path: root/arch
2014-09-27Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Here's our last set of fixes for 3.17. Most of these are for TI platforms, fixing some noisy Kconfig issues, runtime clock and power issues on several platforms and NAND timings on DRA7. There are also a couple of bug fixes for i.MX, one for QCOM and a small fix to avoid section mismatch noise on PXA. Diffstat looks large, partially due to some tables being updated and thus touching many lines. The qcom gsbi change also restructures clock management a bit and thus touches a bunch of lines. All in all, a bit more changes than we'd like at this point, but nothing stands out as risky either so it seems like the right thing to send it up now instead of holding it to the merge window" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: drivers/soc: qcom: do not disable the iface clock in probe ARM: imx: fix .is_enabled() of shared gate clock ARM: OMAP3: Fix I/O chain clock line assertion timed out error ARM: keystone: dts: fix bindings for pcie and usb clock nodes bus: omap_l3_noc: Fix connID for OMAP4 ARM: DT: imx53: fix lvds channel 1 port ARM: dts: cm-t54: fix serial console power supply. ARM: dts: dra7-evm: Fix NAND GPMC timings ARM: pxa: fix section mismatch warning for pxa_timer_nodt_init ARM: OMAP: Fix Kconfig warning for omap1
2014-09-27Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "The final round of fixes. One corner case in the math emulator and another one in the mcount function for ftrace" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: mcount: Adjust stack pointer for static trace in MIPS32 MIPS: Fix MFC1 & MFHC1 emulation for 64-bit MIPS systems
2014-09-27Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "This has: - EFI revert to fix a boot regression - early_ioremap() fix for boot failure - KASLR fix for possible boot failures - EFI fix for corrupted string printing - remove a misleading EFI bootup 'failed!' error message Unfortunately it's all rather close to the merge window" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/efi: Truncate 64-bit values when calling 32-bit OutputString() x86/efi: Delete misleading efi_printk() error message Revert "efi/x86: efistub: Move shared dependencies to <asm/efi.h>" x86/kaslr: Avoid the setup_data area when picking location x86 early_ioremap: Increase FIX_BTMAPS_SLOTS to 8
2014-09-26Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "A CONFIG_STACK_GROWSUP=y fix, and a hotplug llc CPU mask fix" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Fix unreleased llc_shared_mask bit during CPU hotplug sched: Fix end_of_stack() and location of stack canary for architectures using CONFIG_STACK_GROWSUP
2014-09-26MIPS: mcount: Adjust stack pointer for static trace in MIPS32Markos Chandras
Every mcount() call in the MIPS 32-bit kernel is done as follows: [...] move at, ra jal _mcount addiu sp, sp, -8 [...] but upon returning from the mcount() function, the stack pointer is not adjusted properly. This is explained in details in 58b69401c797 (MIPS: Function tracer: Fix broken function tracing). Commit ad8c396936e3 ("MIPS: Unbreak function tracer for 64-bit kernel.) fixed the stack manipulation for 64-bit but it didn't fix it completely for MIPS32. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: <stable@vger.kernel.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7792/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-09-26MIPS: Fix MFC1 & MFHC1 emulation for 64-bit MIPS systemsPaul Burton
Commit bbd426f542cb "MIPS: Simplify FP context access" modified the SIFROMREG & SIFROMHREG macros such that they return unsigned rather than signed 32b integers. I had believed that to be fine, but inadvertently missed the MFC1 & MFHC1 cases which write to a struct pt_regs regs element. On MIPS32 this is fine, but on 64 bit those saved regs' fields are 64 bit wide. Using unsigned values caused the 32 bit value from the FP register to be zero rather than sign extended as the architecture specifies, causing incorrect emulation of the MFC1 & MFHc1 instructions. Fix by reintroducing the casts to signed integers, and therefore the sign extension. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: stable@vger.kernel.org # v3.15+ Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7848/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-09-25Merge tag 'efi-urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/mfleming/efi into x86/urgent Pull EFI fixes from Matt Fleming: * Revert the static library changes from the merge window since they're causing issues for Macbooks and Fedora + Grub2 (Matt Fleming) * Delete the misleading "setup_efi_pci() failed!" message which some people are seeing when booting EFI (Matt Fleming) * Fix printing strings from the 32-bit EFI boot stub by only passing 32-bit addresses to the firmware (Matt Fleming) Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-09-24x86/efi: Truncate 64-bit values when calling 32-bit OutputString()Matt Fleming
