Ingo writes:
"x86 fixes:
It's 4 misc fixes, 3 build warning fixes and 3 comment fixes.
In hindsight I'd have left out the 3 comment fixes to make the pull
request look less scary at such a late point in the cycle. :-/"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/swiotlb: Enable swiotlb for > 4GiG RAM on 32-bit kernels
x86/fpu: Fix i486 + no387 boot crash by only saving FPU registers on context switch if there is an FPU
x86/fpu: Remove second definition of fpu in __fpu__restore_sig()
x86/entry/64: Further improve paranoid_entry comments
x86/entry/32: Clear the CS high bits
x86/boot: Add -Wno-pointer-sign to KBUILD_CFLAGS
x86/time: Correct the attribute on jiffies' definition
x86/entry: Add some paranoid entry/exit CR3 handling comments
x86/percpu: Fix this_cpu_read()
x86/tsc: Force inlining of cyc2ns bits
We already build the swiotlb code for 32-bit kernels with PAE support,
but the code to actually use swiotlb has only been enabled for 64-bit
kernels for an unknown reason.
Before Linux v4.18 we paper over this fact because the networking code,
the SCSI layer and some random block drivers implemented their own
bounce buffering scheme.
[ mingo: Changelog fixes. ]
Fixes: 21e07dba9fb1 ("scsi: reduce use of block bounce buffers")
Fixes: ab74cfebafa3 ("net: remove the PCI_DMA_BUS_IS_PHYS check in illegal_highdma")
Reported-by: Matthew Whitehead <tedheadster@gmail.com>
Tested-by: Matthew Whitehead <tedheadster@gmail.com>
Cc: konrad.wilk@oracle.com
Cc: iommu@lists.linux-foundation.org
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/20181014075208.2715-1-hch@lst.de
Smatch complains that "val" would be uninitialized if kstrtoul() fails.
Fixes: 9a08862a5d2e ("vDSO for sparc")
First, the trap number for 32-bit syscalls is 0x10.
Also, only negate the return value when syscall error is indicated by
the carry bit being set.
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Helge writes:
"parisc fix:
Fix an unitialized variable usage in the parisc unwind code."
* 'parisc-4.19-3' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: Fix uninitialized variable usage in unwind.c
Booting an i486 with "no387 nofxsr" ends with with the following crash:
math_emulate: 0060:c101987d
Kernel panic - not syncing: Math emulation needed in kernel
on the first context switch in user land.
The reason is that copy_fpregs_to_fpstate() tries FNSAVE which does not work
as the FPU is turned off.
This bug was introduced in:
f1c8cd0176078 ("x86/fpu: Change fpu->fpregs_active users to fpu->fpstate_active")
Add a check for X86_FEATURE_FPU before trying to save FPU registers (we
have such a check in switch_fpu_finish() already).
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Reviewed-by: Andy Lutomirski <luto@kernel.org>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Fixes: f1c8cd0176078 ("x86/fpu: Change fpu->fpregs_active users to fpu->fpstate_active")
Link: http://lkml.kernel.org/r/20181016202525.29437-4-bigeasy@linutronix.de
Commit:
c5bedc6847c3b ("x86/fpu: Get rid of PF_USED_MATH usage, convert it to fpu->fpstate_active")
introduced the 'fpu' variable at top of __restore_xstate_sig(),
which now shadows the other definition:
arch/x86/kernel/fpu/signal.c:318:28: warning: symbol 'fpu' shadows an earlier one
arch/x86/kernel/fpu/signal.c:271:20: originally declared here
Remove the shadowed definition of 'fpu', as the two definitions are the same.
Fixes: c5bedc6847c3b ("x86/fpu: Get rid of PF_USED_MATH usage, convert it to fpu->fpstate_active")
Link: http://lkml.kernel.org/r/20181016202525.29437-3-bigeasy@linutronix.de
Commit:
16561f27f94e ("x86/entry: Add some paranoid entry/exit CR3 handling comments")
... added some comments. This improves them a bit:
- When I first read the new comments, it was unclear to me whether
they were referring to the case where paranoid_entry interrupted
other entry code or where paranoid_entry was itself interrupted.
