path: root/arch
2015-06-22MIPS: Fix enabling of DEBUG_STACKOVERFLOWJames Hogan
commit 5f35b9cd553fd64415b563497d05a563c988dbd6 upstream. Commit 334c86c494b9 ("MIPS: IRQ: Add stackoverflow detection") added kernel stack overflow detection, however it only enabled it conditional upon the preprocessor definition DEBUG_STACKOVERFLOW, which is never actually defined. The Kconfig option is called DEBUG_STACKOVERFLOW, which manifests to the preprocessor as CONFIG_DEBUG_STACKOVERFLOW, so switch it to using that definition instead. Fixes: 334c86c494b9 ("MIPS: IRQ: Add stackoverflow detection") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Adam Jiang <jiang.adam@gmail.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/10531/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-05ARM: fix missing syscall trace exitRussell King
commit 1b97937246d8b97c0760d16d8992c7937bdf5e6a upstream. Josh Stone reports: I've discovered a case where both arm and arm64 will miss a ptrace syscall-exit that they should report. If the syscall is entered without TIF_SYSCALL_TRACE set, then it goes on the fast path. It's then possible to have TIF_SYSCALL_TRACE added in the middle of the syscall, but ret_fast_syscall doesn't check this flag again. Fix this by always checking for a syscall trace in the fast exit path. Reported-by: Josh Stone <jistone@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-05ARM: dts: imx27: only map 4 Kbyte for fec registersPhilippe Reynes
commit a29ef819f3f34f89a1b9b6a939b4c1cdfe1e85ce upstream. According to the imx27 documentation, fec has a 4 Kbyte memory space map. Moreover, the actual 16 Kbyte mapping overlaps the SCC (Security Controller) memory register space. So, we reduce the memory register space to 4 Kbyte. Signed-off-by: Philippe Reynes <tremyfr@gmail.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Fixes: 9f0749e3eb88 ("ARM i.MX27: Add devicetree support") Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-05crypto: s390/ghash - Fix incorrect ghash icv buffer handling.Harald Freudenberger
commit a1cae34e23b1293eccbcc8ee9b39298039c3952a upstream. Multitheaded tests showed that the icv buffer in the current ghash implementation is not handled correctly. A move of this working ghash buffer value to the descriptor context fixed this. Code is tested and verified with an multithreaded application via af_alg interface. Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com> Signed-off-by: Gerald Schaefer <geraldsc@linux.vnet.ibm.com> Reported-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-05powerpc: Align TOC to 256 bytesAnton Blanchard
commit 5e95235ccd5442d4a4fe11ec4eb99ba1b7959368 upstream. Recent toolchains force the TOC to be 256 byte aligned. We need to enforce this alignment in our linker script, otherwise pointers to our TOC variables (__toc_start, __prom_init_toc_start) could be incorrect. If they are bad, we die a few hundred instructions into boot. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-05KVM: MMU: fix CR4.SMEP=1, CR0.WP=0 with shadow pagesPaolo Bonzini
commit 898761158be7682082955e3efa4ad24725305fc7 upstream. smep_andnot_wp is initialized in kvm_init_shadow_mmu and shadow pages should not be reused for different values of it. Thus, it has to be added to the mask in kvm_mmu_pte_write. Reviewed-by: Xiao Guangrong <guangrong.xiao@linux.intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17ARM: mvebu: armada-xp-openblocks-ax3-4: Disable internal RTCGregory CLEMENT
commit 750e30d4076ae5e02ad13a376e96c95a2627742c upstream. There is no crystal connected to the internal RTC on the Open Block AX3. So let's disable it in order to prevent the kernel probing the driver uselessly. Eventually this patches removes the following warning message from the boot log: "rtc-mv d0010300.rtc: internal RTC not ticking" Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17ARM: dts: imx23-olinuxino: Fix dr_mode of usb0Stefan Wahren
commit 0fdebe1a2f4d3a8fc03754022fabf8ba95e131a3 upstream. The dr_mode of usb0 on imx233-olinuxino is left to default "otg". Since the green LED (GPIO2_1) on imx233-olinuxino is connected to the same pin as USB_OTG_ID it's possible to disable USB host by LED toggling: echo 0 > /sys/class/leds/green/brightness [ 1068.890000] ci_hdrc ci_hdrc.0: remove, state 1 [ 1068.890000] usb usb1: USB disconnect, device number 1 [ 1068.920000] usb 1-1: USB disconnect, device number 2 [ 1068.920000] usb 1-1.1: USB disconnect, device number 3 [ 1069.070000] usb 1-1.2: USB disconnect, device number 4 [ 1069.450000] ci_hdrc ci_hdrc.0: USB bus 1 deregistered [ 1074.460000] ci_hdrc ci_hdrc.0: timeout waiting for 00000800 in 11 This patch fixes the issue by setting dr_mode to "host" in the dts file. Reported-by: Harald Geyer <harald@ccbib.org> Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Peter Chen <peter.chen@freescale.com> Fixes: b49312948285 ("ARM: dts: imx23-olinuxino: Add USB host support") Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17ARM: dts: imx28: Fix AUART4 TX-DMA interrupt nameMarek Vasut
commit 4ada77e37a773168fea484899201e272ab44ba8b upstream. Fix a typo in the TX DMA interrupt name for AUART4. This patch makes AUART4 operational again. Signed-off-by: Marek Vasut <marex@denx.de> Fixes: f30fb03d4d3a ("ARM: dts: add generic DMA device tree binding for mxs-dma") Acked-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17ARM: dts: imx25: Add #pwm-cells to pwm4Markus Pargmann
