path: root/arch
2018-01-23MIPS: AR7: ensure the port type's FCR value is usedJonas Gorski
commit 0a5191efe06b5103909206e4fbcff81d30283f8e upstream. Since commit aef9a7bd9b67 ("serial/uart/8250: Add tunable RX interrupt trigger I/F of FIFO buffers"), the port's default FCR value isn't used in serial8250_do_set_termios anymore, but copied over once in serial8250_config_port and then modified as needed. Unfortunately, serial8250_config_port will never be called if the port is shared between kernel and userspace, and the port's flag doesn't have UPF_BOOT_AUTOCONF, which would trigger a serial8250_config_port as well. This causes garbled output from userspace: [ 5.220000] random: procd urandom read with 49 bits of entropy available ers [kee Fix this by forcing it to be configured on boot, resulting in the expected output: [ 5.250000] random: procd urandom read with 50 bits of entropy available Press the [f] key and hit [enter] to enter failsafe mode Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level Fixes: aef9a7bd9b67 ("serial/uart/8250: Add tunable RX interrupt trigger I/F of FIFO buffers") Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Yoshihiro YUNOMAE <yoshihiro.yunomae.ez@hitachi.com> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Nicolas Schichan <nschichan@freebox.fr> Cc: linux-mips@linux-mips.org Cc: linux-serial@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/17544/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: James Hogan <jhogan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/retpoline: Optimize inline assembler for vmexit_fill_RSBAndi Kleen
commit 3f7d875566d8e79c5e0b2c9a413e91b2c29e0854 upstream. The generated assembler for the C fill RSB inline asm operations has several issues: - The C code sets up the loop register, which is then immediately overwritten in __FILL_RETURN_BUFFER with the same value again. - The C code also passes in the iteration count in another register, which is not used at all. Remove these two unnecessary operations. Just rely on the single constant passed to the macro for the iterations. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw@amazon.co.uk> Cc: dave.hansen@intel.com Cc: gregkh@linuxfoundation.org Cc: torvalds@linux-foundation.org Cc: arjan@linux.intel.com Link: https://lkml.kernel.org/r/20180117225328.15414-1-andi@firstfloor.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23kprobes/x86: Disable optimizing on the function jumps to indirect thunkMasami Hiramatsu
commit c86a32c09f8ced67971a2310e3b0dda4d1749007 upstream. Since indirect jump instructions will be replaced by jump to __x86_indirect_thunk_*, those jmp instruction must be treated as an indirect jump. Since optprobe prohibits to optimize probes in the function which uses an indirect jump, it also needs to find out the function which jump to __x86_indirect_thunk_* and disable optimization. Add a check that the jump target address is between the __indirect_thunk_start/end when optimizing kprobe. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw@amazon.co.uk> Cc: Andi Kleen <ak@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Link: https://lkml.kernel.org/r/151629212062.10241.6991266100233002273.stgit@devbox Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23kprobes/x86: Blacklist indirect thunk functions for kprobesMasami Hiramatsu
commit c1804a236894ecc942da7dc6c5abe209e56cba93 upstream. Mark __x86_indirect_thunk_* functions as blacklist for kprobes because those functions can be called from anywhere in the kernel including blacklist functions of kprobes. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw@amazon.co.uk> Cc: Andi Kleen <ak@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Link: https://lkml.kernel.org/r/151629209111.10241.5444852823378068683.stgit@devbox Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23retpoline: Introduce start/end markers of indirect thunkMasami Hiramatsu
commit 736e80a4213e9bbce40a7c050337047128b472ac upstream. Introduce start/end markers of __x86_indirect_thunk_* functions. To make it easy, consolidate .text.__x86.indirect_thunk.* sections to one .text.__x86.indirect_thunk section and put it in the end of kernel text section and adds __indirect_thunk_start/end so that other subsystem (e.g. kprobes) can identify it. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw@amazon.co.uk> Cc: Andi Kleen <ak@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Link: https://lkml.kernel.org/r/151629206178.10241.6828804696410044771.stgit@devbox Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/mce: Make machine check speculation protectedThomas Gleixner
commit 6f41c34d69eb005e7848716bbcafc979b35037d5 upstream. The machine check idtentry uses an indirect branch directly from the low level code. This evades the speculation protection. Replace it by a direct call into C code and issue the indirect call there so the compiler can apply the proper speculation protection. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by:Borislav Petkov <bp@alien8.de> Reviewed-by: David Woodhouse <dwmw@amazon.co.uk> Niced-by: Peter Zijlstra <peterz@infradead.org> Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1801181626290.1847@nanos Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/cpu, x86/pti: Do not enable PTI on AMD processorsTom Lendacky
