path: root/arch
2007-08-27Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC32]: Make flush_tlb_kernel_range() an inline function. [SERIAL]: Fix 32-bit warnings in sunzilog.c and sunsu.c [SPARC32]: Kill unused vars and macros from prom/console.c [SPARC32]: Add __cmpdi2() libcall implementation ala. MIPS. [VIDEO]: Do not prom_halt() in cg3 and bw2 device probe. [SUNVDC]: Use slice 0xff on VD_DISK_TYPE_DISK.
2007-08-27Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (60 commits) [MIPS] Fulong doesn't need ISA DMA. [MIPS] IP27: intr_sconnect_level: don't disable interrupts. [MIPS] IP27: startup_bridge_irq: connect interrupt. [MIPS] IP27: shutdown_bridge_irq: don't free irq. [MIPS] Sort out handling of ISA-less PCI systems. [MIPS] Add __cmpdi2 [MIPS] HOTPLUG: Make register_pci_controller __devinit. [MIPS] PCI: Remove __devinit attribute from pcibios_fixup_bus. [MIPS] PCI: Remove __devinit attribute from pcibios_fixup_bus. [MIPS] Delete duplicate inclusion of <linux/delay.h>. [MIPS] Polish <asm/edac.h>. [MIPS] IP22: Export sgi_gfxaddr for use by the Newport console driver. [MIPS] Maintain si_code field properly for FP exceptions [MIPS] SMTC: Fix duplicate status dumps on NMI [MIPS] Unconditionally writeback and invalidate caches on kexec. [PATCH] rtc: Make rtc-rs5c348 driver hotplug-aware [MIPS] Fix gcc 3.3 warning. [MIPS] Fix invalid semicolon after if statement [MIPS] Update Cobalt defconfig [MIPS] Update workpad_defconfig ...
2007-08-27Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Fix SLB initialization at boot time [POWERPC] Fix undefined reference to device_power_up/resume [POWERPC] cell: Update cell_defconfig for 2.6.23 [POWERPC] axonram: Do not delete gendisks queue in error path [POWERPC] axonram: Module modification for latest firmware API changes [POWERPC] cell: Support pinhole-reset on IBM cell blades [POWERPC] spu_manage: Use newer physical-id attribute [POWERPC] pasemi: Another IOMMU bugfix for 64K PAGE_SIZE
git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: [PARISC] Add NOTES section [PARISC] Use compat_sys_getdents [PARISC] Do not allow STI_CONSOLE to be modular [PARISC] Clean up sti_flush [PARISC] Add dummy isa_(bus|virt)_to_(virt|bus) inlines [PARISC] Add empty <asm-parisc/vga.h>
2007-08-27[PARISC] Add NOTES sectionKyle McMartin
Bisected bizarre kernel-space nullptr dereference in udev to commit 18991197b4b588255ccabf472ebc84db7b66a19c, adding the NOTES section fixes it. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-08-27[PARISC] Use compat_sys_getdentsKyle McMartin
Switch to using the generic compat_sys_getdents instead of a homebrew one. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-08-26[SPARC32]: Kill unused vars and macros from prom/console.cDavid S. Miller
This should have been removed during the of_console_device changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-26[SPARC32]: Add __cmpdi2() libcall implementation ala. MIPS.David S. Miller
Device mapper generates calls to this with recent versions of gcc. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-27[MIPS] Fulong doesn't need ISA DMA.Ralf Baechle
2007-08-27[MIPS] IP27: intr_sconnect_level: don't disable interrupts.Ralf Baechle
There is no reason to. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] IP27: startup_bridge_irq: connect interrupt.Ralf Baechle
shutdown_bridge_irq disconnects the irq so we need to connect the irq or requesting the same irq a send time will fail. This used to make things like ifconfig eth0 down; ifconfig eth0 up fail on IP27. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] IP27: shutdown_bridge_irq: don't free irq.Ralf Baechle
2007-08-27[MIPS] Sort out handling of ISA-less PCI systems.Ralf Baechle
2007-08-27[MIPS] Add __cmpdi2Ralf Baechle
Certain 32-bit kernel configurations seem to be able to cause references, this was observed with gcc 4.1.2. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] HOTPLUG: Make register_pci_controller __devinit.Ralf Baechle
2007-08-27[MIPS] PCI: Remove __devinit attribute from pcibios_fixup_bus.Ralf Baechle
Since 96bde06a2df1b363206d3cdef53134b84ff37813 several callers of pcibios_resource_to_bus are no longer marked __devinit resulting in a pile of modpost warnings if PCI && !HOTPLUG: MODPOST vmlinux.o WARNING: vmlinux.o(.text+0x15dde8): Section mismatch: reference to .init.text:pcibios_resource_to_bus (between 'pci_map_rom' and 'pci_map_rom_copy') WARNING: vmlinux.o(.text+0x15e140): Section mismatch: reference to .init.text:pcibios_resource_to_bus (between 'pci_update_resource' and 'pci_claim_resource') WARNING: vmlinux.o(.text+0x15f0cc): Section mismatch: reference to .init.text:pcibios_resource_to_bus (between 'pci_setup_cardbus' and 'pci_bus_assign_resources') WARNING: vmlinux.o(.text+0x15f0f0): Section mismatch: reference to .init.text:pcibios_resource_to_bus (between 'pci_setup_cardbus' and 'pci_bus_assign_resources') WARNING: vmlinux.o(.text+0x15f114): Section mismatch: reference to .init.text:pcibios_resource_to_bus (between 'pci_setup_cardbus' and 'pci_bus_assign_resources') WARNING: vmlinux.o(.text+0x15f138): Section mismatch: reference to .init.text:pcibios_resource_to_bus (between 'pci_setup_cardbus' and 'pci_bus_assign_resources') WARNING: vmlinux.o(.text+0x15f438): Section mismatch: reference to .init.text:pcibios_resource_to_bus (between 'pci_bus_assign_resources' and 'pbus_size_mem') WARNING: vmlinux.o(.text+0x15f4f4): Section mismatch: reference to .init.text:pcibios_resource_to_bus (between 'pci_bus_assign_resources' and 'pbus_size_mem') Removing __devinit from pcibios_resource_to_bus make the same necessary for pcibios_fixup_device_resources as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