commit f90d3f0d0a11fa77918fd5497cb616dd2faa8431 upstream. The property '#pwm-cells' is currently missing. It is not possible to use pwm4 without this property. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Fixes: 5658a68fb578 ("ARM i.MX25: Add devicetree") Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ARC: signal handling robustifyVineet Gupta
commit e4140819dadc3624accac8294881bca8a3cba4ed upstream. A malicious signal handler / restorer can DOS the system by fudging the user regs saved on stack, causing weird things such as sigreturn returning to user mode PC but cpu state still being kernel mode.... Ensure that in sigreturn path status32 always has U bit; any other bogosity (gargbage PC etc) will be taken care of by normal user mode exceptions mechanisms. Reproducer signal handler: void handle_sig(int signo, siginfo_t *info, void *context) { ucontext_t *uc = context; struct user_regs_struct *regs = &(uc->uc_mcontext.regs); regs->scratch.status32 = 0; } Before the fix, kernel would go off to weeds like below: --------->8----------- [ARCLinux]$ ./signal-test Path: /signal-test CPU: 0 PID: 61 Comm: signal-test Not tainted 4.0.0-rc5+ #65 task: 8f177880 ti: 5ffe6000 task.ti: 8f15c000 [ECR ]: 0x00220200 => Invalid Write @ 0x00000010 by insn @ 0x00010698 [EFA ]: 0x00000010 [BLINK ]: 0x2007c1ee [ERET ]: 0x10698 [STAT32]: 0x00000000 : <-------- BTA: 0x00010680 SP: 0x5ffe7e48 FP: 0x00000000 LPS: 0x20003c6c LPE: 0x20003c70 LPC: 0x00000000 ... --------->8----------- Reported-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ARM: dts: dove: Fix uart[23] reg propertySebastian Hesselbarth
commit a74cd13b807029397f7232449df929bac11fb228 upstream. Fix Dove's register addresses of uart2 and uart3 nodes that seem to be broken since ages due to a copy-and-paste error. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06s390: Fix build errorGuenter Roeck
s390 images fail to build in 3.10 with arch/s390/kernel/suspend.c: In function 'pfn_is_nosave': arch/s390/kernel/suspend.c:147:10: error: 'ipl_info' undeclared arch/s390/kernel/suspend.c:147:27: error: 'IPL_TYPE_NSS' undeclared due to a missing include file. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06nosave: consolidate __nosave_{begin,end} in <asm/sections.h>Geert Uytterhoeven
commit 7f8998c7aef3ac9c5f3f2943e083dfa6302e90d0 upstream. The different architectures used their own (and different) declarations: extern __visible const void __nosave_begin, __nosave_end; extern const void __nosave_begin, __nosave_end; extern long __nosave_begin, __nosave_end; Consolidate them using the first variant in <asm/sections.h>. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06C6x: time: Ensure consistency in __initNishanth Menon
commit f4831605f2dacd12730fe73961c77253cc2ea425 upstream. time_init invokes timer64_init (which is __init annotation) since all of these are invoked at init time, lets maintain consistency by ensuring time_init is marked appropriately as well. This fixes the following warning with CONFIG_DEBUG_SECTION_MISMATCH=y WARNING: vmlinux.o(.text+0x3bfc): Section mismatch in reference from the function time_init() to the function .init.text:timer64_init() The function time_init() references the function __init timer64_init(). This is often because time_init lacks a __init annotation or the annotation of timer64_init is wrong. Fixes: 546a39546c64 ("C6X: time management") Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06xtensa: provide __NR_sync_file_range2 instead of __NR_sync_file_rangeMax Filippov
commit 01e84c70fe40c8111f960987bcf7f931842e6d07 upstream. xtensa actually uses sync_file_range2 implementation, so it should define __NR_sync_file_range2 as other architectures that use that function. That fixes userspace interface (that apparently never worked) and avoids special-casing xtensa in libc implementations. See the thread ending at http://lists.busybox.net/pipermail/uclibc/2015-February/048833.html for more details. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06xtensa: xtfpga: fix hardware lockup caused by LCD driverMax Filippov
commit 4949009eb8d40a441dcddcd96e101e77d31cf1b2 upstream. LCD driver is always built for the XTFPGA platform, but its base address is not configurable, and is wrong for ML605/KC705. Its initialization locks up KC705 board hardware. Make the whole driver optional, and its base address and bus width configurable. Implement 4-bit bus access method. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06powerpc/perf: Cap 64bit userspace backtraces to PERF_MAX_STACK_DEPTHAnton Blanchard
commit 9a5cbce421a283e6aea3c4007f141735bf9da8c3 upstream. We cap 32bit userspace backtraces to PERF_MAX_STACK_DEPTH (currently 127), but we forgot to do the same for 64bit backtraces. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06arm64: kernel: compiling issue, need delete read_current_timer()Chen Gang
