path: root/arch
2008-06-16Merge branch 'linus' into tracing/mmiotrace-mergefixupstip-tracing-mmiotrace-mergefixups-2008-06-16_09.16_MonIngo Molnar
2008-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: fixup write combine comment in pci_mmap_resource x86: PAT export resource_wc in pci sysfs x86, pci-dma.c: don't always add __GFP_NORETRY to gfp suspend-vs-iommu: prevent suspend if we could not resume x86: pci-dma.c: use __GFP_NO_OOM instead of __GFP_NORETRY pci, x86: add workaround for bug in ASUS A7V600 BIOS (rev 1005) PCI: use dev_to_node in pci_call_probe PCI: Correct last two HP entries in the bfsort whitelist
2008-06-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: update my email address parisc: fix miscompilation of ip_fast_csum with gcc >= 4.3 parisc: fix off by one in setup_sigcontext32 parisc: export empty_zero_page parisc: export copy_user_page_asm parisc: move head.S to head.text section Revert "parisc: fix trivial section name warnings"
2008-06-13parisc: fix off by one in setup_sigcontext32Kyle McMartin
Thankfully, the values were irrelevant... Spotted by newer gcc. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13parisc: export empty_zero_pageKyle McMartin
Needed by ext4 when built as a module. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13parisc: export copy_user_page_asmKyle McMartin
Needed by fuse (via copy_highpage). Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13parisc: move head.S to head.text sectionKyle McMartin
And explicitly list it in vmlinux.lds... Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13Revert "parisc: fix trivial section name warnings"Kyle McMartin
This reverts commit bd3bb8c15b9a80dbddfb7905b237a4a11a4725b4. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-12Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 5091/1: Add missing bitfield include to regs-lcd.h [ARM] 5090/1: Correct pxafb palette typo error [ARM] 5077/1: spi: fix list scan success verification in PXA ssp driver
2008-06-12provide rtc_cmos platform deviceStas Sergeev
Recently (around 2.6.25) I've noticed that RTC no longer works for me. It turned out this is because I use pnpacpi=off kernel option to work around the parport_pc bugs. I always did so, but RTC used to work fine in the past, and now it have regressed. The patch fixes the problem by creating the platform device for the RTC when PNP is disabled. This may also help running the PNP-enabled kernel on an older PCs. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Cc: David Brownell <david-b@pacbell.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12uml: work around broken host PTRACE_SYSEMUJeff Dike
Fedora broke PTRACE_SYSEMU again, and UML crashes as a result when it doesn't need to. This patch makes the PTRACE_SYSEMU check fail gracefully and makes UML fall back to PTRACE_SYSCALL. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12uml: remove include of asm/user.hJeff Dike
I allowed an include of asm/user.h to sneak back in. This patch replaces it with sys/user.h. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12m68knommu: init coldfire timer TRR with n - 1, not nPhilippe De Muyter
The coldfire timer must be initialised to n - 1 if we want it to count n cycles between each tick interrupt. This was already fixed, but has been lost with the conversion to GENERIC_TIMER. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12Merge branch 'pci-for-jesse' of ↵Jesse Barnes
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip into for-linus
