Makes UML compile on any possible processor choice. The two problems were:
*) x86 code, when 386 is selected, checks at runtime boot_cpuflags, which we
not have.
*) 3Dnow support for memcpy() et al. does not compile currently and fixing t
is not trivial, so simply disable it; with this change, if one selects MK
UML compiles (while it did not).
Merged upstream.
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
This updated patch adds the Intel ICH9 LPC and SMBus Controller DID's.
Signed-off-by: Jason Gaston <jason.d.gaston@intel.com>
Based on patches from Linus' tree.
SYSENTER can cause a NT to be set which might cause crashes on the IRET
in the next task.
Following similar i386 patch from Linus.
Backport to 2.6.16 by Chuck Ebbert <76306.1226@compuserve.com>
[Changed 'set_debugreg' to the older 'set_debug' in setup64.c
and added raw_local_save_flags() from 2.6.19 to system.h]
Signed-off-by: Andi Kleen <ak@suse.de>
(And reset it on new thread creation)
It turns out that eflags is important to save and restore not just
because of iopl, but due to the magic bits like the NT bit, which we
don't want leaking between different threads.
Backported to 2.6.16 by Chuck Ebbert <76306.1226@compuserve.com>
[Backport consisted of removing the CFI annotations.]
On the Core2 cpus, the rdtsc instruction is not serializing (as defined
in the architecture reference since rdtsc exists) and due to the deep
speculation of these cores, it's possible that you can observe time go
backwards between cores due to this speculation. Since the kernel
already deals with this with the SYNC_RDTSC flag, the solution is
simple, only assume that the instruction is serializing on family 15...
The price one pays for this is a slightly slower gettimeofday (by a
dozen or two cycles), but that increase is quite small to pay for a
really-going-forward tsc counter.
Backport by Chris Wright.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
When called to do a transfer that has a start offset within the cache
line which is uneven between source and destination and a length which
terminates the source of the copy exactly on a cache line, one extra
line gets copied into a temporary buffer. This is normally not an issue
since the buffer is a kernel buffer and only the requested information
gets copied into the user buffer.
The problem arises when the source ends at the very last physical page
of memory. That last cache line does not exist and results in the SHUB
chip raising an MCA.
Signed-off-by: Robin Holt <holt@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
There appears to be a typo in the EV56 config option. NORITAKE and PRIMO are
be able to set a variation of either.
Signed-off-by: Daniel Drake <dsd@gentoo.org>
Convert various spin_lock_irqsave() callers to correctly use `unsigned long'
The alignment exception used to only check the exception table for
-EFAULT, not for other errors. That opens an oops window if we can
coerce the kernel into getting an alignment exception for other reasons
in what would normally be a user-protected accessor, which can be done
via some of the futex ops. This fixes it by always checking the
exception tables.
fix interrput routing for via 586 bridges. pirq can be 5 which needs to be
mapped to INTD. but currently the access functions can handle only pirq 1-4.
this is similar to the other via chipsets where pirq 4 and 5 are both mapped
to INTD. fixes bugzilla #7490
Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch>
This patch prevents cross-region mappings
on IA64 and SPARC which could lead to system crash.
Adrian Bunk:
Adapted to 2.6.16.
Signed-Off-By: Kirill Korotaev <dev@openvz.org>
As pointed out by Herbert Xu <herbert@gondor.apana.org.au>, our
memcpy implementation didn't return the destination pointer as its
return value, and there is code in the kernel that expects that.
This fixes it.
Fix powernow-k8 doesn't load bug.
Reference:
https://launchpad.net/distros/ubuntu/+source/linux-source-2.6.15/+bug/35145
Signed-off-by: Ben Collins <bcollins@ubuntu.com>
Signed-off-by: Dave Jones <davej@redhat.com>
Even though powernow-k7 doesn't work in SMP environments,
it can work on an SMP configured kernel if there's only
one CPU present, however recalibrate_cpu_khz was returning
-EINVAL on such kernels, so we failed to init the cpufreq driver.
http://bugzilla.kernel.org/show_bug.cgi?id=5653
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
The previous patch to correct the copy_from_user padding is quite
broken. The execute instruction needs to be done via the register %r4,
not via %r2 and 31 bit doesn't know the instructions lgr and ahji.
A user space program can read uninitialised kernel memory
by appending to a file from a bad address and then reading
the result back. The cause is the copy_from_user function
that does not clear the remaining bytes of the kernel
buffer after it got a fault on the user space address.
Fix a bug in sys_perfmonctl() whereby it was not correctly
decrementing the file descriptor reference count.