commit 694d99d40972f12e59a3696effee8a376b79d7c8 upstream. AMD processors are not subject to the types of attacks that the kernel page table isolation feature protects against. The AMD microarchitecture does not allow memory references, including speculative references, that access higher privileged data when running in a lesser privileged mode when that access would result in a page fault. Disable page table isolation by default on AMD processors by not setting the X86_BUG_CPU_INSECURE feature, which controls whether X86_FEATURE_PTI is set. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20171227054354.20369.94587.stgit@tlendack-t1.amdoffice.net Cc: Nick Lowe <nick.lowe@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23arm64: KVM: Fix SMCCC handling of unimplemented SMC/HVC callsMarc Zyngier
commit acfb3b883f6d6a4b5d27ad7fdded11f6a09ae6dd upstream. KVM doesn't follow the SMCCC when it comes to unimplemented calls, and inject an UNDEF instead of returning an error. Since firmware calls are now used for security mitigation, they are becoming more common, and the undef is counter productive. Instead, let's follow the SMCCC which states that -1 must be returned to the caller when getting an unknown function number. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23ARM: dts: kirkwood: fix pin-muxing of MPP7 on OpenBlocks A7Thomas Petazzoni
commit 56aeb07c914a616ab84357d34f8414a69b140cdf upstream. MPP7 is currently muxed as "gpio", but this function doesn't exist for MPP7, only "gpo" is available. This causes the following error: kirkwood-pinctrl f1010000.pin-controller: unsupported function gpio on pin mpp7 pinctrl core: failed to register map default (6): invalid type given kirkwood-pinctrl f1010000.pin-controller: error claiming hogs: -22 kirkwood-pinctrl f1010000.pin-controller: could not claim hogs: -22 kirkwood-pinctrl f1010000.pin-controller: unable to register pinctrl driver kirkwood-pinctrl: probe of f1010000.pin-controller failed with error -22 So the pinctrl driver is not probed, all device drivers (including the UART driver) do a -EPROBE_DEFER, and therefore the system doesn't really boot (well, it boots, but with no UART, and no devices that require pin-muxing). Back when the Device Tree file for this board was introduced, the definition was already wrong. The pinctrl driver also always described as "gpo" this function for MPP7. However, between Linux 4.10 and 4.11, a hog pin failing to be muxed was turned from a simple warning to a hard error that caused the entire pinctrl driver probe to bail out. This is probably the result of commit 6118714275f0a ("pinctrl: core: Fix pinctrl_register_and_init() with pinctrl_enable()"). This commit fixes the Device Tree to use the proper "gpo" function for MPP7, which fixes the boot of OpenBlocks A7, which was broken since Linux 4.11. Fixes: f24b56cbcd9d ("ARM: kirkwood: add support for OpenBlocks A7 platform") Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23ARM: sunxi_defconfig: Enable CMAMaxime Ripard
commit c13e7f313da33d1488355440f1a10feb1897480a upstream. The DRM driver most notably, but also out of tree drivers (for now) like the VPU or GPU drivers, are quite big consumers of large, contiguous memory buffers. However, the sunxi_defconfig doesn't enable CMA in order to mitigate that, which makes them almost unusable. Enable it to make sure it somewhat works. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/apic/vector: Fix off by one in error pathThomas Gleixner
commit 45d55e7bac4028af93f5fa324e69958a0b868e96 upstream. Keith reported the following warning: WARNING: CPU: 28 PID: 1420 at kernel/irq/matrix.c:222 irq_matrix_remove_managed+0x10f/0x120 x86_vector_free_irqs+0xa1/0x180 x86_vector_alloc_irqs+0x1e4/0x3a0 msi_domain_alloc+0x62/0x130 The reason for this is that if the vector allocation fails the error handling code tries to free the failed vector as well, which causes the above imbalance warning to trigger. Adjust the error path to handle this correctly. Fixes: b5dc8e6c21e7 ("x86/irq: Use hierarchical irqdomain to manage CPU interrupt vectors") Reported-by: Keith Busch <keith.busch@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Keith Busch <keith.busch@intel.com> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1801161217300.1823@nanos Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/tsc: Fix erroneous TSC rate on Skylake XeonLen Brown
commit b511203093489eb1829cb4de86e8214752205ac6 upstream. The INTEL_FAM6_SKYLAKE_X hardcoded crystal_khz value of 25MHZ is problematic: - SKX workstations (with same model # as server variants) use a 24 MHz crystal. This results in a -4.0% time drift rate on SKX workstations. - SKX servers subject the crystal to an EMI reduction circuit that reduces its actual frequency by (approximately) -0.25%. This results in -1 second per 10 minute time drift as compared to network time. This issue can also trigger a timer and power problem, on configurations that use the LAPIC timer (versus the TSC deadline timer). Clock ticks scheduled with the LAPIC timer arrive a few usec before the time they are expected (according to the slow TSC). This causes Linux to poll-idle, when it should be in an idle power saving state. The idle and clock code do not graciously recover from this error, sometimes resulting in significant polling and measurable power impact. Stop using native_calibrate_tsc() for INTEL_FAM6_SKYLAKE_X. native_calibrate_tsc() will return 0, boot will run with tsc_khz = cpu_khz, and the TSC refined calibration will update tsc_khz to correct for the difference. [ tglx: Sanitized change log ] Fixes: 6baf3d61821f ("x86/tsc: Add additional Intel CPU models to the crystal quirk list") Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: peterz@infradead.org Cc: Prarit Bhargava <prarit@redhat.com> Link: https://lkml.kernel.org/r/ff6dcea166e8ff8f2f6a03c17beab2cb436aa779.1513920414.git.len.brown@intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/mm/pkeys: Fix fill_sig_info_pkeyEric W. Biederman
