commit d974baa398f34393db76be45f7d4d04fbdbb4a0a upstream.
CR4 isn't constant; at least the TSD and PCE bits can vary.
TBH, treating CR0 and CR3 as constant scares me a bit, too, but it looks
like it's correct.
This adds a branch and a read from cr4 to each vm entry. Because it is
extremely likely that consecutive entries into the same vcpu will have
the same host cr4 value, this fixes up the vmcs instead of restoring cr4
after the fact. A subsequent patch will add a kernel-wide cr4 shadow,
reducing the overhead in the common case to just two memory reads and a
branch.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: Petr Matousek <pmatouse@redhat.com>
Cc: Gleb Natapov <gleb@kernel.org>
[wangkai: Backport to 3.10: adjust context]
Signed-off-by: Wang Kai <morgan.wang@huawei.com>
commit a642fc305053cc1c6e47e4f4df327895747ab485 upstream.
On systems with invvpid instruction support (corresponding bit in
IA32_VMX_EPT_VPID_CAP MSR is set) guest invocation of invvpid
causes vm exit, which is currently not handled and results in
propagation of unknown exit to userspace.
Fix this by installing an invvpid vm exit handler.
This is CVE-2014-3646.
Cc: stable@vger.kernel.org
Signed-off-by: Petr Matousek <pmatouse@redhat.com>
commit 44b82b7700d05a52cd983799d3ecde1a976b3bed upstream.
Commit d7a49086f263164a (arm64: cpuinfo: print info for all CPUs)
attempted to clean up /proc/cpuinfo, but due to concerns regarding
further changes was reverted in commit 5e39977edf6500fd (Revert "arm64:
cpuinfo: print info for all CPUs").
There are two major issues with the arm64 /proc/cpuinfo format
currently:
* The "Features" line describes (only) the 64-bit hwcaps, which is
problematic for some 32-bit applications which attempt to parse it. As
the same names are used for analogous ISA features (e.g. aes) despite
these generally being architecturally unrelated, it is not possible to
simply append the 64-bit and 32-bit hwcaps in a manner that might not
be misleading to some applications.
Various potential solutions have appeared in vendor kernels. Typically
the format of the Features line varies depending on whether the task
is 32-bit.
* Information is only printed regarding a single CPU. This does not
match the ARM format, and does not provide sufficient information in
big.LITTLE systems where CPUs are heterogeneous. The CPU information
printed is queried from the current CPU's registers, which is racy
w.r.t. cross-cpu migration.
This patch attempts to solve these issues. The following changes are
made:
* When a task with a LINUX32 personality attempts to read /proc/cpuinfo,
the "Features" line contains the decoded 32-bit hwcaps, as with the
arm port. Otherwise, the decoded 64-bit hwcaps are shown. This aligns
with the behaviour of COMPAT_UTS_MACHINE and COMPAT_ELF_PLATFORM. In
the absense of compat support, the Features line is empty.
The set of hwcaps injected into a task's auxval are unaffected.
* Properties are printed per-cpu, as with the ARM port. The per-cpu
information is queried from pre-recorded cpu information (as used by
the sanity checks).
* As with the previous attempt at fixing up /proc/cpuinfo, the hardware
field is removed. The only users so far are 32-bit applications tied
to particular boards, so no portable applications should be affected,
and this should prevent future tying to particular boards.
The following differences remain:
* No model_name is printed, as this cannot be queried from the hardware
and cannot be provided in a stable fashion. Use of the CPU
{implementor,variant,part,revision} fields is sufficient to identify a
CPU and is portable across arm and arm64.
* The following system-wide properties are not provided, as they are not
possible to provide generally. Programs relying on these are already
tied to particular (32-bit only) boards:
- Hardware
- Revision
- Serial
No software has yet been identified for which these remaining
differences are problematic.
Cc: Greg Hackmann <ghackmann@google.com>
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Serban Constantinescu <serban.constantinescu@arm.com>
Cc: cross-distro@lists.linaro.org
Cc: linux-api@vger.kernel.org
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
[Mark: backport to v3.10.x]
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
commit c7754e75100ed5e3068ac5085747f2bfc386c8d6 upstream.
As printk() invocation can cause e.g. a TLB miss, printk() cannot be
called before the exception handlers have been properly initialized.
This can happen e.g. when netconsole has been loaded as a kernel module
and the TLB table has been cleared when a CPU was offline.
Call cpu_report() in start_secondary() only after the exception handlers
have been initialized to fix this.
Without the patch the kernel will randomly either lockup or crash
after a CPU is onlined and the console driver is a module.
Signed-off-by: Hemmo Nieminen <hemmo.nieminen@iki.fi>
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: David Daney <david.daney@cavium.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/8953/
commit a3e6c1eff54878506b2dddcc202df9cc8180facb upstream.
If the irq_chip does not define .irq_disable, any call to disable_irq
will defer disabling the IRQ until it fires while marked as disabled.
