path: root/arch
2013-11-13xtensa: don't use alternate signal stack on threadsBaruch Siach
commit cba9a90053e3b7973eff4f1946f33032e98eeed5 upstream. According to create_thread(3): "The new thread does not inherit the creating thread's alternate signal stack". Since commit f9a3879a (Fix sigaltstack corruption among cloned threads), current->sas_ss_size is set to 0 for cloned processes sharing VM with their parent. Don't use the (nonexistent) alternate signal stack in this case. This has been broken since commit 29c4dfd9 ([XTENSA] Remove non-rt signal handling). Fixes the SA_ONSTACK part of the nptl/tst-cancel20 test from uClibc. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13uml: check length in exitcode_proc_write()Dan Carpenter
commit 201f99f170df14ba52ea4c52847779042b7a623b upstream. We don't cap the size of buffer from the user so we could write past the end of the array here. Only root can write to this file. Reported-by: Nico Golde <nico@ngolde.de> Reported-by: Fabian Yamaguchi <fabs@goesec.de> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13ARC: Incorrect mm reference used in vmalloc fault handlerVineet Gupta
commit 9c41f4eeb9d51f3ece20428d35a3ea32cf3b5622 upstream. A vmalloc fault needs to sync up PGD/PTE entry from init_mm to current task's "active_mm". ARC vmalloc fault handler however was using mm. A vmalloc fault for non user task context (actually pre-userland, from init thread's open for /dev/console) caused the handler to deref NULL mm (for mm->pgd) The reasons it worked so far is amazing: 1. By default (!SMP), vmalloc fault handler uses a cached value of PGD. In SMP that MMU register is repurposed hence need for mm pointer deref. 2. In pre-3.12 SMP kernel, the problem triggering vmalloc didn't exist in pre-userland code path - it was introduced with commit 20bafb3d23d108bc "n_tty: Move buffers into n_tty_data" Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Gilad Ben-Yossef <gilad@benyossef.com> Cc: Noam Camus <noamc@ezchip.com> Cc: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13parisc: Do not crash 64bit SMP kernels on machines with >= 4GB RAMHelge Deller
commit 54e181e073fc1415e41917d725ebdbd7de956455 upstream. Since the beginning of the parisc-linux port, sometimes 64bit SMP kernels were not able to bring up other CPUs than the monarch CPU and instead crashed the kernel. The reason was unclear, esp. since it involved various machines (e.g. J5600, J6750 and SuperDome). Testing showed, that those crashes didn't happened when less than 4GB were installed, or if a 32bit Linux kernel was booted. In the end, the fix for those SMP problems is trivial: During the early phase of the initialization of the CPUs, including the monarch CPU, the PDC_PSW firmware function to enable WIDE (=64bit) mode is called. It's documented that this firmware function may clobber various registers, and one one of those possibly clobbered registers is %cr30 which holds the task thread info pointer. Now, if %cr30 would always have been clobbered, then this bug would have been detected much earlier. But lots of testing finally showed, that - at least for %cr30 - on some machines only the upper 32bits of the 64bit register suddenly turned zero after the firmware call. So, after finding the root cause, the explanation for the various crashes became clear: - On 32bit SMP Linux kernels all upper 32bit were zero, so we didn't faced this problem. - Monarch CPUs in 64bit mode always booted sucessfully, because the inital task thread info pointer was below 4GB. - Secondary CPUs booted sucessfully on machines with less than 4GB RAM because the upper 32bit were zero anyay. - Secondary CPus failed to boot if we had more than 4GB RAM and the task thread info pointer was located above the 4GB boundary. Finally, the patch to fix this problem is trivial by saving the %cr30 register before the firmware call and restoring it afterwards. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13x86: Update UV3 hub revision IDRuss Anderson
commit dd3c9c4b603c664fedc12facf180db0f1794aafe upstream. The UV3 hub revision ID is different than expected. The first revision was supposed to start at 1 but instead will start at 0. Signed-off-by: Russ Anderson <rja@sgi.com> Link: http://lkml.kernel.org/r/20131014161733.GA6274@sgi.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04ARM: integrator: deactivate timer0 on the Integrator/CPLinus Walleij