commit beacd6f7ed5e2915959442245b3b2480c2e37490 upstream. SEGV_PKUERR is a signal specific si_code which happens to have the same numeric value as several others: BUS_MCEERR_AR, ILL_ILLTRP, FPE_FLTOVF, TRAP_HWBKPT, CLD_TRAPPED, POLL_ERR, SEGV_THREAD_ID, as such it is not safe to just test the si_code the signal number must also be tested to prevent a false positive in fill_sig_info_pkey. This error was by inspection, and BUS_MCEERR_AR appears to be a real candidate for confusion. So pass in si_signo and check for SIG_SEGV to verify that it is actually a SEGV_PKUERR Fixes: 019132ff3daf ("x86/mm/pkeys: Fill in pkey field in siginfo") Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Link: https://lkml.kernel.org/r/20180112203135.4669-2-ebiederm@xmission.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/cpufeature: Move processor tracing out of scattered featuresPaolo Bonzini
commit 4fdec2034b7540dda461c6ba33325dfcff345c64 upstream. Processor tracing is already enumerated in word 9 (CPUID[7,0].EBX), so do not duplicate it in the scattered features word. Besides being more tidy, this will be useful for KVM when it presents processor tracing to the guests. KVM selects host features that are supported by both the host kernel (depending on command line options, CPU errata, or whatever) and KVM. Whenever a full feature word exists, KVM's code is written in the expectation that the CPUID bit number matches the X86_FEATURE_* bit number, but this is not the case for X86_FEATURE_INTEL_PT. Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Cc: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luwei Kang <luwei.kang@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: kvm@vger.kernel.org Link: http://lkml.kernel.org/r/1516117345-34561-1-git-send-email-pbonzini@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/retpoline: Add LFENCE to the retpoline/RSB filling RSB macrosTom Lendacky
commit 28d437d550e1e39f805d99f9f8ac399c778827b7 upstream. The PAUSE instruction is currently used in the retpoline and RSB filling macros as a speculation trap. The use of PAUSE was originally suggested because it showed a very, very small difference in the amount of cycles/time used to execute the retpoline as compared to LFENCE. On AMD, the PAUSE instruction is not a serializing instruction, so the pause/jmp loop will use excess power as it is speculated over waiting for return to mispredict to the correct target. The RSB filling macro is applicable to AMD, and, if software is unable to verify that LFENCE is serializing on AMD (possible when running under a hypervisor), the generic retpoline support will be used and, so, is also applicable to AMD. Keep the current usage of PAUSE for Intel, but add an LFENCE instruction to the speculation trap for AMD. The same sequence has been adopted by GCC for the GCC generated retpolines. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@alien8.de> Acked-by: David Woodhouse <dwmw@amazon.co.uk> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Paul Turner <pjt@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Jiri Kosina <jikos@kernel.org> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Kees Cook <keescook@google.com> Link: https://lkml.kernel.org/r/20180113232730.31060.36287.stgit@tlendack-t1.amdoffice.net Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/retpoline: Fill RSB on context switch for affected CPUsDavid Woodhouse
commit c995efd5a740d9cbafbf58bde4973e8b50b4d761 upstream. On context switch from a shallow call stack to a deeper one, as the CPU does 'ret' up the deeper side it may encounter RSB entries (predictions for where the 'ret' goes to) which were populated in userspace. This is problematic if neither SMEP nor KPTI (the latter of which marks userspace pages as NX for the kernel) are active, as malicious code in userspace may then be executed speculatively. Overwrite the CPU's return prediction stack with calls which are predicted to return to an infinite loop, to "capture" speculation if this happens. This is required both for retpoline, and also in conjunction with IBRS for !SMEP && !KPTI. On Skylake+ the problem is slightly different, and an *underflow* of the RSB may cause errant branch predictions to occur. So there it's not so much overwrite, as *filling* the RSB to attempt to prevent it getting empty. This is only a partial solution for Skylake+ since there are many other conditions which may result in the RSB becoming empty. The full solution on Skylake+ is to use IBRS, which will prevent the problem even when the RSB becomes empty. With IBRS, the RSB-stuffing will not be required on context switch. [ tglx: Added missing vendor check and slighty massaged comments and changelog ] Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515779365-9032-1-git-send-email-dwmw@amazon.co.uk Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/pti/efi: broken conversion from efi to kernel page tablePavel Tatashin