Clarify it.
- Remove the EBX comment. We no longer use EBX as a SWAPGS
indicator.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Link: http://lkml.kernel.org/r/c47daa1888dc2298e7e1d3f82bd76b776ea33393.1539542111.git.luto@kernel.org
Even if not on an entry stack, the CS's high bits must be
initialized because they are unconditionally evaluated in
PARANOID_EXIT_TO_KERNEL_MODE.
Failing to do so broke the boot on Galileo Gen2 and IOT2000 boards.
[ bp: Make the commit message tone passive and impartial. ]
Fixes: b92a165df17e ("x86/entry/32: Handle Entry from Kernel-Mode on Entry-Stack")
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Reviewed-by: Joerg Roedel <jroedel@suse.de>
Acked-by: Joerg Roedel <jroedel@suse.de>
CC: "H. Peter Anvin" <hpa@zytor.com>
CC: Andrea Arcangeli <aarcange@redhat.com>
CC: Andy Lutomirski <luto@kernel.org>
CC: Boris Ostrovsky <boris.ostrovsky@oracle.com>
CC: Brian Gerst <brgerst@gmail.com>
CC: Dave Hansen <dave.hansen@intel.com>
CC: David Laight <David.Laight@aculab.com>
CC: Denys Vlasenko <dvlasenk@redhat.com>
CC: Eduardo Valentin <eduval@amazon.com>
CC: Greg KH <gregkh@linuxfoundation.org>
CC: Ingo Molnar <mingo@kernel.org>
CC: Jiri Kosina <jkosina@suse.cz>
CC: Josh Poimboeuf <jpoimboe@redhat.com>
CC: Juergen Gross <jgross@suse.com>
CC: Linus Torvalds <torvalds@linux-foundation.org>
CC: Peter Zijlstra <peterz@infradead.org>
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Will Deacon <will.deacon@arm.com>
CC: aliguori@amazon.com
CC: daniel.gruss@iaik.tugraz.at
CC: hughd@google.com
CC: keescook@google.com
CC: linux-mm <linux-mm@kvack.org>
CC: x86-ml <x86@kernel.org>
Link: http://lkml.kernel.org/r/f271c747-1714-5a5b-a71f-ae189a093b8d@siemens.com
David writes:
"Sparc fixes
1) Revert the %pOF change, it causes regressions.
2) Wire up io_pgetevents().
3) Fix perf events on single-PCR sparc64 cpus.
4) Do proper perf event throttling like arm and x86."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
Revert "sparc: Convert to using %pOFn instead of device_node.name"
sparc64: Set %l4 properly on trap return after handling signals.
sparc64: Make proc_id signed.
sparc: Throttle perf events properly.
sparc: Fix single-pcr perf event counter management.
sparc: Wire up io_pgetevents system call.
sunvdc: Remove VLA usage
As noticed by Dave Anglin, the last commit introduced a small bug where
the potentially uninitialized r struct is used instead of the regs
pointer as input for unwind_frame_init(). Fix it.
Signed-off-by: Helge Deller <deller@gmx.de>
Reported-by: John David Anglin <dave.anglin@bell.net>
This reverts commit 0b9871a3a8cc7234c285b5d9bf66cc6712cfee7c.
Causes crashes with qemu, interacts badly with commit commit
6d0a70a284be ("vsprintf: print OF node name using full_name")
etc.
Reported-by: Guenter Roeck <linux@roeck-us.net>
If we did some signal processing, we have to reload the pt_regs
tstate register because it's value may have changed.
In doing so we also have to extract the %pil value contained in there
anre load that into %l4.
This value is at bit 20 and thus needs to be shifted down before we
later write it into the %pil register.
Most of the time this is harmless as we are returning to userspace
and the %pil is zero for that case.
So that when it is unset, ie. '-1', userspace can see it
properly.
When compiling the kernel with Clang, this warning appears even though
it is disabled for the whole kernel because this folder has its own set
of KBUILD_CFLAGS. It was disabled before the beginning of git history.