commit 6916b14ea140ff5c915895eefe9431888a39a84d upstream. Under arm64, we will calibrate the delay loop statically using a known timer frequency, so delete read_current_timer(), or it will cause compiling issue with allmodconfig. The related error: ERROR: "read_current_timer" [lib/rbtree_test.ko] undefined! ERROR: "read_current_timer" [lib/interval_tree_test.ko] undefined! ERROR: "read_current_timer" [fs/ext4/ext4.ko] undefined! ERROR: "read_current_timer" [crypto/tcrypt.ko] undefined! Signed-off-by: Chen Gang <gang.chen@asianux.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06ARM: S3C64XX: Use fixed IRQ bases to avoid conflicts on CragganmoreCharles Keepax
commit 4e330ae4ab2915444f1e6dca1358a910aa259362 upstream. There are two PMICs on Cragganmore, currently one dynamically assign its IRQ base and the other uses a fixed base. It is possible for the statically assigned PMIC to fail if its IRQ is taken by the dynamically assigned one. Fix this by statically assigning both the IRQ bases. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06ARM: 8320/1: fix integer overflow in ELF_ET_DYN_BASEAndrey Ryabinin
commit 8defb3367fcd19d1af64c07792aade0747b54e0f upstream. Usually ELF_ET_DYN_BASE is 2/3 of TASK_SIZE. With 3G/1G user/kernel split this is not so, because 2*TASK_SIZE overflows 32 bits, so the actual value of ELF_ET_DYN_BASE is: (2 * TASK_SIZE / 3) = 0x2a000000 When ASLR is disabled PIE binaries will load at ELF_ET_DYN_BASE address. On 32bit platforms AddressSanitzer uses addresses [0x20000000 - 0x40000000] for shadow memory [1]. So ASan doesn't work for PIE binaries when ASLR disabled as it fails to map shadow memory. Also after Kees's 'split ET_DYN ASLR from mmap ASLR' patchset PIE binaries has a high chance of loading somewhere in between [0x2a000000 - 0x40000000] even if ASLR enabled. This makes ASan with PIE absolutely incompatible. Fix overflow by dividing TASK_SIZE prior to multiplying. After this patch ELF_ET_DYN_BASE equals to (for CONFIG_VMSPLIT_3G=y): (TASK_SIZE / 3 * 2) = 0x7f555554 [1] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerAlgorithm#Mapping Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Reported-by: Maria Guseva <m.guseva@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06MIPS: Hibernate: flush TLB entries earlierHuacai Chen
commit a843d00d038b11267279e3b5388222320f9ddc1d upstream. We found that TLB mismatch not only happens after kernel resume, but also happens during snapshot restore. So move it to the beginning of swsusp_arch_suspend(). Signed-off-by: Huacai Chen <chenhc@lemote.com> Cc: Steven J. Hill <Steven.Hill@imgtec.com> Cc: linux-mips@linux-mips.org Cc: Fuxin Zhang <zhangfx@lemote.com> Cc: Zhangjin Wu <wuzhangjin@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/9621/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06s390/hibernate: fix save and restore of kernel text sectionHeiko Carstens
commit d74419495633493c9cd3f2bbeb7f3529d0edded6 upstream. Sebastian reported a crash caused by a jump label mismatch after resume. This happens because we do not save the kernel text section during suspend and therefore also do not restore it during resume, but use the kernel image that restores the old system. This means that after a suspend/resume cycle we lost all modifications done to the kernel text section. The reason for this is the pfn_is_nosave() function, which incorrectly returns that read-only pages don't need to be saved. This is incorrect since we mark the kernel text section read-only. We still need to make sure to not save and restore pages contained within NSS and DCSS segment. To fix this add an extra case for the kernel text section and only save those pages if they are not contained within an NSS segment. Fixes the following crash (and the above bugs as well): Jump label code mismatch at netif_receive_skb_internal+0x28/0xd0 Found: c0 04 00 00 00 00 Expected: c0 f4 00 00 00 11 New: c0 04 00 00 00 00 Kernel panic - not syncing: Corrupted kernel text CPU: 0 PID: 9 Comm: migration/0 Not tainted 3.19.0-01975-gb1b096e70f23 #4 Call Trace: [<0000000000113972>] show_stack+0x72/0xf0 [<000000000081f15e>] dump_stack+0x6e/0x90 [<000000000081c4e8>] panic+0x108/0x2b0 [<000000000081be64>] jump_label_bug.isra.2+0x104/0x108 [<0000000000112176>] __jump_label_transform+0x9e/0xd0 [<00000000001121e6>] __sm_arch_jump_label_transform+0x3e/0x50 [<00000000001d1136>] multi_cpu_stop+0x12e/0x170 [<00000000001d1472>] cpu_stopper_thread+0xb2/0x168 [<000000000015d2ac>] smpboot_thread_fn+0x134/0x1b0 [<0000000000158baa>] kthread+0x10a/0x110 [<0000000000824a86>] kernel_thread_starter+0x6/0xc Reported-and-tested-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06KVM: s390: Zero out current VMDB of STSI before including level3 data.Ekaterina Tumanova
commit b75f4c9afac2604feb971441116c07a24ecca1ec upstream. s390 documentation requires words 0 and 10-15 to be reserved and stored as zeros. As we fill out all other fields, we can memset the full structure. Signed-off-by: Ekaterina Tumanova <tumanova@linux.vnet.ibm.com> Reviewed-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-29arc: mm: Fix build failureGuenter Roeck
commit e262eb9381ad51b5de7a9e762ee773bbd25ce650 upstream. Fix misspelled define. Fixes: 33692f27597f ("vm: add VM_FAULT_SIGSEGV handling support") Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-29x86: mm: move mmap_sem unlock from mm_fault_error() to callerLinus Torvalds
