commit 1de63d60cd5b0d33a812efa455d5933bf1564a51 upstream.
There was a serious problem in samsung-laptop that its platform driver is
designed to run under BIOS and running under EFI can cause the machine to
become bricked or can cause Machine Check Exceptions.
Discussion about this problem:
https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557
https://bugzilla.kernel.org/show_bug.cgi?id=47121
The patches to fix this problem:
efi: Make 'efi_enabled' a function to query EFI facilities
83e68189745ad931c2afd45d8ee3303929233e7f
samsung-laptop: Disable on EFI hardware
e0094244e41c4d0c7ad69920681972fc45d8ce34
Unfortunately this problem comes back again if users specify "noefi" option.
This parameter clears EFI_BOOT and that driver continues to run even if running
under EFI. Refer to the document, this parameter should clear
EFI_RUNTIME_SERVICES instead.
Documentation/kernel-parameters.txt:
noefi [X86] Disable EFI runtime services support.
Documentation/x86/x86_64/uefi.txt:
- If some or all EFI runtime services don't work, you can try following
kernel command line parameters to turn off some or all EFI runtime
services.
noefi turn off all EFI runtime services
Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com>
Link: http://lkml.kernel.org/r/511C2C04.2070108@jp.fujitsu.com
Cc: Matt Fleming <matt.fleming@intel.com>
commit 13d2b4d11d69a92574a55bfd985cfb0ca77aebdc upstream.
This fixes CVE-2013-0228 / XSA-42
Drew Jones while working on CVE-2013-0190 found that that unprivileged guest user
in 32bit PV guest can use to crash the > guest with the panic like this:
general protection fault: 0000 [#1] SMP
last sysfs file: /sys/devices/vbd-51712/block/xvda/dev
Modules linked in: sunrpc ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4
iptable_filter ip_tables ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6
xt_state nf_conntrack ip6table_filter ip6_tables ipv6 xen_netfront ext4
mbcache jbd2 xen_blkfront dm_mirror dm_region_hash dm_log dm_mod [last
unloaded: scsi_wait_scan]
Pid: 1250, comm: r Not tainted 2.6.32-356.el6.i686 #1
EIP: 0061:[<c0407462>] EFLAGS: 00010086 CPU: 0
EIP is at xen_iret+0x12/0x2b
EAX: eb8d0000 EBX: 00000001 ECX: 08049860 EDX: 00000010
ESI: 00000000 EDI: 003d0f00 EBP: b77f8388 ESP: eb8d1fe0
DS: 0000 ES: 007b FS: 0000 GS: 00e0 SS: 0069
Process r (pid: 1250, ti=eb8d0000 task=c2953550 task.ti=eb8d0000)
Stack:
00000000 0027f416 00000073 00000206 b77f8364 0000007b 00000000 00000000
Call Trace:
Code: c3 8b 44 24 18 81 4c 24 38 00 02 00 00 8d 64 24 30 e9 03 00 00 00
8d 76 00 f7 44 24 08 00 00 02 80 75 33 50 b8 00 e0 ff ff 21 e0 <8b> 40
10 8b 04 85 a0 f6 ab c0 8b 80 0c b0 b3 c0 f6 44 24 0d 02
EIP: [<c0407462>] xen_iret+0x12/0x2b SS:ESP 0069:eb8d1fe0
general protection fault: 0000 [#2]
---[ end trace ab0d29a492dcd330 ]---
Kernel panic - not syncing: Fatal exception
Pid: 1250, comm: r Tainted: G D ---------------
Call Trace:
[<c08476df>] ? panic+0x6e/0x122
[<c084b63c>] ? oops_end+0xbc/0xd0
[<c084b260>] ? do_general_protection+0x0/0x210
[<c084a9b7>] ? error_code+0x73/
Petr says: "
I've analysed the bug and I think that xen_iret() cannot cope with
mangled DS, in this case zeroed out (null selector/descriptor) by either
xen_failsafe_callback() or RESTORE_REGS because the corresponding LDT
entry was invalidated by the reproducer. "
Jan took a look at the preliminary patch and came up a fix that solves
this problem:
"This code gets called after all registers other than those handled by
IRET got already restored, hence a null selector in %ds or a non-null
one that got loaded from a code or read-only data descriptor would
cause a kernel mode fault (with the potential of crashing the kernel
as a whole, if panic_on_oops is set)."
The way to fix this is to realize that the we can only relay on the
registers that IRET restores. The two that are guaranteed are the
%cs and %ss as they are always fixed GDT selectors. Also they are
inaccessible from user mode - so they cannot be altered. This is
the approach taken in this patch.
Another alternative option suggested by Jan would be to relay on
the subtle realization that using the %ebp or %esp relative references uses
the %ss segment. In which case we could switch from using %eax to %ebp and
would not need the %ss over-rides. That would also require one extra
instruction to compensate for the one place where the register is used
as scaled index. However Andrew pointed out that is too subtle and if
further work was to be done in this code-path it could escape folks attention
and lead to accidents.
Reviewed-by: Petr Matousek <pmatouse@redhat.com>
Reported-by: Petr Matousek <pmatouse@redhat.com>
Reviewed-by: Andrew Cooper <andrew.cooper3@citrix.com>
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 0ee364eb316348ddf3e0dfcd986f5f13f528f821 upstream.
