commit b4ff8389ed14b849354b59ce9b360bdefcdbf99c upstream.
After commit 8c058b0b9c34 ("x86/irq: Probe for PIC presence before
allocating descs for legacy IRQs") early_irq_init() will no longer
preallocate descriptors for legacy interrupts if PIC does not
exist, which is the case for Xen PV guests.
Therefore we may need to allocate those descriptors ourselves.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
commit 5967c17b118a2bd1dd1d554cc4eee16233e52bec upstream.
We should never allow to enable/disable any facilities for the guest
when other VCPUs were already created.
kvm_arch_vcpu_(load|put) relies on SIMD not changing during runtime.
If somebody would create and run VCPUs and then decides to enable
SIMD, undefined behaviour could be possible (e.g. vector save area
not being set up).
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit b85de33a1a3433487b6a721cfdce25ec8673e622 upstream.
Commit 383d0b050106 ("KVM: s390: handle pending local interrupts via
bitmap") introduced a possible memory overwrite from user space.
User space could pass an invalid emergency signal code (sending VCPU)
and therefore exceed the bitmap. Let's take care of this case and
check that the id is in the valid range.
Reviewed-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
commit 152e9f65d66f0a3891efc3869440becc0e7ff53f upstream.
For now, VCPUs were always created sequentially with incrementing
VCPU ids. Therefore, the index in the VCPUs array matched the id.
As sequential creation might change with cpu hotplug, let's use
the correct lookup function to find a VCPU by id, not array index.
Let's also use kvm_lookup_vcpu() for validation of the sending VCPU
on external call injection.
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit c5c2c393468576bad6d10b2b5fefff8cd25df3f4 upstream.
We seemed to have missed a few corner cases in commit f6c137ff00a4
("KVM: s390: randomize sca address").
The SCA has a maximum size of 2112 bytes. By setting the sca_offset to
some unlucky numbers, we exceed the page.
0x7c0 (1984) -> Fits exactly
0x7d0 (2000) -> 16 bytes out
0x7e0 (2016) -> 32 bytes out
0x7f0 (2032) -> 48 bytes out
One VCPU entry is 32 bytes long.
For the last two cases, we actually write data to the other page.
1. The address of the VCPU.
2. Injection/delivery/clearing of SIGP externall calls via SIGP IF.
Especially the 2. happens regularly. So this could produce two problems:
1. The guest losing/getting external calls.
2. Random memory overwrites in the host.
So this problem happens on every 127 + 128 created VM with 64 VCPUs.
commit 7cc8944e13c73374b6f33b39ca24c0891c87b077 upstream.
zpci_err_insn writes stale stack content to the debugfs.
Ensure that the struct in zpci_err_insn is ordered in a way that
we don't have uninitialized holes in it. In addition to that
add the packed attribute.
Fixes: 3d8258e (s390/pci: move debug messages to debugfs)
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
commit 55a423b6f105fa323168f15f4bb67f23b21da44e upstream.
git commit 155e839a814834a3b4b31e729f4716e59d3d2dd4
"s390/kernel: dynamically allocate FP register save area"
introduced a regression in regard to ptrace.
If the vector register extension is not present or unused the
ptrace peek of a floating pointer register return incorrect data
and the ptrace poke to a floating pointer register overwrites the
task structure starting at task->thread.fpu.fprs.
commit cb083816ab5ac3d10a9417527f07fc5962cc3808 upstream.
A kernel built with DEBUG_RO_DATA && !CONFIG_DEBUG_ALIGN_RODATA doesn't
have .text aligned to a page boundary, though fixup_executable works at
page-granularity thanks to its use of create_mapping. If .text is not
page-aligned, the first page it exists in may be marked non-executable,
leading to failures when an attempt is made to execute code in said
page.
This patch upgrades ALIGN_DEBUG_RO and ALIGN_DEBUG_RO_MIN to force page
alignment for DEBUG_RO_DATA && !CONFIG_DEBUG_ALIGN_RODATA kernels,
ensuring that all sections with specific RWX permission requirements are
mapped with the correct permissions.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Reported-by: Jeremy Linton <jeremy.linton@arm.com>
Reviewed-by: Laura Abbott <laura@labbott.name>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Suzuki Poulose <suzuki.poulose@arm.com>
Fixes: da141706aea52c1a ("arm64: add better page protections to arm64")
commit 5accd17d0eb523350c9ef754d655e379c9bb93b3 upstream.
