path: root/arch
2012-08-16Merge tag 'stable/for-linus-3.6-rc1-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen fix from Konrad Rzeszutek Wilk: "Way back in v3.5 we added a mechanism to populate back pages that were released (they overlapped with MMIO regions), but neglected to reserve the proper amount of virtual space for extend_brk to work properly. Coincidentally some other commit aligned the _brk space to larger area so I didn't trigger this until it was run on a machine with more than 2GB of MMIO space." * On machines with large MMIO/PCI E820 spaces we fail to boot b/c we failed to pre-allocate large enough virtual space for extend_brk. * tag 'stable/for-linus-3.6-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/p2m: Reserve 8MB of _brk space for P2M leafs when populating back.
2012-08-16Merge tag 'sh-for-linus' of git://github.com/pmundt/linux-shLinus Torvalds
Pull SuperH fixes from Paul Mundt. * tag 'sh-for-linus' of git://github.com/pmundt/linux-sh: sh: intc: Handle domain association for sparseirq pre-allocated vectors. sh: sh7269: Fix LCD pinmux sh: dma: fix request_irq usage
2012-08-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull two sparc fixes from David S. Miller. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Be less verbose during vmemmap population. sparc64: do not clobber personality flags in sys_sparc64_personality()
2012-08-15sparc64: Be less verbose during vmemmap population.David S. Miller
On a 2-node machine with 256GB of ram we get 512 lines of console output, which is just too much. This mimicks Yinghai Lu's x86 commit c2b91e2eec9678dbda274e906cc32ea8f711da3b (x86_64/mm: check and print vmemmap allocation continuous) except that we aren't ever going to get contiguous block pointers in between calls so just print when the virtual address or node changes. This decreases the output by an order of 16. Also demote this to KERN_DEBUG. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 patches from Martin Schwidefsky: "Included are bug fixes and a patch to enable system call filtering with BPF." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/compat: fix mmap compat system calls s390/compat: fix compat wrappers for process_vm system calls s390: do not clobber personality flags in sys_32_personality() s390/seccomp: add support for system call filtering using BPF s390/sclp_sdias: Add missing break and "fall through" s390/mm: remove MAX_PHYSADDR_BITS define
2012-08-12Merge tag 'gpio-fixes-v3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull gpio fixes from Linus Walleij: - Fix a resource leak in the SCH driver - Fix the register address calculation in the MSIC driver - Fix the PXA driver's devicetree functions - Delete redundant shadow variable leftovers in the MXC driver - Specify the GPIO base for the device tree probe in the MXC driver - Add a modalias for the i.MX driver - Fix off-by-one bug in the Samsung driver - Fix erroneous errorpath in the Langwell driver * tag 'gpio-fixes-v3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: drivers/gpio/gpio-langwell.c: fix error return code gpio: samsung: Fix off-by-one bug in gpio addresses ARM: dts: imx: add alias for gpio gpio/mxc: specify gpio base for device tree probe gpio/mxc: remove redundant shadow variables initialization GPIO: gpio-pxa: fix devicetree functions gpio: msic: Fix calculating register address in msic_gpio_to_oreg() gpio-sch: Fix leak of resource
2012-08-12Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull arm-soc bug fixes from Arnd Bergmann: "These are a bunch of bug fixes that came in after the merge window and one update for the MAINTAINERS file. The largest part of the fixes are patches that address bugs found by building all the ARM defconfig files. There are a lot more warnings that we have patches for, but the others are either still under discussion or are harmless and do not cause actual problems besides making the build slightly noisy." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (30 commits) ARM: davinci: remove broken ntosd2_init_i2c ARM: s3c24xx: enable CONFIG_BUG for tct_hammer omap-rng: fix use of SIMPLE_DEV_PM_OPS spi/s3c64xx: improve error handling mtd/omap2: fix dmaengine_slave_config error handling gpio: em: do not discard em_gio_irq_domain_cleanup ARM: exynos: exynos_pm_add_dev_to_genpd may be unused ARM: imx: gpmi-nand depends on mxs-dma ARM: integrator: include <linux/export.h> ARM: s3c24xx: use new PWM driver ARM: sa1100: include linux/io.h in hackkit leds code Input: eeti_ts: pass gpio value instead of IRQ ARM: pxa: remove irq_to_gpio from ezx-pcap driver ARM: tegra: more regulator fixes for Harmony usb/ohci-omap: remove unused variable mfd/asic3: fix asic3_mfd_probe return value ARM: kirkwood: fix typo in Makefile.boot i.MX27: Fix emma-prp and csi clocks. ARM: integrator: use clk_prepare_enable() for timer MAINTAINERS: update entry for Linus Walleij ...