commit 29114fd7db2fc82a34da8340d29b8fa413e03dca upstream. This fixes a long-standing Integrator/CP regression from commit 870e2928cf3368ca9b06bc925d0027b0a56bcd8e "ARM: integrator-cp: convert use CLKSRC_OF for timer init" When this code was introduced, the both aliases pointing the system to use timer1 as primary (clocksource) and timer2 as secondary (clockevent) was ignored, and the system would simply use the first two timers found as clocksource and clockevent. However this made the system timeline accelerate by a factor x25, as it turns out that the way the clocking actually works (totally undocumented and found after some trial-and-error) is that timer0 runs @ 25MHz and timer1 and timer2 runs @ 1MHz. Presumably this divider setting is a boot-on default and configurable albeit the way to configure it is not documented. So as a quick fix to the problem, let's mark timer0 as disabled, so the code will chose timer1 and timer2 as it used to. This also deletes the two aliases for the primary and secondary timer as they have been superceded by the auto-selection Cc: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04ARM: 7851/1: check for number of arguments in syscall_get/set_arguments()AKASHI Takahiro
commit 3c1532df5c1b54b5f6246cdef94eeb73a39fe43a upstream. In ftrace_syscall_enter(), syscall_get_arguments(..., 0, n, ...) if (i == 0) { <handle ORIG_r0> ...; n--;} memcpy(..., n * sizeof(args[0])); If 'number of arguments(n)' is zero and 'argument index(i)' is also zero in syscall_get_arguments(), none of arguments should be copied by memcpy(). Otherwise 'n--' can be a big positive number and unexpected amount of data will be copied. Tracing system calls which take no argument, say sync(void), may hit this case and eventually make the system corrupted. This patch fixes the issue both in syscall_get_arguments() and syscall_set_arguments(). Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18x86: avoid remapping data in parse_setup_data()Linn Crosetto
commit 30e46b574a1db7d14404e52dca8e1aa5f5155fd2 upstream. Type SETUP_PCI, added by setup_efi_pci(), may advertise a ROM size larger than early_memremap() is able to handle, which is currently limited to 256kB. If this occurs it leads to a NULL dereference in parse_setup_data(). To avoid this, remap the setup_data header and allow parsing functions for individual types to handle their own data remapping. Signed-off-by: Linn Crosetto <linn@hp.com> Link: http://lkml.kernel.org/r/1376430401-67445-1-git-send-email-linn@hp.com Acked-by: Yinghai Lu <yinghai@kernel.org> Reviewed-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18compiler/gcc4: Add quirk for 'asm goto' miscompilation bugIngo Molnar
commit 3f0116c3238a96bc18ad4b4acefe4e7be32fa861 upstream. Fengguang Wu, Oleg Nesterov and Peter Zijlstra tracked down a kernel crash to a GCC bug: GCC miscompiles certain 'asm goto' constructs, as outlined here: http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670 Implement a workaround suggested by Jakub Jelinek. Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Suggested-by: Jakub Jelinek <jakub@redhat.com> Reviewed-by: Richard Henderson <rth@twiddle.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20131015062351.GA4666@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: Ignore ptrace SETREGSET request for synthetic register "stop_pc"Vineet Gupta
commit 5b24282846c064ee90d40fcb3a8f63b8e754fd28 upstream. ARCompact TRAP_S insn used for breakpoints, commits before exception is taken (updating architectural PC). So ptregs->ret contains next-PC and not the breakpoint PC itself. This is different from other restartable exceptions such as TLB Miss where ptregs->ret has exact faulting PC. gdb needs to know exact-PC hence ARC ptrace GETREGSET provides for @stop_pc which returns ptregs->ret vs. EFA depending on the situation. However, writing stop_pc (SETREGSET request), which updates ptregs->ret doesn't makes sense stop_pc doesn't always correspond to that reg as described above. This was not an issue so far since user_regs->ret / user_regs->stop_pc had same value and both writing to ptregs->ret was OK, needless, but NOT broken, hence not observed. With gdb "jump", they diverge, and user_regs->ret updating ptregs is overwritten immediately with stop_pc, which this patch fixes. Reported-by: Anton Kolesov <akolesov@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: Fix signal frame management for SA_SIGINFOChristian Ruppert