A user reported the following oops when a backup process reads
/proc/kcore:
BUG: unable to handle kernel paging request at ffffbb00ff33b000
IP: [<ffffffff8103157e>] kern_addr_valid+0xbe/0x110
Call Trace:
[<ffffffff811b8aaa>] read_kcore+0x17a/0x370
[<ffffffff811ad847>] proc_reg_read+0x77/0xc0
[<ffffffff81151687>] vfs_read+0xc7/0x130
[<ffffffff811517f3>] sys_read+0x53/0xa0
[<ffffffff81449692>] system_call_fastpath+0x16/0x1b
Investigation determined that the bug triggered when reading
system RAM at the 4G mark. On this system, that was the first
address using 1G pages for the virt->phys direct mapping so the
PUD is pointing to a physical address, not a PMD page.
The problem is that the page table walker in kern_addr_valid() is
not checking pud_large() and treats the physical address as if
it was a PMD. If it happens to look like pmd_none then it'll
silently fail, probably returning zeros instead of real data. If
the data happens to look like a present PMD though, it will be
walked resulting in the oops above.
This patch adds the necessary pud_large() check.
Unfortunately the problem was not readily reproducible and now
they are running the backup program without accessing
/proc/kcore so the patch has not been validated but I think it
makes sense.
Reviewed-by: Rik van Riel <riel@redhat.coM>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20130211145236.GX21389@suse.de
commit cb214ede7657db458fd0b2a25ea0b28dbf900ebc upstream.
When a HP ProLiant DL980 G7 Server boots a regular kernel,
there will be intermittent lost interrupts which could
result in a hang or (in extreme cases) data loss.
The reason is that this system only supports x2apic physical
mode, while the kernel boots with a logical-cluster default
setting.
This bug can be worked around by specifying the "x2apic_phys" or
"nox2apic" boot option, but we want to handle this system
without requiring manual workarounds.
The BIOS sets ACPI_FADT_APIC_PHYSICAL in FADT table.
As all apicids are smaller than 255, BIOS need to pass the
control to the OS with xapic mode, according to x2apic-spec,
chapter 2.9.
Current code handle x2apic when BIOS pass with xapic mode
enabled:
When user specifies x2apic_phys, or FADT indicates PHYSICAL:
1. During madt oem check, apic driver is set with xapic logical
or xapic phys driver at first.
2. enable_IR_x2apic() will enable x2apic_mode.
3. if user specifies x2apic_phys on the boot line, x2apic_phys_probe()
will install the correct x2apic phys driver and use x2apic phys mode.
Otherwise it will skip the driver will let x2apic_cluster_probe to
take over to install x2apic cluster driver (wrong one) even though FADT
indicates PHYSICAL, because x2apic_phys_probe does not check
FADT PHYSICAL.
Add checking x2apic_fadt_phys in x2apic_phys_probe() to fix the
problem.
Signed-off-by: Stoney Wang <song-bo.wang@hp.com>
[ updated the changelog and simplified the code ]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Link: http://lkml.kernel.org/r/1360263182-16226-1-git-send-email-yinghai@kernel.org
commit e575a86fdc50d013bf3ad3aa81d9100e8e6cc60d upstream.
Without this patch, it is trivial to determine kernel page
mappings by examining the error code reported to dmesg[1].
Instead, declare the entire kernel memory space as a violation
of a present page.
Additionally, since show_unhandled_signals is enabled by
default, switch branch hinting to the more realistic
expectation, and unobfuscate the setting of the PF_PROT bit to
improve readability.
[1] http://vulnfactory.org/blog/2013/02/06/a-linux-memory-trick/
Reported-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Suggested-by: Brad Spengler <spender@grsecurity.net>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Link: http://lkml.kernel.org/r/20130207174413.GA12485@www.outflux.net
commit d911e03d097bdc01363df5d81c43f69432eb785c upstream.
Since ed4f209 "s390/time: fix sched_clock() overflow" a new helper function
is used to avoid overflows when converting TOD format values to nanosecond
values.
The kvm interrupt code formerly however only worked by accident because of
an overflow. It tried to program a timer that would expire in more than ~29
years. Because of the old TOD-to-nanoseconds overflow bug the real expiry
value however was much smaller, but now it isn't anymore.
This however triggers yet another bug in the function that programs the clock
comparator s390_next_ktime(): if the absolute "expires" value is after 2042
this will result in an overflow and the programmed value is lower than the
current TOD value which immediatly triggers a clock comparator (= timer)
interrupt.
Since the timer isn't expired it will be programmed immediately again and so
on... the result is a dead system.
To fix this simply program the maximum possible value if an overflow is
detected.
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit 40a1ef95da85843696fc3ebe5fce39b0db32669f upstream.
For some reason they didn't get replaced so far by their
paravirt equivalents, resulting in code to be run with
interrupts disabled that doesn't expect so (causing, in the
observed case, a BUG_ON() to trigger) when syscall auditing is
enabled.
David (Cc-ed) came up with an identical fix, so likely this can
be taken to count as an ack from him.
Reported-by: Peter Moody <pmoody@google.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/5108E01902000078000BA9C5@nat28.tlf.novell.com
Tested-by: Peter Moody <pmoody@google.com>
commit eda8eebdd153c48a4e2a3a3ac3cd9e2e31f5c6b3 upstream.
The ASM version of hash computation function was truncating the upper bit.
Make the ASM version similar to hpt_hash function. Remove masking vsid bits.