2012-08-12Merge branch 'fixes-for-linus-for-3.6-rc2' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull three dma-mapping fixes from Marek Szyprowski. * 'fixes-for-linus-for-3.6-rc2' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: ARM: dma-mapping: fix incorrect freeing of atomic allocations ARM: dma-mapping: fix atomic allocation alignment ARM: mm: fix MMU mapping of CMA regions
2012-08-10ARM: davinci: remove broken ntosd2_init_i2cArnd Bergmann
ntosd2_init_i2c walks the ntosd2_i2c_info array, which it expects to be populated with at least one member. gcc correctly warns about the out-of-bounds access here. Since this can not possibly work, it's better to disable i2c support entirely on this board. Without this patch, building davinci_all_defconfig results in: arch/arm/mach-davinci/board-neuros-osd2.c: In function 'davinci_ntosd2_init': arch/arm/mach-davinci/board-neuros-osd2.c:187:20: warning: array subscript is above array bounds [-Warray-bounds] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Sekhar Nori <nsekhar@ti.com> Cc: Kevin Hilman <khilman@ti.com> Cc: Andrey Porodko <panda@chelcom.ru>
2012-08-10ARM: s3c24xx: enable CONFIG_BUG for tct_hammerArnd Bergmann
Disabling CONFIG_BUG creates an insane amount of build warnings, which makes it useless to check for building defconfigs to see if new warnings show up. Without this patch, building tct_hammer_defconfig results in: net/packet/af_packet.c: In function 'tpacket_rcv': net/packet/af_packet.c:1889:30: warning: 'hdrlen' may be used uninitialized in this function [-Wuninitialized] net/core/ethtool.c: In function 'ethtool_get_feature_mask': net/core/ethtool.c:213:1: warning: control reaches end of non-void function [-Wreturn-type] block/cfq-iosched.c: In function 'cfq_async_queue_prio': block/cfq-iosched.c:2914:1: warning: control reaches end of non-void function [-Wreturn-type] mm/bootmem.c: In function 'mark_bootmem': mm/bootmem.c:352:1: warning: control reaches end of non-void function [-Wreturn-type] net/core/dev.c: In function 'skb_warn_bad_offload': net/core/dev.c:1904:33: warning: unused variable 'null_features' [-Wunused-variable] drivers/mtd/chips/cfi_probe.c: In function 'cfi_chip_setup': include/linux/mtd/cfi.h:489:3: warning: 'r.x[0]' may be used uninitialized in this function [-Wuninitialized] include/linux/mtd/map.h:394:11: note: 'r.x[0]' was declared here include/linux/mtd/cfi.h:489:3: warning: 'r.x[0]' may be used uninitialized in this function [-Wuninitialized] (and many more) The size of vmlinux increases by 1.78% because of this: size obj-arm/vmlinux.nobug text data bss dec hex filename 2108474 116916 55352 2280742 22cd26 obj-arm/vmlinux size obj-arm/vmlinux.bug text data bss dec hex filename 2150804 116916 53696 2321416 236c08 obj-arm/vmlinux Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org>
2012-08-10Merge branch 'testing/new-warnings' into fixesArnd Bergmann
These patches all fix bugs that were newly introduced in v3.6-rc1 and found because they cause a gcc warning with one of the ARM defconfigs. Most of them are harmless, but since we're trying to get rid of all warnings eventually, we can start with the ones that were not there before. * testing/new-warnings: omap-rng: fix use of SIMPLE_DEV_PM_OPS spi/s3c64xx: improve error handling mtd/omap2: fix dmaengine_slave_config error handling gpio: em: do not discard em_gio_irq_domain_cleanup ARM: exynos: exynos_pm_add_dev_to_genpd may be unused usb/ohci-omap: remove unused variable mfd/asic3: fix asic3_mfd_probe return value Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-08-10ARM: exynos: exynos_pm_add_dev_to_genpd may be unusedArnd Bergmann
exynos_pm_add_dev_to_genpd is used if one or more out of a large number of Kconfig symbols are enabled. However the new exynos_defconfig selects none of those, so the function becomes unused. Marking it so lets the compiler automatically discard it. Without this patch, building exynos_defconfig results in: arch/arm/mach-exynos/pm_domains.c:118:123: warning: 'exynos_pm_add_dev_to_genpd' defined but not used [-Wunused-function] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Abraham <thomas.abraham@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Rafael J. Wysocki <rjw@sisk.pl>