2008-06-12Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: fix pointer type warning in arch/x86/mm/init_64.c:early_memtest x86, lockdep: fix "WARNING: at kernel/lockdep.c:2658 check_flags+0x4c/0x128()" x86: fix an incompatible pointer type warning on 64-bit compilations x86: fix lockdep warning during suspend-to-ram x86: fix unused variable 'loops' warning in arch/x86/boot/a20.c Revert "x86: fix ioapic bug again" x86: fix asm warning in head_32.S x86: fix endless page faults in mount_block_root for Linux 2.6 geode: fix modular build
2008-06-12x86: fix pointer type warning in arch/x86/mm/init_64.c:early_memtestKevin Winchester
Changed the call to find_e820_area_size to pass u64 instead of unsigned long. Signed-off-by: Kevin Winchester <kjwinchester@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12x86, lockdep: fix "WARNING: at kernel/lockdep.c:2658 check_flags+0x4c/0x128()"Vegard Nossum
Alessandro Suardi reported: > Recently upgraded my FC6 desktop to Fedora 9; with the > latest nautilus RPM updates my VNC session went nuts > with nautilus pegging the CPU for everything that breathed. > > I now reverted to an earlier nautilus package, but during > the peak CPU period my kernel spat this: > > [314185.623294] ------------[ cut here ]------------ > [314185.623414] WARNING: at kernel/lockdep.c:2658 check_flags+0x4c/0x128() > [314185.623514] Modules linked in: iptable_filter ip_tables x_tables > sunrpc ipv6 fuse snd_via82xx snd_ac97_codec ac97_bus snd_mpu401_uart > snd_rawmidi via686a hwmon parport_pc sg parport uhci_hcd ehci_hcd > [314185.623924] Pid: 12314, comm: nautilus Not tainted 2.6.26-rc5-git2 #4 > [314185.624021] [<c0115b95>] warn_on_slowpath+0x41/0x7b > [314185.624021] [<c010de70>] ? do_page_fault+0x2c1/0x5fd > [314185.624021] [<c0128396>] ? up_read+0x16/0x28 > [314185.624021] [<c010de70>] ? do_page_fault+0x2c1/0x5fd > [314185.624021] [<c012fa33>] ? __lock_acquire+0xbb4/0xbc3 > [314185.624021] [<c012d0a0>] check_flags+0x4c/0x128 > [314185.624021] [<c012fa73>] lock_acquire+0x31/0x7d > [314185.624021] [<c0128cf6>] __atomic_notifier_call_chain+0x30/0x80 > [314185.624021] [<c0128cc6>] ? __atomic_notifier_call_chain+0x0/0x80 > [314185.624021] [<c0128d52>] atomic_notifier_call_chain+0xc/0xe > [314185.624021] [<c0128d81>] notify_die+0x2d/0x2f > [314185.624021] [<c01043b0>] do_int3+0x1f/0x4d > [314185.624021] [<c02f2d3b>] int3+0x27/0x2c > [314185.624021] ======================= > [314185.624021] ---[ end trace 1923f65a2d7bb246 ]--- > [314185.624021] possible reason: unannotated irqs-off. > [314185.624021] irq event stamp: 488879 > [314185.624021] hardirqs last enabled at (488879): [<c0102d67>] > restore_nocheck+0x12/0x15 > [314185.624021] hardirqs last disabled at (488878): [<c0102dca>] > work_resched+0x19/0x30 > [314185.624021] softirqs last enabled at (488876): [<c011a1ba>] > __do_softirq+0xa6/0xac > [314185.624021] softirqs last disabled at (488865): [<c010476e>] > do_softirq+0x57/0xa6 > > I didn't seem to find it with some googling, so here it is. > > I was incidentally ltracing that process to try and find out > what was gulping down that much CPU (sorry, no idea > whether ltrace and the WARNING happened at the same > time or which came first) and: Yeah, this is extremely likely to be the source of the warning. The warning should be harmless, however. > Box is my trusty noname K7-800, 512MB RAM; if there's > anything else useful I might be able to provide, just ask. It would be interesting to see where the int3 comes from. Too bad, lockdep doesn't provide the register dump. The stacktrace also doesn't go further than the int3(), I wonder if this int3 came from userspace? The ltrace readme says "software breakpoints, like gdb", so I guess this is the case. Yep, seems like it. This looks relevant: | commit fb1dac909d94ff807cd833d340c6827c3a957159 | Author: Peter Zijlstra <a.p.zijlstra@chello.nl> | Date: Wed Jan 16 09:51:59 2008 +0100 | | lockdep: more hardirq annotations for notify_die() I'm attaching a similarly-looking patch for this case (DO_VM86_ERROR), though I suspect it might be missing for the other cases (DO_ERROR/DO_ERROR_INFO) as well. Reported-by: Alessandro Suardi <alessandro.suardi@gmail.com> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12x86: fix an incompatible pointer type warning on 64-bit compilationsDavid Howells