If we're executing the 32-bit efi_char16_printk() code path (i.e. running on top of 32-bit firmware) we know that efi_early->text_output will be a 32-bit value, even though ->text_output has type u64. Unfortunately, we currently pass ->text_output directly to efi_early->call() so for CONFIG_X86_32 the compiler will push a 64-bit value onto the stack, causing the other parameters to be misaligned. The way we handle this in the rest of the EFI boot stub is to pass pointers as arguments to efi_early->call(), which automatically do the right thing (pointers are 32-bit on CONFIG_X86_32, and we simply ignore the upper 32-bits of the argument register if running in 64-bit mode with 32-bit firmware). This fixes a corruption bug when printing strings from the 32-bit EFI boot stub. Link: https://bugzilla.kernel.org/show_bug.cgi?id=84241 Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-09-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Here is a quick pull request primarily meant to address the deconfig fallout from changing SCSI_NETLINK from being used via 'select' to being used via 'depends'. I applied a set of 5 patches written by Michal Marek, and then I carefully audited all of the remaining config files, basically: 1) I scanned every arch config file, and if it mentioned CONFIG_INET or CONFIG_UNIX, I made sure it had CONFIG_NET=y 2) After that, I scanned every arch config file, and if it did not have CONFIG_NET=y I made sure it did not reference any networking config options. Finally, we have some late breaking wireless fixes in here from John Linville and co" [ And there's a sparc bpf fix snuck in too ] * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: sparc: bpf_jit: fix loads from negative offsets parisc: Update defconfigs which were missing CONFIG_NET. powerpc: Update defconfigs which were missing CONFIG_NET. s390: Update defconfigs which were missing CONFIG_NET. mips: Update some more defconfigs which were missing CONFIG_NET. sparc: Set CONFIG_NET=y in defconfigs sh: Set CONFIG_NET=y in defconfigs powerpc: Set CONFIG_NET=y in defconfigs parisc: Set CONFIG_NET=y in defconfigs mips: Set CONFIG_NET=y in defconfigs brcmfmac: Fix off by one bug in brcmf_count_20mhz_channels() ath9k: Fix NULL pointer dereference on early irq net: rfkill: gpio: Fix clock status NFC: st21nfca: Fix potential depmod dependency cycle NFC: st21nfcb: Fix depmod dependency cycle NFC: microread: Potential overflows in microread_target_discovered()
2014-09-24sparc: bpf_jit: fix loads from negative offsetsAlexei Starovoitov
- fix BPF_LD|ABS|IND from negative offsets: make sure to sign extend lower 32 bits in 64-bit register before calling C helpers from JITed code, otherwise 'int k' argument of bpf_internal_load_pointer_neg_helper() function will be added as large unsigned integer, causing packet size check to trigger and abort the program. It's worth noting that JITed code for 'A = A op K' will affect upper 32 bits differently depending whether K is simm13 or not. Since small constants are sign extended, whereas large constants are stored in temp register and zero extended. That is ok and we don't have to pay a penalty of sign extension for every sethi, since all classic BPF instructions have 32-bit semantics and we only need to set correct upper bits when transitioning from JITed code into C. - though instructions 'A &= 0' and 'A *= 0' are odd, JIT compiler should not optimize them out Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-24parisc: Update defconfigs which were missing CONFIG_NET.David S. Miller
Commit df568d8e ("scsi: Use 'depends' with LIBFC instead of 'select'.") removed what happened to be the only instance of 'select NET'. Defconfigs that were relying on the select now lack networking support. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-24powerpc: Update defconfigs which were missing CONFIG_NET.David S. Miller
2014-09-24s390: Update defconfigs which were missing CONFIG_NET.David S. Miller
2014-09-24mips: Update some more defconfigs which were missing CONFIG_NET.David S. Miller
2014-09-24sparc: Set CONFIG_NET=y in defconfigsMichal Marek
Commit 5d6be6a5 ("scsi_netlink : Make SCSI_NETLINK dependent on NET instead of selecting NET") removed what happened to be the only instance of 'select NET'. Defconfigs that were relying on the select now lack networking support. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: sparclinux@vger.kernel.org Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-24sh: Set CONFIG_NET=y in defconfigsMichal Marek
Commit 5d6be6a5 ("scsi_netlink : Make SCSI_NETLINK dependent on NET instead of selecting NET") removed what happened to be the only instance of 'select NET'. Defconfigs that were relying on the select now lack networking support. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: linux-sh@vger.kernel.org Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-24powerpc: Set CONFIG_NET=y in defconfigsMichal Marek
Commit 5d6be6a5 ("scsi_netlink : Make SCSI_NETLINK dependent on NET instead of selecting NET") removed what happened to be the only instance of 'select NET'. Defconfigs that were relying on the select now lack networking support. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-24parisc: Set CONFIG_NET=y in defconfigsMichal Marek