For reasons not entirely apparent, but now enshrined in history, the
architectural mapping of AArch32 banked registers to AArch64 registers
actually orders SP_<mode> and LR_<mode> backwards compared to the
intuitive r13/r14 order, for all modes except FIQ.
Fix the compat_<reg>_<mode> macros accordingly, in the hope of avoiding
subtle bugs with KVM and AArch32 guests.
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
commit f3119b830264d89d216bfb378ab65065dffa02d9 upstream.
I received a bug report that running 32-bit MPX binaries on
64-bit kernels was broken. I traced it down to this little code
snippet. We were switching our "number of bounds directory
entries" calculation correctly. But, we didn't switch the other
side of the calculation: the virtual space size.
This meant that we were calculating an absurd size for
bd_entry_virt_space() on 32-bit because we used the 64-bit
virt_space.
This was _also_ broken for 32-bit kernels running on 64-bit
hardware since boot_cpu_data.x86_virt_bits=48 even when running
in 32-bit mode.
Correct that and properly handle all 3 possible cases:
1. 32-bit binary on 64-bit kernel
2. 64-bit binary on 64-bit kernel
3. 32-bit binary on 32-bit kernel
This manifested in having bounds tables not properly unmapped.
It "leaked" memory but had no functional impact otherwise.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dave Hansen <dave@sr71.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/20151111181934.FA7FAC34@viggo.jf.intel.com
commit 46561c3959d6307d22139c24cd0bf196162e5681 upstream.
When you call get_user(foo, bar), you effectively do a
copy_from_user(&foo, bar, sizeof(*bar));
Note that the sizeof() is implicit.
When we reach out to userspace to try to zap an entire "bounds
table" we need to go read a "bounds directory entry" in order to
locate the table's address. The size of a "directory entry"
depends on the binary being run and is always the size of a
pointer.
But, when we have a 64-bit kernel and a 32-bit application, the
directory entry is still only 32-bits long, but we fetch it with
a 64-bit pointer which makes get_user() does a 64-bit fetch.
Reading 4 extra bytes isn't harmful, unless we are at the end of
and run off the table. It might also cause the zero page to get
faulted in unnecessarily even if you are not at the end.
Fix it up by doing a special 32-bit get_user() via a cast when
we have 32-bit userspace.
Link: http://lkml.kernel.org/r/20151111181931.3ACF6822@viggo.jf.intel.com
commit ab6b52947545a5355154f64f449f97af9d05845f upstream.
(This should have gone to LKML originally. Sorry for the extra
noise, folks on the cc.)
Background:
Signal frames on x86 have two formats:
1. For 32-bit executables (whether on a real 32-bit kernel or
under 32-bit emulation on a 64-bit kernel) we have a
'fpregset_t' that includes the "FSAVE" registers.
2. For 64-bit executables (on 64-bit kernels obviously), the
'fpregset_t' is smaller and does not contain the "FSAVE"
state.
When creating the signal frame, we have to be aware of whether
we are running a 32 or 64-bit executable so we create the
correct format signal frame.
Problem:
save_xstate_epilog() uses 'fx_sw_reserved_ia32' whenever it is
called for a 32-bit executable. This is for real 32-bit and
ia32 emulation.
But, fpu__init_prepare_fx_sw_frame() only initializes
'fx_sw_reserved_ia32' when emulation is enabled, *NOT* for real
32-bit kernels.
This leads to really wierd situations where 32-bit programs
lose their extended state when returning from a signal handler.
The kernel copies the uninitialized (zero) 'fx_sw_reserved_ia32'
out to userspace in save_xstate_epilog(). But when returning
from the signal, the kernel errors out in check_for_xstate()
when it does not see FP_XSTATE_MAGIC1 present (because it was
zeroed). This leads to the FPU/XSAVE state being initialized.