In file included from arch/x86/boot/compressed/kaslr.c:29:
In file included from arch/x86/boot/compressed/misc.h:21:
In file included from ./include/linux/elf.h:5:
In file included from ./arch/x86/include/asm/elf.h:77:
In file included from ./arch/x86/include/asm/vdso.h:11:
In file included from ./include/linux/mm_types.h:9:
In file included from ./include/linux/spinlock.h:88:
In file included from ./arch/x86/include/asm/spinlock.h:43:
In file included from ./arch/x86/include/asm/qrwlock.h:6:
./include/asm-generic/qrwlock.h:101:53: warning: passing 'u32 *' (aka
'unsigned int *') to parameter of type 'int *' converts between pointers
to integer types with different sign [-Wpointer-sign]
if (likely(atomic_try_cmpxchg_acquire(&lock->cnts, &cnts, _QW_LOCKED)))
./include/linux/compiler.h:76:40: note: expanded from macro 'likely'
# define likely(x) __builtin_expect(!!(x), 1)
./include/asm-generic/atomic-instrumented.h:69:66: note: passing
argument to parameter 'old' here
static __always_inline bool atomic_try_cmpxchg(atomic_t *v, int *old, int new)
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Cc: Nick Desaulniers <ndesaulniers@google.com>
Link: https://lkml.kernel.org/r/20181013010713.6999-1-natechancellor@gmail.com
Clang warns that the declaration of jiffies in include/linux/jiffies.h
doesn't match the definition in arch/x86/time/kernel.c:
arch/x86/kernel/time.c:29:42: warning: section does not match previous declaration [-Wsection]
__visible volatile unsigned long jiffies __cacheline_aligned = INITIAL_JIFFIES;
./include/linux/cache.h:49:4: note: expanded from macro '__cacheline_aligned'
__section__(".data..cacheline_aligned")))
./include/linux/jiffies.h:81:31: note: previous attribute is here
extern unsigned long volatile __cacheline_aligned_in_smp __jiffy_arch_data jiffies;
./arch/x86/include/asm/cache.h:20:2: note: expanded from macro '__cacheline_aligned_in_smp'
__page_aligned_data
./include/linux/linkage.h:39:29: note: expanded from macro '__page_aligned_data'
#define __page_aligned_data __section(.data..page_aligned) __aligned(PAGE_SIZE)
./include/linux/compiler_attributes.h:233:56: note: expanded from macro '__section'
#define __section(S) __attribute__((__section__(#S)))
1 warning generated.
The declaration was changed in commit 7c30f352c852 ("jiffies.h: declare
jiffies and jiffies_64 with ____cacheline_aligned_in_smp") but wasn't
updated here. Make them match so Clang no longer warns.
Fixes: 7c30f352c852 ("jiffies.h: declare jiffies and jiffies_64 with ____cacheline_aligned_in_smp")
Link: https://lkml.kernel.org/r/20181013005311.28617-1-natechancellor@gmail.com
Andi Kleen was just asking me about the NMI CR3 handling and why
we restore it unconditionally. I was *sure* we had documented it
well. We did not.
Add some documentation. We have common entry code where the CR3
value is stashed, but three places in two big code paths where we
restore it. I put bulk of the comments in this common path and
then refer to it from the other spots.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: luto@kernel.org
Cc: bp@alien8.de
Cc: "H. Peter Anvin" <hpa@zytor.come
Link: https://lkml.kernel.org/r/20181012232118.3EAAE77B@viggo.jf.intel.com
Eric reported that a sequence count loop using this_cpu_read() got
optimized out. This is wrong, this_cpu_read() must imply READ_ONCE()
because the interface is IRQ-safe, therefore an interrupt can have
changed the per-cpu value.
Fixes: 7c3576d261ce ("[PATCH] i386: Convert PDA into the percpu section")
Reported-by: Eric Dumazet <edumazet@google.com>
Cc: hpa@zytor.com
Cc: eric.dumazet@gmail.com
Cc: bp@alien8.de
Link: https://lkml.kernel.org/r/20181011104019.748208519@infradead.org
Looking at the asm for native_sched_clock() I noticed we don't inline
enough. Mostly caused by sharing code with cyc2ns_read_begin(), which
we didn't used to do. So mark all that __force_inline to make it DTRT.