commit 7fb08eca45270d0ae86e1ad9d39c40b7a55d0190 upstream. This replaces four copies in various stages of mm_fault_error() handling with just a single one. It will also allow for more natural placement of the unlocking after some further cleanup. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-29vm: add VM_FAULT_SIGSEGV handling supportLinus Torvalds
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream. The core VM already knows about VM_FAULT_SIGBUS, but cannot return a "you should SIGSEGV" error, because the SIGSEGV case was generally handled by the caller - usually the architecture fault handler. That results in lots of duplication - all the architecture fault handlers end up doing very similar "look up vma, check permissions, do retries etc" - but it generally works. However, there are cases where the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV. In particular, when accessing the stack guard page, libsigsegv expects a SIGSEGV. And it usually got one, because the stack growth is handled by that duplicated architecture fault handler. However, when the generic VM layer started propagating the error return from the stack expansion in commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page"), that now exposed the existing VM_FAULT_SIGBUS result to user space. And user space really expected SIGSEGV, not SIGBUS. To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those duplicate architecture fault handlers about it. They all already have the code to handle SIGSEGV, so it's about just tying that new return value to the existing code, but it's all a bit annoying. This is the mindless minimal patch to do this. A more extensive patch would be to try to gather up the mostly shared fault handling logic into one generic helper routine, and long-term we really should do that cleanup. Just from this patch, you can generally see that most architectures just copied (directly or indirectly) the old x86 way of doing things, but in the meantime that original x86 model has been improved to hold the VM semaphore for shorter times etc and to handle VM_FAULT_RETRY and other "newer" things, so it would be a good idea to bring all those improvements to the generic case and teach other architectures about them too. Reported-and-tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots" Cc: linux-arch@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [shengyong: Backport to 3.10 - adjust context - ignore modification for arch nios2, because 3.10 does not support it - ignore modification for driver lustre, because 3.10 does not support it - ignore VM_FAULT_FALLBACK in VM_FAULT_ERROR, becase 3.10 does not support this flag - add SIGSEGV handling to powerpc/cell spu_fault.c, because 3.10 does not separate it to copro_fault.c - add SIGSEGV handling in mm/memory.c, because 3.10 does not separate it to gup.c ] Signed-off-by: Sheng Yong <shengyong1@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-29move d_rcu from overlapping d_child to overlapping d_aliasAl Viro
commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Ben Hutchings <ben@decadent.org.uk> [hujianyang: Backported to 3.10 refer to the work of Ben Hutchings in 3.2: - Apply name changes in all the different places we use d_alias and d_child - Move the WARN_ON() in __d_free() to d_free() as we don't have dentry_free()] Signed-off-by: hujianyang <hujianyang@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-29KVM: x86: SYSENTER emulation is brokenNadav Amit
commit f3747379accba8e95d70cec0eae0582c8c182050 upstream. SYSENTER emulation is broken in several ways: 1. It misses the case of 16-bit code segments completely (CVE-2015-0239). 2. MSR_IA32_SYSENTER_CS is checked in 64-bit mode incorrectly (bits 0 and 1 can still be set without causing #GP). 3. MSR_IA32_SYSENTER_EIP and MSR_IA32_SYSENTER_ESP are not masked in legacy-mode. 4. There is some unneeded code. Fix it. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> [zhangzhiqiang: backport to 3.10: - adjust context - in 3.10 context "ctxt->eflags &= ~(EFLG_VM | EFLG_IF | EFLG_RF)" is replaced by "ctxt->eflags &= ~(EFLG_VM | EFLG_IF)" in upstream, which was changed by another commit. - After the above adjustments, becomes same to the original patch: https://github.com/torvalds/linux/commit/f3747379accba8e95d70cec0eae0582c8c182050 ] Signed-off-by: Zhiqiang Zhang <zhangzhiqiang.zhang@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-13powerpc/mpc85xx: Add ranges to etsec2 nodesScott Wood
commit bb344ca5b90df62b1a3b7a35c6a9d00b306a170d upstream. Commit 746c9e9f92dd "of/base: Fix PowerPC address parsing hack" limited the applicability of the workaround whereby a missing ranges is treated as an empty ranges. This workaround was hiding a bug in the etsec2 device tree nodes, which have children with reg, but did not have ranges. Signed-off-by: Scott Wood <scottwood@freescale.com> Reported-by: Alexander Graf <agraf@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26ARM: at91: pm: fix at91rm9200 standbyAlexandre Belloni
commit 84e871660bebfddb9a62ebd6f19d02536e782f0a upstream. at91rm9200 standby and suspend to ram has been broken since 00482a4078f4. It is wrongly using AT91_BASE_SYS which is a physical address and actually doesn't correspond to any register on at91rm9200. Use the correct at91_ramc_base[0] instead. Fixes: 00482a4078f4 (ARM: at91: implement the standby function for pm/cpuidle) Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26powerpc/smp: Wait until secondaries are active & onlineMichael Ellerman