Without this patch, we observed hang during bootup due to not satisfying page
fault request correctly. The fault handler used wrong hash values to update
the HPTE. Hence we kept looping with page fault.
hash_page(ea=000001003e260008, access=203, trap=300 ip=3fff91787134 dsisr 42000000
The computed value of hash 000000000f22f390
update: avpnv=4003e46054003e00, hash=000000000722f390, f=80000006, psize: 2 ...
BenH: The over-masking has been there for ever but only hurts with the
new 64T support introduced in 3.7
Reported-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Tested-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
commit e43b3cec711a61edf047adf6204d542f3a659ef8 upstream.
early_pci_allowed() and read_pci_config_16() are only available if
CONFIG_PCI is defined.
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com>
commit 712ba9e9afc4b3d3d6fa81565ca36fe518915c01 upstream.
efi.runtime_version is erroneously being set to the value of the
vendor's firmware revision instead of that of the implemented EFI
specification. We can't deduce which EFI functions are available based
on the revision of the vendor's firmware since the version scheme is
likely to be unique to each vendor.
What we really need to know is the revision of the implemented EFI
specification, which is available in the EFI System Table header.
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Cc: Seiji Aguchi <seiji.aguchi@hds.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
commit b8f2c21db390273c3eaf0e5308faeaeb1e233840 upstream.
Update efi_call_phys_prelog to install an identity mapping of all available
memory. This corrects a bug on very large systems with more then 512 GB in
which bios would not be able to access addresses above not in the mapping.
The result is a crash that looks much like this.
BUG: unable to handle kernel paging request at 000000effd870020
IP: [<0000000078bce331>] 0x78bce330
PGD 0
Oops: 0000 [#1] SMP
Modules linked in:
CPU 0
Pid: 0, comm: swapper/0 Tainted: G W 3.8.0-rc1-next-20121224-medusa_ntz+ #2 Intel Corp. Stoutland Platform
RIP: 0010:[<0000000078bce331>] [<0000000078bce331>] 0x78bce330
RSP: 0000:ffffffff81601d28 EFLAGS: 00010006
RAX: 0000000078b80e18 RBX: 0000000000000004 RCX: 0000000000000004
RDX: 0000000078bcf958 RSI: 0000000000002400 RDI: 8000000000000000
RBP: 0000000078bcf760 R08: 000000effd870000 R09: 0000000000000000
R10: 0000000000000000 R11: 00000000000000c3 R12: 0000000000000030
R13: 000000effd870000 R14: 0000000000000000 R15: ffff88effd870000
FS: 0000000000000000(0000) GS:ffff88effe400000(0000) knlGS:0000000000000000
CR2: 000000effd870020 CR3: 000000000160c000 CR4: 00000000000006b0
Process swapper/0 (pid: 0, threadinfo ffffffff81600000, task ffffffff81614400)
Stack:
0000000078b80d18 0000000000000004 0000000078bced7b ffff880078b81fff
0000000000000000 0000000000000082 0000000078bce3a8 0000000000002400
0000000060000202 0000000078b80da0 0000000078bce45d ffffffff8107cb5a
Call Trace:
[<ffffffff8107cb5a>] ? on_each_cpu+0x77/0x83
[<ffffffff8102f4eb>] ? change_page_attr_set_clr+0x32f/0x3ed
[<ffffffff81035946>] ? efi_call4+0x46/0x80
[<ffffffff816c5abb>] ? efi_enter_virtual_mode+0x1f5/0x305
[<ffffffff816aeb24>] ? start_kernel+0x34a/0x3d2
[<ffffffff816ae5ed>] ? repair_env_string+0x60/0x60
[<ffffffff816ae2be>] ? x86_64_start_reservations+0xba/0xc1
[<ffffffff816ae120>] ? early_idt_handlers+0x120/0x120
[<ffffffff816ae419>] ? x86_64_start_kernel+0x154/0x163
Code: Bad RIP value.
RIP [<0000000078bce331>] 0x78bce330
RSP <ffffffff81601d28>
---[ end trace ead828934fef5eab ]---
Signed-off-by: Nathan Zimmer <nzimmer@sgi.com>
Signed-off-by: Robin Holt <holt@sgi.com>
commit f791620fa7517e1045742c475a7f005db9a634b8 upstream.
If the bootloader calls the EFI handover entry point as a standard function
call, then it'll have a return address on the stack. We need to pop that
before calling efi_main(), or the arguments will all be out of position on
the stack.
Link: http://lkml.kernel.org/r/1358513837.2397.247.camel@shinybook.infradead.org
commit 70a479cbe80296d3113e65cc2f713a5101061daf upstream.
When booting under OVMF we have precisely one GOP device, and it
implements the ConOut protocol.
We break out of the loop when we look at it... and then promptly abort
because 'first_gop' never gets set. We should set first_gop *before*
breaking out of the loop. Yes, it doesn't really mean "first" any more,
but that doesn't matter. It's only a flag to indicate that a suitable
GOP was found.
In fact, we'd do just as well to initialise 'width' to zero in this
function, then just check *that* instead of first_gop. But I'll do the
minimal fix for now (and for stable@).
commit 83e68189745ad931c2afd45d8ee3303929233e7f upstream.