2012-08-09ARM: imx: gpmi-nand depends on mxs-dmaArnd Bergmann
It is not currently possible to build the gpmi-nand driver without also building the mxs-dma driver. Clarify this Kconfig and enable both in the defconfig file so we can build it again with both enabled. drivers/built-in.o: In function `gpmi_dma_filter': clk-fixed-factor.c:(.text+0xafc18): undefined reference to `mxs_dma_is_apbh' make[1]: *** [vmlinux] Error 1 make: *** [sub-make] Error 2 Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Sascha Hauer <kernel@pengutronix.de>
2012-08-09ARM: integrator: include <linux/export.h>Arnd Bergmann
Without this patch, building integrator_defconfig results in: arch/arm/mach-integrator/core.c:150:1: warning: data definition has no type or storage class [enabled by default] arch/arm/mach-integrator/core.c:150:1: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' [-Wimplicit-int] arch/arm/mach-integrator/core.c:150:1: warning: parameter names (without types) in function declaration [enabled by default] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Russell King <linux@arm.linux.org.uk>
2012-08-09ARM: s3c24xx: use new PWM driverArnd Bergmann
The samsung PWM driver has moved to the new PWM subsystem, which changed the Kconfig symbol for that driver, but the rx1950 and gta02 boards still uses the old one. Without this patch, building s3c2410_defconfig results in: arch/arm/mach-s3c24xx/built-in.o: In function `rx1950_lcd_power': arch/arm/mach-s3c24xx/mach-rx1950.c:430: undefined reference to `pwm_config' arch/arm/mach-s3c24xx/mach-rx1950.c:431: undefined reference to `pwm_disable' arch/arm/mach-s3c24xx/mach-rx1950.c:437: undefined reference to `pwm_config' arch/arm/mach-s3c24xx/mach-rx1950.c:438: undefined reference to `pwm_enable' arch/arm/mach-s3c24xx/built-in.o: In function `rx1950_backlight_exit': arch/arm/mach-s3c24xx/mach-rx1950.c:504: undefined reference to `pwm_free' arch/arm/mach-s3c24xx/built-in.o: In function `rx1950_backlight_init': arch/arm/mach-s3c24xx/mach-rx1950.c:487: undefined reference to `pwm_request' Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reported-by: Tushar Behera <tushar.behera@linaro.org> Cc: Kukjin Kim <kgene.kim@samsung.com>
2012-08-09ARM: sa1100: include linux/io.h in hackkit leds codeArnd Bergmann
The sa1100 definition of the io_p2v macro has changed in v3.6, and this one file stopped working because of that. Without this patch, building hackkit_defconfig results in: arch/arm/mach-sa1100/leds-hackkit.c: In function 'hackkit_leds_event': arch/arm/mach-sa1100/leds-hackkit.c:39:4: error: implicit declaration of function 'IOMEM' [-Werror=implicit-function-declaration] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk>
2012-08-09Input: eeti_ts: pass gpio value instead of IRQArnd Bergmann
The EETI touchscreen asserts its IRQ line as soon as it has data in its internal buffers. The line is automatically deasserted once all data has been read via I2C. Hence, the driver has to monitor the GPIO line and cannot simply rely on the interrupt handler reception. In the current implementation of the driver, irq_to_gpio() is used to determine the GPIO number from the i2c_client's IRQ value. As irq_to_gpio() is not available on all platforms, this patch changes this and makes the driver ignore the passed in IRQ. Instead, a GPIO is added to the platform_data struct and gpio_to_irq is used to derive the IRQ from that GPIO. If this fails, bail out. The driver is only able to work in environments where the touchscreen GPIO can be mapped to an IRQ. Without this patch, building raumfeld_defconfig results in: drivers/input/touchscreen/eeti_ts.c: In function 'eeti_ts_irq_active': drivers/input/touchscreen/eeti_ts.c:65:2: error: implicit declaration of function 'irq_to_gpio' [-Werror=implicit-function-declaration] Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: stable@vger.kernel.org (v3.2+) Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Sven Neumann <s.neumann@raumfeld.com> Cc: linux-input@vger.kernel.org Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-08-09ARM: tegra: more regulator fixes for HarmonyStephen Warren