Since 96bde06a2df1b363206d3cdef53134b84ff37813 pcibios_fixup_bus's caller pci_scan_child_bus is no longer marked __devinit resulting in this modpost warning if PCI && !HOTPLUG: MODPOST vmlinux.o WARNING: vmlinux.o(.text+0x158b9c): Section mismatch: reference to .init.text:pcibios_fixup_bus (between 'pci_scan_child_bus' and 'pci_scan_bus_parented') Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] IP22: Export sgi_gfxaddr for use by the Newport console driver.Ralf Baechle
2007-08-27[MIPS] Maintain si_code field properly for FP exceptionsThiemo Seufer
The appended patch adds code to update siginfo_t's si_code field. It fixes e.g. a floating point overflow regression in the SBCL testsuite. Signed-off-By: Thiemo Seufer <ths@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] SMTC: Fix duplicate status dumps on NMIThiemo Seufer
Also removes the while(1); loop by propagating the ATTRIB_NORET of die() to nmi_exception_handler. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Unconditionally writeback and invalidate caches on kexec.Nicolas Schichan
Signed-off-by: Nicolas Schichan <nschichan@freebox.fr> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[PATCH] rtc: Make rtc-rs5c348 driver hotplug-awareAtsushi Nemoto
The rtc-rs5c348 SPI driver name doesn't match its module name, which prevents it from properly hotplugging. There is only one in-tree user of its driver, which is fixed by this patch too. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Fix gcc 3.3 warning.Ralf Baechle
CC arch/mips/kernel/cpu-bugs64.o arch/mips/kernel/cpu-bugs64.c: In function 'align_mod': arch/mips/kernel/cpu-bugs64.c:23: warning: asm operand 0 probably doesn't match constraints arch/mips/kernel/cpu-bugs64.c:23: warning: asm operand 1 probably doesn't match constraints Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Fix invalid semicolon after if statementIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Update Cobalt defconfigYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Update workpad_defconfigYoichi Yuasa
2007-08-27[MIPS] Update tb0287_defconfigYoichi Yuasa
2007-08-27[MIPS] Update tb0226_defconfigYoichi Yuasa
2007-08-27[MIPS] Update tb0219_defconfigYoichi Yuasa
2007-08-27[MIPS] Update mpc30x_defconfigYoichi Yuasa
2007-08-27[MIPS] Update e55_defconfigYoichi Yuasa
2007-08-27[MIPS] Update capcella_defconfigYoichi Yuasa
2007-08-27[MIPS] IP22: Fix modpost warning.Ralf Baechle
MODPOST vmlinux.o WARNING: vmlinux.o(.text+0xc70): Section mismatch: reference to .init.text:add_memory_region (between 'probe_memory' and 'enable_local0_irq') Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Gcc 3.3 build fixes.Ralf Baechle
Work around gcc 3.3's unability to evaluate that certain expressions indeed are constant. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] MT: Use kallsyms in CPU state dumpRalf Baechle
2007-08-27[MIPS] MIPSsim: Delete old file that survived moving around in the tree.Ralf Baechle
2007-08-27[MIPS] Excite: disable 64-bit kernel support.Ralf Baechle
CC arch/mips/basler/excite/excite_prom.o arch/mips/basler/excite/excite_prom.c:136:3: #error 64 bit support not implemented Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Kconfig: Fix configuration warning by hardwiring HOTPLUG_CPU to n.Ralf Baechle
2007-08-27[MIPS] Update a few defconfigs.Ralf Baechle
2007-08-27[MIPS] SMTC: Move MIPS_CPU_IPI_IRQ definition into header.Ralf Baechle
2007-08-27[MIPS] Malta: Include <linux/irq.h for cp0_compare_irq / cp0_perfcount_irq.Ralf Baechle
2007-08-27[MIPS] SMP: Scatter __cpuinit over the code as needed.Ralf Baechle
MIPS doesn't do CPU hotplugging yet but since many of the functions don't even have an __init let's fix this right. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] SEAD: Don't mark as experimental.Ralf Baechle
2007-08-27[MIPS] SNI: remove unused pcimt_scache.cYoichi Yuasa
2007-08-27[MIPS] SNI: Remove unneeded sni_machine_haltYoichi Yuasa
2007-08-27[MIPS] Remove dead code from irq_txx9.cAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Do not discard extra debugging sections.Daniel Jacobowitz
Leaving these sections is useful to some tools that look at the image, and none of them are loaded into memory. The .mdebug.abi64 section, in particular, lets GDB recognize vmlinux.32 as an N64 program instead of guessing that it is O32. Signed-off-by: Daniel Jacobowitz <dan@codesourcery.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Update defconfigs for TX39/TX49Atsushi Nemoto
Update defconfigs, disabling CONFIG_EXPERIMENTAL. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Use -Werror on TX39/TX49 boardsAtsushi Nemoto
Now these directories can be built cleanly. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Drop unneeded config options for RBTX4938Atsushi Nemoto
