path: root/arch
2007-01-05[PATCH] i386: modpost smpboot code warning fixVivek Goyal
o Currently synchronize_tsc_ap() is of type __init. It is called by smp_callin() which is of type __cpuinit. So synchronize_tsc_ap() should be of type __cpuinit. o Modpost generates warnings for i386 if CONFIG_RELOCATABLE=y and CONFIG_HOTPLUG_CPU=y WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between 'start_secondary' (at offset 0xc01164dc) and 'initialize_secondary' WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between 'start_secondary' (at offset 0xc01164e8) and 'initialize_secondary' o tsc is of type __initdata. It should be of type __cpuinitdata. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: Andi Kleen <ak@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-05[PATCH] i386: fix another modpost warningVivek Goyal
o MODPOST generates warning for i386 if kernel is compiled with CONFIG_RELOCATABLE=y WARNING: vmlinux - Section mismatch: reference to .init.data: from .data between 'this_cpu' (at offset 0xc05194d0) and 'cpuinfo_op' o this_cpu pointer should be of type __cpuinitdata. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: Andi Kleen <ak@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-05[PATCH] i386: fix modpost warning in SMP trampoline codeVivek Goyal
o MODPOST generates warning for i386 if kernel is compiled with CONFIG_RELOCATABLE=y WARNING: vmlinux - Section mismatch: reference to .init.text:startup_32_smp from .data between 'trampoline_data' (at offset 0xc0519cf8) and 'boot_gdt' o trampoline code/data can go into init section is CPU hotplug is not enabled. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: Andi Kleen <ak@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-05[PATCH] i386: Restore CONFIG_PHYSICAL_START optionVivek Goyal
o Relocatable bzImage support had got rid of CONFIG_PHYSICAL_START option thinking that now this option is not required as people can build a second kernel as relocatable and load it anywhere. So need of compiling the kernel for a custom address was gone. But Magnus uses vmlinux images for second kernel in Xen environment and he wants to continue to use it. o Restoring the CONFIG_PHYSICAL_START option for the time being. I think down the line we can get rid of it. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-04Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: asus_acpi: new MAINTAINER ACPI: fix section mis-match build warning ACPI: increase ACPI_MAX_REFERENCE_COUNT for larger systems ACPI: EC: move verbose printk to debug build only backlight: fix backlight_device_register compile failures
2007-01-03Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] longhaul: Kill off warnings introduced by recent changes. [CPUFREQ] Uninitialized use of cmd.val in arch/i386/kernel/cpu/cpufreq/acpi-cpufreq.c:acpi_cpufreq_target() [CPUFREQ] Longhaul - Always guess FSB [CPUFREQ] Longhaul - Fix up powersaver assumptions. [CPUFREQ] longhaul: Fix up unreachable code. [CPUFREQ] speedstep-centrino: missing space and bracket [CPUFREQ] Bug fix for acpi-cpufreq and cpufreq_stats oops on frequency change notification [CPUFREQ] select consistently
2007-01-03[PATCH] x86_64: Fix dump_trace()OGAWA Hirofumi
If caller passed the tsk, we should use it to validate a stack ptr. Otherwise, sysrq-t and other debugging stuff doesn't work. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-02[CPUFREQ] longhaul: Kill off warnings introduced by recent changes.Dave Jones
Bunch of unused vars + one case where gcc isn't smart enough. Signed-off-by: Dave Jones <davej@redhat.com>
2007-01-02[CPUFREQ] Uninitialized use of cmd.val in ↵Guillaume Chazarain
arch/i386/kernel/cpu/cpufreq/acpi-cpufreq.c:acpi_cpufreq_target() cmd.val was used uninitialized on the line below. Signed-off-by: Guillaume Chazarain <guichaz@yahoo.fr> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Dave Jones <davej@redhat.com>
2007-01-02[CPUFREQ] Longhaul - Always guess FSBRafa³ Bilski