commit 875ebe940d77a41682c367ad799b4f39f128d3fa upstream. Anton has a busy ppc64le KVM box where guests sometimes hit the infamous "kernel BUG at kernel/smpboot.c:134!" issue during boot: BUG_ON(td->cpu != smp_processor_id()); Basically a per CPU hotplug thread scheduled on the wrong CPU. The oops output confirms it: CPU: 0 Comm: watchdog/130 The problem is that we aren't ensuring the CPU active bit is set for the secondary before allowing the master to continue on. The master unparks the secondary CPU's kthreads and the scheduler looks for a CPU to run on. It calls select_task_rq() and realises the suggested CPU is not in the cpus_allowed mask. It then ends up in select_fallback_rq(), and since the active bit isnt't set we choose some other CPU to run on. This seems to have been introduced by 6acbfb96976f "sched: Fix hotplug vs. set_cpus_allowed_ptr()", which changed from setting active before online to setting active after online. However that was in turn fixing a bug where other code assumed an active CPU was also online, so we can't just revert that fix. The simplest fix is just to spin waiting for both active & online to be set. We already have a barrier prior to set_cpu_online() (which also sets active), to ensure all other setup is completed before online & active are set. Fixes: 6acbfb96976f ("sched: Fix hotplug vs. set_cpus_allowed_ptr()") Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26x86/vdso: Fix the build on GCC5Jiri Slaby
commit e893286918d2cde3a94850d8f7101cd1039e0c62 upstream. On gcc5 the kernel does not link: ld: .eh_frame_hdr table[4] FDE at 0000000000000648 overlaps table[5] FDE at 0000000000000670. Because prior GCC versions always emitted NOPs on ALIGN directives, but gcc5 started omitting them. .LSTARTFDEDLSI1 says: /* HACK: The dwarf2 unwind routines will subtract 1 from the return address to get an address in the middle of the presumed call instruction. Since we didn't get here via a call, we need to include the nop before the real start to make up for it. */ .long .LSTART_sigreturn-1-. /* PC-relative start address */ But commit 69d0627a7f6e ("x86 vDSO: reorder vdso32 code") from 2.6.25 replaced .org __kernel_vsyscall+32,0x90 by ALIGN right before __kernel_sigreturn. Of course, ALIGN need not generate any NOP in there. Esp. gcc5 collapses vclock_gettime.o and int80.o together with no generated NOPs as "ALIGN". So fix this by adding to that point at least a single NOP and make the function ALIGN possibly with more NOPs then. Kudos for reporting and diagnosing should go to Richard. Reported-by: Richard Biener <rguenther@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1425543211-12542-1-git-send-email-jslaby@suse.cz Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26x86/fpu: Drop_fpu() should not assume that tsk equals currentOleg Nesterov
commit f4c3686386393c120710dd34df2a74183ab805fd upstream. drop_fpu() does clear_used_math() and usually this is correct because tsk == current. However switch_fpu_finish()->restore_fpu_checking() is called before __switch_to() updates the "current_task" variable. If it fails, we will wrongly clear the PF_USED_MATH flag of the previous task. So use clear_stopped_child_used_math() instead. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Borislav Petkov <bp@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Pekka Riikonen <priikone@iki.fi> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Suresh Siddha <sbsiddha@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20150309171041.GB11388@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26x86/fpu: Avoid math_state_restore() without used_math() in ↵Oleg Nesterov
__restore_xstate_sig() commit a7c80ebcac3068b1c3cb27d538d29558c30010c8 upstream. math_state_restore() assumes it is called with irqs disabled, but this is not true if the caller is __restore_xstate_sig(). This means that if ia32_fxstate == T and __copy_from_user() fails, __restore_xstate_sig() returns with irqs disabled too. This triggers: BUG: sleeping function called from invalid context at kernel/locking/rwsem.c:41 dump_stack ___might_sleep ? _raw_spin_unlock_irqrestore __might_sleep down_read ? _raw_spin_unlock_irqrestore print_vma_addr signal_fault sys32_rt_sigreturn Change __restore_xstate_sig() to call set_used_math() unconditionally. This avoids enabling and disabling interrupts in math_state_restore(). If copy_from_user() fails, we can simply do fpu_finit() by hand. [ Note: this is only the first step. math_state_restore() should not check used_math(), it should set this flag. While init_fpu() should simply die. ] Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Pekka Riikonen <priikone@iki.fi> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Rik van Riel <riel@redhat.com> Cc: Suresh Siddha <sbsiddha@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20150307153844.GB25954@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26crypto: aesni - fix memory usage in GCM decryptionStephan Mueller
commit ccfe8c3f7e52ae83155cb038753f4c75b774ca8a