The page table order must be increased for EFI table in order to avoid a bug where NMI tries to change the page table to kernel page table, while efi page table is active. For more disccussion about this bug, see this thread: http://lkml.iu.edu/hypermail/linux/kernel/1801.1/00951.html Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Reviewed-by: Steven Sistare <steven.sistare@oracle.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/retpoline: Remove compile time warningThomas Gleixner
commit b8b9ce4b5aec8de9e23cabb0a26b78641f9ab1d6 upstream. Remove the compile time warning when CONFIG_RETPOLINE=y and the compiler does not have retpoline support. Linus rationale for this is: It's wrong because it will just make people turn off RETPOLINE, and the asm updates - and return stack clearing - that are independent of the compiler are likely the most important parts because they are likely the ones easiest to target. And it's annoying because most people won't be able to do anything about it. The number of people building their own compiler? Very small. So if their distro hasn't got a compiler yet (and pretty much nobody does), the warning is just annoying crap. It is already properly reported as part of the sysfs interface. The compile-time warning only encourages bad things. Fixes: 76b043848fd2 ("x86/retpoline: Add initial retpoline support") Requested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: David Woodhouse <dwmw@amazon.co.uk> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Link: https://lkml.kernel.org/r/CA+55aFzWgquv4i6Mab6bASqYXg3ErV3XDFEYf=GEcCDQg5uAtw@mail.gmail.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/retpoline: Fill return stack buffer on vmexitDavid Woodhouse
commit 117cc7a908c83697b0b737d15ae1eb5943afe35b upstream. In accordance with the Intel and AMD documentation, we need to overwrite all entries in the RSB on exiting a guest, to prevent malicious branch target predictions from affecting the host kernel. This is needed both for retpoline and for IBRS. [ak: numbers again for the RSB stuffing labels] Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515755487-8524-1-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/retpoline/irq32: Convert assembler indirect jumpsAndi Kleen
commit 7614e913db1f40fff819b36216484dc3808995d4 upstream. Convert all indirect jumps in 32bit irq inline asm code to use non speculative sequences. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-12-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/retpoline/checksum32: Convert assembler indirect jumpsDavid Woodhouse
commit 5096732f6f695001fa2d6f1335a2680b37912c69 upstream. Convert all indirect jumps in 32bit checksum assembler code to use non-speculative sequences when CONFIG_RETPOLINE is enabled. Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-11-git-send-email-dwmw@amazon.co.uk Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/retpoline/xen: Convert Xen hypercall indirect jumpsDavid Woodhouse
commit ea08816d5b185ab3d09e95e393f265af54560350 upstream. Convert indirect call in Xen hypercall to use non-speculative sequence, when CONFIG_RETPOLINE is enabled. Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Reviewed-by: Juergen Gross <jgross@suse.com> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-10-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/retpoline/ftrace: Convert ftrace assembler indirect jumpsDavid Woodhouse
commit 9351803bd803cdbeb9b5a7850b7b6f464806e3db upstream. Convert all indirect jumps in ftrace assembler code to use non-speculative sequences when CONFIG_RETPOLINE is enabled. Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-8-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/retpoline/entry: Convert entry assembler indirect jumpsDavid Woodhouse
commit 2641f08bb7fc63a636a2b18173221d7040a3512e upstream. Convert indirect jumps in core 32/64bit entry assembler code to use non-speculative sequences when CONFIG_RETPOLINE is enabled. Don't use CALL_NOSPEC in entry_SYSCALL_64_fastpath because the return address after the 'call' instruction must be *precisely* at the .Lentry_SYSCALL_64_after_fastpath label for stub_ptregs_64 to work, and the use of alternatives will mess that up unless we play horrid games to prepend with NOPs and make the variants the same length. It's not worth it; in the case where we ALTERNATIVE out the retpoline, the first instruction at __x86.indirect_thunk.rax is going to be a bare jmp *%rax anyway. Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-7-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/retpoline/crypto: Convert crypto assembler indirect jumpsDavid Woodhouse
commit 9697fa39efd3fc3692f2949d4045f393ec58450b upstream. Convert all indirect jumps in crypto assembler code to use non-speculative sequences when CONFIG_RETPOLINE is enabled. Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-6-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/spectre: Add boot time option to select Spectre v2 mitigationDavid Woodhouse