This is patch that solves Ebox mini PC issue and make FSB code more specification compilant. At start guess_fsb function is guessing 200MHz FSB too. It is better to make it in this way because, thanks to this function, driver will fail for bogus FSB values caused by bogus multiplier value. For PowerSaver processors we can't depend on Max / MinMHzFSB because these values are only used for PowerSaver 2.0 and 3.0. Most processors on which Longhaul is used are PowerSaver 1.0 only. I'm changing code for older CPU's too, but not so much as previously, and this code was already used for Ezra. Using MinMHzBR for Ezra-T is outside spec. It is for voltage scaling purpose and don't have to be equal to minmult (but it is). Same for Nehemiah (it isn't for sure). Added mult - current multiplier value. Signed-off-by: Rafa³ Bilski <rafalbilski@interia.pl> Signed-off-by: Dave Jones <davej@redhat.com>
2007-01-02Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 4081/1: Add definition for TI Sync Serial Protocol [ARM] 4080/1: Fix for the SSCR0_SlotsPerFrm macro [ARM] Fix VFP initialisation issue for SMP systems [ARM] 4078/1: Fix ARM copypage cache coherency problems [ARM] 4077/1: iop13xx: fix __io() macro [ARM] 4074/1: Flat loader stack alignment [ARM] 4073/1: Prevent s3c24xx drivers from including asm/arch/hardware.h and asm/arch/irqs.h [ARM] 4071/1: S3C24XX: Documentation update [ARM] 4066/1: correct a comment about PXA's sched_clock range [ARM] 4065/1: S3C24XX: dma printk fixes [ARM] 4064/1: make pxa_get_cycles() static [ARM] 4063/1: ep93xx: fix IRQ_EP93XX_GPIO?MUX numbering
2007-01-02[ARM] Fix VFP initialisation issue for SMP systemsRussell King
When we install the handlers for context switching, we must enable VFP on all CPU cores, otherwise undefined (and random) effects occur. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-02[PATCH] Fix insta-reboot with "i386: Relocatable kernel support"Segher Boessenkool
Commit 968de4f02621db35b8ae5239c8cfc6664fb872d8 ("i386: Relocatable kernel support") caused problems for people with old binutils versions that didn't mark ".text.*" sections automatically allocated. So we should use .section command to specifically mark .text.head section as AX (allocatable and executable) to solve the problem. This should be unnecessary with binutils 2.15 and later, which is already three years old, but it doesn't hurt supporting older toolchains where possible. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-02ACPI: fix section mis-match build warningLen Brown
Dunno why this pops out in only in the allmodconfig build. Though the warning is accurate, all the callers of the flagged non __init function are __init, this is not a functional change. WARNING: vmlinux - Section mismatch: reference to .init.data:acpi_sci_flags from .text between 'acpi_sci_ioapic_setup' (at offset 0xc010f0a 6) and 'acpi_gsi_to_irq' WARNING: vmlinux - Section mismatch: reference to .init.text:mp_override_legacy_irq from .text between 'acpi_sci_ioapic_setup' (at offset 0 xc010f0de) and 'acpi_gsi_to_irq' WARNING: vmlinux - Section mismatch: reference to .init.data:acpi_sci_override_gsi from .text between 'acpi_sci_ioapic_setup' (at offset 0x c010f0e4) and 'acpi_gsi_to_irq' Signed-off-by: Len Brown <len.brown@intel.com>
2007-01-01Revert "[PATCH] x86_64: fix boot hang caused by ↵Linus Torvalds
CALGARY_IOMMU_ENABLED_BY_DEFAULT" This reverts commit a9622f6219ce58faba1417743bf3078501eb3434. Now that the Calgary code apparently detects itself properly, it's not needed any more. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-31[SPARC64]: Handle ISA devices with no 'regs' property.David S. Miller
And this points out that the return value from isa_dev_get_resource() and the 'pregs' arg to isa_dev_get_irq() are totally unused. Based upon a patch from Richard Mortimer <richm@oldelvet.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-31[SPARC64]: Update defconfig.David S. Miller
2006-12-31[SPARC64]: Fix of_iounmap() region release.David S. Miller
We need to pass in the resource otherwise we cannot release the region properly. We must know whether it is an I/O or MEM resource. Spotted by Eric Brower. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-31[SPARC64]: Fix "mem=xxx" handling.David S. Miller
We were not being careful enough. When we trim the physical memory areas, we have to make sure we don't remove the kernel image or initial ramdisk image ranges. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-30[PATCH] sparc32: add offset in pci_map_sg()Jan Andersson
Add sg->offset to sg->dvma_address in pci_map_sg() on sparc32. Without the offset, transfers to buffers that do not begin on a page boundary will not work as expected. Signed-off-by: Jan Andersson <jan.andersson@ieee.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] ARM: OMAP: fix missing header on apollon boardKyungmin Park