Originally 'efi_enabled' indicated whether a kernel was booted from
EFI firmware. Over time its semantics have changed, and it now
indicates whether or not we are booted on an EFI machine with
bit-native firmware, e.g. 64-bit kernel with 64-bit firmware.
The immediate motivation for this patch is the bug report at,
which details how running a platform driver on an EFI machine that is
designed to run under BIOS can cause the machine to become
bricked. Also, the following report,
details how running said driver can also cause Machine Check
Exceptions. Drivers need a new means of detecting whether they're
running on an EFI machine, as sadly the expression,
if (!efi_enabled)
hasn't been a sufficient condition for quite some time.
Users actually want to query 'efi_enabled' for different reasons -
what they really want access to is the list of available EFI
facilities.
For instance, the x86 reboot code needs to know whether it can invoke
the ResetSystem() function provided by the EFI runtime services, while
the ACPI OSL code wants to know whether the EFI config tables were
mapped successfully. There are also checks in some of the platform
driver code to simply see if they're running on an EFI machine (which
would make it a bad idea to do BIOS-y things).
This patch is a prereq for the samsung-laptop fix patch.
Cc: David Airlie <airlied@linux.ie>
Cc: Corentin Chary <corentincj@iksaif.net>
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Peter Jones <pjones@redhat.com>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Steve Langasek <steve.langasek@canonical.com>
Cc: Konrad Rzeszutek Wilk <konrad@kernel.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
commit c903f0456bc69176912dee6dd25c6a66ee1aed00 upstream.
At the moment the MSR driver only relies upon file system
checks. This means that anything as root with any capability set
can write to MSRs. Historically that wasn't very interesting but
on modern processors the MSRs are such that writing to them
provides several ways to execute arbitary code in kernel space.
Sample code and documentation on doing this is circulating and
MSR attacks are used on Windows 64bit rootkits already.
In the Linux case you still need to be able to open the device
file so the impact is fairly limited and reduces the security of
some capability and security model based systems down towards
that of a generic "root owns the box" setup.
Therefore they should require CAP_SYS_RAWIO to prevent an
elevation of capabilities. The impact of this is fairly minimal
on most setups because they don't have heavy use of
capabilities. Those using SELinux, SMACK or AppArmor rules might
want to consider if their rulesets on the MSR driver could be
tighter.
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit be3286507dab888d4aad9f91fd6ff5202b24cd5b upstream.
On s390, an architecture-specific implementation of the function
pmdp_set_wrprotect() is missing and the generic version is currently
being used. The generic version does not flush the tlb as it would be
needed on s390 when modifying an active pmd, which can lead to subtle
tlb errors on s390 when using transparent hugepages.
This patch adds an s390-specific implementation of pmdp_set_wrprotect()
including the missing tlb flush.
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
commit d01723479e6a6c70c83295f7847477a016d5e14a upstream.
__hyp_stub_install duplicates quite a bit of safe_svcmode_maskall
by forcing the CPU back to SVC. This is unnecessary, as
safe_svcmode_maskall is called just after.
Furthermore, the way we build SPSR_hyp is buggy as we fail to mask
the interrupts, leading to interesting behaviours on TC2 + UEFI.
The fix is to simply remove this code and rely on safe_svcmode_maskall
to do the right thing.
Reviewed-by: Dave Martin <dave.martin@linaro.org>
Reported-by: Harry Liebel <harry.liebel@arm.com>
commit 6e484be1ccca3ea495db45900fd42aac8d49d754 upstream.
Secondary CPUs should use the __hyp_stub_install_secondary entry
point, so boot mode inconsistencies can be detected.
Acked-by: Dave Martin <dave.martin@linaro.org>
Reported-by: Ian Molton <ian.molton@collabora.co.uk>
commit a4a12e008e292a81d312659529b71be2026ab355 upstream.
Non-T variants of ARMv4 do not support the bx instruction.
However, __hyp_stub_install is always called from the same
instruction set used to build the bulk of the kernel, so bx should
not be necessary.
This patch uses the traditional "mov pc" instead of bx.
Signed-off-by: Dave Martin <dave.martin@linaro.org>
[will: fixed up remaining bx instruction]
commit 6f16f4998f98e42e3f2dedf663cfb691ff0324af upstream.
We currently use a temporary 1MB section aligned to a 1MB boundary for
mapping the provided device tree until the final page table is created.
However, if the device tree happens to cross that 1MB boundary, the end
of it remains unmapped and the kernel crashes when it attempts to access
it. Given no restriction on the location of that DTB, it could end up
with only a few bytes mapped at the end of a section.
Solve this issue by mapping two consecutive sections.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Sascha Hauer <s.hauer@pengutronix.de>
Tested-by: Tomasz Figa <t.figa@samsung.com>
commit 568dca15aa2a0f4ddee255894ec393a159f13147 upstream.
Patrik Kluba reports that the preempt count becomes invalid due
to the preempt_enable() call being unbalanced with a
preempt_disable() call in the vfp assembly routines. This happens
because preempt_enable() and preempt_disable() update preempt
counts under PREEMPT_COUNT=y but the vfp assembly routines do so
under PREEMPT=y. In a configuration where PREEMPT=n and
DEBUG_ATOMIC_SLEEP=y, PREEMPT_COUNT=y and so the preempt_enable()
call in VFP_bounce() keeps subtracting from the preempt count
until it goes negative.