commit 10469350e345599dfef3fa78a7c19fb230e674c1 upstream. Previously, when a signal was registered with SA_SIGINFO, parameters 2 and 3 of the signal handler were written to registers r1 and r2 before the register set was saved. This led to corruption of these two registers after returning from the signal handler (the wrong values were restored). With this patch, registers are now saved before any parameters are passed, thus maintaining the processor state from before signal entry. Signed-off-by: Christian Ruppert <christian.ruppert@abilis.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: Workaround spinlock livelock in SMP SystemC simulationVineet Gupta
commit 6c00350b573c0bd3635436e43e8696951dd6e1b6 upstream. Some ARC SMP systems lack native atomic R-M-W (LLOCK/SCOND) insns and can only use atomic EX insn (reg with mem) to build higher level R-M-W primitives. This includes a SystemC based SMP simulation model. So rwlocks need to use a protecting spinlock for atomic cmp-n-exchange operation to update reader(s)/writer count. The spinlock operation itself looks as follows: mov reg, 1 ; 1=locked, 0=unlocked retry: EX reg, [lock] ; load existing, store 1, atomically BREQ reg, 1, rety ; if already locked, retry In single-threaded simulation, SystemC alternates between the 2 cores with "N" insn each based scheduling. Additionally for insn with global side effect, such as EX writing to shared mem, a core switch is enforced too. Given that, 2 cores doing a repeated EX on same location, Linux often got into a livelock e.g. when both cores were fiddling with tasklist lock (gdbserver / hackbench) for read/write respectively as the sequence diagram below shows: core1 core2 -------- -------- 1. spin lock [EX r=0, w=1] - LOCKED 2. rwlock(Read) - LOCKED 3. spin unlock [ST 0] - UNLOCKED spin lock [EX r=0,w=1] - LOCKED -- resched core 1---- 5. spin lock [EX r=1] - ALREADY-LOCKED -- resched core 2---- 6. rwlock(Write) - READER-LOCKED 7. spin unlock [ST 0] 8. rwlock failed, retry again 9. spin lock [EX r=0, w=1] -- resched core 1---- 10 spinlock locked in #9, retry #5 11. spin lock [EX gets 1] -- resched core 2---- ... ... The fix was to unlock using the EX insn too (step 7), to trigger another SystemC scheduling pass which would let core1 proceed, eliding the livelock. Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: Fix 32-bit wrap around in access_ok()Vineet Gupta
commit 0752adfda15f0eca9859a76da3db1800e129ad43 upstream. Anton reported | LTP tests syscalls/process_vm_readv01 and process_vm_writev01 fail | similarly in one testcase test_iov_invalid -> lvec->iov_base. | Testcase expects errno EFAULT and return code -1, | but it gets return code 1 and ERRNO is 0 what means success. Essentially test case was passing a pointer of -1 which access_ok() was not catching. It was doing [@addr + @sz <= TASK_SIZE] which would pass for @addr == -1 Fixed that by rewriting as [@addr <= TASK_SIZE - @sz] Reported-by: Anton Kolesov <Anton.Kolesov@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: Handle zero-overhead-loop in unaligned access handlerMischa Jonker
commit c11eb222fd7d4db91196121dbf854178505d2751 upstream. If a load or store is the last instruction in a zero-overhead-loop, and it's misaligned, the loop would execute only once. This fixes that problem. Signed-off-by: Mischa Jonker <mjonker@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: Fix __udelay calculationMischa Jonker
commit 7efd0da2d17360e1cef91507dbe619db0ee2c691 upstream. Cast usecs to u64, to ensure that the (usecs * 4295 * HZ) multiplication is 64 bit. Initially, the (usecs * 4295 * HZ) part was done as a 32 bit multiplication, with the result casted to 64 bit. This led to some bits falling off, causing a "DMA initialization error" in the stmmac Ethernet driver, due to a premature timeout. Signed-off-by: Mischa Jonker <mjonker@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: SMP failed to boot due to missing IVT setupNoam Camus
commit c3567f8a359b7917dcffa442301f88ed0a75211f upstream. Commit 05b016ecf5e7a "ARC: Setup Vector Table Base in early boot" moved the Interrupt vector Table setup out of arc_init_IRQ() which is called for all CPUs, to entry point of boot cpu only, breaking booting of others. Fix by adding the same to entry point of non-boot CPUs too. read_arc_build_cfg_regs() printing IVT Base Register didn't help the casue since it prints a synthetic value if zero which is totally bogus, so fix that to print the exact Register. [vgupta: Remove the now stale comment from header of arc_init_IRQ and also added the commentary for halt-on-reset] Cc: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Noam Camus <noamc@ezchip.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: Setup Vector Table Base in early bootVineet Gupta