Fixes: 59eaef78bfea ("x86/tsc: Remodel cyc2ns to use seqcount_latch()")
Cc: hpa@zytor.com
Cc: bp@alien8.de
Link: https://lkml.kernel.org/r/20181011104019.695196158@infradead.org
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Dan writes:
"libnvdimm/dax 4.19-rc8
* Fix a livelock in dax_layout_busy_page() present since v4.18. The
lockup triggers when truncating an actively mapped huge page out of
a mapping pinned for direct-I/O.
* Fix mprotect() clobbers of _PAGE_DEVMAP. Broken since v4.5
mprotect() clears this flag that is needed to communicate the
liveness of device pages to the get_user_pages() path."
* tag 'libnvdimm-fixes-4.19-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
mm: Preserve _PAGE_DEVMAP across mprotect() calls
filesystem-dax: Fix dax_layout_busy_page() livelock
Paolo writes:
"KVM fixes for 4.19-rc8
Leftover bugfixes."
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: vmx: hyper-v: don't pass EPT configuration info to vmx_hv_remote_flush_tlb()
KVM: x86: support CONFIG_KVM_AMD=y with CONFIG_CRYPTO_DEV_CCP_DD=m
ARM: KVM: Correctly order SGI register entries in the cp15 array
I'm observing random crashes in multi-vCPU L2 guests running on KVM on
Hyper-V. I bisected the issue to the commit 877ad952be3d ("KVM: vmx: Add
tlb_remote_flush callback support"). Hyper-V TLFS states:
"AddressSpace specifies an address space ID (an EPT PML4 table pointer)"
So apparently, Hyper-V doesn't expect us to pass naked EPTP, only PML4
pointer should be used. Strip off EPT configuration information before
calling into vmx_hv_remote_flush_tlb().
Fixes: 877ad952be3d ("KVM: vmx: Add tlb_remote_flush callback support")
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Will writes:
"More arm64 fixes
- Reject CHAIN PMU events when they are not part of a 64-bit counter
- Fix WARN_ON_ONCE() that triggers for reserved regions that don't
correspond to mapped memory"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64: perf: Reject stand-alone CHAIN events for PMUv3
arm64: Fix /proc/iomem for reserved but not memory regions
Like x86 and arm, call perf_sample_event_took() in perf event
NMI interrupt handler.
It is important to clear the hw->state value for non-stopped events
when they are added into the PMU. Otherwise when the event is
scheduled out, we won't read the counter because HES_UPTODATE is still
set. This breaks 'perf stat' and similar use cases, causing all the
events to show zero.
This worked for multi-pcr because we make explicit sparc_pmu_start()
calls in calculate_multiple_pcrs(). calculate_single_pcr() doesn't do
this because the idea there is to accumulate all of the counter
settings into the single pcr value. So we have to add explicit
hw->state handling there.
Like x86, we use the PERF_HES_ARCH bit to track truly stopped events
so that we don't accidently start them on a reload.
Related to all of this, sparc_pmu_start() is missing a userpage update
so add it.
Arnd writes:
"ARM: SoC fixes for 4.19
Two last minute bugfixes, both for NXP platforms:
* The Layerscape 'qbman' infrastructure suffers from probe ordering
bugs in some configurations, a two-patch series adds a hotfix for
this. 4.20 will have a longer set of patches to rework it.
* The old imx53-qsb board regressed in 4.19 after the addition
of cpufreq support, adding a set of explicit operating points
fixes this."
* tag 'armsoc-fixes-4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
soc: fsl: qman_portals: defer probe after qman's probe
soc: fsl: qbman: add APIs to retrieve the probing status
ARM: dts: imx53-qsb: disable 1.2GHz OPP
It doesn't make sense for a perf event to be configured as a CHAIN event
in isolation, so extend the arm_pmu structure with a ->filter_match()
function to allow the backend PMU implementation to reject CHAIN events
early.
Cc: <stable@vger.kernel.org>
Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com>
We describe ranges of 'reserved' memory to userspace via /proc/iomem.