Commit 3d55c29 "ARM: tegra: harmony: add regulator supply name and its input supply" was supposed to fix all the problems with regulators on Harmony. However, it appears that I only tested it when booting using board files, not when booting using device tree. This change fixes two problems with regulators when booting using device tree: 1) That patch only created the vdd_sys regulator when booting using a board file. Since this is the root of the whole regulator tree, this caused no regulators to successfully initialize when booting using device tree. The registration of vdd_sys is moved to fix this. 2) When booting use DT, the regulator core sets has_full_constraints, which in turn causes the core to turn off any regulators not marked as always on. Some of the affected regulators are required for basic system operation. To solve this, add always on constraints to all relevant regulators. This doesn't affect booting using a board file since nothing sets has_full_constraints in that case. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-08-09ARM: dma-mapping: fix incorrect freeing of atomic allocationsAaro Koskinen
Commit e9da6e9905e639b0f842a244bc770b48ad0523e9 (ARM: dma-mapping: remove custom consistent dma region) changed the way atomic allocations are handled. However, arm_dma_free() was not modified accordingly, and as a result freeing of atomic allocations does not work correctly when CMA is disabled. Memory is leaked and following WARNINGs are seen: [ 57.698911] ------------[ cut here ]------------ [ 57.753518] WARNING: at arch/arm/mm/dma-mapping.c:263 arm_dma_free+0x88/0xe4() [ 57.811473] trying to free invalid coherent area: e0848000 [ 57.867398] Modules linked in: sata_mv(-) [ 57.921373] [<c000d270>] (unwind_backtrace+0x0/0xf0) from [<c0015430>] (warn_slowpath_common+0x50/0x68) [ 58.033924] [<c0015430>] (warn_slowpath_common+0x50/0x68) from [<c00154dc>] (warn_slowpath_fmt+0x30/0x40) [ 58.152024] [<c00154dc>] (warn_slowpath_fmt+0x30/0x40) from [<c000dc18>] (arm_dma_free+0x88/0xe4) [ 58.219592] [<c000dc18>] (arm_dma_free+0x88/0xe4) from [<c008fa30>] (dma_pool_destroy+0x100/0x148) [ 58.345526] [<c008fa30>] (dma_pool_destroy+0x100/0x148) from [<c019a64c>] (release_nodes+0x144/0x218) [ 58.475782] [<c019a64c>] (release_nodes+0x144/0x218) from [<c0197e10>] (__device_release_driver+0x60/0xb8) [ 58.614260] [<c0197e10>] (__device_release_driver+0x60/0xb8) from [<c0198608>] (driver_detach+0xd8/0xec) [ 58.756527] [<c0198608>] (driver_detach+0xd8/0xec) from [<c0197c54>] (bus_remove_driver+0x7c/0xc4) [ 58.901648] [<c0197c54>] (bus_remove_driver+0x7c/0xc4) from [<c004bfac>] (sys_delete_module+0x19c/0x220) [ 59.051447] [<c004bfac>] (sys_delete_module+0x19c/0x220) from [<c0009140>] (ret_fast_syscall+0x0/0x2c) [ 59.207996] ---[ end trace 0745420412c0325a ]--- [ 59.287110] ------------[ cut here ]------------ [ 59.366324] WARNING: at arch/arm/mm/dma-mapping.c:263 arm_dma_free+0x88/0xe4() [ 59.450511] trying to free invalid coherent area: e0847000 [ 59.534357] Modules linked in: sata_mv(-) [ 59.616785] [<c000d270>] (unwind_backtrace+0x0/0xf0) from [<c0015430>] (warn_slowpath_common+0x50/0x68) [ 59.790030] [<c0015430>] (warn_slowpath_common+0x50/0x68) from [<c00154dc>] (warn_slowpath_fmt+0x30/0x40) [ 59.972322] [<c00154dc>] (warn_slowpath_fmt+0x30/0x40) from [<c000dc18>] (arm_dma_free+0x88/0xe4) [ 60.070701] [<c000dc18>] (arm_dma_free+0x88/0xe4) from [<c008fa30>] (dma_pool_destroy+0x100/0x148) [ 60.256817] [<c008fa30>] (dma_pool_destroy+0x100/0x148) from [<c019a64c>] (release_nodes+0x144/0x218) [ 60.445201] [<c019a64c>] (release_nodes+0x144/0x218) from [<c0197e10>] (__device_release_driver+0x60/0xb8) [ 60.634148] [<c0197e10>] (__device_release_driver+0x60/0xb8) from [<c0198608>] (driver_detach+0xd8/0xec) [ 60.823623] [<c0198608>] (driver_detach+0xd8/0xec) from [<c0197c54>] (bus_remove_driver+0x7c/0xc4) [ 61.013268] [<c0197c54>] (bus_remove_driver+0x7c/0xc4) from [<c004bfac>] (sys_delete_module+0x19c/0x220) [ 61.203472] [<c004bfac>] (sys_delete_module+0x19c/0x220) from [<c0009140>] (ret_fast_syscall+0x0/0x2c) [ 61.393390] ---[ end trace 0745420412c0325b ]--- The patch fixes this. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2012-08-09ARM: dma-mapping: fix atomic allocation alignmentAaro Koskinen