For MPX, this leads to the most permissive state and means we
silently lose bounds violations. I think this would also mean
that we could lose *ANY* FPU/SSE/AVX state. I'm not sure why
no one has spotted this bug.
I believe this was broken by:
72a671ced66d ("x86, fpu: Unify signal handling code paths for x86 and x86_64 kernels")
way back in 2012.
Cc: dave@sr71.net
Cc: fenghua.yu@intel.com
Cc: yu-cheng.yu@intel.com
Link: http://lkml.kernel.org/r/20151111002354.A0799571@viggo.jf.intel.com
commit a05917b6ba9dc9a95fc42bdcbe3a875e8ad83935 upstream.
KVM uses the get_xsave_addr() function in a different fashion from
the native kernel, in that the 'xsave' parameter belongs to guest vcpu,
not the currently running task.
But 'xsave' is replaced with current task's (host) xsave structure, so
get_xsave_addr() will incorrectly return the bad xsave address to KVM.
Fix it so that the passed in 'xsave' address is used - as intended
originally.
Signed-off-by: Huaitong Han <huaitong.han@intel.com>
Reviewed-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Cc: dave.hansen@intel.com
Link: http://lkml.kernel.org/r/1446800423-21622-1-git-send-email-huaitong.han@intel.com
[ Tidied up the changelog. ]
commit 581b7f158fe0383b492acd1ce3fb4e99d4e57808 upstream.
There appears to be no formal statement of what pv_irq_ops.save_fl() is
supposed to return precisely. Native returns the full flags, while lguest and
Xen only return the Interrupt Flag, and both have comments by the
implementations stating that only the Interrupt Flag is looked at. This may
have been true when initially implemented, but no longer is.
To make matters worse, the Xen PVOP leaves the upper bits undefined, making
the BUG_ON() undefined behaviour. Experimentally, this now trips for 32bit PV
guests on Broadwell hardware. The BUG_ON() is consistent for an individual
build, but not consistent for all builds. It has also been a sitting timebomb
since SMAP support was introduced.
Use native_save_fl() instead, which will obtain an accurate view of the AC
flag.
Signed-off-by: Andrew Cooper <andrew.cooper3@citrix.com>
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Tested-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: <lguest@lists.ozlabs.org>
Cc: Xen-devel <xen-devel@lists.xen.org>
Link: http://lkml.kernel.org/r/1433323874-6927-1-git-send-email-andrew.cooper3@citrix.com
commit 04633df0c43d710e5f696b06539c100898678235 upstream.
When we get loaded by a 64-bit bootloader, kernel entry point is
startup_64 in head_64.S. We don't trust any and all bootloaders because
some will fiddle with CPU configuration so we go ahead and massage each
CPU into sanity again.
For example, some dell BIOSes have this XD disable feature which set
IA32_MISC_ENABLE[34] and disable NX. This might be some dumb workaround
for other OSes but Linux sure doesn't need it.
A similar thing is present in the Surface 3 firmware - see
https://bugzilla.kernel.org/show_bug.cgi?id=106051 - which sets this bit
only on the BSP:
# rdmsr -a 0x1a0
400850089
850089
850089
850089
I know, right?!
There's not even an off switch in there.
So fix all those cases by sanitizing the 64-bit entry point too. For
that, make verify_cpu() callable in 64-bit mode also.
Requested-and-debugged-by: "H. Peter Anvin" <hpa@zytor.com>
Reported-and-tested-by: Bastien Nocera <bugzilla@hadess.net>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Link: http://lkml.kernel.org/r/1446739076-21303-1-git-send-email-bp@alien8.de
commit 8c058b0b9c34d8c8d7912880956543769323e2d8 upstream.
Commit d32932d02e18 ("x86/irq: Convert IOAPIC to use hierarchical irqdomain
interfaces") brought a regression for Hyper-V Gen2 instances. These
instances don't have i8259 legacy PIC but they use legacy IRQs for serial
port, rtc, and acpi. With this commit included we end up with these IRQs
not initialized. Earlier, there was a special workaround for legacy IRQs
in mp_map_pin_to_irq() doing mp_irqdomain_map() without looking at
nr_legacy_irqs() and now we fail in __irq_domain_alloc_irqs() when
irq_domain_alloc_descs() returns -EEXIST.