Fix apollon board compiler error Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] ARM: OMAP: fix GPMC compiler errorsKyungmin Park
Fix GPMC compiler errors on OMAP2 Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] make fn_keys work again on power/macbooksSoeren Sonnenburg
The apple fn keys don't work anymore with 2.6.20-rc1. The reason is that USB_HID_POWERBOOK appears in several files although USB_HIDINPUT_POWERBOOK is the thing to be used. The patch fixes this. Cc: Greg KH <greg@kroah.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] Add .gitignore file for relocs in arch/i386Thomas Meyer
Due to the changes to make the kernel relocateable a new file is created during the build process. [jirislaby@gmail.com: The .gitigonre was intended to be in arch/ subtree] Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[ARM] 4078/1: Fix ARM copypage cache coherency problemsRichard Purdie
If PG_dcache_dirty is set for a page, we need to flush the source page before performing any copypage operation using a different virtual address. This fixes the copypage implementations for XScale, StrongARM and ARMv6. This patch fixes segmentation faults seen in the dynamic linker under the usage patterns in glibc 2.4/2.5. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-30[ARM] 4077/1: iop13xx: fix __io() macroDan Williams
Since iop13xx defines the PCI I/O spaces with physical resource addresses the __io macro needs to perform the physical to virtual conversion. I incorrectly assumed that this would be handled by ioremap, but drivers (like e1000) directly dereference the address returned from __io. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-30[ARM] 4066/1: correct a comment about PXA's sched_clock rangeNicolas Pitre
Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-30[ARM] 4065/1: S3C24XX: dma printk fixesArnaud Patard
The commit 505788cccbb96cd496b646594c8a5fcdc26bc2d9 in linus kernel tree introduced some printks (for debugging ?) which are flooding the logs on my h1940. This patch replace them with pr_debug calls. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-30[ARM] 4064/1: make pxa_get_cycles() staticNicolas Pitre
... and fix a comment as well. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-29[CPUFREQ] Longhaul - Fix up powersaver assumptions.Rafa³ Bilski
ACPI PM2 register was fallback for "Longhaul ver. 1" CPU's. My assumption that this register isn't present at "PowerSaver" motherboards is so far true, but current code will not work correctly in other case. There are three possible supports: ACPI C3, PM2 and northbridge. That was my assumption that ACPI C3 and northbridge is for PS and northbridge and PM2 is for V1. In current code we can only check if it is ACPI support or not by port22_en. So remove port22_en and add longhaul_flags. If USE_ACPI_C3 and USE_NORTHBRIDGE are both clear then it means ACPI PM2 support. Also change order of support probe from ACPI C3, PM2, northbridge to ACPI C3, northbridge, ACPI PM2. Paranoid protection against port 0x22 cast as ACPI PM2 register. Bit 1 clear in such case - lockup on AGP DMA. And obvious (now) fixup for do_powersaver. Use cx->address only for ACPI C3 ("PowerSaver" processor using PM2 support). Signed-off-by: Rafa¿ Bilski <rafalbilski@interia.pl> Signed-off-by: Dave Jones <davej@redhat.com>
2006-12-28[CPUFREQ] longhaul: Fix up unreachable code.Dave Jones
Signed-off-by: Rafał Bilski <rafalbilski@interia.pl> Signed-off-by: Dave Jones <davej@redhat.com>
2006-12-23[PATCH] arch/i386/pci/mmconfig.c tlb flush fixOGAWA Hirofumi
We use the fixmap for accessing pci config space in pci_mmcfg_read/write(). The problem is in pci_exp_set_dev_base(). It is caching a last accessed address to avoid calling set_fixmap_nocache() whenever pci_mmcfg_read/write() is used. static inline void pci_exp_set_dev_base(int bus, int devfn) { u32 dev_base = base | (bus << 20) | (devfn << 12); if (dev_base != mmcfg_last_accessed_device) { mmcfg_last_accessed_device = dev_base; set_fixmap_nocache(FIX_PCIE_MCFG, dev_base); } } cpu0 cpu1 --------------------------------------------------------------------------- pci_mmcfg_read("device-A") pci_exp_set_dev_base() set_fixmap_nocache() pci_mmcfg_read("device-B") pci_exp_set_dev_base() set_fixmap_nocache() pci_mmcfg_read("device-B") pci_exp_set_dev_base() /* doesn't flush tlb */ But if cpus accessed the above order, the second pci_mmcfg_read() on cpu0 doesn't flush the TLB, because "mmcfg_last_accessed_device" is device-B. So, second pci_mmcfg_read() on cpu0 accesses a device-A via a previous TLB cache. This problem became the cause of several strange behavior. This patches fixes this situation by adds "mmcfg_last_accessed_cpu" check. [ Alternatively, we could make a per-cpu mapping area or something. Not that it's probably worth it, but if we wanted to avoid all locking and instead just disable preemption, that would be the way to go. --Linus ] Signed-off-by: OGAWA Hirofumi <hogawa@miraclelinux.