upstream. The kernel crypto API logic requires the caller to provide the length of (ciphertext || authentication tag) as cryptlen for the AEAD decryption operation. Thus, the cipher implementation must calculate the size of the plaintext output itself and cannot simply use cryptlen. The RFC4106 GCM decryption operation tries to overwrite cryptlen memory in req->dst. As the destination buffer for decryption only needs to hold the plaintext memory but cryptlen references the input buffer holding (ciphertext || authentication tag), the assumption of the destination buffer length in RFC4106 GCM operation leads to a too large size. This patch simply uses the already calculated plaintext size. In addition, this patch fixes the offset calculation of the AAD buffer pointer: as mentioned before, cryptlen already includes the size of the tag. Thus, the tag does not need to be added. With the addition, the AAD will be written beyond the already allocated buffer. Note, this fixes a kernel crash that can be triggered from user space via AF_ALG(aead) -- simply use the libkcapi test application from [1] and update it to use rfc4106-gcm-aes. Using [1], the changes were tested using CAVS vectors to demonstrate that the crypto operation still delivers the right results. [1] http://www.chronox.de/libkcapi.html CC: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26sparc64: Fix several bugs in memmove().David S. Miller
[ Upstream commit 2077cef4d5c29cf886192ec32066f783d6a80db8 ] Firstly, handle zero length calls properly. Believe it or not there are a few of these happening during early boot. Next, we can't just drop to a memcpy() call in the forward copy case where dst <= src. The reason is that the cache initializing stores used in the Niagara memcpy() implementations can end up clearing out cache lines before we've sourced their original contents completely. For example, considering NG4memcpy, the main unrolled loop begins like this: load src + 0x00 load src + 0x08 load src + 0x10 load src + 0x18 load src + 0x20 store dst + 0x00 Assume dst is 64 byte aligned and let's say that dst is src - 8 for this memcpy() call. That store at the end there is the one to the first line in the cache line, thus clearing the whole line, which thus clobbers "src + 0x28" before it even gets loaded. To avoid this, just fall through to a simple copy only mildly optimized for the case where src and dst are 8 byte aligned and the length is a multiple of 8 as well. We could get fancy and call GENmemcpy() but this is good enough for how this thing is actually used. Reported-by: David Ahern <david.ahern@oracle.com> Reported-by: Bob Picco <bpicco@meloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26sparc: Touch NMI watchdog when walking cpus and calling printkDavid Ahern
[ Upstream commit 31aaa98c248da766ece922bbbe8cc78cfd0bc920 ] With the increase in number of CPUs calls to functions that dump output to console (e.g., arch_trigger_all_cpu_backtrace) can take a long time to complete. If IRQs are disabled eventually the NMI watchdog kicks in and creates more havoc. Avoid by telling the NMI watchdog everything is ok. Signed-off-by: David Ahern <david.ahern@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26sparc: perf: Make counting mode actually workDavid Ahern
[ Upstream commit d51291cb8f32bfae6b331e1838651f3ddefa73a5 ] Currently perf-stat (aka, counting mode) does not work: $ perf stat ls ... Performance counter stats for 'ls': 1.585665 task-clock (msec) # 0.580 CPUs utilized 24 context-switches # 0.015 M/sec 0 cpu-migrations # 0.000 K/sec 86 page-faults # 0.054 M/sec <not supported> cycles <not supported> stalled-cycles-frontend <not supported> stalled-cycles-backend <not supported> instructions <not supported> branches <not supported> branch-misses 0.002735100 seconds time elapsed The reason is that state is never reset (stays with PERF_HES_UPTODATE set). Add a call to sparc_pmu_enable_event during the added_event handling. Clean up the encoding since pmu_start calls sparc_pmu_enable_event which does the same. Passing PERF_EF_RELOAD to sparc_pmu_start means the call to sparc_perf_event_set_period can be removed as well. With this patch: $ perf stat ls ... Performance counter stats for 'ls': 1.552890 task-clock (msec) # 0.552 CPUs utilized 24 context-switches # 0.015 M/sec 0 cpu-migrations # 0.000 K/sec 86 page-faults # 0.055 M/sec 5,748,997 cycles # 3.702 GHz <not supported> stalled-cycles-frontend:HG <not supported> stalled-cycles-backend:HG 1,684,362 instructions:HG # 0.29 insns per cycle 295,133 branches:HG # 190.054 M/sec 28,007 branch-misses:HG # 9.49% of all branches 0.002815665 seconds time elapsed Signed-off-by: David Ahern <david.ahern@oracle.com> Acked-by: Bob Picco <bob.picco@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26sparc: perf: Remove redundant perf_pmu_{en|dis}able callsDavid Ahern
[ Upstream commit 5b0d4b5514bbcce69b516d0742f2cfc84ebd6db3 ] perf_pmu_disable is called by core perf code before pmu->del and the enable function is called by core perf code afterwards. No need to call again within sparc_pmu_del. Ditto for pmu->add and sparc_pmu_add. Signed-off-by: David Ahern <david.ahern@oracle.com> Acked-by: Bob Picco <bob.picco@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26sparc: semtimedop() unreachable due to comparison errorRob Gardner