Commit 50d7ba36b916 ("arm64: export memblock_reserve()d regions via
/proc/iomem") updated the logic to export regions that were reserved
because their contents should be preserved. This allowed kexec-tools
to tell the difference between 'reserved' memory that must be
preserved and not overwritten, (e.g. the ACPI tables), and 'nomap'
memory that must not be touched without knowing the memory-attributes
(e.g. RAS CPER regions).
The above commit wrongly assumed that memblock_reserve() would not
be used to reserve regions that aren't memory. It turns out this is
exactly what early_init_dt_reserve_memory_arch() will do if it finds
a DT reserved-memory that was also carved out of the memory node, which
results in a WARN_ON_ONCE() and the region being reserved instead of
ignored. The ramoops description on hikey and dragonboard-410c both do
this, so we can't simply write this configuration off as "buggy firmware".
Avoid this issue by rewriting reserve_memblock_reserved_regions() so
that only the portions of reserved regions which overlap with mapped
memory are actually reserved.
Fixes: 50d7ba36b916 ("arm64: export memblock_reserve()d regions via /proc/iomem")
Reported-by: John Stultz <john.stultz@linaro.org>
Reported-by: Paolo Pisati <p.pisati@gmail.com>
CC: Akashi Takahiro <takahiro.akashi@linaro.org>
CC: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Reviewed-by: James Morse <james.morse@arm.com>
Enabling CONFIG_GCOV_PROFILE_ALL=y causes linker errors on ARM:
`.text.exit' referenced in section `.ARM.exidx.text.exit':
defined in discarded section `.text.exit'
`.text.exit' referenced in section `.fini_array.00100':
And related errors on NDS32:
`.text.exit' referenced in section `.dtors.65435':
The gcov compiler flags cause certain compiler versions to generate
additional destructor-related sections that are not yet handled by the
linker script, resulting in references between discarded and
non-discarded sections.
Since destructors are not used in the Linux kernel, fix this by
discarding these additional sections.
Tested-by: Arnd Bergmann <arnd@arndb.de>
Reported-by: Greentime Hu <green.hu@gmail.com>
Tested-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Peter Oberparleiter <oberpar@linux.ibm.com>
Ingo writes:
"x86 fixes
An intel_rdt memory access fix and a VLA fix in pgd_alloc()."
x86/mm: Avoid VLA in pgd_alloc()
x86/intel_rdt: Fix out-of-bounds memory access in CBM tests
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Martin writes:
"s390 fixes for 4.19-rc8
Four more patches for 4.19:
- Fix resume after suspend-to-disk if resume-CPU != suspend-CPU
- Fix vfio-ccw check for pinned pages
- Two patches to avoid a usercopy-whitelist warning in vfio-ccw"
* tag 's390-4.19-4' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/cio: Fix how vfio-ccw checks pinned pages
s390/cio: Refactor alloc of ccw_io_region
s390/cio: Convert ccw_io_region to pointer
s390/hibernate: fix error handling when suspend cpu != resume cpu
git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux
Paul writes:
"A few MIPS fixes for 4.19:
- Avoid suboptimal placement of our VDSO when using the legacy mmap
layout, which can prevent statically linked programs that were able
to allocate large amounts of memory using the brk syscall prior to
the introduction of our VDSO from functioning correctly.
- Fix up CONFIG_CMDLINE handling for platforms which ought to ignore
DT arguments but have incorrectly used them & lost other arguments
since v3.16.
- Fix a path in MAINTAINERS to use valid wildcards.
- Fixup a regression from v4.17 in memset() for systems using
CPU_DADDI_WORKAROUNDS."