commit da285121560e769cc31797bba6422eea71d473e0 upstream. Add a spectre_v2= option to select the mitigation used for the indirect branch speculation vulnerability. Currently, the only option available is retpoline, in its various forms. This will be expanded to cover the new IBRS/IBPB microcode features. The RETPOLINE_AMD feature relies on a serializing LFENCE for speculation control. For AMD hardware, only set RETPOLINE_AMD if LFENCE is a serializing instruction, which is indicated by the LFENCE_RDTSC feature. [ tglx: Folded back the LFENCE/AMD fixes and reworked it so IBRS integration becomes simple ] Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-5-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/retpoline: Add initial retpoline supportDavid Woodhouse
commit 76b043848fd22dbf7f8bf3a1452f8c70d557b860 upstream. Enable the use of -mindirect-branch=thunk-extern in newer GCC, and provide the corresponding thunks. Provide assembler macros for invoking the thunks in the same way that GCC does, from native and inline assembler. This adds X86_FEATURE_RETPOLINE and sets it by default on all CPUs. In some circumstances, IBRS microcode features may be used instead, and the retpoline can be disabled. On AMD CPUs if lfence is serialising, the retpoline can be dramatically simplified to a simple "lfence; jmp *\reg". A future patch, after it has been verified that lfence really is serialising in all circumstances, can enable this by setting the X86_FEATURE_RETPOLINE_AMD feature bit in addition to X86_FEATURE_RETPOLINE. Do not align the retpoline in the altinstr section, because there is no guarantee that it stays aligned when it's copied over the oldinstr during alternative patching. [ Andi Kleen: Rename the macros, add CONFIG_RETPOLINE option, export thunks] [ tglx: Put actual function CALL/JMP in front of the macros, convert to symbolic labels ] [ dwmw2: Convert back to numeric labels, merge objtool fixes ] Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-4-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/asm: Use register variable to get stack pointer valueAndrey Ryabinin
commit 196bd485ee4f03ce4c690bfcf38138abfcd0a4bc upstream. Currently we use current_stack_pointer() function to get the value of the stack pointer register. Since commit: f5caf621ee35 ("x86/asm: Fix inline asm call constraints for Clang") ... we have a stack register variable declared. It can be used instead of current_stack_pointer() function which allows to optimize away some excessive "mov %rsp, %<dst>" instructions: -mov %rsp,%rdx -sub %rdx,%rax -cmp $0x3fff,%rax -ja ffffffff810722fd <ist_begin_non_atomic+0x2d> +sub %rsp,%rax +cmp $0x3fff,%rax +ja ffffffff810722fa <ist_begin_non_atomic+0x2a> Remove current_stack_pointer(), rename __asm_call_sp to current_stack_pointer and use it instead of the removed function. Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170929141537.29167-1-aryabinin@virtuozzo.com Signed-off-by: Ingo Molnar <mingo@kernel.org> [dwmw2: We want ASM_CALL_CONSTRAINT for retpoline] Signed-off-by: David Woodhouse <dwmw@amazon.co.ku> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/mm/32: Move setup_clear_cpu_cap(X86_FEATURE_PCID) earlierAndy Lutomirski
commit b8b7abaed7a49b350f8ba659ddc264b04931d581 upstream. Otherwise we might have the PCID feature bit set during cpu_init(). This is just for robustness. I haven't seen any actual bugs here. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bpetkov@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: cba4671af755 ("x86/mm: Disable PCID on 32-bit kernels") Link: http://lkml.kernel.org/r/b16dae9d6b0db5d9801ddbebbfd83384097c61f3.1505663533.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/alternatives: Add missing '\n' at end of ALTERNATIVE inline asmDavid Woodhouse
commit b9e705ef7cfaf22db0daab91ad3cd33b0fa32eb9 upstream. Where an ALTERNATIVE is used in the middle of an inline asm block, this would otherwise lead to the following instruction being appended directly to the trailing ".popsection", and a failed compile. Fixes: 9cebed423c84 ("x86, alternative: Use .pushsection/.popsection") Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: ak@linux.intel.com Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Turner <pjt@google.com> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180104143710.8961-8-dwmw@amazon.co.uk Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/alternatives: Fix optimize_nops() checkingBorislav Petkov
commit 612e8e9350fd19cae6900cf36ea0c6892d1a0dca upstream. The alternatives code checks only the first byte whether it is a NOP, but with NOPs in front of the payload and having actual instructions after it breaks the "optimized' test. Make sure to scan all bytes before deciding to optimize the NOPs in there. Reported-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Tom Lendacky <thomas.lendacky@amd.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Andrew Lutomirski <luto@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/20180110112815.mgciyf5acwacphkq@pd.tnic Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/cpu/AMD: Use LFENCE_RDTSC in preference to MFENCE_RDTSCTom Lendacky
commit 9c6a73c75864ad9fa49e5fa6513e4c4071c0e29f upstream. With LFENCE now a serializing instruction, use LFENCE_RDTSC in preference to MFENCE_RDTSC. However, since the kernel could be running under a hypervisor that does not support writing that MSR, read the MSR back and verify that the bit has been set successfully. If the MSR can be read and the bit is set, then set the LFENCE_RDTSC feature, otherwise set the MFENCE_RDTSC feature. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: David Woodhouse <dwmw@amazon.co.uk> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/20180108220932.12580.52458.stgit@tlendack-t1.amdoffice.net Signed-off-by: Razvan Ghitulete <rga@amazon.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/cpu/AMD: Make LFENCE a serializing instructionTom Lendacky