Signed-off-by: Stephane Eranian <eranian@hpl.hp.com>
There is an ancient and totally incorrect sanity check being
done on the ramdisk location. The check assumes that the
kernel is always loaded to physical address zero, which is
wrong. It was trying to validate the ramdisk value by saying that
if it fell within the kernel image address range it must be wrong.
Anyways, kill this because it actually creates problems. The
'ramdisk_image' should always be adjusted down by KERNBASE.
SILO can easily put the ramdisk in a location which causes
this test to trigger, breaking things.
[ Based almost entirely upon a patch from Ben Collins. ]
Unfortunately, sparc64 doesn't have an easy way to do a "64 X 64 -->
128" bit multiply like PowerPC and IA64 do. We were doing a
"64 X 64 --> 64" bit multiple which causes overflow very quickly with
a 30-bit quotient shift.
So use a quotientshift count of 10 instead of 30, just like x86 and
ARM do.
This also fixes the wrapping of printk timestamp values every ~17
seconds.
Jack Steiner identified a problem where XPC can cause a silent
data corruption. On module load, the placement may cause the
xpc_remote_copy_buffer to span two physical pages. DMA transfers are
done to the start virtual address translated to physical.
This patch changes the buffer from a statically allocated buffer to a
kmalloc'd buffer. Dean Nelson reviewed this before posting. I have
tested it in the configuration that was showing the memory corruption
and verified it works. I also added a BUG_ON statement to help catch
this if a similar situation is encountered.
Signed-off-by: Dean Nelson <dcn@sgi.com>
Signed-off-by: Jack Steiner <steiner@sgi.com>
Clear HID0[en_attn] at CPU init time on PPC970. Closes CVE-2006-4093.
Fix the calculation of the end address when flushing iotlb entries to
ram. This bug has been a cause of esp dma errors, and it affects
HyperSPARC systems much worse than SuperSPARC systems.
Signed-off-by: Bob Breuer <breuerr@mc.net>
Acked-by: William Lee Irwin III <wli@holomorphy.com>
The i386 defconfig wasn't updated for ages.
Instead of running "make oldconfig" on the old defconfig and trying to
give reasonable answers at all new options, this patch replaces it with
the one I'm using in 2.6.16-rc1.
This way, it's a .config that is confirmed to work on at least one
computer in the world. ;-)
Memory hotplug code of i386 adds memory to only highmem. So, if
CONFIG_HIGHMEM is not set, CONFIG_MEMORY_HOTPLUG shouldn't be set.
Otherwise, it causes compile error.
In addition, many architecture can't use memory hotplug feature yet. So, I
introduce CONFIG_ARCH_ENABLE_MEMORY_HOTPLUG.
Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Both csum_partial() and the csum_partial_copy*() family of routines
forget to do a final fold on the computed checksum value on sparc64.
So do the standard Sparc "add + set condition codes, add carry"
sequence, then make sure the high 32-bits of the return value are
clear.
Based upon some excellent detective work and debugging done by
Richard Braun and Samuel Thibault.
Using asm-generic/dma-mapping.h does not work because pushing
the call down to pci_alloc_coherent() causes the gfp_t argument
of dma_alloc_coherent() to be ignored.
Fix this by implementing things directly, and adding a gfp_t
argument we can use in the internal call down to the PCI DMA
implementation of pci_alloc_coherent().
This fixes massive memory corruption when using the sound driver
layer, which passes things like __GFP_COMP down into these
routines and (correctly) expects that to work.
This is a disk eater when sound is used, so it's pretty critical.
This fixes a bug found by Dave Jones that means that it is possible
for userspace to provoke a machine check on 32-bit kernels. This
also fixes a couple of other places where I found similar problems
by inspection.
This fixes a regression from the earlier DOS fix for non canonical
IRET addresses. It broke UML.
int_ret_from_syscall already does syscall exit tracing, so
no need to do it again in the caller.
This caused problems for UML and some other special programs doing
syscall interception.
o Start booting into the capture kernel after an Oops if system is in a
unrecoverable state. System will boot into the capture kernel, if one is
pre-loaded by the user, and capture the kernel core dump.
o One of the following conditions should be true to trigger the booting of
capture kernel.
- panic_on_oops is set.
- pid of current thread is 0
- pid of current thread is 1
- Oops happened inside interrupt context.
Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com>
For a very long time, echoing 'standby' or 'mem' into /sys/power/state has
killed the machine on powerpc. This patch fixes that.