Commit 5d6be6a5 ("scsi_netlink : Make SCSI_NETLINK dependent on NET instead of selecting NET") removed what happened to be the only instance of 'select NET'. Defconfigs that were relying on the select now lack networking support. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: linux-parisc@vger.kernel.org Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-24mips: Set CONFIG_NET=y in defconfigsMichal Marek
Commit 5d6be6a5 ("scsi_netlink : Make SCSI_NETLINK dependent on NET instead of selecting NET") removed what happened to be the only instance of 'select NET'. Defconfigs that were relying on the select now lack networking support. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: linux-mips@linux-mips.org Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fixes from Herbert Xu: "This fixes three issues: - if ccp is loaded on a machine without ccp, it will incorrectly activate causing all requests to fail. Fixed by preventing ccp from loading if hardware isn't available. - not all IRQs were enabled for the qat driver, leading to potential stalls when it is used - disabled buggy AVX CTR implementation in aesni" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: aesni - disable "by8" AVX CTR optimization crypto: ccp - Check for CCP before registering crypto algs crypto: qat - Enable all 32 IRQs
2014-09-24crypto: aesni - disable "by8" AVX CTR optimizationMathias Krause
The "by8" implementation introduced in commit 22cddcc7df8f ("crypto: aes - AES CTR x86_64 "by8" AVX optimization") is failing crypto tests as it handles counter block overflows differently. It only accounts the right most 32 bit as a counter -- not the whole block as all other implementations do. This makes it fail the cryptomgr test #4 that specifically tests this corner case. As we're quite late in the release cycle, just disable the "by8" variant for now. Reported-by: Romain Francoise <romain@orebokech.com> Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Chandramouli Narayanan <mouli@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-09-24sched: Fix unreleased llc_shared_mask bit during CPU hotplugWanpeng Li
The following bug can be triggered by hot adding and removing a large number of xen domain0's vcpus repeatedly: BUG: unable to handle kernel NULL pointer dereference at 0000000000000004 IP: [..] find_busiest_group PGD 5a9d5067 PUD 13067 PMD 0 Oops: 0000 [#3] SMP [...] Call Trace: load_balance ? _raw_spin_unlock_irqrestore idle_balance __schedule schedule schedule_timeout ? lock_timer_base schedule_timeout_uninterruptible msleep lock_device_hotplug_sysfs online_store dev_attr_store sysfs_write_file vfs_write SyS_write system_call_fastpath Last level cache shared mask is built during CPU up and the build_sched_domain() routine takes advantage of it to setup the sched domain CPU topology. However, llc_shared_mask is not released during CPU disable, which leads to an invalid sched domainCPU topology. This patch fix it by releasing the llc_shared_mask correctly during CPU disable. Yasuaki also reported that this can happen on real hardware: https://lkml.org/lkml/2014/7/22/1018 His case is here: == Here is an example on my system. My system has 4 sockets and each socket has 15 cores and HT is enabled. In this case, each core of sockes is numbered as follows: | CPU# Socket#0 | 0-14 , 60-74 Socket#1 | 15-29, 75-89 Socket#2 | 30-44, 90-104 Socket#3 | 45-59, 105-119 Then llc_shared_mask of CPU#30 has 0x3fff80000001fffc0000000. It means that last level cache of Socket#2 is shared with CPU#30-44 and 90-104. When hot-removing socket#2 and #3, each core of sockets is numbered as follows: | CPU# Socket#0 | 0-14 , 60-74 Socket#1 | 15-29, 75-89 But llc_shared_mask is not cleared. So llc_shared_mask of CPU#30 remains having 0x3fff80000001fffc0000000. After that, when hot-adding socket#2 and #3, each core of sockets is numbered as follows: | CPU# Socket#0 | 0-14 , 60-74 Socket#1 | 15-29, 75-89 Socket#2 | 30-59 Socket#3 | 90-119 Then llc_shared_mask of CPU#30 becomes 0x3fff8000fffffffc0000000. It means that last level cache of Socket#2 is shared with CPU#30-59 and 90-104. So the mask has the wrong value. Signed-off-by: Wanpeng Li <wanpeng.li@linux.intel.com> Tested-by: Linn Crosetto <linn@hp.com> Reviewed-by: Borislav Petkov <bp@suse.de> Reviewed-by: Toshi Kani <toshi.kani@hp.com> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: <stable@vger.kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1411547885-48165-1-git-send-email-wanpeng.li@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-09-24x86/efi: Delete misleading efi_printk() error messageMatt Fleming