The essence of the issue seems to be that early_irq_init() calls
arch_probe_nr_irqs() to figure out the number of legacy IRQs before
we probe for i8259 and gets 16. Later when init_8259A() is called we switch
to NULL legacy PIC and nr_legacy_irqs() starts to return 0 but we already
have 16 descs allocated.
Solve the issue by separating i8259 probe from init and calling it in
arch_probe_nr_irqs() before we actually use nr_legacy_irqs() information.
Fixes: d32932d02e18 ("x86/irq: Convert IOAPIC to use hierarchical irqdomain interfaces")
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Cc: K. Y. Srinivasan <kys@microsoft.com>
Link: http://lkml.kernel.org/r/1446543614-3621-1-git-send-email-vkuznets@redhat.com
commit 68accac392d859d24adcf1be3a90e41f978bd54c upstream.
The commit f5f3497cad8c extended the low identity mapping. However, if
the kernel uses more than 2 GB (VMSPLIT_2G_OPT or VMSPLIT_1G memory
split), the normal memory mapping is overwritten by the low identity
mapping causing a crash. To avoid overwritting, limit the low identity
map to cover only memory before kernel range (PAGE_OFFSET).
Fixes: f5f3497cad8c "x86/setup: Extend low identity map to cover whole kernel range
Signed-off-by: Krzysztof Mazur <krzysiek@podlesie.net>
Cc: Laszlo Ersek <lersek@redhat.com>
Cc: Matt Fleming <matt.fleming@intel.com>
Link: http://lkml.kernel.org/r/1446815916-22105-1-git-send-email-krzysiek@podlesie.net
commit 54a20552e1eae07aa240fa370a0293e006b5faed upstream.
It was found that a guest can DoS a host by triggering an infinite
stream of "alignment check" (#AC) exceptions. This causes the
microcode to enter an infinite loop where the core never receives
another interrupt. The host kernel panics pretty quickly due to the
effects (CVE-2015-5307).
Signed-off-by: Eric Northup <digitaleric@google.com>
commit 879ae1880449c88db11c1ebdaedc2da79b2fe73f upstream.
Commit b18d5431acc7 ("KVM: x86: fix CR0.CD virtualization") was
technically correct, but it broke OVMF guests by slowing down various
parts of the firmware.
Commit fb279950ba02 ("KVM: vmx: obey KVM_QUIRK_CD_NW_CLEARED") quirked the
first function modified by b18d5431acc7, vmx_get_mt_mask(), for OVMF's
sake. This restored the speed of the OVMF code that runs before
PlatformPei (including the memory intensive LZMA decompression in SEC).
This patch extends the quirk to the second function modified by
b18d5431acc7, kvm_set_cr0(). It eliminates the intrusive slowdown that
hits the EFI_MP_SERVICES_PROTOCOL implementation of edk2's
UefiCpuPkg/CpuDxe -- which is built into OVMF --, when CpuDxe starts up
all APs at once for initialization, in order to count them.
We also carry over the kvm_arch_has_noncoherent_dma() sub-condition from
the other half of the original commit b18d5431acc7.
Fixes: b18d5431acc7a2fd22767925f3a6f597aa4bd29e
Cc: Jordan Justen <jordan.l.justen@intel.com>
Cc: Alex Williamson <alex.williamson@redhat.com>
Reviewed-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
Tested-by: Janusz Mocek <januszmk6@gmail.com>
Signed-off-by: Laszlo Ersek <lersek@redhat.com>#
commit 89651a3decbe03754f304a0b248f27eeb9a37937 upstream.
The SDM says that exiting system management mode from 64-bit mode
is invalid, but that would be too good to be true. But actually,
most of the code is already there to support exiting from compat
mode (EFER.LME=1, EFER.LMA=0). Getting all the way from 64-bit
mode to real mode only requires clearing CS.L and CR4.PCIDE.
Fixes: 660a5d517aaab9187f93854425c4c63f4a09195c
Tested-by: Laszlo Ersek <lersek@redhat.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
commit f40606b147dd5b4678cedc877a71deb520ca507e upstream.