This patch adds the .valid callback to pm_ops on PowerMac so that only the
suspend to disk state can be entered. Note that just returning 0 would
suffice since the upper layers don't pass PM_SUSPEND_DISK down, but we
handle it there regardless just in case that changes.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Cc: <stable@kernel.org>
In the branch emulation for floating-point exceptions, __compute_return_epc
must determine for bc1f et al which condition code bit to test. This is
based on bits <4:2> of the rt field. The switch statement to distinguish
bc1f et al needs to use only the two low bits of rt, but the old code tests
on the whole rt field. This patch masks off the proper bits.
Signed-off-by: Win Treese <treese@acm.org>
Fix the cache index value in tx49_blast_icache32_page_indexed().
This is damage by de62893bc0725f8b5f0445250577cd7a10b2d8f8 commit.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
As it turned out after recent SCSI changes, strncpy() was broken -
it mixed up the return values from __stxncpy() in registers $24 and $27.
Thanks to Mathieu Chouquet-Stringer for tracking down the problem
and providing an excellent test case.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
We do this by removing a micro-optimization that tries to avoid grabbing
the iommu_bitmap_lock spinlock and using a bus-locked operation.
This still races with other simultaneous alloc_iommu or free_iommu(size
> 1) which both use bus-unlocked operations.
The end result of this race is eventually ending
up with an iommu_gart_bitmap that has bits errornously set all over,
making large contiguous iommu space allocations fail with 'PCI-DMA:
Out of IOMMU space'.
Signed-off-by: Mike Waychison <mikew@google.com>
pages
This quietens warnings and actually fixes a bug. The unwind tables would
come out wrong without -32, causing pthread cancellation during them
to crash in the gcc runtime.
The problem seems to only happen with newer binutils
(it doesn't happen with 2.16.91.0.2 but happens wit 2.16.91.0.5)
Thanks to Brian Baker @ HP for test case and initial analysis.
Cc: brian.b@hp.com
hi,
The motivation behind the patch below was to address messages in
/var/log/messages such as:
Jan 31 10:54:15 mets kernel: audit(:0): major=252 name_count=0: freeing
multiple contexts (1)
Jan 31 10:54:15 mets kernel: audit(:0): major=113 name_count=0: freeing
multiple contexts (2)
I can reproduce by running 'get-edid' from:
http://john.fremlin.de/programs/linux/read-edid/.
These messages come about in the log b/c the vm86 calls do not exit via
the normal system call exit paths and thus do not call
'audit_syscall_exit'. The next system call will then free the context for
itself and for the vm86 context, thus generating the above messages. This
patch addresses the issue by simply adding a call to 'audit_syscall_exit'
from the vm86 code.
Besides fixing the above error messages the patch also now allows vm86
system calls to become auditable. This is useful since strace does not
appear to properly record the return values from sys_vm86.
I think this patch is also a step in the right direction in terms of
cleaning up some core auditing code. If we can correct any other paths
that do not properly call the audit exit and entries points, then we can
also eliminate the notion of context chaining.
I've tested this patch by verifying that the log messages no longer
appear, and that the audit records for sys_vm86 appear to be correct.
Also, 'read_edid' produces itentical output.
thanks,
-Jason
Signed-off-by: Jason Baron <jbaron@redhat.com>
Fix the "apm: set display: Interface not engaged" error on Armada laptops
again.
Jordan said:
I think this is fine. It seems to me that this may be the fault of one or
both of the APM solutions handling this situation in a non-standard way, but
since APM is used very little on the Geode, and I have direct access to our
BIOS folks, if this problem comes up with a customer again, we'll solve it
from the firmware.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: "Jordan Crouse" <jordan.crouse@amd.com>
Cc: Zachary Amsden <zach@vmware.com>
AMD K7/K8 CPUs only save/restore the FOP/FIP/FDP x87 registers in FXSAVE
when an exception is pending. This means the value leak through context
switches and allow processes to observe some x87 instruction state of
other processes.
This was actually documented by AMD, but nobody recognized it as being
different from Intel before.
The fix first adds an optimization: instead of unconditionally calling
FNCLEX after each FXSAVE test if ES is pending and skip it when not
needed. Then do a x87 load from a kernel variable to clear FOP/FIP/FDP.
This means other processes always will only see a constant value defined
by the kernel in their FP state.
I took some pain to make sure to chose a variable that's already in L1
during context switch to make the overhead of this low.
Also alternative() is used to patch away the new code on CPUs who don't
need it.
Patch for both i386/x86-64.