commit 05b016ecf5e7a8c24409d8e9effb5d2ec9107708 upstream. Otherwise early boot exceptions such as instructions errors due to configuration mismatch between kernel and hardware go off to la-la land, as opposed to hitting the handler and panic()'ing properly. Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARM: Fix the world famous typo with is_gate_vma()Russell King
commit 1d0bbf428924f94867542d49d436cf254b9dbd06 upstream. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Colin Cross <ccross@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18parisc: fix interruption handler to respect pagefault_disable()Helge Deller
commit 59b33f148cc08fb33cbe823fca1e34f7f023765e upstream. Running an "echo t > /proc/sysrq-trigger" crashes the parisc kernel. The problem is, that in print_worker_info() we try to read the workqueue info via the probe_kernel_read() functions which use pagefault_disable() to avoid crashes like this: probe_kernel_read(&pwq, &worker->current_pwq, sizeof(pwq)); probe_kernel_read(&wq, &pwq->wq, sizeof(wq)); probe_kernel_read(name, wq->name, sizeof(name) - 1); The problem here is, that the first probe_kernel_read(&pwq) might return zero in pwq and as such the following probe_kernel_reads() try to access contents of the page zero which is read protected and generate a kernel segfault. With this patch we fix the interruption handler to call parisc_terminate() directly only if pagefault_disable() was not called (in which case preempt_count()==0). Otherwise we hand over to the pagefault handler which will try to look up the faulting address in the fixup tables. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18KVM: PPC: Book3S HV: Fix typo in saving DSCRPaul Mackerras
commit cfc860253abd73e1681696c08ea268d33285a2c4 upstream. This fixes a typo in the code that saves the guest DSCR (Data Stream Control Register) into the kvm_vcpu_arch struct on guest exit. The effect of the typo was that the DSCR value was saved in the wrong place, so changes to the DSCR by the guest didn't persist across guest exit and entry, and some host kernel memory got corrupted. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: Alexander Graf <agraf@suse.de> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13s390: fix system call restart after inferior callMartin Schwidefsky
commit dbbfe487e5f3fc00c9fe5207d63309859704d12f upstream. Git commit 616498813b11ffef "s390: system call path micro optimization" introduced a regression in regard to system call restarting and inferior function calls via the ptrace interface. The pointer to the system call table needs to be loaded in sysc_sigpending if do_signal returns with TIF_SYSCALl set after it restored a system call context. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13tile: use a more conservative __my_cpu_offset in CONFIG_PREEMPTChris Metcalf
commit f862eefec0b68e099a9fa58d3761ffb10bad97e1 upstream. It turns out the kernel relies on barrier() to force a reload of the percpu offset value. Since we can't easily modify the definition of barrier() to include "tp" as an output register, we instead provide a definition of __my_cpu_offset as extended assembly that includes a fake stack read to hazard against barrier(), forcing gcc to know that it must reread "tp" and recompute anything based on "tp" after a barrier. This fixes observed hangs in the slub allocator when we are looping on a percpu cmpxchg_double. A similar fix for ARMv7 was made in June in change 509eb76ebf97. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13sparc32: Fix exit flag passed from traced sys_sigreturnKirill Tkhai
[ Upstream commit 7a3b0f89e3fea680f93932691ca41a68eee7ab5e ] Pass 1 in %o1 to indicate that syscall_trace accounts exit. Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> CC: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13sparc64: Fix not SRA'ed %o5 in 32-bit traced syscallKirill Tkhai
[ Upstream commit ab2abda6377723e0d5fbbfe5f5aa16a5523344d1 ] (From v1 to v2: changed comment) On the way linux_sparc_syscall32->linux_syscall_trace32->goto 2f, register %o5 doesn't clear its second 32-bit. Fix that. Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> CC: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13sparc64: Fix off by one in trampoline TLB mapping installation loop.David S. Miller
[ Upstream commit 63d499662aeec1864ec36d042aca8184ea6a938e ] Reported-by: Kirill Tkhai <tkhai@yandex.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13sparc: fix ldom_reboot buffer overflow harderKees Cook