GET_SMSTATE depends on real mode to ensure that smbase+offset is treated
as a physical address, which has already caused a bug after shuffling
the code. Enforce physical addressing.
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Reported-by: Laszlo Ersek <lersek@redhat.com>
commit 7a036a6f670f63b32c5ee126425f9109271ca13f upstream.
We want to read the physical memory when emulating RSM.
X86EMUL_IO_NEEDED is returned on all errors for consistency with other
helpers.
commit 5690891bcec5fcfda38da974ffa5488e36a59811 upstream.
Not zeroing EFER means that a 32-bit firmware cannot enter paging mode
without clearing EFER.LME first (which it should not know about).
Yang Zhang from Intel confirmed that the manual is wrong and EFER is
cleared to zero on INIT.
Fixes: d28bc9dd25ce023270d2e039e7c98d38ecbf7758
Cc: Yang Z Zhang <yang.z.zhang@intel.com>
commit c77f3fab441c3e466b4c3601a475fc31ce156b06 upstream.
After moving PIR to IRR, the interrupt needs to be delivered manually.
Reported-by: Paolo Bonzini <pbonzini@redhat.com>
commit 585bb8f9a5e592f2ce7abbe5ed3112d5438d2754 upstream.
If either of the memory allocations in kvm_arch_vcpu_create() fail, the
vcpu which has been allocated and kvm_vcpu_init'd doesn't get uninit'd
in the error handling path. Add a call to kvm_vcpu_uninit() to fix this.
Fixes: 669e846e6c4e ("KVM/MIPS32: MIPS arch specific APIs for KVM")
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: linux-mips@linux-mips.org
Cc: kvm@vger.kernel.org
commit c5c2a3b998f1ff5a586f9d37e154070b8d550d17 upstream.
The immediate field of the CACHE instruction is signed, so ensure that
it gets sign extended by casting it to an int16_t rather than just
masking the low 16 bits.
Fixes: e685c689f3a8 ("KVM/MIPS32: Privileged instruction/target branch emulation.")
commit 002374f371bd02df864cce1fe85d90dc5b292837 upstream.
ASID restoration on guest resume should determine the guest execution
mode based on the guest Status register rather than bit 30 of the guest
PC.
Fix the two places in locore.S that do this, loading the guest status
from the cop0 area. Note, this assembly is specific to the trap &
emulate implementation of KVM, so it doesn't need to check the
supervisor bit as that mode is not implemented in the guest.
Fixes: b680f70fc111 ("KVM/MIPS32: Entry point for trampolining to...")
commit 5011a7e808c9fec643d752c5a495a48f27268a48 upstream.
The DDR control initialization needs to know the SoC type, however
ath79_detect_sys_type() was called after ath79_ddr_ctrl_init().
Reverse the order to fix the DDR control initialization on ar71xx and
ar934x.
Signed-off-by: Alban Bedel <albeu@free.fr>
Cc: Felix Fietkau <nbd@openwrt.org>
Cc: Qais Yousef <qais.yousef@imgtec.com>
Cc: Andrew Bresticker <abrestic@chromium.org>
Patchwork: https://patchwork.linux-mips.org/patch/11500/
commit 1b4a5ddb127caf125e14551ebd334be1acf21805 upstream.
Add helper macro builtin_mips_cdmm_driver() for builtin CDMM drivers
that don't do anything special in init and have no exit. The
module_mips_cdmm_driver() helper isn't really appropriate for drivers
that can't be built as a module.
Cc: Jiri Slaby <jslaby@suse.com>
Patchwork: http://patchwork.linux-mips.org/patch/11264/
commit 4e7d30dba493b60a80e9b590add1b4402265cc83 upstream.
This adds a basic implementation of clk_round_rate()
The clk_round_rate() function is called by multiple drivers and
subsystems now and the lantiq clk driver is supposed to export this,
but doesn't do so, this causes linking problems like this one:
ERROR: "clk_round_rate" [drivers/media/v4l2-core/videodev.ko] undefined!