The alignment mask is calculated incorrectly. Fixing the calculation makes strange hangs/lockups disappear during the boot with Amstrad E3 and 3.6-rc1 kernel. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2012-08-09ARM: mm: fix MMU mapping of CMA regionsChris Brand
Fix dma_contiguous_remap() so that it continues through all the regions, even after encountering one that is outside lowmem. Without this change, if you have two CMA regions, the first outside lowmem and the seocnd inside lowmem, only the second one will get set up in the MMU. Data written to that region then doesn't get automatically flushed from the cache into memory. Signed-off-by: Chris Brand <cbrand@broadcom.com> [extended patch subject with 'fix' word] Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2012-08-09Merge branches 'sh/urgent' and 'sh/gpiolib' into sh-latestPaul Mundt
2012-08-09sh: sh7269: Fix LCD pinmuxPhil Edworthy
There are two ports that can output the LCD data, therefore they have to use separate pimux identifiers so we can select the one we want to use. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-08-09sh: dma: fix request_irq usageMike Frysinger
When calling request_irq with IRQF_SHARED, the dev cookie must be set (i.e. non-NULL), otherwise the code rejects it immediately with -EINVAL. So restore the logic here where we'd pass a pointer to the name as a dummy unique val. Otherwise, booting up on my LANDISK system would fail with: DMAC Address Error0 request_irq fail This was introduced in commit 7f47c7189b3e8f19a589f77a3ad169d7b691b582. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-08-08s390/compat: fix mmap compat system callsHeiko Carstens
The native 31 bit and the compat behaviour for the mmap system calls differ: In native 31 bit mode the passed in address for the mmap system call will be unmodified passed to sys_mmap_pgoff(). In compat mode however the passed in address will be modified with compat_ptr() which masks out the most significant bit. The result is that in native 31 bit mode each mmap request (with MAP_FIXED) will fail where the most significat bit is set, while in compat mode it may succeed. This odd behaviour was introduced with d3815898 "[S390] mmap: add missing compat_ptr conversion to both mmap compat syscalls". To restore a consistent behaviour accross native and compat mode this patch functionally reverts the above mentioned commit. Cc: stable@vger.kernel.org Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-08-08s390/compat: fix compat wrappers for process_vm system callsHeiko Carstens
The compat wrappers incorrectly called the non compat versions of the system process_vm system calls. Cc: stable@vger.kernel.org Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-08-08s390: do not clobber personality flags in sys_32_personality()Jiri Kosina
There are multiple errors in how sys_32_personality() handles personality flags stored in top three bytes. - directly comparing current->personality against PER_LINUX32 doesn't work in cases when any of the personality flags stored in the top three bytes are used. - directly forcefully setting personality to PER_LINUX32 or PER_LINUX discards any flags stored in the top three bytes Fix the first one by properly using personality() macro to compare only PER_MASK bytes. Fix the second one by setting only the bits that should be set, instead of overwriting the whole value. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-08-08s390/seccomp: add support for system call filtering using BPFHeiko Carstens
2012-08-08s390/mm: remove MAX_PHYSADDR_BITS defineHeiko Carstens
It's unused, so remove it. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-08-07Merge tag 'imx-fixes' of git://git.pengutronix.de/git/imx/linux-2.6 into fixesArnd Bergmann