This assumes that the handler function checks for this condition, which
handle_percpu_irq does not. In this case, calling disable_irq leads to
an IRQ storm, if the interrupt fires while disabled.
This optimization is only useful when disabling the IRQ is slow, which
is not true for the MIPS CPU IRQ.
Disable this optimization by implementing .irq_disable and .irq_enable
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Patchwork: https://patchwork.linux-mips.org/patch/8949/
commit 51ac3d2f0c505ca36ffc9715ffd518d756589ef8 upstream.
NEC OEMs the same platforms as Stratus does, which have multiple devices on
some PCIe buses under downstream ports.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=51331
Fixes: 1278998f8ff6 ("PCI: Work around Stratus ftServer broken PCIe hierarchy (fix DMI check)")
Signed-off-by: Charlotte Richardson <charlotte.richardson@stratus.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: Myron Stowe <myron.stowe@redhat.com>
commit ded9477984690d026e46dd75e8157392cea3f13f upstream.
For LPAE, we have the following means for encoding writable or dirty
ptes:
L_PTE_DIRTY L_PTE_RDONLY
!pte_dirty && !pte_write 0 1
!pte_dirty && pte_write 0 1
pte_dirty && !pte_write 1 1
pte_dirty && pte_write 1 0
So we can't distinguish between writeable clean ptes and read only
ptes. This can cause problems with ptes being incorrectly flagged as
read only when they are writeable but not dirty.
This patch renumbers L_PTE_RDONLY from AP[2] to a software bit #58,
and adds additional logic to set AP[2] whenever the pte is read only
or not dirty. That way we can distinguish between clean writeable ptes
and read only ptes.
HugeTLB pages will use this new logic automatically.
We need to add some logic to Transparent HugePages to ensure that they
correctly interpret the revised pgprot permissions (L_PTE_RDONLY has
moved and no longer matches PMD_SECT_AP2). In the process of revising
THP, the names of the PMD software bits have been prefixed with L_ to
make them easier to distinguish from their hardware bit counterparts.
Signed-off-by: Steve Capper <steve.capper@linaro.org>
Reviewed-by: Will Deacon <will.deacon@arm.com>
[hpy: Backported to 3.10
- adjust the context
- ignore change related to pmd, because 3.10 does not support HugePage ]
Signed-off-by: Hou Pengyang <houpengyang@huawei.com>
commit f2950706871c4b6e8c0f0d7c3f62d35930b8de63 upstream.
Long descriptors on ARM are 64 bits, and some pte functions such as
pte_dirty return a bitwise-and of a flag with the pte value. If the
flag to be tested resides in the upper 32 bits of the pte, then we run
into the danger of the result being dropped if downcast.
For example:
gather_stats(page, md, pte_dirty(*pte), 1);
where pte_dirty(*pte) is downcast to an int.
This patch introduces a new macro pte_isset which performs the bitwise
and, then performs a double logical invert (where needed) to ensure
predictable downcasting. The logical inverse pte_isclear is also
introduced.
Equivalent pmd functions for Transparent HugePages have also been
added.
[hpy: Backported to 3.10:
- ignore change to pmd, because 3.10 does not support HugePage.]
commit 6b076991dca9817e75c37e2f0db6d52611ea42fa upstream.
When setting up the CMA region, we must ensure that the old section
mappings are flushed from the TLB before replacing them with page
tables, otherwise we can suffer from mismatched aliases if the CPU
speculatively prefetches from these mappings at an inopportune time.
A mismatched alias can occur when the TLB contains a section mapping,
but a subsequent prefetch causes it to load a page table mapping,
resulting in the possibility of the TLB containing two matching
mappings for the same virtual address region.
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Hou Pengyang <houpengyang@huawei.com>
commit efea3403d4b7c6d1dd5d5ac3234c161e8b314d66 upstream.
The definition of virt_addr_valid is that virt_addr_valid should
return true if and only if virt_to_page returns a valid pointer.
The current definition of virt_addr_valid only checks against the
virtual address range. There's no guarantee that just because a
virtual address falls bewteen PAGE_OFFSET and high_memory the
associated physical memory has a valid backing struct page. Follow
the example of other architectures and convert to pfn_valid to
verify that the virtual address is actually valid. The check for
an address between PAGE_OFFSET and high_memory is still necessary
as vmalloc/highmem addresses are not valid with virt_to_page.
Cc: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
commit b713aa0b15015a65ad5421543b80df86de043d62 upstream.