Fix an incompatible pointer type warning on x86_64 compilations. early_memtest() is passing a u64* to find_e820_area_size() which is expecting an unsigned long. Change t_start and t_size to unsigned long as those are also 64-bit types on x88_64. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12x86: fix lockdep warning during suspend-to-ramPeter Zijlstra
Andrew Morton wrote: > I've been seeing the below for a long time during suspend-to-ram on the Vaio. > > > PM: Syncing filesystems ... done. > PM: Preparing system for mem sleep > Freezing user space processes ... <4>------------[ cut here ]------------ > WARNING: at kernel/lockdep.c:2658 check_flags+0x4c/0x127() > Modules linked in: i915 drm ipw2200 sonypi ipv6 autofs4 hidp l2cap bluetooth sunrpc nf_conntrack_netbios_ns ipt_REJECT nf_conntrack_ipv4 xt_state nf_conntrack xt_tcpudp iptable_filter ip_tables x_tables acpi_cpufreq nvram ohci1394 ieee1394 ehci_hcd uhci_hcd sg joydev snd_hda_intel snd_seq_dummy sr_mod snd_seq_oss cdrom snd_seq_midi_event snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss ieee80211 pcspkr ieee80211_crypt snd_pcm i2c_i801 snd_timer i2c_core ide_pci_generic piix snd soundcore snd_page_alloc button ext3 jbd ide_disk ide_core [last unloaded: ipw2200] > Pid: 3250, comm: zsh Not tainted 2.6.26-rc5 #1 > [<c011c5f5>] warn_on_slowpath+0x41/0x6d > [<c01080e6>] ? native_sched_clock+0x82/0x96 > [<c013789c>] ? mark_held_locks+0x41/0x5c > [<c0315688>] ? _spin_unlock_irqrestore+0x36/0x58 > [<c0137a29>] ? trace_hardirqs_on+0xe6/0x10d > [<c0138637>] ? __lock_acquire+0xae3/0xb2b > [<c0313413>] ? schedule+0x39b/0x3b4 > [<c0135596>] check_flags+0x4c/0x127 > [<c01386b9>] lock_acquire+0x3a/0x86 > [<c0315075>] _spin_lock+0x26/0x53 > [<c0140660>] ? refrigerator+0x13/0xc3 > [<c0140660>] refrigerator+0x13/0xc3 > [<c012684a>] get_signal_to_deliver+0x3c/0x31e > [<c0102fe7>] do_notify_resume+0x91/0x6ee > [<c01359fd>] ? lock_release_holdtime+0x50/0x56 > [<c0315688>] ? _spin_unlock_irqrestore+0x36/0x58 > [<c0235d24>] ? read_chan+0x0/0x58c > [<c0137a29>] ? trace_hardirqs_on+0xe6/0x10d > [<c0315694>] ? _spin_unlock_irqrestore+0x42/0x58 > [<c0230afa>] ? tty_ldisc_deref+0x5c/0x63 > [<c0233104>] ? tty_read+0x66/0x98 > [<c014b3f0>] ? audit_syscall_exit+0x2aa/0x2c5 > [<c0109430>] ? do_syscall_trace+0x6b/0x16f > [<c0103a9c>] work_notifysig+0x13/0x1b > ======================= > ---[ end trace 25b49fe59a25afa5 ]--- > possible reason: unannotated irqs-off. > irq event stamp: 58919 > hardirqs last enabled at (58919): [<c0103afd>] syscall_exit_work+0x11/0x26 Joy - I so love entry.S Best I can make of it: syscall_exit_work resume_userspace DISABLE_INTERRUPTS (no TRACE_IRQS_OFF) work_pending work_notifysig do_notify_resume() do_signal() get_signal_to_deliver() try_to_freeze() refrigerator() task_lock() -> check_flags() -> BANG The normal path is: syscall_exit_work resume_userspace DISABLE_INTERRUPTS restore_all TRACE_IRQS_IRET iret No idea why that would not warn.. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12x86: fix unused variable 'loops' warning in arch/x86/boot/a20.cManish Katiyar
Following patch fixes the below warning message : arch/x86/boot/a20.c:118: warning: unused variable 'loops' Signed-off-by : Manish Katiyar <mkatiyar@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12Revert "x86: fix ioapic bug again"Ingo Molnar