[ Upstream commit 20928bd3f08afb036c096d9559d581926b895918 ] The length argument to strlcpy was still wrong. It could overflow the end of full_boot_str by 5 bytes. Instead of strcat and strlcpy, just use snprint. Reported-by: Brad Spengler <spender@grsecurity.net> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13sparc64: Fix buggy strlcpy() conversion in ldom_reboot().David S. Miller
[ Upstream commit 2bd161a605f1f84a5fc8a4fe8410113a94f79355 ] Commit 117a0c5fc9c2d06045bd217385b2b39ea426b5a6 ("sparc: kernel: using strlcpy() instead of strcpy()") added a bug to ldom_reboot in arch/sparc/kernel/ds.c - strcpy(full_boot_str + strlen("boot "), boot_command); + strlcpy(full_boot_str + strlen("boot "), boot_command, + sizeof(full_boot_str + strlen("boot "))); That last sizeof() expression evaluates to sizeof(size_t) which is not what was intended. Also even the corrected: sizeof(full_boot_str) + strlen("boot ") is not right as the destination buffer length is just plain "sizeof(full_boot_str)" and that's what the final argument should be. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13sparc64: Remove RWSEM export leftoversKirill Tkhai
[ Upstream commit 61d9b9355b0d427bd1e732bd54628ff9103e496f ] The functions __down_read __down_read_trylock __down_write __down_write_trylock __up_read __up_write __downgrade_write are implemented inline, so remove corresponding EXPORT_SYMBOLs (They lead to compile errors on RT kernel). Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> CC: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13sparc64: Fix ITLB handler of null pageKirill Tkhai
[ Upstream commit 1c2696cdaad84580545a2e9c0879ff597880b1a9 ] 1)Use kvmap_itlb_longpath instead of kvmap_dtlb_longpath. 2)Handle page #0 only, don't handle page #1: bleu -> blu (KERNBASE is 0x400000, so #1 does not exist too. But everything is possible in the future. Fix to not to have problems later.) 3)Remove unused kvmap_itlb_nonlinear. Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> CC: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13powerpc: Restore registers on error exit from csum_partial_copy_generic()Paul E. McKenney
commit 8f21bd0090052e740944f9397e2be5ac7957ded7 upstream. The csum_partial_copy_generic() function saves the PowerPC non-volatile r14, r15, and r16 registers for the main checksum-and-copy loop. Unfortunately, it fails to restore them upon error exit from this loop, which results in silent corruption of these registers in the presumably rare event of an access exception within that loop. This commit therefore restores these register on error exit from the loop. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13powerpc/sysfs: Disable writing to PURR in guest modeMadhavan Srinivasan
commit d1211af3049f4c9c1d8d4eb8f8098cc4f4f0d0c7 upstream. arch/powerpc/kernel/sysfs.c exports PURR with write permission. This may be valid for kernel in phyp mode. But writing to the file in guest mode causes crash due to a priviledge violation Signed-off-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13powerpc: Fix parameter clobber in csum_partial_copy_generic()Paul E. McKenney
commit d9813c3681a36774b254c0cdc9cce53c9e22c756 upstream. The csum_partial_copy_generic() uses register r7 to adjust the remaining bytes to process. Unfortunately, r7 also holds a parameter, namely the address of the flag to set in case of access exceptions while reading the source buffer. Lacking a quantum implementation of PowerPC, this commit instead uses register r9 to do the adjusting, leaving r7's pointer uncorrupted. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13powerpc/vio: Fix modalias_show return valuesPrarit Bhargava
commit e82b89a6f19bae73fb064d1b3dd91fcefbb478f4 upstream. modalias_show() should return an empty string on error, not -ENODEV. This causes the following false and annoying error: > find /sys/devices -name modalias -print0 | xargs -0 cat >/dev/null cat: /sys/devices/vio/4000/modalias: No such device cat: /sys/devices/vio/4001/modalias: No such device cat: /sys/devices/vio/4002/modalias: No such device cat: /sys/devices/vio/4004/modalias: No such device cat: /sys/devices/vio/modalias: No such device Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13powerpc/tm: Switch out userspace PPR and DSCR soonerMichael Neuling