commit e4d0e84e490790798691aaa0f2e598637f1867ec upstream. To aid in speculation control, make LFENCE a serializing instruction since it has less overhead than MFENCE. This is done by setting bit 1 of MSR 0xc0011029 (DE_CFG). Some families that support LFENCE do not have this MSR. For these families, the LFENCE instruction is already serializing. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: David Woodhouse <dwmw@amazon.co.uk> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/20180108220921.12580.71694.stgit@tlendack-t1.amdoffice.net Signed-off-by: Razvan Ghitulete <rga@amazon.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/cpu: Implement CPU vulnerabilites sysfs functionsThomas Gleixner
commit 61dc0f555b5c761cdafb0ba5bd41ecf22d68a4c4 upstream. Implement the CPU vulnerabilty show functions for meltdown, spectre_v1 and spectre_v2. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Linus Torvalds <torvalds@linuxfoundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: David Woodhouse <dwmw@amazon.co.uk> Link: https://lkml.kernel.org/r/20180107214913.177414879@linutronix.de Signed-off-by: Razvan Ghitulete <rga@amazon.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/cpu: Merge bugs.c and bugs_64.cBorislav Petkov
commit 62a67e123e058a67db58bc6a14354dd037bafd0a upstream. Should be easier when following boot paths. It probably is a left over from the x86 unification eons ago. No functionality change. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20161024173844.23038-3-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Razvan Ghitulete <rga@amazon.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/cpufeatures: Add X86_BUG_SPECTRE_V[12]David Woodhouse
commit 99c6fa2511d8a683e61468be91b83f85452115fa upstream. Add the bug bits for spectre v1/2 and force them unconditionally for all cpus. Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/1515239374-23361-2-git-send-email-dwmw@amazon.co.uk Signed-off-by: Razvan Ghitulete <rga@amazon.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/pti: Rename BUG_CPU_INSECURE to BUG_CPU_MELTDOWNThomas Gleixner
commit de791821c295cc61419a06fe5562288417d1bc58 upstream. Use the name associated with the particular attack which needs page table isolation for mitigation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw@amazon.co.uk> Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk> Cc: Jiri Koshina <jikos@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Andi Lutomirski <luto@amacapital.net> Cc: Andi Kleen <ak@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Turner <pjt@google.com> Cc: Tom Lendacky <thomas.lendacky@amd.com> Cc: Greg KH <gregkh@linux-foundation.org> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1801051525300.1724@nanos Signed-off-by: Razvan Ghitulete <rga@amazon.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/cpufeatures: Add X86_BUG_CPU_INSECUREThomas Gleixner
commit a89f040fa34ec9cd682aed98b8f04e3c47d998bd upstream. Many x86 CPUs leak information to user space due to missing isolation of user space and kernel space page tables. There are many well documented ways to exploit that. The upcoming software migitation of isolating the user and kernel space page tables needs a misfeature flag so code can be made runtime conditional. Add the BUG bits which indicates that the CPU is affected and add a feature bit which indicates that the software migitation is enabled. Assume for now that _ALL_ x86 CPUs are affected by this. Exceptions can be made later. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: David Laight <David.Laight@aculab.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Eduardo Valentin <eduval@amazon.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: aliguori@amazon.com Cc: daniel.gruss@iaik.tugraz.at Cc: hughd@google.com Cc: keescook@google.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/cpufeatures: Make CPU bugs stickyThomas Gleixner
commit 6cbd2171e89b13377261d15e64384df60ecb530e upstream. There is currently no way to force CPU bug bits like CPU feature bits. That makes it impossible to set a bug bit once at boot and have it stick for all upcoming CPUs. Extend the force set/clear arrays to handle bug bits as well. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bpetkov@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: David Laight <David.Laight@aculab.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Eduardo Valentin <eduval@amazon.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Will Deacon <will.deacon@arm.com> Cc: aliguori@amazon.com Cc: daniel.gruss@iaik.tugraz.at Cc: hughd@google.com Cc: keescook@google.com Link: https://lkml.kernel.org/r/20171204150606.992156574@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/cpu: Factor out application of forced CPU capsAndy Lutomirski
commit 8bf1ebca215c262e48c15a4a15f175991776f57f upstream. There are multiple call sites that apply forced CPU caps. Factor them into a helper. Signed-off-by: Andy Lutomirski <luto@kernel.org> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matthew Whitehead <tedheadster@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: One Thousand Gnomes <gnomes@lxorguk.ukuu.org.uk> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/623ff7555488122143e4417de09b18be2085ad06.1484705016.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17kaiser: Set _PAGE_NX only if supportedLepton Wu