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[CPUFREQ] speedstep-centrino: missing space and bracketBrice Goglin
A space and a bracket are missing (and indentation is wrong). Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-12-22[CPUFREQ] Bug fix for acpi-cpufreq and cpufreq_stats oops on frequency ↵Venkatesh Pallipadi
change notification Fixes the oops in cpufreq_stats with acpi_cpufreq driver. The issue was that the frequency was reported as 0 in acpi-cpufreq.c. The bug is due to different indicies for freq_table and ACPI perf table. Also adds a check in cpufreq_stats to check for error return from freq_table_get_index() and avoid using the error return value. Patch fixes the issue reported at http://www.ussg.iu.edu/hypermail/linux/kernel/0611.2/0629.html and also other similar issue here http://bugme.osdl.org/show_bug.cgi?id=7383 comment 53 Signed-off-by: Dhaval Giani <dhaval.giani@gmail.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-12-22[CPUFREQ] select consistentlyRandy Dunlap
Make x86_64 ACPI_CPU_FREQ select CPU_FREQ_TABLE like other methods do. (although we should still eliminate as much use of 'select' as possible) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-12-22Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (68 commits) ACPI: replace kmalloc+memset with kzalloc ACPI: Add support for acpi_load_table/acpi_unload_table_id fbdev: update after backlight argument change ACPI: video: Add dev argument for backlight_device_register ACPI: Implement acpi_video_get_next_level() ACPI: Kconfig - depend on PM rather than selecting it ACPI: fix NULL check in drivers/acpi/osl.c ACPI: make drivers/acpi/ec.c:ec_ecdt static ACPI: prevent processor module from loading on failures ACPI: fix single linked list manipulation ACPI: ibm_acpi: allow clean removal ACPI: fix git automerge failure ACPI: ibm_acpi: respond to workqueue update ACPI: dock: add uevent to indicate change in device status ACPI: ec: Lindent once again ACPI: ec: Change #define to enums there possible. ACPI: ec: Style changes. ACPI: ec: Acquire Global Lock under EC mutex. ACPI: ec: Drop udelay() from poll mode. Loop by reading status field instead. ACPI: ec: Rename gpe_bit to gpe ...
2006-12-22[PATCH] sched: fix bad missed wakeups in the i386, x86_64, ia64, ACPI and ↵Ingo Molnar
APM idle code Fernando Lopez-Lezcano reported frequent scheduling latencies and audio xruns starting at the 2.6.18-rt kernel, and those problems persisted all until current -rt kernels. The latencies were serious and unjustified by system load, often in the milliseconds range. After a patient and heroic multi-month effort of Fernando, where he tested dozens of kernels, tried various configs, boot options, test-patches of mine and provided latency traces of those incidents, the following 'smoking gun' trace was captured by him: _------=> CPU# / _-----=> irqs-off | / _----=> need-resched || / _---=> hardirq/softirq ||| / _--=> preempt-depth |||| / ||||| delay cmd pid ||||| time | caller \ / ||||| \ | / IRQ_19-1479 1D..1 0us : __trace_start_sched_wakeup (try_to_wake_up) IRQ_19-1479 1D..1 0us : __trace_start_sched_wakeup <<...>-5856> (37 0) IRQ_19-1479 1D..1 0us : __trace_start_sched_wakeup (c01262ba 0 0) IRQ_19-1479 1D..1 0us : resched_task (try_to_wake_up) IRQ_19-1479 1D..1 0us : __spin_unlock_irqrestore (try_to_wake_up) ... <idle>-0 1...1 11us!: default_idle (cpu_idle) ... <idle>-0 0Dn.1 602us : smp_apic_timer_interrupt (c0103baf 1 0) ... <...>-5856 0D..2 618us : __switch_to (__schedule) <...>-5856 0D..2 618us : __schedule <<idle>-0> (20 162) <...>-5856 0D..2 619us : __spin_unlock_irq (__schedule) <...>-5856 0...1 619us : trace_stop_sched_switched (__schedule) <...>-5856 0D..1 619us : trace_stop_sched_switched <<...