Jason Gunthorpe reports a build failure when ARM_PATCH_PHYS_VIRT is
not defined:
In file included from arch/arm/include/asm/page.h:163:0,
from include/linux/mm_types.h:16,
from include/linux/sched.h:24,
from arch/arm/kernel/asm-offsets.c:13:
arch/arm/include/asm/memory.h: In function '__virt_to_phys':
arch/arm/include/asm/memory.h:244:40: error: 'PHYS_OFFSET' undeclared (first use in this function)
arch/arm/include/asm/memory.h:244:40: note: each undeclared identifier is reported only once for each function it appears in
arch/arm/include/asm/memory.h: In function '__phys_to_virt':
arch/arm/include/asm/memory.h:249:13: error: 'PHYS_OFFSET' undeclared (first use in this function)
Fixes: ca5a45c06cd4 ("ARM: mm: use phys_addr_t appropriately in p2v and v2p conversions")
Tested-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
- MPU is not supported by 3.10, so ignore fix to MPU compared with the original patch.]
in atomic_cmpxchg().
commit 4dcc1cf7316a26e112f5c9fcca531ff98ef44700 upstream.
For atomic_cmpxchg(), the type of 'oldval' need be 'int' to match the
type of "*ptr" (used by 'ldrex' instruction) and 'old' (used by 'teq'
instruction).
Signed-off-by: Chen Gang <gang.chen@asianux.com>
commit 237f12337cfa2175474e4dd015bc07a25eb9080d upstream.
atomic* value is signed value, and atomic* functions need also process
signed value (parameter value, and return value), so 32-bit arm need
use 'long long' instead of 'u64'.
After replacement, it will also fix a bug for atomic64_add_negative():
"u64 is never less than 0".
The modifications are:
in vim, use "1,% s/\<u64\>/long long/g" command.
remove '__aligned(8)' which is useless for 64-bit.
be sure of 80 column limitation after replacement.
commit e38a517578d6c0f764b0d0f6e26dcdf9f70c69d7 upstream.
For 2-level page tables, PTE_HWTABLE_PTRS describes the offset between
Linux PTEs and hardware PTEs. On LPAE, there is no distinction (since
we have 64-bit descriptors with plenty of space) so PTE_HWTABLE_PTRS
should be 0. Unfortunately, it is wrongly defined as PTRS_PER_PTE,
meaning that current pte table flushing is off by a page. Luckily,
all current LPAE implementations are SMP, so the hardware walker can
snoop L1.
This patch fixes the broken definition.
commit 5b20c5b2f014ecc0a6310988af69cd7ede9e7c67 upstream.
On LPAE machines, PHYS_OFFSET evaluates to a phys_addr_t and this type is
inherited by the PHYS_PFN_OFFSET definition as well. Consequently, the kernel
build emits warnings of the form:
init/main.c: In function 'start_kernel':
init/main.c:588:7: warning: format '%lx' expects argument of type 'long unsigned int', but argument 2 has type 'phys_addr_t' [-Wformat]
This patch fixes this warning by pinning down the PFN type to unsigned long.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Subash Patel <subash.rp@samsung.com>
commit 20d6956d8cd2452cec0889ff040f18afc03c2e6b upstream.
This patch fixes the alloc_init_pud() function to use phys_addr_t instead of
unsigned long when passing in the phys argument.
This is an extension to commit 97092e0c56830457af0639f6bd904537a150ea4a (ARM:
pgtable: use phys_addr_t for physical addresses), which applied similar changes
elsewhere in the ARM memory management code.
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
commit 926edcc747e2efb3c9add7ed4dbc4e7a3a959d02 upstream.
This patch applies to PAGE_MASK, PMD_MASK, and PGDIR_MASK, where forcing
unsigned long math truncates the mask at the 32-bits. This clearly does bad
things on PAE systems.
This patch fixes this problem by defining these masks as signed quantities.
We then rely on sign extension to do the right thing.
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
commit dde1b65110353517816bcbc58539463396202244 upstream.
For 3 levels of paging the PTE_EXT_NG bit will be set for user
address ptes that are written to a page table but not for ptes
created with mk_pte.
This can cause some comparison tests made by pte_same to fail
spuriously and lead to other problems.
To correct this behaviour, we mask off PTE_EXT_NG for any pte that
is present before running the comparison.
commit 849b882b52df0f276d9ffded01d85654aa0da422 upstream.
It appears that gcc may put some code in ".text.unlikely" or
".text.hot" sections. Right now those aren't accounted for in unwind
tables. Add them.
I found some docs about this at:
http://gcc.gnu.org/onlinedocs/gcc-4.6.2/gcc.pdf
Without this, if you have slub_debug turned on, you can get messages
that look like this:
unwind: Index not found 7f008c50
Signed-off-by: Doug Anderson <dianders@chromium.org>
[wangkai: backport to 3.10
- adjust context
commit e6eb2eba494d6f99e69ca3c3748cd37a2544ab38 upstream.
The commit 3b8a3c010969 ("powerpc/pseries: Fix endiannes issue in RTAS
call from xmon") was fixing an endianness issue in the call made from
xmon to RTAS.
However, as Michael Ellerman noticed, this fix was not complete, the
token value was not byte swapped. This lead to call an unexpected and
most of the time unexisting RTAS function, which is silently ignored by
RTAS.
This fix addresses this hole.
Reported-by: Michael Ellerman <mpe@ellerman.id.au>
Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
commit 3e14dcf7cb80b34a1f38b55bc96f02d23fdaaaaf upstream.