* tag 'mips_fixes_4.19_2' of git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux:
MIPS: memset: Fix CPU_DADDI_WORKAROUNDS `small_fixup' regression
MAINTAINERS: MIPS/LOONGSON2 ARCHITECTURE - Use the normal wildcard style
MIPS: Fix CONFIG_CMDLINE handling
MIPS: VDSO: Always map near top of user memory
Currently _PAGE_DEVMAP bit is not preserved in mprotect(2) calls. As a
result we will see warnings such as:
BUG: Bad page map in process JobWrk0013 pte:800001803875ea25 pmd:7624381067
addr:00007f0930720000 vm_flags:280000f9 anon_vma: (null) mapping:ffff97f2384056f0 index:0
file:457-000000fe00000030-00000009-000000ca-00000001_2001.fileblock fault:xfs_filemap_fault [xfs] mmap:xfs_file_mmap [xfs] readpage: (null)
CPU: 3 PID: 15848 Comm: JobWrk0013 Tainted: G W 4.12.14-2.g7573215-default #1 SLE12-SP4 (unreleased)
Hardware name: Intel Corporation S2600WFD/S2600WFD, BIOS SE5C620.86B.01.00.0833.051120182255 05/11/2018
Call Trace:
dump_stack+0x5a/0x75
print_bad_pte+0x217/0x2c0
? enqueue_task_fair+0x76/0x9f0
_vm_normal_page+0xe5/0x100
zap_pte_range+0x148/0x740
unmap_page_range+0x39a/0x4b0
unmap_vmas+0x42/0x90
unmap_region+0x99/0xf0
? vma_gap_callbacks_rotate+0x1a/0x20
do_munmap+0x255/0x3a0
vm_munmap+0x54/0x80
SyS_munmap+0x1d/0x30
do_syscall_64+0x74/0x150
entry_SYSCALL_64_after_hwframe+0x3d/0xa2
when mprotect(2) gets used on DAX mappings. Also there is a wide variety
of other failures that can result from the missing _PAGE_DEVMAP flag
when the area gets used by get_user_pages() later.
Fix the problem by including _PAGE_DEVMAP in a set of flags that get
preserved by mprotect(2).
Fixes: 69660fd797c3 ("x86, mm: introduce _PAGE_DEVMAP")
Fixes: ebd31197931d ("powerpc/mm: Add devmap support for ppc64")
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-master
KVM/arm fixes for 4.19, take #2
- Correctly order GICv3 SGI registers in the cp15 array
SEV requires access to the AMD cryptographic device APIs, and this
does not work when KVM is builtin and the crypto driver is a module.
Actually the Kconfig conditions for CONFIG_KVM_AMD_SEV try to disable
SEV in that case, but it does not work because the actual crypto
calls are not culled, only sev_hardware_setup() is.
This patch adds two CONFIG_KVM_AMD_SEV checks that gate all the remaining
SEV code; it fixes this particular configuration, and drops 5 KiB of
code when CONFIG_KVM_AMD_SEV=n.
The ICC_ASGI1R and ICC_SGI0R register entries in the cp15 array
are not correctly ordered, leading to a BUG() at boot time.
Move them to their natural location.
Fixes: 3e8a8a50c7ef ("KVM: arm: vgic-v3: Add support for ICC_SGI0R and ICC_ASGI1R accesses")
Reported-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Florian Fainelli <f.fainelli@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc
Vineet writes:
"ARC updates for 4.19-rc8
- Fix clone syscall to update Thread pointer register
- Make/build updates (needed for AGL/OE builds) [Alexey]
- Typo fix [Colin Ian King]"
* tag 'arc-4.19-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc:
ARC: clone syscall to setp r25 as thread pointer
ARC: build: Don't set CROSS_COMPILE in arch's Makefile
ARC: fix spelling mistake "entires" -> "entries"
ARC: build: Get rid of toolchain check
ARCv2: build: use mcpu=hs38 iso generic mcpu=archs
Arnd Bergmann reported that turning on -Wvla found a new (unintended) VLA usage:
arch/x86/mm/pgtable.c: In function 'pgd_alloc':
include/linux/build_bug.h:29:45: error: ISO C90 forbids variable length array 'u_pmds' [-Werror=vla]
arch/x86/mm/pgtable.c:190:34: note: in expansion of macro 'static_cpu_has'
#define PREALLOCATED_USER_PMDS (static_cpu_has(X86_FEATURE_PTI) ? \
arch/x86/mm/pgtable.c:431:16: note: in expansion of macro 'PREALLOCATED_USER_PMDS'
pmd_t *u_pmds[PREALLOCATED_USER_PMDS];
Use the actual size of the array that is used for X86_FEATURE_PTI,
which is known at build time, instead of the variable size.