Fix this by always using PREEMPT_COUNT to decided when to update
preempt counts in the ARM assembly code.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Reported-by: Patrik Kluba <pkluba@dension.com>
Tested-by: Patrik Kluba <pkluba@dension.com>
commit b86dc0d8c12bbb9fed3f392c284bdc7114ce00c1 upstream.
We are using S3C_EINT(4) instead of S3C_EINT(5).
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
commit 36224d0fe0f34cdde66a381708853ebadeac799c upstream.
Make BGA as the default version as we are supposed to just have
to specify when we use the PQFP version.
Issue was existing since commit:
3e90772 (ARM: at91: fix at91rm9200 soc subtype handling).
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit 7662a9c60fee25d7234da4be6d8eab2b2ac88448 upstream.
Add the UART2 muxing data to the board file (this used to be,
erroneously, done in the bootloader).
Signed-off-by: Luciano Coelho <coelho@ti.com>
commit 15653371c67c3fbe359ae37b720639dd4c7b42c5 upstream.
Subhash Jadavani reported this partial backtrace:
Now consider this call stack from MMC block driver (this is on the ARMv7
based board):
[<c001b50c>] (v7_dma_inv_range+0x30/0x48) from [<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c)
[<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c) from [<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c)
[<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c) from [<c0017ff8>] (dma_map_sg+0x3c/0x114)
This is caused by incrementing the struct page pointer, and running off
the end of the sparsemem page array. Fix this by incrementing by pfn
instead, and convert the pfn to a struct page.
Suggested-by: James Bottomley <JBottomley@Parallels.com>
Tested-by: Subhash Jadavani <subhashj@codeaurora.org>
commit 572177d7c77db1981ba2563e01478126482c43bc upstream.
In preempt case current arch_local_irq_restore() from
preempt_schedule_irq() may enable hard interrupt but we really
should disable interrupts when we return from the interrupt,
and so that we don't get interrupted after loading SRR0/1.
Signed-off-by: Tiejun Chen <tiejun.chen@windriver.com>
commit d3286144c92ec876da9e30320afa875699b7e0f1 upstream.
Guests can trigger MMIO exits using dcbf. Since we don't emulate cache
incoherent MMIO, just do nothing and move on.
Reported-by: Ben Collins <ben.c@servergy.com>
Tested-by: Ben Collins <ben.c@servergy.com>
commit 9cf2b72b25f3f6a5a1a46a4f36037e66de52465c upstream.
The kernel's internal definition of ELF_NGREG uses struct pt_regs, which
means that we disagree with userspace on the size of coredumps since
glibc correctly uses the user-visible struct user_pt_regs.
This patch fixes our ELF_NGREG definition to use struct user_pt_regs
and introduces our own ELF_CORE_COPY_REGS to convert between the user
and kernel structure definitions.
commit 9899d11f654474d2d54ea52ceaa2a1f4db3abd68 upstream.
putreg() assumes that the tracee is not running and pt_regs_access() can
safely play with its stack. However a killed tracee can return from
ptrace_stop() to the low-level asm code and do RESTORE_REST, this means
that debugger can actually read/modify the kernel stack until the tracee
does SAVE_REST again.
set_task_blockstep() can race with SIGKILL too and in some sense this
race is even worse, the very fact the tracee can be woken up breaks the
logic.
As Linus suggested we can clear TASK_WAKEKILL around the arch_ptrace()
call, this ensures that nobody can ever wakeup the tracee while the
debugger looks at it. Not only this fixes the mentioned problems, we
can do some cleanups/simplifications in arch_ptrace() paths.
Probably ptrace_unfreeze_traced() needs more callers, for example it
makes sense to make the tracee killable for oom-killer before
access_process_vm().
While at it, add the comment into may_ptrace_stop() to explain why
ptrace_stop() still can't rely on SIGKILL and signal_pending_state().
Reported-by: Salman Qazi <sqazi@google.com>
Reported-by: Suleiman Souhlal <suleiman@google.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
commit a706d965dcfdff73bf2bad1c300f8119900714c7 upstream.
This patch is brought to you by the letter 'H'.
Commit 20b279 breaks compatiblity with older perf binaries when run with
precise modifier (:p or :pp) by requiring the exclude_guest attribute to be
set. Older binaries default exclude_guest to 0 (ie., wanting guest-based
samples) unless host only profiling is requested (:H modifier). The workaround
for older binaries is to add H to the modifier list (e.g., -e cycles:ppH -
toggles exclude_guest to 1). This was deemed unacceptable by Linus:
https://lkml.org/lkml/2012/12/12/570
Between family in town and the fresh snow in Breckenridge there is no time left
to be working on the proper fix for this over the holidays. In the New Year I
have more pressing problems to resolve -- like some memory leaks in perf which
are proving to be elusive -- although the aforementioned snow is probably why
they are proving to be elusive. Either way I do not have any spare time to work
on this and from the time I have managed to spend on it the solution is more
difficult than just moving to a new exclude_guest flag (does not work) or
flipping the logic to include_guest (which is not as trivial as one would
think).
So, two options: silently force exclude_guest on as suggested by Gleb which
means no impact to older perf binaries or revert the original patch which
caused the breakage.
This patch does the latter -- reverts the original patch that introduced the
regression. The problem can be revisited in the future as time allows.