This finally resolve crash if loaded under qemu + haxm. Haitao Shan pointed out that the reason of that crash is that NX bit get set for page tables. It seems we missed checking if _PAGE_NX is supported in kaiser_add_user_map Link: https://www.spinics.net/lists/kernel/msg2689835.html Reviewed-by: Guenter Roeck <groeck@chromium.org> Signed-off-by: Lepton Wu <ytht.net@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17KVM: x86: Add memory barrier on vmcs field lookupAndrew Honig
commit 75f139aaf896d6fdeec2e468ddfa4b2fe469bf40 upstream. This adds a memory barrier when performing a lookup into the vmcs_field_to_offset_table. This is related to CVE-2017-5753. Signed-off-by: Andrew Honig <ahonig@google.com> Reviewed-by: Jim Mattson <jmattson@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/microcode/intel: Extend BDW late-loading with a revision checkJia Zhang
commit b94b7373317164402ff7728d10f7023127a02b60 upstream. Instead of blacklisting all model 79 CPUs when attempting a late microcode loading, limit that only to CPUs with microcode revisions < 0x0b000021 because only on those late loading may cause a system hang. For such processors either: a) a BIOS update which might contain a newer microcode revision or b) the early microcode loading method should be considered. Processors with revisions 0x0b000021 or higher will not experience such hangs. For more details, see erratum BDF90 in document #334165 (Intel Xeon Processor E7-8800/4800 v4 Product Family Specification Update) from September 2017. [ bp: Heavily massage commit message and pr_* statements. ] Fixes: 723f2828a98c ("x86/microcode/intel: Disable late loading on model 79") Signed-off-by: Jia Zhang <qianyue.zj@alibaba-inc.com> Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Tony Luck <tony.luck@intel.com> Cc: x86-ml <x86@kernel.org> Link: http://lkml.kernel.org/r/1514772287-92959-1-git-send-email-qianyue.zj@alibaba-inc.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/acpi: Reduce code duplication in mp_override_legacy_irq()Vikas C Sajjan
commit 4ee2ec1b122599f7b10c849fa7915cebb37b7edb upstream. The new function mp_register_ioapic_irq() is a subset of the code in mp_override_legacy_irq(). Replace the code duplication by invoking mp_register_ioapic_irq() from mp_override_legacy_irq(). Signed-off-by: Vikas C Sajjan <vikas.cha.sajjan@hpe.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: linux-pm@vger.kernel.org Cc: kkamagui@gmail.com Cc: linux-acpi@vger.kernel.org Link: https://lkml.kernel.org/r/1510848825-21965-3-git-send-email-vikas.cha.sajjan@hpe.com Cc: Jean Delvare <jdelvare@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/acpi: Handle SCI interrupts above legacy space gracefullyVikas C Sajjan
commit 252714155f04c5d16989cb3aadb85fd1b5772f99 upstream. Platforms which support only IOAPIC mode, pass the SCI information above the legacy space (0-15) via the FADT mechanism and not via MADT. In such cases mp_override_legacy_irq() which is invoked from acpi_sci_ioapic_setup() to register SCI interrupts fails for interrupts greater equal 16, since it is meant to handle only the legacy space and emits error "Invalid bus_irq %u for legacy override". Add a new function to handle SCI interrupts >= 16 and invoke it conditionally in acpi_sci_ioapic_setup(). The code duplication due to this new function will be cleaned up in a separate patch. Co-developed-by: Sunil V L <sunil.vl@hpe.com> Signed-off-by: Vikas C Sajjan <vikas.cha.sajjan@hpe.com> Signed-off-by: Sunil V L <sunil.vl@hpe.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Abdul Lateef Attar <abdul-lateef.attar@hpe.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: linux-pm@vger.kernel.org Cc: kkamagui@gmail.com Cc: linux-acpi@vger.kernel.org Link: https://lkml.kernel.org/r/1510848825-21965-2-git-send-email-vikas.cha.sajjan@hpe.com Cc: Jean Delvare <jdelvare@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17kvm: vmx: Scrub hardware GPRs at VM-exitJim Mattson
commit 0cb5b30698fdc8f6b4646012e3acb4ddce430788 upstream. Guest GPR values are live in the hardware GPRs at VM-exit. Do not leave any guest values in hardware GPRs after the guest GPR values are saved to the vcpu_vmx structure. This is a partial mitigation for CVE 2017-5715 and CVE 2017-5753. Specifically, it defeats the Project Zero PoC for CVE 2017-5715. Suggested-by: Eric Northup <digitaleric@google.com> Signed-off-by: Jim Mattson <jmattson@google.com> Reviewed-by: Eric Northup <digitaleric@google.com> Reviewed-by: Benjamin Serebrin <serebrin@google.com> Reviewed-by: Andrew Honig <ahonig@google.com> [Paolo: Add AMD bits, Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>] Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17MIPS: Disallow outsized PTRACE_SETREGSET NT_PRFPREG regset accessesMaciej W. Rozycki
commit c8c5a3a24d395b14447a9a89d61586a913840a3b upstream. Complement commit c23b3d1a5311 ("MIPS: ptrace: Change GP regset to use correct core dump register layout") and also reject outsized PTRACE_SETREGSET requests to the NT_PRFPREG regset, like with the NT_PRSTATUS regset. Signed-off-by: Maciej W. Rozycki <macro@mips.com> Fixes: c23b3d1a5311 ("MIPS: ptrace: Change GP regset to use correct core dump register layout") Cc: James Hogan <james.hogan@mips.com> Cc: Paul Burton <Paul.Burton@mips.com> Cc: Alex Smith <alex@alex-smith.me.uk> Cc: Dave Martin <Dave.Martin@arm.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/17930/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17MIPS: Also verify sizeof `elf_fpreg_t' with PTRACE_SETREGSETMaciej W. Rozycki