This reverts commit 6e908947b4995bc0e551a8257c586d5c3e428201. Németh Márton reported: | there is a problem in 2.6.26-rc3 which was not there in case of | 2.6.25: the CPU wakes up ~90,000 times per sec instead of ~60 per sec. | | I also "git bisected" the problem, the result is: | | 6e908947b4995bc0e551a8257c586d5c3e428201 is first bad commit | commit 6e908947b4995bc0e551a8257c586d5c3e428201 | Author: Ingo Molnar <mingo@elte.hu> | Date: Fri Mar 21 14:32:36 2008 +0100 | | x86: fix ioapic bug again the original problem is fixed by Maciej W. Rozycki in the tip/x86/apic branch (confirmed by Márton), but those changes are too intrusive for v2.6.26 so we'll go for the less intrusive (repeated) revert now. Reported-and-bisected-by: Németh Márton <nm127@freemail.hu> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12x86: fix asm warning in head_32.SJoe Korty
On Mon, May 19, 2008 at 04:10:02PM -0700, Linus Torvalds wrote: > It also causes these warnings on 32-bit PAE: > > AS arch/x86/kernel/head_32.o > arch/x86/kernel/head_32.S: Assembler messages: > arch/x86/kernel/head_32.S:225: Warning: left operand is a bignum; integer 0 assumed > arch/x86/kernel/head_32.S:609: Warning: left operand is a bignum; integer 0 assumed > > and I do not see why (the end result seems to be identical). Fix head_32.S gcc bignum warnings when CONFIG_PAE=y. arch/x86/kernel/head_32.S: Assembler messages: arch/x86/kernel/head_32.S:225: Warning: left operand is a bignum; integer 0 assumed arch/x86/kernel/head_32.S:609: Warning: left operand is a bignum; integer 0 assumed The assembler was stumbling over the 64-bit constant 0x100000000 in the KPMDS #define. Testing: a cmp(1) on head_32.o before and after shows the binary is unchanged. Signed-off-by: Joe Korty <joe.korty@ccur.com Cc: Hugh Dickins <hugh@veritas.com> Cc: Theodore Tso <tytso@mit.edu> Cc: Gabriel C <nix.or.die@googlemail.com> Cc: Keith Packard <keithp@keithp.com> Cc: "Pallipadi Venkatesh" <venkatesh.pallipadi@intel.com> Cc: Eric Anholt <eric@anholt.net> Cc: "Siddha Suresh B" <suresh.b.siddha@intel.com> Cc: bugme-daemon@bugzilla.kernel.org Cc: airlied@linux.ie Cc: "Barnes Jesse" <jesse.barnes@intel.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12x86: fix endless page faults in mount_block_root for Linux 2.6Henry Nestler
Page faults in kernel address space between PAGE_OFFSET up to VMALLOC_START should not try to map as vmalloc. Fix rarely endless page faults inside mount_block_root for root filesystem at boot time. All 32bit kernels up to 2.6.25 can fail into this hole. I can not present this under native linux kernel. I see, that the 64bit has fixed the problem. I copied the same lines into 32bit part. Recorded debugs are from coLinux kernel 2.6.22.18 (virtualisation): http://www.henrynestler.com/colinux/testing/pfn-check-0.7.3/20080410-antinx/bug16-recursive-page-fault-endless.txt The physicaly memory was trimmed down to 192MB to better catch the bug. More memory gets the bug more rarely. Details, how every x86 32bit system can fail: Start from "mount_block_root", http://lxr.linux.no/linux/init/do_mounts.c#L297 There the variable "fs_names" got one memory page with 4096 bytes. Variable "p" walks through the existing file system types. The first string is no problem. But, with the second loop in mount_block_root the offset of "p" is not at beginning of page, the offset is for example +9, if "reiserfs" is the first in list. Than calls do_mount_root, and lands in sys_mount. Remember: Variable "type_page" contains now "fs_type+9" and not contains a full page. The sys_mount copies 4096 bytes with function "exact_copy_from_user()": http://lxr.linux.no/linux/fs/namespace.c#L1540 Mostly exist pages after the buffer "fs_names+4096+9" and the page fault handler was not called. No problem. In the case, if