ARM i.MX fixes for 3.6-rc * tag 'imx-fixes' of git://git.pengutronix.de/git/imx/linux-2.6: i.MX27: Fix emma-prp and csi clocks. ARM: clk-imx31: Fix the keypad clock name ARM: dts: imx27-3ds.dts: Fix serial console node
2012-08-07ARM: kirkwood: fix typo in Makefile.bootSebastian Hesselbarth
Just a small typo fix to make lsxl dtbs compile Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@googlemail.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-08-07i.MX27: Fix emma-prp and csi clocks.Javier Martin
Naming of emma-prp related clocks for the i.MX27 is not correct. Signed-off-by: Javier Martin <javier.martin@vista-silicon.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-08-07ARM: dts: imx: add alias for gpioShawn Guo
Add alias for gpio nodes, so that gpio driver can identify the port number and then specify a sensible gpio base rather than using the one dynamically allocated by gpio core. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-08-06ARM: integrator: use clk_prepare_enable() for timerLinus Walleij
The Integrator timer is using the clock framework to get the timer frequency, but missed to prepare the clock before enabling. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-08-06Merge branch 'mxs/fixes-for-3.6' of ↵Arnd Bergmann
git://git.linaro.org/people/shawnguo/linux-2.6 into fixes * 'mxs/fixes-for-3.6' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: mxs: always build ocotp ARM: mxs: Remove MMAP_MIN_ADDR setting from mxs_defconfig ARM: mx28: Fix registers range ARM: mx23: Fix registers range
2012-08-04ARM: mxs: always build ocotpMarc Kleine-Budde
With this patch ocotp support will always be build into the kernel on mxs. Otherwise a DT-only kernel fails to link with: arch/arm/mach-mxs/mach-mxs.c:169: undefined reference to `mxs_get_ocotp' Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-08-04ARM: mxs: Remove MMAP_MIN_ADDR setting from mxs_defconfigMarek Vasut
The CONFIG_DEFAULT_MMAP_MIN_ADDR was set to 65536 in mxs_defconfig, this caused severe breakage of userland applications since the upper limit for ARM is 32768. By default CONFIG_DEFAULT_MMAP_MIN_ADDR is set to 4096 and can also be changed via /proc/sys/vm/mmap_min_addr if needed. Quoting Russell King [1]: "4096 is also fine for ARM too. There's not much point in having defconfigs change it - that would just be pure noise in the config files." the CONFIG_DEFAULT_MMAP_MIN_ADDR can be removed from the defconfig altogether. This problem was introduced by commit cde7c41 (ARM: configs: add defconfig for mach-mxs). [1] http://marc.info/?l=linux-arm-kernel&m=134401593807820&w=2 Signed-off-by: Marek Vasut <marex@denx.de> Cc: stable@vger.kernel.org Cc: Russell King <linux@arm.linux.org.uk> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-08-03Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull ACPI and power management fixes from Len Brown: "A 3.3 sleep regression fixed, numa bugfix, plus some minor cleanups" * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: ACPI processor: Fix tick_broadcast_mask online/offline regression ACPI: Only count valid srat memory structures ACPI: Untangle a return statement for better readability ACPI / PCI: Do not try to acquire _OSC control if that is hopeless ACPI: delete _GTS/_BFS support ACPI/x86: revert 'x86, acpi: Call acpi_enter_sleep_state via an asmlinkage C function from assembler' ACPI: replace strlen("string") with sizeof("string") -1 ACPI / PM: Fix build warning in sleep.c for CONFIG_ACPI_SLEEP unset
2012-08-03Merge git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM bug fixes from Marcelo Tosatti: - Fix DS/ES segment register corruption on x86_32. - Fix kvmclock wallclock migration offset. - Fix PIT interrupt ACK vs system reset logic bug. * git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: VMX: Fix ds/es corruption on i386 with preemption KVM: x86: apply kvmclock offset to guest wall clock time KVM: PIC: call ack notifiers for irqs that are dropped form irr