[ mingo: Squashed original fix with followup fix to avoid bisection breakage, wrote new changelog. ]
Original-written-by: Arnd Bergmann <arnd@arndb.de>
Reported-by: Borislav Petkov <bp@alien8.de>
Cc: Joerg Roedel <jroedel@suse.de>
Cc: Toshi Kani <toshi.kani@hpe.com>
Fixes: 1be3f247c288 ("x86/mm: Avoid VLA in pgd_alloc()")
Link: http://lkml.kernel.org/r/20181008235434.GA35035@beast
While the DOC at the beginning of lib/bitmap.c explicitly states that
"The number of valid bits in a given bitmap does _not_ need to be an
exact multiple of BITS_PER_LONG.", some of the bitmap operations do
indeed access BITS_PER_LONG portions of the provided bitmap no matter
the size of the provided bitmap. For example, if bitmap_intersects()
is provided with an 8 bit bitmap the operation will access
BITS_PER_LONG bits from the provided bitmap. While the operation
ensures that these extra bits do not affect the result, the memory
is still accessed.
The capacity bitmasks (CBMs) are typically stored in u32 since they
can never exceed 32 bits. A few instances exist where a bitmap_*
operation is performed on a CBM by simply pointing the bitmap operation
to the stored u32 value.
The consequence of this pattern is that some bitmap_* operations will
access out-of-bounds memory when interacting with the provided CBM. This
is confirmed with a KASAN test that reports:
BUG: KASAN: stack-out-of-bounds in __bitmap_intersects+0xa2/0x100
and
BUG: KASAN: stack-out-of-bounds in __bitmap_weight+0x58/0x90
Fix this by moving any CBM provided to a bitmap operation needing
BITS_PER_LONG to an 'unsigned long' variable.
[ tglx: Changed related function arguments to unsigned long and got rid
of the _cbm extra step ]
Fixes: 72d505056604 ("x86/intel_rdt: Add utilities to test pseudo-locked region possibility")
Fixes: 49f7b4efa110 ("x86/intel_rdt: Enable setting of exclusive mode")
Fixes: d9b48c86eb38 ("x86/intel_rdt: Display resource groups' allocations' size in bytes")
Fixes: 95f0b77efa57 ("x86/intel_rdt: Initialize new resource group with sane defaults")
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
Cc: fenghua.yu@intel.com
Cc: tony.luck@intel.com
Cc: gavin.hindman@intel.com
Cc: jithu.joseph@intel.com
Cc: dave.hansen@intel.com
Cc: hpa@zytor.com
Link: https://lkml.kernel.org/r/69a428613a53f10e80594679ac726246020ff94f.1538686926.git.reinette.chatre@intel.com
David writes:
"Sparc fixes:
1) Minor fallthru comment tweaks from Gustavo A. R. Silva.
2) VLA removal from Kees Cook.
3) Make sparc vdso Makefile match x86, from Masahiro Yamada.
4) Fix clock divider programming in mach64 driver, from Mikulas
Patocka."
sparc64: fix fall-through annotation
sparc32: fix fall-through annotation
sparc: vdso: clean-up vdso Makefile
oradax: remove redundant null check before kfree
sparc64: viohs: Remove VLA usage
sbus: Use of_get_child_by_name helper
mach64: detect the dot clock divider correctly on sparc
Replace "fallthru" with a proper "fall through" annotation.
This fix is part of the ongoing efforts to enabling
-Wimplicit-fallthrough
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
arch/sparc/vdso/Makefile is a replica of arch/x86/entry/vdso/Makefile.
Clean-up the Makefile in the same way as I did for x86:
- Remove unnecessary export
- Put the generated linker script to $(obj)/ instead of $(src)/
- Simplify cmd_vdso2c
The corresponding x86 commits are:
- 61615faf0a89 ("x86/build/vdso: Remove unnecessary export in Makefile")
- 1742ed2088cc ("x86/build/vdso: Put generated linker scripts to $(obj)/")
- c5fcdbf15523 ("x86/build/vdso: Simplify 'cmd_vdso2c'")
In the quest to remove all stack VLA usage from the kernel[1], this
allocates a fixed size array for the maximum number of cookies and
adds a runtime sanity check.