>-5856> (37 0) what is visible in this trace is that CPU#1 ran try_to_wake_up() for PID:5856, it placed PID:5856 on CPU#0's runqueue and ran resched_task() for CPU#0. But it decided to not send an IPI that no CPU - due to TS_POLLING. But CPU#0 never woke up after its NEED_RESCHED bit was set, and only rescheduled to PID:5856 upon the next lapic timer IRQ. The result was a 600+ usecs latency and a missed wakeup! the bug turned out to be an idle-wakeup bug introduced into the mainline kernel this summer via an optimization in the x86_64 tree: commit 495ab9c045e1b0e5c82951b762257fe1c9d81564 Author: Andi Kleen <ak@suse.de> Date: Mon Jun 26 13:59:11 2006 +0200 [PATCH] i386/x86-64/ia64: Move polling flag into thread_info_status During some profiling I noticed that default_idle causes a lot of memory traffic. I think that is caused by the atomic operations to clear/set the polling flag in thread_info. There is actually no reason to make this atomic - only the idle thread does it to itself, other CPUs only read it. So I moved it into ti->status. the problem is this type of change: if (!hlt_counter && boot_cpu_data.hlt_works_ok) { - clear_thread_flag(TIF_POLLING_NRFLAG); + current_thread_info()->status &= ~TS_POLLING; smp_mb__after_clear_bit(); while (!need_resched()) { local_irq_disable(); this changes clear_thread_flag() to an explicit clearing of TS_POLLING. clear_thread_flag() is defined as: clear_bit(flag, &ti->flags); and clear_bit() is a LOCK-ed atomic instruction on all x86 platforms: static inline void clear_bit(int nr, volatile unsigned long * addr) { __asm__ __volatile__( LOCK_PREFIX "btrl %1,%0" hence smp_mb__after_clear_bit() is defined as a simple compile barrier: #define smp_mb__after_clear_bit() barrier() but the explicit TS_POLLING clearing introduced by the patch: + current_thread_info()->status &= ~TS_POLLING; is not an atomic op! So the clearing of the TS_POLLING bit is freely reorderable with the reading of the NEED_RESCHED bit - and both now reside in different memory addresses. CPU idle wakeup very much depends on ordered memory ops, the clearing of the TS_POLLING flag must always be done before we test need_resched() and hit the idle instruction(s). [Symmetrically, the wakeup code needs to set NEED_RESCHED before it tests the TS_POLLING flag, so memory ordering is paramount.] Fernando's dual-core Athlon64 system has a sufficiently advanced memory ordering model so that it triggered this scenario very often. ( And it also turned out that the reason why these latencies never triggered on my testsystems is that i routinely use idle=poll, which was the only idle variant not affected by this bug. ) The fix is to change the smp_mb__after_clear_bit() to an smp_mb(), to act as an absolute barrier between the TS_POLLING write and the NEED_RESCHED read. This affects almost all idling methods (default, ACPI, APM), on all 3 x86 architectures: i386, x86_64, ia64. Signed-off-by: Ingo Molnar <mingo@elte.hu> Tested-by: Fernando Lopez-Lezcano <nando@ccrma.Stanford.EDU> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] ptrace: Fix EFL_OFFSET value according to i386 pda changesJeremy Fitzhardinge
The PDA patches introduced a bug in ptrace: it reads eflags from the wrong place on the target's stack, but writes it back to the correct place. The result is a corrupted eflags, which is most visible when it turns interrupts off unexpectedly. This patch fixes this by making the ptrace code a little less fragile. It changes [gs]et_stack_long to take a straightforward byte offset into struct pt_regs, rather than requiring all callers to do a sizeof(struct pt_regs) offset adjustment. This means that the eflag's offset (EFL_OFFSET) on the target stack can be simply computed with offsetof(). Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Frederik Deweerdt <deweerdt@free.fr> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] memory hotplug: fix compile error for i386 with NUMA configYasunori Goto
Fix compile error when config memory hotplug with numa on i386. The cause of compile error was missing of arch_add_memory(), remove_memory(), and memory_add_physaddr_to_nid(). Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@cs.washington.edu> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] microcode: fix mc_cpu_notifier section warningJean Delvare