[ Upstream commit 53eb2516972b8c4628651dfcb926cb9ef8b2864a ] A bug was reported that the semtimedop() system call was always failing eith ENOSYS. Since SEMCTL is defined as 3, and SEMTIMEDOP is defined as 4, the comparison "call <= SEMCTL" will always prevent SEMTIMEDOP from getting through to the semaphore ops switch statement. This is corrected by changing the comparison to "call <= SEMTIMEDOP". Orabug: 20633375 Signed-off-by: Rob Gardner <rob.gardner@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26sparc32: destroy_context() and switch_mm() needs to disable interrupts.Andreas Larsson
[ Upstream commit 66d0f7ec9f1038452178b1993fc07fd96d30fd38 ] Load balancing can be triggered in the critical sections protected by srmmu_context_spinlock in destroy_context() and switch_mm() and can hang the cpu waiting for the rq lock of another cpu that in turn has called switch_mm hangning on srmmu_context_spinlock leading to deadlock. So, disable interrupt while taking srmmu_context_spinlock in destroy_context() and switch_mm() so we don't deadlock. See also commit 77b838fa1ef0 ("[SPARC64]: destroy_context() needs to disable interrupts.") Signed-off-by: Andreas Larsson <andreas@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-18KVM: MIPS: Fix trace event to save PC directlyJames Hogan
commit b3cffac04eca9af46e1e23560a8ee22b1bd36d43 upstream. Currently the guest exit trace event saves the VCPU pointer to the structure, and the guest PC is retrieved by dereferencing it when the event is printed rather than directly from the trace record. This isn't safe as the printing may occur long afterwards, after the PC has changed and potentially after the VCPU has been freed. Usually this results in the same (wrong) PC being printed for multiple trace events. It also isn't portable as userland has no way to access the VCPU data structure when interpreting the trace record itself. Lets save the actual PC in the structure so that the correct value is accessible later. Fixes: 669e846e6c4e ("KVM/MIPS32: MIPS arch specific APIs for KVM") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: linux-mips@linux-mips.org Cc: kvm@vger.kernel.org Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-18KVM: emulate: fix CMPXCHG8B on 32-bit hostsPaolo Bonzini
commit 4ff6f8e61eb7f96d3ca535c6d240f863ccd6fb7d upstream. This has been broken for a long time: it broke first in 2.6.35, then was almost fixed in 2.6.36 but this one-liner slipped through the cracks. The bug shows up as an infinite loop in Windows 7 (and newer) boot on 32-bit hosts without EPT. Windows uses CMPXCHG8B to write to page tables, which causes a page fault if running without EPT; the emulator is then called from kvm_mmu_page_fault. The loop then happens if the higher 4 bytes are not 0; the common case for this is that the NX bit (bit 63) is 1. Fixes: 6550e1f165f384f3a46b60a1be9aba4bc3c2adad Fixes: 16518d5ada690643453eb0aef3cc7841d3623c2d Reported-by: Erik Rull <erik.rull@rdsoftware.de> Tested-by: Erik Rull <erik.rull@rdsoftware.de> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-18x86/asm/entry/64: Remove a bogus 'ret_from_fork' optimizationAndy Lutomirski
commit 956421fbb74c3a6261903f3836c0740187cf038b upstream. 'ret_from_fork' checks TIF_IA32 to determine whether 'pt_regs' and the related state make sense for 'ret_from_sys_call'. This is entirely the wrong check. TS_COMPAT would make a little more sense, but there's really no point in keeping this optimization at all. This fixes a return to the wrong user CS if we came from int 0x80 in a 64-bit task. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/4710be56d76ef994ddf59087aad98c000fbab9a4.1424989793.git.luto@amacapital.net [ Backported from tip:x86/asm. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06MIPS: Export FP functions used by lose_fpu(1) for KVMJames Hogan
commit 3ce465e04bfd8de9956d515d6e9587faac3375dc upstream. Export the _save_fp asm function used by the lose_fpu(1) macro to GPL modules so that KVM can make use of it when it is built as a module. This fixes the following build error when CONFIG_KVM=m due to commit f798217dfd03 ("KVM: MIPS: Don't leak FPU/DSP to guest"): ERROR: "_save_fp" [arch/mips/kvm/kvm.ko] undefined! Signed-off-by: James Hogan <james.hogan@imgtec.com> Fixes: f798217dfd03 (KVM: MIPS: Don't leak FPU/DSP to guest) Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Gleb Natapov <gleb@kernel.org> Cc: kvm@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/9260/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> [james.hogan@imgtec.com: Only export when CPU_R4K_FPU=y prior to v3.16, so as not to break the Octeon build which excludes FPU support. KVM depends on MIPS32r2 anyway.] Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06x86, mm/ASLR: Fix stack randomization on 64-bit systemsHector Marco-Gisbert