Signed-off-by: David Ahern <dsahern@gmail.com>
Cc: Avi Kivity <avi@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Robert Richter <robert.richter@amd.com>
Link: http://lkml.kernel.org/r/1356749767-17322-1-git-send-email-dsahern@gmail.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit 9174adbee4a9a49d0139f5d71969852b36720809 upstream.
This fixes CVE-2013-0190 / XSA-40
There has been an error on the xen_failsafe_callback path for failed
iret, which causes the stack pointer to be wrong when entering the
iret_exc error path. This can result in the kernel crashing.
In the classic kernel case, the relevant code looked a little like:
popl %eax # Error code from hypervisor
jz 5f
addl $16,%esp
jmp iret_exc # Hypervisor said iret fault
5: addl $16,%esp
# Hypervisor said segment selector fault
Here, there are two identical addls on either option of a branch which
appears to have been optimised by hoisting it above the jz, and
converting it to an lea, which leaves the flags register unaffected.
In the PVOPS case, the code looks like:
popl_cfi %eax # Error from the hypervisor
lea 16(%esp),%esp # Add $16 before choosing fault path
CFI_ADJUST_CFA_OFFSET -16
jz 5f
addl $16,%esp # Incorrectly adjust %esp again
jmp iret_exc
It is possible unprivileged userspace applications to cause this
behaviour, for example by loading an LDT code selector, then changing
the code selector to be not-present. At this point, there is a race
condition where it is possible for the hypervisor to return back to
userspace from an interrupt, fault on its own iret, and inject a
failsafe_callback into the kernel.
This bug has been present since the introduction of Xen PVOPS support
in commit 5ead97c84 (xen: Core Xen implementation), in 2.6.23.
Signed-off-by: Frediano Ziglio <frediano.ziglio@citrix.com>
Signed-off-by: Andrew Cooper <andrew.cooper3@citrix.com>
commit a9acc5365dbda29f7be2884efb63771dc24bd815 upstream.
SNB graphics devices have a bug that prevent them from accessing certain
memory ranges, namely anything below 1M and in the pages listed in the
table. So reserve those at boot if set detect a SNB gfx device on the
CPU to avoid GPU hangs.
Stephane Marchesin had a similar patch to the page allocator awhile
back, but rather than reserving pages up front, it leaked them at
allocation time.
[ hpa: made a number of stylistic changes, marked arrays as static
const, and made less verbose; use "memblock=debug" for full
verbosity. ]
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: CAI Qian <caiqian@redhat.com>
commit ed4f20943cd4c7b55105c04daedf8d63ab6d499c upstream.
Converting a 64 Bit TOD format value to nanoseconds means that the value
must be divided by 4.096. In order to achieve that we multiply with 125
and divide by 512.
When used within sched_clock() this triggers an overflow after appr.
417 days. Resulting in a sched_clock() return value that is much smaller
than previously and therefore may cause all sort of weird things in
subsystems that rely on a monotonic sched_clock() behaviour.
To fix this implement a tod_to_ns() helper function which converts TOD
values without overflow and call this function from both places that
open coded the conversion: sched_clock() and kvm_s390_handle_wait().
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
commit 02522463c84748b3b8ad770f9424bcfa70a5b4c4 upstream.
Marking non-present ptes as read-only can corrupt file ptes, breaking
things like swap and file mappings.
This patch ensures that we only manipulate user pte bits when the pte
is marked present.
commit 4a71997a3279a339e7336ea5d0cd27282e2dea44 upstream.
Ensure that the aux table is properly initialized, even when optional features
are missing. Without this, the FDPIC loader did not work. This was meant to
be included in commit d5ab780305bb6d60a7b5a74f18cf84eb6ad153b1.
Signed-off-by: Thomas Schwinge <thomas@codesourcery.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
commit e43a028752fed049e4bd94ef895542f96d79fa74 upstream.
When remembering the direction of a DCR transaction, we should write
to the same variable that we interpret on later when doing vcpu_run
again.
Signed-off-by: CAI Qian <caiqian@redhat.com>
commit 9120963578320532dfb3a9a7947e8d05b39900b5 upstream.
This reverts commit ff401e52100dcdc85e572d1ad376d3307b3fe28e.
This breaks on MIPS64 R2 cores such as Broadcom's.
Signed-off-by: Jayachandran C <jchandra@broadcom.com>
commit 3b4bc7bccc7857274705b05cf81a0c72cfd0b0dd upstream.
This patch fixes some code that implements a work-around to a hardware bug in
the ac97 controller on the pxa27x. A bug in the controller's warm reset
functionality requires that the mfp used by the controller as the AC97_nRESET
line be temporarily reconfigured as a generic output gpio (AF0) and manually
held high for the duration of the warm reset cycle. This is what was done in
the original code, but it was broken long ago by commit fb1bf8cd
([ARM] pxa: introduce processor specific pxa27x_assert_ac97reset())
which changed the mfp to a GPIO input instead of a high output.
The fix requires the ac97 controller to obtain the gpio via gpio_request_one(),
with arguments that configure the gpio as an output initially driven high.
Tested on a palm treo 680 machine. Reportedly, this broken code only prevents a
warm reset on hardware that lacks a pull-up on the line, which appears to be the
case for me.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
commit ca2e16faa7378878c1522a7c1b6c38211de3331d upstream.
The i2c handling in tfp410 driver, which handles converting parallel RGB
to DVI, was changed in 958f2717b84e88bf833d996997fda8f73276f2af
(OMAPDSS: TFP410: pdata rewrite). The patch changed what value the
driver considers as invalid/undefined. Before the patch, 0 was the
invalid value, but as 0 is a valid bus number, the patch changed this to
-1.