commit e9bdc3d6143d1c4b8d8ce5231fc958268331f983 upstream. When we do a treclaim or trecheckpoint we end up running with userspace PPR and DSCR values. Currently we don't do anything special to avoid running with user values which could cause a severe performance degradation. This patch moves the PPR and DSCR save and restore around treclaim and trecheckpoint so that we run with user values for a much shorter period. More care is taken with the PPR as it's impact is greater than the DSCR. This is similar to user exceptions, where we run HTM_MEDIUM early to ensure that we don't run with a userspace PPR values in the kernel. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13powerpc/perf: Fix handling of FAB eventsMichael Ellerman
commit a53b27b3abeef406de92a2bb0ceb6fb4c3fb8fc4 upstream. Commit 4df4899 "Add power8 EBB support" included a bug in the handling of the FAB_CRESP_MATCH and FAB_TYPE_MATCH fields. These values are pulled out of the event code using EVENT_THR_CTL_SHIFT, however we were then or'ing that value directly into MMCR1. This meant we were failing to set the FAB fields correctly, and also potentially corrupting the value for PMC4SEL. Leading to no counts for the FAB events and incorrect counts for PMC4. The fix is simply to shift left the FAB value correctly before or'ing it with MMCR1. Reported-by: Sooraj Ravindran Nair <soonair3@in.ibm.com> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13powerpc/iommu: Use GFP_KERNEL instead of GFP_ATOMIC in iommu_init_table()Nishanth Aravamudan
commit 1cf389df090194a0976dc867b7fffe99d9d490cb upstream. Under heavy (DLPAR?) stress, we tripped this panic() in arch/powerpc/kernel/iommu.c::iommu_init_table(): page = alloc_pages_node(nid, GFP_ATOMIC, get_order(sz)); if (!page) panic("iommu_init_table: Can't allocate %ld bytes\n", sz); Before the panic() we got a page allocation failure for an order-2 allocation. There appears to be memory free, but perhaps not in the ATOMIC context. I looked through all the call-sites of iommu_init_table() and didn't see any obvious reason to need an ATOMIC allocation. Most call-sites in fact have an explicit GFP_KERNEL allocation shortly before the call to iommu_init_table(), indicating we are not in an atomic context. There is some indirection for some paths, but I didn't see any locks indicating that GFP_KERNEL is inappropriate. With this change under the same conditions, we have not been able to reproduce the panic. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13avr32: fix clockevents kernel warningGabor Juhos
commit 1b0135b5e20c56b2edae29e92b91c0b12c983432 upstream. Since commit 01426478df3a8791ff5c8b6b82d409e699cfaf38 (avr32: Use generic idle loop) the kernel throws the following warning on avr32: WARNING: at 900322e4 [verbose debug info unavailable] Modules linked in: CPU: 0 PID: 0 Comm: swapper Not tainted 3.12.0-rc2 #117 task: 901c3ecc ti: 901c0000 task.ti: 901c0000 PC is at cpu_idle_poll_ctrl+0x1c/0x38 LR is at comparator_mode+0x3e/0x40 pc : [<900322e4>] lr : [<90014882>] Not tainted sp : 901c1f74 r12: 00000000 r11: 901c74a0 r10: 901d2510 r9 : 00000001 r8 : 901db4de r7 : 901c74a0 r6 : 00000001 r5 : 00410020 r4 : 901db574 r3 : 00410024 r2 : 90206fe0 r1 : 00000000 r0 : 007f0000 Flags: qvnzc Mode bits: hjmde....G CPU Mode: Supervisor Call trace: [<90039ede>] clockevents_set_mode+0x16/0x2e [<90039f00>] clockevents_shutdown+0xa/0x1e [<9003a078>] clockevents_exchange_device+0x58/0x70 [<9003a78c>] tick_check_new_device+0x38/0x54 [<9003a1a2>] clockevents_register_device+0x32/0x90 [<900035c4>] time_init+0xa8/0x108 [<90000520>] start_kernel+0x128/0x23c When the 'avr32_comparator' clockevent device is registered, the clockevent core sets the mode of that clockevent device to CLOCK_EVT_MODE_SHUTDOWN. Due to this, the 'comparator_mode' function calls the 'cpu_idle_poll_ctrl' to disables idle poll. This results in the aforementioned warning because the polling is not enabled yet. Change the code to only disable idle poll if it is enabled by the same function to avoid the warning. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05ARM: mxs: stub out mxs_pm_init for !CONFIG_PMArnd Bergmann
commit 7a9caf59f60e55a8caf96f856713bd0ef0cc25a7 upstream. When building a kernel without CONFIG_PM, we get a link error from referencing mxs_pm_init in the machine descriptor. This defines a macro to NULL for that case. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05ARM: 7837/3: fix Thumb-2 bug in AES assembler codeArd Biesheuvel
commit 40190c85f427dcfdbab5dbef4ffd2510d649da1f upstream. Patch 638591c enabled building the AES assembler code in Thumb2 mode. However, this code used arithmetic involving PC rather than adr{l} instructions to generate PC-relative references to the lookup tables, and this needs to take into account the different PC offset when running in Thumb mode. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05x86, efi: Don't map Boot Services on i386Josh Boyer