Commit 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
changed the automatic module loading when requesting crypto algorithms
to prefix all module requests with "crypto-". This requires all crypto
modules to have a crypto specific module alias even if their file name
would otherwise match the requested crypto algorithm.
Even though commit 5d26a105b5a7 added those aliases for a vast amount of
modules, it was missing a few. Add the required MODULE_ALIAS_CRYPTO
annotations to those files to make them get loaded automatically, again.
This fixes, e.g., requesting 'ecb(blowfish-generic)', which used to work
with kernels v3.18 and below.
Also change MODULE_ALIAS() lines to MODULE_ALIAS_CRYPTO(). The former
won't work for crypto modules any more.
Fixes: 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit 4943ba16bbc2db05115707b3ff7b4874e9e3c560 upstream.
This adds the module loading prefix "crypto-" to the template lookup
as well.
For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly
includes the "crypto-" prefix at every level, correctly rejecting "vfat":
net-pf-38
algif-hash
crypto-vfat(blowfish)
crypto-vfat(blowfish)-all
crypto-vfat
Reported-by: Mathias Krause <minipli@googlemail.com>
Acked-by: Mathias Krause <minipli@googlemail.com>
commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
commit 7ddc6a2199f1da405a2fb68c40db8899b1a8cd87 upstream.
These functions can be executed on the int3 stack, so kprobes
are dangerous. Tracing is probably a bad idea, too.
Fixes: b645af2d5905 ("x86_64, traps: Rework bad_iret")
Link: http://lkml.kernel.org/r/50e33d26adca60816f3ba968875801652507d0c4.1416870125.git.luto@amacapital.net
[bwh: Backported to 3.10:
- Use __kprobes instead of NOKPROBE_SYMBOL()
- Adjust context]
commit 3669ef9fa7d35f573ec9c0e0341b29251c2734a7 upstream.
The Witcher 2 did something like this to allocate a TLS segment index:
struct user_desc u_info;
bzero(&u_info, sizeof(u_info));
u_info.entry_number = (uint32_t)-1;
syscall(SYS_set_thread_area, &u_info);
Strictly speaking, this code was never correct. It should have set
read_exec_only and seg_not_present to 1 to indicate that it wanted
to find a free slot without putting anything there, or it should
have put something sensible in the TLS slot if it wanted to allocate
a TLS entry for real. The actual effect of this code was to
allocate a bogus segment that could be used to exploit espfix.
The set_thread_area hardening patches changed the behavior, causing
set_thread_area to return -EINVAL and crashing the game.
This changes set_thread_area to interpret this as a request to find
a free slot and to leave it empty, which isn't *quite* what the game
expects but should be close enough to keep it working. In
particular, using the code above to allocate two segments will
allocate the same segment both times.
According to FrostbittenKing on Github, this fixes The Witcher 2.
If this somehow still causes problems, we could instead allocate
a limit==0 32-bit data segment, but that seems rather ugly to me.
Fixes: 41bdc78544b8 x86/tls: Validate TLS entries to protect espfix
Cc: torvalds@linux-foundation.org
Link: http://lkml.kernel.org/r/0cb251abe1ff0958b8e468a9a9a905b80ae3a746.1421954363.git.luto@amacapital.net
commit e30ab185c490e9a9381385529e0fd32f0a399495 upstream.
32-bit programs don't have an lm bit in their ABI, so they can't
reliably cause LDT_empty to return true without resorting to memset.
They shouldn't need to do this.
This should fix a longstanding, if minor, issue in all 64-bit kernels
as well as a potential regression in the TLS hardening code.
Link: http://lkml.kernel.org/r/72a059de55e86ad5e2935c80aa91880ddf19d07c.1421954363.git.luto@amacapital.net
commit 520452172e6b318f3a8bd9d4fe1e25066393de25 upstream.
Many users see this message when booting without knowning that it is
of no importance and that TSC calibration may have succeeded by
another way.
As explained by Paul Bolle in
http://lkml.kernel.org/r/1348488259.1436.22.camel@x61.thuisdomein
"Fast TSC calibration failed" should not be considered as an error
since other calibration methods are being tried afterward. At most,
those send a warning if they fail (not an error). So let's change
the message from error to warning.
[ tglx: Make if pr_info. It's really not important at all ]
Fixes: c767a54ba065 x86/debug: Add KERN_<LEVEL> to bare printks, convert printks to pr_<level>
Signed-off-by: Alexandre Demers <alexandre.f.demers@gmail.com>
Link: http://lkml.kernel.org/r/1418106470-6906-1-git-send-email-alexandre.f.demers@gmail.com
commit 32c6590d126836a062b3140ed52d898507987017 upstream.