The problem was discovered originally by Jan Beulich. Richard Brunner
provided the basic code for the workarounds, with contribution from Jan.
This is CVE-2006-1056
Cc: richard.brunner@amd.com
Cc: jbeulich@novell.com
I've encountered two problems with 2.6.16 and newer kernels on my API CS20
(dual 833MHz Alpha 21264b processors). The first is the kernel OOPSing
because of a NULL pointer dereference while trying to populate SysFS with the
CPU information. The other is that only one processor was being brought up.
I've included a small Alpha-specific patch that fixes both problems.
The first problem was caused by the CPUs never being properly registered using
register_cpu(), the way it's done on other architectures.
The second problem has to do with the removal of hwrpb_cpu_present_mask in
arch/alpha/kernel/smp.c. In setup_smp() in the 2.6.15 kernel sources,
hwrpb_cpu_present_mask has a bit set for each processor that is probed, and
afterwards cpu_present_mask is set to the cpumask for the boot CPU. In the
same function of the same file in the 2.6.16 sources, instead of
hwrpb_cpu_present_mask being set, cpu_possible_map is updated for each probed
CPU. cpu_present_mask is still set to the cpumask of the boot CPU afterwards.
The problem lies in include/asm-alpha/smp.h, where cpu_possible_map is
#define'd to be cpu_present_mask.
Cleanups from: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
- cpu_present_mask and cpu_possible_map are essentially the same thing
on alpha, as it doesn't support CPU hotplug;
- allocate "struct cpu" only for present CPUs, like sparc64 does.
Static array of "struct cpu" is just a waste of memory.
Signed-off-by: Brian Uhrain <buhrain@rosettastone.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
SMP kernel
This patch fixes a boot problem of the m32r SMP kernel 2.6.16-rc1-mm3 or
later.
In this patch, cpu_possible_map is statically initialized, and cpu_present_map
is also copied from cpu_possible_map in smp_prepare_cpus(), because the m32r
architecture has not supported CPU hotplug yet.
Signed-off-by: Hayato Fujiwara <fujiwara.hayato@renesas.com>
Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
Update {get,put}_user macros for m32r kernel.
- Modify get_user to use __get_user_asm macro, instead of __get_user_x macro.
- Remove arch/m32r/lib/{get,put}user.S.
- Some cosmetic updates.
I would like to thank NIIBE Yutaka for his reporting about the m32r kernel's
security problem in {get,put}_user macros.
There were no address checking for user space access in {get,put}_user macros.
Cc: NIIBE Yutaka <gniibe@fsij.org>
*) When setting a sighandler using sigaction() call, if the flag
SA_ONSTACK is set and no alternate stack is provided via sigaltstack(),
the kernel still try to install the alternate stack. This behavior is
the opposite of the one which is documented in Single Unix
Specifications V3.
*) Also when setting an alternate stack using sigaltstack() with the
flag SS_DISABLE, the kernel try to install the alternate stack on
signal delivery.
These two use cases makes the process crash at signal delivery.
This fixes it.
Signed-off-by: Laurent Meyer <meyerlau@fr.ibm.com>
Since the powerpc 64k pages patch went in, systems that have SLBs
(like Power4 iSeries) needed to have slb_initialize called to set up
some variables for the SLB miss handler. This was not being called
on the boot processor on iSeries, so on single cpu iSeries machines,
we would get apparent memory curruption as soon as we entered user mode.
This patch fixes that by calling slb_initialize on the boot cpu if the
processor has an SLB.
(CVE-2006-0744)
Intel EM64T CPUs handle uncanonical return addresses differently from
AMD CPUs.
The exception is reported in the SYSRET, not the next instruction.
Thgis leads to the kernel exception handler running on the user stack
with the wrong GS because the kernel didn't expect exceptions on this
instruction.
This version of the patch has the teething problems that plagued an
earlier version fixed.
This is CVE-2006-0744
Thanks to Ernie Petrides and Asit B. Mallick for analysis and initial
patches.
Just call IRET always, no need for any special cases.
Needed for the next bug fix.
[CPUFREQ] Fix the p4-clockmod N60 errata workaround.
Fix the code to disable freqs less than 2GHz in N60 errata.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
[CPUFREQ] Mark longhaul driver as broken.
This seems to work for a short period of time, but when
used in conjunction with a userspace governor that changes
the frequency regularly, it's only a matter of time before
everything just locks up.
We used to assume that a DMA mapping request with a NULL dev was for
ISA DMA. This assumption was broken at some point. Now we explicitly
pass the detected ISA PCI device in the floppy setup.