A number of people are reporting seeing the "setup_efi_pci() failed!" error message in what used to be a quiet boot, https://bugzilla.kernel.org/show_bug.cgi?id=81891 The message isn't all that helpful because setup_efi_pci() can return a non-success error code for a variety of reasons, not all of them fatal. Let's drop the return code from setup_efi_pci*() altogether, since there's no way to process it in any meaningful way outside of the inner __setup_efi_pci*() functions. Reported-by: Darren Hart <dvhart@linux.intel.com> Reported-by: Josh Boyer <jwboyer@fedoraproject.org> Cc: Ulf Winkelvos <ulf@winkelvos.de> Cc: Andre Müller <andre.muller@web.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-09-23Merge branch 'parisc-3.17-7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull parisc fixes from Helge Deller: "We avoid using -mfast-indirect-calls for 64bit kernel builds to prevent building an unbootable kernel due to latest gcc changes. In the pdc_stable/firmware-access driver we fix a few possible stack overflows and we now call secure_computing_strict() instead of secure_computing() which fixes upcoming SECCOMP patches in the for-next trees" * 'parisc-3.17-7' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: Only use -mfast-indirect-calls option for 32-bit kernel builds parisc: pdc_stable.c: Avoid potential stack overflows parisc: pdc_stable.c: Cleaning up unnecessary use of memset in conjunction with strncpy parisc: ptrace: use secure_computing_strict()
2014-09-23Revert "efi/x86: efistub: Move shared dependencies to <asm/efi.h>"Matt Fleming
This reverts commit f23cf8bd5c1f ("efi/x86: efistub: Move shared dependencies to <asm/efi.h>") as well as the x86 parts of commit f4f75ad5741f ("efi: efistub: Convert into static library"). The road leading to these two reverts is long and winding. The above two commits were merged during the v3.17 merge window and turned the common EFI boot stub code into a static library. This necessitated making some symbols global in the x86 boot stub which introduced new entries into the early boot GOT. The problem was that we weren't fixing up the newly created GOT entries before invoking the EFI boot stub, which sometimes resulted in hangs or resets. This failure was reported by Maarten on his Macbook pro. The proposed fix was commit 9cb0e394234d ("x86/efi: Fixup GOT in all boot code paths"). However, that caused issues for Linus when booting his Sony Vaio Pro 11. It was subsequently reverted in commit f3670394c29f. So that leaves us back with Maarten's Macbook pro not booting. At this stage in the release cycle the least risky option is to revert the x86 EFI boot stub to the pre-merge window code structure where we explicitly #include efi-stub-helper.c instead of linking with the static library. The arm64 code remains unaffected. We can take another swing at the x86 parts for v3.18. Conflicts: arch/x86/include/asm/efi.h Tested-by: Josh Boyer <jwboyer@fedoraproject.org> Tested-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Tested-by: Leif Lindholm <leif.lindholm@linaro.org> [arm64] Tested-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>, Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-09-23parisc: Only use -mfast-indirect-calls option for 32-bit kernel buildsJohn David Anglin
In spite of what the GCC manual says, the -mfast-indirect-calls has never been supported in the 64-bit parisc compiler. Indirect calls have always been done using function descriptors irrespective of the -mfast-indirect-calls option. Recently, it was noticed that a function descriptor was always requested when the -mfast-indirect-calls option was specified. This caused problems when the option was used in application code and doesn't make any sense because the whole point of the option is to avoid using a function descriptor for indirect calls. Fixing this broke 64-bit kernel builds. I will fix GCC but for now we need the attached change. This results in the same kernel code as before. Signed-off-by: John David Anglin <dave.anglin@bell.net> Cc: stable@vger.kernel.org # v3.0+ Signed-off-by: Helge Deller <deller@gmx.de>
2014-09-23[IA64] refresh arch/ia64/configs/* using "make savedefconfig"Tony Luck
Prompted by a change to drivers/scsi/Kconfig which used to do a "select NET" but now does a "depends on NET". This meant that some configurations ended up without CONFIG_NET=y Signed-off-by Tony Luck <tony.luck@intel.com>
2014-09-22Revert "x86/efi: Fixup GOT in all boot code paths"Linus Torvalds
This reverts commit 9cb0e394234d244fe5a97e743ec9dd7ddff7e64b. It causes my Sony Vaio Pro 11 to immediately reboot at startup. Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Peter Anvin <hpa@zytor.com> Cc: Maarten Lankhorst <maarten.lankhorst@canonical.com> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-22Merge tag 'fix-v3.17-io-chain-v3' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes Regression fix for early omap3 revisions for wake-up events that too some time to narrow down. Although a bit intrusive, this would be good to get into the -rc cycle as there are quite a few boards out there with omap3 es2.1 and es3.0, and we have those in at least three boot test systems too that show errors without this patch. * tag 'fix-v3.17-io-chain-v3' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP3: Fix I/O chain clock line assertion timed out error Signed-off-by: Olof Johansson <olof@lixom.net>