However, the fact was missed that many board files do not define the bus
number at all, thus it's left to 0. This causes the driver to fail to
get the i2c bus, exiting from the driver's probe with an error, meaning
that the DVI output does not work for those boards.
This patch fixes the issue by changing the i2c_bus number field in the
driver's platform data from u16 to int, and setting the bus number to -1
in the board files for the boards that did not define the bus. The
exception is devkit8000, for which the bus is set to 1, which is the
correct bus for that board.
The bug exists in v3.5+ kernels.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Reported-by: Thomas Weber <thomas@tomweber.eu>
Cc: Thomas Weber <thomas@tomweber.eu>
commit 8add1ecb81f541ef2fcb0b85a5470ad9ecfb4a84 upstream.
When poweroff machine, kernel_power_off() call disable_nonboot_cpus().
And if we have HOTPLUG_CPU configured, disable_nonboot_cpus() is not an
empty function but attempt to actually disable the nonboot cpus. Since
system state is SYSTEM_POWER_OFF, play_dead() won't be called and thus
disable_nonboot_cpus() hangs. Therefore, we make this patch to avoid
poweroff failure.
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Signed-off-by: Hongliang Tao <taohl@lemote.com>
Signed-off-by: Hua Yan <yanh@lemote.com>
Cc: Yong Zhang <yong.zhang@windriver.com>
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/4211/
commit e400e72f250d2567e89c9bafb47ab91e8d9a15a2 upstream.
We were only allocating half the bytes we need, which was made more
obvious by a recent fix to the memset in clear_tlb1_bitmap().
commit e6449c9b2d90c1bd9a5985bf05ddebfd1631cd6b upstream.
The missing NULL terminator can cause a panic on
PPC405 boards during boot:
Linux/PowerPC load: console=ttyS0,115200 root=/dev/mtdblock1 rootfstype=squashfs,jffs2 noinitrd init=/etc/preinit
Finalizing device tree... flat tree at 0x6a5160
bootconsole [udbg0] enabled
Page fault in user mode with in_atomic() = 1 mm = (null)
NIP = c0275f50 MSR = fffffffe
Oops: Weird page fault, sig: 11 [#1]
PowerPC 40x Platform
Modules linked in:
NIP: c0275f50 LR: c0275f60 CTR: c0280000
REGS: c0275eb0 TRAP: 636f7265 Not tainted (3.7.1)
MSR: fffffffe <VEC,VSX,EE,PR,FP,ME,SE,BE,IR,DR,PMM,RI> CR: c06a6190 XER: 00000001
TASK = c02662a8[0] 'swapper' THREAD: c0274000
GPR00: c0275ec0 c000c658 c027c4bf 00000000 c0275ee0 c000a0ec c020a1a8 c020a1f0
GPR08: c020f631 c020f404 c025f078 c025f080 c0275f10
Call Trace:
---[ end trace 31fd0ba7d8756001 ]---
Kernel panic - not syncing: Attempted to kill the idle task!
The panic happens since commit 9597abe00c1bab2aedce6b49866bf6d1e81c9eed
(sections: fix section conflicts in arch/powerpc), however the root
cause of this is that the NULL terminator were not added in commit
a4f740cf33f7f6c164bbde3c0cdbcc77b0c4997c (of/flattree: Add of_flat_dt_match()
helper function).
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
commit ce73ec6db47af84d1466402781ae0872a9e7873c upstream.
The locking in update_vsyscall_tz() is not only unnecessary because the vdso
code copies the data unproteced in __kernel_gettimeofday() but also
introduces a hard to reproduce race condition between update_vsyscall()
and update_vsyscall_tz(), which causes user space process to loop
forever in vdso code.
The following patch removes the locking from update_vsyscall_tz().
Locking is not only unnecessary because the vdso code copies the data
unprotected in __kernel_gettimeofday() but also erroneous because updating
the tb_update_count is not atomic and introduces a hard to reproduce race
condition between update_vsyscall() and update_vsyscall_tz(), which further
causes user space process to loop forever in vdso code.
The below scenario describes the race condition,
x==0 Boot CPU other CPU
proc_P: x==0
timer interrupt
update_vsyscall
x==1 x++;sync settimeofday
update_vsyscall_tz
x==2 x++;sync
x==3 sync;x++
sync;x++
proc_P: x==3 (loops until x becomes even)
Because the ++ operator would be implemented as three instructions and not
atomic on powerpc.
A similar change was made for x86 in commit 6c260d58634
("x86: vdso: Remove bogus locking in update_vsyscall_tz")
Signed-off-by: Shan Hai <shan.hai@windriver.com>
commit 11ee7e99f35ecb15f59b21da6a82d96d2cd3fcc8 upstream.
If we build a kernel with CONFIG_RELOCATABLE=y CONFIG_CRASH_DUMP=n,
the kernel fails when we run at a non zero offset. It turns out
we were incorrectly wrapping some of the relocatable kernel code
with CONFIG_CRASH_DUMP.
commit ce6a04ac1b759beafc88dbc443ae5da867579eeb upstream.
I was chasing down a bug of random validity intercepts on s390.