2012-08-03Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Various fixes" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86-64, kcmp: The kcmp system call can be common arch/x86/kernel/kdebugfs.c: Ensure a consistent return value in error case x86/mce: Add quirk for instruction recovery on Sandy Bridge processors x86/mce: Move MCACOD defines from mce-severity.c to <asm/mce.h> x86/ioapic: Fix NULL pointer dereference on CPU hotplug after disabling irqs x86, nops: Missing break resulting in incorrect selection on Intel x86: CONFIG_CC_STACKPROTECTOR=y is no longer experimental
2012-08-03Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Fix merge window fallout and fix sleep profiling (this was always broken, so it's not a fix for the merge window - we can skip this one from the head of the tree)." * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/trace: Add ability to set a target task for events perf/x86: Fix USER/KERNEL tagging of samples properly perf/x86/intel/uncore: Make UNCORE_PMU_HRTIMER_INTERVAL 64-bit
2012-08-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k updates from Geert Uytterhoeven. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k: Make sys_atomic_cmpxchg_32 work on classic m68k m68k/apollo: Rename "timer" to "apollo_timer" zorro: Remove unused zorro_bus.devices m68k: Remove never used asm/shm.h m68k/sun3: Remove unselectable code in prom_init() m68k: Use asm-generic version of <asm/sections.h> m68k: Replace m68k-specific _[se]bss by generic __bss_{start,stop} mtd/uclinux: Use generic __bss_stop instead of _ebss m68knommu: Allow ColdFire CPUs to use unaligned accesses m68k: Remove five unused headers m68k: CPU32 does not support unaligned accesses m68k: Introduce config option CPU_HAS_NO_UNALIGNED m68k: delay, muldi3 - Use CONFIG_CPU_HAS_NO_MULDIV64 m68k: Move CPU_HAS_* config options m68k: Remove duplicate FPU config option m68knommu: Clean up printing of sections m68k: Use asm-generic version of <asm/types.h> m68k: Use Kbuild logic to import asm-generic headers
2012-08-03ARM: dts: imx: fix gpio interrupts propertyShawn Guo
Commit 88cde8b (ARM: dts: imx: update #interrupt-cells for gpio nodes) changes gpio #interrupt-cells from 1 to 2 without updating the users. It causes the gpio irq requesting call failing in client driver's probe function. Add the irq type cell for those gpio interrupt users to fix their driver probe failure. Reported-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-08-03ARM: dts: imx53-ard: add regulators for lan9220Shawn Guo
Since commit c7e963f (net/smsc911x: Add regulator support), the lan9220 device tree probe fails on imx53-ard board, because the commit makes VDD33A and VDDVARIO supplies mandatory for the driver. Add a fixed dummy 3V3 supplying lan9220 to fix the regression. Cc: stable@vger.kernel.org Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-08-03ARM: imx: enable emi_slow_gate clock for imx5Shawn Guo
The imx5 common clock migration causes a regression with smsc911x driver on imx53-ard board, where a smsc lan9220 controller gets connected on imx53 with EIM interface. EIM needs clock emi_slow_gate to be functional. In the new imx5 clock driver, there is no use count incremented for the clock by enabling it, so the framework closes the clock at late init time and makes EIM stop working then. Enable emi_slow_gate in clock driver initialization to fix the regression. Cc: stable@vger.kernel.org Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-08-03ARM: clk-imx31: Fix the keypad clock nameFabio Estevam
Fix the keypad clock name, in order to fix the following error: imx-keypad imx-keypad: failed to get keypad clock imx-keypad: probe of imx-keypad failed with error -2 Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Cc: stable@vger.kernel.org
2012-08-03ARM: mx28: Fix registers rangeFabio Estevam
Fix registers range. Cc: stable@vger.kernel.org Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-08-03ARM: mx23: Fix registers rangeFabio Estevam
2012-08-03ARM: imx6q-sabrelite: Setup CLKO IOMUXFabio Estevam
In order to have audio functional on mx6qsabrelite, it is necessary to setup the IOMUX for MX6Q_PAD_GPIO_0__CCM_CLKO pins as it provides the audio clock. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-08-03Merge branches 'delete-gts-bfs', 'misc', 'novell-bugzilla-757888-numa' and ↵Len Brown
'osc-pcie' into base