Structure mc_cpu_notifier references a __cpuinit function, but isn't declared __cpuinitdata itself: WARNING: arch/i386/kernel/microcode.o - Section mismatch: reference to .init.text: from .data after 'mc_cpu_notifier' (at offset 0x118) Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] compile error of register_memory()Yasunori Goto
register_memory() becomes double definition in 2.6.20-rc1. It is defined in arch/i386/kernel/setup.c as static definition in 2.6.19. But it is moved to arch/i386/kernel/e820.c in 2.6.20-rc1. And same name function is defined in driver/base/memory.c too. So, it becomes cause of compile error of duplicate definition if memory hotplug option is on. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-21[PATCH] x86_64: fix boot time hang in detect_calgary()Ingo Molnar
if CONFIG_CALGARY_IOMMU is built into the kernel via CONFIG_CALGARY_IOMMU_ENABLED_BY_DEFAULT, or is enabled via the iommu=calgary boot option, then the detect_calgary() function runs to detect the presence of a Calgary IOMMU. detect_calgary() first searches the BIOS EBDA area for a "rio_table_hdr" BIOS table. It has this parsing algorithm for the EBDA: while (offset) { ... /* The next offset is stored in the 1st word. 0 means no more */ offset = *((unsigned short *)(ptr + offset)); } got that? Lets repeat it slowly: we've got a BIOS-supplied data structure, plus Linux kernel code that will only break out of an infinite parsing loop once the BIOS gives a zero offset. Ok? Translation: what an excellent opportunity for BIOS writers to lock up the Linux boot process in an utterly hard to debug place! Indeed the BIOS jumped on that opportunity on my box, which has the following EBDA chaining layout: 384, 65282, 65535, 65535, 65535, 65535, 65535, 65535 ... see the pattern? So my, definitely non-Calgary system happily locks up in detect_calgary()! the patch below fixes the boot hang by trusting the BIOS-supplied data structure a bit less: the parser always has to make forward progress, and if it doesnt, we break out of the loop and i get the expected kernel message: Calgary: Unable to locate Rio Grande Table in EBDA - bailing! Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-21[PATCH] x86_64: fix boot hang caused by CALGARY_IOMMU_ENABLED_BY_DEFAULTIngo Molnar
one of my boxes didnt boot the 2.6.20-rc1-rt0 kernel rpm, it hung during early bootup. After an hour or two of happy debugging i narrowed it down to the CALGARY_IOMMU_ENABLED_BY_DEFAULT option, which was freshly added to 2.6.20 via the x86_64 tree and /enabled by default/. commit bff6547bb6a4e82c399d74e7fba78b12d2f162ed claims: [PATCH] Calgary: allow compiling Calgary in but not using it by default This patch makes it possible to compile Calgary in but not use it by default. In this mode, use 'iommu=calgary' to activate it. but the change does not actually practice it: config CALGARY_IOMMU_ENABLED_BY_DEFAULT bool "Should Calgary be enabled by default?" default y depends on CALGARY_IOMMU help Should Calgary be enabled by default? if you choose 'y', Calgary will be used (if it exists). If you choose 'n', Calgary will not be used even if it exists. If you choose 'n' and would like to use Calgary anyway, pass 'iommu=calgary' on the kernel command line. If unsure, say Y. it's both 'default y', and says "If unsure, say Y". Clearly not a typo. disabling this option makes my box boot again. The patch below fixes the Kconfig entry. Grumble. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-21Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (22 commits) acpiphp: Link-time error for PCI Hotplug shpchp: cleanup shpchp.h shpchp: remove shpchprm_get_physical_slot_number shpchp: cleanup struct controller shpchp: remove unnecessary struct php_ctlr PCI: ATI sb600 sata quirk PCI legacy resource fix PCI: don't export device IDs to userspace PCI: Be a bit defensive in quirk_nvidia_ck804() so we don't risk dereferencing a NULL pdev. PCI: Fix multiple problems with VIA hardware PCI: Only check the HT capability bits in mpic.c PCI: Use pci_find_ht_capability() in drivers/pci/quirks.c PCI: Add #defines for Hypertransport MSI fields PCI: Use pci_find_ht_capability() in drivers/pci/htirq.c PCI: Add pci_find_ht_capability() for finding Hypertransport capabilities PCI: Create __pci_bus_find_cap_start() from __pci_bus_find_cap() pci: Introduce pci_find_present PCI: pcieport-driver: remove invalid warning message rpaphp: compiler warning cleanup PCI quirks: remove redundant check ...