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Acked-by: John Crispin <blogic@openwrt.org>
Patchwork: https://patchwork.linux-mips.org/patch/11358/
commit 54c09889bff6d99c8733eed4a26c9391b177c88b upstream.
The z2 machine calls pxa27x_set_pwrmode() in order to power off
the machine, but this function gets discarded early at boot because
it is marked __init, as pointed out by kbuild:
WARNING: vmlinux.o(.text+0x145c4): Section mismatch in reference from the function z2_power_off() to the function .init.text:pxa27x_set_pwrmode()
The function z2_power_off() references
the function __init pxa27x_set_pwrmode().
This is often because z2_power_off lacks a __init
annotation or the annotation of pxa27x_set_pwrmode is wrong.
This removes the __init section modifier to fix rebooting and the
build error.
Fixes: ba4a90a6d86a ("ARM: pxa/z2: fix building error of pxa27x_cpu_suspend() no longer available")
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit 976d84fce6aa1e5bf92b8d06d69014ac45fd5fad upstream.
The VDD-CPU and VDD-GPU regulators were incorrectly swapped.
Fixes: bab03561224ba ("ARM: dts: sun6i: hummingbird: Add AXP221 regulator
nodes")
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
commit 0efc898a9bea7a2e8e583c6efab0e19dc7093078 upstream.
Commit 99f84cae43df ("ARM: dts: add wl12xx/wl18xx bindings") added
device tree bindings for the TI WLAN SDIO on many omap variants.
I recall wondering how come omap5-uevm did not have the WLAN
added and this issue has been bugging me for a while now, and
I finally tracked it down to a bad pinmux regression, and a missing
deferred probe handling for the 32k clock from palmas that's
requested by twl6040.
Basically 392adaf796b9 ("ARM: dts: omap5-evm: Add mcspi data")
added pin muxing for mcspi4 that conflicts with the onboard
WLAN. While some omap5-uevm don't have WLAN populated, the
pins are not reused for other devices. And as the SDIO bus
should be probed, let's try to enable WLAN by default.
Let's fix the regression and add the WLAN configuration as
done for the other boards in 99f84cae43df ("ARM: dts: add
wl12xx/wl18xx bindings"). And let's use the new MMC pwrseq for
the 32k clock as suggested by Javier Martinez Canillas
<javier@dowhile0.org>.
Note that without a related deferred probe fix for twl6040,
the 32k clock is not initialized if palmas-clk is a module
and twl6040 is built-in.
Let's also use the generic "non-removable" instead of the
legacy "ti,non-removable" property while at it.
And finally, note that omap5 seems to require WAKEUP_EN for
the WLAN GPIO interrupt.
Fixes: 392adaf796b9 ("ARM: dts: omap5-evm: Add mcspi data")
Cc: Sourav Poddar <sourav.poddar@ti.com>
exynos4412 boards
commit 4ae9a4c66cdcb8b5d4e4d904846f1b450dbcabb4 upstream.
Exynos USB2 PHY driver now supports VBUS regulator, so add it to all
boards which have it available. This also fixes commit
7eec1266751b ("ARM: dts: Add Maxim 77693 PMIC to exynos4412-trats2"),
which added new regulators to Trats2 board, but without linking them to
the consumers.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Fixes: 7eec1266751b ("ARM: dts: Add Maxim 77693 PMIC to exynos4412-trats2")
Signed-off-by: Kukjin Kim <kgene@kernel.org>
commit 5fcf8d1a0e84792b2bc44922c5d833dab96a9c1e upstream.
fncpy() requires that the source and the destination are both 8-byte
aligned.
Signed-off-by: Patrick Doyle <pdoyle@irobot.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Fixes: d94e688cae56 ("ARM: at91/pm: move the copying the sram function to the sram initialization phase")
commit d1a9c24ad16ab2b26f1574bc3f2c165a7beff5df upstream.
Correcting the dma declaration for i2c1 dma.
Signed-off-by: Holger Busse <h.busse@kathrein-sachsen.de>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Fixes: 4cc7cdf35c5f ("ARM: at91/dt: add i2c1 declaration to sama5d4")
commit e77b675f8786f38d40fc1562e1275875daf67fef upstream.