commit 4e7c22d447bb6d7e37bfe39ff658486ae78e8d77 upstream. The issue is that the stack for processes is not properly randomized on 64 bit architectures due to an integer overflow. The affected function is randomize_stack_top() in file "fs/binfmt_elf.c": static unsigned long randomize_stack_top(unsigned long stack_top) { unsigned int random_variable = 0; if ((current->flags & PF_RANDOMIZE) && !(current->personality & ADDR_NO_RANDOMIZE)) { random_variable = get_random_int() & STACK_RND_MASK; random_variable <<= PAGE_SHIFT; } return PAGE_ALIGN(stack_top) + random_variable; return PAGE_ALIGN(stack_top) - random_variable; } Note that, it declares the "random_variable" variable as "unsigned int". Since the result of the shifting operation between STACK_RND_MASK (which is 0x3fffff on x86_64, 22 bits) and PAGE_SHIFT (which is 12 on x86_64): random_variable <<= PAGE_SHIFT; then the two leftmost bits are dropped when storing the result in the "random_variable". This variable shall be at least 34 bits long to hold the (22+12) result. These two dropped bits have an impact on the entropy of process stack. Concretely, the total stack entropy is reduced by four: from 2^28 to 2^30 (One fourth of expected entropy). This patch restores back the entropy by correcting the types involved in the operations in the functions randomize_stack_top() and stack_maxrandom_size(). The successful fix can be tested with: $ for i in `seq 1 10`; do cat /proc/self/maps | grep stack; done 7ffeda566000-7ffeda587000 rw-p 00000000 00:00 0 [stack] 7fff5a332000-7fff5a353000 rw-p 00000000 00:00 0 [stack] 7ffcdb7a1000-7ffcdb7c2000 rw-p 00000000 00:00 0 [stack] 7ffd5e2c4000-7ffd5e2e5000 rw-p 00000000 00:00 0 [stack] ... Once corrected, the leading bytes should be between 7ffc and 7fff, rather than always being 7fff. Signed-off-by: Hector Marco-Gisbert <hecmargi@upv.es> Signed-off-by: Ismael Ripoll <iripoll@upv.es> [ Rebased, fixed 80 char bugs, cleaned up commit message, added test example and CVE ] Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Fixes: CVE-2015-1593 Link: http://lkml.kernel.org/r/20150214173350.GA18393@www.outflux.net Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06metag: Fix KSTK_EIP() and KSTK_ESP() macrosJames Hogan
commit c2996cb29bfb73927a79dc96e598a718e843f01a upstream. The KSTK_EIP() and KSTK_ESP() macros should return the user program counter (PC) and stack pointer (A0StP) of the given task. These are used to determine which VMA corresponds to the user stack in /proc/<pid>/maps, and for the user PC & A0StP in /proc/<pid>/stat. However for Meta the PC & A0StP from the task's kernel context are used, resulting in broken output. For example in following /proc/<pid>/maps output, the 3afff000-3b021000 VMA should be described as the stack: # cat /proc/self/maps ... 100b0000-100b1000 rwxp 00000000 00:00 0 [heap] 3afff000-3b021000 rwxp 00000000 00:00 0 And in the following /proc/<pid>/stat output, the PC is in kernel code (1074234964 = 0x40078654) and the A0StP is in the kernel heap (1335981392 = 0x4fa17550): # cat /proc/self/stat 51 (cat) R ... 1335981392 1074234964 ... Fix the definitions of KSTK_EIP() and KSTK_ESP() to use task_pt_regs(tsk)->ctx rather than (tsk)->thread.kernel_context. This gets the registers from the user context stored after the thread info at the base of the kernel stack, which is from the last entry into the kernel from userland, regardless of where in the kernel the task may have been interrupted, which results in the following more correct /proc/<pid>/maps output: # cat /proc/self/maps ... 0800b000-08070000 r-xp 00000000 00:02 207 /lib/libuClibc-0.9.34-git.so ... 100b0000-100b1000 rwxp 00000000 00:00 0 [heap] 3afff000-3b021000 rwxp 00000000 00:00 0 [stack] And /proc/<pid>/stat now correctly reports the PC in libuClibc (134320308 = 0x80190b4) and the A0StP in the [stack] region (989864576 = 0x3b002280): # cat /proc/self/stat 51 (cat) R ... 989864576 134320308 ... Reported-by: Alexey Brodkin <Alexey.Brodkin@synopsys.com> Reported-by: Vineet Gupta <Vineet.Gupta1@synopsys.com> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06arm64: compat Fix siginfo_t -> compat_siginfo_t conversion on big endianCatalin Marinas
commit 9d42d48a342aee208c1154696196497fdc556bbf upstream. The native (64-bit) sigval_t union contains sival_int (32-bit) and sival_ptr (64-bit). When a compat application invokes a syscall that takes a sigval_t value (as part of a larger structure, e.g. compat_sys_mq_notify, compat_sys_timer_create), the compat_sigval_t union is converted to the native sigval_t with sival_int overlapping with either the least or the most significant half of sival_ptr, depending on endianness. When the corresponding signal is delivered to a compat application, on big endian the current (compat_uptr_t)sival_ptr cast always returns 0 since sival_int corresponds to the top part of sival_ptr. This patch fixes copy_siginfo_to_user32() so that sival_int is copied to the compat_siginfo_t structure. Reported-by: Bamvor Jian Zhang <bamvor.zhangjian@huawei.com> Tested-by: Bamvor Jian Zhang <bamvor.zhangjian@huawei.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06hx4700: regulator: declare full constraintsMartin Vajnar
commit a52d209336f8fc7483a8c7f4a8a7d2a8e1692a6c upstream. Since the removal of CONFIG_REGULATOR_DUMMY option, the touchscreen stopped working. This patch enables the "replacement" for REGULATOR_DUMMY and allows the touchscreen to work even though there is no regulator for "vcc". Signed-off-by: Martin Vajnar <martin.vajnar@gmail.com> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