commit 006501e039eec411842bb3150c41358867d320c2 upstream. Complement commit d614fd58a283 ("mips/ptrace: Preserve previous registers for short regset write") and like with the PTRACE_GETREGSET ptrace(2) request also apply a BUILD_BUG_ON check for the size of the `elf_fpreg_t' type in the PTRACE_SETREGSET request handler. Signed-off-by: Maciej W. Rozycki <macro@mips.com> Fixes: d614fd58a283 ("mips/ptrace: Preserve previous registers for short regset write") Cc: James Hogan <james.hogan@mips.com> Cc: Paul Burton <Paul.Burton@mips.com> Cc: Alex Smith <alex@alex-smith.me.uk> Cc: Dave Martin <Dave.Martin@arm.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/17929/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17MIPS: Fix an FCSR access API regression with NT_PRFPREG and MSAMaciej W. Rozycki
commit be07a6a1188372b6d19a3307ec33211fc9c9439d upstream. Fix a commit 72b22bbad1e7 ("MIPS: Don't assume 64-bit FP registers for FP regset") public API regression, then activated by commit 1db1af84d6df ("MIPS: Basic MSA context switching support"), that caused the FCSR register not to be read or written for CONFIG_CPU_HAS_MSA kernel configurations (regardless of actual presence or absence of the MSA feature in a given processor) with ptrace(2) PTRACE_GETREGSET and PTRACE_SETREGSET requests nor recorded in core dumps. This is because with !CONFIG_CPU_HAS_MSA configurations the whole of `elf_fpregset_t' array is bulk-copied as it is, which includes the FCSR in one half of the last, 33rd slot, whereas with CONFIG_CPU_HAS_MSA configurations array elements are copied individually, and then only the leading 32 FGR slots while the remaining slot is ignored. Correct the code then such that only FGR slots are copied in the respective !MSA and MSA helpers an then the FCSR slot is handled separately in common code. Use `ptrace_setfcr31' to update the FCSR too, so that the read-only mask is respected. Retrieving a correct value of FCSR is important in debugging not only for the human to be able to get the right interpretation of the situation, but for correct operation of GDB as well. This is because the condition code bits in FSCR are used by GDB to determine the location to place a breakpoint at when single-stepping through an FPU branch instruction. If such a breakpoint is placed incorrectly (i.e. with the condition reversed), then it will be missed, likely causing the debuggee to run away from the control of GDB and consequently breaking the process of investigation. Fortunately GDB continues using the older PTRACE_GETFPREGS ptrace(2) request which is unaffected, so the regression only really hits with post-mortem debug sessions using a core dump file, in which case execution, and consequently single-stepping through branches is not possible. Of course core files created by buggy kernels out there will have the value of FCSR recorded clobbered, but such core files cannot be corrected and the person using them simply will have to be aware that the value of FCSR retrieved is not reliable. Which also means we can likely get away without defining a replacement API which would ensure a correct value of FSCR to be retrieved, or none at all. This is based on previous work by Alex Smith, extensively rewritten. Signed-off-by: Alex Smith <alex@alex-smith.me.uk> Signed-off-by: James Hogan <james.hogan@mips.com> Signed-off-by: Maciej W. Rozycki <macro@mips.com> Fixes: 72b22bbad1e7 ("MIPS: Don't assume 64-bit FP registers for FP regset") Cc: Paul Burton <Paul.Burton@mips.com> Cc: Dave Martin <Dave.Martin@arm.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/17928/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17MIPS: Consistently handle buffer counter with PTRACE_SETREGSETMaciej W. Rozycki
commit 80b3ffce0196ea50068885d085ff981e4b8396f4 upstream. Update commit d614fd58a283 ("mips/ptrace: Preserve previous registers for short regset write") bug and consistently consume all data supplied to `fpr_set_msa' with the ptrace(2) PTRACE_SETREGSET request, such that a zero data buffer counter is returned where insufficient data has been given to fill a whole number of FP general registers. In reality this is not going to happen, as the caller is supposed to only supply data covering a whole number of registers and it is verified in `ptrace_regset' and again asserted in `fpr_set', however structuring code such that the presence of trailing partial FP general register data causes `fpr_set_msa' to return with a non-zero data buffer counter makes it appear that this trailing data will be used if there are subsequent writes made to FP registers, which is going to be the case with the FCSR once the missing write to that register has been fixed. Fixes: d614fd58a283 ("mips/ptrace: Preserve previous registers for short regset write") Signed-off-by: Maciej W. Rozycki <macro@mips.com> Cc: James Hogan <james.hogan@mips.com> Cc: Paul Burton <Paul.Burton@mips.com> Cc: Alex Smith <alex@alex-smith.me.uk> Cc: Dave Martin <Dave.Martin@arm.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/17927/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