commit 700870119f49084da004ab588ea2b799689efaf7 upstream. Add patch to fix 32bit EFI service mapping (rhbz 726701) Multiple people are reporting hitting the following WARNING on i386, WARNING: at arch/x86/mm/ioremap.c:102 __ioremap_caller+0x3d3/0x440() Modules linked in: Pid: 0, comm: swapper Not tainted 3.9.0-rc7+ #95 Call Trace: [<c102b6af>] warn_slowpath_common+0x5f/0x80 [<c1023fb3>] ? __ioremap_caller+0x3d3/0x440 [<c1023fb3>] ? __ioremap_caller+0x3d3/0x440 [<c102b6ed>] warn_slowpath_null+0x1d/0x20 [<c1023fb3>] __ioremap_caller+0x3d3/0x440 [<c106007b>] ? get_usage_chars+0xfb/0x110 [<c102d937>] ? vprintk_emit+0x147/0x480 [<c1418593>] ? efi_enter_virtual_mode+0x1e4/0x3de [<c102406a>] ioremap_cache+0x1a/0x20 [<c1418593>] ? efi_enter_virtual_mode+0x1e4/0x3de [<c1418593>] efi_enter_virtual_mode+0x1e4/0x3de [<c1407984>] start_kernel+0x286/0x2f4 [<c1407535>] ? repair_env_string+0x51/0x51 [<c1407362>] i386_start_kernel+0x12c/0x12f Due to the workaround described in commit 916f676f8 ("x86, efi: Retain boot service code until after switching to virtual mode") EFI Boot Service regions are mapped for a period during boot. Unfortunately, with the limited size of the i386 direct kernel map it's possible that some of the Boot Service regions will not be directly accessible, which causes them to be ioremap()'d, triggering the above warning as the regions are marked as E820_RAM in the e820 memmap. There are currently only two situations where we need to map EFI Boot Service regions, 1. To workaround the firmware bug described in 916f676f8 2. To access the ACPI BGRT image but since we haven't seen an i386 implementation that requires either, this simple fix should suffice for now. [ Added to changelog - Matt ] Reported-by: Bryan O'Donoghue <bryan.odonoghue.lkml@nexus-software.ie> Acked-by: Tom Zanussi <tom.zanussi@intel.com> Acked-by: Darren Hart <dvhart@linux.intel.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05x86/reboot: Add quirk to make Dell C6100 use reboot=pci automaticallyMasoud Sharbiani
commit 4f0acd31c31f03ba42494c8baf6c0465150e2621 upstream. Dell PowerEdge C6100 machines fail to completely reboot about 20% of the time. Signed-off-by: Masoud Sharbiani <msharbiani@twitter.com> Signed-off-by: Vinson Lee <vlee@twitter.com> Cc: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Link: http://lkml.kernel.org/r/1379717947-18042-1-git-send-email-vlee@freedesktop.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26um: Implement probe_kernel_read()Richard Weinberger
commit f75b1b1bedfb498cc43a992ce4d7ed8df3b1e770 upstream. UML needs it's own probe_kernel_read() to handle kernel mode faults correctly. The implementation uses mincore() on the host side to detect whether a page is owned by the UML kernel process. This fixes also a possible crash when sysrq-t is used. Starting with 3.10 sysrq-t calls probe_kernel_read() to read details from the kernel workers. As kernel worker are completely async pointers may turn NULL while reading them. Signed-off-by: Richard Weinberger <richard@nod.at> Cc: <stian@nixia.no> Cc: <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26MIPS: ath79: Fix ar933x watchdog clockFelix Fietkau
commit a1191927ace7e6f827132aa9e062779eb3f11fa5 upstream. The watchdog device on the AR933x is connected to the AHB clock, however the current code uses the reference clock. Due to the wrong rate, the watchdog driver can't calculate correct register values for a given timeout value and the watchdog unexpectedly restarts the system. The code uses the wrong value since the initial commit 04225e1d227c8e68d685936ecf42ac175fec0e54 (MIPS: ath79: add AR933X specific clock init) The patch fixes the code to use the correct clock rate to avoid the problem. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5777/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26sched/x86: Optimize switch_mm() for multi-threaded workloadsRik van Riel