2014-09-22Merge tag 'fixes-v3.17-rc4' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes Few regression fixes for omaps for the -rc cycle: - Fix for omap_l3_noc bus code - Serial console fix for cm-t53 - NAND timings fix for dra7-evm * tag 'fixes-v3.17-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: bus: omap_l3_noc: Fix connID for OMAP4 ARM: dts: cm-t54: fix serial console power supply. ARM: dts: dra7-evm: Fix NAND GPMC timings Signed-off-by: Olof Johansson <olof@lixom.net>
git://git.kernel.org/pub/scm/linux/kernel/git/ssantosh/linux-keystone into fixes Keystone Edision dts fix for -rc cycle. Fix the PCIE and USB nodes. * tag 'fixes-v3.17-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/ssantosh/linux-keystone: ARM: keystone: dts: fix bindings for pcie and usb clock nodes Signed-off-by: Olof Johansson <olof@lixom.net>
2014-09-22ARM: imx: fix .is_enabled() of shared gate clockShawn Guo
Commit 63288b721a80 ("ARM: imx: fix shared gate clock") attempted to fix an issue with particular enable/disable sequence from two shared gate clocks. But unfortunately, while it partially fixed the issue, it also did something wrong in .is_enabled() function hook. In case of shared gate, the function shouldn't really query the hardware state via share_count, because the function is trying to query the enabling state of the clock in question, not the hardware state which is shared by multiple clocks. Fix the issue by returning the enable_count of the clock itself which is maintained by clock core, in case it's a clock sharing hardware gate with others. As the result, the initialization of share_count per hardware state is not needed now. So remove it. Reported-by: Fabio Estevam <fabio.estevam@freescale.com> Fixes: 63288b721a80 ("ARM: imx: fix shared gate clock") Cc: <stable@vger.kernel.org> Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-09-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) If the user gives us a msg_namelen of 0, don't try to interpret anything pointed to by msg_name. From Ani Sinha. 2) Fix some bnx2i/bnx2fc randconfig compilation errors. The gist of the issue is that we firstly have drivers that span both SCSI and networking. And at the top of that chain of dependencies we have things like SCSI_FC_ATTRS and SCSI_NETLINK which are selected. But since select is a sledgehammer and ignores dependencies, everything to select's SCSI_FC_ATTRS and/or SCSI_NETLINK has to also explicitly select their dependencies and so on and so forth. Generally speaking 'select' is supposed to only be used for child nodes, those which have no dependencies of their own. And this whole chain of dependencies in the scsi layer violates that rather strongly. So just make SCSI_NETLINK depend upon it's dependencies, and so on and so forth for the things selecting it (either directly or indirectly). From Anish Bhatt and Randy Dunlap. 3) Fix generation of blackhole routes in IPSEC, from Steffen Klassert. 4) Actually notice netdev feature changes in rtl_open() code, from Hayes Wang. 5) Fix divide by zero in bond enslaving, from Nikolay Aleksandrov. 6) Missing memory barrier in sunvnet driver, from David Stevens. 7) Don't leave anycast addresses around when ipv6 interface is destroyed, from Sabrina Dubroca. 8) Don't call efx_{arch}_filter_sync_rx_mode before addr_list_lock is initialized in SFC driver, from Edward Cree. 9) Fix missing DMA error checking in 3c59x, from Neal Horman. 10) Openvswitch doesn't emit OVS_FLOW_CMD_NEW notifications accidently, fix from Samuel Gauthier. 11) pch_gbe needs to select NET_PTP_CLASSIFY otherwise we can get a build error. 12) Fix macvlan regression wherein we stopped emitting broadcast/multicast frames over software devices. From Nicolas Dichtel. 13) Fix infiniband bug due to unintended overflow of skb->cb[], from Eric Dumazet. And add an assertion so this doesn't happen again. 14) dm9000_parse_dt() should return error pointers, not NULL. From Tobias Klauser. 15) IP tunneling code uses this_cpu_ptr() in preemptible contexts, fix from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (87 commits) net: bcmgenet: call bcmgenet_dma_teardown in bcmgenet_fini_dma net: bcmgenet: fix TX reclaim accounting for fragments ipv4: do not use this_cpu_ptr() in preemptible context dm9000: Return an ERR_PTR() in all error conditions of dm9000_parse_dt() r8169: fix an if condition r8152: disable ALDPS ipoib: validate struct ipoib_cb size net: sched: shrink struct qdisc_skb_cb to 28 bytes tg3: Work around HW/FW limitations with vlan encapsulated frames macvlan: allow to enqueue broadcast pkt on virtual device pch_gbe: 'select' NET_PTP_CLASSIFY. scsi: Use 'depends' with LIBFC instead of 'select'. openvswitch: restore OVS_FLOW_CMD_NEW notifications genetlink: add function genl_has_listeners() lib: rhashtable: remove second linux/log2.h inclusion net: allow macvlans to move to net namespace 3c59x: Fix bad offset spec in skb_frag_dma_map 3c59x: Add dma error checking and recovery sparc: bpf_jit: fix support for ldx/stx mem and SKF_AD_VLAN_TAG can: at91_can: add missing prepare and unprepare of the clock ...