the page after "fs_names+4096" is not mapped, the page fault handler was called from http://lxr.linux.no/linux/fs/namespace.c#L1320 The do_page_fault gots an address 0xc03b4000. It's kernel address, address >= TASK_SIZE, but not from vmalloc! It's from "__getname()" alias "kmem_cache_alloc". The "error_code" is 0. "vmalloc_fault" will be call: http://lxr.linux.no/linux/arch/i386/mm/fault.c#L332 "vmalloc_fault" tryed to find the physical page for a non existing virtual memory area. The macro "pte_present" in vmalloc_fault() got a next page fault for 0xc0000ed0 at: http://lxr.linux.no/linux/arch/i386/mm/fault.c#L282 No PTE exist for such virtual address. The page fault handler was trying to sync the physical page for the PTE lockup. This called vmalloc_fault() again for address 0xc000000, and that also was not existing. The endless began... In normal case the cpu would still loop with disabled interrrupts. Under coLinux this was catched by a stack overflow inside printk debugs. Signed-off-by: Henry Nestler <henry.nestler@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-06-12geode: fix modular buildIngo Molnar
-tip testing found this build bug: MODPOST 331 modules ERROR: "geode_mfgpt_toggle_event" [drivers/watchdog/geodewdt.ko] undefined! ERROR: "geode_mfgpt_alloc_timer" [drivers/watchdog/geodewdt.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 with this config: http://redhat.com/~mingo/misc/config-Wed_Jun__4_18_01_59_CEST_2008.bad export those symbols. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12Merge branch 'core/iter-div' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/iter-div' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: always_inline timespec_add_ns add an inlined version of iter_div_u64_rem common implementation of iterative div/mod
2008-06-12common implementation of iterative div/modJeremy Fitzhardinge
We have a few instances of the open-coded iterative div/mod loop, used when we don't expcet the dividend to be much bigger than the divisor. Unfortunately modern gcc's have the tendency to strength "reduce" this into a full mod operation, which isn't necessarily any faster, and even if it were, doesn't exist if gcc implements it in libgcc. The workaround is to put a dummy asm statement in the loop to prevent gcc from performing the transformation. This patch creates a single implementation of this loop, and uses it to replace the open-coded versions I know about. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Segher Boessenkool <segher@kernel.crashing.org> Cc: Christian Kujau <lists@nerdbynature.de> Cc: Robert Hancock <hancockr@shaw.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-11Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (23 commits) ACPICA: fix stray va_end() caused by mis-merge ACPI: Reject below-freezing temperatures as invalid critical temperatures ACPICA: Fix for access to deleted object <regression> ACPICA: Fix to make _SST method optional ACPICA: Fix for Load operator, load table at the namespace root ACPICA: Ignore ACPI table signature for Load() operator ACPICA: Fix to allow zero-length ASL field declarations ACPI: use memory_read_from_buffer() bay: exit if notify handler cannot be installed dock.c remove trailing printk whitespace proper prototype for acpi_processor_tstate_has_changed() ACPI: handle invalid ACPI SLIT table PNPACPI: use _CRS IRQ descriptor length for _SRS pnpacpi: fix shareable IRQ encode/decode pnpacpi: fix IRQ flag decoding MAINTAINERS: update ACPI homepage ACPI 2.6.26-rc2: Add missing newline to DSDT/SSDT warning message ACPI: EC: Use msleep instead of udelay while waiting for event. thinkpad-acpi: fix LED handling on older ThinkPads thinkpad-acpi: fix initialization error paths ...