[1] https://lkml.kernel.org/r/CA+55aFzCG-zNmZwX4A2FQpadafLfEzK6CC=qPXydAacU1
RqZWA@mail.gmail.com
In preparation to remove the node name pointer from struct device_node,
convert printf users to use the %pOFn format specifier.
Cc: sparclinux@vger.kernel.org
Signed-off-by: Rob Herring <robh@kernel.org>
https://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Michael writes:
"powerpc fixes for 4.19 #4
Four regression fixes.
A fix for a change to lib/xz which broke our zImage loader when
building with XZ compression. OK'ed by Herbert who merged the
original patch.
The recent fix we did to avoid patching __init text broke some 32-bit
machines, fix that.
Our show_user_instructions() could be tricked into printing kernel
memory, add a check to avoid that.
And a fix for a change to our NUMA initialisation logic, which causes
crashes in some kdump configurations.
Thanks to:
Christophe Leroy, Hari Bathini, Jann Horn, Joel Stanley, Meelis
Roos, Murilo Opsfelder Araujo, Srikar Dronamraju."
* tag 'powerpc-4.19-4' of https://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux:
powerpc/numa: Skip onlining a offline node in kdump path
powerpc: Don't print kernel instructions in show_user_instructions()
powerpc/lib: fix book3s/32 boot failure due to code patching
lib/xz: Put CRC32_POLY_LE in xz_private.h
Ingo writes:
"perf fixes:
- fix a CPU#0 hot unplug bug and a PCI enumeration bug in the x86 Intel uncore PMU driver
- fix a CPU event enumeration bug in the x86 AMD PMU driver
- fix a perf ring-buffer corruption bug when using tracepoints
- fix a PMU unregister locking bug"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/amd/uncore: Set ThreadMask and SliceMask for L3 Cache perf events
perf/x86/intel/uncore: Fix PCI BDF address of M3UPI on SKX
perf/ring_buffer: Prevent concurent ring buffer access
perf/x86/intel/uncore: Use boot_cpu_data.phys_proc_id instead of hardcorded physical package ID 0
perf/core: Fix perf_pmu_unregister() locking
Ingo writes:
"x86 fixes:
Misc fixes:
- fix various vDSO bugs: asm constraints and retpolines
- add vDSO test units to make sure they never re-appear
- fix UV platform TSC initialization bug
- fix build warning on Clang"
x86/vdso: Fix vDSO syscall fallback asm constraint regression
x86/cpu/amd: Remove unnecessary parentheses
x86/vdso: Only enable vDSO retpolines when enabled and supported
x86/tsc: Fix UV TSC initialization
x86/platform/uv: Provide is_early_uv_system()
selftests/x86: Add clock_gettime() tests to test_vdso
x86/vdso: Fix asm constraints on vDSO syscall fallbacks
Per ARC TLS ABI, r25 is designated TP (thread pointer register).
However so far kernel didn't do any special treatment, like setting up
usermode r25, even for CLONE_SETTLS. We instead relied on libc runtime
to do this, in say clone libc wrapper [1]. This was deliberate to keep
kernel ABI agnostic (userspace could potentially change TP, specially
for different ARC ISA say ARCompact vs. ARCv2 with different spare
registers etc)
However userspace setting up r25, after clone syscall opens a race, if
child is not scheduled and gets a signal instead. It starts off in
userspace not in clone but in a signal handler and anything TP sepcific
there such as pthread_self() fails which showed up with uClibc
testsuite nptl/tst-kill6 [2]
Fix this by having kernel populate r25 to TP value. So this locks in
ABI, but it was not going to change anyways, and fwiw is same for both
ARCompact (arc700 core) and ARCvs (HS3x cores)
[1] https://cgit.uclibc-ng.org/cgi/cgit/uclibc-ng.git/tree/libc/sysdeps/linux/arc/clone.S
[2] https://github.com/wbx-github/uclibc-ng-test/blob/master/test/nptl/tst-kill6.c
Fixes: ARC STAR 9001378481
Reported-by: Nikita Sobolev <sobolev@synopsys.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