2014-09-22Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fixes from Paolo Bonzini: "Two very simple bugfixes, affecting all supported architectures" [ Two? There's three commits in here. Oh well, I guess Paolo didn't count the preparatory symbol export ] * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: correct null pid check in kvm_vcpu_yield_to() KVM: check for !is_zero_pfn() in kvm_is_mmio_pfn() mm: export symbol dependencies of is_zero_pfn()
2014-09-21Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Fixes for ARM, the most notable being the fix from Nathan Lynch to fix the state of various registers during execve, to ensure that data can't be leaked between two executables. Fixes from Victor Kamensky for get_user() on big endian platforms, since the addition of 8-byte get_user() support broke these fairly badly. A fix from Sudeep Holla for affinity setting when hotplugging CPU 0. A fix from Stephen Boyd for a perf-induced sleep attempt while atomic. Lastly, a correctness fix for emulation of the SWP instruction on ARMv7+, and a fix for wrong carry handling when updating the translation table base address on LPAE platforms" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8149/1: perf: Don't sleep while atomic when enabling per-cpu interrupts ARM: 8148/1: flush TLS and thumbee register state during exec ARM: 8151/1: add missing exports for asm functions required by get_user macro ARM: 8137/1: fix get_user BE behavior for target variable with size of 8 bytes ARM: 8135/1: Fix in-correct barrier usage in SWP{B} emulation ARM: 8133/1: use irq_set_affinity with force=false when migrating irqs ARM: 8132/1: LPAE: drop wrong carry flag correction after adding TTBR1_OFFSET
2014-09-21parisc: ptrace: use secure_computing_strict()Helge Deller
2014-09-19sparc: bpf_jit: fix support for ldx/stx mem and SKF_AD_VLAN_TAGAlexei Starovoitov
fix several issues in sparc BPF JIT compiler. ldx/stx related: . classic BPF instructions that access mem[] slots were not setting SEEN_MEM flag, so stack wasn't allocated. Fix that by advertising correct flags . LDX/STX instructions were missing SEEN_XREG, so register value could have leaked to user space. Fix it. . since stack for mem[] slots is allocated with 'sub %sp' instead of 'save %sp', use %sp as base register instead of %fp. . ldx mem[0] means first slot in classic BPF which should have -4 offset instead of 0. . sparc64 needs 2047 stack bias as per ABI to access stack . emit_stmem() was using LD32I macro instead of ST32I SKF_AD_VLAN_TAG* related: . SKF_AD_VLAN_TAG_PRESENT must return 1 or 0 instead of '> 0' or 0 as per classic BPF de facto standard . SKF_AD_VLAN_TAG needs to mask the field correctly Fixes: 2809a2087cc4 ("net: filter: Just In Time compiler for sparc") Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-19Merge tag 'pci-v3.17-fixes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: "These fix: - Boot video device detection on dual-GPU Apple systems - Hotplug fiascos on VGA switcheroo with radeon & nouveau drivers - Boot hang on Freescale i.MX6 systems - Excessive "no hotplug settings from platform" warnings In particular: Enumeration - Don't default exclusively to first video device (Bruno Prémont) PCI device hotplug - Remove "no hotplug settings from platform" warning (Bjorn Helgaas) - Add pci_ignore_hotplug() for VGA switcheroo (Bjorn Helgaas) Freescale i.MX6 - Put LTSSM in "Detect" state before disabling (Lucas Stach)" * tag 'pci-v3.17-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: vgaarb: Drop obsolete #ifndef vgaarb: Don't default exclusively to first video device with mem+io ACPIPHP / radeon / nouveau: Remove acpi_bus_no_hotplug() PCI: Remove "no hotplug settings from platform" warning PCI: Add pci_ignore_hotplug() to ignore hotplug events for a device PCI: imx6: Put LTSSM in "Detect" state before disabling it MAINTAINERS: Add Lucas Stach as co-maintainer for i.MX6 PCI driver
2014-09-19Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Two kernel side fixes: a kprobes fix and a perf_remove_from_context() fix (which does not yet fix the migration bug which is WIP)" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf: Fix a race condition in perf_remove_from_context() kprobes/x86: Free 'optinsn' cache when range check fails
2014-09-19Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Misc fixes: EFI fixes, a build fix, a page table dumping (debug) fix and a clang build fix" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: efi/arm64: Fix fdt-related memory reservation x86/mm: Apply the section attribute to the variable, not its type x86/efi: Fixup GOT in all boot code paths x86/efi: Only load initrd above 4g on second try x86-64, ptdump: Mark espfix area only if existent x86, irq: Fix build error caused by 9eabc99a635a77cbf09
2014-09-19Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "A fair number of build fixes for various configurations. Fixes to BPF, and the BCM47xx platform code, a preemption fix for the Loongson core, a syscall auditing fix, wire up the new getrandom and memfd_create. Several patches for EVA" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (30 commits) MIPS: SmartMIPS: Disable assembler warnings MIPS: Move CPU topology macros to topology.h MIPS: Wire up new syscalls getrandom and memfd_create. MIPS: Fix a warning for virt_to_page arch/mips/net/bpf_jit.c: fix failure check MIPS: COP2: CPP macro safety fixes. MIPS: Kconfig: Select SMP symbols for CMP MIPS: ZBOOT: add missing <linux/string.h> include MIPS: IP28: Fix/clean spaces.h MIPS: IP28: Select correct L1_CACHE_SHIFT MIPS: BCM63xx: delete double assignment MIPS: Spelling s/confugrations/configurations/ MIPS: OCTEON: make get_system_type() thread-safe MIPS: CPS: Initialize EVA before bringing up VPEs from secondary cores MIPS: Malta: EVA: Rename 'eva_entry' to 'platform_eva_init' MIPS: EVA: Add new EVA header MIPS: scall64-o32: Fix indirect syscall detection MIPS: syscall: Fix AUDIT value for O32 processes on MIPS64 MIPS: Loongson: Fix COP2 usage for preemptible kernel MIPS: NL: Fix nlm_xlp_defconfig build error ...