2008-06-11ACPI: handle invalid ACPI SLIT tableFenghua Yu
This is a SLIT sanity checking patch. It moves slit_valid() function to generic ACPI code and does sanity checking for both x86 and ia64. It sets up node_distance with LOCAL_DISTANCE and REMOTE_DISTANCE when hitting invalid SLIT table on ia64. It also cleans up unused variable localities in acpi_parse_slit() on x86. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-06-11[ARM] 5077/1: spi: fix list scan success verification in PXA ssp driverGuennadi Liakhovetski
The list search success check in arch/arm/mach-pxa/ssp.c is wrong: for example, it didn't recognise failure for me when I requested port 0. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-11Merge branch 'kvm-updates-2.6.26' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'kvm-updates-2.6.26' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: KVM: MMU: Fix is_empty_shadow_page() check KVM: MMU: Fix printk() format string KVM: IOAPIC: only set remote_irr if interrupt was injected KVM: MMU: reschedule during shadow teardown KVM: VMX: Clear CR4.VMXE in hardware_disable KVM: migrate PIT timer KVM: ppc: Report bad GFNs KVM: ppc: Use a read lock around MMU operations, and release it on error KVM: ppc: Remove unmatched kunmap() call KVM: ppc: add lwzx/stwz emulation KVM: ppc: Remove duplicate function KVM: s390: Fix race condition in kvm_s390_handle_wait KVM: s390: Send program check on access error KVM: s390: fix interrupt delivery KVM: s390: handle machine checks when guest is running KVM: s390: fix locking order problem in enable_sie KVM: s390: use yield instead of schedule to implement diag 0x44 KVM: x86 emulator: fix hypercall return value on AMD KVM: ia64: fix zero extending for mmio ld1/2/4 emulation in KVM
2008-06-10x86, pci-dma.c: don't always add __GFP_NORETRY to gfpMiquel van Smoorenburg
Currently arch/x86/kernel/pci-dma.c always adds __GFP_NORETRY to the allocation flags, because it wants to be reasonably sure not to deadlock when calling alloc_pages(). But really that should only be done in two cases: - when allocating memory in the lower 16 MB DMA zone. If there's no free memory there, waiting or OOM killing is of no use - when optimistically trying an allocation in the DMA32 zone when dma_mask < DMA_32BIT_MASK hoping that the allocation happens to fall within the limits of the dma_mask Also blindly adding __GFP_NORETRY to the the gfp variable might not be a good idea since we then also use it when calling dma_ops->alloc_coherent(). Clearing it might also not be a good idea, dma_alloc_coherent()'s caller might have set it on purpose. The gfp variable should not be clobbered. [ mingo@elte.hu: converted to delta patch ontop of previous version. ] Signed-off-by: Miquel van Smoorenburg <miquels@cistron.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-10[S390] Fix build failure in __cpu_up()Segher Boessenkool
The first argument to __ctl_store() should be the array to store stuff in, not just the first element of that array. With the current code in __cpu_up(), mainline GCC dies with an internal compiler error. I didn't diagnose that further, but just fixed the kernel bug. Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-06-10[S390] vmemmap: fix off-by-one bug.Heiko Carstens
If a memory range is supposed to be added to the 1:1 mapping and it ends just below the maximum supported physical address it won't succeed. This is because a test doesn't consider that the end address is 1 smaller than start + size. Fix the comparison. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-06-10[S390] sparsemem: use SPARSEMEM_STATIC if !64BIT.Heiko Carstens
In case of !64BIT kernel we end up with a zero sized mem_section array. This happens because NR_MEM_SECTIONS is smaller than SECTIONS_PER_ROOT but we have: #define NR_SECTION_ROOTS (NR_MEM_SECTIONS / SECTIONS_PER_ROOT) and struct mem_section *mem_section[NR_SECTION_ROOTS]; So fix this by selecting SPARSEMEM_STATIC which makes sure that SECTIONS_PER_ROOT is 1. Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-06-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6: Blackfin serial driver: fix up tty core set_ldisc API change breakage bug Blackfin arch: protect only the SPI bus controller with CONFIG_SPI_BFIN Blackfin arch: fixup warnings with the new cplb saved values Blackfin Serial Driver: Clean up BF54x macro in blackfin UART driver.