The Hyper-V clocksource is continuous; mark it accordingly.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Acked-by: jasowang@redhat.com
Cc: gregkh@linuxfoundation.org
Cc: devel@linuxdriverproject.org
Cc: olaf@aepfle.de
Cc: apw@canonical.com
Link: http://lkml.kernel.org/r/1421108762-3331-1-git-send-email-kys@microsoft.com
commit 7ecd0bde5bfea524a843ad8fa8cb66ccbce68779 upstream.
Currently PWM functionality is broken on mx25 due to the wrong assignment of the
PWM "per" clock.
According to Documentation/devicetree/bindings/clock/imx25-clock.txt:
pwm_ipg_per 52
,so update the pwm "per" to use 'pwm_ipg_per' instead of 'per10' clock.
With this change PWM can work fine on mx25.
Reported-by: Carlos Soto <csotoalonso@gmail.com>
commit b485342bd79af363c77ef1a421c4a0aef2de9812 upstream.
Commit a074335a370e ("x86, um: Mark system call tables readonly") was
supposed to mark the sys_call_table in UML as RO by adding the const,
but it doesn't have the desired effect as it's nevertheless being placed
into the data section since __cacheline_aligned enforces sys_call_table
being placed into .data..cacheline_aligned instead. We need to use
the ____cacheline_aligned version instead to fix this issue.
Before:
$ nm -v arch/x86/um/sys_call_table_64.o | grep -1 "sys_call_table"
U sys_writev
0000000000000000 D sys_call_table
0000000000000000 D syscall_table_size
After:
U sys_writev
0000000000000000 R sys_call_table
Fixes: a074335a370e ("x86, um: Mark system call tables readonly")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit f911d731054ab3d82ee72a16b889e17ca3a2332a upstream.
futex_atomic_cmpxchg_inatomic() does not work on UML because
it triggers a copy_from_user() in kernel context.
On UML copy_from_user() can only be used if the kernel was called
by a real user space process such that UML can use ptrace()
to fetch the value.
Reported-by: Miklos Szeredi <miklos@szeredi.hu>
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Daniel Walter <d.walter@0x90.at>
commit b0ddb319db3d7a1943445f0de0a45c07a7f3457a upstream.
The sh73a0 INTC can't mask interrupts properly most likely due to a
hardware bug. Set the .control_parent flag to delegate masking to the
parent interrupt controller, like was already done for irqpin1.
Without this, accessing the three-axis digital accelerometer ADXL345
on kzm9g through /dev/input/event1 causes an interrupt storm, which
requires a power-cycle to recover from.
This was inspired by a patch for arch/arm/boot/dts/sh73a0.dtsi from
Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Fixes: 341eb5465f67437a ("ARM: shmobile: INTC External IRQ pin driver on sh73a0")
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
commit 572b24e6d85d98cdc552f07e9fb9870d9460d81b upstream.
The switch statement of the possible list of SYSCLK1 frequencies is
missing a 0 in 4 out of the 7 frequencies.
Fixes: fa6d79d27614 ("ARM: OMAP: Add initialisation for the real-time counter")
Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Acked-by: Nishanth Menon <nm@ti.com>
commit 81ef447950bf0955aca46f4a7617d8ce435cf0ce upstream.
The post dividers do not work on i.MX6Q rev T0 1.0 so they must be fixed
to 1. As the table index was wrong, a divider a of 4 could still be
requested which implied the clock not to be set properly. This is the
root cause of the HDMI not working at high resolution on rev T0 1.0 of
the SoC.
Signed-off-by: Gary Bisson <bisson.gary@gmail.com>
Cc: <stable@vger.kernel.org>
commit d2a10a1727b3948019128e83162f22c65859f1fd upstream.
Drop unnecessary semicolon after closing curly bracket.
Signed-off-by: Dmitry Voytik <voytikd@gmail.com>
commit 7a87e9cbc3a2f0ff0955815335e08c9862359130 upstream.
From Documentation/devicetree/bindings/clock/imx25-clock.txt:
cspi1_ipg 78
cspi2_ipg 79
cspi3_ipg 80
, so fix the SPI1 clocks accordingly to avoid a kernel hang when trying to
access SPI1.
commit 237d28db036e411f22c03cfd5b0f6dc2aa9bf3bc upstream.
If the function graph tracer traces a jprobe callback, the system will
crash. This can easily be demonstrated by compiling the jprobe
sample module that is in the kernel tree, loading it and running the
function graph tracer.
# modprobe jprobe_example.ko
# echo function_graph > /sys/kernel/debug/tracing/current_tracer
# ls
The first two commands end up in a nice crash after the first fork.
(do_fork has a jprobe attached to it, so "ls" just triggers that fork)
The problem is caused by the jprobe_return() that all jprobe callbacks
must end with. The way jprobes works is that the function a jprobe
is attached to has a breakpoint placed at the start of it (or it uses
ftrace if fentry is supported). The breakpoint handler (or ftrace callback)
will copy the stack frame and change the ip address to return to the
jprobe handler instead of the function. The jprobe handler must end
with jprobe_return() which swaps the stack and does an int3 (breakpoint).