2014-09-19x86/kaslr: Avoid the setup_data area when picking locationKees Cook
The KASLR location-choosing logic needs to avoid the setup_data list memory areas as well. Without this, it would be possible to have the ASLR position stomp on the memory, ultimately causing the boot to fail. Signed-off-by: Kees Cook <keescook@chromium.org> Tested-by: Baoquan He <bhe@redhat.com> Cc: stable@vger.kernel.org Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Pavel Machek <pavel@ucw.cz> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140911161931.GA12001@www.outflux.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-09-19Merge tag 'efi-urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/mfleming/efi into x86/urgent Pull EFI fix from Matt Fleming: * Increase the number of early_ioremap() slots to fix a regression with earlyprintk=efi after recent changes to the ACPI code (Dave Young) Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-09-17MIPS: SmartMIPS: Disable assembler warningsMarkos Chandras
The kernel code overrides the default ISA as passed by the compiler in quite a few places. This has unfortunate side effects when smartmips is enabled leading to hundreds of warnings during build such as: {standard input}: Assembler messages: {standard input}:411: Warning: the `smartmips' extension requires MIPS32 revision 1 or greater {standard input}: Assembler messages: {standard input}:43: Warning: the 64-bit MIPS architecture does not support the `smartmips' extension [...] Until the kernel code is fixed properly (if possible), disable all the assembler warning messages to make the build logs readable again. This has no runtime side effects but it makes it easier to spot more critical warnings and problems during build. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7356/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-09-16ARM: OMAP3: Fix I/O chain clock line assertion timed out errorTony Lindgren
We are getting "PRM: I/O chain clock line assertion timed out" errors on early omaps for device tree based booting. This is because we are unconditionally calling reconfigure_io_chain while legacy booting has omap3_has_io_chain_ctrl() checks in place in omap_hwmod.c. For device tree based booting, we are calling reconfigure_io_chain unconditionally from pinctrl framework. So we need to add a check for omap3_has_io_chain_ctrl() to avoid the errors for trying to access a register that does not exist. For es3.0, the documentation in "4.11.2 Device Off-Mode Configuration" just mentions PM_WKEN_WKUP[8] bit. For es3.1, there's a new chapter in documentation for "4.11.2.2 I/O Wake-Up Mechanism" that describes the PM_WKEN_WKUP[16] ST_IO_CHAIN bit. So PM_WKEN_WKUP[16] bit did not get added until in es3.1 probaly to fix issues with flakey wake-up events. We are doing proper checks for ST_IO_CHAIN already in id.c and with omap3_has_io_chain_ctrl(). For more information, see also commit b02b917211d5 ("ARM: OMAP3: PM: fix I/O wakeup and I/O chain clock control detection"). Let's fix the issue by selecting the right function during init for reconfigure_io_chain depending on the omap revision. For es3.0 and earlier we need to just toggle EN_IO. By doing this, we can move the check for omap3_has_io_chain_ctrl() from omap_hwmod.c to the init code in prm_3xxx.c. And then we can unconditionally call reconfigure_io_chain. Thanks to Paul Walmsley and Nishanth Menon for help with debugging the issue. Fixes: 30a69ef785e8 ("ARM: OMAP: Move DT wake-up event handling over to use pinctrl-single-omap") Cc: Kevin Hilman <khilman@kernel.org> Cc: Paul Walmsley <paul@pwsan.com> Cc: Tero Kristo <t-kristo@ti.com> Reviewed-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-16vgaarb: Don't default exclusively to first video device with mem+ioBruno Prémont
Commit 20cde694027e ("x86, ia64: Move EFI_FB vga_default_device() initialization to pci_vga_fixup()") moved boot video device detection from efifb to x86 and ia64 pci/fixup.c. For dual-GPU Apple computers above change represents a regression as code in efifb did forcefully override vga_default_device while the merge did not (vgaarb happens prior to PCI fixup). To improve on initial device selection by vgaarb (it cannot know if PCI device not behind bridges see/decode legacy VGA I/O or not), move the screen_info based check from pci_video_fixup() to vgaarb's init function and use it to refine/override decision taken while adding the individual PCI VGA devices. This way PCI fixup has no reason to adjust vga_default_device anymore but can depend on its value for flagging shadowed VBIOS. This has the nice benefit of removing duplicated code but does introduce a #if defined() block in vgaarb. Not all architectures have screen_info and would cause compile to fail without it. Link: https://bugzilla.kernel.org/show_bug.cgi?id=84461 Reported-and-Tested-By: Andreas Noever <andreas.noever@gmail.com> Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: Matthew Garrett <matthew.garrett@nebula.com> CC: stable@vger.kernel.org # v3.5+
