Without this fix, /proc/cpuinfo will display an incorrect amount
of CPU cores, after bringing them offline and online again, as
exemplified below:
$ cat /proc/cpuinfo | grep cores
cpu cores : 4
cpu cores : 8
cpu cores : 8
cpu cores : 20
cpu cores : 4
cpu cores : 3
cpu cores : 2
cpu cores : 2
This patch fixes this by always zeroing the booted_cores variable
upon turning off a logical CPU.
Tested-by: Dou Liyang <douly.fnst@cn.fujitsu.com>
Signed-off-by: Samuel Neves <sneves@dei.uc.pt>
Cc: jgross@suse.com
Cc: luto@kernel.org
Cc: vkuznets@redhat.com
Link: http://lkml.kernel.org/r/20180221205036.5244-1-sneves@dei.uc.pt
[ Upstream commit 472e8c55cf6622d1c112dc2bc777f68bbd4189db ]
Successful RMW operations are supposed to be fully ordered, but
Alpha's xchg() and cmpxchg() do not meet this requirement.
Will Deacon noticed the bug:
> So MP using xchg:
> WRITE_ONCE(x, 1)
> xchg(y, 1)
> smp_load_acquire(y) == 1
> READ_ONCE(x) == 0
> would be allowed.
... which thus violates the above requirement.
Fix it by adding a leading smp_mb() to the xchg() and cmpxchg() implementations.
Reported-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Andrea Parri <parri.andrea@gmail.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: linux-alpha@vger.kernel.org
Link: http://lkml.kernel.org/r/1519291488-5752-1-git-send-email-parri.andrea@gmail.com
[ Upstream commit ba6887836178d43b3665b9da075c2c5dfe1d207c ]
We need to enable PM runtime on omap1 also as otherwise we
will get errors:
omap_timer omap_timer.1: omap_dm_timer_probe: pm_runtime_get_sync failed!
omap_timer: probe of omap_timer.1 failed with error -13
We are checking for OMAP_TIMER_NEEDS_RESET flag elsewhere so this is
safe to do.
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Keerthy <j-keerthy@ti.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
[ Upstream commit 083b20907185b076f21c265b30fe5b5f24c03d8c ]
I am using SECCOMP to filter syscalls on a ppc32 platform, and noticed
that the JIT compiler was failing on the BPF even though the
interpreter was working fine.
The issue was that the compiler was missing one of the instructions
used by SECCOMP, so here is a patch to enable JIT for that
instruction.
Fixes: eb84bab0fb38 ("ppc: Kconfig: Enable BPF JIT on ppc32")
Signed-off-by: Mark Lord <mlord@pobox.com>
Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
[ Upstream commit cb13b424e986aed68d74cbaec3449ea23c50e167 ]
Continuing along with the fight against smp_read_barrier_depends() [1]
(or rather, against its improper use), add an unconditional barrier to
cmpxchg. This guarantees that dependency ordering is preserved when a
dependency is headed by an unsuccessful cmpxchg. As it turns out, the
change could enable further simplification of LKMM as proposed in [2].
[1] https://marc.info/?l=linux-kernel&m=150884953419377&w=2
https://marc.info/?l=linux-kernel&m=150884946319353&w=2
https://marc.info/?l=linux-kernel&m=151215810824468&w=2
https://marc.info/?l=linux-kernel&m=151215816324484&w=2
[2] https://marc.info/?l=linux-kernel&m=151881978314872&w=2
Acked-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1519152356-4804-1-git-send-email-parri.andrea@gmail.com
[ Upstream commit 8cbbf1745dcde7ba7e423dc70619d223de90fd43 ]
When exposing data access through debugfs, the correct
debugfs_create_*() functions must be used, depending on data type.
Remove all casts from data pointers passed to debugfs_create_*()
functions, as such casts prevent the compiler from flagging bugs.
Correct all wrong usage:
- clk.rate is unsigned long, not u32,
- clk.flags is u8, not u32, which exposed the successive
clk.rate_offset and clk.src_offset fields.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Aaro Koskinen <aaro.koskinen@iki.fi>
[ Upstream commit d3be6d2a08bd26580562d9714d3d97ea9ba22c73 ]
For platform_suspend_ops, the finish call is too late to re-enable wake
irqs and we need re-enable wake irqs on wake call instead.
Otherwise noirq resume for devices has already happened. And then
dev_pm_disarm_wake_irq() has already disabled the dedicated wake irqs
when the interrupt triggers and the wake irq is never handled.
For devices that are already in PM runtime suspended state when we
enter suspend this means that a possible wake irq will never trigger.
And this can lead into a situation where a device has a pending padconf
wake irq, and the device will stay unresponsive to any further wake
irqs.
This issue can be easily reproduced by setting serial console log level
to zero, letting the serial console idle, and suspend the system from
an ssh terminal. Then try to wake up the system by typing to the serial
console.
Note that this affects only omap3 PRM interrupt as that's currently
the only omap variant that does anything in omap_pm_wake().
In general, for the wake irqs to work, the interrupt must have either
IRQF_NO_SUSPEND or IRQF_EARLY_RESUME set for it to trigger before
dev_pm_disarm_wake_irq() disables the wake irqs.
Reported-by: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: Tero Kristo <t-kristo@ti.com>
[ Upstream commit db35340c536f1af0108ec9a0b2126a05d358d14a ]
When more than one GP timers are used as kernel system timers and the
corresponding nodes in device-tree are marked with the same "disabled"
property, then the "attr" field of the property will be initialized
more than once as the property being added to sys file system via
__of_add_property_sysfs().
In __of_add_property_sysfs(), the "name" field of pp->attr.attr is set
directly to the return value of safe_name(), without taking care of
whether it's already a valid pointer to a memory block. If it is, its
old value will always be overwritten by the new one and the memory block
allocated before will a "ghost", then a kmemleak happened.
That the same "disabled" property being added to different nodes of device
tree would cause that kind of kmemleak overhead, at least once.
To fix it, allocate the property dynamically, and delete static one.
Signed-off-by: Qi Hou <qi.hou@windriver.com>
[ Upstream commit 827cc2fa024dd6517d62de7a44c7b42f32af371b ]
'default N' should be 'default n', though they happen to have the same
effect here, due to undefined symbols (N in this case) evaluating to n
in a tristate sense.
Remove the default from ARC_EMUL_UNALIGNED instead of changing it. bool
and tristate symbols implicitly default to n.
Discovered with the
https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_ulfalizer_Kconfiglib_blob_master_examples_list-5Fundefined.py&d=DwIBAg&c=DPL6_X_6JkXFx7AXWqB0tg&r=c14YS-cH-kdhTOW89KozFhBtBJgs1zXscZojEZQ0THs&m=WxxD8ozR7QQUVzNCBksiznaisBGO_crN7PBOvAoju8s&s=1LmxsNqxwT-7wcInVpZ6Z1J27duZKSoyKxHIJclXU_M&e=
script.
Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