This breakpoint handler will then put back the saved stack frame,
simulate the instruction at the beginning of the function it added
a breakpoint to, and then continue on.
For function tracing to work, it hijakes the return address from the
stack frame, and replaces it with a hook function that will trace
the end of the call. This hook function will restore the return
address of the function call.
If the function tracer traces the jprobe handler, the hook function
for that handler will not be called, and its saved return address
will be used for the next function. This will result in a kernel crash.
To solve this, pause function tracing before the jprobe handler is called
and unpause it before it returns back to the function it probed.
Some other updates:
Used a variable "saved_sp" to hold kcb->jprobe_saved_sp. This makes the
code look a bit cleaner and easier to understand (various tries to fix
this bug required this change).
Note, if fentry is being used, jprobes will change the ip address before
the function graph tracer runs and it will not be able to trace the
function that the jprobe is probing.
Link: http://lkml.kernel.org/r/20150114154329.552437962@goodmis.org
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
commit e8ef060b37c2d3cc5fd0c0edbe4e42ec1cb9768b upstream.
This allows the sdplite/Zebu images to run on OSCI simulation platform
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit af91568e762d04931dcbdd6bef4655433d8b9418 upstream.
The uncore_collect_events functions assumes that event group
might contain only uncore events which is wrong, because it
might contain any type of events.
This bug leads to uncore framework touching 'not' uncore events,
which could end up all sorts of bugs.
One was triggered by Vince's perf fuzzer, when the uncore code
touched breakpoint event private event space as if it was uncore
event and caused BUG:
BUG: unable to handle kernel paging request at ffffffff82822068
IP: [<ffffffff81020338>] uncore_assign_events+0x188/0x250
The code in uncore_assign_events() function was looking for
event->hw.idx data while the event was initialized as a
breakpoint with different members in event->hw union.
This patch forces uncore_collect_events() to collect only uncore
events.
Reported-by: Vince Weaver <vince@deater.net>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Yan, Zheng <zheng.z.yan@intel.com>
Link: http://lkml.kernel.org/r/1418243031-20367-2-git-send-email-jolsa@kernel.org
commit e55355453600a33bb5ca4f71f2d7214875f3b061 upstream.
Enabling the hardware I/O coherency on Armada 370, Armada 375, Armada
38x and Armada XP requires a certain number of conditions:
- On Armada 370, the cache policy must be set to write-allocate.
- On Armada 375, 38x and XP, the cache policy must be set to
write-allocate, the pages must be mapped with the shareable
attribute, and the SMP bit must be set
Currently, on Armada XP, when CONFIG_SMP is enabled, those conditions
are met. However, when Armada XP is used in a !CONFIG_SMP kernel, none
of these conditions are met. With Armada 370, the situation is worse:
since the processor is single core, regardless of whether CONFIG_SMP
or !CONFIG_SMP is used, the cache policy will be set to write-back by
the kernel and not write-allocate.
Since solving this problem turns out to be quite complicated, and we
don't want to let users with a mainline kernel known to have
infrequent but existing data corruptions, this commit proposes to
simply disable hardware I/O coherency in situations where it is known
not to work.
And basically, the is_smp() function of the kernel tells us whether it
is OK to enable hardware I/O coherency or not, so this commit slightly
refactors the coherency_type() function to return
COHERENCY_FABRIC_TYPE_NONE when is_smp() is false, or the appropriate
type of the coherency fabric in the other case.
Thanks to this, the I/O coherency fabric will no longer be used at all
in !CONFIG_SMP configurations. It will continue to be used in
CONFIG_SMP configurations on Armada XP, Armada 375 and Armada 38x
(which are multiple cores processors), but will no longer be used on
Armada 370 (which is a single core processor).
In the process, it simplifies the implementation of the
coherency_type() function, and adds a missing call to of_node_put().
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Fixes: e60304f8cb7bb545e79fe62d9b9762460c254ec2 ("arm: mvebu: Add hardware I/O Coherency support")
Cc: <stable@vger.kernel.org> # v3.8+
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Link: https://lkml.kernel.org/r/1415871540-20302-3-git-send-email-thomas.petazzoni@free-electrons.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit 1ddf0b1b11aa8a90cef6706e935fc31c75c406ba upstream.
In Linux 3.18 and below, GCC hoists the lsl instructions in the
pvclock code all the way to the beginning of __vdso_clock_gettime,
slowing the non-paravirt case significantly. For unknown reasons,
presumably related to the removal of a branch, the performance issue
is gone as of
e76b027e6408 x86,vdso: Use LSL unconditionally for vgetcpu
but I don't trust GCC enough to expect the problem to stay fixed.
There should be no correctness issue, because the __getcpu calls in
__vdso_vlock_gettime were never necessary in the first place.
Note to stable maintainers: In 3.18 and below, depending on
configuration, gcc 4.9.2 generates code like this:
9c3: 44 0f 03 e8 lsl %ax,%r13d
9c7: 45 89 eb mov %r13d,%r11d
9ca: 0f 03 d8 lsl %ax,%ebx
This patch won't apply as is to any released kernel, but I'll send a
trivial backported version if needed.