2014-09-16ARM: 8149/1: perf: Don't sleep while atomic when enabling per-cpu interruptsStephen Boyd
Rob Clark reports a sleeping while atomic bug when using perf. BUG: sleeping function called from invalid context at ../kernel/locking/mutex.c:583 in_atomic(): 1, irqs_disabled(): 128, pid: 0, name: swapper/0 ------------[ cut here ]------------ WARNING: CPU: 2 PID: 4828 at ../kernel/locking/mutex.c:479 mutex_lock_nested+0x3a0/0x3e8() DEBUG_LOCKS_WARN_ON(in_interrupt()) Modules linked in: CPU: 2 PID: 4828 Comm: Xorg.bin Tainted: G W 3.17.0-rc3-00234-gd535c45-dirty #819 [<c0216690>] (unwind_backtrace) from [<c0212174>] (show_stack+0x10/0x14) [<c0212174>] (show_stack) from [<c0867cc0>] (dump_stack+0x98/0xb8) [<c0867cc0>] (dump_stack) from [<c02492a4>] (warn_slowpath_common+0x70/0x8c) [<c02492a4>] (warn_slowpath_common) from [<c02492f0>] (warn_slowpath_fmt+0x30/0x40) [<c02492f0>] (warn_slowpath_fmt) from [<c086a3f8>] (mutex_lock_nested+0x3a0/0x3e8) [<c086a3f8>] (mutex_lock_nested) from [<c0294d08>] (irq_find_host+0x20/0x9c) [<c0294d08>] (irq_find_host) from [<c0769d50>] (of_irq_get+0x28/0x48) [<c0769d50>] (of_irq_get) from [<c057d104>] (platform_get_irq+0x1c/0x8c) [<c057d104>] (platform_get_irq) from [<c021a06c>] (cpu_pmu_enable_percpu_irq+0x14/0x38) [<c021a06c>] (cpu_pmu_enable_percpu_irq) from [<c02b1634>] (flush_smp_call_function_queue+0x88/0x178) [<c02b1634>] (flush_smp_call_function_queue) from [<c0214dc0>] (handle_IPI+0x88/0x160) [<c0214dc0>] (handle_IPI) from [<c0208930>] (gic_handle_irq+0x64/0x68) [<c0208930>] (gic_handle_irq) from [<c0212d04>] (__irq_svc+0x44/0x5c) Exception stack(0xe63ddea0 to 0xe63ddee8) dea0: 00000001 00000001 00000000 c2f3b200 c16db380 c032d4a0 e63ddf40 60010013 dec0: 00000000 001fbfd4 00000100 00000000 00000001 e63ddee8 c0284770 c02a2e30 dee0: 20010013 ffffffff [<c0212d04>] (__irq_svc) from [<c02a2e30>] (ktime_get_ts64+0x1c8/0x200) [<c02a2e30>] (ktime_get_ts64) from [<c032d4a0>] (poll_select_set_timeout+0x60/0xa8) [<c032d4a0>] (poll_select_set_timeout) from [<c032df64>] (SyS_select+0xa8/0x118) [<c032df64>] (SyS_select) from [<c020e8e0>] (ret_fast_syscall+0x0/0x48) ---[ end trace 0bb583b46342da6f ]--- INFO: lockdep is turned off. We don't really need to get the platform irq again when we're enabling or disabling the per-cpu irq. Furthermore, we don't really need to set and clear bits in the active_irqs bitmask because that's only used in the non-percpu irq case to figure out when the last CPU PMU has been disabled. Just pass the irq directly to the enable/disable functions to clean all this up. This should be slightly more efficient and also fix the scheduling while atomic bug. Fixes: bbd64559376f "ARM: perf: support percpu irqs for the CPU PMU" Reported-by: Rob Clark <robdclark@gmail.com> Acked-by: Will Deacon <will.deacon@arm.com> Cc: stable@vger.kernel.org Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-09-16ARM: 8148/1: flush TLS and thumbee register state during execNathan Lynch
The TPIDRURO and TPIDRURW registers need to be flushed during exec; otherwise TLS information is potentially leaked. TPIDRURO in particular needs careful treatment. Since flush_thread basically needs the same code used to set the TLS in arm_syscall, pull that into a common set_tls helper in tls.h and use it in both places. Similarly, TEEHBR needs to be cleared during exec as well. Clearing its save slot in thread_info isn't right as there is no guarantee that a thread switch will occur before the new program runs. Just setting the register directly is sufficient. Signed-off-by: Nathan Lynch <nathan_lynch@mentor.com> Acked-by: Will Deacon <will.deacon@arm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-09-16ARM: 8151/1: add missing exports for asm functions required by get_user macroVictor Kamensky
Previous commits that dealt with get_user for 64bit type missed to export proper functions, so if get_user macro with particular target/value types are used by kernel module modpost would produce 'undefined!' error. Solution is to export all required functions. Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-09-15ia64: Fix syscall number for memfd_createTony Luck
Cut & paste typo from the line above. Reported-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