Commit 72daceb9a10a ("net: rfkill: gpio: Add default GPIO driver mappings
for ACPI") removed possibility to request GPIO by table index for non-ACPI
platforms without changing its users. As result "shutdown" GPIO request
will fail if request for "reset" GPIO succeeded or "reset" will be
requested instead of "shutdown" if "reset" wasn't defined. Fix it by
making gpiod_lookup_table use con_id's instead of indexes.
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Fixes: 72daceb (net: rfkill: gpio: Add default GPIO driver mappings for ACPI)
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
Reviewed-by: Marc Dietrich <marvin24@gmx.de>
Tested-by: Marc Dietrich <marvin24@gmx.de>
Signed-off-by: Thierry Reding <treding@nvidia.com>
commit facf47ee6b4d07d43c3bfd6f0762f1b28f64703a upstream.
For imx27, it needs three clocks to let the controller work,
the old code is wrong, and usbmisc has not included clock handling
code any more. Without this patch, it will cause below data
abort when accessing usbmisc registers.
usbcore: registered new interface driver usb-storage
Unhandled fault: external abort on non-linefetch (0x008) at 0xf4424600
pgd = c0004000
[f4424600] *pgd=10000452(bad)
Internal error: : 8 [#1] PREEMPT ARM
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 4.1.0-next-20150701-dirty #3089
Hardware name: Freescale i.MX27 (Device Tree Support)
task: c7832b60 ti: c783e000 task.ti: c783e000
PC is at usbmisc_imx27_init+0x4c/0xbc
LR is at usbmisc_imx27_init+0x40/0xbc
pc : [<c03cb5c0>] lr : [<c03cb5b4>] psr: 60000093
sp : c783fe08 ip : 00000000 fp : 00000000
r10: c0576434 r9 : 0000009c r8 : c7a773a0
r7 : 01000000 r6 : 60000013 r5 : c7a776f0 r4 : c7a773f0
r3 : f4424600 r2 : 00000000 r1 : 00000001 r0 : 00000001
Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 0005317f Table: a0004000 DAC: 00000017
Process swapper (pid: 1, stack limit = 0xc783e190)
Stack: (0xc783fe08 to 0xc7840000)
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Reported-by: Fabio Estevam <fabio.estevam@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
commit 696d8b70c09dd421c4d037fab04341e5b30585cf upstream.
In case when the interrupt happened for the second eDMA the channel
number was incorrectly passed to the client driver.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 7e31210349e9e03a9a4dff31ab5f2bc83e8e84f5 upstream.
IOMMU-based dma_mmap() implementation lacked proper support for offset
parameter used in mmap call (it always assumed that mapping starts from
offset zero). This patch adds support for offset parameter to IOMMU-based
implementation.
commit 371f0f085f629fc0f66695f572373ca4445a67ad upstream.
dma_mmap() function in IOMMU-based dma-mapping implementation lacked
a check for valid range of mmap parameters (offset and buffer size), what
might have caused access beyond the allocated buffer. This patch fixes
this issue.
commit 38850d786a799c3ff2de0dc1980902c3263698dc upstream.
Commit 8a603f91cc48 ("ARM: 8445/1: fix vdsomunge not to depend on
glibc specific byteswap.h") unfortunately introduced a bug created but
not found during discussion and patch simplification.
Reported-by: Efraim Yawitz <efraim.yawitz@gmail.com>
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
Fixes: 8a603f91cc48 ("ARM: 8445/1: fix vdsomunge not to depend on glibc specific byteswap.h")
Signed-off-by: Nathan Lynch <nathan_lynch@mentor.com>
Pull x86 fixes from Thomas Gleixner:
"This set of updates contains:
- Another bugfix for the pathologic vm86 machinery. Clear
thread.vm86 on fork to prevent corrupting the parent state. This
comes along with an update to the vm86 selftest case
- Fix another corner case in the ioapic setup code which causes a
boot crash on some oddball systems
- Fix the fallout from the dma allocation consolidation work, which
leads to a NULL pointer dereference when the allocation code is
called with a NULL device"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/vm86: Set thread.vm86 to NULL on fork/clone
selftests/x86: Add a fork() to entry_from_vm86 to catch fork bugs
x86/ioapic: Prevent NULL pointer dereference in setup_ioapic_dest()
x86/dma-mapping: Fix arch_dma_alloc_attrs() oops with NULL dev
Pull ARM SoC fixes from Olof Johansson:
"This should be our final batch of fixes for 4.3:
- A patch from Sudeep Holla that fixes annotation of wakeup sources
properly, old unused format seems to have spread through copying.