Backported by Andy Lutomirski. Should apply to all affected
versions. This fixes a functionality bug as well as a performance
bug: buggy kernels can infinite loop in __vdso_clock_gettime on
affected compilers. See, for exammple:
https://bugzilla.redhat.com/show_bug.cgi?id=1178975
Fixes: 51c19b4f5927 x86: vdso: pvclock gettime support
Cc: Marcelo Tosatti <mtosatti@redhat.com>
commit 394f56fe480140877304d342dec46d50dc823d46 upstream.
The theory behind vdso randomization is that it's mapped at a random
offset above the top of the stack. To avoid wasting a page of
memory for an extra page table, the vdso isn't supposed to extend
past the lowest PMD into which it can fit. Other than that, the
address should be a uniformly distributed address that meets all of
the alignment requirements.
The current algorithm is buggy: the vdso has about a 50% probability
of being at the very end of a PMD. The current algorithm also has a
decent chance of failing outright due to incorrect handling of the
case where the top of the stack is near the top of its PMD.
This fixes the implementation. The paxtest estimate of vdso
"randomisation" improves from 11 bits to 18 bits. (Disclaimer: I
don't know what the paxtest code is actually calculating.)
It's worth noting that this algorithm is inherently biased: the vdso
is more likely to end up near the end of its PMD than near the
beginning. Ideally we would either nix the PMD sharing requirement
or jointly randomize the vdso and the stack to reduce the bias.
In the mean time, this is a considerable improvement with basically
no risk of compatibility issues, since the allowed outputs of the
algorithm are unchanged.
As an easy test, doing this:
for i in `seq 10000`
do grep -P vdso /proc/self/maps |cut -d- -f1
done |sort |uniq -d
used to produce lots of output (1445 lines on my most recent run).
A tiny subset looks like this:
7fffdfffe000
7fffe01fe000
7fffe05fe000
7fffe07fe000
7fffe09fe000
7fffe0bfe000
7fffe0dfe000
Note the suspicious fe000 endings. With the fix, I get a much more
palatable 76 repeated addresses.
commit 7ff4d90b4c24a03666f296c3d4878cd39001e81e upstream.
Today there are 3 instances of setgroups and due to an oversight their
permission checking has diverged. Add a common function so that
they may all share the same permission checking code.
This corrects the current oversight in the current permission checks
and adds a helper to avoid this in the future.
A user namespace security fix will update this new helper, shortly.
commit 3fb2f4237bb452eb4e98f6a5dbd5a445b4fed9d0 upstream.
It turns out that there's a lurking ABI issue. GCC, when
compiling this in a 32-bit program:
struct user_desc desc = {
.entry_number = idx,
.base_addr = base,
.limit = 0xfffff,
.seg_32bit = 1,
.contents = 0, /* Data, grow-up */
.read_exec_only = 0,
.limit_in_pages = 1,
.seg_not_present = 0,
.useable = 0,
will leave .lm uninitialized. This means that anything in the
kernel that reads user_desc.lm for 32-bit tasks is unreliable.
Revert the .lm check in set_thread_area(). The value never did
anything in the first place.
Fixes: 0e58af4e1d21 ("x86/tls: Disallow unusual TLS segments")
Link: http://lkml.kernel.org/r/d7875b60e28c512f6a6fc0baf5714d58e7eaadbb.1418856405.git.luto@amacapital.net
commit 29fa6825463c97e5157284db80107d1bfac5d77b upstream.
paravirt_enabled has the following effects:
- Disables the F00F bug workaround warning. There is no F00F bug
workaround any more because Linux's standard IDT handling already
works around the F00F bug, but the warning still exists. This
is only cosmetic, and, in any event, there is no such thing as
KVM on a CPU with the F00F bug.
- Disables 32-bit APM BIOS detection. On a KVM paravirt system,
there should be no APM BIOS anyway.
- Disables tboot. I think that the tboot code should check the
CPUID hypervisor bit directly if it matters.
- paravirt_enabled disables espfix32. espfix32 should *not* be
disabled under KVM paravirt.
The last point is the purpose of this patch. It fixes a leak of the
high 16 bits of the kernel stack address on 32-bit KVM paravirt
guests. Fixes CVE-2014-8134.
Suggested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit f647d7c155f069c1a068030255c300663516420e upstream.
Otherwise, if buggy user code points DS or ES into the TLS
array, they would be corrupted after a context switch.
This also significantly improves the comments and documents some
gotchas in the code.
Before this patch, the both tests below failed. With this
patch, the es test passes, although the gsbase test still fails.