commit 8f898fbbe5ee5e20a77c4074472a1fd088dc47d1 upstream. Dick Fowles, Don Zickus and Joe Mario have been working on improvements to perf, and noticed heavy cache line contention on the mm_cpumask, running linpack on a 60 core / 120 thread system. The cause turned out to be unnecessary atomic accesses to the mm_cpumask. When in lazy TLB mode, the CPU is only removed from the mm_cpumask if there is a TLB flush event. Most of the time, no such TLB flush happens, and the kernel skips the TLB reload. It can also skip the atomic memory set & test. Here is a summary of Joe's test results: * The __schedule function dropped from 24% of all program cycles down to 5.5%. * The cacheline contention/hotness for accesses to that bitmask went from being the 1st/2nd hottest - down to the 84th hottest (0.3% of all shared misses which is now quite cold) * The average load latency for the bit-test-n-set instruction in __schedule dropped from 10k-15k cycles down to an average of 600 cycles. * The linpack program results improved from 133 GFlops to 144 GFlops. Peak GFlops rose from 133 to 153. Reported-by: Don Zickus <dzickus@redhat.com> Reported-by: Joe Mario <jmario@redhat.com> Tested-by: Joe Mario <jmario@redhat.com> Signed-off-by: Rik van Riel <riel@redhat.com> Reviewed-by: Paul Turner <pjt@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20130731221421.616d3d20@annuminas.surriel.com [ Made the comments consistent around the modified code. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26x86/mce: Pay no attention to 'F' bit in MCACOD when parsing 'UC' errorsTony Luck
commit 0ca06c0857aee11911f91621db14498496f2c2cd upstream. The 0x1000 bit of the MCACOD field of machine check MCi_STATUS registers is only defined for corrected errors (where it means that hardware may be filtering errors see SDM section 15.9.2.1). For uncorrected errors it may, or may not be set - so we should mask it out when checking for the architecturaly defined recoverable error signatures (see SDM 15.9.3.1 and 15.9.3.2) Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26x86, amd_nb: Clarify F15h, model 30h GART and L3 supportAravind Gopalakrishnan
commit 7d64ac6422092adbbdaa279ab32f9d4c90a84558 upstream. F15h, models 0x30 and later don't have a GART. Note that. Also check CPUID leaf 0x80000006 for L3 prescence because there are models which don't sport an L3 cache. Signed-off-by: Aravind Gopalakrishnan <Aravind.Gopalakrishnan@amd.com> [ Boris: rewrite commit message, cleanup comments. ] Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26Introduce [compat_]save_altstack_ex() to unbreak x86 SMAPAl Viro
commit bd1c149aa9915b9abb6d83d0f01dfd2ace0680b5 upstream. For performance reasons, when SMAP is in use, SMAP is left open for an entire put_user_try { ... } put_user_catch(); block, however, calling __put_user() in the middle of that block will close SMAP as the STAC..CLAC constructs intentionally do not nest. Furthermore, using __put_user() rather than put_user_ex() here is bad for performance. Thus, introduce new [compat_]save_altstack_ex() helpers that replace __[compat_]save_altstack() for x86, being currently the only architecture which supports put_user_try { ... } put_user_catch(). Reported-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/n/tip-es5p6y64if71k8p5u08agv9n@git.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26x86, smap: Handle csum_partial_copy_*_user()H. Peter Anvin
commit 7263dda41b5a28ae6566fd126d9b06ada73dd721 upstream. Add SMAP annotations to csum_partial_copy_to/from_user(). These functions legitimately access user space and thus need to set the AC flag. TODO: add explicit checks that the side with the kernel space pointer really points into kernel space. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/n/tip-2aps0u00eer658fd5xyanan7@git.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26KVM: PPC: Book3S: Fix compile error in XICS emulationPaul Mackerras
commit 7bfa9ad55d691f2b836b576769b11eca2cf50816 upstream. Commit 8e44ddc3f3 ("powerpc/kvm/book3s: Add support for H_IPOLL and H_XIRR_X in XICS emulation") added a call to get_tb() but didn't include the header that defines it, and on some configs this means book3s_xics.c fails to compile: arch/powerpc/kvm/book3s_xics.c: In function ‘kvmppc_xics_hcall’: arch/powerpc/kvm/book3s_xics.c:812:3: error: implicit declaration of function ‘get_tb’ [-Werror=implicit-function-declaration] Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26ARM: PCI: versatile: Fix SMAP register offsetsPeter Maydell
commit 99f2b130370b904ca5300079243fdbcafa2c708b upstream. The SMAP register offsets in the versatile PCI controller code were all off by four. (This didn't have any observable bad effects because on this board PHYS_OFFSET is zero, and (a) writing zero to the flags register at offset 0x10 has no effect and (b) the reset value of the SMAP register is zero anyway, so failing to write SMAP2 didn't matter.) Signed-off-by: Peter Maydell <peter.maydell@linaro.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