2008-06-09Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] ehea: Remove dependency on MEMORY_HOTPLUG [POWERPC] Make walk_memory_resource available with MEMORY_HOTPLUG=n [POWERPC] Use dev_set_name in pci_64.c [POWERPC] Fix incorrect enabling of VMX when building signal or user context [POWERPC] boot/Makefile CONFIG_ variable fixes
2008-06-09sh: Add -mno-fdpic to default flags.Paul Mundt
Presently the --fdpic specifier and the --isa matching clash when building with FDPIC toolchains. As we have no interest in building the kernel with --fdpic in the first place, always try to add in -mno-fdpic to the default flags. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-06-09sh: add resource of USB host for SH7723Yoshihiro Shimoda
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-06-09sh: Fix compile error SH7763 setup codeNobuhiro Iwamatsu
SH7763's setup code use old DECLARE_INTC_DESC. There was a compile error because of this. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-06-09sh: Add SH7723 SCIF supportYusuke.Goda
Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-06-09[POWERPC] Make walk_memory_resource available with MEMORY_HOTPLUG=nNathan Lynch
The ehea driver was recently changed[1] to use walk_memory_resource() to detect the system's memory layout. However, walk_memory_resource() is available only when memory hotplug is enabled. So CONFIG_EHEA was made to depend on MEMORY_HOTPLUG [2], but it is inappropriate for a network driver to have such a dependency. Make the declaration of walk_memory_resource() and its powerpc implementation (ehea is powerpc-specific) unconditionally available. [1] 48cfb14f8b89d4d5b3df6c16f08b258686fb12ad "ehea: Add DLPAR memory remove support" [2] fb7b6ca2b6b7c23b52be143bdd5f55a23b9780c8 "ehea: Add dependency to Kconfig" Signed-off-by: Nathan Lynch <ntl@pobox.com> Acked-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-09[POWERPC] Use dev_set_name in pci_64.cStephen Rothwell
During the next merge window, pci_name()'s return value will become const, so use the new dev_set_name() instead to avoid the warning (from linux-next): arch/powerpc/kernel/pci_64.c: In function 'of_create_pci_dev': arch/powerpc/kernel/pci_64.c:193: warning: passing argument 1 of 'sprintf' discards qualifiers from pointer target type Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-09[POWERPC] Fix incorrect enabling of VMX when building signal or user contextBenjamin Herrenschmidt
When building a signal or a ucontext, we can incorrectly set the MSR_VEC bit of the kernel pt_regs->msr before returning to userspace if the task -ever- used VMX. This can lead to funny result if that stack used it in the past, then "lost" it (ie. it wasn't enabled after a context switch for example) and then called get_context. It can end up with VMX enabled and the registers containing values from some other task. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-09[POWERPC] boot/Makefile CONFIG_ variable fixesAdrian Bunk
This corrects the names of two CONFIG_ variables. Note that the CONFIG_MPC86XADS fix uncovers another bug (with mpc866_ads_defconfig) that will require fixing: <-- snip --> ... arch/powerpc/boot/dtc -O dtb -o arch/powerpc/boot/mpc866ads.dtb -b 0 /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/powerpc/boot/dts/mpc866ads.dts DTC: dts->dtb on file "/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/powerpc/boot/dts/mpc866ads.dts" WRAP arch/powerpc/boot/cuImage.mpc866ads powerpc64-linux-ld: arch/powerpc/boot/cuboot-mpc866ads.o: No such file: No such file or directory make[2]: *** [arch/powerpc/boot/cuImage.mpc866ads] Error 1 <-- snip --> Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-07Blackfin arch: protect only the SPI bus controller with CONFIG_SPI_BFINMike Frysinger
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-06-06KVM: MMU: Fix is_empty_shadow_page() checkAvi Kivity
The check is only looking at one of two possible empty ptes. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-06-06KVM: MMU: Fix printk() format stringAvi Kivity
2008-06-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: x86/PCI: add workaround for bug in ASUS A7V600 BIOS (rev 1005) PCI/x86: fix up PCI stuff so that PCI_GOANY supports OLPC
2008-06-06KVM: MMU: reschedule during shadow teardownAvi Kivity
Shadows for large guests can take a long time to tear down, so reschedule occasionally to avoid softlockup warnings. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-06-06KVM: VMX: Clear CR4.VMXE in hardware_disableEli Collins
Clear CR4.VMXE in hardware_disable. There's no reason to leave it set after doing a VMXOFF. VMware Workstation 6.5 checks CR4.VMXE as a proxy for whether the CPU is in VMX mode, so leaving VMXE set means we'll refuse to power on. With this change the user can power on after unloading the kvm-intel module. I tested on kvm-67 and kvm-69. Signed-off-by: Eli Collins <ecollins@vmware.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