----- begin es test -----
* Copyright (c) 2014 Andy Lutomirski
* GPL v2
static unsigned short GDT3(int idx)
return (idx << 3) | 3;
static int create_tls(int idx, unsigned int base)
.base_addr = base,
.limit = 0xfffff,
.seg_32bit = 1,
.useable = 0,
if (syscall(SYS_set_thread_area, &desc) != 0)
err(1, "set_thread_area");
return desc.entry_number;
int main()
int idx = create_tls(-1, 0);
printf("Allocated GDT index %d\n", idx);
unsigned short orig_es;
asm volatile ("mov %%es,%0" : "=rm" (orig_es));
int errors = 0;
int total = 1000;
for (int i = 0; i < total; i++) {
asm volatile ("mov %0,%%es" : : "rm" (GDT3(idx)));
usleep(100);
unsigned short es;
asm volatile ("mov %%es,%0" : "=rm" (es));
asm volatile ("mov %0,%%es" : : "rm" (orig_es));
if (es != GDT3(idx)) {
if (errors == 0)
printf("[FAIL]\tES changed from 0x%hx to 0x%hx\n",
GDT3(idx), es);
errors++;
if (errors) {
printf("[FAIL]\tES was corrupted %d/%d times\n", errors, total);
return 1;
} else {
printf("[OK]\tES was preserved\n");
return 0;
----- end es test -----
----- begin gsbase test -----
* gsbase.c, a gsbase test
* GPL v2
static unsigned char *testptr, *testptr2;
static unsigned char read_gs_testvals(void)
unsigned char ret;
asm volatile ("movb %%gs:%1, %0" : "=r" (ret) : "m" (*testptr));
return ret;
int main()
int errors = 0;
testptr = mmap((void *)0x200000000UL, 1, PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_FIXED | MAP_ANONYMOUS, -1, 0);
if (testptr == MAP_FAILED)
err(1, "mmap");
testptr2 = mmap((void *)0x300000000UL, 1, PROT_READ | PROT_WRITE,
if (testptr2 == MAP_FAILED)
err(1, "mmap");
*testptr = 0;
*testptr2 = 1;
if (syscall(SYS_arch_prctl, ARCH_SET_GS,
(unsigned long)testptr2 - (unsigned long)testptr) != 0)
err(1, "ARCH_SET_GS");
usleep(100);
if (read_gs_testvals() == 1) {
printf("[OK]\tARCH_SET_GS worked\n");
} else {
printf("[FAIL]\tARCH_SET_GS failed\n");
errors++;
asm volatile ("mov %0,%%gs" : : "r" (0));
if (read_gs_testvals() == 0) {
printf("[OK]\tWriting 0 to gs worked\n");
} else {
printf("[FAIL]\tWriting 0 to gs failed\n");
errors++;
usleep(100);
printf("[OK]\tgsbase is still zero\n");
} else {
printf("[FAIL]\tgsbase was corrupted\n");
errors++;
return errors == 0 ? 0 : 1;
----- end gsbase test -----
Link: http://lkml.kernel.org/r/509d27c9fec78217691c3dad91cec87e1006b34a.1418075657.git.luto@amacapital.net
commit 0e58af4e1d2166e9e33375a0f121e4867010d4f8 upstream.
Users have no business installing custom code segments into the
GDT, and segments that are not present but are otherwise valid
are a historical source of interesting attacks.
For completeness, block attempts to set the L bit. (Prior to
this patch, the L bit would have been silently dropped.)
This is an ABI break. I've checked glibc, musl, and Wine, and
none of them look like they'll have any trouble.
Note to stable maintainers: this is a hardening patch that fixes
no known bugs. Given the possibility of ABI issues, this
probably shouldn't be backported quickly.
Acked-by: H. Peter Anvin <hpa@zytor.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Willy Tarreau <w@1wt.eu>
commit 41bdc78544b8a93a9c6814b8bbbfef966272abbe upstream.
Installing a 16-bit RW data segment into the GDT defeats espfix.
AFAICT this will not affect glibc, Wine, or dosemu at all.
commit 152d44a853e42952f6c8a504fb1f8eefd21fd5fd upstream.
I used some 64 bit instructions when adding the 32 bit getcpu VDSO
function. Fix it.
Fixes: 18ad51dd342a ("powerpc: Add VDSO version of getcpu")
commit 336ae1180df5f69b9e0fb6561bec01c5f64361cf upstream.
There is a small race between when the cycle count is read from
the hardware and when the epoch stabilizes. Consider this
scenario:
CPU0 CPU1
cyc = read_sched_clock()
cyc_to_sched_clock()
update_sched_clock()
cd.epoch_cyc = cyc;
epoch_cyc = cd.epoch_cyc;
epoch_ns + cyc_to_ns((cyc - epoch_cyc)
The cyc on cpu0 was read before the epoch changed. But we
calculate the nanoseconds based on the new epoch by subtracting
the new epoch from the old cycle count. Since epoch is most likely
larger than the old cycle count we calculate a large number that
will be converted to nanoseconds and added to epoch_ns, causing
time to jump forward too much.
Fix this problem by reading the hardware after the epoch has
stabilized.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: John Stultz <john.stultz@linaro.org>