2006-12-20Merge branch 'merge' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of master.kernel.org:/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Fix register save area alignment for swapcontext syscall [POWERPC] Fix PCI device channel state initialization [POWERPC] Update MTD OF documentation [POWERPC] Probe Efika platform before CHRP. [POWERPC] Fix build of cell zImage.initrd [POWERPC] iSeries: fix CONFIG_VIOPATH dependency [POWERPC] iSeries: fix viocons init [POWERPC] iSeries: fix viocd init [POWERPC] iSeries: fix iseries_veth init [POWERPC] iSeries: fix viotape init [POWERPC] iSeries: fix viodasd init [POWERPC] Workaround oldworld OF bug with IRQs & P2P bridges [POWERPC] powerpc: add scanning of ebc bus to of_platform [POWERPC] spufs: fix assignment of node numbers [POWERPC] cell: Fix spufs with "new style" device-tree [POWERPC] cell: Enable spider workarounds on all PCI buses [POWERPC] cell: add forward struct declarations to spu.h [POWERPC] cell: update cell_defconfig
2006-12-20Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (29 commits) [ARM] 4062/1: S3C24XX: Anubis and Osiris shuld have CONFIG_PM_SIMTEC [ARM] 4060/1: update several ARM defconfigs [ARM] 4061/1: xsc3: change of maintainer [ARM] 4059/1: VR1000: fix LED3's platform device number [ARM] 4022/1: iop13xx: generic irq fixups [ARM] 4015/1: s3c2410 cpu ifdefs [ARM] 4057/1: ixp23xx: unconditionally enable hardware coherency [ARM] 4056/1: iop13xx: fix resource.end off-by-one in flash setup [ARM] 4055/1: iop13xx: fix phys_io/io_pg_offst for iq81340mc/sc [ARM] 4054/1: ep93xx: add HWCAP_CRUNCH [ARM] 4052/1: S3C24XX: Fix PM in arch/arm/mach-s3c2410/Kconfig [ARM] Fix warnings from asm/system.h [ARM] 4051/1: S3C24XX: clean includes in S3C2440 and S3C2442 support [ARM] 4050/1: S3C24XX: remove old changelogs in arch/arm/mach-s3c2410 [ARM] 4049/1: S3C24XX: fix sparse warning due to upf_t in regs-serial.h [ARM] 4048/1: S3C24XX: make s3c2410_pm_resume() static [ARM] 4046/1: S3C24XX: fix sparse errors arch/arm/mach-s3c2410 [ARM] 4045/1: S3C24XX: remove old VA for non-shared areas [ARM] 4044/1: S3C24XX: fix sparse warnings in arch/arm/mach-s3c2410/s3c2442-clock.c [ARM] 4043/1: S3C24XX: fix sparse warnings in arch/arm/mach-s3c2410/s3c2440-clock.c ...
2006-12-20ACPI: replace kmalloc+memset with kzallocBurman Yan
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-12-20PCI: Fix multiple problems with VIA hardwareAlan Cox
This patch is designed to fix: - Disk eating corruptor on KT7 after resume from RAM - VIA IRQ handling - VIA fixups for bus lockups after resume from RAM The core of this is to add a table of resume fixups run at resume time. We need to do this for a variety of boards and features, but particularly we need to do this to get various critical VIA fixups done on resume. The second part of the problem is to handle VIA IRQ number rules which are a bit odd and need special handling for PIC interrupts. Various patches broke various boxes and while this one may not be perfect (hopefully it is) it ensures the workaround is applied to the right devices only. From: Jean Delvare <khali@linux-fr.org> Now that PCI quirks are replayed on software resume, we can safely re-enable the Asus SMBus unhiding quirk even when software suspend support is enabled. [akpm@osdl.org: fix const warning] Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20PCI: Only check the HT capability bits in mpic.cMichael Ellerman
Only compare the exact HT capability bits against HT_CAPTYPE_IRQ, this is a little paranoid, but doesn't hurt. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20merge linus into test branchLen Brown