- Two patches from Tony for OMAP. One dealing with MUSB setup
problems due to runtime PM being enabled too early on the parent
device. The other fixes IRQ numbering for OMAP1"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
usb: musb: omap2430: Fix regression caused by driver core change
ARM: OMAP1: fix incorrect INT_DMA_LCD
ARM: dts: fix gpio-keys wakeup-source property
thread.vm86 points to per-task information -- the pointer should not
be copied on clone.
Fixes: d4ce0f26c790 ("x86/vm86: Move fields from 'struct kernel_vm86_struct' to 'struct vm86'")
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Stas Sergeev <stsp@list.ru>
Link: http://lkml.kernel.org/r/71c5d6985d70ec8197c8d72f003823c81b7dcf99.1446270067.git.luto@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes from Will Deacon:
"Apologies for this being so late, but we've uncovered a few nasty
issues on arm64 which didn't settle down until yesterday and the fixes
all look suitable for 4.3. Of the four patches, three of them are
Cc'd to stable, with the remaining patch fixing an issue that only
took effect during the merge window.
Summary:
- Fix corruption in SWP emulation when STXR fails due to contention
- Fix MMU re-initialisation when resuming from a low-power state
- Fix stack unwinding code to match what ftrace expects
- Fix relocation code in the EFI stub when DRAM base is not 2MB aligned"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64/efi: do not assume DRAM base is aligned to 2 MB
Revert "ARM64: unwind: Fix PC calculation"
arm64: kernel: fix tcr_el1.t0sz restore on systems with extended idmap
arm64: compat: fix stxr failure case in SWP emulation
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux
Pull ia64 kcmp syscall from Tony Luck:
"Missed adding the kcmp() syscall a long time ago. Now it seems that
it is essential to build systemd"
* tag 'please-pull-syscalls' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux:
[IA64] Wire up kcmp syscall
The current arm64 Image relocation code in the UEFI stub assumes that
the dram_base argument it receives is always a multiple of 2 MB. In
reality, it is simply the lowest start address of all RAM entries in
the UEFI memory map, which means it could be any multiple of 4 KB.
Since the arm64 kernel Image needs to reside TEXT_OFFSET bytes beyond
a 2 MB aligned base, or it will fail to boot, make sure we round dram_base
to 2 MB before using it to calculate the relocation address.
Fixes: e38457c361b30c5a ("arm64: efi: prefer AllocatePages() over efi_low_alloc() for vmlinux")
Reported-by: Timur Tabi <timur@codeaurora.org>
Tested-by: Timur Tabi <timur@codeaurora.org>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
systemd > 218 fails to compile on ia64 with:
error: ‘__NR_kcmp’ undeclared [1].
I've been told that this is because the kcmp syscall hasn't been wired up
for the ia64 arch [2].
The proposed patch thus wire up the kcmp syscall for the ia64 arch.
[1] https://bugs.gentoo.org/show_bug.cgi?id=560492
[2] https://bugs.gentoo.org/show_bug.cgi?id=560492#c17
Signed-off-by: Émeric MASCHINO <emeric.maschino@gmail.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
This reverts commit e306dfd06fcb44d21c80acb8e5a88d55f3d1cf63.
With this patch applied, we were the only architecture making this sort
of adjustment to the PC calculation in the unwinder. This causes
problems for ftrace, where the PC values are matched against the
contents of the stack frames in the callchain and fail to match any
records after the address adjustment.
Whilst there has been some effort to change ftrace to workaround this,
those patches are not yet ready for mainline and, since we're the odd
architecture in this regard, let's just step in line with other
architectures (like arch/arm/) for now.
Cc: <stable@vger.kernel.org>