(guest prefix page not mapped in the host virtual aspace). Turns out
that the problem was a wrong address space control element. The
cause was quite complex:
During paging activity a DAT protection during SIE caused a program
interrupt. Normally, the sie retry loop tries to catch all
interrupts during and shortly before sie to rerun the setup. The
problem is now that protection causes a suppressing program interrupt,
causing the PSW to point to the instruction AFTER SIE in case of DAT
protection. This confused the logic of the retry loop to not trigger,
instead we jumped directly back to SIE after return from
the program interrupt. (the protection fault handler itself did
a rewind of the psw). This usually works quite well, but:
If now the protection fault handler has to wait, another program
might be scheduled in. Later on the sie process will be schedules
in again. In that case the content of CR1 (primary address space)
will be wrong because switch_to will put the user space ASCE into CR1
and not the guest ASCE.
In addition the program parameter is also wrong for every protection
fault of a guest, since we dont issue the SPP instruction.
So lets also check for PSW == instruction after SIE in the program
check handler. Instead of expensively checking all program
interruption codes that might be suppressing we assume that a program
interrupt pointing after SIE was always a program interrupt in SIE.
(Otherwise we have a kernel bug anyway).
We also have to compensate the rewinding, since the C-level handlers
will do that. Therefore we need to add a nop with the same length
as SIE before the sie_loop.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
CC: Heiko Carstens <heiko.carstens@de.ibm.com>
commit 87cac8f879a5ecd7109dbe688087e8810b3364eb upstream.
Newer kernels (linux-next with the transparent huge page patches)
use rrbm if the feature is announced via feature bit 66.
RRBM will cause intercepts, so KVM does not handle it right now,
causing an illegal instruction in the guest.
The easy solution is to disable the feature bit for the guest.
This fixes bugs like:
Kernel BUG at 0000000000124c2a [verbose debug info unavailable]
illegal operation: 0001 [#1] SMP
Modules linked in: virtio_balloon virtio_net ipv6 autofs4
CPU: 0 Not tainted 3.5.4 #1
Process fmempig (pid: 659, task: 000000007b712fd0, ksp: 000000007bed3670)
Krnl PSW : 0704d00180000000 0000000000124c2a (pmdp_clear_flush_young+0x5e/0x80)
R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:3 CC:1 PM:0 EA:3
00000000003cc000 0000000000000004 0000000000000000 0000000079800000
0000000000040000 0000000000000000 000000007bed3918 000000007cf40000
0000000000000001 000003fff7f00000 000003d281a94000 000000007bed383c
000000007bed3918 00000000005ecbf8 00000000002314a6 000000007bed36e0
Krnl Code:>0000000000124c2a: b9810025 ogr %r2,%r5
0000000000124c2e: 41343000 la %r3,0(%r4,%r3)
0000000000124c32: a716fffa brct %r1,124c26
0000000000124c36: b9010022 lngr %r2,%r2
0000000000124c3a: e3d0f0800004 lg %r13,128(%r15)
0000000000124c40: eb22003f000c srlg %r2,%r2,63
[ 2150.713198] Call Trace:
[ 2150.713223] ([<00000000002312c4>] page_referenced_one+0x6c/0x27c)
[ 2150.713749] [<0000000000233812>] page_referenced+0x32a/0x410
CC: Alex Graf <agraf@suse.de>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit c24bf9b4cc6a0f330ea355d73bfdf1dae7e63a05 upstream.
The inb/outb macros for CRIS are broken from a number of points of view,
missing () around parameters and they have an unprotected if statement
in them. This was breaking the compile of IPMI on CRIS and thus I was
being annoyed by build regressions, so I fixed them.
Plus I don't think they would have worked at all, since the data values
were missing "&" and the outsl had a "3" instead of a "4" for the size.
From what I can tell, this stuff is not used at all, so this can't be
any more broken than it was before, anyway.
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Mikael Starvik <starvik@axis.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
commit 1278998f8ff6d66044ed00b581bbf14aacaba215 upstream.
Commit 284f5f9 was intended to disable the "only_one_child()" optimization
on Stratus ftServer systems, but its DMI check is wrong. It looks for
DMI_SYS_VENDOR that contains "ftServer", when it should look for
DMI_SYS_VENDOR containing "Stratus" and DMI_PRODUCT_NAME containing
"ftServer".
Tested on Stratus ftServer 6400.
Reported-by: Fadeeva Marina <astarta@rat.ru>
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=51331
Signed-off-by: Myron Stowe <myron.stowe@redhat.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit d056a699dd3d9366dd3b4d9996e7848209199cda upstream.
flush_cache_louis flushes the D-side caches to the point of unification
inner-shareable. On uniprocessor CPUs, this is defined as zero and
therefore no flushing will take place. Rather than invent a new interface
for UP systems, instead use our SMP_ON_UP patching code to read the
LoUU from the CLIDR instead.
Cc: Lorenzo Pieralisi <Lorenzo.Pieralisi@arm.com>
Tested-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
commit e6ee4b2b57a8e0d8e551031173de080b338d3969 upstream.
Commit 34ae6c96a6a7 ("ARM: 7298/1: realview: fix mapping of MPCore
private memory region") accidentally broke the definition for the base
address of the private peripheral region on revision B Realview-EB
boards.
This patch uses the correct address for REALVIEW_EB11MP_PRIV_MEM_BASE.
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Tested-by: Florian Fainelli <florian@openwrt.org>
